- 11-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-EVC-MIB
- 04-HH3C-L2VPN-MIB
- 05-HH3C-L3VPN-MIB
- 06-HH3C-MPLS-LDP-MIB
- 07-HH3C-MPLS-VPN-BGP-MIB
- 08-HH3C-MPLSCRLSP-MIB
- 09-HH3C-MPLSEXT-MIB
- 10-HH3C-VSI-MIB
- 11-HH3C-MPLSTE-MIB
- 12-HH3C-MPLSSLSP-MIB
- 13-HH3C-MPLSPCE-MIB
- 14-MPLS-FRR-FACILITY-STD-MIB
- 15-MPLS-FRR-GENERAL-STD-MIB
- 16-MPLS-FTN-STD-MIB
- 17-MPLS-L3VPN-STD-MIB
- 18-MPLS-LDP-STD-MIB
- 19-MPLS-LSR-STD-MIB
- 20-MPLS-TE-STD-MIB
- 21-PW-ENET-STD-MIB
- 22-PW-MPLS-STD-MIB
- 23-PW-STD-MIB
- 24-TE-MIB
| 09-HH3C-MPLSEXT-MIB | 135.33 KB |
mplsTunnelConfigured (1.3.6.1.2.1.10.166.3.1.1)
mplsTunnelActive (1.3.6.1.2.1.10.166.3.1.2)
mplsTunnelTEDistProto (1.3.6.1.2.1.10.166.3.1.3)
mplsTunnelMaxHops (1.3.6.1.2.1.10.166.3.1.4)
mplsTunnelNotificationMaxRate (1.3.6.1.2.1.10.166.3.1.5)
mplsTunnelIndexNext (1.3.6.1.2.1.10.166.3.2.1)
mplsTunnelHopListIndexNext (1.3.6.1.2.1.10.166.3.2.3)
mplsTunnelResourceIndexNext (1.3.6.1.2.1.10.166.3.2.5)
mplsTunnelNotificationEnable (1.3.6.1.2.1.10.166.3.2.11)
HH3C-MPLSEXT-MIB
About this MIB
Use this MIB to manage MPLS and LDP capabilities and MPLS BFD sessions.
MIB file name
rfc3812-mpls-te-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsTeStdMIB(3)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelConfigured (1.3.6.1.2.1.10.166.3.1.1) |
read-only |
Integer32 |
Integer32 (0..4294967295) |
Number of configured tunnels. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelActive (1.3.6.1.2.1.10.166.3.1.2) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Number of active tunnels. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelTEDistProto (1.3.6.1.2.1.10.166.3.1.3) |
read-only |
BITS |
other(0) ospf(1) isis(2) |
IGP used to advertise link information. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelMaxHops (1.3.6.1.2.1.10.166.3.1.4) |
read-only |
Unsigned32 |
Unsigned32 (255) |
Maximum number of hops allowed by a tunnel. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelNotificationMaxRate (1.3.6.1.2.1.10.166.3.1.5) |
read-write |
Unsigned32 |
Tunnel advertisement frequency. |
Supports only the read operation. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelIndexNext (1.3.6.1.2.1.10.166.3.2.1) |
read-only |
Unsigned32 |
Unsigned32 (0..65535) |
Next tunnel index. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelHopListIndexNext (1.3.6.1.2.1.10.166.3.2.3) |
read-only |
Unsigned32 |
Appropriate value to be used for mplsTunnelHopListIndex when creating entries in the mplsTunnelHopTable. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelResourceIndexNext (1.3.6.1.2.1.10.166.3.2.5) |
read-only |
Unsigned32 |
Unsigned32 (0..2147483647 |
Next resource table index. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelNotificationEnable (1.3.6.1.2.1.10.166.3.2.11) |
read-write |
TruthValue |
true(1), false(2) |
Whether MPLS TE notification is enabled. |
As per the MIB. |
Tabular objects
mplsTunnelTable
About this table
This table allows you to create new MPLS tunnels between an LSR and a remote endpoint and delete existing tunnels.
