13-设备管理命令
本章节下载: 13-设备管理命令 (1.33 MB)
1.1.14 display cpu-usage configuration
1.1.15 display cpu-usage history
1.1.17 display device manuinfo
1.1.18 display device manuinfo chassis-only
1.1.19 display device manuinfo power
1.1.21 display diagnostic-information
1.1.22 display disk-information
1.1.24 display fabric multicast-forwarding mode
1.1.26 display forward-flow-mode
1.1.27 display hardware-failure-detection
1.1.28 display kernel memory alloc-failure
1.1.29 display kernel memory fragment free
1.1.32 display memory-threshold
1.1.33 display memory-threshold dma
1.1.36 display resource-monitor
1.1.38 display scheduler logfile
1.1.39 display scheduler reboot
1.1.40 display scheduler schedule
1.1.41 display switch-mode status
1.1.43 display system health history
1.1.44 display system stable state
1.1.45 display system-working-mode
1.1.46 display transceiver alarm
1.1.47 display transceiver diagnosis
1.1.48 display transceiver eyediagram-diagnosis
1.1.49 display transceiver health
1.1.50 display transceiver interface
1.1.51 display transceiver manuinfo
1.1.52 display transceiver power
1.1.53 display transceiver status
1.1.55 display version-update-record
1.1.57 fabric multicast-forwarding mode
1.1.60 forward-path-detection enable
1.1.62 hardware-failure-detection
1.1.69 monitor cpu-usage enable
1.1.70 monitor cpu-usage interval
1.1.71 monitor cpu-usage logging interval
1.1.72 monitor cpu-usage threshold
1.1.73 monitor handshake-timeout disable-port
1.1.74 monitor memory-usage logging interval
1.1.75 monitor resend cpu-usage
1.1.76 monitor resend memory-threshold
1.1.77 parity-error consistency-check log enable
1.1.78 parity-error consistency-check period
1.1.79 parity-error consistency-check threshold
1.1.80 parity-error monitor log enable
1.1.81 parity-error monitor period
1.1.82 parity-error monitor threshold
1.1.83 parity-error unrecoverable log enable
1.1.84 parity-error unrecoverable period
1.1.85 parity-error unrecoverable reboot
1.1.86 parity-error unrecoverable threshold
1.1.87 password-recovery enable
1.1.92 power-supply policy enable
1.1.93 power-supply policy priority
1.1.94 power-supply policy redundant
1.1.97 reset scheduler logfile
1.1.98 reset transceiver interface
1.1.99 reset version-update-record
1.1.100 resource-monitor minor resend enable
1.1.101 resource-monitor output
1.1.102 resource-monitor resource
1.1.104 restore factory-default
1.1.106 scheduler logfile size
1.1.108 scheduler reboot delay
1.1.115 system handshake timeout
1.1.122 transceiver health check enable
1.1.123 transceiver health weight
1.1.124 transceiver monitor enable
1.1.125 transceiver monitor interval
1.1.126 transceiver power-mode
1.1.127 transceiver rx-power high-threshold
1.1.128 transceiver rx-power low-threshold
1.1.129 transceiver rx-power change-threshold
1.1.130 transceiver tx-power high-threshold
1.1.131 transceiver tx-power low-threshold
clock datetime命令用来配置设备的系统时间。
clock datetime time date
设备的系统时间为UTC时间2011年1月1日零点。
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
执行本命令会修改设备的系统时间,会影响和系统时间相关特性的执行(例如定时执行任务功能),以及和其他设备的协同操作(例如日志上报和统计),请谨慎执行。
仅缺省MDC支持本命令。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
设备断电重启后,该命令会恢复到缺省情况,需要重新配置。
# 配置设备的系统时间为2015年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2015
# 配置设备的系统时间为2015年1月1日8时10分。
<Sysname> clock datetime 8:10 2015/1/1
· clock protocol
· clock summer-time
· clock timezone
· display clock
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | { ntp | ptp } }
undo clock protocol
从缺省MDC通过NTP协议获取时间。
none:表示通过命令行配置系统时间。
ptp:表示通过PTP(Precision Time Protocol,精确时间协议)协议获取时间。关于PTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“PTP”。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
仅缺省MDC支持本命令。
系统时间的获取方式有:
· 配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
· 配置clock protocol ntp命令后,通过NTP协议从网络中获取时间。该方式下,设备会周期性的同步服务器的UTC(Coordinated Universal Time,国际协调时间)时间,并用同步得到的UTC时间和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。该方式获取的时间比命令行配置的时间更精准,推荐使用。
多次执行本命令,最后一次执行的命令生效。
所有MDC的系统时间相同。当设备从某个MDC获取时钟后,会同步给其它MDC。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
· 直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
· 分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:January、February、March、April、May、June、July、August、September、October、November或December;然后输入开始的星期,用当月的第几个星期表示,取值如下:first、second、third、fourth、fifth或last;最后输入起始日,取值为Sunday、Monday、Tuesday、Wednesday、Thursday、Friday或Saturday。
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
· 直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
仅缺省MDC支持本命令。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
· clock datetime
· clock timezone
· display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用UTC时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
仅缺省MDC支持本命令。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
· clock datetime
· clock summer-time
· display clock
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnet、ftp、ssh2和monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口Ten-GigabitEthernet3/0/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface ten-gigabitethernet 3/0/1
[Sysname-job-shutdownGE] command 3 shutdown
· scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
display alarm命令用来显示设备的告警信息。
(独立运行模式)
display alarm [ slot slot-number ]
display alarm [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的告警信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的告警信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
仅缺省MDC支持本命令。
# 显示设备的告警信息。(独立运行模式)
<Sysname> display alarm
Slot CPU Level Info
1 0 ERROR faulty
表1-1 display alarm命令显示信息描述表
Slot |
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上 |
CPU |
告警CPU的编号 |
Level |
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO |
Info |
告警的详细信息。取值为: · faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态) · Fan n is absent:风扇n当前不在位 · Fan n is faulty:风扇n处于异常状态 · Power n is absent:电源n当前不在位 · Power n is faulty:电源n处于异常状态 · Slot n temperature is too low, below the low limit:单板温度过低,低于低温告警门限(独立运行模式) · Chassis n slot m temperature is too low, below the low limit:单板温度过低,低于低温告警门限(IRF模式) · Slot n temperature is too high, above the warning/high/shutdown limit:单板温度过高,高于一般级/严重级/关闭级高温告警门限(独立运行模式) · Chassis n slot m temperature is too high, above the warning/high/shutdown limit:单板温度过高,高于一般级/严重级/关闭级高温告警门限(IRF模式) |
display alarm active命令用来显示设备当前仍未恢复的告警信息。
display alarm active [ verbose ]
verbose:显示告警项的详细信息。不指定该参数时,显示告警项的概要信息。
仅缺省MDC支持本命令。
当设备的电源、CPU、风扇等运行异常时,使用display alarm命令可以查看到相应的告警信息。对于过去发生的、已经恢复的告警可以使用display alarm history命令查看;对于过去发生的、当前仍未恢复的告警可以使用display alarm active命令查看。
# 显示设备当前仍未恢复的告警信息。(独立运行模式)
<Sysname> display alarm active
Seq Level Time Info
24 Warning 2020-01-11 12:40:00 CPU usage is in minor alarm state on slot 1.
23 Warning 2020-01-11 12:30:00 Memory minor threshold has been exceeded on slot 1.
22 Minor 2020-01-11 12:18:00 Board state changed to Fault on slot 1.
表1-2 display alarm active命令显示信息描述表
Seq |
告警序列号,告警发生时分配。 |
Level |
告警的级别,级别由高到低依次为Critical、Major、Minor、Warning |
Time |
告警产生的时间 |
Info |
告警的详细信息,涉及风扇、电源、设备温度等硬件故障,主要取值包括: · Board state changed to Fault on slot xx:slot xx变成Fault状态(该slot可能正在启动,或者处于故障状态) · Slot xx fan xx is absent:Slot xx上风扇xx未插入 · Slot xx fan xx is failed:Slot xx上风扇xx处于异常状态 · Slot xx power xx is absent:Slot xx上电源xx未插入 · Slot xx power xx failed:Slot xx上电源xx处于异常状态 · Temperature is higher than the high-temperature alarming threshold on slot xx sensor inflow xx:slot xx上的传感器xx的温度高于高温门限 · Memory minor threshold has been exceeded on slot xx:slot xx的空闲内存高于minor门限 · CPU usage is in minor alarm state on slot xx:slot xx的CPU使用率高于minor门限 · Interface-name: RX power is high!:接口Interface-name光功率过高 · Interface-name:The bit error ratio exceeds the upper threshold:接口Interface-name误码率超过了上限 · SSH user username (IP: IP-Address) connected to the server successfully:SSH用户的用户名(IP:IP地址)成功登录服务器 · Member port xx of aggregation group xx changed to the inactive state, because xx.:聚合xx内成员接口xx因为xx原因非选中 · The mpls ldp session status changes. (SessionState=$1, DiscontinuityTime=$2, StatsUnknownMesTypeErrors=$3, StatsUnknownTlvErrors=$4):LDP会话状态变化 ¡ $1:LDP会话状态,取值包括:nonexistent,initialized,openrec,opensent,operational ¡ $2:LDP会话处于Operational状态的持续时间 ¡ $3:LDP会话收到未知信息的次数 ¡ $4:LDP会话收到未知TLV的次数 · The number of routes received from the BGP peer exceeded the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6):从BGP对等体收到的路由数量超过允许接收的最大路由数量 ¡ $1:BGP实例名称 ¡ $2:地址族标识符 ¡ $3:子地址族标识符 ¡ $4:BGP对等体的IP地址类型 ¡ $5:BGP对等体的IP地址 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 · BGP $1.$2: The number of routes from peer $3 ($4-$5) exceeds the limit $6.:从对等体学到的路由数量超过了允许的最大路由数量 ¡ $1:BGP实例名称 ¡ $2:VPN实例名称。如果是公网内的日志信息,则显示为空 ¡ $3:BGP对等体的IP地址 ¡ $4:地址族标识符 ¡ $5:子地址族标识符 ¡ $6:允许从对等体接收的最大路由前缀数量 · BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has reached the threshold ($7):接收的路由数量占允许的最大路由数量的百分比达到了阈值 ¡ $1:BGP实例名称 ¡ $2:VPN实例名称。如果是公网内的日志信息,则显示为空 ¡ $3:BGP对等体的IP地址 ¡ $4:地址族标识符 ¡ $5:子地址族标识符 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 ¡ $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量 · The number of routes received from the BGP peer exceeded the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7):从BGP对等体收到的路由数量超过告警阈值 ¡ $1:BGP实例名称 ¡ $2:地址族标识符 ¡ $3:子地址族标识符 ¡ $4:BGP对等体的IP地址类型 ¡ $5:BGP对等体的IP地址 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 ¡ $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量 |
# 显示设备当前仍未恢复的告警信息详细内容。(独立运行模式)
<Sysname> display alarm active verbose
Seq 4
Alarm name: BoardStatus
Alarm source: slot 2
Level: Minor
Start time: 2022-05-16 18:58:46
Info: Board state changed to Fault on slot 2.
表1-3 display alarm active verbose命令显示信息描述表
Seq |
告警序列号,告警发生时由系统自动分配 |
Alarm name |
告警的名称 |
Alarm source |
告警对象所在位置 |
Level |
Start time |
告警发生时间 |
Info |
告警的详细信息 |
# 显示设备当前仍未恢复的告警信息。(IRF模式)
Seq Level Time Info
24 Warning 2020-01-11 12:40:00 CPU usage is in minor alarm state on chassis 1 slot 1.
23 Warning 2020-01-11 12:30:00 Memory minor threshold has been exceeded on chassis 1 slot 1.
22 Minor 2020-01-11 12:18:00 Board state changed to Fault on chassis 1 slot 1.
表1-4 display alarm active命令显示信息描述表
Seq |
告警序列号,告警发生时分配。 |
Level |
Time |
告警产生的时间 |
Info |
告警的详细信息,涉及风扇、电源、设备温度等硬件故障,主要取值包括: · Board state changed to Fault on chassis xx slot xx:框xx槽位xx上的单板变成Fault状态(该单板可能正在启动,或者处于故障状态) · Chassis xx slot xx fan xx is absent:框xx槽位xx上的风扇xx未插入 · Chassis xx slot xx fan xx is failed:框xx槽位xx上的风扇xx处于异常状态 · Chassis xx slot xx power xx is absent:框xx槽位xx上的电源xx未插入 · Chassis xx slot xx power xx failed:框xx槽位xx上的电源xx处于异常状态 · Temperature is higher than the high-temperature alarming threshold on chassis xx slot xx sensor inflow xx:框xx槽位xx上的传感器xx的温度高于高温门限 · Memory minor threshold has been exceeded on chassis xx slot xx:框xx槽位xx的空闲内存高于minor门限 · CPU usage is in minor alarm state on chassis xx slot xx:框xx槽位xx的CPU使用率高于minor门限 · Interface-name: RX power is high!:接口Interface-name光功率过高 · Interface-name:The bit error ratio exceeds the upper threshold:接口Interface-name误码率超过了上限 · SSH user username (IP: IP-Address) connected to the server successfully:SSH用户的用户名(IP:IP地址)成功登录服务器 · Member port xx of aggregation group xx changed to the inactive state, because xx.:聚合xx内成员接口xx因为xx原因非选中 · The mpls ldp session status changes. (SessionState=$1, DiscontinuityTime=$2, StatsUnknownMesTypeErrors=$3, StatsUnknownTlvErrors=$4):LDP会话状态变化 ¡ $1:LDP会话状态,取值包括:nonexistent,initialized,openrec,opensent,operational ¡ $2:LDP会话处于Operational状态的持续时间 ¡ $3:LDP会话收到未知信息的次数 ¡ $4:LDP会话收到未知TLV的次数 · The number of routes received from the BGP peer exceeded the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6):从BGP对等体收到的路由数量超过允许接收的最大路由数量 ¡ $1:BGP实例名称 ¡ $2:地址族标识符 ¡ $3:子地址族标识符 ¡ $4:BGP对等体的IP地址类型 ¡ $5:BGP对等体的IP地址 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 · BGP $1.$2: The number of routes from peer $3 ($4-$5) exceeds the limit $6.:从对等体学到的路由数量超过了允许的最大路由数量 ¡ $1:BGP实例名称 ¡ $2:VPN实例名称。如果是公网内的日志信息,则显示为空 ¡ $3:BGP对等体的IP地址 ¡ $4:地址族标识符 ¡ $5:子地址族标识符 ¡ $6:允许从对等体接收的最大路由前缀数量 · BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has reached the threshold ($7):接收的路由数量占允许的最大路由数量的百分比达到了阈值 ¡ $1:BGP实例名称 ¡ $2:VPN实例名称。如果是公网内的日志信息,则显示为空 ¡ $3:BGP对等体的IP地址 ¡ $4:地址族标识符 ¡ $5:子地址族标识符 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 ¡ $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量 · The number of routes received from the BGP peer exceeded the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7):从BGP对等体收到的路由数量超过告警阈值 ¡ $1:BGP实例名称 ¡ $2:地址族标识符 ¡ $3:子地址族标识符 ¡ $4:BGP对等体的IP地址类型 ¡ $5:BGP对等体的IP地址 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 ¡ $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量 |
# 显示设备当前仍未恢复的告警信息详细内容。(IRF模式)
Seq 13
Alarm name: IPC_PKT_LOSS
Alarm source: e0003-0/ffff/0
Level: Major
Start time: 2022-05-25 19:22:40
Info: Chassis 1 slot 8: Packet loss occurred on inter-board IPC channel. Sourc
e port = Chassis 1 Slot 2, Destination port = Chassis 1 Slot 8. Detailed informa
tion = BLOCKED.
表1-5 display alarm active verbose命令显示信息描述表
Seq |
Alarm name |
告警的名称 |
Alarm source |
告警对象所在位置 |
Level |
Start time |
告警发生时间 |
Info |
告警的详细信息 |
· display alarm
· display alarm history
display alarm history命令用来显示已经恢复的告警信息。
display alarm history [ verbose ]
verbose:显示告警项的详细信息。不指定该参数时,显示概要信息。
仅缺省MDC支持本命令。
# 显示设备告警历史信息。(独立运行模式)
<Sysname> display alarm history
Seq Time Info
23 2020-01-11 12:40:00 CPU usage recovered to normal state on slot 1.
