02-QoS命令
本章节下载: 02-QoS命令 (1.19 MB)
1.1.2 display traffic classifier
1.2.3 display traffic behavior
1.2.13 remark local-precedence
1.3.3 control-plane management
1.3.5 display qos policy control-plane
1.3.6 display qos policy control-plane management
1.3.7 display qos policy control-plane management pre-defined
1.3.8 display qos policy control-plane pre-defined
1.3.9 display qos policy control-plane rule-statistics
1.3.10 display qos policy global
1.3.11 display qos policy global rule-statistics
1.3.12 display qos policy interface
1.3.13 display qos policy interface rule-statistics
1.3.14 display qos policy l2vpn-ac
1.3.15 display qos policy l2vpn-ac rule-statistics
1.3.16 display qos policy user-profile
1.3.17 display qos vlan-policy
1.3.18 display qos vlan-policy rule-statistics
1.3.20 qos apply policy (user profile view)
1.3.21 qos apply policy global
1.3.24 reset qos policy control-plane
1.3.25 reset qos policy control-plane management
1.3.26 reset qos policy global
1.3.27 reset qos policy l2vpn-ac
1.4.1 snmp-agent trap enable qos
2.1.2 display qos map-table color
2.2.1 display qos trust interface
2.2.3 qos trust tunnel-dscp (system view)
3.1.1 display qos gts interface
3.2.1 display qos lr interface
4.1.1 display qos queue interface
4.3.1 display qos queue sp interface
4.4.1 display qos queue wrr interface
4.4.2 qos wrr (interface view)
4.4.3 qos wrr { byte-count | weight }
4.5.1 display qos queue wfq interface
4.5.3 qos wfq (interface view)
4.5.4 qos wfq { byte-count | weight }
4.6.2 display qos qmprofile configuration
4.6.3 display qos qmprofile interface
5.1.2 display qos wred interface
5.1.9 qos wred queue weighting-constant
5.1.10 queue (Wred table view)
5.1.11 queue weighting-constant
9.1.1 display qos packet-statistics interface
9.1.3 reset qos packet-statistics interface
10.1.1 display qos queue-statistics interface outbound
10.1.2 qos queue-statistics byte-count
LSCM2系列单板是指单板丝印以LSCM2开头的接口板和主控板
description命令用来配置类的描述信息。
undo description命令用来恢复缺省情况。
未配置类的描述信息。
类视图
text:表示类的描述信息,为1~127个字符的字符串,区分大小写。
多次执行本命令,最后一次执行的命令生效。
# 为类class1配置描述信息。
[Sysname-classifier-class1] description classifier
display traffic classifier命令用来显示类的配置信息。
(独立运行模式)
display traffic classifier user-defined [ classifier-name ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定单板的流分类的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主用主控板的类的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的流分类的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示全局主用主控板的类的配置信息。(IRF模式)
# 显示用户定义类的配置信息。
User-defined classifier information:
Classifier: 1 (ID 100)
Operator: AND
Rule(s) :
If-match acl 2000
Classifier: 2 (ID 101)
Operator: AND
Rule(s) :
If-match protocol ipv6
Classifier: 3 (ID 102)
Operator: AND
Rule(s) :
-none-
表1-1 display traffic classifier命令显示信息描述表
User-defined classifier information |
用户自定义类的信息 |
Classifier |
类的名称及其内容,内容可以有多种类型 |
Operator |
分类规则之间的逻辑关系 |
Rule(s) |
分类规则 |
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match match-criteria
undo if-match match-criteria
未定义匹配数据包的规则。
类视图
取值 |
acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } [ inner | geneve-inner [ option-header-length option-length ] ] |
定义匹配ACL的规则 · acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999,用户自定义ACL序号的取值范围是5000~5999 · acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all · inner表示if-match命令引用的ACL是用于匹配VXLAN报文的内层头内容,不配置inner则表示if-match命令引用的ACL是用于匹配未经封装报文的报文头内容或封装后的VXLAN报文的外层头内容。需要注意的是,上述引用的ACL中的规则不能配置为rule [ rule-id ] { deny | permit } vxlan。如果引用的ACL中配置的规则是rule [ rule-id ] { deny | permit } vxlan,则if-match acl命令不需要携带inner也能匹配封装后的VXLAN报文的内层头内容 · geneve-inner表示if-match命令引用的ACL是用于匹配GENEVE报文的内层头内容。在配置geneve-inner时,必须同时配置if-match geneve。如果不配置geneve-inner则表示if-match命令引用的ACL是用于匹配未经封装报文的报文头内容或封装后的GENEVE报文的外层头内容。需要注意的是,if-match命令指定geneve-inner后,则引用的ACL中的规则不能配置为rule [ rule-id ] { deny | permit } geneve,否则无法匹配GENEVE报文的内层信息。如果希望匹配GENEVE报文的内层信息,请在if-match命令中指定geneve-inner参数或者在引用的ACL中配置携带geneve参数的rule命令,二者选其一。仅SF系列接口板、LSCM2系列SC单板和SD系列接口板支持匹配GENEVE报文的内层头内容 · option-length用于指定匹配GENEVE报文的内层报文信息时,GENEVE协议的可选协议头字节数,取值范围为0~252且必须为4的倍数,如果未指定本参数时,缺省情况下,option-length取值为0 ACL规则中未指定VPN实例时,表示该规则对非VPN报文和VPN报文均有效 |
any |
定义匹配所有数据包的规则 |
control-plane protocol protocol-name&<1-8> |
定义匹配控制平面协议的规则,protocol-name&<1-8>为系统预定义匹配协议报文类型名称的列表,具体如表1-3所示,&<1-8>表示前面的参数最多可以输入8次 |
control-plane protocol-group protocol-group-name |
定义匹配控制平面协议组的规则,protocol-group-name取值为critical、important、management、monitor、normal、redirect |
customer-dot1p dot1p-value&<1-8> |
定义匹配内层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次 |
customer-vlan-id vlan-id-list |
定义匹配内层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次 |
destination-mac mac-address [ mac-address-mask ] |
定义匹配目的MAC地址的规则,仅对以太网接口生效 |
dscp dscp-value&<1-8> |
定义匹配DSCP的规则,dscp-value&<1-8>为DSCP取值的列表,DSCP的取值范围为0~63,&<1-8>表示前面的参数最多可以输入8次;也可以输入关键字,具体如remark dscp所示 |
forwarding-layer { bridge | route } |
定义匹配转发报文的二、三层属性的规则,其中bridge表示只匹配二层转发报文,route表示只匹配三层转发报文。出方向上,仅设备的工作模式为专家模式时支持。有关设备工作模式的详细介绍,请参见“基础配置指导”中的“设备管理” |
inbound-interface interface-type interface-number |
仅LSCM2系列SC单板、SD系列接口板和SF系列接口板支持配置该参数 定义匹配入接口的规则,interface-type interface-number为接口类型和接口编号 在“and”模式的流分类中如果配置了本规则,然后将入接口所在单板或子卡拔出,会导致流分类失效,此时如果将单板或子卡恢复,则流分类会重新生效。但如果不恢复单板或子卡,请删除该流分类并按需重新配置。否则,即使再向该流分类中新增其他匹配规则,该流分类也不会生效 |
ip-precedence ip-precedence-value&<1-8> |
定义匹配IP优先级的规则,ip-precedence-value&<1-8>为IP优先级的列表,IP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次 |
outbound-interface interface-type interface-number |
定义匹配出接口的规则,interface-type interface-number为接口类型和接口编号 该匹配项仅支持匹配二层以太网接口、三层以太网接口的出方向。 |
protocol protocol-name |
定义匹配协议的规则,protocol-name取值为ip、ipv6 |
qos-local-id local-id-value |
定义匹配QoS本地ID值的规则,local-id-value为QoS本地ID,对于SF系列接口板,取值范围为1~384。对于LSCM2系列SC单板和SD系列接口板,取值范围为1~32。 出方向上不支持匹配QoS本地ID值 不支持在VXLAN M-LAG环境下使用 |
qos-local-id egress-active local-id-value |
定义匹配报文出方向QoS本地ID值的规则: · 如果在入方向上应用了remark qos-local-id egress-activelocal-id-value命令对报文的QoS本地ID值进行标记且该标记仅在出方向生效,则在出方向上只能使用if-match qos-local-id egress-active local-id-value命令来匹配报文的QoS本地ID值 · 如果应用了remark qos-local-id local-id-value命令且未指定egress-active参数对报文的QoS本地ID值进行标记,重标记报文的QoS本地ID值在任意方向都生效,则只能使用if-match qos-local-id local-id-value来匹配报文的QoS本地ID值 local-id-value为QoS本地ID,取值范围为1~128 |
service-dot1p dot1p-value&<1-8> |
定义匹配外层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次 |
service-vlan-id vlan-id-list |
定义匹配外层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次 若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID规则来匹配 |
source-mac mac-address |
定义匹配源MAC地址的规则,仅对以太网接口生效 |
tunnel-id tunnel-id |
对于SF系列接口板: · 匹配指定隧道内的所有VXLAN报文,指定的隧道必须是VXLAN隧道 · 配置该规则的QoS策略支持应用在出和入方向 · 配置该规则的QoS策略不支持应用在以太网服务实例和Tunnel接口 · 在出方向上,配置该规则的QoS策略中流行为不支持配置为重新标记报文的DSCP值 对于其它接口板:定义匹配指定隧道内的报文,且配置该规则的QoS策略仅支持应用在入方向 |
vxlan { any | vxlan-id } |
定义匹配VXLAN编号的规则 |
geneve { any | geneve-id } |
定义匹配GENEVE封装报文头中VNI(Virtual Network Identifier,虚拟网络标识符)的规则 |
报文类型 |
arp |
ARP协议 |
arp-snooping |
ARP Snooping协议 |
bfd |
BFD协议 |
bgp |
BGP协议 |
bgp4+ |
IPv6 BGP |
dhcp |
DHCP协议 |
dhcp-snooping |
DHCP Snooping协议 |
dhcp6 |
IPv6 DHCP协议 |
dot1x |
802.1p 协议 |
icmp |
ICMP协议 |
icmp6 |
IPv6 ICMP协议 |
isis |
IS-IS协议 |
lacp |
LACP协议 |
ldp |
LDP协议 |
ldp6 |
IPv6 LDP协议 |
lldp |
LLDP协议 |
msdp |
MSDP协议 |
mvrp |
MVRP协议(包含GVRP协议) |
ntp |
NTP协议 |
oam |
OAM协议 |
ospf-multicast |
OSPF组播 |
ospf-unicast |
OSPF单播 |
ospf3-multicast |
OSPFv3组播 |
ospf3-unicast |
OSPFv3单播 |
pim-multicast |
PIM组播 |
pim-unicast |
PIM单播 |
pim6-multicast |
IPv6 PIM组播 |
pim6-unicast |
IPv6 PIM单播 |
portal |
PORTAL协议 |
pvst |
PVST协议 |
rip |
RIP协议 |
ripng |
RIPng协议 |
rrpp |
RRPP协议 |
rsvp |
RSVP协议 |
smart-link |
Smart Link协议 |
snmp |
SNMP协议 |
stp |
STP协议 |
udp-helper |
UDP中继转发 |
vrrp |
VRRP协议 |
vrrp6 |
IPv6 VRRP协议 |
一个类下可配置多条匹配命令,各个配置之间互相不覆盖。
在接口出方向应用QoS策略时,如果流分类引用的二层ACL中包含匹配MAC地址的规则,则该规则无法匹配IPv6报文。
在定义匹配规则(DSCP、VLAN ID、802.1p优先级、IP优先级)时,请注意:
· 一条命令可以配置多个规则,如果指定了多个相同的规则,系统默认为一个;一条命令中多个不同的规则是或的关系,即只要有一个值匹配,就算匹配这条规则。
· 删除某条匹配的规则时,必须与该规则中定义的完全相同才会删除,顺序可以不同。
在定义匹配ACL的规则时,类中引用的ACL必须已经存在。
当if-match中引用的ACL规则的动作为deny时,则直接忽略ACL规则的动作,以流行为中定义的动作为准,报文匹配只使用ACL中的分类域。
对于SF系列接口板出方向和SE系列接口板,当QoS策略的匹配对象为IPv6报文时,流分类中需额外配置匹配IPv6报文的规则。规则可配置为匹配IPv6协议类型。
对于LSCM1GT48SC0单板,当QoS策略的匹配对象为MPLS报文时,流分类中需额外配置匹配MPLS报文的规则。规则可配置为通过ACL规则匹配MPLS协议类型。
对于SF系列接口板:
对于VXLAN过路报文,在入方向上应用QoS策略无法匹配报文的源MAC、customer-vlan-id 和customer-dot1p。
对于GRE和NVGER报文,在入方向上应用QoS策略无法匹配过路报文的源MAC和customer-vlan-id。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的802.1p优先级为3。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1或6或9的报文。
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# 定义类class1的匹配规则为:匹配IP优先级值为1或6的报文。
[Sysname-classifier-class1] if-match ip-precedence 1 6
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的VLAN ID值为1或6或9的报文。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的VLAN ID值为2或7或10的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# 在流分类class1中配置匹配上送控制平面的normal协议组报文。
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# 在流分类class1中定义匹配隧道编号为2的报文。
[Sysname-classifier-class1] if-match tunnel-id 2
# 定义类class1的匹配规则为:匹配VXLAN编号为10的报文。
[Sysname-classifier-class1] if-match vxlan 10
traffic classifier命令用来创建一个类,并进入类视图。如果指定的类已经存在,则直接进入类视图。
undo traffic classifier命令用来删除一个类。
未配置类。
operator:指定各规则之间的逻辑运算符。缺省情况为and。
# 定义一个名为class1的类。
· display traffic classifier
accounting命令用来配置流量统计动作。
undo accounting命令用来恢复缺省情况。
accounting [ byte | packet ]
undo accounting
未配置流量统计动作。
流行为视图
byte:表示报文基于字节进行统计。
packet:表示报文基于包进行统计。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
若配置流量统计动作但不指定byte和packet参数,设备将以包和字节为单位进行报文统计。
# 为流行为配置流量统计动作,基于字节进行统计。
[Sysname-behavior-database] accounting byte
car命令用来配置流量监管动作。
undo car命令用来恢复缺省情况。
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
未配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。流量的平均速率,单位为kbps。取值范围为16~100000000且必须为8的整数倍。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
· 如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过67092480。
· 如果指定cbs参数,取值范围512~67092480且必须为512的整数倍。
ebs excess-burst-size:超出突发尺寸,单位为byte。取值范围为512~67092480且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps,取值范围为16~100000000且必须为8的整数倍。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass。
action:对数据包采取的动作,有以下几种:
discard:丢弃数据包。
pass:允许数据包通过。
remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
如果未配置峰值速率,则表示所配置的是单速率流量监管,否则表示双速率流量监管。
如果需要对红色、黄色和绿色报文进行流量统计,则需要在流行为同时配置accounting流量统计动作。
# 为流行为配置流量监管。报文正常流速为256kbps,承诺突发尺寸为51200bytes。
[Sysname-behavior-database] car cir 256 cbs 51200
display traffic behavior命令用来显示流行为的配置信息。
display traffic behavior user-defined [ behavior-name ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定单板的流行为的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的流行为的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的流行为的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的流行为的配置信息。(IRF模式)
# 显示用户定义行为的配置信息。
User-defined behavior information:
Behavior: 1 (ID 100)
Marking:
Remark dscp 3
Committed Access Rate:
CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Behavior: 2 (ID 101)
Accounting enable: Packet
Filter enable: Permit
Redirecting:
Redirect to the CPU
Behavior: 3 (ID 102)
-none-
表1-4 display traffic behavior命令显示信息描述表
User-defined behavior information |
用户自定义流行为的信息 |
Behavior |
行为的名称及其内容,内容可以有多种类型 |
Marking |
标记相关信息 |
Remark dscp |
重新标记报文的DSCP优先级值 |
Committed Access Rate |
流量限速的相关信息 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,单位为byte |
EBS |
超出突发尺寸,单位为byte |
Green action |
对绿色报文的动作 |
Red action |
对红色报文的动作 |
Yellow action |
对黄色报文的动作 |
none |
表示未配置其他流行为 |
filter命令用来配置流量过滤动作。
undo filter命令用来恢复缺省情况。
filter { deny | permit }
undo filter
未配置流量过滤动作。
流行为视图
deny:丢弃命中规则的数据包。
permit:不丢弃命中规则的数据包。
MQC方式的QoS策略中如果执行了filter命令配置流量过滤动作,存在以下不同的处理方式:
· 丢弃报文(Drop):即filter命令指定deny参数。如果报文命中了该CB对中的流量匹配规则,则直接丢弃报文,报文不再受低优先级应用的处理动作影响。
· 不丢弃报文(Drop Cancel):即filter命令指定permit参数。如果报文命中了该CB对中的流量匹配规则,则标记为不丢弃报文,报文不再受低优先级应用的处理动作影响,即使低优先级应用的处理动作为丢弃数据报文,该报文也不会被丢弃。
# 为流行为database配置丢弃数据包的过滤动作。
nest top-most命令用来配置添加报文的外层VLAN Tag动作。
undo nest top-most命令用来恢复缺省情况。
nest top-most vlan vlan-id
undo nest top-most
未配置添加报文外层VLAN Tag动作。
流行为视图
vlan vlan-id:添加的VLAN ID,取值范围为1~4094。
引用了添加VLAN Tag动作的QoS策略只能应用到接口的入方向上。
引用了添加VLAN Tag动作的QoS策略,请勿应用到聚合组成员端口、VSI和AC上。
当报文被添加外层VLAN编号后,在该报文的出接口上必须确保该报文内层VLAN编号也能通过。否则,报文无法正常转发。
执行本命令后的二层转发报文无法进行三层转发。
对于SF系列接口板,基于Tunnel接口应用QoS策略时,流行为不支持配置为添加报文的外层VLAN Tag动作。