Support for operations
Create:You can create only tunnel interfaces. To create a tunnel interface, configure mplsTunnelIndex, mplsTunnelInstance, mplsTunnelIngressLSRId, and mplsTunnelEgressLSRId, and use the default settings for other objects. The value of the mplsTunnelInstance object must be 0.
To create a static tunnel interface, associate it with a static CRLSP.
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table indexes are mplsTunnelIndex, mplsTunnelInstance, mplsTunnelIngressLSRId, and mplsTunnelEgressLSRId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelIndex (1.3.6.1.2.1.10.166.3.2.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
Tunnel index. |
As per the MIB. |
mplsTunnelInstance (1.3.6.1.2.1.10.166.3.2.2.1.2) |
not-accessible |
Unsigned32 |
Tunnel instance ID. |
As per the MIB. |
mplsTunnelIngressLSRId (1.3.6.1.2.1.10.166.3.2.2.1.3) |
not-accessible |
Unsigned32 |
Router ID of the ingress LSR. |
As per the MIB. |
mplsTunnelEgressLSRId (1.3.6.1.2.1.10.166.3.2.2.1.4) |
not-accessible |
Unsigned32 |
Router ID of the egress LSR. |
As per the MIB. |
mplsTunnelName (1.3.6.1.2.1.10.166.3.2.2.1.5) |
read-create |
Octet String |
Octet String (0..255) |
Tunnel name. |
As per the MIB. |
mplsTunnelDescr (1.3.6.1.2.1.10.166.3.2.2.1.6) |
read-create |
Octet String |
Tunnel description. |
As per the MIB. |
mplsTunnelIsIf (1.3.6.1.2.1.10.166.3.2.2.1.7) |
read-create |
TruthValue |
true(1), false(2) |
Tunnel. |
As per the MIB. |
mplsTunnelIfIndex (1.3.6.1.2.1.10.166.3.2.2.1.8) |
read-only |
Integer32 |
Integer32 (0..2147483647 |
Tunnel interface index. |
As per the MIB. |
mplsTunnelOwner (1.3.6.1.2.1.10.166.3.2.2.1.9) |
read-only |
Integer |
unknown(1), other(2), snmp(3), ldp(4), crldp(5), rsvpTe(6), policyAgent(7) |
Tunnel owner. |
As per the MIB. |
mplsTunnelRole (1.3.6.1.2.1.10.166.3.2.2.1.10) |
read-create |
Integer |
head(1), transit(2), tail(3), headTail(4) |
Role that this tunnel entry/instance represents. |
The value of Set operation is head(1). |
mplsTunnelXCPointer (1.3.6.1.2.1.10.166.3.2.2.1.11) |
read-create |
Object Identifier |
Standard MIB values. |
Pointer to a row in the mplsXCTable. |
As per the MIB. |
mplsTunnelSignallingProto (1.3.6.1.2.1.10.166.3.2.2.1.12) |
read-create |
Integer |
none(1), rsvp(2), crldp(3), other(4) |
Tunnel signaling protocol. |
Supports only rsvp(2) and other(4). |
mplsTunnelSetupPrio (1.3.6.1.2.1.10.166.3.2.2.1.13) |
read-create |
Integer32 |
Integer32 (0..7) |
Tunnel setup priority. |
As per the MIB. |
mplsTunnelHoldingPrio (1.3.6.1.2.1.10.166.3.2.2.1.14) |
read-create |
Integer32 |
Integer32 (0..7) |
Tunnel holding priority. |
As per the MIB. |
mplsTunnelSessionAttributes (1.3.6.1.2.1.10.166.3.2.2.1.15) |
read-create |
BITS |
fastReroute (0), mergingPermitted (1), isPersistent (2), isPinned (3), recordRoute(4) |
Tunnel session attributes. |
As per the MIB. |
mplsTunnelLocalProtectInUse (1.3.6.1.2.1.10.166.3.2.2.1.16) |
read-create |
TruthValue |
true(1), false(2) |
Whether local protection is enabled for the tunnel. |
As per the MIB. |
mplsTunnelResourcePointer (1.3.6.1.2.1.10.166.3.2.2.1.17) |
read-create |
Object Identifier |
Tunnel resource pointer. |
mplsTunnelPrimaryInstance (1.3.6.1.2.1.10.166.3.2.2.1.18) |
read-only |
Unsigned32 |
Unsigned32 (0..2147483647) |
Primary instance of the tunnel. |