本命令显示信息描述表请参见“display alarm active”中的“display alarm active命令显示信息描述表”。
# 显示设备告警历史信息详细内容。(独立运行模式)
<Sysname> display alarm history verbose
Seq 23
Alarm name: CPUUsageMinor
Alarm position: slot 1
Start time: 2020-01-11 12:30:00
Level: Warning
Info: CPU usage is in minor alarm state on slot 1
Recovery time: 2020-01-11 12:40:30
Info: CPU usage minor alarm removed on slot 1.
表1-6 display alarm history verbose命令显示信息描述表
Seq |
Alarm name |
告警的名称 |
AlarmPosition |
告警对象所在位置 |
Start time |
告警发生时间 |
Level |
Recovery time |
告警恢复时间 |
Info |
告警的详细信息,取值主要包括: · BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has fallen below the threshold ($7):从BGP对等体收到的路由数量降低到告警阈值以下 ¡ $1:BGP实例名称 ¡ $2:VPN实例名称。如果是公网内的日志信息,则显示为空 ¡ $3:BGP对等体的IP地址 ¡ $4:地址族标识符 ¡ $5:子地址族标识符 ¡ $6:允许从对等体接收的最大路由数量 ¡ $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量 · The number of routes received from the BGP peer decreased below the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7).:从BGP对等体收到的路由数量降低到告警阈值以下 ¡ $1:BGP实例名称 ¡ $2:地址族标识符 ¡ $3:子地址族标识符 ¡ $4:BGP对等体的IP地址类型 ¡ $5:BGP对等体的IP地址 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 ¡ $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量 · The number of routes received from the BGP peer decreased below the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6):从BGP对等体收到的路由数量降低到允许接收的最大路由数量以下 ¡ $1:BGP实例名称 ¡ $2:地址族标识符 ¡ $3:子地址族标识符 ¡ $4:BGP对等体的IP地址类型 ¡ $5:BGP对等体的IP地址 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 · BGP $1.$2: The number of routes from peer $3 ($4-$5) fell below the limit $6.:从对等体学到的路由数量降低到了允许的最大路由数量以下 ¡ $1:BGP实例名称 ¡ $2:VPN实例名称。如果是公网内的日志信息,则显示为空 ¡ $3:BGP对等体的IP地址 ¡ $4:地址族标识符 ¡ $5:子地址族标识符 ¡ $6:为指定BGP对等体配置的允许设备接收的最大路由数量 |
# 显示设备告警历史信息。(IRF模式)
Seq Time Info
23 2020-01-11 12:40:00 CPU usage recovered to normal state on chassis 1 slot 1.
# 显示设备告警历史信息详细内容。
Seq 23
Alarm position: chassis 1 slot 1
Level: Warning
Info: CPU usage is in minor alarm state on chassis 1 slot 1
Info: CPU usage minor alarm removed on chassis 1 slot 1.
表1-7 display alarm history verbose命令显示信息描述表
Seq |
Alarm name |
告警的名称 |
AlarmPosition |
告警对象所在位置 |
Start time |
告警发生时间 |
Level |
Recovery time |
告警恢复时间 |
Info |
· display alarm
· display alarm active
display asset-info命令用来显示设备的用户资产信息。使用该命令,可以显示设备机箱、单板的资产信息。
(独立运行模式)
display asset-info { chassis | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
display asset-info chassis chassis-number { chassis | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
chassis:显示设备机箱的用户资产信息。
slot slot-number:显示指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn:显示资产编号信息。
custom:显示用户自定义的资产信息。
department:显示资产的归属部门信息。
description:显示资产的描述信息。
service-date:显示资产的启用时间信息。
state:显示资产的使用状态信息。
chassis chassis-number:显示指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
【描述】
当用户希望显示设备机箱、单板的具体信息项目(比如资产编号、资产描述信息等)时,只需要选择该信息项目对应的命令行参数;不选择具体信息项目对应的参数时,显示的是该设备机箱、单板的所有用户资产信息。
使用该命令显示设备机箱、单板没有经过设置的具体信息项目时,该信息项目的内容显示为空。
# 显示机箱的资产编号信息(该显示信息与用户的当前配置有关)。(独立运行模式)
<Sysname> display asset-info chassis csn
Type : Chassis
csn : 123456789
<Sysname> display asset-info chassis 1 chassis
Type : Chassis
csn : 123456789
description : frameA
service-date:
department :MKT
state :Normal
custom :1:789
表1-8 display asset-info命令显示信息描述表
Type |
资产类型,内容为指定的设备机箱、单板 |
csn |
资产编号信息,内容为空表示用户没有进行设置 |
description |
资产描述信息,内容为空表示用户没有进行设置 |
location |
资产位置信息,内容为空表示用户没有进行设置 |
service-date |
资产启用时间信息,内容为空表示用户没有进行设置 |
department |
资产归属部门信息,内容为空表示用户没有进行设置 |
state |
资产使用状态信息,内容为空表示用户没有进行设置 |
custom |
用户自定义的资产信息,内容为空表示用户没有进行设置 |
· reset asset-info
· set asset-info
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
显示信息中,时间的格式采用“时:分:秒.毫秒”的格式。
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00.211 Z5 Fri 03/16/2015
· clock datetime
· clock timezone
· clock summer-time
display copyright命令用来显示设备的版权信息。
显示信息略……。
display cpu-usage命令用来显示CPU利用率的统计信息。
(独立运行模式)
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number| all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ] ]
display cpu-usage [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
control-plane:显示控制平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
data-plane:显示数据平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
slot slot-number:显示指定单板的CPU利用率的统计信息。slot-number表示单板所在的槽位号。不指定该参数时,显示的是所有单板的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板的CPU利用率的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。
登录MDC后执行该命令,会显示该MDC可使用的CPU的利用率统计信息。
当最近5秒、最近1分钟、最近5分钟的CPU利用率取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 以段的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage summary
Slot CPU Last 5 sec Last 1 min Last 5 min
1 0 17% 29% 28%
表1-9 display cpu-usage命令显示信息描述表
1% in last 5 seconds |
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU或CPU核的平均利用率。该字段显示的是最近一个5秒统计周期内CPU或CPU核的平均利用率 |
Last 5 sec |
1% in last 1 minute |
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU或CPU核的平均利用率 |
Last 1 min |
1% in last 5 minutes |
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU或CPU核的平均利用率 |
Last 5 min |
display cpu-usage configuration命令用来显示CPU利用率监控功能的相关配置。
(独立运行模式)
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,显示的是主用主控板上的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。不指定该参数时,显示的是全局主用主控板上的相应信息。(IRF模式)
cpu cpu-number:表示CPU的编号。
登录MDC后执行该命令,会显示该MDC可使用的CPU的对应信息。
# 显示CPU利用率监控功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 90%.
Current minor alarm threshold is 80%.
Current recovery-threshold is 40%.
表1-10 display cpu-usage configuration命令显示信息描述表
CPU usage monitor is enabled. |
CPU利用率历史记录功能处于开启状态 |
Current monitor interval is 60 seconds. |
CPU利用率历史记录的采样周期为60秒 |
Current severe alarm threshold is 90%. |
CPU以及CPU核利用率的告警门限为90% |
Current minor alarm threshold is 80%. |
CPU低级别告警门限为80% |
Current recovery-threshold is 40%. |
CPU恢复门限为40% |
· monitor cpu-usage enable
· monitor cpu-usage interval
· monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
(独立运行模式)
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定单板的CPU利用率的历史信息。slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是主用主控板上指定进程的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CPU利用率的历史信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是全局主用主控板上指定进程的相应信息。(IRF模式)
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
· 纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
· 横坐标表示时间,时间越靠左表示距离当前时间越近。
· 用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。(独立运行模式)
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
(独立运行模式)
display device[ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
display device[ flash | usb ] [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ]
flash:显示Flash的信息。
usb:显示USB接口的信息。
chassis chassis-number:显示指定成员设备的详细信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
不指定flash和usb参数时,显示单板的信息。
在缺省MDC和非缺省MDC下执行该命令,显示信息相同,且均显示物理设备的对应信息。
# 显示设备信息。(独立运行模式)
<Sysname> display device
……显示信息略……
表1-11 display device命令显示信息描述表
Slot |
单板的槽位号 |
Brd Type |
单板的硬件类型 |
Status |
单板状态: · Standby表示该板是备用主控板 · Master表示该板是主用主控板 · Absent表示该槽位没有插入单板 · Fault表示该槽位单板正在启动、单板被下电或者单板出错,不能正常启动 · Normal表示该槽位单板是接口板并处于正常工作状态 |
Subslot |
单板支持接口子卡的最大个数 |
Sft Ver |
当前单板上运行的软件版本 |
Patch Ver |
当前单板上运行的、最新发布的热补丁版本。取值为None时表示没有安装热补丁 若同时安装了叠加补丁和非叠加补丁,则显示最新发布的叠加补丁。关于叠加补丁和非叠加补丁的介绍请参见“基础配置指导”中的“软件升级” |
display device manuinfo命令用来显示设备的电子标签信息。
(独立运行模式)
display device manuinfo [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示指定成员设备的电子标签信息。chassis-number表示设备在IRF中的成员编号。不输入该参数时,显示所有成员设备的相应信息。(IRF模式)
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该参数时,显示所有单板的相应信息。
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
本命令仅缺省MDC支持。
# 显示设备的电子标签信息。
<Sysname> display device manuinfo
显示信息略……。
display device manuinfo chassis-only命令用来显示背板的电子标签信息。
(独立运行模式)
display device manuinfo chassis chassis-number chassis-only
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
本命令仅缺省MDC支持。
# 显示机框背板的电子标签信息。
<Sysname> display device manuinfo chassis-only
显示信息略……。
display device manuinfo power命令用来显示电源的电子标签信息。
(独立运行模式)
display device manuinfo power power-id
display device manuinfo chassis chassis-number power power-id
power-id:表示设备上电源的ID编号。
本命令仅缺省MDC支持。
仅S7506X-G和S7510X-G设备支持此命令。
# 显示指定电源的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo power 1
显示信息略……。
display device uptime命令用来显示单板最近一次启动后的运行时长。
# 显示单板最近一次启动后的运行时长。(独立运行模式)
<Sysname> display device uptime
Slot No. Brd Type Brd Status Subslot UP time(DD:HH:MM)
0 LSCM1SUP03A0 Master 0 0001:05:37
1 NONE Absent 0 None
2 NONE Absent 0 None
3 LSCM1QGS8CSSE0 Normal 0 0001:05:34
4 LSCM1TGS48SE0 Normal 0 0001:05:34
# 显示单板最近一次启动后的运行时长。(IRF模式)
Slot Type State Subslot UP time(DD:HH:MM)
1/0 LSCM1SUP03A0 Master 0 0001:05:37
1/1 NONE Absent 0 None
1/2 NONE Absent 0 None
1/3 LSCM1QGS8CSSE0 Normal 0 0001:05:34
1/4 LSCM1TGS48SE0 Normal 0 0001:05:34
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ hardware | ifmgr | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware:收集硬件相关的诊断信息。
ifmgr:收集IFMGR模块相关诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1) 使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2) 使用gunzip命令将文件XXXX.gz解包成文件XXXX。
(3) 使用more命令查看文件XXXX的内容。
如果收集诊断文件过程半途中止,可能导致gunzip命令无法正常解压,但诊断文件中仍包括已经生成的诊断信息,可以将诊断文件传输到PC上使用Linux系统下的gunzip -c命令解压查看。
不指定filename参数执行display diagnostic-information命令时,系统会要求用户选择显示诊断信息还是将诊断信息保存到文件中。如果用户选择保存诊断信息,且当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
未指定hardware、infrastructure、l2、l3和service参数时,将收集设备产生的所有诊断信息。
该命令不支持“|”、“>”和“>>”参数。
执行display diagnostic-information命令前,请使用display cpu-usage、display memory命令查看CPU、内存使用率。如果CPU使用率为100%,或者内存使用率超过90%,请暂时不要执行display diagnostic-information命令,等CPU和内存使用率回落后再执行。
执行本命令收集诊断信息时,请不要配置设备,以免影响收集结果。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2015
显示信息略……。
# 将收集到的诊断信息保存到缺省诊断文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
· gunzip(基础配置命令参考/文件系统管理)
· more(基础配置命令参考/文件系统管理)
· tar extract(基础配置命令参考/文件系统管理)
display disk-information命令用来收集硬盘信息。
(独立运行模式)
display disk-information [ slot slot-number [ cpu cpu-number ] ]
display disk-information [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示单板上指定CPU对应的硬盘信息。slot-number表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:显示单板上指定CPU对应的硬盘信息。chassis-number表示IRF中设备的成员编号,slot-number表示指定成员设备上的指定单板。不指定该参数时,表示全局主用主控板。(IRF模式)
cpu cpu-number:显示指定CPU对应的硬盘信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
当存储介质故障或者需要查看硬盘状态时,可以通过本命令收集设备硬盘信息,来诊断故障。
该命令会收集设备上所有硬盘信息并显示,通过diskid进行区分。
对于单板丝印前缀为LSCM1的单板,不支持本命令。
# 收集硬盘信息。(适用于NVMe硬盘)
<Sysname> display disk-information slot 1
Slot 1:
DiskID: nvme0n1
smartctl 7.2 2022-06-08 r635726:636193M [aarch64-linux-4.4.65] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: FORESEE 256GB SSD
Serial Number: LD1ZS4H000022
Firmware Version: V2.2
PCI Vendor ID: 0x2263
PCI Vendor Subsystem ID: 0x1d97
IEEE OUI Identifier: 0x000000
Total NVM Capacity: 256,060,514,304 [256 GB]
Unallocated NVM Capacity: 0
Controller ID: 1
NVMe Version: 1.3
Number of Namespaces: 1
Namespace 1 Size/Capacity: 256,060,514,304 [256 GB]
Namespace 1 Formatted LBA Size: 512
Local Time is: Mon Apr 10 15:58:42 2023 UTC
Firmware Updates (0x02): 1 Slot
Optional Admin Commands (0x0007): Security Format Frmw_DL
Optional NVM Commands (0x0015): Comp DS_Mngmt Sav/Sel_Feat
Log Page Attributes (0x0a): Cmd_Eff_Lg Telmtry_Lg
Maximum Data Transfer Size: 32 Pages
Warning Comp. Temp. Threshold: 85 Celsius
Critical Comp. Temp. Threshold: 90 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 5.00W - - 0 0 0 0 0 0
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 34 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 1%
Data Units Read: 3,752,041 [1.92 TB]
Data Units Written: 89,005 [45.5 GB]
Host Read Commands: 22,919,229
Host Write Commands: 659,876
Controller Busy Time: 57
Power Cycles: 52
Power On Hours: 4,575
Unsafe Shutdowns: 45
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 34 Celsius
Thermal Temp. 2 Transition Count: 37
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
# 收集硬盘信息。(适用于SATA硬盘)
Slot 16:
DiskID: sda
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-4.4.65] (local build)
Model Family: Micron 5100 Pro / 52x0 / 5300 SSDs
Device Model: Micron_5300_MTFDDAV480TDS
Serial Number: 20122744FA44
LU WWN Device Id: 5 00a075 12744fa44
Firmware Version: D3MU001
User Capacity: 480,103,981,056 bytes [480 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: Solid State Device
Form Factor: M.2
TRIM Command: Available, deterministic, zeroed
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Apr 10 20:15:55 2023 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 1674) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 6) minutes.
Conveyance self-test routine
recommended polling time: ( 3) minutes.