对于SF系列接口板、LSCM2系列SC单板和SD系列接口板应用QoS策略时,流行为配置为添加报文的外层VLAN Tag动作与流分类定义匹配指定隧道内的报文不支持配置到同一QoS策略中。
对于SF系列接口板、LSCM2系列SC单板和SD系列接口板,仅filter permit、accounting可以和nest top-most vlan同时配置。
对于SF系列接口板、LSCM2系列SC单板和SD系列接口板,应用的QoS策略流行为配置本命令时,对Untagged报文在进行三层转发时不生效。
# 在流行为b1上配置如下动作:添加VLAN ID为123的外层VLAN Tag。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
packet-rate命令用来配置协议报文限速动作。
undo packet-rate命令用来恢复缺省情况。
packet-rate { value | attack-defense-threshold threshold-value } *
undo packet-rate
未配置协议报文限速动作。
流行为视图
value:协议报文速率,单位为包每秒(pps)。取值范围为1~3000。
attack-defense-threshold threshold-value:接口协议报文防攻击限速功能的监控门限。threshold-value为门限阈值,达到此阈值则启动接口协议报文防攻击限速功能,单位为包每秒(pps)。取值范围为1~3000。
仅LSCM2系列SC单板、SD系列接口板和SF系列接口板支持配置协议报文限速。
通过QoS策略配置协议报文限速后,可实现对上送CPU的协议报文的防攻击功能。
设备缺省会对上送CPU的各协议报文进行限速(即COPP上存在系统预定义的QoS策略),以防止出现大量协议报文同时上送CPU、对CPU产生冲击的情况。一旦某协议报文上送CPU的速率达到或超过限速值,设备就会自动开启接口防攻击限速功能(即在接口上对接收的该协议报文进行限速),以降低该协议报文上送CPU的速率。
· 通过packet-rate value命令可以对上送CPU的各协议报文的限速值进行修改。
· 通过packet-rate attack-defense-threshold threshod-value命令配置接口协议报文防攻击限速功能的监控门限时:
¡ 当配置的门限值小于等于上送CPU的协议报文限速值时,一旦协议报文上送CPU的实际速率达到门限值,设备就会自动开启接口防攻击限速功能。
¡ 当配置的门限值大于上送CPU的协议报文限速值时,等效于不开启接口协议报文防攻击限速功能。
# 为流行为copp配置CPU报文限速动作。
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
# 为流行为copp1配置CPU报文限速值为1600pps,并配置接口协议报文防攻击限速功能的监控门限为1400pps。
[Sysname] traffic behavior copp1
[Sysname-behavior-copp1] packet-rate 1600 attack-defense-threshold 1400
· display qos policy
· display qos policy control-plane
· display qos policy control-plane pre-defined
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来恢复缺省情况。
redirect { cpu | interface interface-type interface-number | monitoring-group group-id | next-hop { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] } [ fail-action { discard | forward } ] }
undo redirect { cpu | interface interface-type interface-number | monitoring-group group-id | next-hop }
未配置流量重定向动作。
流行为视图
cpu:重定向到CPU。
interface:重定向到指定的接口。
monitoring-group group-id:重定向到监控组,group-id表示监控组的编号。取值范围为1~4096。
next-hop:重定向到指定的下一跳。在配置重定向到下一跳的动作时,指定的下一跳地址必须路由可达,如果同时配置了优选和备选地址,则至少需要有一个地址路由可达,否则将导致重定向失败。在配置生效后,重定向功能会定期查询路由表,检查下一跳地址是否有效;如果配置了Track项,则通过Track检测结果来判断下一跳地址是否有效。如果检测到优选和备选地址均失效,则重定向到下一跳的动作将不再生效。
ipv4-add1:优选的下一跳IPv4地址。如果重定向到优选的IPv4地址失败,则会重定向到备选IPv4地址。
ipv4-add2:备选的下一跳IPv4地址。
ipv6-add1:优选的下一跳IPv6地址。如果重定向到优选的IPv6地址失败,则会重定向到备选IPv6地址。
ipv6-add2:备选的下一跳IPv6地址。
track track-entry-number:指定下一跳关联的Track项,优选和备选的地址可以分别指定不同的Track项。track-entry-number取值范围为1~1024。通过指定Track项,可实现与监测特性(如NQA、BFD)的联动,详情请参见“可靠性配置指导”中的“Track”。
fail-action:当下一跳的地址不存在时,对报文采取的处理动作。未配置本参数时,若下一跳地址不存在,不进行重定向,正常转发此报文。
discard:表示丢弃此报文。
forward:表示不进行重定向,正常转发此报文。
引用了重定向流行为动作的QoS策略只能应用到入方向上。
在配置重定向到下一跳的动作时,指定的下一跳地址必须路由可达,如果同时配置了优选和备选地址,则至少需要有一个地址路由可达,否则将导致重定向失败。在配置生效后,重定向功能会定期查询路由表,检查下一跳地址是否有效。
# 为流行为配置流量重定向动作,重定向到接口Ten-GigabitEthernet3/0/1。
[Sysname-behavior-database] redirect interface ten-gigabitethernet 3/0/1
# 为流行为配置流量重定向到下一跳的动作,优选IPv4地址为10.55.66.1,备选IPv4地址为10.55.88.1,为优选和备选地址分别关联Track项1和2,当下一跳的地址不存在时,丢弃报文。
[Sysname-behavior-database] redirect next-hop 10.55.66.1 track 1 10.55.88.1 track 2 fail-action discard
· classifier behavior
· monitoring-group(网络管理和监控命令参考/镜像)
· qos policy
· traffic behavior
remark customer-vlan-id命令用来重新标记报文的CVLAN。
undo remark customer-vlan-id命令用来恢复缺省情况。
未配置重新标记报文CVLAN的动作。
流行为视图
vlan-id:表示重新标记报文内层VLAN(CVLAN)的编号,取值范围为1~4094。
引用了重新标记报文内层VLAN Tag动作的QoS策略只能应用到入方向上。
对于LSCM2系列SC单板、SD系列接口板和SF系列接口板而言,引用了重新标记报文内层VLAN Tag动作的QoS策略请勿应用到聚合组成员端口、VSI和AC上。
对于SF系列接口板,基于Tunnel接口应用QoS策略时,流行为不支持配置为重新标记报文的CVLAN。
对于SF系列接口板、LSCM2系列SC单板和SD系列接口板应用QoS策略时,流行为配置为重新标记报文的CVLAN与流分类定义匹配指定隧道内的报文不支持配置到同一QoS策略中。
对于SF系列接口板、LSCM2系列SC单板和SD系列接口板,在同一个流行为中,仅filter permit、accounting、remark dot1p、remark service-vlan-id可以和remark customer-vlan-id同时被执行。
# 在流行为b1上配置重新标记报文的CVLAN为VLAN 111。
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p命令用来配置重新标记报文的802.1p优先级。
undo remark dot1p命令用来恢复缺省情况。
remark dot1p dot1p-value
undo remark dot1p
未配置重新标记报文802.1p优先级。
流行为视图
dot1p-value:802.1p优先级,取值范围为0~7。
LSCM2系列SC单板、SD系列接口板和SF系列接口板支持将引用了重新标记报文的802.1p优先级动作的QoS策略应用到出和入方向上。SE系列接口板和LSCM1GT48SC0单板仅支持将引用了重新标记报文的802.1p优先级动作的QoS策略应用到入方向上。需要注意的是,出方向上重新标记的802.1p优先级仅在出方向转发后的报文中生效。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence命令用来重新标记报文的丢弃优先级。
undo remark drop-precedence命令用来恢复缺省情况。
remark drop-precedence drop-precedence-value
未配置重新标记报文丢弃优先级的动作。
流行为视图
drop-precedence-value:丢弃优先级,取值范围为0~2。
仅QoS策略应用在入方向时,重新标记报文的丢弃优先级的动作才会生效。
当QoS策略中配置的流行为动作为重新标记报文的丢弃优先级时,该策略仅在SE系列接口板和LSCM2系列SC单板上生效。
# 重新标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来恢复缺省情况。
remark dscp dscp-value
undo remark dscp
未配置重新标记报文DSCP值的动作。
流行为视图
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
表1-5 DSCP关键字与值的对应表
关键字 |
DSCP值(二进制) |
DSCP值(十进制) |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
对于SF系列接口板,同时支持对入方向和出方向的报文重标记报文的DSCP值;对于其他接口板,只支持对入方向的报文重标记报文的DSCP值。
对于SF系列接口板,支持出方向的报文重标记报文的DSCP值时:
· 仅支持应用在全局、二层以太接口和三层以太接口。
· 在二层以太接口和三层以太接口上应用QoS策略时仅对单播报文有效。若三层以太网接口上存在子接口,则QoS策略对三层以太网子接口也生效。
· 若报文在转发过程部分字段发生了变化,且流分类中匹配了该变化的字段(如源MAC地址),无法重标记报文的DSCP值。
· 在流分类中不支持匹配报文出方向QoS本地ID值的规则。
· 若转发接口属于不同的接口分组,则无法重标记报文的DSCP值。如下两种情况代表不同接口分组:
¡ 不同单板上的接口。
¡ 同一单板上,在Probe视图执行display hardware internal port mapping命令,显示信息中LchipId字段取值不同的接口。
· 如下两种情况下,流行为不支持重新标记报文的DSCP值:
¡ 在聚合组成员端口上应用QoS策略。
¡ 定义匹配出接口的规则匹配的端口是聚合成员口。
在SF系列接口板上,对于ECMP的流量,不支持以下两种方式修改出方向报文的DSCP:
· 直接在接口上应用QoS策略修改出方向报文的DSCP。
· 通过流分类if-match outbound-interface匹配出方向报文,修改其DSCP。
在SF系列接口板上,在聚合组成员端口上应用QoS策略时,不支持将流行为配置为remark dscp。
在SF系列接口板上,在出方向应用QoS策略时,如果流分类中if-match outbound-interface的端口是聚合成员口,不支持将对应的流行为配置为remark dscp。
在SF系列接口板上,出方向应用QoS策略修改DSCP时,流分类中不支持匹配egress-active qos-local-id。
# 重新标记报文的DSCP值为6。
remark ip-precedence命令用来重新标记报文的IP优先级。
undo remark ip-precedence命令用来恢复缺省情况。
remark ip-precedence ip-precedence-value
未配置重新标记报文IP优先级的动作。
流行为视图
ip-precedence-value:IP优先级,取值范围为0~7。
# 重新标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来恢复缺省情况。
remark [ green | red | yellow ] local-precedence local-precedence-value [ green | red | yellow ]
undo remark [ green | red | yellow ] local-precedence [ green | red | yellow ]
未配置重新标记报文本地优先级的动作。
流行为视图
green:对绿色报文进行重新标记。
red:对红色报文进行重新标记。
yellow:对黄色报文进行重新标记。
local-precedence-value:本地优先级,取值范围为0~15。
green:重标记报文为绿色报文。
red:重标记报文为红色报文。
yellow:重标记报文为黄色报文。
设备仅支持在入方向应用QoS策略配置重新标记报文的本地优先级。
对带颜色的报文重新标记本地优先级仅对LSCM2系列SC单板、SD系列接口板和SF系列接口板收到的报文生效。
重新标记报文的本地优先级即将命中QoS策略中流分类规则的报文送入指定的优先级队列中,实现报文在本设备中的差分服务。通过display qos queue-statistics interface outbound命令可查看端口队列出方向的统计信息。
使用本命令标记报文的本地优先级时,还可以标记报文的颜色,通过16个不同的LP(Local Precedence,本地优先级)值和红、黄、绿三种颜色组合可以实现总计48种不同标记,大大增加了对报文的分类标记数量。可以先在接收报文的接口入方向上应用QoS策略,在该QoS策略中定义标记本地优先级和颜色的流行为,实现对入方向报文的分类。
使用本功能标记本地优先级LP和颜色之后,在报文转发的出方向上应用带颜色的LP到DSCP的优先级映射表,即执行qos map-table color命令并指定lp-tunnel-dscp参数,根据本地优先级和颜色来修改报文外层DSCP值的功能。
目前,带颜色的LP到DSCP的优先级映射表仅对报文的出方向为VXLAN隧道和VXLAN-DCI隧道时生效。
当本地优先级取值为8~15时,必须指定重标记报文的颜色参数。
# 重新标记报文的本地优先级值为2。
remark qos-local-id命令用来重新标记报文的QoS本地ID值。
undo remark qos-local-id命令用来恢复缺省情况。
remark qos-local-id [ egress-active ] local-id-value
undo remark qos-local-id [ egress-active ]
未配置重新标记报文的QoS本地ID值的动作。
流行为视图
egress-active:QoS本地ID值仅在出方向生效。如果未指定本参数,则QoS本地ID值仅在入方向生效。
local-id-value:QoS本地ID值,取值范围为1~4095,目前仅支持取值为1~384。如果指定egress-active参数,则取值范围为1~128。
在入方向应用QoS策略对报文的QoS本地ID值进行标记,此QoS本地ID值仅在入方向生效。
对于SF系列接口板,基于Tunnel接口应用QoS策略时,流行为不支持配置为重新标记报文的QoS本地ID值。
对于SF系列接口板、LSCM2系列SC单板和SD系列接口板应用QoS策略时,流行为重新标记报文的QoS本地ID值与流分类定义匹配指定隧道内的报文不支持配置到同一QoS策略中。
# 重新标记报文的QoS本地ID值为2。
[Sysname-behavior-database] remark qos-local-id 2
remark service-vlan-id命令用来重新标记报文的SVLAN。
undo remark service-vlan-id命令用来恢复缺省情况。
未配置重新标记报文的SVLAN的动作。
流行为视图
vlan-id:表示重新标记报文外层VLAN(SVLAN)的编号,取值范围为1~4094。
引用了重新标记报文外层VLAN Tag动作的QoS策略只能应用到入方向上。
对于LSCM2系列SC单板、SD系列接口板和SF系列接口板而言,引用了重新标记报文外层VLAN Tag动作的QoS策略请勿应用到聚合组成员端口、VSI和AC上。
重新标记报文外层VLAN编号时,在该报文的出接口上必须确保报文重新标记前的外层VLAN编号可以通过并且VLAN Tag不会被删除。否则将导致外层VLAN编号修改失败。
对于SF系列接口板,基于Tunnel接口应用QoS策略时,流行为不支持配置为重新标记报文的SVLAN。
对于SF系列接口板、LSCM2系列SC单板和SD系列接口板应用QoS策略时,流行为配置为重新标记报文的SVLAN与流分类定义匹配指定隧道内的报文不支持配置到同一QoS策略中。
对于SF系列接口板、LSCM2系列SC单板和SD系列接口板,在同一个流行为中,仅filter permit、accounting、remark dot1p、remark customer-vlan-id可以和remark service-vlan-id同时被执行。
# 在流行为b1上配置重新标记报文的SVLAN为VLAN 222。
[Sysname-behavior-b1] remark service-vlan-id 222
remark source-mac命令用来配置重新标记报文的源MAC地址。
undo remark source-mac命令用来恢复缺省情况。
remark source-mac mac-address
未配置重新标记报文的源MAC地址。
流行为视图
mac-address:源MAC地址,形式为H-H-H。
# 在流行为behavior1中配置重新标记报文的源MAC地址为600b-038a-a395。
[Sysname-behavior-behavior1] remark source-mac 600b-038a-a395
· traffic behavior
traffic behavior命令用来创建一个流行为,并进入流行为视图。如果指定的流行为已经存在,则直接进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
不存在流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
# 定义一个名为behavior1的流行为。
· display traffic behavior
classifier behavior命令用来为类指定流行为,即配置CB(Classifier-Behavior)对。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [ mode { dcbx | loose } | insert-before before-classifier-name ] *
没有为类指定流行为。
QoS策略视图
mode dcbx:表示该流分类与流行为的关联模式为DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议)模式。有关DCBX的介绍,请参见“二层技术-以太网交换配置指导”中的“LLDP”。
mode loose:表示该流分类与流行为的关联模式为宽松模式。仅基于控制平面应用QoS策略时,本模式才会生效。
insert-before before-classifier-name:表示将配置的类插入到QoS策略中已存在的指定类之前。before-classifier-name表示QoS策略中已存在的类名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示新配置的类与流行为配对将添加到QoS策略最后。
QoS策略中可以配置多个CB(Classifier-Behavior)对,应用QoS策略之后,报文按顺序逐个匹配QoS策略中CB对,遵循“一旦命中即停止匹配”的逻辑。如果匹配到某个CB对,则报文直接执行该CB对中指定流行为的所有转发动作,报文不再继续匹配其他CB对。
QoS策略下每个类只能与一个流行为关联。
如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
# 在QoS策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
# 在QoS策略user1中为类database指定流行为test,并将该类插入到策略中已存在的类class-a前。
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
· qos policy
control-plane命令用来进入控制平面视图。
(独立运行模式)
control-plane chassis chassis-number slot slot-number
slot slot-number:指定单板。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 进入指定slot上的控制平面视图。(独立运行模式)
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
control-plane management命令用来进入管理口控制平面视图。
# 进入管理口控制平面视图。
[Sysname] control-plane management
[Sysname-cp-management]
display qos policy命令用来显示QoS策略的配置信息。
(独立运行模式)
display qos policy user-defined [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
display qos policy user-defined [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义QoS策略。
ipv6-matching:显示IPv6 Matching类型的QoS策略。
accounting:显示统计类型的QoS策略。
mirroring:显示镜像类型的QoS策略。
remarking:显示重标记类型的QoS策略。
tcp-erspan:显示TCP ERSPAN类型的QoS策略。
exact-matching:显示精确匹配类型的QoS策略。
policy-name:QoS策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:QoS策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定单板的QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的QoS策略的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的QoS策略的配置信息。(IRF模式)
如果未指定ipv6-matching、accounting、mirroring、remarking、tcp-erspan或exact-matching,则显示用户定义的通用类型QoS策略的配置信息。
# 显示用户定义QoS策略的配置信息。
User-defined QoS policy information:
Policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
Green action : pass
Behavior: 2
Marking:
Remark dot1p 4
Behavior: 3
-none-
# 显示用户定义的统计类型QoS策略的配置信息。
<Sysname> display qos policy user-defined accounting
Accounting policy: 1 (ID 100)
Behavior: 1
# 显示用户定义的镜像类型QoS策略的配置信息。
<Sysname> display qos policy user-defined mirroring
Mirroring policy: 1 (ID 100)
Behavior: 1
Mirroring:
Mirror to the CPU
# 显示用户定义的重标记类型QoS策略的配置信息。
<Sysname> display qos policy user-defined remarking
Marking policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
# 显示用户定义的TCP ERSPAN类型QoS策略的配置信息。
<Sysname> display qos policy user-defined tcp-erspan
TCP ERSPAN policy: 1 (ID 100)
Behavior: 1
Mirroring:
Mirror to the interface: Ten-GigabitEthernet3/0/1
表1-6 display qos policy命令显示信息描述表
User-defined QoS policy information |
用户自定义QoS策略的信息 |
Policy |
用户定义的QoS策略名 |
IPv6 Matching policy |
用户定义的IPv6类型的QoS策略名 |
Accounting policy |
用户定义的统计类型的QoS策略名 |
Mirroring policy |
用户定义的镜像类型的QoS策略名 |
Marking policy |
用户定义的重标记类型的QoS策略名 |
TCP ERSPAN policy |
用户定义的TCP ERSPAN类型的QoS策略名 |
Exact-matching policy |
用户定义的精确匹配类型的QoS策略名 |
其它显示信息解释请参见display traffic classifier和display traffic behavior。
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
(独立运行模式)
display qos policy control-plane chassis chassis-number slot slot-number
slot slot-number:显示指定单板的控制平面应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的控制平面应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 显示应用到slot 1控制平面的QoS策略信息。(独立运行模式)
