- 11-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-EVC-MIB
- 04-HH3C-L2VPN-MIB
- 05-HH3C-L3VPN-MIB
- 06-HH3C-MPLS-LDP-MIB
- 07-HH3C-MPLS-VPN-BGP-MIB
- 08-HH3C-MPLSCRLSP-MIB
- 09-HH3C-MPLSEXT-MIB
- 10-HH3C-VSI-MIB
- 11-HH3C-MPLSTE-MIB
- 12-HH3C-MPLSSLSP-MIB
- 13-HH3C-MPLSPCE-MIB
- 14-MPLS-FRR-FACILITY-STD-MIB
- 15-MPLS-FRR-GENERAL-STD-MIB
- 16-MPLS-FTN-STD-MIB
- 17-MPLS-L3VPN-STD-MIB
- 18-MPLS-LDP-STD-MIB
- 19-MPLS-LSR-STD-MIB
- 20-MPLS-TE-STD-MIB
- 21-PW-ENET-STD-MIB
- 22-PW-MPLS-STD-MIB
- 23-PW-STD-MIB
- 24-TE-MIB
| 02-HH3C-MPLSLSPV-MIB | 44.37 KB |
HH3C-MPLSLSPV-MIB
About this MIB
Use this MIB to implement LSPV trap notification.
MIB file name
hh3c-mplslspv.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsLspv(241)
Scalar objects
hh3cMplsLspvBaseInfo (1.3.6.1.4.1.25506.2.241.1.1.1)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsLspvBaseInfo (1.3.6.1.4.1.25506.2.241.1.1.1) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (0..127) |
LSPV basic information. |
As per the MIB. |
Notifications
hh3cMplsLspvPingProbe
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.241.0.1 |
LSP ping notification. |
Informational |
Major |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when the device receives LSP ping packets and the reply mode is no reply.
System impact
No negative impact on the system.
Status control
None.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.241.1.1.1 (hh3cMplsLspvBaseInfo) |
N/A |
OCTET STRING |
Standard MIB values. |
Recommended action
No action is required.
hh3cMplsLspvTracertProbe
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.241.0.2 |
LSP tracert notification. |
Informational |
Major |
N/A (N/A) |
ON |
This notification is generated when the device receives LSP tracert packets and the reply mode is no reply.
System impact
Status control
None.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
Recommended action
