- 11-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-EVC-MIB
- 04-HH3C-L2VPN-MIB
- 05-HH3C-L3VPN-MIB
- 06-HH3C-MPLS-LDP-MIB
- 07-HH3C-MPLS-VPN-BGP-MIB
- 08-HH3C-MPLSCRLSP-MIB
- 09-HH3C-MPLSEXT-MIB
- 10-HH3C-VSI-MIB
- 11-HH3C-MPLSTE-MIB
- 12-HH3C-MPLSSLSP-MIB
- 13-HH3C-MPLSPCE-MIB
- 14-MPLS-FRR-FACILITY-STD-MIB
- 15-MPLS-FRR-GENERAL-STD-MIB
- 16-MPLS-FTN-STD-MIB
- 17-MPLS-L3VPN-STD-MIB
- 18-MPLS-LDP-STD-MIB
- 19-MPLS-LSR-STD-MIB
- 20-MPLS-TE-STD-MIB
- 21-PW-ENET-STD-MIB
- 22-PW-MPLS-STD-MIB
- 23-PW-STD-MIB
- 24-TE-MIB
| 21-PW-ENET-STD-MIB | 62.44 KB |
PW-ENET-STD-MIB
About this MIB
Use this MIB to configure Ethernet PW related settings.
MIB file name
rfc5603-pw-enet-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pwEnetStdMIB(180)
Tabular objects
pwEnetTable
About this table
This table contains the AC configuration for Ethernet PW.
Support for operations
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table indexes are pwIndex and pwEnetPwInstance.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwEnetPwInstance (1.3.6.1.2.1.180.1.1.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (0..4294967295) |
Index of an AC configuration entry for an Ethernet PW. |
As per the MIB. |
pwEnetPwVlan (1.3.6.1.2.1.180.1.1.1.2) |
read-create |
VlanIdOrAnyOrNone |
Integer32 (0 | 1..4094 | 4095) |
Negotiated VLAN ID. |
As per the MIB. |
pwEnetVlanMode (1.3.6.1.2.1.180.1.1.1.3) |
read-create |
INTEGER |
other(0), portBased(1), noChange(2), changeVlan(3), addVlan(4), removeVlan(5) |
VLAN handling mode. |
As per the MIB. |
pwEnetPortVlan (1.3.6.1.2.1.180.1.1.1.4) |
read-create |
VlanIdOrAnyOrNone |
Port VLAN ID. |
As per the MIB. |
pwEnetPortIfIndex (1.3.6.1.2.1.180.1.1.1.5) |
read-create |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
Index of the Ethernet port. |
As per the MIB. |
pwEnetRowStatus (1.3.6.1.2.1.180.1.1.1.7) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
pwEnetStorageType (1.3.6.1.2.1.180.1.1.1.8) |
read-create |
StorageType |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type for the AC configuration entry. |
Supports only the read operation. The value is always nonVolatile(3). |