As per the MIB. |
mplsTunnelInstancePriority (1.3.6.1.2.1.10.166.3.2.2.1.19) |
read-create |
Unsigned32 |
Tunnel instance priority. |
Not supported. The value is fixed at 1. |
mplsTunnelHopTableIndex (1.3.6.1.2.1.10.166.3.2.2.1.20) |
read-create |
Unsigned32 |
Hop table index. |
mplsTunnelPathInUse (1.3.6.1.2.1.10.166.3.2.2.1.21) |
read-create |
Unsigned32 |
Path used by the tunnel. |
mplsTunnelARHopTableIndex (1.3.6.1.2.1.10.166.3.2.2.1.22) |
read-only |
Unsigned32 |
ARHop table index. |
As per the MIB. |
mplsTunnelCHopTableIndex (1.3.6.1.2.1.10.166.3.2.2.1.23) |
read-only |
Unsigned32 |
Chop table index. |
As per the MIB. |
mplsTunnelIncludeAnyAffinity (1.3.6.1.2.1.10.166.3.2.2.1.24) |
read-create |
Unsigned32 |
IncludeAny affinity attribute. |
As per the MIB. |
mplsTunnelIncludeAllAffinity (1.3.6.1.2.1.10.166.3.2.2.1.25) |
read-create |
Unsigned32 |
IncludeAll affinity attribute. |
The value is fixed at 0. If set to other values, this parameter will be ignored. This value can be obtained after the path for the MPLS TE tunnel is established. |
mplsTunnelExcludeAnyAffinity (1.3.6.1.2.1.10.166.3.2.2.1.26) |
read-create |
Unsigned32 |
A link satisfies the exclude-any constraint if and only if the link contains none of the administrative groups specified in the constraint. |
As per the MIB. |
mplsTunnelTotalUpTime (1.3.6.1.2.1.10.166.3.2.2.1.27) |
read-only |
TimeTicks |
Aggregate up time for all instances of this tunnel, if available. |
As per the MIB. |
mplsTunnelInstanceUpTime (1.3.6.1.2.1.10.166.3.2.2.1.28) |
read-only |
TimeTicks |
Total time that the tunnel instance's operStatus has been Up(1). |
As per the MIB. |
mplsTunnelPrimaryUpTime (1.3.6.1.2.1.10.166.3.2.2.1.29) |
read-only |
TimeTicks |
Total time the primary instance of the tunnel has been active. |
As per the MIB. |
mplsTunnelPathChanges (1.3.6.1.2.1.10.166.3.2.2.1.30) |
read-only |
Counter32 |
Number of times the actual path for the tunnel instance has changed. |
As per the MIB. |
mplsTunnelLastPathChange (1.3.6.1.2.1.10.166.3.2.2.1.31) |
read-only |
TimeTicks |
Time since the last change to the actual path for the tunnel instance. |
As per the MIB. |
mplsTunnelCreationTime (1.3.6.1.2.1.10.166.3.2.2.1.32) |
read-only |
TimeTicks |
Time when the tunnel was created. |
As per the MIB. |
mplsTunnelStateTransitions (1.3.6.1.2.1.10.166.3.2.2.1.33) |
read-only |
Counter32 |
Counter32 (0..4294967295) |
Number of times the state of this tunnel instance has changed. |
As per the MIB. |
mplsTunnelAdminStatus (1.3.6.1.2.1.10.166.3.2.2.1.34) |
read-create |
Integer |
up(1), down(2), testing(3) |
Administrative state of the tunnel. |
Supports only the read operation. Supports only up(1). |
mplsTunnelOperStatus (1.3.6.1.2.1.10.166.3.2.2.1.35) |
read-only |
Integer |
up(1), down(2), testing(3), unknown(4), dormant(5), notPresent(6), lowerlayerDown(7) |
Operational state of the tunnel. |
Supports only up(1) and down(2). |
mplsTunnelRowStatus (1.3.6.1.2.1.10.166.3.2.2.1.36) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
mplsTunnelStorageType (1.3.6.1.2.1.10.166.3.2.2.1.37) |
read-create |
StorageType |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type. |
As per the MIB. |
mplsTunnelHopTable
About this table
This table contains explicit path information for tunnel interfaces.
