03-Typical Configuration Example
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration ExamplesH3C SR8800-X Routers Configuration Examples All-In-One-R838x-6W10203-Typical Configuration Example
Table of Contents
Related Documents
51-Bidirectional NAT and NAT Server Configuration Examples
Example: Configuring bidirectional NAT and NAT Server
As shown in Figure 1, Host A accesses the Internet after NAT on Device A. A CGN card is installed on slot 2 of Device A, which provides address translation. The company uses private IP addresses on network 192.168.1.0/24 and public IP address 202.38.1.100 to provide FTP services.
Configure bidirectional NAT and NAT Server to meet the following requirements:
·     Both Host A and Host B can access the FTP server by using IP address 202.38.1.100 and port 21.
·     Only users on subnet 192.168.1.0/24 can access the Internet by using public IP addresses 202.38.1.2 and 202.38.1.3.
Figure 1 Network diagram
Procedures
Configuring Device A
1.     Specify IPv4 addresses for the interfaces on Device A.
[DeviceA] interface ten-gigabitethernet 3/1/1
[DeviceA-Ten-GigabitEthernet3/1/1] ip address 192.168.1.1 255.255.255.0
[DeviceA-Ten-GigabitEthernet3/1/1] quit
[DeviceA] interface ten-gigabitethernet 3/1/2
[DeviceA-Ten-GigabitEthernet3/1/2] ip address 202.38.1.10 255.255.255.0
[DeviceA-Ten-GigabitEthernet3/1/2] quit
2.     Configure an ACL:
# Configure ACL 3002 to permit all packets.
[DeviceA] acl advanced 3002
[DeviceA-acl-ipv4-adv-3002] rule 5 permit ip source any
[DeviceA-acl-ipv4-adv-3002] quit
3.     Configure a failover group:
# Specify the CGN card in slot 2 as the primary node in failover group cgn1.
[DeviceA] failover group cgn1 id 1
[DeviceA-failover-group-cgn] bind slot 2 primary
[DeviceA-failover-group-cgn] quit
4.     Create service instance group 1 and associate it with failover group cgn1.
[[DeviceA] service-instance-group 1
[DeviceA-service-instance-group 1] failover-group cgn1
[DeviceA-service-instance-group 1] quit
5.     Configure an address group:
# Configure address group 0 and add an address range from 202.38.1.2 to 202.38.1.3.
[DeviceA] nat address-group 0
[DeviceA-address-group-0] address 202.38.1.2 202.38.1.3
[DeviceA-address-group-0] quit
6.     Configure a NAT instance:
# Create a NAT instance named a with ID 1.
[DeviceA] nat instance a id 1
# Associate NAT instance a with service instance group 1.
[DeviceA-nat-instance-a] service-instance-group 1
# Configure outbound dynamic NAT to use NAT address group 0 to translate packets permitted by ACL 3002.
[DeviceA-nat-instance-a] nat outbound 3002 address-group 0
# Configure a NAT server mapping to allow external users to access the FTP server by using the address 202.38.1.100 and port 21.
[DeviceA-nat-instance-a] nat server protocol tcp global 202.38.1.100 21 inside 192.168.1.3 ftp
[Device-nat-instance-a] quit
7.     Configure a QoS policy to redirect traffic to the NAT instance for address translation:
# Configure traffic class cgn and traffic behavior cgn.
[DeviceA] traffic classifier cgn operator and
[DeviceA-classifier-cgn] if-match acl 3002
[DeviceA-classifier-cgn] quit
[DeviceA] traffic behavior cgn
[DeviceA-behavior-cgn] bind nat-instance a
[DeviceA-behavior-cgn] quit
# Create QoS policy cgn and associate the traffic class with the traffic behavior.
[DeviceA] qos policy cgn
[DeviceA-qospolicy-cgn] classifier cgn behavior cgn
[DeviceA-qospolicy-cgn] quit
# Apply the QoS policy to the inbound traffic on Ten-GigabitEthernet3/1/1.
[DeviceA-Ten-GigabitEthernet3/1/1] qos apply policy cgn inbound
Configuring Host B
Make sure Host B and Device A can reach each other.
# Access the FTP server by using IP address 202.38.1.100 and port 21 on Host A. Display NAT session information generated on Device A when Host A accesses the FTP server.
[DeviceA] display nat session verbose
Slot 2:
Initiator:
  Source      IP/port: 192.168.1.2/22213
  Destination IP/port: 202.38.1.100/21
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: Ten-GigabitEthernet3/1/1
Responder:
  Source      IP/port: 192.168.1.3/21
  Destination IP/port: 202.38.1.3/1024
  Protocol: TCP(6)
State: TCP_ESTABLISHED
Application: FTP
Role: Master
Failover group ID: 1
Start time: 2023-03-06 15:40:47    TTL: 3592s
Initiator->Responder:            0 packets          0 bytes
Responder->Initiator:            0 packets          0 bytes
Total sessions found: 1
# Enter the IP address of the WWW server in the address bar of the Web browser on Host A. Display NAT session information generated on Device A when Host A accesses the WWW server.
Slot 2:
Initiator:
  Source      IP/port: 192.168.1.2/4481
  Destination IP/port: 200.1.1.20/80
  Protocol: TCP(6)
Responder:
  Source      IP/port: 200.1.1.20/80
  Destination IP/port: 202.38.1.2/1029
  Protocol: TCP(6)
  Inbound interface: Ten-GigabitEthernet3/1/2
Application: HTTP
Role: Master
Start time: 2023-03-06 15:50:33    TTL: 3583s
# Access the FTP server by using IP address 202.38.1.100 and port 21 on Host B. Display NAT session information generated on Device A when Host B accesses the FTP server.
Slot 2:
Initiator:
  Source      IP/port: 200.1.1.10/60738
  Protocol: TCP(6)
Responder:
  Destination IP/port: 200.1.1.10/60738
  Protocol: TCP(6)
Application: FTP
Role: Master
Start time: 2023-03-06 15:55:40    TTL: 3593s
Configuration files
Device A:
 bind slot 2 primary
 failover-group cgn1
nat instance a id 1
 nat server protocol tcp global 202.38.1.100 21 inside 192.168.1.3 21
 if-match acl 3002
 bind nat-instance a
qos policy cgn
interface Ten-GigabitEthernet3/1/1
interface Ten-GigabitEthernet3/1/2
nat address-group 0
acl advanced 3002
 rule 5 permit ip