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Yellow packets: 0 (Packets) 0 (Bytes)
Red packets : 0 (Packets) 0 (Bytes)
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets), 0 (Bytes)
0 (pps), 0 (bps)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
表1-7 display qos policy control-plane命令显示信息描述表
Direction |
QoS策略应用的方向 |
display qos policy control-plane management命令用于显示管理口控制平面应用的QoS策略信息。
# 显示对进入管理口控制平面的报文应用的QoS策略信息。
<Sysname> display qos policy control-plane management
Control plane management
Direction: Inbound
Policy: a
Classifier: default-class
Matched : 0 (Packets) 0 (Bytes)
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: a
Matched : 3 (Packets) 180 (Bytes)
Operator: OR
Rule(s) :
If-match control-plane protocol arp
If-match control-plane protocol rip
If-match control-plane protocol-group critical
If-match acl 3001
If-match control-plane protocol bgp
If-match control-plane protocol bgp4+
If-match control-plane protocol ftp
If-match control-plane protocol http https icmp icmp6 ripng snmp
Behavior: a
CIR 128 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Green action : pass
Green packets : 3 (Packets) 180 (Bytes)
表1-8 display qos policy control-plane management命令显示信息描述表
Direction |
QoS策略应用的方向 |
display qos policy control-plane management pre-defined命令用来显示系统预定义的管理口控制平面应用QoS策略的信息。
# 显示系统预定义的管理口控制平面应用QoS策略的信息。
<Sysname> display qos policy control-plane management pre-defined
Pre-defined control plane policy management
Protocol Priority Bandwidth Group
Default N/A 100000 (bps) N/A
ARP N/A 128 (bps) normal
BGP N/A 256 (bps) critical
BGPv6 N/A 256 (bps) critical
HTTP N/A 512 (bps) management
HTTPS N/A 512 (bps) management
ICMP N/A 128 (bps) monitor
ICMPv6 N/A 128 (bps) monitor
OSPF Multicast N/A 256 (bps) critical
OSPF Unicast N/A 256 (bps) critical
OSPFv3 Multicast N/A 256 (bps) critical
OSFPv3 Unicast N/A 256 (bps) critical
RIP N/A 1024 (bps) critical
RIPng N/A 256 (bps) critical
SNMP N/A 512 (bps) management
SSH N/A 512 (bps) management
TELNET N/A 512 (bps) management
FTP N/A 512 (bps) management
TFTP N/A 512 (bps) management
表1-9 display qos policy control-plane management pre-defined命令显示信息描述表
Pre-defined control plane policy management |
预定义管理口控制平面策略内容 |
Protocol |
系统预定义协议报文类型 |
Priority |
优先级 |
Bandwidth |
带宽 |
Group |
协议组 |
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
(独立运行模式)
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的系统预定义的控制平面策略信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有在位单板的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的系统预定义的控制平面策略信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有成员设备上在位单板的系统预定义的控制平面应用QoS策略的信息。(IRF模式)
# 显示指定slot上的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
ARP 109 1000 (pps) normal
ARP Snooping 109 1000 (pps) normal
BGP 111 2800 (pps) critical
BGPv6 112 2800 (pps) critical
DHCP 117 384 (kbps) normal
DHCP Snooping 117 384 (kbps) redirect
DHCPv6 118 384 (kbps) normal
802.1x 67 500 (pps) important
MVRP 79 100 (pps) critical
ICMP 113 1000 (pps) monitor
ICMPv6 114 1000 (pps) monitor
IS-IS 69 1000 (pps) critical
LACP 64 200 (pps) critical
LDP 110 500 (pps) important
LDPv6 110 500 (pps) important
LLDP 68 100 (pps) important
MSDP 96 1000 (pps) important
NTP 114 100 (kbps) normal
OAM 64 200 (pps) important
OSPF Multicast 105 100 (kbps) critical
OSPF Unicast 105 100 (kbps) critical
OSPFv3 Multicast 106 100 (kbps) critical
OSPFv3 Unicast 106 100 (kbps) critical
PIM Multicast 97 100 (kbps) important
PIM Unicast 97 2800 (pps) important
PIMv6 Multicast 98 100 (kbps) important
PIMv6 Unicast 98 2800 (pps) important
PORTAL 90 500 (kbps) redirect
PVST 84 2800 (pps) critical
RIP 107 2800 (pps) normal
RIPng 108 2800 (pps) normal
RRPP 71 100 (kbps) important
RSVP 115 200 (pps) important
Smart Link 68 100 (pps) important
SNMP 116 2800 (pps) management
STP 65 100 (pps) critical
UDP Helper 122 100 (kbps) normal
VRRP 103 1000 (pps) important
VRRPv6 104 1000 (pps) important
BFD 34 8000 (pps) critical
表1-10 display qos policy control-plane pre-defined命令显示信息描述表
Pre-defined policy information |
预定义控制平面策略内容 |
Protocol |
系统预定义协议报文类型 |
Priority |
优先级 |
Bandwidth |
带宽 |
Group |
协议所属的协议组 |
其它显示信息解释请参见if-match和display traffic behavior。
display qos policy control-plane rule-statistics命令用来显示应用在控制平面的QoS策略的统计信息。
(独立运行模式)
display qos policy control-plane slot slot-number rule-statistics
display qos policy control-plane chassis chassis-number slot slot-number rule-statistics
slot slot-number:显示指定单板的控制平面应用QoS策略的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的控制平面应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
使用本命令可以显示QoS策略里流分类中多个匹配规则匹配到的报文统计数据。请在QoS策略里的流行为中执行accounting命令开启流量统计功能,保证统计的报文匹配数据信息正常显示。
# 显示应用在slot 0的控制平面QoS策略的统计信息。(独立运行模式)
<Sysname> display qos policy control-plane slot 0 rule-statistics
Control plane slot 0
Direction: Inbound, Policy: p1, Status: Succeed
Classifier: c1, Operator: AND, Behavior: b1, State: Succeed
Accounting: Enabled, Car: Enabled
if-match source-mac 0001-0001-0001
if-match local-precedence 1
if-match acl 3000
rule 0 permit ip source 1.1.1.1 0
Passed packets 500, Passed pps 5
Dropped packets 500, Dropped pps 5
Passed bytes 5000, Passed bps 50
Dropped bytes 5000, Dropped bps 50
if-match acl 3000
rule 5 permit ip destination 2.2.2.2 0
表1-11 display qos policy control-plane rule-statistics命令显示信息描述表
Control plane slot |
指定的单板号控制平面 |
Direction |
QoS策略应用的方向 |
Policy |
QoS策略名称 |
Status |
QoS策略应用状态,取值包括: · Succeed:QoS策略应用成功 · Failed:QoS策略应用失败,失败状态下无法正常显示统计信息 |
Classifier |
QoS策略的流分类名称 |
Operator |
流分类中各匹配规则之间的逻辑关系,取值包括: · AND:逻辑“与”的关系,报文要同时满足if-match所有匹配的分类规则,才作为统计为匹配的报文流量。需要注意的是如果使用的是if-match acl,ACL中的不同rule规则之间仍为“或”的关系 · OR:逻辑“或”的关系,报文仅需要满足if-match的规则之一,就可以作为统计为匹配的报文流量 |
Behavior |
QoS策略的流行为名称 |
State |
Classifier和Behavior配置冲突和异常状态: · Succeed:Classifier和Behavior的配置正常 · Failed:Classifier或Behavior的配置中存在异常,例如流分类中存在不可同时生效的匹配条件,流行为中的动作之间存在冲突,状态下无法正常显示统计信息 |
Accounting |
流行为中accounting流量统计行为的配置状态: · Enabled:开启了流量统计行为 · Disabled:未开启流量统计行为,流量数据无法统计 |
Car |
流行为中流量监管的配置状态: · Enabled:配置了流量监管 · Disabled:未配置流量监管,流量数据无法统计 |
if-match xx, |
表示流分类中if-match命令定义的匹配分类规则 |
rule yy |
ACL规则的详细信息,其中yy表示流分类中的ACL规则编号 |
Passed packets |
统计到通过的报文数量,只有在流行为中配置accounting命令指定packet参数才会显示报文数统计 |
Passed bytes |
统计到通过的字节数量,只有在流行为中配置accounting命令指定byte参数才会显示字节数统计 |
Passed pps |
统计到每秒通过的报文数量,只有在流行为中配置accounting命令指定packet参数才会显示报文数统计 |
Passed bps |
统计到每秒通过的bit数量,只有在流行为中配置accounting命令指定byte参数才会显示bit数统计 |
Dropped packets |
统计到丢弃的报文数量,只有在流行为中配置accounting命令指定packet参数才会显示报文数统计 |
Dropped bytes |
统计到丢弃的字节数量,只有在流行为中配置accounting命令指定byte参数才会显示字节数统计 |
Dropped pps |
统计到每秒丢弃的报文数量,只有在流行为中配置accounting命令指定packet参数才会显示报文数统计 |
Dropped bps |
统计到每秒丢弃的bit数量,只有在流行为中配置accounting命令指定byte参数才会显示bit数统计 |
· qos apply policy(control plane view)
· accounting
display qos policy global命令用来显示基于全局应用QoS策略的配置信息和运行情况。
(独立运行模式)
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy global [ slot slot-number ] [ inbound | outbound ]
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
ipv6-matching:显示IPv6 Matching类型QoS策略的配置信息和运行情况。
accounting:显示统计类型QoS策略的配置信息和运行情况。
mirroring:显示镜像类型QoS策略的配置信息和运行情况。
remarking:显示重标记类型QoS策略的配置信息和运行情况。
tcp-erspan:显示TCP ERSPAN类型QoS策略的配置信息和运行情况。
exact-matching:显示精确匹配类型QoS策略的配置信息和运行情况。
inbound:显示入方向QoS策略的配置信息和运行情况。
outbound:显示出方向QoS策略的配置信息和运行情况。
slot slot-number:显示指定单板的基于全局应用QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于全局应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于全局应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于全局应用QoS策略的信息。(IRF模式)
如果未指定ipv6-matching、accounting、mirroring、remarking、tcp-erspan或exact-matching,则显示通用类型QoS策略的配置信息和运行情况。
如果未指定显示方向,则同时显示出入两个方向QoS策略的配置信息和运行情况。
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
184057187 (Packets)
844575 (pps)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# 显示基于全局应用统计类型QoS策略的信息。
<Sysname> display qos accounting policy global
Direction: Inbound
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
# 显示基于全局应用镜像类型QoS策略的信息。
<Sysname> display qos mirroring policy global
Direction: Inbound
Mirroring policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Mirroring:
Mirror to the CPU
# 显示基于全局应用重标记类型QoS策略的信息。
<Sysname> display qos remarking policy global
Direction: Inbound
Marking policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
# 显示基于全局应用IPv6 Matching类型QoS策略的信息。
<Sysname> display qos ipv6-matching policy global
Direction: Inbound
IPv6 Matching policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl ipv6 3000
Behavior: 1
Marking:
Remark dscp 3
# 显示基于全局应用TCP ERSPAN类型QoS策略的信息。
<Sysname> display qos tcp-erspan policy global
Direction: Inbound
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 3000
Behavior: 1
Mirroring:
表1-12 display qos policy global命令显示信息描述表
Direction |
QoS策略应用的方向 |
Policy |
用户定义的QoS策略名 |
Accounting policy |
用户定义的统计类型的QoS策略名 |
Mirroring policy |
用户定义的镜像类型的QoS策略名 |
Marking policy |
用户定义的重标记类型的QoS策略名 |
TCP ERSPAN policy |
display qos policy global rule-statistics命令用来显示应用在全局的QoS策略的统计信息。
(独立运行模式)
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy global [ slot slot-number ] [ inbound | outbound ] rule-statistics
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ] rule-statistics
inbound:显示入方向QoS策略的统计信息。
outbound:显示出方向QoS策略的统计信息。
slot slot-number:显示指定单板的基于全局应用QoS策略的统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于全局应用QoS策略的统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于全局应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于全局应用QoS策略的统计信息。(IRF模式)
如果未指定显示方向,则同时显示出入两个方向QoS策略的统计信息。
# 显示应用在slot 0全局入方向的QoS策略的统计信息。(独立运行模式)
<Sysname> display qos policy global slot 0 inbound rule-statistics
Slot 0
if-match acl 3000
if-match acl 3000
表1-13 display qos policy global rule-statistics命令显示信息描述表
Direction |
QoS策略应用的方向 |
Policy |
QoS策略名称 |
Status |
Classifier |
QoS策略的流分类名称 |
Operator |
Behavior |
QoS策略的流行为名称 |
State |
Accounting |
Car |
if-match xx |
rule yy |
Passed packets |
Passed bytes |
Passed pps |
Passed bps |
Dropped packets |
Dropped bytes |
Dropped pps |
Dropped bps |
· qos apply policy global
· accounting
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
(独立运行模式)
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的配置信息和运行情况。
slot slot-number:显示指定单板上指定逻辑接口的QoS策略的配置信息和运行情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板逻辑接口的QoS策略的配置信息和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定逻辑接口的QoS策略的配置信息和运行情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板逻辑接口QoS策略的配置信息和运行情况。(IRF模式)
如果未指定ipv6-matching、accounting、mirroring、remarking、tcp-erspan或exact-matching,则显示通用类型QoS策略的配置信息。
# 显示对接口Ten-GigabitEthernet3/0/1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface ten-gigabitethernet 3/0/1 inbound
Interface: Ten-GigabitEthernet3/0/1
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# 显示对接口Ten-GigabitEthernet3/0/1接收到的报文应用统计类型QoS策略的配置信息和运行情况。
<Sysname> display qos accounting policy interface ten-gigabitethernet 3/0/1 inbound
Direction: Inbound
Accounting Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Accounting enable:
0 (pps), 0 (bps)
# 显示对接口Ten-GigabitEthernet3/0/1接收到的报文应用重标记类型QoS策略的配置信息和运行情况。
<Sysname> display qos remarking policy interface ten-gigabitethernet 3/0/1 inbound
Direction: Inbound
Marking policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
# 显示对接口Ten-GigabitEthernet3/0/1接收到的报文应用镜像类型QoS策略的配置信息和运行情况。
<Sysname> display qos mirroring policy interface ten-gigabitethernet 3/0/1 inbound
Direction: Inbound
Mirroring policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Mirroring:
Mirror to the CPU
# 显示对接口Ten-GigabitEthernet3/0/1接收到的报文应用TCP ERSPAN类型QoS策略的配置信息和运行情况。
<Sysname> display qos tcp-erspan policy interface ten-gigabitethernet 3/0/1 inbound
Direction: Inbound
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Mirroring:
Mirror to the interface: Ten-GigabitEthernet3/0/2
# 显示所有接口上QoS策略的配置信息和运行情况。
Direction: Inbound
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Green action : pass
Interface: Ten-GigabitEthernet3/0/3
Direction: Inbound
Policy: b
Classifier: b
Operator: AND
Rule(s) :
If-match any
Behavior: b
Green action : pass
Green packets : 0(Packets)
Interface: Ten-GigabitEthernet3/0/4
Direction: Inbound
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: Ten-GigabitEthernet3/0/5
Green action : pass
表1-14 display qos policy interface命令显示信息描述表
Direction |