Create:The mplsTunnelHopPathOptionName object must be specified.
The value range for the mplsTunnelHopPathOptionIndex object is 1 to 10 for the primary CRLSP and 101 to 110 for the backup CRLSP.
When the value of the mplsTunnelHopEntryPathComp object is dynamic(1), the value of the mplsTunnelHopIndex object must be 0.
Delete:Supported
Read:Supported
Columns
The table indexes are mplsTunnelHopListIndex, mplsTunnelHopPathOptionIndex, and mplsTunnelHopIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelHopListIndex (1.3.6.1.2.1.10.166.3.2.4.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..2147483647) |
Hop table index. |
As per the MIB. |
mplsTunnelHopPathOptionIndex (1.3.6.1.2.1.10.166.3.2.4.1.2) |
not-accessible |
Unsigned32 |
Path option index. |
As per the MIB. |
mplsTunnelHopIndex (1.3.6.1.2.1.10.166.3.2.4.1.3) |
not-accessible |
Unsigned32 |
Hop index. |
As per the MIB. |
mplsTunnelHopAddrType (1.3.6.1.2.1.10.166.3.2.4.1.4) |
read-create |
TeHopAddressType Integer |
Address type. |
Supports only ipv4(1). |
mplsTunnelHopIpAddr (1.3.6.1.2.1.10.166.3.2.4.1.5) |
read-create |
TeHopAddress |
OCTET STRING (0..32) |
Address. |
As per the MIB. |
mplsTunnelHopIpPrefixLen (1.3.6.1.2.1.10.166.3.2.4.1.6) |
read-create |
InetAddressPrefixLength |
Unsigned32 (0..2040) |
Address prefix. |
As per the MIB. |
mplsTunnelHopType (1.3.6.1.2.1.10.166.3.2.4.1.10) |
read-create |
Integer |
strict(1), loose(2) |
Hop type. |
As per the MIB. |
mplsTunnelHopInclude (1.3.6.1.2.1.10.166.3.2.4.1.11) |
read-create |
TurthValue |
true(1), false(2) |
Whether this hop is included in the tunnel's path. |
As per the MIB. |
mplsTunnelHopPathOptionName (1.3.6.1.2.1.10.166.3.2.4.1.12) |
read-create |
SnmpAdminString |
OCTET STRING (0..255) |
Description of this series of hops as they relate to the specified path option. |
As per the MIB. |
mplsTunnelHopEntryPathComp (1.3.6.1.2.1.10.166.3.2.4.1.13) |
read-create |
Integer |
dynamic(1), explicit(2) |
Features using the path. |
As per the MIB. |
mplsTunnelHopRowStatus (1.3.6.1.2.1.10.166.3.2.4.1.14) |
read-create |
RowStatus |
Row status. |
mplsTunnelHopStorageType (1.3.6.1.2.1.10.166.3.2.4.1.15) |
read-create |
StorageType |
Storage type. |
The value of this object is fixed at nonvolatile(3). |
mplsTunnelResourceTable
About this table
This table contains tunnel resource information.
Create:Supported
Delete:Objects used by mplsXCEntry objects cannot be deleted.