SCT capabilities: (0x0035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 050 Pre-fail Always - 0
5 Reallocated_Sector_Ct 0x0032 100 100 001 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 1317
12 Power_Cycle_Count 0x0032 100 100 001 Old_age Always - 236
170 Reserved_Block_Pct 0x0033 100 100 010 Pre-fail Always - 0
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 001 Old_age Always - 0
173 Avg_Block-Erase_Count 0x0032 100 100 000 Old_age Always - 15
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 233
183 SATA_Int_Downshift_Ct 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 80
194 Temperature_Celsius 0x0022 062 028 000 Old_age Always - 38 (Min/Max 19/72)
195 Hardware_ECC_Recovered 0x0032 100 100 000 Old_age Always - 0
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
202 Percent_Lifetime_Remain 0x0030 100 100 001 Old_age Offline - 0
206 Write_Error_Rate 0x000e 100 100 000 Old_age Always - 0
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 18779935651
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 586907500
248 Bckgnd_Program_Page_Cnt 0x0032 100 100 000 Old_age Always - 52641458
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033 100 100 000 Pre-fail Always - 2161
210 RAIN_Success_Recovered 0x0032 100 100 000 Old_age Always - 0
211 Integ_Scan_Complete_Cnt 0x0032 100 100 000 Old_age Always - 176
212 Integ_Scan_Folding_Cnt 0x0032 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Self-test routine in progress 90% 1299 -
# 2 Short offline Self-test routine in progress 90% 1299 -
# 3 Short offline Self-test routine in progress 90% 1299 -
# 4 Short offline Self-test routine in progress 90% 1299 -
# 5 Short offline Self-test routine in progress 90% 1299 -
# 6 Short offline Self-test routine in progress 90% 1299 -
# 7 Short offline Self-test routine in progress 90% 1299 -
# 8 Short offline Self-test routine in progress 90% 1299 -
# 9 Short offline Self-test routine in progress 90% 1299 -
#10 Short offline Self-test routine in progress 90% 1299 -
#11 Short offline Self-test routine in progress 90% 1299 -
#12 Short offline Self-test routine in progress 90% 1299 -
#13 Short offline Self-test routine in progress 90% 1299 -
#14 Short offline Self-test routine in progress 90% 1299 -
#15 Short offline Self-test routine in progress 90% 1299 -
#16 Short offline Self-test routine in progress 90% 1299 -
#17 Short offline Self-test routine in progress 90% 1299 -
#18 Short offline Self-test routine in progress 90% 1299 -
#19 Short offline Self-test routine in progress 10% 1299 -
#20 Short offline Self-test routine in progress 90% 1299 -
#21 Extended captive Interrupted (host reset) 00% 177 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
表1-12 display disk-information命令显示信息描述表
DiskId |
硬盘ID。如果产品未分配,使用内核分配的可唯一标识硬盘的信息,否则使用产品分配的ID。 |
Model Family |
硬盘系列 |
Device Model |
型号 |
Serial Number |
序列号 |
LU WWN Device Id |
全球唯一ID |
Firmware Version |
固件版本号 |
User Capacity |
容量 |
Sector Sizes |
Sector大小 |
Rotation Rate |
机械硬盘转速,其他不涉及 |
Form Factor |
接口形式 |
TRIM Command |
Trim执行支持情况 |
Device is |
Smartctl database是否包含该硬盘 |
ATA Version is |
支持ATA协议版本 |
SATA Version is |
支持SATA协议版本 |
Local Time is |
当前时间 |
SMART support is |
硬盘是否支持Smart |
SMART support is |
Smart是否使能 |
SMART overall-health self-assessment test result |
硬盘健康状态,PASSED为健康 |
Model Number |
硬盘型号 |
PCI Vendor ID |
Vendor ID |
PCI Vendor Subsystem ID |
IEEE OUI Identifier |
组织唯一标识符 |
Total NVM Capacity |
容量 |
Unallocated NVM Capacity |
未分配容量 |
Controller ID |
控制器ID |
NVMe Version |
NVMe版本 |
Number of Namespaces |
命名空间数量 |
Namespace n Size/Capacity |
命名空间n容量 |
Namespace n Formatted LBA Size |
命名空间n LBA大小 |
Firmware Updates |
支持的firmware slots数量 |
Optional Admin Commands |
支持的可选Admin命令 |
Optional NVM Commands |
支持的可选NVM命令 |
Log Page Attributes |
支持的log page |
Maximum Data Transfer Size |
单个命令最大传输大小 |
Warning Comp. Temp. Threshold |
过热警告温度 |
Critical Comp. Temp. Threshold |
过热临界温度 |
其余字段和硬盘型号、硬盘厂商有关,需要结合硬盘手册或者厂家FAE支持进行翻译。
display environment命令用来显示设备上温度传感器的温度信息。
(独立运行模式)
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示IRF中指定成员设备上温度传感器的温度信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的对应信息。(IRF模式)
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。不指定该参数时,显示所有单板的对应信息。
不指定slot参数时,显示的是设备上所有温度传感器的温度信息。(独立运行模式)
不指定chassis参数时,显示的是IRF中所有温度传感器的温度信息;指定chassis但不指定slot参数时,显示的是指定成员设备上所有温度传感器的温度信息。(IRF模式)
本命令仅缺省MDC支持。
# 显示设备上所有温度传感器的温度信息。(独立运行模式)
<Sysname> display environment
System temperature information (degree centigrade):
Slot Sensor Temperature Lower Warning Alarm Shutdown
1 hotspot 1 38 10 40 50 100
1 hotspot 2 42 10 50 80 100
表1-13 display environment命令显示信息描述表
System Temperature information (degree centigrade) |
系统温度信息,单位为摄氏度 |
sensor |
温度传感器 · hotspot:表示热点温度传感器 · inflow:表示入风口温度传感器 · outflow:表示出风口温度传感器 |
Slot |
当显示数字时表示指定slot上温度传感器的温度信息 |
Temperature |
当前温度。当显示为Failed时,表示温度传感器故障 |
Lower |
低温告警门限。当显示为NA时,表示不支持该门限 |
Warning |
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限 |
Alarm |
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限 |
Shutdown |
关断级(Shutdown)高温告警门限,当风扇故障或不在位时,并且温度传感器的温度大于该门限超过10S时,设备会自动关闭。当显示为NA时,表示不支持该门限 |
display fabric multicast-forwarding mode命令用来显示组播的转发模式。
# 显示组播的转发模式。
<Sysname> display fabric multicast-forwarding mode
The current mode is standard.
The mode at the next startup is standard.
display fan命令用来显示风扇的工作状态。
(独立运行模式)
display fan [ verbose ]
display fan [ chassis chassis-number ] [ verbose ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定chassis参数时,表示所有风扇。(IRF模式)
fan-id:表示设备内置风扇的编号。不指定该参数时,表示指定位置的所有风扇。
verbose:显示设备内置风扇的详细信息。不指定该参数时,显示设备内置风扇的简要信息。
本命令仅缺省MDC支持。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
Fan 0 State: Normal
表1-14 display fan命令显示信息描述表
Fan 0 |
风扇框的编号 |
State |
风扇状态: · Absent:风扇不在位 · Normal:风扇正常工作 · Faulty:风扇故障 |
<Sysname> display fan verbose
Fan 0:
Fan State: Normal
Sub Fan number: 2
Fan mode: Auto
Airflow Direction: Left-to-right
SubFan PWM Max speed:
1 84% 12000
2 84% 12000
表1-15 display fan命令显示信息描述表
Fan 0 |
设备上风扇的编号 |
State |
Sub Fan number |
子风扇的数量 |
Fan mode |
风扇框的调速模式 |
Airflow Direction |
风扇框的吹风方向 |
SubFan |
子风扇的编号 |
PWM |
最大功率占比 |
Max speed |
风扇最大转速 |
display forward-flow-mode命令用来显示设备跨板转发单条数据流的工作模式。
本命令用来显示设备当前跨板转发单条数据流的工作模式,以及设备下次重启后跨板转发单条数据流的工作模式。
仅缺省MDC支持本命令。
# 显示设备跨板转发单条数据流的工作模式。
<Sysname> display forward-flow-mode
Current flow forwarding mode: Standard.
Flow forwarding mode at the next startup: Enhanced.
表1-16 display forward-flow-mode命令显示信息描述表
Current flow forwarding mode |
当前设备跨板转发单条数据流的工作模式 |
Flow forwarding mode at the next startup |
下次重启时设备跨板转发单条数据流的工作模式 |
· forward-flow-mode
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息。
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息,包括各种故障对应的修复操作,以及系统中每个单板最近十次故障修复的历史信息。
硬件故障检测和修复的历史信息保存在主用主控板上,即使某个槽位单板已拔出或者更换过,只要在主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(独立运行模式)
硬件故障检测和修复的历史信息保存在本地主用主控板上,即使某个槽位单板已拔出或者更换过,只要在本地主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当本地主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(IRF模式)
仅缺省MDC支持本命令。
# 查看设备的硬件故障检测和故障修复信息。(独立运行模式)
<Sysname> display hardware-failure-detection
Current level:
chip : isolate
board : isolate
forwarding : warning
Recent record:
--------------------------Slot 0 executed records:-----------------------------
There is no record.
--------------------------Slot 0 trapped records:-----------------------------
There is no record.
表1-17 display hardware-failure-detection命令显示信息描述表
Current level |
当前故障检测对应的修复操作 |
chip : |
器件类故障对应的修复操作 |
board : |
单板类故障对应的修复操作 |
forwarding : |
转发类故障对应的修复操作 |
Recent record: |
最近记录 |
Slot n executed records: |
主控板n上记录的各个单板的历史操作记录(独立运行模式) |
Chassis n, Slot m executed records: |
成员设备n主控板m上记录的各个单板的历史操作记录(IRF模式) |
Slot n trapped records: |
主控板n上记录的各个单板的trap告警信息(独立运行模式) |
Chassis n, Slot m trapped records: |
成员设备n主控板m上记录的各个单板的trap告警信息(IRF模式) |
display kernel memory alloc-failure命令用来显示内核内存申请失败信息。
(独立运行模式)
display kernel memory alloc-failure [ slot slot-number [ cpu cpu-number ] ]
display kernel memory alloc-failure [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定Master设备主用主控板。(IRF模式)
# 显示内核内存申请失败信息。
<System> display kernel memory alloc-failure
kmalloc_tag failures: 55.
kcalloc_tag failures: 0.
kzalloc_tag failures: 0.
krealloc_tag failures: 0.
kmem_cache_alloc_tag failures: 0.
表1-18 display kernel memory alloc-failure 命令显示信息描述表
kmalloc_tag failures |
调用kmalloc_tag申请内存失败的次数 |
kcalloc_tag failures |
调用kcalloc_tag申请内存失败的次数 |
kzalloc_tag failures |
调用kzalloc_tag申请内存失败的次数 |
krealloc_tag failures |
调用krealloc_tag申请内存失败的次数 |
kmem_cache_alloc_tag failures |
调用kmem_cache_alloc_tag申请内存失败的次数 |
display kernel memory fragment free命令用来显示内核空间空闲内存的统计信息。
(独立运行模式)
display kernel memory fragment free [ slot slot-number [ cpu cpu-number ] ]
display kernel memory fragment free [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
# 显示内核空间空闲内存的统计信息。
<Sysname> display kernel memory fragment free
Kernel memory free ratio: 0.13%
cfq_io_context memory free (in kbytes): 0
LFIB_NhlfeEntryCache26 memory free (in kbytes): 0
LFIB_NhlfeEntryCache74 memory free (in kbytes): 0
L2VFIB_TUNNELBMP_Cache memory free (in kbytes): 0
NAT_SESSION_EXT_INFO memory free (in kbytes): 0
ARP_VSISUP_Entry_cache memory free (in kbytes): 0
LFIB_NhlfeEntryCache1 memory free (in kbytes): 0
FVN_FwdCache19 memory free (in kbytes): 0
---- More ----
表1-19 display kernel memory fragment 命令显示信息描述表
Kernel memory free ratio |
内核空间空闲内存占内核空间总内存的比例 |
cfq_io_context memory free (in kbytes) |
Slab名为cfq_io_context的空闲内存大小,单位为千字节 |
display memory命令用来显示内存使用情况。
(独立运行模式)
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
slot slot-number:表示单板所在的槽位号,不指定时显示当前所有单板的内存使用情况。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示所有主控板。(IRF模式)
cpu cpu-number:表示CPU编号。
登录MDC后执行该命令,会显示该MDC可使用的内存的使用情况。
当显示信息中某一行所有参数的取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 显示设备的内存使用情况的详细信息。(独立运行模式)
<Sysname> display memory
Memory statistics are measured in KB:
Slot 0:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 1993056 1643360 349696 0 2592 914912 51.4%
-/+ Buffers/Cache: 725856 1267200
Swap: 0 0 0
# 显示设备的内存使用情况的简要信息。(独立运行模式)
<Sysname> display memory summary
Slot CPU Total Used Free Buffers Caches FreeRatio
0 0 1993056 1643536 349520 2592 914912 51.4%
3 0 1993056 349584 1643472 96 54272 82.5%
4 0 1993056 351408 1641648 96 54272 82.4%
表1-20 display memory命令显示信息描述表
Memory statistics are measured in KB: |
系统内存使用情况,以下统计信息均以KB为单位 |
Mem |
内存使用信息 |
Total |
系统可分配的物理内存的大小 设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销以及ISSU功能运行等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小 |
Used |
整个系统已用的物理内存大小 |
Free |
整个系统可用的物理内存大小 |
Shared |
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值 |
Buffers |
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值 |
Cached |
高速缓冲寄存器已使用的内存大小。当系统内存告警时,高速缓冲寄存器中的部分内存可主动释放供其他业务使用。取值为“--”时,表示不支持统计该参数的值 |
Caches |
高速缓冲寄存器已使用的内存大小。当系统内存告警时,高速缓冲寄存器中的部分内存可主动释放供其他业务使用 |
FreeRatio |
整个系统物理内存的空闲率。包含当前剩余空闲内存以及高速缓冲寄存器中当前正在使用但是内存告警状态下可主动释放的内存 |
-/+ buffers/cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小 -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小 |
Swap |
交换分区的使用信息 |
display memory dma命令用来显示DMA内存的使用情况。
(独立运行模式)
display memory dma [ slot slot-number [ cpu cpu-number ] ]
display memory dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
# 显示slot1的DMA内存使用相关信息。(独立运行模式)
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total Used Free FreeRatio
16384 6140 10244 63%
表1-21 display memory dma 命令显示信息描述表
DMA memory statistics measured in KB |
系统使用DMA内存情况,单位为KB |
Total |
内存分片的总个数,为Free和Used之和 |
Used |
系统已使用的DMA内存大小 |
Free |
系统可使用的DMA内存大小 |
FreeRatio |
Free与Total的比率,可以反映系统DMA内存的空闲率 |
display memory-threshold命令用来显示内存告警门限相关信息。
(独立运行模式)
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(IRF模式)
仅缺省MDC支持本命令。
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free-memory thresholds:
Minor: 194M
Severe: 136M
Critical: 77M
Normal: 252M
Early-warning: 311M
Secure: 350M
Current free-memory state: Normal (secure)
Free-memory event statistics:
[Back to secure state]
First notification: 0.0
Latest notification: 0.0
Total number of notifications sent: 0
[Entered early-warning state]
First notification at: 0.0
Latest notification at: 0.0
[Back to normal state]
[Entered minor alarm state]
[Back to minor alarm state]
[Entered severe alarm state]
[Back to severe alarm state]
[Entered critical alarm state]
表1-22 display memory-threshold命令显示信息描述表
Memory usage threshold |
内存利用率阈值 |
Free-memory thresholds Minor Severe Critical Normal Early-warning Secure |
剩余内存门限阈值: · Minor:一级告警门限,单位为MB · Severe:二级告警门限,单位为MB · Critical:三级告警门限,单位为MB · Normal:恢复到正常状态的阈值,单位为MB · Early-warning:预告警门限,单位为MB · Secure:恢复预告警门限状态的阈值,单位为MB |
Current free-memory state |
系统当前内存使用状态: · Normal:正常状态 · Minor:一级告警门限状态 · Severe:二级告警门限状态 · Critical:三级告警门限状态 · Normal (early-warning):预告警状态 · Normal (secure):安全状态 |
Free-memory event statistics: |