QoS策略应用的方向 |
Policy |
用户定义的QoS策略名 |
IPv6类型的QoS策略名 |
Accounting policy |
统计类型的QoS策略名 |
Mirroring policy |
镜像类型的QoS策略名 |
Marking policy |
重标记类型的QoS策略名 |
TCP ERSPAN policy |
精确匹配类型的QoS策略名 |
Mode |
QoS和ACL资源的共享模式,当应用QoS策略时携带了share-mode关键字,显示信息中才会出现该字段 |
Green packets |
(仅QoS策略配置了accounting流量统计动作才会有统计计数)绿色报文的流量统计 |
Yellow packets |
(仅QoS策略配置了accounting流量统计动作才会有统计计数)黄色报文的流量统计 |
Red packets |
(仅QoS策略配置了accounting流量统计动作才会有统计计数)红色报文的流量统计 |
display qos policy interface rule-statistics命令用来显示应用在接口上的QoS策略的统计信息。
(独立运行模式)
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ] rule-statistics
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ] rule-statistics
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的统计信息。
slot slot-number:显示指定单板上指定逻辑接口的QoS策略的统计信息。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板逻辑接口的QoS策略的统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定逻辑接口的QoS策略的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。仅对于逻辑接口才可以指定本参数。如果未指定本参数,则显示全局主用主控板逻辑接口QoS策略的统计信息。(IRF模式)
# 显示应用在slot 1所有接口入方向的QoS策略的统计信息。(独立运行模式)
<Sysname> display qos policy global slot 1 inbound rule-statistics
Slot 1
if-match acl 3000
if-match acl 3000
表1-15 display qos policy interface rule-statistics命令显示信息描述表
接口编号和接口类型 |
Direction |
QoS策略应用的方向 |
Policy |
QoS策略名称 |
Status |
Classifier |
QoS策略的流分类名称 |
Operator |
Behavior |
QoS策略的流行为名称 |
State |
Accounting |
Car |
if-match xx |
rule yy |
Passed packets |
Passed bytes |
Passed pps |
Passed bps |
Dropped packets |
Dropped bytes |
Dropped pps |
Dropped bps |
· qos apply policy (Interface view)
· accounting
display qos policy l2vpn-ac命令用来显示L2VPN AC承载的以太网服务实例上QoS策略的配置信息和运行情况。
(独立运行模式)
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound ]
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ chassis chassis-number slot slot-number ] ] [ inbound ]
ipv6-matching:指定IPv6 Matching类型的QoS策略。
accounting:指定统计类型的QoS策略。
mirroring:指定镜像类型的QoS策略。
remarking:指定重标记类型的QoS策略。
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口下以太网服务实例上QoS策略的配置信息和运行情况。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将显示接口下所有以太网服务实例上QoS策略的配置信息和运行情况。
slot slot-number:显示指定单板上指定二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上二层聚合接口下以太网服务实例的QoS策略的配置信息和运行情况。(IRF模式)
inbound:显示入方向QoS策略的配置信息和运行情况。指定与未指定本关键字时,命令的执行结果相同。
# 显示对接口Ten-GigabitEthernet3/0/1下以太网服务实例1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy l2vpn-ac interface ten-gigabitethernet 3/0/1 service-instance 1 inbound
Interface: Ten-GigabitEthernet3/0/1 Service instance ID: 1
Direction: Inbound
Policy: p
Classifier: c
Operator: AND
Rule(s) :
If-match any
Behavior: b
CIR 88 (kbps), CBS 5632 (Bytes), EBS 0 (Bytes)
Green action : pass
表1-16 display qos policy l2vpn-ac命令显示信息描述表
Service instance ID |
以太网服务实例ID |
Direction |
QoS策略应用的方向 |
Green action |
对绿色报文的动作 |
Yellow action |
对黄色报文的动作 |
Red action |
对红色报文的动作 |
Green packets |
绿色报文的流量统计 |
Yellow packets |
黄色报文的流量统计 |
Red packets |
红色报文的流量统计 |
display qos policy l2vpn-ac rule-statistics 命令用来显示应用在L2VPN AC以太网服务实例上QoS策略的统计信息。
(独立运行模式)
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound ] rule-statistics
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ chassis chassis-number slot slot-number ] ] [ inbound ] rule-statistics
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口下以太网服务实例上QoS策略的统计信息。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将显示接口下所有以太网服务实例上QoS策略的统计信息。
slot slot-number:显示指定单板上指定二层聚合接口下以太网服务实例的QoS策略的统计信息。slot-number表示单板所在的槽位号。仅对于二层聚合口才可以指定本参数。如果未指定本参数,将显示所有单板上二层聚合接口下以太网服务实例的QoS策略的统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定二层聚合接口下以太网服务实例的QoS策略的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。仅对于二层聚合口才可以指定本参数。如果未指定本参数,将显示所有单板上二层聚合接口下以太网服务实例的QoS策略的统计信息。(IRF模式)
# 显示应用在slot 1接口Ten-GigabitEthernet3/0/1下以太网服务实例1应用QoS策略的统计信息。(独立运行模式)
<Sysname> display qos policy l2vpn-ac interface ten-gigabitethernet 3/0/1 slot 1 inbound rule-statistics
Slot 1
if-match acl 3000
if-match acl 3000
表1-17 display qos policy l2vpn-ac rule-statistics命令显示信息描述表
接口编号和接口类型 |
以太网服务实例ID |
Direction |
QoS策略应用的方向 |
Policy |
QoS策略名称 |
Status |
Classifier |
QoS策略的流分类名称 |
Operator |
Behavior |
QoS策略的流行为名称 |
State |
Accounting |
Car |
if-match xx, |
rule yy |
Passed packets |
Passed bytes |
Passed pps |
Passed bps |
Dropped packets |
Dropped bytes |
Dropped pps |
Dropped bps |
· qos apply policy (Ethernet service instance view)
· accounting
display qos policy user-profile命令用来显示用户上线后User Profile下应用的QoS策略的信息和运行情况。
(独立运行模式)
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name profile-name:指定User Profile的名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线,且必须以英文字母开始,区分大小写。User Profile的名称必须全局唯一。如果未指定本参数,将显示所有User Profile下应用的QoS策略的信息和运行情况。
user-id user-id:表示在线用户的ID,为系统所分配,取值范围为十六进制数0~fffffffe。若未指定本参数,则显示所有用户在User Profile下应用的QoS策略的信息和运行情况。
slot slot-number:显示指定单板上指定用户在User Profile下应用的QoS策略的信息和运行情况,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上的在线用户的QoS策略的信息和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上指定用户在User Profile下应用的QoS策略的信息和运行情况,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有成员设备所有单板上指定用户在User Profile下应用的QoS策略的信息和运行情况。(IRF模式)
# 显示指定全局用户(从聚合口等全局口上线的用户)在User Profile下应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy user-profile name abc user-id 30000000 inbound
User-Profile: abc
User ID: 0x30000000(global)
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
# 显示指定的非全局用户在User Profile下应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy user-profile name abc user-id 30000001 inbound
User-Profile: abc
slot 2:
User ID: 0x30000001(local)
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
表1-18 display qos policy user-profile命令显示信息描述表
User-Profile |
User Profile名称 |
User ID |
上线用户的ID |
global |
该用户从聚合口等全局口上线 |
local |
该用户从物理口上线 |
Mirror to the interface |
镜像到接口 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为byte |
EBS |
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位为byte |
PIR |
峰值信息速率 |
Direction |
QoS策略应用的方向 |
Matched |
符合分类规则的数据包数目 |
Green packets |
绿色报文的流量统计 |
Yellow packets |
黄色报文的流量统计 |
Red packets |
红色报文的流量统计 |
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的配置信息和运行情况。
(独立运行模式)
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称,为1~31个字符的字符串,区分大小写。
vlan vlan-id:显示指定VLAN上应用QoS策略的信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
slot slot-number:显示指定单板上基于VLAN应用QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于VLAN应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于VLAN应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于VLAN应用QoS策略的信息。(IRF模式)
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
Direction: inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
表1-19 display qos vlan-policy命令显示信息描述表
Direction |
QoS策略应用的方向 |
display qos vlan-policy rule-statistics命令用来显示应用在指定VLAN上QoS策略的统计信息。
(独立运行模式)
display qos vlan-policy vlan [ vlan-id ] [ slot slot-number ] [ inbound | outbound ] rule-statistics
display qos vlan-policy vlan [ vlan-id ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ] rule-statistics
vlan vlan-id:显示指定VLAN上应用QoS策略的统计信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
slot slot-number:显示指定单板上基于VLAN应用QoS策略的统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于VLAN应用QoS策略的统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于VLAN应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于VLAN应用QoS策略的统计信息。(IRF模式)
# 显示应用在Slot 1,VLAN 10入方向上QoS策略的统计信息。(独立运行模式)
<Sysname> display qos vlan-policy vlan 10 slot 1 inbound rule-statistics
Slot 0
Vlan 10
if-match acl 3000
if-match acl 3000
表1-20 display qos policy control-plane rule-statistics命令显示信息描述表
VLAN |
VLAN ID值 |
Direction |
QoS策略应用的方向 |
Policy |
QoS策略名称 |
Status |
Classifier |
QoS策略的流分类名称 |
Operator |
Behavior |
QoS策略的流行为名称 |
State |
Accounting |
Car |
if-match xx, |
rule yy |
Passed packets |
Passed bytes |
Passed pps |
Passed bps |
Dropped packets |
Dropped bytes |
Dropped pps |
Dropped bps |
· qos vlan-policy
· accounting
qos apply policy命令用来在控制平面、管理口控制平面、接口或以太网服务实例上应用QoS策略。
undo qos apply policy命令用来取消控制平面、管理口控制平面、接口或以太网服务实例上应用的QoS策略。
qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy policy-name { inbound | outbound } [ longest-match | share-mode ] *
undo qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy policy-name { inbound | outbound }
未应用QoS策略。
控制平面视图/管理口控制平面视图
以太网服务实例视图
ipv6-matching:指定IPv6 Matching类型的QoS策略。仅支持基于接口和以太网服务实例应用IPv6类型的QoS策略。
accounting:指定统计类型的QoS策略。仅支持基于接口和以太网服务实例应用统计类型的QoS策略。
mirroring:指定镜像类型的QoS策略。仅支持基于接口和以太网服务实例应用镜像类型的QoS策略。
remarking:指定重标记类型的QoS策略。仅支持基于接口和以太网服务实例应用重标记类型的QoS策略。
tcp-erspan:指定TCP ERSPAN类型的QoS策略。仅支持基于接口应用TCP ERSPAN类型的QoS策略。
exact-matching:指定精确匹配类型的QoS策略。仅支持基于接口入方向应用精确匹配类型的QoS策略。
policy-name:策略名,为1~31个字符的字符串,区分大小写。
inbound:入方向应用QoS策略。
outbound:出方向应用QoS策略。设备不支持在以太网服务实例出方向应用QoS策略。
longest-match:QoS策略中的流分类引用ACL规则指定源或目的地址时,源或目的地址的掩码最长的流分类优先匹配流量并优先执行该流分类对应的流行为。
share-mode:对二层以太网接口间、VLAN接口间或三层以太网接口间应用共享QoS和ACL资源模式的QoS策略。该模式下,相同方向相同类型接口应用相同QoS策略的接口共享一份QoS和ACL资源。
基于控制平面应用QoS策略时,流分类中支持使用如下方法匹配上送控制平面的协议报文:
· 使用if-match control-plane protocol命令。
· 使用if-match control-plane protocol-group命令。
· 使用if-match acl命令,该方法可以更灵活地匹配上送控制平面的协议报文,需要注意的是if-match引用的ACL必须为高级ACL,且该ACL规则必须满足如下条件:
¡ 规则中的protocol协议类型必须为TCP或UDP;
¡ 规则中必须通过操作符eq指定一个源端口或指定一个目的端口。
例如,在流行为中,通过if-match引用配置rule permit tcp source-port eq 80规则的IPv4高级ACL,则该流行为可以匹配上送控制平面的TCP协议报文。
关于以太网服务实例的相关配置命令,请参见“MPLS命令参考”中的“MPLS L2VPN、VPLS”或“VXLAN命令参考”。
未指定longest-match参数应用QoS策略时,如果QoS策略中存在多个流分类和流分类绑定的流行为(即Classifier-Behavior对),则系统按照Classifier-Behavior对的配置顺序依次匹配流量,流分类匹配到流量后即执行该流分类对应的流行为,不再进行下一步匹配。
指定longest-match参数应用QoS策略时,如果流分类引用的ACL规则指定源或目的地址时,源或目的地址的掩码最长的流分类优先匹配流量并优先执行该流分类对应的流行为。例如,下列QoS策略A中按顺序配置了3对Classifier-Behavior,其中,Classifier 1中指定的ACL规则3001中未指定源和目的地址,Classifier 2中指定的ACL规则3002中目的地址为10.10.10.0,掩码长度为24,Classifier 3中指定的ACL规则3003中目的地址为10.10.10.10,掩码长度为32,则系统进行流量匹配时,掩码长度最长的Classifier 3的匹配优先顺序最高,优先进行报文匹配,再匹配掩码长度其次的Classifier 2,最后匹配Classifier 1。
QoS策略A:
Classifier 1 (if-match acl 3001) Behavior 1
Classifier 2 (if-match acl 3002) Behavior 2
Classifier 3 (if-match acl 3003) Behavior 3
如果多个流分类引用的ACL规则中同时指定源和目的地址,则先按照目的地址掩码长度排序,目的地址排序完成后,剩下的Classifier-Behavior对再按照源地址掩码长度继续排序。
指定longest-match参数的QoS策略仅在接口视图、VSI视图和以太网服务实例视图下配置,以太网服务实例仅入方向时支持此参数。
在QoS策略中,如果流分类配置了规则匹配VXLAN或GENEVE报文的内层报文信息时,longest-match参数不生效。
应用QoS策略时,如果携带了share-mode关键字,则需要注意的是:
· 同一单板的相同方向上所有应用了该QoS策略的接口共享一份QoS和ACL资源,而未携带share-mode关键字时,应用该QoS策略的各接口独享一份QoS和ACL资源。
display qos policy interface命令中共享QoS和ACL资源的接口的统计信息不仅包含接口自身的统计信息,还包含了所有共享该QoS和ACL资源的接口的统计信息。
QoS策略应用后不能动态修改QoS和ACL的资源共享模式,如需修改,请先取消该接口应用的QoS策略,然后在配置接口应用QoS策略时选择携带或不携带share-mode关键字。
基于接口应用QoS策略时,在相同方向最多可以应用七个不同类型的策略,包括一个通用类型的QoS策略、一个IPv6 Matching类型的QoS策略、一个统计类型的QoS策略、一个镜像类型的QoS策略、一个重标记类型的QoS策略、一个TCP ERSPAN类型的QoS策略和一个精确匹配类型的QoS策略。接口同时应用不同类型的QoS策略后,可以对接口收到的同一份流量分别执行不同的流行为动作。
指定exact-matching参数配置精确匹配策略时:
· 该策略中仅支持使用exact-match命令配置EM模板中定义的匹配规则,且不支持配置掩码类型的规则。关于EM模板的匹配规则详细介绍请参见“ACL和QoS命令参考”中的“ACL”。
· 报文将优先匹配精确匹配策略。
· 仅支持在接口入方向配置,且不支持和其他参数同时配置。
针对LSCM2XPG24SF0、LSCM2XPT24SF0单板,ONU接口不支持应用QoS策略和包过滤,OLT口与ONU子接口上支持应用QoS策略和包过滤。
SF系列接口板支持基于Tunnel接口出和入方向应用QoS策略,且隧道模式需要指定为vxlan、vxlan ipv6、vxlan-dci或者vxlan-dci ipv6。
SF系列接口板支持基于VSI接口出方向应用QoS策略,且流分类中不支持配置用户自定义ACL或二层ACL匹配规则。
仅SF系列接口板支持share-mode关键字。
对于SF系列接口板、LSCM2系列SC单板和SD系列接口板,VLAN接口入方向应用Qos策略时,流行为不支持配置重新标记报文的QoS本地ID值、CVLAN、SVLAN以及添加报文的外层VLAN Tag。
对于SE系列接口板和LSCM1GT48SC0单板,在VLAN接口出方向应用QoS策略时,不支持跨接口组之间的转发。
对于SF系列接口板、LSCM2系列SC单板和SD系列接口板,设备的工作模式为标准模式时,在VLAN接口出方向应用QoS策略时,不支持跨接口组之间的转发。有关设备工作模式的详细介绍,请参见“基础配置指导”中的“设备管理”。
# 将QoS策略TEST1应用到接口Ten-GigabitEthernet3/0/1的出方向上。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] qos apply policy TEST1 outbound
# 将统计类型QoS策略TEST2应用到接口Ten-GigabitEthernet3/0/1的出方向上。
[Sysname-Ten-GigabitEthernet3/0/1] qos apply accounting policy TEST2 outbound
# 将镜像类型QoS策略TEST3应用到接口Ten-GigabitEthernet3/0/1的出方向上。
[Sysname-Ten-GigabitEthernet3/0/1] qos apply mirroring policy TEST3 outbound
# 将重标记类型QoS策略TEST4应用到接口Ten-GigabitEthernet3/0/1的出方向上。
[Sysname-Ten-GigabitEthernet3/0/1] qos apply remarking policy TEST4 outbound
# 将TCP ERSPAN类型QoS策略TEST4应用到接口Ten-GigabitEthernet3/0/1的出方向上。
[Sysname-Ten-GigabitEthernet3/0/1] qos apply tcp-erspan policy TEST4 outbound
# 对进入3号槽控制平面的报文应用QoS策略TEST5。
[Sysname-cp-slot3] qos apply policy TEST5 inbound
# 对进入以太网服务实例的报文应用通用类型QoS策略TEST9。
[Sysname-Ten-GigabitEthernet3/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet3/0/1-srv200] qos apply policy TEST9 inbound
