- 11-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-EVC-MIB
- 04-HH3C-L2VPN-MIB
- 05-HH3C-L3VPN-MIB
- 06-HH3C-MPLS-LDP-MIB
- 07-HH3C-MPLS-VPN-BGP-MIB
- 08-HH3C-MPLSCRLSP-MIB
- 09-HH3C-MPLSEXT-MIB
- 10-HH3C-VSI-MIB
- 11-HH3C-MPLSTE-MIB
- 12-HH3C-MPLSSLSP-MIB
- 13-HH3C-MPLSPCE-MIB
- 14-MPLS-FRR-FACILITY-STD-MIB
- 15-MPLS-FRR-GENERAL-STD-MIB
- 16-MPLS-FTN-STD-MIB
- 17-MPLS-L3VPN-STD-MIB
- 18-MPLS-LDP-STD-MIB
- 19-MPLS-LSR-STD-MIB
- 20-MPLS-TE-STD-MIB
- 21-PW-ENET-STD-MIB
- 22-PW-MPLS-STD-MIB
- 23-PW-STD-MIB
- 24-TE-MIB
| 07-HH3C-MPLS-VPN-BGP-MIB | 77.09 KB |
About this MIB
Use this MIB to manage the L3VPN related configuration and obtain path and prefix information about MPLS VPN BGP peers.
MIB file name
hh3c-mpls-vpn-bgp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cMpls(12).hh3cMplsVpn(3)
Tabular objects
hh3cMplsVpnVrfConfTable
About this table
This table is obsolete. It specifies per-interface MPLS/BGP VPN VRF table capabilities and the associated information.
Support for operations
Create:Supported
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cMplsVpnVrfName and hh3cMplsVpnVrfBgpNbrAdd.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsVpnVrfName (1.3.6.1.4.1.25506.2.160.1.1.1.1.1) |
not-accessible |
Hh3cMplsVpnId |
OCTET STRING(0..31) |
Name of a VRF (VPN instance). |
As per the MIB. |
hh3cMplsVpnVrfRtDistinguisher (1.3.6.1.4.1.25506.2.160.1.1.1.1.2) |
read-create |
Hh3cMplsVpnRtDistinguisher |
OCTET STRING(0..256) |
Route distinguisher for the VRF. |
As per the MIB. |
hh3cMplsVpnVrfNetPrefixType (1.3.6.1.4.1.25506.2.160.1.1.1.1.3) |
read-only |
INTEGER |
other(1), rip(2), ospf(3), isis(4), bgp(5), static(6) |
Type of the network prefix for the PE-CE connection. |
As per the MIB. |
hh3cMplsVpnVrfNetPrefix (1.3.6.1.4.1.25506.2.160.1.1.1.1.4) |
read-only |
IpAddress |
OCTET STRING (4) |
Network prefix of the PE-CE connection. |
As per the MIB. |
hh3cMplsVpnVrfIpRtRedistributeConn (1.3.6.1.4.1.25506.2.160.1.1.1.1.5) |
read-create |
TruthValue |
true(1), false(2) |
Redistribution of directly connected networks into the VRF BGP table. |
As per the MIB. |
hh3cMplsVpnVrfIpRtRedistributeStatic (1.3.6.1.4.1.25506.2.160.1.1.1.1.6) |
read-create |
TruthValue |
true(1), false(2) |
Redistribution of static routes into the VRF BGP table. |
As per the MIB. |
hh3cMplsVpnVrfIpRtRedistributeRip (1.3.6.1.4.1.25506.2.160.1.1.1.1.7) |
read-create |
TruthValue |
true(1), false(2) |
Redistribution of RIP routes into the VRF BGP table. |
As per the MIB. |
hh3cMplsVpnVrfConfHighRtThreshold (1.3.6.1.4.1.25506.2.160.1.1.1.1.8) |
read-create |
Unsigned32 |
Standard MIB values. |
Warning threshold for the number of active routes in the VRF. |
As per the MIB. |
hh3cMplsVpnVrfConfIsWarnOnly (1.3.6.1.4.1.25506.2.160.1.1.1.1.9) |
read-create |
TruthValue |
true(1), false(2) |
Action to take when the number of active routes in the VRF exceeds the warning threshold. |
As per the MIB. |
hh3cMplsVpnVrfConfMaxRts (1.3.6.1.4.1.25506.2.160.1.1.1.1.10) |
read-create |
Unsigned32 |
Maximum number of routes set for the VRF. |
As per the MIB. |
hh3cMplsVpnVrfConfRowStatus (1.3.6.1.4.1.25506.2.160.1.1.1.1.11) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
This variable is used to create, edit, and/or delete a row in this table. |
As per the MIB. |
hh3cMplsVpnVrfBgpNbrAddrTable
About this table
This table contains information about MPLS VPN BGP peers.
Create:Supported
Edit/Modify:Supported only by hh3cMplsVpnVrfBgpNbrAdminStatus.