门限事件统计信息,事件分为: · Back to secure state:恢复到预告警前的状态 · Entered early-warning state:进入预告警门限状态 · Back to normal state:内存恢复到正常状态 · Entered minor alarm state:进入一级告警门限状态 · Back to minor alarm state:恢复到一级告警前的状态 · Entered severe alarm state:进入二级告警门限状态 · Back to severe alarm state:恢复到二级告警前的状态 · Entered critical alarm state:进入三级告警门限状态 |
First notification at |
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification at |
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notification send |
事件发生的总次数 |
display memory-threshold dma命令用来显示DMA内存告警相关信息。
(独立运行模式)
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
display memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
# 显示DMA内存告警相关信息。
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
Critical: 2048KB
Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
[Entered to critcal state]
表1-23 display memory-threshold dma 命令显示信息描述表
Free DMA memory thresholds: Critical: Normal: |
DMA内存告警阈值(单位为KB): · Critical:告警阈值 · Normal:告警恢复阈值 |
Current DMA memory state |
DMA内存的当前状态: · Critical:告警状态 · Normal:正常状态 |
Free memory event statistics: |
告警事件统计信息,事件分为: · Back to normal state:内存恢复到正常状态 · Entered to critcal state:进入告警状态 |
First notification |
告警事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification |
告警事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notifications sent |
告警事件发生的总次数 |
display power命令用来显示设备电源的信息。
(独立运行模式)
display power [ power-id | verbose ]
display power [ chassis chassis-number [ power-id | verbose ] ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有电源。(IRF模式)
power-id:表示电源模块的编号。不指定该参数时,表示指定位置的所有电源。
verbose:显示电源的详细信息。不指定该参数时,显示电源的简要信息。
本命令仅缺省MDC支持。
# 显示设备电源的简要信息。
<Sysname> display power
Input Power: 1600.0 W
PowerID State Mode Current(A) Voltage(V) Power(W) FanDirection
1 Absent -- -- -- -- --
2 Absent -- -- -- -- --
3 Absent -- -- -- -- --
4 Absent -- -- -- -- --
5 Normal AC 13.5 54.7 738.2 --
6 Absent -- -- -- -- --
7 Absent -- -- -- -- --
8 Absent -- -- -- -- --
表1-24 display power命令显示信息描述表
Input Power |
设备的额定功率 |
PowerID |
设备上的电源模块编号 |
State |
电源模块的状态 · Absent:电源不在位 · Normal:电源正常工作 · Fault:电源故障 |
Mode |
电源模块的类型,取值为: · AC:表示交流电源 · DC:表示直流电源 |
Current(A) |
电源输出电流,单位为安,显示为“--”表示设备暂不支持统计该信息 |
Voltage(V) |
电源输出电压,单位为伏,显示为“--”表示设备暂不支持统计该信息 |
Power(W) |
电源输出功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息 |
FanDirection |
电源模块内风扇的吹风方向,取值为: · PowerToPort:电源侧进风、端口侧出风 · PortToPower:端口侧进风、电源侧出风 · --:表示暂不支持统计该信息 |
# 显示电源的详细信息。(独立运行模式)
<Sysname> display power verbose
System power information:
Power modules installed: 1
Power modules usable: 1
Rated power: 1600 W
Usable power: 1500 W
Used power: 670.0 W
Redundant power: 0 W
Fan power: 460 W
Surplus power: 930 W
Total DC output: 12.1 A
Total Power input: 160.0 W
PowerID In/Out Type State InVoltage(V) InPower(W) OutVoltage(V)
OutCurrent(A) OutPower(W) Switch
1 AC/DC PSR1600B-12A-B Normal 238.0 160.0 12.0
12.1 145.4 on
2 --/-- Power Absent -- -- --
3 --/-- Power Absent -- -- --
4 --/-- Power Absent -- -- --
表1-25 display power verbose命令显示信息描述表
System power information |
设备上电源系统的相关信息 |
Power modules installed |
设备中已安装的电源模块数量 |
Power modules usable |
设备中可用的电源模块数量 |
Rated power |
处于Normal状态的电源模块的额定功率之和,单位为瓦 |
Usable power |
处于Normal状态的电源模块可分配的功率之和,单位为瓦 |
Used power |
当前已分配的功率,单位为瓦 |
Redundant power |
电源系统实际的冗余功率,单位为瓦 |
Fan power |
当前风扇框已使用的功率,单位为瓦 |
Surplus power |
设备中所有电源模块输入功率的和,单位为瓦 |
Total DC output |
设备中所有电源模块输出电流值的和,单位为安 |
Total Power input |
设备中所有电源模块输入功耗的和,单位为瓦 |
PowerID |
设备上电源模块的编号 |
In/Out |
电源模块输入/输出类型: · AC:表示交流输入/输出 DC:表示直流输入/输出 |
Type |
电源模块的型号 |
State |
电源模块的状态,取值为: · Absent:表示未安装电源 · Normal:表示电源正常工作 · Faulty:表示电源故障 |
InVoltage(V) |
电源模块的实际输入电压 |
InPower(W) |
电源模块的实际输入功率 |
OutVoltage(V) |
电源模块的实际输出电压 |
OutCurrent(A) |
电源模块的实际输出电流 |
OutPower(W) |
电源模块的实际输出功率 |
Power information by slot |
各slot对当前电源模块的使用情况 |
Type |
单板的类型 |
Current(A) |
单板当前的输入电流,单位为安,显示为“--”表示设备暂不支持统计该信息 |
Power(W) |
单板的额定功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息 |
CH1-I(A) |
单板channel1上的实际电流 |
CH1-V(V) |
单板channel1上的实际电压 |
CH2-I(A) |
单板channel2上的实际电流 |
CH2-V(V) |
单板channel2上的实际电压 |
CH3-I(A) |
单板channel3上的实际电流 |
CH3-V(V) |
单板channel3上的实际电压 |
ActualPower(W) |
单板的实际功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息 |
Status |
单板的状态: · Absent:表示单板不在位 · Normal:表示单板正常 · Faulty:表示单板故障 |
display power-supply命令用来显示电源管理功能的相关信息。
(独立运行模式)
display power-supply [ chassis chassis-number ]
chassis chassis-number:显示指定成员设备上电源管理功能的相关信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
对于主控板和IRF物理端口所在的单板,不支持显示供电优先级相关的信息。
# 显示设备电源管理功能的相关信息。(独立运行模式)
<Sysname> display power-supply
Power supply policy: Disable
Power modules redundant (setting): 0
Board power supply information:
Slot Type Priority Status
0 LSCM1SUP03A0 -- Powered on
1 None -- Reserved
2 LSCM1TGS48SE0 5 Powered on
3 LSCM1QGS8CSSE0 5 Powered on
4 None 5 Absent
表1-26 display power-supply命令显示信息描述表
Power supply policy |
电源管理功能是否处于开启状态: · Disable:处于关闭状态 · Enable:处于开启状态 |
Power modules redundant (setting) |
配置的冗余电源模块数 |
Board power supply information |
单板电源管理信息 |
Priority |
单板的供电优先级 |
Slot |
单板所在槽位号 |
Type |
单板型号 |
Status |
单板状态,取值为: · Powered on:表示单板处于上电状态 · Powered off:表示单板电源功率不足未上电 · Reserved:表示单板预留 · Off(manual):表示单板被手动下电 · Off(Temp):表示单板高温下电 · Absent:表示单板不在位 · --:表示单板功率状态获取失败 |
display resource-monitor命令用来显示资源监控功能的相关信息。
(独立运行模式)
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
display resource-monitor [ resource resource-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
resource resource-name:需要监测的资源的名称。参数的取值请参见resource-monitor resource命令的设备可监测的资源描述表。
slot slot-number:显示指定单板的资源告警事件通知功能的相关信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的资源告警事件通知功能的相关信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的资源告警事件通知功能的相关信息。cpu-number表示需要检测的资源所在CPU的编号。
LSCM1GT48SC0单板不支持本命令。
# 显示ARP资源监控的相关信息。(独立运行模式)
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource Minor Severe Free/Total
(%) (%) (absolute)
arp 50 20 90095/90098
表1-27 display resource-monitor命令显示信息描述表
Minor alarms resending |
周期发送低级别资源告警通知功能的开启状态: · Enabled:表示该功能已开启 · Disabled:表示该功能未开启 |
Resource |
监控资源的名称 |
Minor (%) |
低级别告警门限,单位为百分比 |
Severe (%) |
高级别门限,单位为百分比 |
Free/Total (absolute) |
剩余资源的数量/该资源的总数,用绝对值形式表示 |
· resource-monitor minor resend enable
· resource-monitor resource
display scheduler job命令用来显示Job的配置信息。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name : shutdown
Schedule name : shutdown
Execution time : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang ten-gigabitethernet 3/0/1 to ten-gigabitethernet 3/0/3
[Sysname-if-range]shutdown
表1-28 display scheduler logfile命令显示信息描述表
Logfile Size |
Schedule日志文件的大小,单位为字节 |
Job name |
Job的名称 |
Schedule name |
Schedule的名称 |
Execution time |
开始执行Job的时间 |
Completion time |
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息) |
Job output |
Job中的命令执行时的输出信息 |
· reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
· scheduler reboot at
· scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type : Run once after 0 hours 2 minutes
Start time : Tue Dec 27 10:44:42 2015
Last execution time : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts : 1
Job name Last execution status
shutdown Successful
表1-29 display scheduler schedule命令显示信息描述表
Schedule name |
Schedule的名称 |
Schedule type |
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息 |
Start time |
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息 |
Last execution time |
Schedule上一开始执行的时间 · 如果没有为Schedule配置执行时间,则不会显示该信息 · 如果还没有执行,则显示Yet to be executed |
Last completion time |
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息 |
Execution counts |
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息 |
Job name |
Schedule下关联的Job的名称 |
Last execution status |
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看) · Successful:表示执行成功 · Failed:表示执行失败 · Waiting:表示正在等待被执行 · In process:表示正在执行 · -NA-:表示还没有到执行时间 |
display switch-mode status用于查看所有业务板当前的工作模式以及业务板配置的工作模式。
(独立运行模式)
display switch-mode status chassis chassis-number
chassis chassis-number:显示指定成员设备上所有业务板当前的工作模式和代理模式以及业务板配置的工作模式和代理模式。chassis-number表示设备在IRF中的成员编号。(IRF模式)
使用undo switch-mode命令将业务板的工作模式恢复到未配置状态(即config显示为NONE),保存配置并重启该设备后,业务板将以缺省工作模式启动。
# 查看交换机所有业务板当前的工作模式以及业务板配置的工作模式。
<Sysname> display switch-mode status
LPU switch mode:
Slot Current Config
0 NORMAL NONE
2 NORMAL NONE
3 NORMAL NONE
表1-30 display switch-mode status显示信息描述表
LPU switch mode |
业务板的工作模式 |
Slot |
业务板槽位号 |
Current |
业务板当前的工作模式: NONE:业务板不支持配置业务板的工作模式 NORMAL:业务板当前的工作模式为普通模式 BALANCE:业务板当前的工作模式为均衡模式 BRIDGING:业务板当前的工作模式为MAC扩展模式 ROUTING:业务板当前的工作模式为路由扩展模式 ENHANCE:业务板当前的工作模式为增强模式 EHC-BALANCE:业务板当前的工作模式为增强的均衡模式 EHC-BRIDGING:业务板当前的工作模式为增强的MAC扩展模式 EHC-ROUTING:业务板当前的工作模式为增强的路由扩展模式 |
Config |
业务板配置的工作模式: NONE:业务板不支持配置业务板的工作模式 NORMAL:业务板当前的工作模式为普通模式 BALANCE:业务板当前的工作模式为均衡模式 BRIDGING:业务板当前的工作模式为MAC扩展模式 ROUTING:业务板当前的工作模式为路由扩展模式 ENHANCE:业务板当前的工作模式为增强模式 EHC-BALANCE:业务板当前的工作模式为增强的均衡模式 EHC-BRIDGING:业务板当前的工作模式为增强的MAC扩展模式 EHC-ROUTING:业务板当前的工作模式为增强的路由扩展模式 |
· switch-mode
display system health命令用来显示设备的健康状态。
(独立运行模式)
display system health [ chassis chassis-number ]
chassis chassis-number :表示设备在IRF中的成员编号。不指定该参数时,则表示主设备。(IRF模式)
设备会定期执行一系列检查,以便了解设备是否处于健康状态。检查项在设备出厂时已固定,检查结果可供设备内部业务模块(例如IRF、M-LAG等)使用,也可通过本命令供用户查看。
# 显示系统健康情况。(独立运行模式)
<Sysname> display system health
Health: Faulty(3)
Memory: Normal(0)
Communication: Normal(0)
DBM monitor: Normal(0)
Chip jam: Normal(0)
CPU deadloop: Normal(0)
Forwarding channel: Normal(0)
HG: Normal(0)
LSW CPU: Normal(0)
LSW port: Normal(0)
Board status: Faulty(3)
Fan status: Normal(0)
Temperature: Normal(0)
# 显示系统健康情况。(IRF模式)
Chassis 1 health: Normal(0)
Memory: Normal(0)
Chip jam: Normal(0)
HG: Normal(0)
LSW CPU: Normal(0)
LSW port: Normal(0)
Board status: Normal(0)
Chassis 2 health: Normal(0)
Memory: Normal(0)
Chip jam: Normal(0)
HG: Normal(0)
LSW CPU: Normal(0)
LSW port: Normal(0)
表1-31 display system health命令显示信息描述表
Health: Normal(0) |
系统的健康状态。取值为: · Normal(0):表示系统健康 · Faulty(n):表示系统不健康,n表示健康值,取值越大越不健康 |
Memory |
内存检测 |
Communication |
通信检测 |
DBM monitor |
DBM进程异常检测 |
Chip jam |
芯片堵死定时检测 |
CPU deadloop |
CPU死循环检测 |
Forwarding channel |
(S7503X-G、S7503X-M-G不支持)设备跨板业务检测 |
HG |
单板间HG检测 |
LSW CPU |
LSW CPU故障检测 |
LSW port |
LSW端口检测 |
Board status |
单板状态检测 |
Fan status |
风扇状态检测 |
Temperature status |
温度传感器状态检测 |
· display system health history
display system health history命令用来显示系统健康状态变化的历史信息。
(独立运行模式)
display system health history[ chassis chassis-number ]
# 显示系统健康状态变化的历史信息。
<Sysname> display system health history
Health: Faulty(1)
Chip jam:
Faulty(1) 2019-10-10 18:00:00 on slot 1
Normal(0) 2019-10-08 17:00:00 on slot 1
Faulty(1) 2019-10-07 18:00:00 on slot 1
表1-32 display system health history命令显示信息描述表
Health: Normal(0) |
系统当前的健康状态。取值为: · Normal(0):表示系统健康 · Faulty(n):表示系统不健康,n表示健康值,取值越大越不健康 |
Chip jam: Faulty(1) 2019-10-10 18:00:00 on slot 1 |
健康检测结果有变化的检测项的历史信息,设备支持的检测项请参见“display system health”中的“display system health命令显示信息描述表”,每个测试项最多显示30条系统健康状态变化的历史信息 Faulty(1) 2019-10-10 18:00:00 on slot 1表示slot 1在2019-10-10 18:00:00状态变为Faulty(1) |
display system stable state命令用来显示系统的稳定状态。
display system stable state [ mdc { mdc-id | all } ] [ summary ]
mdc { mdc-id | all }:显示指定或所有MDC的系统稳定状态。mdc-id表示MDC的编号,MDC的取值范围为1~5。
summary:显示系统稳定状态的汇总信息,该信息包括CPU的运行状态、主备状态和NSR的稳定状态。不指定该参数时,显示CPU的运行状态、主备状态,以及CPU运行状态的详细信息。
不指定mdc参数时,显示系统的稳定状态。
在进行ISSU升级或主备倒换前,请先执行该命令,检查设备是否处于稳定状态。如果System State未处于Stable状态,不能进行ISSU升级;如果Redundancy Stable未处于Stable状态,不能进行主备倒换。
设备/单板/MDC启动需要一定的时间,才能达到Stable状态。如果设备/单板/MDC长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备/单板/MDC,根据其具体状态,采取进一步措施。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
· 通过display device命令查看设备是否处于故障状态。
· 通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
· 通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统稳定状态的汇总信息。
<Sysname> display system stable state summary
System state : Stable
Redundancy state : No redundancy
NSR state : No standby
# 显示系统的稳定状态。(独立运行模式)
Redundancy state : Stable
Slot CPU Role State
0 0 Active Stable
1 0 Standby Stable
3 0 Other Stable
15 0 Other Stable
表1-33 display system stable state命令显示信息描述表
System state |
单板运行状态的汇总: · Stable:稳定运行,表示所有单板均处于稳定运行状态 · Not ready:未稳定,此时不能进行ISSU升级 |
Redundancy state |
主备状态: · Stable:主备状态稳定,可以倒换 · No redundancy:系统无冗余,不能倒换 · Not ready:未稳定,不可以倒换 |
NSR state |
各模块NSR(Nonstop Routing,不间断路由)状态的汇总,取值为: · Ready:稳定状态,表示所有开启的NSR功能均能正常工作 · Not ready:未稳定状态,此时不能进行进程倒换或者主备倒换、ISSU升级 · No standby:没有备用主控板 · Not configured:未开启NSR功能 |
Role |
单板在系统中的身份: · Active:主用主控板 · Standby:备用主控板,提供冗余备份 · Other:业务板 |
State |
单板的运行状态: · Stable:单板稳定运行 · Board inserted:单板插入 · Kernel initiating:单板内核初始化 · Service starting:单板上的服务正在启动 · Service stopping:单板上的服务正在关闭 · HA Batch backup:HA批量备份中 · Interface data batch backup:接口管理批量备份未完成 · MDC starting:MDC正在启动 · MDC stopping:MDC正在关闭 · Automatic configuration:MDC正在进行自动配置 |
当前对象处于未稳定状态 |
· display device
· display ha service-group(可靠性命令参考/进程分布优化)
· display mdc(虚拟化技术命令参考/MDC)
display system-working-mode命令用来显示设备的工作模式。
仅缺省MDC支持本命令。
# 显示设备的工作模式。
<Sysname> display system-working-mode
The current system working mode is standard.