# 将IPv6类型QoS策略TEST13应用到接口Ten-GigabitEthernet3/0/1的出方向上。
[Sysname-Ten-GigabitEthernet3/0/1] qos apply ipv6-matching policy TEST13 outbound
qos apply policy命令用来在User Profile下应用策略。
undo qos apply policy命令用来取消User Profile下应用的策略。
undo qos apply policy policy-name { inbound | outbound }
未在User Profile下应用QoS策略。
User Profile视图
inbound:入方向应用QoS策略。
policy-name:策略名,为1~31个字符的字符串。
User Profile被删除将导致其下引用的QoS策略被删除。
# 对设备发送的上线用户user的流量应用策略test(该策略已经建立)。
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy policy-name global { inbound | outbound } [ longest-match ]
undo qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy policy-name global { inbound | outbound }
未在全局应用QoS策略。
exact-matching:指定精确匹配类型的QoS策略,仅支持入方向应用精确匹配类型的QoS策略。
inbound:入方向应用QoS策略。
全局应用的QoS策略对全部流量生效。
基于全局应用策略时,在相同方向最多可以应用七个不同类型的策略,包括一个通用类型的QoS策略、一个IPv6 Matching类型的QoS策略、一个统计类型的QoS策略、一个镜像类型的QoS策略、一个重标记类型的QoS策略、一个TCP ERSPAN类型的QoS策略和一个精确匹配类型的QoS策略。
QoS策略A:
如果未指定ipv6-matching、accounting、mirroring、remarking、tcp-erspan或exact-matching,则在全局应用通用类型QoS策略。
· 报文将优先匹配精确匹配策略。
· 仅支持在全局入方向配置,且不支持和其他参数同时配置。
# 将通用类型QoS策略user1应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
# 将镜像类型QoS策略user2应用到全局的入方向上。
[Sysname] qos apply mirroring policy user2 global inbound
qos policy命令用来创建一个QoS策略,并进入QoS策略视图。如果指定的QoS策略已经存在,则直接进入QoS策略视图。
undo qos policy命令用来删除一个QoS策略。
qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy policy-name
undo qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan | exact-matching ] policy policy-name
不存在QoS策略。
创建QoS策略时:
· 如果未指定ipv6-matching、accounting、mirroring、remarking、tcp-erspan或exact-matching,则表示通用类型的QoS策略。
· 不同类型的QoS策略不能使用相同的名称。
· 请避免使用“ipv6-matching”、“accounting”、“mirroring”、“remarking”、“tcp-erspan”、“exact-matching”做策略名称,也不要使用这些词的前几个字母做策略名称,例如“ipv6”、“acc”、“mirror”、“remark”、“tcp”、“exact”等。如果这样做,会导致执行display qos policy user-defined policy-name命令时无相关信息显示,因为系统会认为输入的策略名是命令行关键字而非policy-name。
如下各类型QoS策略的使用方法相同:
· 通用类型的QoS策略可以应用在所有支持的位置,包括接口、VLAN、全局等,能配置所有的流行为动作。
· IPv6 Matching类型的QoS策略仅支持应用在接口、以太网服务实例或全局,常用于配置引用IPv6 ACL的流分类。
· 统计类型QoS策略仅支持应用在接口、以太网服务实例或全局,常用于配置流量统计动作。
· 镜像类型QoS策略仅支持应用在接口、以太网服务实例或全局,常用于配置镜像动作。
· 重标记类型QoS策略仅支持应用在接口、以太网服务实例或全局,常用于配置重标记动作。
· TCP ERSPAN类型QoS策略仅支持应用在接口或全局,常用于配置erspan镜像动作。
· 精确匹配类型QoS策略仅支持应用在接口或全局入方向,常用于配置基于EM模板的高性能精确匹配业务。
TCP ERSPAN类型的QoS策略中流分类用来匹配TCP报文的标识(包括ACK、FIN、PSH、RST、SYN和URG等),QoS策略中的流量转发动作是流镜像ERSPAN,关于流镜像ERSPAN的详细介绍,请参见“网络管理和监控配置指导”中的“镜像”。
如果需要同时对用户业务流进行流镜像分析和流限速,则可以使用通用类型的QoS策略对上线用户进行带宽限速,使用TCP ERSPAN类型的QoS策略将用户业务流进行流镜像分析,两类QoS策略使用的硬件资源互不影响。
如果QoS策略已经被应用,则不允许删除,需要先在应用的位置上取消对QoS策略的应用,然后再使用undo qos policy命令删除。
# 定义一个名为user1的QoS策略。
# 定义一个名为user2的统计类型的QoS策略。
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# 定义一个名为user3的重标记类型的QoS策略。
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
# 定义一个名为user4的镜像类型的QoS策略。
[Sysname] qos mirroring policy user4
[Sysname-qospolicy-user4]
# 定义一个名为user6的IPv6 Matching类型的QoS策略。
[Sysname] qos ipv6-matching policy user6
[Sysname-qospolicy-user6]
· qos apply policy
· qos vlan-policy
qos vlan-policy命令用来在VLAN上应用QoS策略。
undo qos vlan-policy命令用来取消VLAN上应用的QoS策略。
qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound } [ longest-match ]
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
未在VLAN上应用QoS策略。
policy-name:策略名称,为1~31个字符的字符串,区分大小写。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:入方向应用QoS策略。
在同一个VLAN的同一个方向上,不能同时应用扩展类型和普通类型策略,二者取其一。扩展型策略可以使用更多的硬件资源,但支持的参数类型较少。
QoS策略A:
# 在VLAN 200、300、400、500的入方向上应用策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
(独立运行模式)
reset qos policy control-plane chassis chassis-number slot slot-number
slot slot-number:清除指定单板的基于控制平面应用QoS策略的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的基于控制平面应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 清除应用到指定slot上的控制平面的QoS策略统计信息。(独立运行模式)
<Sysname> reset qos policy control-plane slot 1
reset qos policy control-plane management命令用来清除管理口控制平面QoS策略的统计信息。
# 清除管理口控制平面QoS策略的统计信息。
<Sysname> reset qos policy control-plane management
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
reset qos [ ipv6-matching | accounting | mirroring | remarking| tcp-erspan | exact-matching ] policy global [ inbound | outbound ]
inbound:清除入方向QoS策略的统计信息。
outbound:清除出方向QoS策略的统计信息。
如果未指定ipv6-matching、accounting、mirroring、remarking、tcp-erspan或exact-matching,则清除通用类型QoS策略的统计信息。
如果未指定清除方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
# 清除全局入方向应用的镜像类型QoS策略的统计信息。
<Sysname> reset qos mirroring policy global inbound
reset qos policy l2vpn-ac命令用来清除L2VPN AC承载的以太网服务实例上QoS策略的统计信息。
reset qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ] [ inbound ]
interface interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将清除所有接口下以太网服务实例上QoS策略的统计信息。
service-instance instance-id:指定以太网服务实例,instance-id为以太网服务实例的ID,取值范围为1~4096。如果未指定本参数,将清除接口下所有以太网服务实例上QoS策略的统计信息。
如果未指定ipv6-matching、accounting、mirroring和remarking,则清除通用类型QoS策略的统计信息。
# 清除接口Ten-GigabitEthernet3/0/1下以太网服务实例1入方向QoS策略的统计信息。
<Sysname> reset qos policy l2vpn-ac interface ten-gigabitethernet 3/0/1 service-instance 1 inbound
# 清除接口Ten-GigabitEthernet3/0/1下以太网服务实例1收到的IPv6 Matching类型QoS策略的统计信息。
<Sysname> reset qos ipv6-matching policy l2vpn-ac interface ten-gigabitethernet 3/0/1 service-instance 1 inbound
· display qos policy l2vpn-ac
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
vlan vlan-id:指定VLAN。vlan-id为指定VLAN的ID号,取值范围为1~4094。
如果未指定方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
snmp-agent trap enable qos命令用来开启QoS模块的告警功能。
undo snmp-agent trap enable qos命令用来关闭QoS模块的告警功能。
QoS模块的告警功能处于关闭状态。
开启QoS模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 开启QoS告警功能。
[Sysname] snmp-agent trap enable qos
display qos map-table命令用来显示优先级映射表的配置情况。
display qos map-table [ dot1p-dp | dot1p-lp | dscp-dp | dscp-dscp | dscp-lp | exp-lp | lp-exp ]
优先级映射 |
dot1p-dp |
802.1p优先级到丢弃优先级映射表 |
dot1p-lp |
802.1p优先级到本地优先级映射表 |
dscp-dp |
DSCP到丢弃优先级映射表 |
dscp-lp |
DSCP到本地优先级映射表 |
dscp-dscp |
DSCP到DSCP映射表 |
exp-lp |
EXP到本地优先级映射表 |
lp-exp |
本地优先级到EXP映射表 |
如果未指定表的类型,将显示所有映射表的配置情况。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
表2-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME |
映射表的名称 |
TYPE |
映射表的类型 |
IMPORT |
映射表的输入值 |
EXPORT |
映射表的输出值 |
display qos map-table color命令用来显示带颜色优先级映射表配置情况。
display qos map-table color [ green | yellow | red ] [ lp-tunnel-dscp ]
表2-3 优先级映射表
优先级映射 |
lp-tunnel-dscp |
本地优先级到隧道封装的外层DSCP映射表,这种类型的优先级映射表项主要应用在报文从VXLAN隧道或VXLAN-DCI隧道转发的场景,根据报文的本地优先级和颜色组合对应地封装报文外层DSCP信息 本映射表项需要配合qos vxlan-dci-tunnel outer dscp或vxlan-tunnel outer dscp命令使用,关于命令的详细介绍,请参见“VXLAN命令参考”中的“VXLAN”。使能上述命令之后按照本地优先级到隧道封装的外层DSCP映射表来控制报文的封装时,会对所有VXLAN报文转发产生影响 |
经过流量监管处理的报文被分成了三种颜色(绿色、黄色、红色),为了对不同颜色报文进行优先级映射,设备提供了多张带颜色优先级映射表,分别对应相应颜色的优先级映射关系。流量监管对报文处理的相关内容请参见流量监管章节内容。
如果未指定颜色,则同时显示三种颜色的优先级映射表的配置情况。
如果未指定方向,则同时显示出和入两个方向的优先级映射表的配置情况。
如果未指定优先级映射表的类型,则同时显示所有优先级映射表的配置情况。
# 显示绿色报文的本地优先级到隧道封装的外层DSCP映射表的配置信息。
<Sysname> display qos map-table color green lp-tunnel-dscp
MAP-TABLE NAME: lp-tunnel-dscp TYPE: pre-define COLOR: green
IMPORT : EXPORT
0 : 3
1 : 7
2 : 11
3 : 15
4 : 19
5 : 23
6 : 27
7 : 31
8 : 35
9 : 39
10 : 43
11 : 47
12 : 51
13 : 55
14 : 59
15 : 63
表2-4 display qos map-table color命令显示信息描述表
· vxlan-dci-tunnel outer dscp(VXLAN命令参考/VXLAN)
· vxlan-tunnel outer dscp(VXLAN命令参考/VXLAN)
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 B。
优先级映射表视图
import-value-list:输入值列表。
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
# 配置802.1p优先级到本地优先级映射表的映射关系,与802.1p优先级4、5相对应的本地优先级为1。
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
· display qos map-table
qos map-table { dot1p-dp | dot1p-lp | dscp-dp | dscp-dscp | dscp-lp | exp-lp | lp-exp }
优先级映射参数请参见display qos map-table。
# 进入802.1p优先级到本地优先级映射表视图。
· import
qos map-table color命令用来进入指定的带颜色优先级映射表视图。
qos map-table color { green | yellow | red } lp-tunnel-dscp
green:绿色报文。
yellow:黄色报文。
red:红色报文。
表2-5 优先级映射表
优先级映射 |
lp-tunnel-dscp |
本地优先级到隧道封装的外层DSCP映射表,这种类型的优先级映射表项主要应用在报文从VXLAN隧道或VXLAN-DCI隧道转发的场景,根据报文的本地优先级和颜色组合对应地封装报文外层DSCP信息 本映射表项需要配合vxlan-dci-tunnel outer dscp或vxlan-tunnel outer dscp命令使用,关于命令的详细介绍,请参见“VXLAN命令参考”中的“VXLAN”,使能上述命令之后按照本地优先级到隧道封装的外层DSCP映射表来控制报文的封装时,会对所有VXLAN报文转发产生影响 |
每个优先级映射(颜色也相同)存在双方向、接收报文方向、发送报文方向三张不同的映射表。如果未指定方向,则表示进入双方向的优先级映射表视图。
# 进入绿色报文的本地优先级到隧道封装的外层DSCP映射表视图。
[Sysname] qos map-table color green lp-tunnel-dscp
[Sysname-maptbl-green-lp-tunnel-dscp]
· display qos map-table color
· import
display qos trust interface命令用来显示端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示端口优先级信任模式信息。
<Sysname> display qos trust interface ten-gigabitethernet 3/0/1
Port priority information
Port priority: 4
Port dscp priority: -
Port priority trust type: dscp
表2-6 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成 |
Port priority information |
端口优先级信任信息 |
Port priority |
端口优先级 |
Port dscp priority |
改写报文的DSCP优先级的值,-表示未配置修改报文的DSCP优先级的值 |
Port priority trust type |
端口优先级信任类型,取值为: · dot1p:802.1p优先级 · dscp:DSCP优先级 |
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { dot1p | dscp }
undo qos trust
设备信任报文的802.1p优先级。
二层以太网接口视图
三层以太网接口视图
三层聚合接口视图
# 在接口Ten-GigabitEthernet3/0/1上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname-Ten-GigabitEthernet3/0/1] qos trust dot1p
qos trust tunnel-dscp命令用来配置信任VXLAN报文外层IP头的DSCP优先级。
undo qos trust tunnel-dscp命令用来恢复缺省情况。
未配置信任VXLAN报文外层IP头的DSCP优先级。
如果希望VXLAN隧道接口信任VXLAN报文外层IP头的DSCP优先级,除了VXLAN隧道所在的以太网接口下配置qos trust dscp,系统视图下还需要配置qos trust tunnel-dscp。
当系统工作模式为standard模式时,不支持配置qos trust tunnel-dscp。关于系统工作模式的详细介绍,请参见“基础配置指导”中的“设备管理”。
# 配置设备信任VXLAN报文外层IP头的DSCP优先级。
[Sysname] qos trust tunnel-dscp
qos priority命令用来配置端口的端口优先级。
undo qos priority命令用来恢复端口优先级为缺省值。
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
端口优先级的缺省值为0。
priority-value:端口优先级值,取值范围为0~7。当设备支持dscp类型的端口优先级时,优先级的取值范围0~63。
# 配置接口Ten-GigabitEthernet3/0/1的端口优先级为2。
[Sysname-Ten-GigabitEthernet3/0/1] qos priority 2
· display qos trust interface
display qos gts interface命令用来显示接口的流量整形配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量整形配置情况。
# 显示所有接口的流量整形配置情况。
Rule: If-match queue 1
CIR 160 (kbps), CBS 51200 (Bytes)
表3-1 display qos gts命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成 |
Rule |
匹配规则 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,单位为byte |
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
undo qos gts queue queue-id
未配置流量整形。
queue queue-id:对队列上的数据包进行流量整形。queue-id为匹配的队列号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。千兆端口的取值范围为10~1000000,万兆端口的取值范围为10~10000000,40GE端口的取值范围为10~40000000,100GE端口的取值范围为10~100000000。用户配置的数值必须是10的倍数。
cbs committed-burst-size:承诺突发尺寸,单位为byte。
· 如果不指定cbs参数,committed-burst-size缺省取值为62.5 × committed-information-rate,且必须为512的整数倍,如果乘积不是512的整数倍,就取比乘积大的最近的512的整数倍,最大不能超过160000000。
· 如果指定cbs参数,取值范围为512~160000000,committed-burst-size必须为512的整数倍。
仅支持对接口上出方向的报文进行流量整形。
# 在接口Ten-GigabitEthernet3/0/1上对队列1的报文进行流量整形。正常流速为160kbps,突发流量为51200bytes。
[Sysname-Ten-GigabitEthernet3/0/1] qos gts queue 1 cir 160 cbs 51200
display qos lr interface命令用来显示接口上的限速配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的限速配置情况。
# 显示所有接口的接口限速配置情况。
Direction: outbound
CIR 2000 (kbps), CBS 20480 (Bytes)
表3-2 display qos lr命令显示信息描述表
Direction |
接口限速应用的方向 |
CIR |
承诺信息速率,单位为kbps |
CBS |
承诺突发尺寸,单位为byte |
qos lr命令用来配置接口限速。
undo qos lr命令用来取消接口配置的限速。
undo qos lr { inbound | outbound }
未配置限速。
inbound:入方向限速。
outbound:出方向限速。
cbs committed-burst-size:承诺突发尺寸,单位为bytes。
# 对接口Ten-GigabitEthernet3/0/1上出方向的报文进行限速。正常流速为160kbps,突发流量为51200bytes,以后速率小于等于160kbps时正常发送,速率大于160kbps时,将进行限速。
[Sysname-Ten-GigabitEthernet3/0/1] qos lr outbound cir 160 cbs 51200
qos overhead layer命令用来配置统计报文长度方式。
undo qos overhead layer命令用来恢复缺省情况。
qos overhead layer { link | physical }
在统计报文长度和QoS限速时,报文总长度包含物理层头部信息。
physical:在统计报文长度和QoS限速时,报文总长度包含物理层头部信息。
link:在统计报文长度和QoS限速时,报文总长度仅包含数据链路层头部信息,不包含物理层头部信息。
物理层的信息包含帧间隙(Interframe Gap)、前导码(Preamble)和帧开始界定符(Start Frame Delimiter)信息,这三部分总长度为20字节。在设备对流量进行统计和QoS监管和限速时存在两种情况:
· 计算报文总长度时包含物理层头部信息。当设备处理的报文平均长度较小,对限速精度要求较高时,应该采用这种方式来保证统计和计算的精度。例如,报文平均长度上百字节,20字节的物理层的信息将大大影响统计准确性。
· 计算报文总长度时不包含物理层头部信息,仅从数据链路层开始计算。当设备处理的报文平均长度较长,或者对限速精度要求不高时,可以采用这种方式来降低计算复杂度。例如,报文平均长度超过上千字节,20字节的物理层的信息几乎不影响统计准确性。
本功能中的QoS限速包括基于MQC的流量监管、接口限速、全局CAR、报文上送CPU限速以及OpenFlow Meter。
对于报文长度的统计方式:在本功能支持之前的版本中,缺省情况下,仅在进行QoS限速时,报文总长度才包含物理层头部信息,而统计报文长度时则不包含。本功能支持之后,缺省情况下在统计报文长度和进行QoS限速时,报文总长度均包含物理层头部信息。
# 配置统计报文长度方式为报文总长度仅包含数据链路层头部信息,不包含物理层头部信息。
[Sysname] qos overhead layer link
· car
· display qos lr
· qos lr