Read:Supported
Columns
The table index is mplsTunnelResourceIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelResourceIndex (1.3.6.1.2.1.10.166.3.2.6.1.1) |
not-accessible |
Unsigned32 |
Resource table index. |
As per the MIB. |
mplsTunnelResourceMaxRate (1.3.6.1.2.1.10.166.3.2.6.1.2) |
read-only |
Unsigned32 |
Unsigned32 (0) |
Maximum transmission rate. |
As per the MIB. |
mplsTunnelResourceMeanRate (1.3.6.1.2.1.10.166.3.2.6.1.3) |
read-create |
Unsigned32 |
Minimum transmission rate. |
As per the MIB. |
mplsTunnelResourceMaxBurstSize (1.3.6.1.2.1.10.166.3.2.6.1.4) |
read-create |
Unsigned32 |
Maximum burst size. |
As per the MIB. |
mplsTunnelResourceMeanBurstSize (1.3.6.1.2.1.10.166.3.2.6.1.5) |
read-create |
Unsigned32 |
Minimum burst size. |
As per the MIB. |
mplsTunnelResourceExBurstSize (1.3.6.1.2.1.10.166.3.2.6.1.6) |
read-create |
Unsigned32 |
Excess burst size in bytes. |
As per the MIB. |
mplsTunnelResourceRowStatus (1.3.6.1.2.1.10.166.3.2.6.1.9) |
read-create |
RowStatus |
Row status. |
mplsTunnelResourceStorageType (1.3.6.1.2.1.10.166.3.2.6.1.10) |
read-create |
StorageType |
Storage type. |
Not supported. The value of this object is fixed at 3. |
About this table
This table contains tunnel ARHop information.
Create:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are mplsTunnelARHopListIndex and mplsTunnelARHopIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelARHopListIndex (1.3.6.1.2.1.10.166.3.2.7.1.1) |
not-accessible |
Unsigned32 |
As per the MIB. |
mplsTunnelARHopIndex (1.3.6.1.2.1.10.166.3.2.7.1.2) |
not-accessible |
Unsigned32 |
ARHop index. |
As per the MIB. |
mplsTunnelARHopAddrType (1.3.6.1.2.1.10.166.3.2.7.1.3) |
read-only |
TeHopAddressType |
unknown(0), ipv4(1), ipv6(2), asnumber(3), unnum(4), lspid(5) |
Address type. |
mplsTunnelARHopIpAddr (1.3.6.1.2.1.10.166.3.2.7.1.4) |
read-only |
TeHopAddress |
IP address. |
As per the MIB. |
mplsTunnelCHopTable
About this table
This table contains CHop information.
Read:Supported
Columns
The table indexes are mplsTunnelCHopListIndex and mplsTunnelCHopIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelCHopListIndex (1.3.6.1.2.1.10.166.3.2.8.1.1) |
not-accessible |
Unsinged32 |
Unsinged32 (1..2147483647) |
CHop table index. |
As per the MIB. |
mplsTunnelCHopIndex (1.3.6.1.2.1.10.166.3.2.8.1.2) |
not-accessible |
Unsigned32 |
CHop index |
As per the MIB. |
mplsTunnelCHopAddrType (1.3.6.1.2.1.10.166.3.2.8.1.3) |
read-only |
TeHopAddressType |
Address type. |
mplsTunnelCHopIpAddr (1.3.6.1.2.1.10.166.3.2.8.1.4) |
read-only |
TeHopAddress |
IP address. |
As per the MIB. |
mplsTunnelCHopIpPrefixLen (1.3.6.1.2.1.10.166.3.2.8.1.5) |
read-only |
Address prefix. |
As per the MIB. |
mplsTunnelCHopType (1.3.6.1.2.1.10.166.3.2.8.1.9) |
read-only |
Integer |
CHop type. |
As per the MIB. |
mplsTunnelPerfTable
About this table
This table contains tunnel performance parameters.