The system working mode for next startup is standard.
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-34 SFP/SFP28/SFP+/GBIC/SFF的display transceiver alarm命令输出信息描述表
RX signal loss |
接收信号丢失 |
RX power high alarm |
接收光功率高告警 |
RX power high warning |
接收光功率高预警 |
RX power low alarm |
接收光功率低告警 |
RX power low warning |
接收光功率低预警 |
TX fault |
发送错误 |
TX bias high alarm |
偏置电流高告警 |
TX bias high warning |
偏置电流高预警 |
TX bias low alarm |
偏置电流低告警 |
TX bias low warning |
偏置电流低预警 |
TX power high alarm |
发送光功率高告警 |
TX power high warning |
发送光功率高预警 |
TX power low alarm |
发送光功率低告警 |
TX power low warning |
发送光功率低预警 |
Temp high alarm |
温度高告警 |
Temp high warning |
温度高预警 |
Temp low alarm |
温度低告警 |
Temp low warning |
温度低预警 |
Voltage high alarm |
电压高告警 |
Voltage high warning |
电压高预警 |
Voltage low alarm |
电压低告警 |
Voltage low warning |
电压低预警 |
Transceiver info I/O error |
模块信息读写错误 |
Transceiver info checksum error |
模块信息校验和错误 |
Transceiver type and port configuration mismatch |
模块类型和端口配置不匹配 |
Transceiver type not supported by port hardware |
端口不支持该模块类型 |
Excessive RX power change |
接收光功率变化量过大告警 |
Excessive TX power change |
发送光功率变化量过大告警 |
Excessive TX bias change |
偏置电流变化量过大告警 |
Excessive temp change |
温度变化量过大告警 |
User-set TX power high |
用户自定义发送光功率高告警 |
User-set TX power low |
用户自定义发送光功率低告警 |
User-set RX power high |
用户自定义接收光功率高告警 |
User-set RX power low |
用户自定义接收光功率低告警 |
RX CDR loss of lock |
接收侧CDR失锁,表示信号不好 |
TX CDR loss of lock |
发送侧CDR失锁,表示信号不好 |
表1-35 QSFP+/QSFP28的display transceiver alarm命令输出信息描述表
Temp high alarm |
温度高告警 |
Temp high warning |
温度高预警 |
Temp low alarm |
温度低告警 |
Temp low warning |
温度低预警 |
电压高告警 |
电压高预警 |
Voltage low alarm |
电压低告警 |
电压低预警 |
RX loss of signal(channel x) |
通道x接收到的信号丢失 |
TX fault(channel x) |
通道x发送报文时出错 |
TX loss of signal(channel x) |
通道x发送的信号丢失 |
RX power high(channel x) |
通道x接收到的光的功率太高 |
RX power low(channel x) |
通道x接收到的光的功率太低 |
TX power high alarm(channel x) |
通道x发送光功率高告警 |
TX power high warning(channel x) |
通道x发送光功率高预警 |
TX power low alarm(channel x) |
通道x发送光功率低告警 |
TX power low warning(channel x) |
通道x发送光功率低预警 |
TX bias high(channel x) |
通道x的偏置电流高 |
TX bias low(channel x) |
通道x的偏置电流低 |
模块读写错误 |
模块信息校验和错误 |
Transceiver type and port configuration mismatched |
模块类型和端口配置不匹配 |
Transceiver type not supported |
端口不支持该类型的模块 |
Excessive RX power change(channel x) |
通道x接收光功率变化量过大告警 |
Excessive TX power change(channel x) |
通道x发送光功率变化量过大告警 |
Excessive TX bias change(channel x) |
通道x偏置电流变化量过大告警 |
温度变化量过大告警 |
User-set TX power high(channel x) |
通道x用户自定义发送光功率高告警 |
User-set TX power low(channel x) |
通道x用户自定义发送光功率低告警 |
User-set RX power high(channel x) |
通道x用户自定义接收光功率高告警 |
User-set RX power low(channel x) |
通道x用户自定义接收光功率低告警 |
表1-36 CFP的display transceiver alarm命令输出信息描述表
TX jitter PLL unlocked |
发送Jitter PLL失锁 |
TX CMU unlocked |
发送CMU失锁 |
Overloaded |
负载过大 |
Loss of REFCLK input |
缺乏参考时钟 |
Channel signals out of alignment |
主机通道信号不对齐 |
PLD or flash initialization error |
初始化错误 |
Power supply fault |
电源错误 |
CFP checksum error |
校验和错误 |
TX bias high |
偏置电流高 |
TX bias low |
偏置电流低 |
Temp high |
温度高 |
Temp low |
温度低 |
Voltage high |
电压高 |
Voltage low |
电压低 |
RX signal loss in channel x |
通道x接收到的信号丢失 |
RX IC unlocked in channel x |
通道x接收到的IC时钟失锁 |
RX FIFO error in channel x |
通道x接收到FIFO错误 |
TX signal loss in channel x |
通道x发送的信号丢失 |
TX IC unlocked in channel x |
通道x发送的IC时钟失锁 |
TX FIFO error in channel x |
主机通道x的发送FIFO出错 |
主机通道x发送的IC时钟失锁 |
APD supply fault in channel x |
通道x出现APD错误 |
TEC fault in channel x |
通道x出现TEC错误 |
Wavelength unlocked in channel x |
通道x的光信号波长失锁 |
RX power high in lane x |
通道x接收到的光的功率太高 |
RX power low in lane x |
通道x接收到的光的功率太低 |
TX power high in lane x |
通道x发送的光的功率太高 |
TX power low in lane x |
通道x发送的光的功率太低 |
TX bias high in lane x |
通道x的偏置电流高 |
TX bias low in lane x |
通道x的偏置电流低 |
Temp high in lane x |
通道x的温度高 |
Temp low in lane x |
通道x的温度低 |
模块读写错误 |
模块信息校验和错误 |
模块类型和端口配置不匹配 |
端口不支持该类型的模块 |
表1-37 XFP的display transceiver alarm命令输出信息描述表
RX signal loss |
接收信号丢失 |
RX not ready |
接收状态未就绪 |
RX CDR时钟失锁 |
接收光功率高告警 |
接收光功率高预警 |
接收光功率低告警 |
接收光功率低预警 |
TX not ready |
发送状态未就绪 |
TX fault |
发送错误 |
TX CDR时钟失锁 |
偏置电流高告警 |
偏置电流高预警 |
TX bias low alarm |
偏置电流低告警 |
偏置电流低预警 |
发送光功率高告警 |
发送光功率高预警 |
发送光功率低告警 |
发送光功率低预警 |
Module not ready |
模块状态未就绪 |
APD supply fault |
APD(Avalanche Photo Diode,雪崩光电二极管)错误 |
TEC fault |
TEC(Thermoelectric Cooler,热点冷却器)错误 |
Wavelength unlocked |
光信号波长失锁 |
Temp high alarm |
温度高告警 |
Temp high warning |
温度高预警 |
Temp low alarm |
温度低告警 |
Temp low warning |
温度低预警 |
Voltage high alarm(3.3V) |
电压高告警(3.3V) |
Voltage high warning(3.3V) |
电压高预警(3.3V) |
Voltage low alarm(3.3V) |
电压低告警(3.3V) |
Voltage low warning(3.3V) |
电压低预警(3.3V) |
Voltage high alarm(5.5V) |
电压高告警(5.5V) |
Voltage high warning(5.5V) |
电压高预警(5.5V) |
Voltage low alarm(5.5V) |
电压低告警(5.5V) |
Voltage low warning(5.5V) |
电压低预警(5.5V) |
Voltage high alarm(1.8V) |
电压高告警(1.8V) |
Voltage high warning(1.8V) |
电压高预警(1.8V) |
Voltage low alarm(1.8V) |
电压低告警(1.8V) |
Voltage low warning(1.8V) |
电压低预警(1.8V) |
Voltage high alarm(5.2V) |
电压高告警(5.2V) |
Voltage high warning(5.2V) |
电压高预警(5.2V) |
Voltage low alarm(5.2V) |
电压低告警(5.2V) |
Voltage low warning(5.2V) |
电压低预警(5.2V) |
模块信息读写错误 |
模块信息校验错误 |
模块类型和端口配置不匹配 |
端口不支持该模块类型 |
表1-38 XENPAK的display transceiver alarm命令输出信息描述表
WIS local fault |
WIS(WAN Interface Sublayer)本地错误 |
Receive optical power fault |
接收光功率错误 |
PMA/PMD receiver local fault |
PMA/PMD(Physical Medium Attachment/Physical Medium Dependent)接收器本地错误 |
PCS receive local fault |
PCS(Physical Coding Sublayer)接收本地错误 |
PHY XS receive local fault |
PHY XS(PHY Extended Sublayer)接收本地错误 |
RX power high |
接收光功率高 |
RX power low |
接收光功率低 |
Laser bias current fault |
激光器偏置电流错误 |
Laser temperature fault |
激光器温度错误 |
Laser output power fault |
激光器输出光功率错误 |
TX fault |
发送器错误 |
PMA/PMD接收器本地错误 |
PCS接收本地错误 |
PHY XS接收本地错误 |
TX bias high |
偏置电流高 |
TX bias low |
偏置电流低 |
TX power high |
发送光功率高 |
TX power low |
发送光功率低 |
Temp high |
温度高 |
Temp low |
温度低 |
模块信息I/O错误 |
模块信息校验错误 |
模块类型和端口配置不匹配 |
端口不支持该模块类型 |
表1-39 QSFP-DD光模块的display transceiver alarm命令输出信息描述表
Data path firmware fault |
数据通道固件错误 |
Module firmware fault |
模块固件错误 |
Module state changed |
模块状态改变 |
Data path state changed in channel x |
通道x的数据路径状态改变 |
TX loss in channel x |
通道x的发送信号丢失 |
TX CDR LOL in channel x |
通道x的TX 时钟和数据恢复失锁 |
TX input eq fault in channel x |
通道x的TX输入均衡错误 |
RX CDR LOL in channel x |
通道x的RX 时钟和数据恢复失锁 |
Loss of reference clock |
基准时钟丢失 |
L-Host Pattern Generator LOL in channel x |
通道x的主机端码型发生器失锁 |
L-Media Pattern Generator LOL in channel x |
通道x的媒体端模式发生器失锁 |
L-Host Pattern Checker LOL in channel x |
通道x的主机端码型检查器失锁 |
L-Media Pattern Checker LOL in channel x |
通道x的媒体端模式检查器失锁 |
通道x接收光功率变化量过大告警 |
通道x发送光功率变化量过大告警 |
通道x偏置电流变化量过大告警 |
温度变化量过大告警 |
通道x用户自定义发送光功率高告警 |
通道x用户自定义发送光功率低告警 |
通道x用户自定义接收光功率高告警 |
通道x用户自定义接收光功率低告警 |
# 显示接口Ten-GigabitEthernet3/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver current alarm information:
RX signal loss
RX power low alarm
表1-40 display transceiver alarm显示信息描述表
transceiver current alarm information |
接口光模块当前故障告警信息 |
RX signal loss |
接收信号丢失 |
接收光功率低告警 |
接收光功率低预警 |
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口Ten-GigabitEthernet3/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver diagnostic information:
Temp.(C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
Warning thresholds:
Temp(C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 45 3.25 1.25 -15.00 4.00
Low 25 2.85 0.85 -25.00 1.00
User-set power thresholds:
High -11.40 N/A
Low -26.00 0.10
# 显示接口HundredGigE1/0/49上插入的QSFP28可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface hundredgige 1/0/49
HundredGigE1/0/49 transceiver diagnostic information:
[module] Temp.(C) Voltage(V)
29 3.33
[channel] Bias(mA) RX power(dBm) TX power(dBm)
1 0.00 -36.96 -36.96
2 0.00 -36.96 -36.96
3 0.00 -36.96 -36.96
4 0.00 -36.96 -36.96
Alarm thresholds:
High 75 3.47 13.00 3.40 5.00
Low -5 3.13 3.00 -14.00 -10.00
Warning thresholds:
High 70 3.45 11.00 2.40 3.00
Low 0 3.15 5.00 -11.00 -8.00
High 4.40 4.40
Low -10.00 N/A
# 显示接口FourHundredGigE1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname>display transceiver diagnosis interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver diagnostic information:
[Module] Temp.(C) Voltage(V) TEC Curr. (%) Laser Temp.(C)
40 3.34 38 53
[Channel] Bias(mA) RX power(dBm) TX power(dBm)
1 1.13 -20.43 -1.0
2 1.13 -20.43 -1.0
3 1.13 -20.43 -1.0
4 1.13 -20.43 -1.0
5 1.13 -20.43 -1.0
6 1.13 -20.43 -1.0
7 1.13 -20.43 -1.0
8 1.13 -20.43 -1.0
Alarm thresholds:
High 80 3.64 15.00 5.00 5.50
Low -10 2.97 4.50 -12.00 -3.50
TEC Curr(%) Laser Temp(%)
High 100.00 70
Low -100.00 5
Warning thresholds:
High 89.55 67
Low -89.85 10
High 4.40 4.40
Low -10.00 N/A
# 显示接口FourHundredGigE1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。(本举例仅CMIS 4.0光模块支持)
<Sysname> display transceiver diagnosis interface fourhundredgige 1/0/1
Temp(C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
Alarm thresholds:
High N/A N/A
Low N/A N/A
Warning thresholds:
High N/A N/A
Low N/A N/A
Media performance monitoring:
Parameter Count
Rx bits : 12345678901234567890
Rx corrected bits : 12345678901234567890
Rx frames : 12345678901234567890
Rx uncorrectable frames : 12345678901234567890
Host performance monitoring:
Parameter Count
Tx bits : 12345678901234567890
Tx corrected bits : 12345678901234567890
Tx frames : 12345678901234567890
Tx uncorrectable frames : 12345678901234567890
表1-41 display transceiver diagnosis显示信息描述表
transceiver diagnostic information |
接口插入的光模块的数字诊断信息 |
Current diagnostic parameters |
当前的诊断参数 |
Temp.(C) |
数字诊断参数——温度,单位为°C,精确到1°C |
Voltage(V) |
数字诊断参数——电压,单位为V,精确到0.01V |
TEC Curr. (%) |
数字诊断参数——制冷器工作电流/制冷器的额定电流,单位为%,精确到0.01% |
Laser Temp.(C) |
数字诊断参数——激光器温度,单位为°C,精确到0.01°C |
Bias(mA) |
数字诊断参数——偏置电流,单位为mA,精确到0.01mA |
Total RX power(dBm) |
数字诊断参数——总接收光功率,单位为dBm,精确到0.01dBm |
Total TX power(dBm) |
数字诊断参数——总发送光功率,单位为dBm,精确到0.01dBm |
RX power(dBm) |
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm |
TX power(dBm) |
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm |
Alarm thresholds |
告警门限 |
High |
高告警门限或高预警门限 |
Low |
低告警门限或低预警门限 |
Warning threshold |
预警门限 |
Warning threshold |
预警门限 |
User-set power thresholds |
用户自定义功率告警门限 |
RX power(dBm) |
用户自定义接收光功率门限值,单位为dBm,精确到0.01dBm |
TX power(dBm) |
用户自定义发送光功率门限值,单位为dBm,精确到0.01dBm |
表1-42 display transceiver diagnosis显示信息中光学参数统计信息描述表(本表中的显示信息仅CMIS 4.0光模块支持)
Media performance monitoring |
介质侧性能监控 |
Host performance monitoring |
主机侧性能监控 |
Rx bits |
接收比特数 |
Rx corrected bits |
FEC纠正的接收比特数 |
Rx frames |
接收帧数 |
Rx uncorrectable frames |
FEC无法纠正的接收帧数 |
Tx bits |
发送比特数 |
Tx FEC corrected bits |
FEC纠正的发送比特数 |
Tx frames |
发送帧数 |
Tx uncorrectable frames |
FEC无法纠正的发送帧数 |