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cMplsVpnVrfName and hh3cMplsVpnVrfBgpNbrAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsVpnVrfBgpNbrAddr (1.3.6.1.4.1.25506.2.160.1.1.2.1.1) |
not-accessible |
IpAddress |
OCTET STRING (4) |
Address of the BGP peer. |
As per the MIB. |
hh3cMplsVpnVrfBgpNbrRole (1.3.6.1.4.1.25506.2.160.1.1.2.1.2) |
read-create |
INTEGER |
ce(1) pe(2) |
Role of the BGP peer. |
Supports only the read operation. |
hh3cMplsVpnVrfBgpNbrAsNumber (1.3.6.1.4.1.25506.2.160.1.1.2.1.3) |
read-create |
Unsigned32 |
AS number of the BGP peer |
hh3cMplsVpnVrfBgpNbrAdminStatus (1.3.6.1.4.1.25506.2.160.1.1.2.1.4) |
read-create |
INTEGER |
mplsVpnVrfBgpNbrSetUp(1) mplsVpnVrfBgpNbrSetDown(2) |
Expected BGP peer connection state. |
As per the MIB. |
hh3cMplsVpnVrfBgpNbrRowStatus (1.3.6.1.4.1.25506.2.160.1.1.2.1.5) |
read-create |
RowStatus |
Row status. |
hh3cMplsVpnVrfBgpNbrState (1.3.6.1.4.1.25506.2.160.1.1.2.1.6) |
read-only |
INTEGER |
idle(1) connect(2) active(3) opensent(4) openconfirm(5) established(6) |
hh3cMplsVpnVrfBgpNbrPrefixTable
About this table
This table contains path and prefix information about MPLS VPN BGP peers.
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cMplsVpnVrfName, hh3cmplsVpnVrfBgpPAtrPeer, hh3cmplsVpnVrfBgpPAtrIpAddrPrefixLen, and hh3cmplsVpnVrfBgpPAtrIpAddrPrefix.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsVpnVrfBgpPAtrPeer (1.3.6.1.4.1.25506.2.160.1.1.3.1.1) |
not-accessible |
IpAddress |
OCTET STRING (4) |
IP address of the EBGP peer. |
As per the MIB. |
hh3cMplsVpnVrfBgpPAtrIpAddrPrefixLen (1.3.6.1.4.1.25506.2.160.1.1.3.1.2) |
not-accessible |
Integer32 |
Integer32 (0..32) |
Mask length of the IP address prefix. |
As per the MIB. |
hh3cMplsVpnVrfBgpPAtrIpAddrPrefix (1.3.6.1.4.1.25506.2.160.1.1.3.1.3) |
not-accessible |
IpAddress |
OCTET STRING (4) |
As per the MIB. |
hh3cMplsVpnVrfBgpPAtrPeerType (1.3.6.1.4.1.25506.2.160.1.1.3.1.4) |
read-only |
InetAddressType |
IPv4(1) IPv6 (2) |
Address family of the PE IP address. |
As per the MIB. |
hh3cMplsVpnVrfBgpPAtrOrigin (1.3.6.1.4.1.25506.2.160.1.1.3.1.5) |
read-only |
INTEGER |
igp(1) egp(2) incomplete(3) |
Ultimate origin of the path information. |
As per the MIB. |
hh3cMplsVpnVrfBgpPAtrASPathSegment (1.3.6.1.4.1.25506.2.160.1.1.3.1.6) |
read-only |
OCTET STRING |
OCTET STRING (2..255) |
Sequence of AS path segments. |
As per the MIB. |
hh3cMplsVpnVrfBgpPAtrNextHop (1.3.6.1.4.1.25506.2.160.1.1.3.1.7) |
read-only |
IpAddress |
OCTET STRING (4) |
Address of the border router. |
As per the MIB. |
hh3cMplsVpnVrfBgpPAtrMultiExitDisc (1.3.6.1.4.1.25506.2.160.1.1.3.1.8) |
read-only |
Integer32 |
Integer32(-1..2147483647) |
Metric used to discriminate between multiple exit points to an adjacent autonomous system. |
The return value is 2147483647 when the actual value is between 2147483647 and 4294967295. |
hh3cMplsVpnVrfBgpPAtrLocalPref (1.3.6.1.4.1.25506.2.160.1.1.3.1.9) |
read-only |
Integer32 |
The originating BGP4 speaker's degree of preference for an advertised route. |
hh3cMplsVpnVrfBgpPAtrAtomicAggregate (1.3.6.1.4.1.25506.2.160.1.1.3.1.10) |
read-only |
INTEGER |
lessSpecificRtNotSelected (1) lessSpecificRtSelected (2) |
ATOMIC_AGGREGATE attribute. |
As per the MIB. |
hh3cMplsVpnVrfBgpPAtrAggregatorAS (1.3.6.1.4.1.25506.2.160.1.1.3.1.11) |
read-only |
Integer32 |
Integer32(0..65535) |
AS number of the last BGP4 speaker that performed route aggregation. |
The return value is 23456 when the actual value is between 65536 and 4294967295. |
hh3cMplsVpnVrfBgpPAtrAggregatorAddr (1.3.6.1.4.1.25506.2.160.1.1.3.1.12) |
read-only |
IpAddress |
OCTET STRING (4) |
IP address of the last BGP4 speaker that performed route aggregation. |
As per the MIB. |
hh3cMplsVpnVrfBgpPAtrCalcLocalPref (1.3.6.1.4.1.25506.2.160.1.1.3.1.13) |
read-only |
Integer32 |
Preference calculated by the receiving BGP4 speaker for an advertised route. |
hh3cMplsVpnVrfBgpPAtrBest (1.3.6.1.4.1.25506.2.160.1.1.3.1.14) |
read-only |
INTEGER |
true(1), false(2) |
Indication of whether or not this route was chosen as the best BGP4 route. |
As per the MIB. |
hh3cMplsVpnVrfBgpPAtrUnknown (1.3.6.1.4.1.25506.2.160.1.1.3.1.15) |
read-only |
OCTET STRING |
OCTET STRING (0..255) |
One or more path attributes not understood by this BGP4 speaker. |
As per the MIB. |