display qos queue interface命令用来显示接口上队列配置情况和统计信息。
display qos queue interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的接口队列配置情况和运行统计信息。
# 显示所有接口下的队列信息。
<Sysname> display qos queue interface
Output queue: Strict Priority queuing
Interface: Ten-GigabitEthernet3/0/2
.....(省略部分显示信息)
表4-1 display qos queue interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列的相关信息 |
Queue ID |
队列号 |
Queue name |
队列名称 |
Group |
分组号,说明队列属于哪一个分组 |
Byte count |
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算 |
queue af命令用来配置类采用AF队列,并配置类可确保的最小带宽。
undo queue af命令用来恢复缺省情况。
queue af bandwidth { bandwidth | pct percentage }
undo queue af
未配置类采用AF队列。
流行为视图
bandwidth:带宽,单位kbps。取值范围为10~100000000。
pct percentage:可用带宽的百分比,取值范围为1~100。
在将类与queue af所属行为关联时,必须满足以下条件:
· 同一个策略下为AF队列和EF队列指定的带宽之和必须不大于该策略所应用接口的可用带宽;
· 同一个策略下为AF队列和EF队列指定的带宽百分比之和必须不大于100;
· 同一个策略下AF队列和EF队列的带宽的配置必须都采用相同的值的类型,比如都采用绝对值形式,或者都采用百分比形式。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
# 为行为database配置采用AF队列,并且确保最小带宽为200kbps。
[Sysname-behavior-database] queue af bandwidth 200
· traffic behavior
queue ef命令用来配置类采用EF队列,并配置最大带宽。
undo queue ef命令用来恢复缺省情况。
queue ef bandwidth { bandwidth [ cbs burst ] | pct percentage [ cbs-ratio ratio ] }
undo queue ef
未配置类采用EF队列。
流行为视图
cbs burst:指定承诺突发尺寸,单位为字节,取值范围为512~1000000000,缺省值为bandwidth×25。
cbs-ratio ratio:允许的突发因子,取值范围为25~500,缺省值是25。
该命令在同一个流行为视图下不能与queue af同时使用。
在策略下,缺省类default-class不能与queue ef所属behavior关联。
当将类与queue ef所属行为关联时,必须满足以下条件:
· 同一个策略下为AF队列和EF队列指定的带宽之和必须不大于该策略所应用接口的可用带宽。
· 同一个策略下为AF队列和EF队列指定的带宽百分比之和必须不大于100。
· 对于设置百分比形式queue ef bandwidth pct percentage [ cbs-ratio ratio ],CBS = 接口可用带宽×percentage×ratio÷100。
· 对于设置绝对值形式queue ef bandwidth bandwidth [ cbs burst ],CBS = burst,若不指定burst,则CBS = bandwidth×25。
# 配置报文进入EF队列,最大带宽为200kbps,承诺突发尺寸为5000bytes。
[Sysname-behavior-database] queue ef bandwidth 200 cbs 5000
· traffic behavior
queue sp命令用来配置类采用SP队列。
undo queue sp用来恢复缺省情况。
queue sp
undo queue sp
未配置类采用SP队列。
流行为视图
配置了该命令的行为不能与缺省类关联使用。
在同一流行为视图下queue sp不能与queue ef命令同时使用。
在同一流行为视图下queue sp不能与queue af命令同时使用。
# 配置报文进入SP队列。
[Sysname-behavior-database] queue sp
· traffic behavior
queue wfq命令用来为缺省类配置采用公平队列。
undo queue wfq命令用来恢复缺省情况。
queue wfq
undo queue wfq
没有为缺省类配置采用公平队列。
流行为视图
配置了该命令的行为仅可以与缺省类关联使用。
# 为缺省类配置使用WFQ。
[Sysname] traffic behavior test
[Sysname-behavior-test] queue wfq
[Sysname-qospolicy-user1] classifier default-class behavior test
· traffic behavior
display qos queue sp interface命令用来显示接口的SP(Strict Priority,严格优先级)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的SP队列配置情况。
# 显示Ten-GigabitEthernet3/0/1的严格优先级队列配置情况。
<Sysname> display qos queue sp interface ten-gigabitethernet 3/0/1
表4-2 display qos queue sp interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列类型 |
qos sp命令用来在接口上配置严格优先队列。
undo qos sp命令用来恢复缺省情况。
qos sp
undo qos sp
接口使用SP队列调度算法。
# 在接口Ten-GigabitEthernet3/0/1上应用SP模式的队列调度。
[Sysname-Ten-GigabitEthernet3/0/1] qos sp
· display qos queue sp interface
display qos queue wrr interface命令用来显示接口的WRR(Weighted Round Robin,加权轮询)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WRR队列配置情况。
# 显示接口Ten-GigabitEthernet3/0/1的WRR队列配置情况。
<Sysname> display qos queue wrr interface ten-gigabitethernet 3/0/1
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Byte count
0 be 1 1
1 af1 1 1
2 af2 1 1
3 af3 1 1
4 af4 1 1
5 ef 1 1
6 cs6 1 1
7 cs7 sp N/A
表4-3 display qos queue wrr interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列类型 |
Queue ID |
队列号 |
Queue name |
队列名称 |
Group |
分组号,说明队列属于哪一个分组 |
Weight |
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算,N/A表示该队列采用SP调度算法 |
Byte count |
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算,N/A表示该队列采用SP调度算法 |
qos wrr命令用来在接口上开启WRR队列。
undo qos wrr命令用来恢复缺省情况。
qos wrr { byte-count | weight }
undo qos wrr { byte-count | weight }
接口使用SP队列调度算法。
byte-count:表示按照每次轮询可发送的字节数进行计算。
weight:表示按照每次轮询可发送的报文个数进行计算。SE系列接口板和LSCM1GT48SC0单板不支持本参数。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行WRR配置。
# 在接口Ten-GigabitEthernet3/0/1上开启WRR队列,并按照每次轮询可发送的报文个数进行计算。
[Sysname-Ten-GigabitEthernet3/0/1] qos wrr weight
# 在接口Ten-GigabitEthernet3/0/1上开启WRR队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-Ten-GigabitEthernet3/0/1] qos wrr byte-count
· display qos queue wrr interface
qos wrr { byte-count | weight }命令用来配置WRR队列或修改WRR队列的参数。
undo qos wrr命令用来恢复指定队列的缺省情况。
qos wrr queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wrr queue-id
在使用WRR队列时,所有队列都处于WRR调度组1中,调度权重从队列0到7分别为1、2、3、4、5、9、13、15。
queue-id:队列序号。取值范围为0~7或表4-4中的关键字。
表4-4 queue-id数字和关键字对应表
queue-id数字 |
queue-id关键字 |
0 |
be |
1 |
af1 |
2 |
af2 |
3 |
af3 |
4 |
af4 |
5 |
ef |
6 |
cs6 |
7 |
cs7 |
group { 1 | 2 }:表示该队列属于哪个WRR优先组,缺省为group 1。其中group 1表示该队列属于WRR优先组1,group 2表示该队列属于WRR优先组2。各组之间执行优先级调度,由组1至组2优先级依次降低。
schedule-value:配置队列的调度权重,取值范围为1~127。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行本配置。
# 在接口Ten-GigabitEthernet3/0/1上应用WRR队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-Ten-GigabitEthernet3/0/1] qos wrr 0 group 1 byte-count 10
· qos wrr
qos wrr group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wrr group sp命令用来取消将队列加入SP组。
qos wrr queue-id group sp
当使用WRR队列时,所有队列都处于WRR调度组1中。
queue-id:队列序号。取值范围为0~7或对应队列的关键字be、af1、af2、af3、af4、ef、cs6、cs7。
本命令需要在端口队列为WRR调度模式下使用。
SP组与普通WRR优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WRR优先组。
# 在接口Ten-GigabitEthernet3/0/1上应用WRR队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-Ten-GigabitEthernet3/0/1] qos wrr 0 group sp
· qos wrr
display qos queue wfq interface命令用来显示接口的WFQ配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WFQ配置情况。
# 显示接口Ten-GigabitEthernet3/0/1的加权公平队列配置情况。
<Sysname> display qos queue wfq interface ten-gigabitethernet 3/0/1
Output queue: Hardware Weighted Fair Queuing
Queue ID Queue name Group Byte count Min Bandwidth
0 be 1 1 0
1 af1 1 1 0
2 af2 1 1 0
3 af3 1 1 0
4 af4 1 1 0
5 ef 1 1 0
6 cs6 1 1 0
7 cs7 1 1 0
表4-5 display qos queue wfq interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
Output queue |
当前出队列类型 |
Queue ID |
队列号 |
Queue name |
队列名称 |
Group |
分组号,说明队列属于哪一个分组 |
Byte-count |
Weight |
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算, N/A表示该队列采用SP调度算法 |
Min-Bandwidth |
队列的最小保证带宽值 |
qos bandwidth queue命令用来配置端口队列的最小带宽保证。
undo qos bandwidth queue命令用来恢复缺省情况。
undo qos bandwidth queue queue-id
在使用WFQ队列时,未配置最小带宽保证。
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。千兆端口的取值范围为8~1000000,万兆端口的取值范围为8~10000000,40GE端口的取值范围为8~40000000,100GE端口的取值范围为8~100000000。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行本配置。
对于SE系列接口板,仅队列5、6、7支持配置最小带宽保证。
# 在接口Ten-GigabitEthernet3/0/1上配置队列7的最小保证带宽值为100kbps。
[Sysname-Ten-GigabitEthernet3/0/1] qos wfq byte-count
[Sysname-Ten-GigabitEthernet3/0/1] qos bandwidth queue 7 min 100
· qos wfq
qos wfq命令用来在接口上开启WFQ队列。
undo qos wfq命令用来恢复缺省情况。
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
接口使用SP队列调度算法。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行WFQ配置。
# 在接口Ten-GigabitEthernet3/0/1上开启WFQ队列,并按照每次轮询可发送的报文个数进行计算。
[Sysname-Ten-GigabitEthernet3/0/1] qos wfq weight
# 在接口Ten-GigabitEthernet3/0/1上开启WFQ队列,并按照每次轮询可发送的字节数进行计算。
· display qos queue wfq interface
qos wfq { byte-count | weight }命令用来配置WFQ队列或修改WFQ队列的参数。
undo qos wfq命令用来恢复指定队列的缺省情况。
qos wfq queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wfq queue-id
在使用WFQ队列时,所有队列都处于WFQ调度组1中,各队列的调度权重均为1。
group { 1 | 2 }:表示该队列属于哪个WFQ优先组,缺省为group 1。其中group 1表示该队列属于WFQ优先组1,group 2表示该队列属于WFQ优先组2。各组之间执行优先级调度,由组1至组2优先级依次降低。
# 在接口Ten-GigabitEthernet3/0/1上应用WFQ队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-Ten-GigabitEthernet3/0/1] qos wfq 0 group 1 byte-count 10
· qos bandwidth queue
· qos wfq
qos wfq group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wfq group sp命令用来取消将队列加入SP组。
qos wfq queue-id group sp
当使用WFQ队列时,所有队列都处于WFQ调度组1中。
本命令需要在端口队列为WFQ调度模式下使用。
SP组与普通WFQ优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WFQ优先组。
# 在接口Ten-GigabitEthernet3/0/1上应用WFQ队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-Ten-GigabitEthernet3/0/1] qos wfq 0 group sp
· qos wfq
bandwidth queue命令用来配置队列调度策略下队列的最小带宽保证。
undo bandwidth queue命令用来恢复缺省情况。
undo bandwidth queue queue-id
在队列调度策略中配置某个队列为WFQ队列后,该队列未配置最小带宽保证。
队列调度策略视图
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。取值范围为8~100000000。
必须先在队列调度策略中将某个队列配置为WFQ队列,才能为该队列配置最小带宽保证。
# 在队列调度策略myprofile中,配置队列7使用WFQ队列算法,使用字节数作为调度权重,权重值为1,分组为1,并为该队列配置最小保证带宽值为100kbps。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 7 wfq group 1 byte-count 1
[Sysname-qmprofile-myprofile] bandwidth queue 7 min 100
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
(独立运行模式)
display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number ]
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有队列调度策略的配置情况。
slot slot-number:显示指定单板的队列调度策略的配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的队列调度策略的配置情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的队列调度策略的配置情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的队列调度策略的配置情况。(IRF模式)
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID Type Group Schedule Schedule Min
unit value bandwidth
be WFQ 1 byte-count 1 0
af1 SP N/A N/A N/A 0
af2 SP N/A N/A N/A 0
af3 SP N/A N/A N/A 0
af4 SP N/A N/A N/A 0
ef SP N/A N/A N/A 0
cs6 SP N/A N/A N/A 0
cs7 SP N/A N/A N/A 0
表4-6 display qos qmprofile configuration命令显示信息描述表
Queue management profile |
队列调度策略名称 |
Queue ID |
队列号 |
Type |
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)、WFQ(加权公平队列) |
Group |
优先组,N/A表示无效 |
Schedule unit |
队列调度单位,包括weight和byte-count,N/A表示无效 |
Schedule vlaue |
· 队列调度单位为weight时,表示报文个数 · 队列调度单位为byte-count时,表示字节个数 · N/A表示无效 |
Min Bandwidth |
最小保证带宽,N/A表示无效 |
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface ten-gigabitethernet 3/0/1
Direction: Outbound
表4-7 display qos qmprofile interface命令显示信息描述表
接口名称 |
Direction |
队列调度策略应用的方向 |
队列调度策略名称 |
qos apply qmprofile命令用来在接口出方向上应用队列调度策略。
undo qos apply qmprofile命令用来恢复缺省情况。
接口上未应用队列调度策略。
每个接口在同一方向上只能应用一个队列调度策略。
# 在接口Ten-GigabitEthernet3/0/1出方向上应用队列调度策略myprofile。
[Sysname-Ten-GigabitEthernet3/0/1] qos apply qmprofile myprofile
· display qos qmprofile interface
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入相应的队列调度策略视图。如果指定的队列调度策略已经存在,则直接进入该队列调度策略视图。
undo qos qmprofile命令用来删除用户自定义的队列调度策略。
qos qmprofile profile-name
undo qos qmprofile profile-name
不存在用户自定义的队列调度策略。
如果需要删除已经应用到接口的队列调度策略,必须先在应用的位置上取消对该队列调度策略的应用,然后再删除该队列调度策略。
# 创建队列调度策略myprofile,并进入队列调度策略视图。
· queue
queue命令用来配置队列调度参数。
undo queue命令用来取消队列调度参数的配置。
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
缺省情况下,队列调度策略的内容是所有队列均采用SP方式调度。
队列调度策略视图
queue-id:队列序号。取值范围为0~7或0~7对应队列的关键字be、af1、af2、af3、af4、ef、cs6、cs7。
sp:配置队列为严格优先级调度。
wfq:配置队列为加权公平调度。
wrr:配置队列为加权轮询调度。
group group-id:优先组号。group-id取值范围为1~2。
schedule-value:配置队列的调度权重。取值范围为1~127。
# 创建自定义的队列调度策略myprofile,并配置队列0为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 0 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,权重为10,分组为1。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 byte-count 10
· qos qmprofile
display qos wred fabric命令用来显示内联口WRED表配置情况。
(独立运行模式)
display qos wred fabric [ slot slot-number ] [ inbound | outbound ]
display qos wred fabric [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
slot slot-number:显示指定单板内联口的WRED表配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板内联口的WRED表配置情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板内联口的WRED表配置情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板内联口的WRED表配置情况。(IRF模式)
[ inbound | outbound ]:显示入或出方向的WRED表,其中inbound表示从网板到接口单板方向的WRED表。outbound表示从接口单板到网板方向的WRED表。如果未指定本参数,则显示双向的WRED表。
# 显示单板1的内联口WRED表的配置情况。
<Sysname> display qos wred fabric slot 1
Slot 1:
Inbound:
Current WRED configuration:
Applied WRED table name: q1 Application status: Successful
Outbound:
表5-1 display qos wred fabric命令显示信息描述表
Slot |
指定单板 |
Inbound |
入方向,即从接口板到网板方向 |
Outbound |
出方向,即从网板到接口板方向 |
Current WRED configuration |
当前WRED的配置情况 |
Applied WRED table name |
当前应用的WRED表的名称 |
Application status |
WRED表配置状态: · Successful:配置WRED表下发成功 · Failed:配置WRED表下发失败 |
Table type |
WRED表类型 |
QID |
队列ID |
gmin |
绿色报文的队列下限 |
gmax |
绿色报文的队列上限 |
gpro |
绿色报文的丢弃概率 |
ymin |
黄色报文的队列下限 |
ymax |
黄色报文的队列上限 |
ypro |
黄色报文的丢弃概率 |
rmin |
红色报文的队列下限 |
rmax |
红色报文的队列上限 |
rpro |
红色报文的丢弃概率 |
exp |
计算平均队列长度指数 |
ECN |
是否对该队列开启了拥塞通知功能,Y表示开启,N表示未开启 |
· qos wred apply fabric
display qos wred interface命令用来显示接口上WRED配置情况和统计信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的WRED配置情况和统计信息。