display transceiver eyediagram-diagnosis命令用来诊断可插拔光模块,并以眼图的形式显示诊断信息。
display transceiver eyediagram-diagnosis interface [ interface-type interface-number ]
interface [ interface-type interface-number ]:诊断接口上插入的可插拔光模块,并以眼图的形式显示诊断信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
本命令是用于模仿专业检测仪器测试数据传输的质量,通过获取芯片上接收数据的采样值,以眼图的形式输出可插拔光模块的诊断结果,方便用户分析和评估可插拔光模块的数据传输质量。
通过眼图分析可插拔光模块的数据传输质量的简要方法:
· 眼睛区域越大,眼睛形状越清晰,表明数据传输信号越稳定,质量越好。眼睛区域是位于中心线(即0mV线)上下的空白区域。
· 眼睛区域中没有数字,表明数据传输质量好;眼睛区域中存在数字,表明数据传输质量不好。
· 仅如下单板支持以眼图的形式显示诊断信息:
¡ LSCM2系列SC单板
¡ SD系列接口板
¡ SF系列接口板
# 诊断接口Ten-GigabitEthernet3/0/1上插入的可插拔光模块,并以眼图的形式输出诊断结果。
<Sysname> display transceiver eyediagram-diagnosis interface ten-gigabitethernet 3/0/1
This operation might consume a large amount of system resources. It might cause unknown risks and might take several minutes. Continue?[Y/N]:y
| EYESCAN Phy: 0x0e1 lane_mask: 0x01 |
Each character N represents approximate error rate 1e-N at that location
UI/64 : -30 -25 -20 -15 -10 -5 0 5 10 15 20 25 30
128mV : 111111111111111111111111112222322222222211111111111111111111111
124mV : 111111111111111111111111122233332222222221111111111111111111111
120mV : 111111111111111111111111222333333332222222211111111111111111111
115mV : 111111111111111111111112223334443333222222221111111111111111111
111mV : 111111111111111111111122233344444333322222222111111111111111111
107mV : 111111111111111111111122233445544433332222222211111111111111111
103mV : 111111111111111111111222334456655544333332222222111111111111111
99mV : 111111111111111111112223344566665544433333222222211111111111111
95mV : 11111111111111111111222344556776655443333322222221111111111111
91mV : 11111111111111111112223345567 :766554443333222222111111111111
86mV : 11111111111111111122233455677 : 76655444333322222211111111111
82mV : 111111111111111111223344567----+---7665544433322222221111111111
78mV : 111111111111111112223345667 : :76655444333222222111111111
74mV : 11111111111111112223345677: : :77665544333322222111111111
70mV : 1111111111111111223344567 7 : : 76655443332222211111111
66mV : 1111111111111112223345677 : : : 7665444333222221111111
62mV : 111111111111112223345667--+----+----+----+776554433322222111111
57mV : 111111111111112223445677 : : : :76655443332222111111
53mV : 1111111111111222334566 : : : : 7765544333222211111
49mV : 1111111111112223345567 : : : : 76554333222221111
45mV : 111111111111222334567: : : : : :7655443322222111
41mV : 111111111112223345677+----+----+----+----+----+7765544332222211
37mV : 11111111112223344567 : : : : : :776544333222211
33mV : 11111111112223345667 : : : : : : 7654433322221
28mV : 1111111112223344567 : : : : : : 7765443322222
24mV : 111111111222334567 : : : : : : 765543332222
20mV : 111111112223345567---+----+----+----+----+----+----+76544333222
16mV : 11111112222344567 : : : : : : :7654433222
12mV : 1111111222334567: : : : : : : :77655433322
8mV : 1111112223344567: : : : : : : : 765543322
4mV : 111111222334566 : : : : : : : : 776544332
0mV : 111111222344567-+----+----+----+----+----+----+----+----6554332
-4mV : 111111222344567 : : : : : : : : 76544332
-8mV : 111111222334567 : : : : : : : : 765443332
-12mV : 1111112223344567: : : : : : : :7655433322
-16mV : 1111111222334567: : : : : : : :7654433222
-20mV : 11111112222344567----+----+----+----+----+----+----776544333222
-24mV : 111111112223345677 : : : : : : 765543332222
-28mV : 111111111222334567 : : : : : : 7665443332222
-33mV : 1111111111222344567 : : : : : : 77654433322221
-37mV : 1111111111222334567 : : : : : :766544333222211
-41mV : 11111111111223344567-+----+----+----+----+----+7765544332222211
-45mV : 11111111111222334566 : : : : : 77655443332222111
-49mV : 1111111111112223345677 : : : : 76554433322221111
-53mV : 1111111111111222344567 : : : : 7765544333222221111
-57mV :1111111111111222334567 : : : :77655443332222211111
-62mV : 111111111111112223445677--+----+----+----+776654433332222211111
-66mV : 111111111111111223345567 : : : 7765544333222222111111
-70mV : 1111111111111112223345667 : : : 7655443333222221111111
-74mV :11111111111111112223345667 : : : 766554433322222211111111
-78mV :111111111111111112233445677 : : 776554433322222211111111
-82mV : 111111111111111112223345567----+----766554443332222221111111111
-86mV : 1111111111111111112223345567 : 765544433322222221111111111
-91mV : 11111111111111111112233445667 : 7665444333322222211111111111
-95mV : 111111111111111111122233445667 :7766554433332222222111111111111
-99mV : 111111111111111111112223344566777665544333322222221111111111111
-103mV : 111111111111111111111223334556676655443333222222211111111111111
-107mV : 111111111111111111111222333445565544333322222222111111111111111
-111mV : 111111111111111111111122233444554443333222222221111111111111111
-115mV : 111111111111111111111112223334444433332222222211111111111111111
-120mV : 111111111111111111111111222333444333322222222111111111111111111
-124mV : 111111111111111111111111222233333332222222211111111111111111111
-128mV : 111111111111111111111111122223333322222222111111111111111111111
UI/64 :-30 -25 -20 -15 -10 -5 0 5 10 15 20 25 30
display transceiver health命令用来显示光模块的健康度信息。
display transceiver health interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。不指定该参数,表示所有接口。
# 显示接口Ten-GigabitEthernet3/0/1上插入的可插拔光模块的健康度信息。
[Sysname] display transceiver health interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 transceiver health information:
LinkStatus health: 10
Transceiver health:
Temp. Voltage Bias RX power TX power Total
10 10 10 10 10 10
表1-43 display transceiver health显示信息描述表
Transceiver health |
接口的光模块健康度信息 |
LinkStatus health |
链路健康度,其计算方法与错包率健康度有关: · 当错包率健康度为1时,则链路健康度=1 · 当错包率健康度为2~9时:链路健康度=(接收光功率健康度+丢包率健康度)/2 · 当错包率健康度为10时,则链路健康度=(接收光功率健康度+10)/2+0.5的值取整 |
Temp |
温度健康度 |
Voltage |
电压健康度 |
Bias |
偏置电流健康度 |
RX power |
接收光功率健康度 |
TX power |
发送光功率健康度 |
Total |
接口的光模块总体健康度,计算方式为下方每一个元素健康度乘以对应权重值之和 |
· transceiver health check enable
· transceiver health weight
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
# 显示接口Ten-GigabitEthernet3/0/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface ten-gigabitethernet 3/0/1
显示信息略……。
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet3/0/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface gigabitethernet 3/0/1
显示信息略……。
display transceiver power命令用来显示可插拔光模块的功耗信息。
display transceiver power interface [ interface-type interface-number ]
interface interface-type interface-number:显示接口上插入的可插拔光模块的功耗信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示设备所有可插拔接口模块的功耗。
<Sysname> display transceiver power interface
Interface Transceiver type Current power(w) Max power(w)
XGE3/0/1 100G_BASE_SR4_QSFP28 2.30 3.50
XGE3/0/2 100G_BASE_LR4_QSFP28 2.50 4.00
XGE3/0/3 100G_BASE_ER4_QSFP28 3.51 5.00
XGE3/0/4 Absent -- --
XGE3/0/5 100G_BASE_SR4_QSFP28 -- --
XGE3/0/6 10G_BASE_LR_SFP -- 1.50
10G_BASE_LR_SFP 1.00 --
Current total power : 9.31w
Maximum total Power : 15.5w
# 显示接口Ten-GigabitEthernet3/0/1上插入的可插拔接口模块的功耗。
<Sysname> display transceiver power interface ten-gigabitethernet 3/0/1
XGE3/0/1 10G_BASE_LR_SFP 1.00 1.50
表1-44 display transceiver power命令信息显示描述表
接口简称 |
Transceiver type |
模块类型 |
Current power(w) |
当前功耗,单位为w,精确到0.01w |
Max power(w) |
最大功耗,单位为w,精确到0.01w |
Current total power |
当前总功耗,单位为w,精确到0.01w |
Max total power |
最大总功耗,单位为w,精确到0.01w |
display transceiver status命令用来显示可插拔光模块的状态信息。
display transceiver status interface [ interface-type interface-number ]
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的状态信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
仅可插拔SFP和QSFP系列光模块支持本命令。
# 显示接口HundredGigE1/0/1上插入的可插拔QSFP系列光模块的状态信息。
<Sysname> display transceiver status interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver status information:
Module state : ModuleReady
Interrupt : YES
Lane Data Path State Media Lane State
Lane1 Activated Enable
Lane2 Activated Enable
Lane3 Activated Enable
Lane4 Activated Enable
Lane5 Activated Enable
Lane6 Activated Enable
Lane7 Activated Enable
Lane8 Activated Enable
表1-45 display transceiver status命令显示信息描述表
interface-name transceiver status information |
接口interface-name上插入的可插拔光模块的状态信息 |
Module state |
光模块的状态,取值为: · ModuleLowPwr:表示低功率状态 · ModulePwrUp:表示上电状态 · ModuleReady:表示就绪状态 · ModulePwrDn:表示断电状态 · Fault state:表示故障状态 · UNKONWN:表示未知状态 |
Interrupt |
光模块当前是否存在中断告警,取值为: · YES:表示处于中断告警态 · NO:表示未处于中断告警状态 |
Data Path State |
数据路径的状态,取值为: · UNKNOWN:表示未知状态 · Deactivated:表示未激活状态 · Init:表示初始化状态 · Deinit:表示未初始化状态 · Activated:表示激活状态 · TxTurnOn:表示Tx端打开状态 · TxTurnOff:表示Tx端关闭状态 · Initialized:表示初始化完成状态 |
Lane |
数据通道 |
Media Lane State |
光模块光通道的状态,取值为: · Enable:表示开启状态 · Disable:表示关闭状态 |
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
显示信息略……。
display version-update-record命令用来显示启动软件包版本更新操作的记录。
仅缺省MDC支持本命令。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1 (updated on Apr 18 2015 at 06:23:54):
*Name : boot-test.bin
Version : 7.1.070 Test 0001
Compile time: Mar 25 2015 15:52:43
*Name : system-test.bin
表1-46 display version-update-record命令显示信息描述表
Record n (updated on Apr 18 2014 at 06:23:54) |
最近的第n次更新时间,最多显示10次。Record 1为最新的一次更新 |
*Name |
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化 |
Version |
软件包的版本号 |
Compile time |
版本编译时间 |
· reset version-update-record
display xbar命令用来显示主控板的负载模式。
(独立运行模式)
display xbar
display xbar [ chassis chassis-number ]
chassis chassis-number:用来显示指定成员设备上主用主控板和备用主控板的负载模式。chassis-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的对应信息。(IRF模式)
仅缺省MDC支持本命令。
配置的负载模式和当前运行的负载模式不一定相同。只有主用主控板和备用主控板同时在位时,配置的负载分担模式才会生效;否则,即便配置了负载分担模式,主用主控板也会自动切换到独立负载模式。
对于S7503X-G、S7503X-M-G设备,当前显示信息无效。
# 显示设备主用主控板和备用主控板的负载模式。(独立运行模式)
<Sysname> display xbar
The configured system HA xbar load mode is BALANCE
The activated system HA xbar load mode is SINGLE
以上显示信息表明:当前系统配置的负载模式为负载分担模式,但实际生效的是独立负载模式。
· xbar
fabric multicast-forwarding mode命令用来配置组播转发模式。
undo fabric multicast-forwarding mode命令用来恢复缺省情况。
fabric multicast-forwarding mode { enhanced | standard }
组播转发模式为标准模式。
enhanced:配置组播转发模式为增强模式。
standard:配置组播转发模式为标准模式。
本功能需要保持配置并重启设备才能生效。
当跨单板转发的组播流量较大时,建议将设备的组播转发模式配置为enhanced模式。
S7503X-G、S7503X-M-G不支持配置组播转发模式。
仅缺省MDC中支持配置组播转发模式。
在组成IRF的所有设备上,组播转发模式(通过fabric multicast-forwarding mode命令配置)配置必须相同,否则这些设备将无法组成IRF。关于IRF的详细介绍,请参见“虚拟化技术配置指导”中的“IRF”。
配置组播转发模式为enhanced模式前,请先确认:
· 设备上已配置聚合负载分担采用本地转发优先功能。关于聚合负载分担采用本地转发优先功能的详细介绍,请参见“二层技术-以太网交换配置指导”中的“以太网链路聚合”。
· IRF链路两端的IRF物理端口所在单板丝印以及单板上端口号必须相同。关于IRF的详细介绍,请参见“虚拟化技术配置指导”中的“IRF”。
LSCM1GT48SC0单板不支持配置组播转发模式。
在增强模式下使用三层组播功能时,需要在对应VLAN内使能二层组播。
# 将组播转发模式配置为增强模式。
[Sysname] fabric multicast-forwarding mode enhanced
Are you sure you want to change the forwarding mode for multicast packets between internal interfaces? [Y/N]:y
Multicast forwarding mode changed. For the change to take effect, save the running configuration and reboot the device.