Read:Supported
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsTunnelPerfPackets (1.3.6.1.2.1.10.166.3.2.9.1.1) |
read-only |
Counter32 |
Number of forwarded packets. This object represents the 32-bit value of the least significant part of the 64-bit value if mplsTunnelPerfHCPackets is also returned. |
As per the MIB. |
mplsTunnelPerfHCPackets (1.3.6.1.2.1.10.166.3.2.9.1.2) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
High capacity counter for number of packets forwarded by this tunnel. |
As per the MIB. |
mplsTunnelPerfErrors (1.3.6.1.2.1.10.166.3.2.9.1.3) |
read-only |
Counter32 |
Number of error packets. |
As per the MIB. |
mplsTunnelPerfBytes (1.3.6.1.2.1.10.166.3.2.9.1.4) |
read-only |
Counter32 |
Number of forwarded bytes. This object represents the 32-bit value of the least significant part of the 64-bit value if mplsTunnelPerfHCBytes is also returned. |
As per the MIB. |
mplsTunnelPerfHCBytes (1.3.6.1.2.1.10.166.3.2.9.1.5) |
read-only |
Counter64 |
High capacity counter for number of bytes forwarded by the tunnel. |
As per the MIB. |
Notifications
mplsTunnelUp
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.10.166.3.0.1 |
A tunnel comes up. |
Recovery |
Warning |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when the operational state (indicated by the mplsTunnelOperStatus object) of a tunnel changes from down to another value (except for notPresent).
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.10.166.3.2.2.1.34 (mplsTunnelAdminStatus) |
mplsTunnelIndex, mplsTunnelInstance, mplsTunnelIngressLSRId, mplsTunnelEgressLSRId |
INTEGER |
up(1) , down(2) , testing(3) |
1.3.6.1.2.1.10.166.3.2.2.1.35 (mplsTunnelOperStatus) |
Actual state of the tunnel. |
INTEGER |
up(1) , down(2) , testing(3) , unknown(4) , dormant(5) , notPresent(6) , lowerLayerDown(7) |
Recommended action
No action is required.
mplsTunnelDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.3.0.2 |
The operation state of a tunnel becomes down. |
Error |
Major |
N/A (N/A) |
ON |
For all types of tunnels, possible reasons for this notification include the following:
The interface went Down.
The configuration of the tunnel was deleted.
The link was faulty.
The tunnel was manually shut down.
Others
For RSVP-TE tunnels, possible reasons for this notification also include the following:
RSVP-TE LSP resources were preempted.
Transmission of an RSVP message timed out.
RSVP Hello mechanism detected a downstream node failure.
CSPF failed to calculate a path.
For Segment Routing TE tunnels, possible reasons for this notification also include the following:
IGP calculation or verification failed.
For static TE tunnels, possible reasons for this notification also include:
A static CR-LSP went Down.
A static SR-LSP went Down.
System impact
Service traffic carried on the tunnel will be interrupted.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
INTEGER |
INTEGER |
Recommended action
To resolve this issue:
1.Check the current tunnel interface configuration, IGP configuration, and the whole tunnel path.
- If an explicit path is configured, check whether the interfaces on each hop of the explicit path are faulty.
If yes, clear link faults.
If no, execute step 2 or 3 according to the tunnel type.
- If no explicit path is configured, check whether a path that satisfies the tunnel requirements exists. If yes, execute step 2 or 3 according to the tunnel type.
2.For an RSVP-TE tunnel, check whether the RSVP protocol, link bandwidth, and link affinity settings are correct.
- If the settings are correct but the issue persists, go to step 4.
- If the settings are not correct, edit the related configuration.
3.For a static MPLS TE tunnel, check whether static CRLSP or SRLSP settings are correct.
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
mplsTunnelRerouted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.3.0.3 |
A tunnel is rerouted. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when a tunnel is rerouted because of the current path used by the tunnel is unreachable. If the mplsTunnelARHopTable is used, the tunnel entry in the mplsTunnelARHopTable might contain the new path of the tunnel for a time period after the agent sends this notification.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
INTEGER |
INTEGER |
Recommended action
No action is required..
mplsTunnelReoptimized
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.3.0.4 |
A tunnel is reoptimized. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the optimal path is selected successfully for a tunnel during tunnel reoptimization. If the mplsTunnelARHopTable is used, the tunnel entry in the mplsTunnelARHopTable might contain the new path of the tunnel for a time period after the agent sends this notification.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
INTEGER |
mplsTunnelIndex,mplsTunnelInstance, mplsTunnelIngressLSRId, mplsTunnelEgressLSRId |
INTEGER |
Recommended action