# 显示所有接口下应用的WRED表配置情况和统计信息。
<Sysname> display qos wred interface
Table type: Queue based WRED
QID gmin gmax gpro ymin ymax ypro rmin rmax rpro exp
0 100 1000 10 100 1000 10 100 1000 10 9
1 100 1000 10 100 1000 10 100 1000 10 9
2 100 1000 10 100 1000 10 100 1000 10 9
3 100 1000 10 100 1000 10 100 1000 10 9
4 100 1000 10 100 1000 10 100 1000 10 9
5 100 1000 10 100 1000 10 100 1000 10 9
6 100 1000 10 100 1000 10 100 1000 10 9
7 100 1000 10 100 1000 10 100 1000 10 9
表5-2 display qos wred interface命令显示信息描述表
接口名,由接口类型和接口编号组成 |
当前WRED的配置情况 |
当前应用的WRED表的名称 |
Table type |
WRED表类型,当前仅支持Queue based WRED |
QID |
队列ID |
gmin |
绿色报文的队列下限 |
gmax |
绿色报文的队列上限 |
gpro |
绿色报文的丢弃概率 |
ymin |
黄色报文的队列下限 |
ymax |
黄色报文的队列上限 |
ypro |
黄色报文的丢弃概率 |
rmin |
红色报文的队列下限 |
rmax |
红色报文的队列上限 |
rpro |
红色报文的丢弃概率 |
exp |
计算平均队列长度指数 |
display qos wred table命令用来显示WRED表的配置情况。
(独立运行模式)
display qos wred table [ name table-name ] [ chassis chassis-number slot slot-number ]
name table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则显示所有WRED表配置情况。
slot slot-number:显示指定单板的WRED表配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的WRED表配置情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的WRED表配置情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的WRED表配置情况。(IRF模式)
# 显示WRED表1的配置情况,表1是一个已经配置好的WRED参数表。
<Sysname> display qos wred table name 1
Table name: 1
QID gmin gmax gprob ymin ymax yprob rmin rmax rprob exp
3 - - - 1000 2000 30 - - - 9
4 - - - 1000 2000 30 - - - 9
5 - - - 1000 2000 40 - - - 9
6 - - - - - - 1000 2000 30 9
表5-3 display qos wred table命令显示信息描述表
Table name |
WRED表名 |
Table type |
WRED表类型 |
QID |
队列ID |
gmin |
绿色报文的队列下限 未配置WRED表参数时,显示为“-”。此时接口上应用时请参见“WRED表参数缺省值” |
gmax |
绿色报文的队列上限 未配置WRED表参数时,显示为“-”。此时接口上应用时请参见“WRED表参数缺省值” |
gpro |
绿色报文的丢弃概率 未配置WRED表参数时,显示为“-”。此时接口上应用时请参见“WRED表参数缺省值” |
ymin |
黄色报文的队列下限 未配置WRED表参数时,显示为“-”。此时接口上应用时请参见“WRED表参数缺省值” |
ymax |
黄色报文的队列上限 未配置WRED表参数时,显示为“-”。此时接口上应用时请参见“WRED表参数缺省值” |
ypro |
黄色报文的丢弃概率 未配置WRED表参数时,显示为“-”。此时接口上应用时请参见“WRED表参数缺省值” |
rmin |
红色报文的队列下限 未配置WRED表参数时,显示为“-”。此时接口上应用时请参见“WRED表参数缺省值” |
rmax |
红色报文的队列上限 未配置WRED表参数时,显示为“-”。此时接口上应用时请参见“WRED表参数缺省值” |
rpro |
红色报文的丢弃概率 未配置WRED表参数时,显示为“-”。此时接口上应用时请参见“WRED表参数缺省值” |
exp |
计算平均队列长度指数 |
表5-4 WRED表参数缺省值
单板型号 |
接口速率 |
low-limit |
high-limit |
discard-pro |
SF系列接口板 LSCM2SRP6C4Y06A0主控板 LSCM3SRP6C4Y06A0主控板 |
1GE |
350 |
700 |
20 |
10GE |
350 |
700 |
20 |
25GE |
350 |
700 |
20 |
40GE |
2000 |
4000 |
20 |
50GE |
2000 |
4000 |
20 |
100GE |
2000 |
4000 |
20 |
200GE |
3000 |
6000 |
20 |
400GE |
3000 |
6000 |
20 |
内联口 |
2000 |
4000 |
20 |
其他单板 |
100 |
1000 |
10 |
qos wred apply命令用来在接口上应用WRED表。
undo qos wred apply命令用来恢复缺省情况。
qos wred apply [ table-name ]
undo qos wred apply
接口没有应用WRED表,即接口采用尾丢弃。
table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则在接口上应用缺省WRED表。
# 在接口Ten-GigabitEthernet3/0/1上应用WRED表。
[Sysname-Ten-GigabitEthernet3/0/1] qos wred apply table1
· display qos wred interface
· display qos wred table
· qos wred queue table
qos wred apply fabric命令用来在板卡的所有内联口上应用WRED表。
undo qos wred apply fabric命令用来恢复缺省情况。
qos wred apply table-name fabric
未应用WRED表,采用尾丢弃。
设备内部的接口板与网板之间交互数据报文时需要用到内联口,内联口也会产生拥塞的情况。可以通过配置本命令实现内联口上的拥塞管理。
本命令仅对SF系列接口板生效,且对IRF端口不生效。有关IRF的详细介绍,请参见“虚拟化技术”中的“IRF”。
# 在所有内联口上应用WRED表。
[Sysname] qos wred apply table1 fabric
· display qos wred fabric
qos wred ecn enable命令用来开启全局拥塞通知功能。
undo qos wred ecn enable命令用来关闭全局拥塞通知功能。
qos wred ecn enable
未开启全局拥塞通知功能。
开启全局拥塞通知功能后,所有配置了WRED参数的队列的拥塞通知功能将自动生效,这些队列包括通过qos wred queue命令在接口下配置了WRED参数的队列和通过在接口下应用WRED表并配置了queue命令的队列。
仅SF系列接口板、LSCM2系列SC单板和SD系列接口板支持开启全局拥塞通知功能。
本功能仅对以下单板带TCP或UDP报文头的报文生效:
· LSCM2系列SC单板
· SD系列接口板。
# 开启全局拥塞通知功能。
[Sysname] qos wred ecn enable
· queue
· queue ecn
· qos wred queue
· qos wred queue ecn
· qos wred smart-ecn enable
qos wred queue命令用来配置队列的WRED参数。
undo qos wred queue命令用来恢复缺省情况。
qos wred queue queue-id low-limit low-limit high-limit high-limit [ discard-probability discard-prob ] [ weighting-constant exponent ]
qos wred queue queue-id [ drop-level drop-level ] { default | low-limit low-limit high-limit high-limit [ discard-probability discard-prob ] }
undo qos wred queue { queue-id [ drop-level drop-level ] | all }
未配置队列的WRED参数。
queue-id:队列编号。取值范围为0~7。
default:表示指定队列使用WRED方式丢弃报文,并采用设备缺省的队列平均长度上下限和丢弃概率作为WRED参数。指定本参数后,可以无需手工配置WRED相关参数,直接使用设备推荐值。未指定本参数或WRED相关参数时,则使用尾丢弃方式丢弃报文。仅SF系列接口板支持本参数。
low-limit low-limit:队列平均长度的下限。取值范围为0~69632。
high-limit high-limit:队列平均长度的上限。取值范围为0~69632且必须大于丢弃下限。
discard-probability discard-prob:丢弃概率,取值越大,计算出的丢弃概率越大。取值范围为0~100。
weighting-constant exponent:计算平均队列长度的指数。缺省情况下未配置计算平均队列长度的指数,取值范围为0~15。仅SF系列接口板支持配置本参数。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,表示后续配置的参数对该队列所有丢弃级别的报文都生效。
all:表示所有队列。
WRED丢弃报文的机制为:
· 当队列平均长度小于下限时,不丢弃报文。
· 当队列平均长度在上限和下限之间时,设备随机丢弃报文,队列越长,丢弃概率越高。队列丢弃概率随队列长度线性增长,最大不超过丢弃概率。
· 当队列平均长度超过上限时,丢弃所有到来的报文。
配置队列平均长度的上下限时,对于LSCM2系列SC单板和SD系列接口板,仅支持配置为0~10496。对于SE系列接口板,仅支持配置为0~22016。对于LSCM1GT48SC0单板,仅支持配置为0~10496。
配置本命令时指定weighting-constant exponent参数,与配置qos wred queue weighting-constant命令等效。
通过本命令直接在接口下配置队列的WRED参数,与使用qos wred apply命令在接口下应用WRED表等效,且两种配置方式互斥。
# 配置接口Ten-GigabitEthernet3/0/1下队列1中的WRED参数:丢弃级别为1,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30%。
[Sysname-Ten-GigabitEthernet3/0/1] qos wred queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。如果指定的WRED表已经存在,则直接进入WRED表视图。
undo qos wred queue table命令用来删除WRED表。
undo qos wred queue table table-name
设备上不存在WRED表。
table table-name:指定WRED表的名称,为1~32个字符的字符串,区分大小写。
设备不允许删除正在使用的WRED表。如果需要删除正在使用的表,请先在接口上取消应用的WRED表。
缺省WRED表可以通过display qos wred table命令显示,不允许修改和删除。
# 创建基于queue的WRED表queue-table1。
[Sysname-wred-table-queue-table1]
qos wred queue weighting-constant命令用来配置计算平均队列长度的指数。
undo qos wred queue weighting-constant命令用来恢复缺省情况。
qos wred queue queue-id weighting-constant exponent
undo qos wred queue queue-id weighting-constant
未配置计算平均队列长度的指数。
weighting-constant exponent:计算平均队列长度的指数。取值范围为0~15。
平均队列长度的指数越大,计算平均队列长度时对队列的实时变化越不敏感。计算队列平均长度的公式为:平均队列长度=(以前的平均队列长度×(1-1/2n))+(当前队列长度×(1/2n))。其中n表示指数。
配置本命令与配置qos wred queue命令时指定weighting-constant exponent参数等效。
仅SF系列接口板支持配置本命令。
# 配置接口Ten-GigabitEthernet3/0/1下队列1计算平均队列长度的指数为12。
[Sysname-Ten-GigabitEthernet3/0/1] qos wred queue 1 weighting-constant 12
· qos wred queue
queue命令用来配置基于队列的WRED表的内容。
undo queue命令用来恢复缺省情况。
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id [ drop-level drop-level ] | all }
WRED表视图
all:表示所有队列。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:队列平均长度的下限。取值范围为0~69632,对于SE系列接口板和LSCM2系列SC单板单位为288byte,对于LSCM1GT48SC0接口板单位为256byte。
high-limit high-limit:队列平均长度的上限。取值范围为0~69632且必须大于丢弃下限,对于SE系列接口板和LSCM2系列SC单板单位为288byte,对于LSCM1GT48SC0接口板单位为256byte。
当队列平均长度小于下限时,不丢弃报文。当队列平均长度在上限和下限之间时,设备随机丢弃报文,队列越长,丢弃概率越高。当队列平均长度超过上限时,丢弃所有到来的报文。
当配置的队列平均长度的下限与上限相等,且丢弃概率为100%时,表示本队列的报文丢弃策略为尾丢弃。
# 配置基于队列的WRED表queue-table1中队列1的丢弃参数:丢弃级别为1,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30%。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
undo queue weighting-constant命令用来恢复缺省情况。
undo queue queue-id weighting-constant
未配置计算平均队列长度的指数。
WRED表视图
仅SF系列接口板支持配置本命令。
# 在WRED表queue-table1中,配置计算平均队列长度的指数为12。
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
car name命令用来配置全局CAR动作。
undo car用来恢复缺省情况。
car name car-name
undo car
未配置全局CAR动作。
流行为视图
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
# 配置流行为be1的聚合CAR动作为aggcar-1。
· display qos car name
· display traffic behavior user-defined
display qos car name命令用来显示全局CAR的配置和统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。显示指定全局CAR的配置和统计信息。如果未指定本参数,将显示所有全局CAR的配置和统计信息。
# 显示全局CAR的配置和统计信息。(独立运行模式)
<Sysname> display qos car name
Mode: aggregative
CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Slot 1:
Green packets : 0 (Packets), 0 (Bytes)
Yellow packets: 0 (Packets), 0 (Bytes)
Red packets : 0 (Packets), 0 (Bytes)
表6-1 display qos car name命令显示信息描述表
Name |
全局CAR的名称 |
Mode |
聚合CAR的类型,取值为aggregative(聚合CAR) |
CIR CBS PIR EBS |
流量监管流量的参数配置 |
Green action |
对绿色报文的动作 |
Yellow action |
对黄色报文的动作 |
Red action |
对红色报文的动作 |
Green packets |
绿色报文的流量统计 |
Yellow packets |
黄色报文的流量统计 |
Red packets |
红色报文的流量统计 |
qos car命令用来配置聚合CAR。
undo qos car命令用来取消聚合CAR的配置。
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
未配置聚合CAR。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为16~100000000且必须为8的整数倍。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
· 如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过67092480。
· 如果指定cbs参数,取值范围512~67092480且必须为512的整数倍。
ebs excess-burst-size:过度突发尺寸,单位为byte。本参数仅全局CAR为聚合模式时支持。
配置pir参数后:
· 如果不指定ebs,则ebs缺省取值为与62.5 × peak-information-rate的乘积最接近且不小于512的整数倍,但是最大值不能超过67092480。
· 如果指定ebs,取值范围0~67092480且必须为512的整数倍。
未配置pir参数时,ebs的取值范围为0~67092480且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为16~100000000且必须为8的整数倍。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass。
action:对数据包采取的动作,有以下几种:
· discard:丢弃数据包。
· pass:允许数据包通过。
· remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。仅LSCM2系列SC单板的入方向支持。
聚合CAR配置需要在策略中引用后才能生效,且该策略在同一视图下不能同时应用到出入两个方向上。
当黄色报文配置为discard动作时,红色报文只支持配置为discard动作。
不配置峰值速率表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 配置聚合CAR采取的CAR参数取值,cir取值为25600,cbs取值为512000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name命令用来清除全局CAR的统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。清除指定全局CAR的统计信息。如果未指定本参数,将清除所有全局CAR的统计信息。
# 清除全局CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
elephant-flow action命令用来配置大流的处理动作。
undo elephant-flow action命令用来恢复缺省情况。
elephant-flow action { drop-precedence drop-precedence-value | dot1p dot1p-value | local-precedence local-precedence-value | none }
未配置大流的处理动作。
大小流视图
drop-precedence drop-precedence-value:指定丢弃优先级,其中drop-precedence-value的取值范围为0~2。
dot1p dot1p-value:指定802.1p优先级,dot1p-value的取值范围为0~7。
local-precedence local-precedence-value:指定本地优先级,local-precedence-value的取值范围为0~7。
none:无后续处理动作,此时大小流功能仅将大流识别出来,不做处理。
# 配置大流的丢弃优先级为2。
<Sysname> system-View
[Sysname] qos mice-elephant-flow
[Sysname-mice-elephant-flow] elephant-flow action drop-precedence 2
· elephant-flow rate
elephant-flow rate命令用来配置大流识别参数。
undo elephant-flow rate命令用来取消已配置的大流识别参数。
elephant-flow rate rate [ gbps | kbps | mbps ] [ size size [ bytes | kbytes | mbytes ] ]
未配置大流识别参数。
大小流视图
rate:大流速率,缺省单位为kbps,取值范围为1~1000。
· gbps:指定大流速率的单位为gbps。
· kbps:指定大流速率的单位为kbps。
· mbps:指定大流速率的单位为mbps。
size size:大流尺寸,缺省单位为bytes,取值范围为1~1000。
· bytes:指定大流尺寸的单位为bytes。
· kbytes:指定大流尺寸的单位为kbytes。
· mbytes:指定大流尺寸的单位为mbytes。
配置本命令后,设备将依据本命令中指定的流量识别参数区分大流和小流:
· 不对小流进行额外处理。
· 将大流的丢弃优先级修改为elephant-flow rate命令中指定的优先级。
一旦发生拥塞,设备优先保证无丢弃优先级或丢弃优先级小的流量的转发。
# 配置大流识别参数,速率为20kbps,尺寸为100kbytes。
[Sysname-mice-elephant-flow] elephant-flow rate 20 kbps size 100 kbytes
· elephant-flow action
agile-buffer enable命令用来开启大小流自适应缓存功能。
undo agile-buffer enable命令用来关闭大小流自适应缓存功能。
agile-buffer enable
大小流自适应缓存功能处于关闭状态。
大小流视图
为了保证大小流自适应缓存功能生效,需要配置如下功能和命令:
· 开启大小流区分调度功能,即执行elephant-flow rate命令配置大小流区分调度的识别参数和elephant-flow action命令并指定local-precedence参数配置大流的本地优先级。
· 创建一个大小流模式的Flow Group或应用一个系统预定义的大小流模式的Flow Group。关于大小流模式的Flow Group的介绍,请参见“Telemetry命令参考”中的“Flow Group”。
大小流区分调度功能是通过静态手工配置大流识别参数(即流速和尺寸),识别出网络流量中的大流,并且为大流指定较低的丢弃优先级、本地优先级或dot1p优先级,一旦发生拥塞,设备根据指定的优先级优先丢弃大流,保证小流的快速转发。大小流区分调度可以在一定程度上解决小流被大流阻塞的问题,但在网络中如果绝大多数流量都是小流的场景或者突发流量等情况下,通过静态配置识别参数的大小流区分调度功能优化的效果不佳,例如数据中心网络中绝大多数流量是对时延更敏感的小流。对于上述场景,可以开启大小流自适应缓存功能。
在设备上,小流队列和大流队列共享一块缓存空间来调度报文。开启大小流自适应缓存功能可以动态调节小流队列和大流队列所占共享缓存空间的大小。当网络拥塞丢包时,在保证大流的吞吐率的前提下,系统动态降低大流队列可占用的共享缓存空间上限,此时小流队列可以占用的共享缓存空间上限相应提升,共享缓存空间可以尽可能多地吸收小流流量,避免小流的丢包,降低丢包带来的小流的时延。开启大小流自适应缓存功能后,设备具体工作流程如下:
(1) 缺省情况下,大流队列和小流队列均使用默认的尾部丢弃(Tail-Drop)的方法,即大流队列或小流队列长度占满缓存空间后,新进入缓存空间的报文被100%丢弃。
(2) 当网络拥塞,小流队列发生丢包时,系统触发大小流自适应缓存功能,此时大流采用WRED丢弃门限,即系统降低大流队列的丢弃门限,并按照WRED方式以一定概率丢弃大流报文,共享缓存空间中用于缓存小流报文的空间相应得到提升。
(3) 如果一定检测周期后设备检测到小流仍然发生丢包,则进一步降低大流队列的WRED丢弃门限,提升共享缓存空间中用于缓存小流报文的空间。
(4) 当某个检测周期内,小流不再发生丢包,逐步恢复大流队列的丢弃门限直到大流队列的丢弃门限恢复到系统默认的尾部丢弃方式。
开启本功能,系统将动态为大流队列设置WRED丢弃门限,即队列长度下限,因此,接口上如果静态配置WRED参数或应用WRED表会与本功能冲突,同时配置本功能和静态配置WRED参数或应用WRED表,静态配置WRED参数或应用WRED表优先生效。
# 开启大小流自适应缓存功能。
[Sysname-mice-elephant-flow] agile-buffer enable
qos mice-elephant-flow命令用来进入大小流视图。
# 进入大小流视图。
display traffic-matrix命令用来显示Traffic Matrix的流表。
(独立运行模式)
display traffic-matrix [ dynamic [ isdf-detect ] ] [ ip | ipv6 ] [ slot slot-number ]
display traffic-matrix [ dynamic [ isdf-detect ] ] [ ip | ipv6 ] [ chassis chassis-number slot slot-number ]
dynamic:显示自适应路由场景下,动态下发的Traffic Matrix流表信息。未指定本参数时,则显示静态配置的Traffic Matrix流表信息。
