- 03-Typical Configuration Example
- 01-H3C_AAA_Configuration_Examples
- 02-H3C_ACL_Configuration_Examples
- 03-H3C_ATM_Configuration_Examples
- 04-H3C_IGMP_Configuration_Examples
- 05-H3C_IP_Source_Guard_Configuration_Examples
- 06-H3C_Ethernet_OAM_Configuration_Examples
- 07-H3C_NQA_Configuration_Examples
- 08-H3C_QinQ_Configuration_Examples
- 09-H3C_OSPF_Configuration_Examples
- 10-H3C_MPLS_TE_Configuration_Examples
- 11-H3C_OpenFlow_Configuration_Examples
- 12-H3C_NAT_Configuration_Examples
- 13-H3C_RBAC_Configuration_Examples
- 14-H3C_IRF_Configuration_Examples
- 15-H3C_POS_Interface_Configuration_Examples
- 16-H3C_CPOS_Interface_Configuration_Examples
- 17-H3C_DHCP_Relay_Redundancy_Configuration_Examples
- 18-H3C_DLDP_Configuration_Examples
- 19-H3C_IS-IS_Configuration_Examples
- 20-H3C_MPLS_L3VPN_Configuration_Examples
- 21-H3C_SSH_Configuration_Examples
- 22-H3C_Login_Management_Configuration_Examples
- 23-H3C_SNMP_Configuration_Examples
- 24-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 25-H3C_Multicast_VPN_Configuration_Examples
- 26-H3C_BGP_Configuration_Examples
- 27-H3C_HoVPN_Configuration_Examples
- 28-H3C_L2TP_Configuration_Examples
- 29-H3C_VRRP_Configuration_Examples
- 30-H3C_Traffic_Filtering_Configuration_Examples
- 31-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
- 32-H3C_Software_Upgrade_Examples
- 33-H3C_MPLS_L2VPN_Configuration_Examples
- 34-H3C_NetStream_Configuration_Examples
- 35-H3C_Policy-Based_Routing_Configuration_Examples
- 36-H3C_Traffic_Policing_Configuration_Examples
- 37-H3C_BFD_Configuration_Examples
- 38-H3C_OSPFv3_Configuration_Examples
- 39-H3C_VPLS_Configuration_Examples
- 40-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 41-H3C_IPv6_IS-IS_Configuration_Examples
- 42-H3C_MPLS OAM_Configuration_Examples
- 43-H3C_BGP_Route_Selection_Configuration_Examples
- 44-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 45-H3C_SRv6 Configuration Examples
- 46-H3C_Attack_Protection_Configuration_Examples
- 47-H3C_OSPF_Multi-Process_Configuration_Examples
- 48-H3C_OSPF_with_Multi-Instance_Configuration_Examples
- 49-H3C_ARP_Attack_Protection_Configuration_Examples
- 50-H3C_DHCPv6_Server_and_DHCPv6_Prefix_Client_Configuration_Examples
- 51-Bidirectional NAT and NAT Server Configuration Examples
- 52-Bidirectional NAT and NAT Server With Easy IP Configuration Examples (Global NAT)
- 53-CE1 Interface Connection Configuration Examples
- 54-General QoS Configuration Examples
- 55-GRE Tunnel Establishment Using OSPF Configuration Examples
- 56-GRE Tunnel Establishment Using Static Routes Configuration Examples
- 57-Internal Users Accessing the External Network Configuration Examples
- 58-OSPF over IPsec for Overseas Branch Access Configuration Examples
- 59-QoS Configuration Examples for the Financial Industry
| 23-H3C_SNMP_Configuration_Examples | 221.28 KB |
Introduction
This document provides SNMP configuration examples.
This document assumes that you have basic knowledge of SNMP.
Example: Configuring SNMPv1 or SNMPv2c
SNMPv1 and SNMPv2c use the same configuration procedure. This example configures SNMPv2c.
As shown in Figure 1, configure the server that acts as the NMS to back up the configuration file of the device over SNMPv2 and enable the device to automatically report events to the NMS.
Follow these restrictions and guidelines for the configuration:
· For the NMS to manage the device, configure the same SNMP version and community names on the device and NMS.
· The NMS software configuration varies by vendor. This example uses IMC PLAT 7.0 (E0202).
Procedures
Configuring the device
# Specify SNMPv2c, and create read-only community readtest and read and write community writetest.
<Agent> system-view
[Agent] snmp-agent sys-info version v2c
[Agent] snmp-agent community read readtest
[Agent] snmp-agent community write writetest
# Configure contact and physical location information for the agent.
[Agent] snmp-agent sys-info contact Mr.Wang-Tel:3306
[Agent] snmp-agent sys-info location telephone-closet,3rd-floor
[Agent] snmp-agent trap enable
[Agent] snmp-agent target-host trap address udp-domain 192.168.100.4 params securityname traptest
Configuring the NMS
1. Add the device to IMC:
b. From the navigation tree, select Resource Management > Add Device.
c. On the Add Device page, configure the following parameters:
- Enter 192.168.100.68 in the Host Name/IP field.