fan speed命令用来配置风扇的转速模式。
undo fan speed命令用来恢复缺省情况。
fan speed { auto | high | low | medium }
undo fan speed
fan speed chassis chassis-number { auto | high | low | medium }
undo fan speed chassis chassis-number
chassis chassis-number:表示设备在IRF中的成员编号(IRF模式)
auto:配置风扇的转速模式为自动模式。
high:配置风扇的转速模式为高速模式。
low:配置风扇的转速模式为低速模式。
medium:配置风扇的转速模式为中速模式。
在设备温度过高时,可以通过调节设备风扇的转速来增强散热,避免设备因温度过高而损坏。若风扇噪音过大时,也可以通过调节设备风扇的转速来降低噪音。
· 自动模式:设备可以根据运行环境的变化自动调节风扇速度,以维持最佳的散热效果。
· 手动模式:允许用户根据具体需求自定义风扇速度。可以选择将风扇的转速设置为低速模式、中速模式或高速模式。
当配置设备风扇的转速模式为手动模式时,风扇将无法自行调节速度。请确保机房和设备的通风散热效果良好。
# 配置风扇的转速模式为高速模式。(独立运行模式)
[Sysname] fan speed high
· display fan
forward-flow-mode命令用来配置设备跨板转发单条数据流的工作模式。
forward-flow-mode { standard | enhanced }
设备跨板转发单条数据流的工作模式为标准模式。
standard:配置设备跨板转发单条数据流的工作模式为标准模式。
enhanced:配置设备跨板转发单条数据流的工作模式为增强模式。
为了提升数据流的转发效率,可以配置设备跨板转发单条数据流的工作模式为enhanced模式。该模式支持更高的跨板转发单条数据流的速率。
当设备需要转发的单条数据流速率大于或等于设备支持的单条数据流最大速率时,在标准模式下,设备需要使用多条数据流通道进行数据转发。在enhanced模式下,设备提高了跨板转发单条数据流的最大速率,减少了对多条数据流通道的需求,从而提升了设备的数据转发效率。
当设备包含多个插槽时,若仅部分插槽支持本命令,则该命令在这些插槽上生效。不支持该命令的插槽不会改变其原有的工作模式。
更改设备跨板转发单条数据流的工作模式后,要使配置生效,必须重启设备。
仅缺省MDC支持本命令。
# 配置设备跨板转发单条数据流的工作模式为enhanced模式。
[Sysname] forward-flow-mode enhanced
forward-path-detection enable命令用来开启转发通道自动检测功能。
undo forward-path-detection enable命令用来关闭转发通道自动检测功能。
转发通道自动检测功能处于开启状态。
转发通道自动检测功能可以检测设备中的数据转发通道是否正常。如果不正常,会打印日志信息提醒用户。
仅缺省MDC支持本命令。
# 开启转发通道自动检测功能。
[Sysname] forward-path-detection enable
hardware-alarm disable命令用来关闭硬件资源告警的发送功能。
hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-port | device | disk | fan | interface | power | subcard | transceiver | voltage } disable
undo hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-port | device | disk | fan | interface | power | subcard | transceiver | voltage } disable
所有硬件资源告警的发送功能处于开启状态。
all:所有硬件资源告警信息的发送功能。
bus:与总线相关的资源告警信息的发送功能。
chip-channel:与芯片通道相关的资源告警信息的发送功能。
chip-port:与芯片端口相关的资源告警信息的发送功能。
device:与设备相关的资源告警信息的发送功能。
disk:与磁盘相关的资源告警信息的发送功能。
fan:与风扇相关的资源告警信息的发送功能。
interface:与接口相关的资源告警信息的发送功能。
syslog:硬件资源告警日志信息的发送功能。
Subcard:与子卡相关的资源告警信息的发送功能。
transceiver:与光模块相关的资源告警信息的发送功能。
trap:硬件资源告警Trap信息的发送功能。
power:与电源相关的资源告警信息的发送功能。
voltage:与电压相关的资源告警信息的发送功能。
# 关闭所有硬件的资源告警Trap信息的发送功能。
<Sysname> system
[Sysname] hardware-alarm trap resource-type all disable
# 关闭与设备相关的资源告警日志信息的发送功能。
<Sysname> system
[Sysname] hardware-alarm syslog resource-type device disable
hardware-failure-detection命令用来配置当系统检测到硬件故障时自动采取的修复操作。
undo hardware-failure-detection命令用来恢复缺省情况。
hardware-failure-detection { board | chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { board | chip | forwarding }
当系统检测到器件(chip)、单板(board)和转发(forwarding)的硬件故障时,修复操作均为reset。
board:对单板故障进行在线检测,包括控制通道检测和单板状态快速检测。
chip:对器件故障进行在线检测,包括单板上各种器件(比如芯片、电容、电阻等)的检测。
forwarding:对转发层面的故障进行在线检测,包括业务自动检测和其他转发相关的检测。
isolate:检测到故障时,设备会自动隔离单板、禁止单板加载或给单板下电,从而尽量减小故障的影响。
off:检测到故障时,设备不进行任何操作。
reset:检测到故障时,设备会自动重启器件/单板以尝试修复故障。
warning:检测到故障时,设备发送Trap信息,若控制通道检查到单板故障,则会重启单板并尝试修复故障。
仅缺省MDC支持本命令。
设备启动后,系统会持续自动检测器件、单板和转发的硬件故障。
# 配置系统检测到器件故障时自动告警。
[Sysname] hardware-failure-detection chip warning
hardware-mode命令用来配置硬件的工作模式。
undo hardware-mode命令用来恢复缺省情况。
hardware-mode { bfd | stamp }
undo hardware-mode
硬件的工作模式为BFD模式。
bfd:硬件的工作模式为BFD模式。
stamp:硬件的工作模式为STAMP模式。
设备支持硬件BFD(Bidirectional Forwarding Detection,双向转发检测)和NQA STAMP(Simple Two-Way Active Measurement Protocol,简单双向主动测量协议)功能,但同一时刻,资源只能分配给其中一个功能使用。当硬件的工作模式设为BFD模式时,可以处理硬件BFD会话;当硬件的工作模式设为STAMP模式时,可以处理NQA STAMP会话。
硬件BFD的相关介绍请参见“可靠性配置指导”中的“BFD”。
NQA STAMP的相关介绍请参见“网络管理和监控配置指导”中的“NQA”。
在开启接口的STAMP功能前,请将硬件的工作模式切换为STAMP模式。
如果需要切换硬件的工作模式为BFD模式,请先执行undo nqa stamp ipv4 enable命令,关闭所有接口的STAMP功能。
当切换硬件的工作模式时,可能会导致BFD及其相关协议震荡。
# 配置硬件的工作模式为STAMP模式。
[Sysname] hardware-mode stamp
The current operation will cause a flapping issue on all BFD sessions and their associated protocols. Continue? [Y/N]:y
· nqa stamp ipv4 enable
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
· scheduler job
· scheduler schedule
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value [ early-warning early-warning-value secure secure-value ]
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
对于不同主控板缺省情况不同,可以通过display memory命令查看当前设备的内存告警门限值信息。
ratio:表示以百分比形式配置门限。不指定该参数时,表示配置的是门限的大小,单位为MB。
minor minor-value:一级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
severe severe-value:二级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
critical critical-value:三级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小。输入该参数的值时可通过输入?,来获取该参数的取值范围。
early-warning early-warning-value:预告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级别的告警功能。
secure secure-value:预告警恢复门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
仅缺省MDC支持本命令。
系统实时监控剩余空闲内存大小,当条件达到一级、二级、三级告警门限或者恢复正常状态门限时,就产生相应的告警/告警解除通知,通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
设备监控的是系统内存中剩余空闲内存的大小,使用display memory命令可以查看系统内存的使用情况。
除了一级、二级、三级告警,设备还支持预告警功能。预告警门限用于内存使用率尚处于正常范围内,但需要提醒用户提前关注内存的情况。预告警恢复门限用于解除预告警。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
满足以下条件时,系统会重启单板。
· 产生三级告警后,剩余空闲内存值持续小于三级告警门限,其时长到达30秒,则系统会重启单板。
· 如果连续产生两次三级告警的时间间隔小于30秒,则系统会重启单板。
· 如果3分钟内产生三次三级告警,则系统会重启单板。
· 产生三级告警后,系统将会周期采样,预测剩余空闲内存是否会在30秒之内耗尽,如果预测结果为会在30秒之内耗尽,则系统会重启单板。
系统监控到剩余空闲内存值达到一级、二级、三级告警门限以及预告警门限后,用户在Console或Telnet登录设备,以及执行每条命令时,都会显示当前内存使用情况。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# 配置一级、二级、三级告警门限分别为设备总内存的3%、2%、1%,当剩余空闲内存大于设备总内存的5%时,恢复到正常状态。
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
· display memory-threshold
memory-threshold dma命令用来配置DMA(Direct Memory Access,直接内存存取)内存告警阈值。
undo memory-threshold dma命令用来恢复缺省情况。
(独立运行模式)
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
DMA内存告警阈值为2048KB,告警恢复阈值为4096KB
cpu cpu-number:表示CPU的编号。
ratio:以百分比配置阈值。
critical critical-value:告警阈值。当指定ratio参数时,critical-value为百分比,取值范围为0~100;当不指定ratio参数时,critical-value单位为KB。
normal normal-value:告警恢复阈值。当指定ratio参数时,normal-value为百分比;当不指定ratio参数时,normal-value单位为KB。设备会根据critical-value的配置值自动调整normal-value的取值范围,请以设备的实际情况为准。
部分业务的运行需要使用DMA内存,如果DMA内存不足,会导致业务模块功能异常。系统周期监控DMA空闲内存大小:当DMA空闲内存小于或等于告警阈值,产生告警事件,表示DMA内存可能不足;当DMA空闲内存大于告警恢复阈值,产生告警解除事件,表示DMA内存充足。
# 配置Slot 1的DMA内存告警的阈值为32KB,告警恢复阈值为96KB。(独立运行模式)
[Sysname] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主用主控板。(独立运行模式)
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
仅缺省MDC支持本命令。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
(独立运行模式)
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(独立运行模式)
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
· display cpu-usage configuration
· display cpu-usage history
· monitor cpu-usage interval
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
undo monitor cpu-usage interval命令用来恢复缺省情况。
(独立运行模式)
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
· monitor cpu-usage enable
monitor cpu-usage logging interval命令用来开启周期性输出CPU利用率日志功能。
undo monitor cpu-usage logging interval命令用来关闭周期性输出CPU利用率日志功能。
monitor cpu-usage logging interval interval-time
周期性输出CPU利用率日志功能处于关闭状态。
interval-time:周期性输出CPU利用率日志的时间间隔,取值为5~300中5的整数倍,单位为秒。
# 开启周期性输出CPU利用率日志信功能,且时间间隔为60秒。
[Sysname] monitor cpu-usage logging interval 60
monitor cpu-usage threshold命令用来配置CPU利用率告警门限。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
(独立运行模式)
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] | slot slot-number cpu cpu-number [ core core-id-list ] }
undo monitor cpu-usage threshold { minor-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] | slot slot-number cpu cpu-number [ core core-id-list ] }
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | chassis chassis-number slot slot-number cpu cpu-number [ core core-id-list ] }
undo monitor cpu-usage threshold { minor-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | chassis chassis-number slot slot-number cpu cpu-number [ core core-id-list ] }
CPU利用率高级别告警门限为99%,CPU利用率低级别告警门限为80%,CPU利用率恢复门限为60%。
severe-threshold:CPU利用率高级别告警门限,取值范围为2~100,单位为百分比。
minor-threshold minor-threshold:CPU利用率低级别告警门限,取值范围为1~“severe-threshold的配置值减1”,单位为百分比。
recovery-threshold recovery-threshold:CPU利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。
core core-id-list:表示CPU核的编号列表。表示方式为core-id-list = { core-id1 [ to core-id2 ] }&<1-10>,core-id2的值要大于或等于core-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
系统每隔1分钟会对CPU以及CPU核的利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为利用率过高,设备会进行相应的处理。
# 配置CPU利用率高级别告警门限为90%,低级别告警门限为80%,恢复门限为70%。
[Sysname] monitor cpu-usage threshold 90 minor-threshold 80 recovery-threshold 70
monitor handshake-timeout disable-port命令用于全局开启Port Down功能。
undo monitor handshake-timeout disable-port命令用于全局关闭Port Down功能。
缺省情况下,Port Down功能处于开启状态。
【描述】
本功能常用于以主备方式提供网络可靠性的双机环境中(例如VRRP)。开启本功能后,当主设备的主控板被拔出或异常重启时,系统将立即关闭主设备上的所有业务口,使业务快速切换到备用设备上。
该功能配置成功后,只有当当前设备上已没有可用的主控板时才生效。
# 全局开启Port Down功能。
[Sysname] monitor handshake-timeout disable-port
Set successfully!
monitor memory-usage logging interval命令用来开启周期性输出内存利用率日志功能。
undo monitor memory-usage logging命令用来关闭周期性输出内存利用率日志功能。
monitor memory-usage logging interval interval-time
undo monitor memory- usage logging interval
周期性输出内存利用率日志功能处于关闭状态。
interval-time:周期性输出内存利用率日志的时间间隔,取值为5~300中5的整数倍,单位为秒。
# 开启周期性输出内存利用率日志信功能,且时间间隔为60秒。
[Sysname] monitor memory-usage logging interval 60
monitor resend cpu-usage命令用来配置发送CPU告警事件的间隔。
undo monitor resend cpu-usage命令用来取消CPU告警事件发送间隔的配置。
(独立运行模式)
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
monitor resend cpu-usage { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU高级别告警事件。
minor-interval minor-interval:CPU低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,CPU将进入该级别告警状态并生成相应的告警事件。
CPU处于低级别告警状态时,会周期发送CPU低级别告警事件,直到CPU进入高级别告警状态或者低级别告警状态解除。CPU处于高级别告警状态时,会周期发送CPU高级别告警事件,直到高级别告警状态解除。使用本命令可以修改CPU告警事件的发送周期。
执行undo monitor resend cpu-usage命令不指定minor-interval和severe-interval参数时,表示将这两个参数恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0低级别告警事件的发送周期为60秒。(独立运行模式)
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend memory-threshold命令用来配置发送内存告警事件的间隔。
undo monitor resend memory-threshold命令用来取消内存告警事件发送间隔的配置。
(独立运行模式)
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
monitor resend memory-threshold { critical-interval critical-interval | early-warning-interval early-warning-interval | minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续1小时超过预告警门限则上报一次预告警事件通知,持续12小时超过一级告警门限则上报一次一级告警事件通知,持续3小时超过二级告警门限则上报一次二级告警事件通知,持续1小时超过三级告警门限则上报一次三级告警事件通知。
critical-interval critical-interval:内存三级告警事件周期发送的间隔,取值范围1~48,单位为小时。
early-warning-interval early-warning-interval:内存预告警事件周期发送的间隔,取值范围1~48,单位为小时。
minor-interval minor-interval:内存一级告警事件周期发送的间隔,取值范围1~48,单位为小时。
severe-interval severe-interval:内存二级告警事件周期发送的间隔,取值范围1~48,单位为小时。
设备定期对内存剩余值进行采样,并将采样值与告警门限进行比较。当采样值从大于变成小于或等于某级别告警门限时,内存将进入该级别告警状态并生成相应的告警事件。
内存支持多个级别的告警,这些告警的严重程度从高到低依次为:内存三级告警、内存二级告警、内存一级告警、内存预告警。
内存处于低级别告警状态时,会周期发送内存低级别告警事件,直到设备进入更高级别告警状态或者低级别告警状态解除。内存处于高级别告警状态时,会周期发送内存高级别告警事件,直到高级别告警状态解除。使用本命令可以修改内存告警事件的发送周期。
执行undo monitor resend memory-threshold命令并不指定critical-interval、early-warning-interval、minor-interval和severe-interval参数时,表示将这些参数均恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0内存一级告警事件的发送周期为12小时。(独立运行模式)
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
parity-error consistency-check log enable命令用来开启软硬件表项一致性检查日志信息功能。
undo parity-error consistency-check log enable命令用来关闭软硬件表项一致性检查日志信息功能。
软硬件表项一致性检查日志信息功能处于开启状态。
设备在运行过程中,会对转发芯片中的硬件表项和软件表项进行一致性检查。配置本命令后,在采样周期内,如果检查软硬件表项的不一致次数达到通过parity-error consistency-check threshold命令配置的错误次数阈值,则生成软硬件表项一致性检查日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启软硬件表项一致性检查日志信息功能。
[Sysname] parity-error consistency-check log enable
· parity-error consistency-check threshold
· parity-error consistency-check period
parity-error consistency-check period命令用来配置软硬件表项一致性检查错误日志的发送周期。
undo parity-error consistency-check period命令用来恢复缺省情况
parity-error consistency-check period value
软硬件表项一致性检查错误日志的发送周期为3600秒。
value:表示软硬件表项一致性检查错误日志的发送周期,取值范围为600~31536000,单位为秒。
设备在运行过程中,会同时在转发芯片中生成硬件表项以及CPU内存中生成软件镜像表项用于指导报文转发。设备会自动检测这两个表项是否一致。配置本命令后,设备会按周期收集软硬件表项一致性检查错误发生的次数。建议将周期设置为大于3600秒。
# 配置软硬件表项一致性检查错误的日志发送周期为600秒。
[Sysname] parity-error consistency-check period 600
· parity-error consistency-check log enable
parity-error consistency-check threshold命令用来配置软硬件表项一致性检查的错误次数阈值。
undo parity-error consistency-check threshold命令用来恢复缺省情况。
parity-error consistency-check threshold value
软硬件表项一致性检查的错误次数阈值为10次。
value:表示软硬件表项一致性检查的错误次数阈值,取值范围为1~2147483647,单位为次数。