isdf-detect:显示静默故障检测机制生成的动态Traffic Matrix流表信息。未指定本参数时,则显示所有动态Traffic Matrix流表信息。关于静默故障检测机制的详细介绍请参见“网络管理和监控”配置中的“NetAnalysis”。
ip:显示所有IPv4流表,未指定本参数和ipv6参数则显示所有Traffic Matrix功能中的流表。
ipv6:显示所有IPv6流表,未指定本参数和ip参数则显示所有Traffic Matrix功能中的流表。
slot slot-number:显示指定单板上指定的配置信息和运行情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板的配置信息和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的配置信息和运行情况。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板的配置信息和运行情况。(IRF模式)
设备上存在多种Traffic Matrix流表:
· 静态配置的Traffic Matrix流表:通过ipv6 source destination或者ip source destination命令配置的Traffic Matrix流表。
· 动态生成的Traffic Matrix流表:自适应路由场景中,设备自动收集网络节点的拥塞情况,动态生成Traffic Matrix流表。关于自适应路由自动生成的Traffic Matrix流表详细介绍,请参见“三层技术-IP路由配置”中的“自适应路由”。
# 显示所有静态配置Traffic Matrix流表。
<Sysname> display traffic-matrix
Total number of traffic matrix entrys: IPv4 3, IPv6 0
Protocol : 17
SPort : 4791 SIP : 1.1.1.1
DPort : 4791 DIP : 2.2.2.2
Traffic path: XGE3/0/1 Next hop: 1.1.1.2
Status : Active Reason : -
Protocol : 17
SPort : - SIP : 1.1.1.1
DPort : - DIP : 2.2.2.2
Status : Inactive Reason : Interface down
Protocol : -
Status : Inactive Reason : Destination unreachable
Slot : 1
Protocol : 17
Protocol : 17
Status : Inactive Reason : ARP/ND unreachable
Protocol : -
Status : Inactive Reason : Remote path failure
# 显示动态生成的Traffic Matrix流表。
<Sysname> display traffic-matrix dynamic
Total number of traffic matrix entrys: IPv4 1, IPv6 0
Slot : 0
Protocol : 17
Source : Routing protocol Aging : 5 minutes remaining
表8-1 display traffic-matrix命令输出信息描述
Protocol |
协议的编号 |
SPort |
源端口号 |
SIP |
源IP地址 |
DPort |
目的端口号 |
DIP |
目的IP地址 |
Traffic path |
流量重定向的出接口 |
Next hop |
流量重定向的下一跳地址 |
Status |
Traffic Matrix的流表生效状态,取值包括: · Active:流表生效 · Inactive:流表未生效 |
Source |
动态生成的Traffic Matrix的流表的来源,取值包括: · Routing protocol:通过路由协议生成的表项 · ISDF detection:静默故障检测机制生成的表项 |
Reason |
Traffic Matrix的流表未生效原因,取值包括: · Interface down:重定向的出接口Down · Destination unreachable:重定向的下一跳地址不可达 · ARP/ND unreachable:ARP或ND表项无效,MAC地址不可达,即使路由可达也无法正常转发 · Remote path failure:通过BGP感知远端路径故障 · Resource not enough:产品设备资源不足 · Not ready:设备驱动未准备就绪,稍后重新执行显示命令后可能恢复正常 · -:Traffic Matrix的流表正常生效 |
Aging |
动态生成的Traffic Matrix流表的老化时间,取值包括: · x minutes remaining:老化时间剩余x分钟,老化时间不足x分钟,则向上取整 · Aged:流表已经老化 · -:在老化周期过半时间内持续有流存在,则不显示剩余老化时间 |
ip source destination命令用来配置Traffic Matrix的IPv4流表。
undo ip source destination命令用来删除Traffic Matrix的IPv4流表。
ip [ protocol { protocol | tcp | udp } ] source source-address destination dest-address [ source-port port destination-port port ] traffic-path interface interface-type interface-number next-hop ip-address
undo ip [ protocol { protocol | tcp | udp } ] source source-address destination dest-address [ source-port port destination-port port ]
Traffic Matrix中未配置IPv4流表。
Traffic Matrix视图
protocol { protocol | tcp | udp }:指定流量的协议类型,其中protocol表示协议的编号,取值范围为0~255。未指定本参数时表示任意协议类型的流量。
source source-address:指定流的源地址,其中source-address表示源IPv4地址。
destination dest-address:指定流的目的地址,其中dest-address表示目的IPv4地址。
source-port port:指定流的源端口,其中port表示端口号,取值范围为0~65535。未指定本参数时表示任意源端口的流量。本参数仅指定protocol为tcp(6)或udp(17)时支持。
destination-port port:指定流的目的端口,其中port表示端口号,取值范围为0~65535。未指定本参数时表示任意目的端口的流量。本参数仅指定protocol为tcp(6)或udp(17)时支持。
traffic-path interface interface-type interface-number:将匹配到的流量重定向到指定的接口转发,interface-type interface-number表示接口类型和接口编号。
next-hop ip-address:将匹配到的流量重定向到指定的下一跳。其中ip-address表示下一跳的IP地址,下一跳地址可以是IPv4地址或IPv6地址。
用于将流量重定向到指定的下一跳和出接口进行转发。重定向的业务流量必须匹配本命令中指定的源地址、目的地址、源端口号、目的端口号以及协议类型条件。
Traffic Matrix功能中可以定义多条IPv4流表。多次配置五元组信息相同的IPv4流表,则最后一次执行的命令所指定的IPv4流表生效。
Traffic Matrix功能中IPv4流表的源、目的及下一跳地址均需为合法单播地址。
在ip source destination命令生效后,Traffic Matrix功能会定期查询路由表,检查ip source destination命令中指定的下一跳地址是否可达。如果路由表中下一跳地址不可达,则ip source destination命令不再生效。
对于同一条业务流如果匹配到Traffic Matrix功能中多个IPv4流表,则IPv4流表优先生效顺序为:
(1) 如果流量匹配到指定了五元组信息即指定了Protocol值、源地址、目的地址、源端口和目的端口的IPv4流表最优先生效。
(2) 如果流量未匹配到指定了五元组信息的IPv4流表,则按照IPv4流表配置的先后顺序进行匹配,先配置的IPv4流表优先生效。
配置未指定完整五元组的Traffic Matrix流表时,请避免不同的Traffic Matrix流表之间存在匹配条件互相包含的情况,使得流量能够匹配到两条不同的Traffic Matrix流表,否则,可能导致重启设备前后或者接口震荡时同一条流命中不同的Traffic Matrix流表。例如:
· 存在Traffic Matrix流表仅指定了源地址1.1.1.1和目的地址2.2.2.2,该流表可以匹配任意源和目的端口、任意协议号的流量。又同时存在Traffic Matrix流表指定了相同的源地址1.1.1.1、相同的目的地址2.2.2.2和协议号80。此时,第一条流表可以匹配的流量包含了第二条流表可以匹配的流量。
· 存在Traffic Matrix流表仅指定了源地址1.1.1.1和目的地址2.2.2.2,该流表可以匹配任意源和目的端口、任意协议号的流量。又同时存在Traffic Matrix流表指定了相同的源地址1.1.1.1、相同的目的地址2.2.2.2和源端口号8080,目的端口号8080。此时,第一条流表可以匹配的流量包含了第二条流表可以匹配的流量。
# 配置Traffic Matrix的IPv4流表:指定协议为tcp,源地址为1.1.1.1,目的地址为2.2.2.2,源端口号8080,目的端口号8080,出接口为Ten-GigabitEthernet3/0/1,下一跳为3.3.3.3。
[Sysname] traffic-matrix
[Sysname-traffic-matrix] ip protocol tcp source 1.1.1.1 destination 2.2.2.2 source-port 8080 destination-port 8080 traffic-path interface ten-gigabitethernet 3/0/1 next-hop 3.3.3.3
· display traffic-matrix
ipv6 source destination命令用来配置Traffic Matrix的IPv6流表。
undo ipv6 source destination命令用来删除Traffic Matrix的IPv6流表。
ipv6 [ protocol { protocol | tcp | udp } ] source source-address destination dest-address [ source-port port destination-port port ] traffic-path interface interface-type interface-number next-hop ip-address
undo ipv6 [ protocol { protocol | tcp | udp } ] source source-address destination dest-address [ source-port port destination-port port ]
Traffic Matrix中未配置IPv6流表。
Traffic Matrix视图
source source-address:指定流的源地址,其中source-address表示源IPv6地址。
destination dest-address:指定流的目的地址,其中dest-address表示目的IPv6地址。
Traffic Matrix功能中可以定义多条IPv6流表。多次配置五元组信息相同的IPv6流表,则最后一次执行的命令所指定的IPv6流表生效。
Traffic Matrix功能中IPv6流表的源、目的及下一跳地址均需为合法单播地址。
在ipv6 source destination命令生效后,Traffic Matrix功能会定期查询路由表,检查ipv6 source destination命令中指定的下一跳地址是否可达。如果路由表中下一跳地址不可达,则ipv6 source destination命令不再生效。
对于同一条业务流如果匹配到Traffic Matrix功能中多个IPv6流表,则IPv6流表优先生效顺序为:
(1) 如果流量匹配到指定了五元组信息即指定了Protocol值、源地址、目的地址、源端口和目的端口的IPv6流表最优先生效。
(2) 如果流量未匹配到指定了五元组信息的IPv6流表,则按照IPv6流表配置的先后顺序进行匹配,先配置的IPv6流表优先生效。
· 存在Traffic Matrix流表仅指定了源地址1::1和目的地址2::2,该流表可以匹配任意源和目的端口、任意协议号的流量。又同时存在Traffic Matrix流表指定了相同的源地址1::1、相同的目的地址2::2和协议号80。此时,第一条流表可以匹配的流量包含了第二条流表可以匹配的流量。
· 存在Traffic Matrix流表仅指定了源地址1::1和目的地址2::2,该流表可以匹配任意源和目的端口、任意协议号的流量。又同时存在Traffic Matrix流表指定了相同的源地址1::1、相同的目的地址2::2和源端口号8080,目的端口号8080。此时,第一条流表可以匹配的流量包含了第二条流表可以匹配的流量。
# 配置Traffic Matrix的IPv6流表:指定协议为tcp,源地址为1::1,目的地址为2::2,源端口号8080,目的端口号8080,出接口为Ten-GigabitEthernet3/0/1,下一跳为3::3。
[Sysname-traffic-matrix] ipv6 protocol tcp source 1::1 destination 2::2 source-port 8080 destination-port 8080 traffic-path interface ten-gigabitethernet 3/0/1 next-hop 3::3
traffic-matrix命令用来开启Traffic Matrix功能,并进入Traffic Matrix视图。
undo traffic-matrix命令用来关闭Traffic Matrix功能,并删除Traffic Matrix的所有流表。
traffic-matrix
undo traffic-matrix
未开启Traffic Matrix功能。
在数据中心网络或智能无损网络进行AI模型训练的场景中,业务流量的条数少,但单条流的流量传输时间长和数据量大,属于大象流,业务流量按照Hash算法通过ECMP(Equal Cost Multi-Path,等价负载分担路径)进行流量负载分担时,容易出现负载不均衡的情况。为解决上述场景中流量负载不均的问题,可以开启Traffic Matrix功能(流量矩阵功能),控制器根据流量五元组等特征,在网络中的Leaf或Spine上下发流表进行引流,流量按照流表中的规则重定向到指定路径进行转发,从而实现由人工控制的流量负载分担。
通过执行traffic-matrix命令,可以进入Traffic Matrix视图,然后在该视图下执行ipv6 source destination命令或ipv6 source destination命令添加流表,流表中定义了详细业务流的路径规划规则。匹配到该规则定义的五元组等条件的业务流,按规则指定的出接口和下一跳进行转发。
Traffic Matrix流表可以通过两种方式生成:
静态配置的Traffic Matrix流表优先级高于动态生成的Traffic Matrix流表。
设备优先按照流表中定义的业务流的路径规划规则进行业务转发,如果流表中定义的路径规划无效,例如出接口故障或下一跳不可达,则流量再正常查询路由转发表项进行转发。
# 开启Traffic Matrix功能,并进入Traffic Matrix视图。
· ip source destination
· ipv6 source destination
display qos packet-statistics interface命令用来显示接口的ECN报文统计信息。
display qos packet-statistics interface interface-type interface-number { inbound | outbound }
inbound:显示接口入方向报文统计信息。
outbound:显示接口出方向报文统计信息。
# 显示接口Ten-GigabitEthernet3/0/1入方向的报文统计信息。
<Sysname> display qos packet-statistics interface ten-gigabitethernet 3/0/1 inbound
Interface: Ten-GigabitEthernet3/0/1
DSCP ECN Statistics
0 0 1 packets, 100 bytes
0 1 1 packets, 100 bytes
0 2 1 packets, 100 bytes
0 3 1 packets, 100 bytes
…略…
63 3 1 packets, 100 bytes
表9-1 display qos packet-statistics interface命令显示信息描述表
接口名称 |
ECN |
ECN标志 |
Statistics |
统计的数据包数目和字节数 |
qos packet-statistics命令用来开启接口上的ECN报文统计功能。
undo qos packet-statistics命令用来关闭接口上的ECN报文统计功能。
qos packet-statistics { inbound | outbound } ecn
undo qos packet-statistics { inbound | outbound }
接口上的报文统计功能处于关闭状态。
inbound:表示开启接口入方向的报文统计功能。
outbound:表示开启接口出方向的报文统计功能。
ecn:表示统计ECN报文。
# 开启接口Ten-GigabitEthernet3/0/1入方向的ECN报文统计功能。
[Sysname-Ten-GigabitEthernet3/0/1] qos packet-statistics inbound ecn
reset qos packet-statistics interface命令用来清除接口的ECN报文统计信息。
reset qos packet-statistics interface [ interface-type interface-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将清除所有接口的报文统计信息。
inbound:表示清除接口入方向的报文统计信息。
outbound:表示清除接口出方向的报文统计信息。
如果未指定方向,则同时清除接口出入两个方向的报文统计信息。
# 清除接口Ten-GigabitEthernet3/0/1入方向的报文统计信息。
<Sysname> reset qos packet-statistics ten-gigabitethernet 3/0/1 inbound
display qos queue-statistics interface outbound命令用来显示端口队列出方向的统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列出方向统计信息。
仅SF系列接口板支持端口队列统计显示功能。
端口队列统计配置功能需要使能AI显式拥塞通知功能。
如果开启指定队列的AI ECN功能,则所有队列都会统计字节数。
队列字节数统计不支持IPv6报文。
队列字节数统计不含帧间隙,字节数越小则统计bps的显示值比实际的流量越少。
队列字节数统计每3秒钟更新一次数据,如果在此期间多次查询,字节数和bps数据不变化。
# 显示接口Ten-GigabitEthernet3/0/1的队列出方向统计信息。
<Sysname> display qos queue-statistics interface ten-gigabitethernet 3/0/1 outbound
Direction: outbound
Forwarded: 0 packets, 0 bytes
Queue 0
Current queue length: 0 packets
Queue 1
Queue 2
Queue 3
Queue 4
Queue 5
Queue 6
Queue 7
表10-1 display qos queue-statistics interface outbound命令显示信息描述表
端口队列统计的端口 |
Direction |
端口队列统计的方向 |
Forwarded |
转发的数据包数目、字节数 |
Queue 0、Queue 1、Queue 2、Queue 3、Queue 4、Queue 5、Queue 6、Queue 7 |
某端口队列统计信息 |
Current queue length |
当前队列长度 |
· reset counters interface(接口管理命令参考/以太网接口)
qos queue-statistics byte-count命令用来开启以字节为单位的端口队列统计功能。
undo qos queue-statistics byte-count命令用来关闭以字节为单位的端口队列统计功能。
以字节为单位的端口队列统计功能处于关闭状态。
开启以字节为单位的端口队列统计功能后,通过display qos queue-statistics interface命令可以查看到以字节数为单位的端口队列粒度报文统计信息,未开启本功能则无法显示端口队列统计到的字节数。
在系统视图下开启本功能会消耗大量的ACL资源。为节省ACL资源,建议仅在对应的接口视图下开启。
在系统视图下开启以字节为单位的端口队列统计功能对于所有接口均生效,即使某个接口视图下执行undo qos queue-statistics byte-count命令关闭了以字节为单位的端口队列统计功能,该接口仍可以基于字节数进行端口队列统计。
# 在系统视图下开启以字节为单位的端口队列统计功能。
[Sysname] qos queue-statistics byte-count
· display qos queue-statistics interface outbound
display qos soft-car protocol命令用来显示协议报文上送CPU速率告警阈值配置情况。
(独立运行模式)
display qos soft-car protocol [ protocol-type ] slot slot-number
display qos soft-car protocol [ protocol-type ] chassis chassis-number slot slot-number
protocol-type:协议报文类型,具体如表11-1所示。如果未指定本参数,则显示表中所有协议报文类型。
slot slot-number:显示指定单板上协议报文速率的告警阈值信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板协议报文速率的告警阈值信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
报文类型 |
arp |
ARP协议 |
bgp |
BGP协议 |
dot1x |
802.1X协议 |
icmp |
ICMP协议 |
isis |
IS-IS协议 |
lacp |
LACP协议 |
oam |
OAM协议 |
pvst |
PVST协议 |
stp |
STP协议 |
vrrp |
VRRP协议 |
仅缺省MDC支持本命令。
本命令不支持使用commit命令下发目标配置。关于目标配置的详细介绍,请参见“基础配置命令参考”中的“目标配置管理”。
# 显示ARP协议报文上送CPU速率告警阈值配置情况。
<Sysname> display qos soft-car protocol arp slot 3
SoftCar limit rate info chip 0
PacketType ReasonId QueueId ReasonRcvAll ReasonRcvPps DisCnts Pps Alarm-threshold
arp 49 109 0 0 0 0 2000
SoftCar limit rate info chip 1
表11-2 display qos soft-car protocol命令显示信息描述表
SoftCar limit rate info chip |
芯片上软件的报文限速信息 |
PacketType |
上送CPU的协议报文类型 |
ReasonId |
上送CPU的原因索引 |
QueueId |
协议报文上送CPU的队列ID |
ReasonRcvAll |
上送CPU的协议报文总个数 |
ReasonRcvPps |
上送CPU的协议报文速率,单位为PPS |
DisCnts |
协议报文丢报个数 |
Pps |
协议报文的限速值,单位为PPS |
Alarm-threshold |
协议报文的告警阈值 |
qos soft-car protocol命令用来配置并启用协议报文上送CPU速率的告警阈值。
undo qos soft-car protocol命令用来关闭协议报文上送CPU速率的告警功能。
(独立运行模式)
qos soft-car protocol protocol-type alarm-threshold alarm-threshold-rate slot slot-number
undo qos soft-car protocol protocol-type alarm-threshold alarm-threshold-rate slot slot-number
qos soft-car protocol protocol-type alarm-threshold alarm-threshold-rate chassis chassis-number slot slot-number
undo qos soft-car protocol protocol-type alarm-threshold alarm-threshold-rate chassis chassis-number slot slot-number
未启用协议报文上送CPU速率的告警阈值。
protocol-type:协议报文类型。取值请参见表11-1。
alarm-threshold-rate:协议报文上送CPU速率的告警阈值。单位为pps。取值范围为0~20000。
slot slot-number:配置指定单板上协议报文速率的告警阈值,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备上指定单板协议报文速率的告警阈值,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
仅缺省MDC支持本命令。
通过本命令设置协议报文上送CPU速率的告警阈值,当超过阈值时打印告警信息。
# 配置ARP协议报文上送CPU速率的告警阈值为200。
[Sysname] qos soft-car protocol arp alarm-threshold 200 slot 3