- Use the default values for other parameters.
Figure 2 Adding a device
2. Configure SNMP parameters:
a. Expand the SNMP Settings area.
b. Click Configure.
c. On the page that opens, configure the following parameters:
- Select SNMPv2c from the Parameter Type list.
- Enter readtest in the Read-Only Community String field.
- Enter writetest in the Read-Write Community String field.
- Click OK.
Figure 3 Configuring SNMP parameters
3. On the Add Device page, click OK.
The device is successfully added to IMC, as shown in Figure 4.
1. Verify that the agent sends notifications to the NMS when the link state of an interface changes:
a. Execute the shutdown or undo shutdown command on an idle interface to shut down or bring up the interface.
b. Click the Alarm tab.
c. From the navigation tree, select Alarm Browse > All Alarms.
You can see the alarms in Figure 5.
2. Back up the agent configuration file:
a. Click the Resource tab.
b. From the navigation tree, select Device View.
c. On the page that opens, click the device label link Agent(192.168.100.68).
d. On the Configuration Center menu, select Backup Configuration File.
The system displays the backup result as shown in Figure 6 if the operation succeeds.
Figure 6 Configuration file backup result
Configuration files
snmp-agent
Example: Configuring SNMPv3
As shown in Figure 7, configure the server that acts as the NMS to back up the configuration file of the device over SNMPv3 and enable the device to automatically report events to the NMS.
· Configure the NMS and device separately and ensure that they have consistent SNMP settings.
· When configuring the notification target host, use an existing SNMPv3 username as the security parameter and make sure the agent and NMS use the same security model.
Procedures
# Enable SNMPv3.
<Agent> system-view
[Agent] snmp-agent sys-info version v3
# Include the mib-2 (OID 1.3.6.1) subtree in the mibtest view.
[Agent] snmp-agent mib-view included mibtest 1.3.6.1
# Create SNMPv3 group managev3group, and specify the authentication with privacy security model for the group. Assign the group read, write, and notification accesses to the mibtest view.
[Agent] snmp-agent group v3 managev3group privacy read-view mibtest write-view mibtest notify-view mibtest
# Add user managev3user to SNMPv3 group managev3group, and set the authentication algorithm to sha, authentication key to 123456TESTauth&!, encryption algorithm to aes128, and encryption key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user managev3group simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Enable SNMP notifications.
# Configure the SNMP agent to send SNMP notifications to an NMS at 192.168.100.4 by using username managev3user.
[Agent] snmp-agent target-host trap address udp-domain 192.168.100.4 params securityname managev3user v3 privacy
Configuring the NMS
1. Add an SNMP template:
a. Click the System tab.
b. From the navigation tree, select Resource Management > SNMP Template.
c. On the SNMP Template page, click Add.
d. On the Add SNMP Template page, configure the following parameters:
- Enter SNMPv3 in the Name field.
- Select SNMPv3 Priv-Aes128 Auth-Sha from the Parameter Type list.
- Enter managev3user in the Username field.
- Enter 123456TESTauth&! in the Authentication Password field.
- Enter 123456TESTencr&! in the Encryption Password field.
- Click OK.
Figure 8 Adding an SNMP template
2. Add the device to IMC:
Figure 9 Adding a device
3. Configure SNMP parameters:
b. Click Configure.
c. Select the Select an Existing Template option.
d. Select template name SNMPv3.
e. Click OK.
Figure 10 Selecting an existing template
4. On the Add Device page, click OK.
The device is successfully added to IMC, as shown in Figure 11.
You can see the alarms in Figure 12.
2. Back up the agent configuration file on the NMS:
The system displays the backup result as shown in Figure 13 if the operation succeeds.
Figure 13 Configuration file backup result
Configuration files
snmp-agent mib-view included mibtest internet
snmp-agent usm-user v3 managev3user managev3group cipher authentication-mode sha $c$3$5JaJZ6gNXlyNRq2FR2ELDT3QQH1exwJRWdYYq7eLfcBewuM5ncM= privacy-mode aes128 $c$3$+bbXZS4+PnsLDyr16OogzBckaLzR6XMDwZQuLBU8RM+dpw==
Related documentation
· H3C SR8800-X Routers Network Management and Monitoring Configuration Guide-R8380
· H3C SR8800-X Routers Network Management and Monitoring Command Reference-R8380