在开启软硬件表项一致性检查日志信息功能后,配置本命令后,设备在软硬件表项一致性检查错误次数的采样周期内,当检查到软硬件表项不一致的错误次数达到配置的阈值时,会生成软硬件表项一致性检查日志信息。
# 配置软硬件表项一致性检查的错误次数阈值为20次。
[Sysname] parity-error consistency-check threshold 20
parity-error monitor log enable命令用来开启硬件表项奇偶校验和ECC校验日志信息功能。
undo parity-error monitor log enable命令用来关闭硬件表项奇偶校验和ECC校验日志信息功能。
硬件表项奇偶校验和ECC校验日志信息功能处于开启状态。
设备在运行过程中,会自动对转发芯片中硬件表项进行奇偶校验和ECC校验,并记录错误次数。配置本命令后,在通过parity-error monitor period命令配置的采样周期内,如果硬件表项的奇偶校验和ECC校验的错误次数达到通过parity-error monitor threshold命令配置的错误次数阈值,则生成硬件表项奇偶校验和ECC校验日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启硬件表项奇偶校验和ECC校验日志信息功能。
[Sysname] parity-error monitor log enable
· parity-error monitor period
· parity-error monitor threshold
parity-error monitor period命令用来配置硬件表项奇偶校验和ECC校验错误次数的采样周期。
undo parity-error monitor period命令用来恢复缺省情况。
parity-error monitor period period
硬件表项奇偶校验和ECC校验错误次数的采样周期为60秒。
period:表示硬件表项奇偶校验和ECC校验错误次数的采样周期,取值范围为1~86400,单位为秒。
在开启硬件表项奇偶校验和ECC校验日志信息功能后,配置本命令后,设备在配置的硬件表项内,当硬件表项奇偶校验和ECC校验的错误次数达到阈值时,会生成硬件表项奇偶校验和ECC校验日志信息。
# 配置奇偶校验和ECC校验错误次数的采样周期为120秒。
[Sysname] parity-error monitor period 120
· parity-error monitor log enable
parity-error monitor threshold命令用来配置硬件表项奇偶校验和ECC校验的错误次数阈值。
undo parity-error monitor threshold命令用来恢复缺省情况。
parity-error monitor threshold value
硬件表项奇偶校验和ECC校验的错误次数阈值为5000次。
value:表示硬件表项奇偶校验和ECC校验的错误次数阈值,取值范围为1~1000000,单位为次数。
在开启硬件表项奇偶校验和ECC校验日志信息功能后,配置本命令后,设备在硬件表项奇偶校验和ECC校验错误次数的采样周期内,当校验错误次数达到配置的阈值时,会生成硬件表项奇偶校验和ECC校验日志信息。
# 配置硬件表项奇偶校验和ECC校验的错误次数阈值为8000次。
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable命令用来开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
undo parity-error unrecoverable log enable命令用来关闭关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能处于开启状态。
设备在运行过程中,会对转发芯片中的硬件表项进行奇偶校验和ECC校验。在硬件表项奇偶校验和ECC校验发现错误时,会尝试恢复这些错误。配置本命令后,当一些关键硬件表项的校验错误不可恢复时,在通过parity-error unrecoverable period命令配置的采样周期内,如果关键硬件表项的校验错误不可恢复的次数达到通过parity-error unrecoverable threshold命令配置的不可恢复次数阈值,则会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
[Sysname] parity-error unrecoverable log enable
· parity-error unrecoverable period
· parity-error unrecoverable reboot
· parity-error unrecoverable threshold
parity-error unrecoverable period命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期。
undo parity-error unrecoverable period命令用来恢复缺省情况。
parity-error unrecoverable period period
关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为60秒。
period:表示关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期,取值范围为1~86400,单位为秒。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在配置的采样周期内,当关键硬件表项奇偶校验和ECC校验错误的不可恢复次数达到阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为120秒。
[Sysname] parity-error unrecoverable period 120
· parity-error unrecoverable log enable
parity-error unrecoverable reboot命令用来开启生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后单板自动重启功能。
undo parity-error unrecoverable reboot命令用来关闭生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后单板自动重启功能。
生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后单板自动重启。
如果单板转发芯片上关键硬件表项发生奇偶校验和ECC校验错误,且不可恢复时,可能会影响业务正常进行,则需要配置本命令,使单板通过重启来恢复关键硬件表项。
配置本命令后,当单板生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后,将自动重启。
# 开启生成关键硬件表项不可恢复日志信息后单板的自动重启功能。
[Sysname] parity-error unrecoverable reboot
parity-error unrecoverable threshold命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值。
undo parity-error unrecoverable threshold命令用来恢复缺省情况。
parity-error unrecoverable threshold value
关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为1。
value:表示关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值,取值范围为1~1000000,单位为次数。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期内,当校验错误不可恢复次数达到配置的阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为10。
[Sysname] parity-error unrecoverable log threshold 10
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
仅缺省MDC支持本命令。
清除认证密码的操作必须在主用主控板的启动过程中进入BootWare菜单进行。(独立运行模式)(IRF模式)
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见设备的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
power turn-off命令用来关闭电源供电功能。
power turn-off [ power-id power-id-list ]
power turn-off [ chassis chassis-number [ power-id power-id-list ] ]
电源模块处于开启状态
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有电源。(IRF模式)
power-id power-id-list:表示电源模块的编号列表。表示方式为power-id-list = { power-id1 [ to power-id2 ] }&<1-16>,power-id2的值要大于或等于power-id1的值,&<1-16>表示前面的参数最多可以重复输入16次。不指定该参数时,表示指定位置的所有电源。
设备提供自动节能和冗余功能,可以根据设备的实际用电情况,自动关闭电源。如果设备未配置自动节能和冗余电源功能,用户可以手工关闭指定位置的电源。
如果设备使能冗余电源功能,可以使用redundant-power energy-saving disable命令关闭多余电源的节能功能。
请在专业人士的指导下配置本命令。配置本命令可能会导致设备功率不足,从而引起整个设备断电。
手工给电源模块断电为一次性操作。执行本命令后不保存配置,重启后电源将恢复为上电状态。
# 关闭电源模块编号为1到3的电源开关。(独立运行模式)
<Sysname> power turn-off power-id 1 to 3
This operation might power off the device. Continue?[Y/N]:y
· display power
power turn-on命令用来开启电源供电功能。
power turn-on [ power-id power-id-list ]
power turn-on [ chassis chassis-number [ power-id power-id-list ] ]
未配置电源开关功能
设备提供自动节能和冗余功能,可以根据设备的实际用电情况,自动开启电源。如果设备未配置自动节能和冗余电源功能,用户可以手工开启指定位置的电源。
# 开启电源模块编号为1到3的电源开关。(独立运行模式)
<Sysname> power turn-on power-id 1 to 3
This operation might power on the device. Continue?[Y/N]:y
· display power
power-supply off命令用来强制给单板断电。
(独立运行模式)
power-supply off slot slot-number
power-supply off chassis chassis-number slot slot-number
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
强制给单板下电后,单板将无法收发报文,请谨慎使用。
仅缺省MDC支持本命令。
如果设备电量不足,且某些接口板处于空闲状态或者连接的为非关键网络节点时,可以手工停止给这些接口板供电,以便节约电能保证给重要接口板供电。
请先开启电源管理功能,再配置本命令。否则,本命令配置失败。
在IRF中,当最后一个处于up状态的IRF物理端口都位于某接口板上时,不允许强制给该接口板断电,以免导致IRF分裂。(IRF模式)
手工给单板断电为一次性操作。执行本命令后不保存配置,重启后单板将恢复为上电状态。
主控板不支持配置本命令。
# 强制给指定slot的单板断电。(独立运行模式)
<Sysname> power-supply off slot 2
· power-supply policy enable
power-supply on命令用来手工给单板供电。
(独立运行模式)
power-supply on slot slot-number
power-supply on chassis chassis-number slot slot-number
仅缺省MDC支持本命令。
# 手工给指定slot的单板供电。(独立运行模式)
<Sysname> power-supply on slot 2
power-supply policy enable命令用来开启电源管理功能。
undo power-supply policy enable命令用来关闭电源管理功能。
(独立运行模式)
power-supply policy chassis chassis-number enable
undo power-supply policy chassis chassis-number enable
电源管理功能处于关闭状态。
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
仅缺省MDC支持本命令。
# 启用电源管理功能。(独立运行模式)
[Sysname] power-supply policy enable
power-supply policy priority命令用来配置单板的供电优先级。
undo power-supply policy priority命令用来恢复缺省情况。
(独立运行模式)
power-supply policy slot slot-number priority priority
undo power-supply policy slot slot-number priority
power-supply policy chassis chassis-number slot slot-number priority priority
undo power-supply policy chassis chassis-number slot slot-number priority
接口板的供电优先级为5。
priority:单板的供电优先级,取值范围为0~10。本参数值越小表示单板的供电优先级越高。
仅缺省MDC支持本命令。
仅业务板支持本命令。
请根据实际组网应用,将正在处理或将要处理重要业务的单板的优先级值减小,以便在系统供电不足或者电力恢复时,优先保证对该单板的供电。
系统会自动保证IRF物理接口所在的接口板的供电优先级:
· 将接口板上的接口和IRF端口绑定后,系统会自动提高该接口板的供电优先级,不再支持手工配置。
· 用户配置接口板的供电优先级,再将接口板上的接口和IRF端口绑定后,接口板的供电优先级配置会继续存在但不生效。
开启电源管理功能后,本命令才会生效。
# 配置指定slot的单板的供电优先级为10。(独立运行模式)
[Sysname] power-supply policy slot 2 priority 10
power-supply policy redundant命令用来配置冗余电源模块数。
undo power-supply policy redundant命令用来恢复缺省情况。
(独立运行模式)
power-supply policy redundant module-count
power-supply policy chassis chassis-number redundant module-count
undo power-supply policy chassis chassis-number redundant
配置的冗余电源模块数为0。
module-count:表示冗余电源模块数目,不同型号的设备支持的取值范围不同,用户可以通过帮助信息来获取设备支持的取值范围,但是该范围的上限是系统支持的最大冗余模块数,根据设备安插的接口板的数量和耗电量不同,用户实际能够配置的值会小于等于系统支持的最大冗余模块数。
仅缺省MDC支持本命令。
只有在开启电源管理功能后,冗余电源配置才会生效。
# 配置电源冗余模块数为1。(独立运行模式)
[Sysname] power-supply policy redundant 1
reboot命令用来重启设备。
(独立运行模式)
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,会重启整个IRF。(IRF模式)
slot slot-number:表示单板所在的槽位号。不指定该参数时,会重启成员设备。(IRF模式)
slot slot-number:表示单板所在的槽位号。不指定该参数时,会重启整个设备。(独立运行模式)
force:强制重启:
· 不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
· 指定该参数时,系统将不进行任何检查,直接执行重启操作。
· 重新启动可能会导致业务中断,请谨慎使用该命令。
· 使用force参数时,系统在重启时不会做任何保护性措施。重启后,可能导致文件系统损坏,请谨慎使用该参数。建议在系统故障或无法正常重启时,才使用该参数。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
(独立运行模式)
重启主用主控板时,如果备用主控板不存在,会重启整个系统;如果备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响系统和单板的运行。可使用display system stable state命令来显示系统的稳定状态。
重启全局主用主控板时,如果全局备用主控板不存在,会重启整个IRF;如果全局备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响IRF和单板的运行。可使用display system stable state命令来显示IRF的稳定状态。
# 重启设备,并保存配置文件。(独立运行模式)
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
· display system stable state
reset asset-info命令用来清除设备的用户资产信息。使用该命令,用户可以清除设备机箱、单板的资产信息。
(独立运行模式)
reset asset-info { chassis | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
reset asset-info chassis chassis-number { chassis | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
chassis:清除设备机箱的用户资产信息。
slot slot-number:清除指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn:清除资产编号信息。
custom:清除用户自定义的资产信息。
department:清除资产的归属部门信息。
description:清除资产的描述信息。
service-date:清除资产的启用时间信息。
state:清除资产的使用状态信息。
chassis chassis-number:清除指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
当用户希望清除设备机箱、单板的具体信息项目(比如资产编号、资产描述信息等)时,只需要选择该信息项目对应的命令行参数;不选择具体信息项目对应的参数时,清除的是该设备机箱、单板的所有用户资产信息。
# 清除设备上0号单板的资产编号信息。(独立运行模式)
[Sysname] reset asset-info slot 0 csn
· display asset-info
· set asset-info
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
仅缺省MDC支持本命令。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
· display scheduler logfile
reset transceiver interface命令用来通过软件复位可插拔光模块。
reset transceiver interface [ interface-type interface-number ]
interface-type interface-number:表示接口类型和接口编号。不指定该参数时,表示所有接口。
当光模块工作异常时,可以通过软件复位光模块来尝试修复光模块。正常情况下,不建议配置。
执行本命令会重启光模块,请谨慎使用。
仅可插拔QSFP系列光模块支持本命令。
# 通过软件复位接口HundredGigE1/0/1上插入的可插拔QSFP28光模块。
<Sysname> reset transceiver interface hundredgige 1/0/1
This operation causes services on the transceiver module to be down for a while. Continue? [Y/N]: Y
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
仅缺省MDC支持本命令。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
· display version-update-record
resource-monitor minor resend enable命令用来开启周期发送低级别资源告警通知功能。
undo resource-monitor minor resend enable命令用来关闭周期发送低级别资源告警通知功能。
周期发送低级别资源告警通知功能处于开启状态。
LSCM1GT48SC0单板不支持本命令。
如果剩余的资源小于或等于低级别告警门限且大于高级别告警门限,则资源进入低级别告警状态,并生成低级别告警通知。
当资源一直处于低级别告警状态时:
· 开启周期发送低级别资源告警通知功能后,第一次达到低级别告警状态时,会生成低级别告警通知,后续还会周期生成低级别告警通知。当剩余资源达到更高级别告警门限时,将会生成更高级别的告警通知,暂时抑制低级别的告警通知。直到高级别的告警状态解除,再周期输出低级别的告警通知。
· 关闭周期发送低级别资源告警通知功能后,只有第一次达到低级别告警状态时,才生成低级别告警通知,不会连续生成低级别告警通知。
高级别告警通知重发功能一直处于开启状态,不能通过命令行配置。
高级别告警通知的重发周期是24小时,低级别告警通知的重发周期是7x24小时,不能配置。
# 开启周期发送低级别资源告警通知功能。
<sysname> system-view
[Sysname] resource-monitor minor resend enable
· display resource-monitor
· resource-monitor output
· resource-monitor resource
resource-monitor output命令用来配置资源告警通知的输出方向。
undo resource-monitor output命令用来关闭资源告警通知的输出方向。
undo resource-monitor output [ netconf-event | snmp-notification | syslog ]*
资源告警通知会同时向NETCONF、SNMP、信息中心三个方向输出。
netconf-event:将资源告警通知输出到NETCONF模块。
syslog:将资源告警通知输出到信息中心模块。
snmp-notification:将资源告警通知输出到SNMP模块。
设备会实时监控一些重要资源的是使用情况,当达到指定门限时,设备会生成对应的资源告警通知,这些通知可以输出到以下三个方向:
· NETCONF模块。通过配置NETCONF模块的参数,可以将资源告警通知以NETCONF事件的形式发送给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
· 信息中心模块。通过配置信息中心模块的参数,可以将资源告警通知以系统日志的形式发送给用户。关于信息中心的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
· SNMP模块。通过配置SNMP模块的参数,可以将资源告警通知以Trap或者Inform消息的形式发送给用户。关于SNMP的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
执行undo resource-monitor output命令,并且不指定可选参数时,表示资源告警通知不会向NETCONF、SNMP、信息中心三个方向输出。
# 将资源告警通知输出到信息中心模块。
[Sysname] resource-monitor output syslog
· resource-monitor minor resend enable
resource-monitor resource命令用来配置生成资源告警通知的门限。
undo resource-monitor resource命令用来取消资源告警通知的门限配置。
(独立运行模式)
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number by-percent minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number
不同类型资源的缺省情况不同,请使用display resource-monitor命令查看。
resource-name:需要监测的资源的名称,不区分大小写,需要完整输入参数的值。参数的取值请参见下表。
表1-47 设备可监测的资源描述表
取值 |
含义 |
agg_group |
聚合组资源 |
agg_member |
聚合组成员端口数 |
arp |
ARP表项资源 |
ecmpgroup |
ECMP组资源 |
egs_acl |
出方向ACL资源 |
egs_counter |
出方向counter资源 |
egs_mqc |
出方向mqc资源 |
egs_pktflt |
出方向pktflt资源 |
host |
主机路由资源 |
igs_acl |
入方向ACL资源 |
igs_counter |
入方向counter资源 |
igs_mqc |
入方向mqc资源 |
igs_openflow |
入方向openflow资源 |
igs_pbr |
入方向pbr资源 |
igs_pktflt |
入方向pktflt资源 |
input_flowrate |
入方向报文速率 |
ipmc |
三层组播复制表资源 |
ipv6 |
IPv6路由表项资源 |
l2mc |
VLAN内组播复制表资源 |
local_mc |
本地复制表资源(组播本地复制表资源池。影响VXLAN隧道可加入的VXLAN数目) |
mac |
MAC地址表项资源 |
meter |
meter资源 |
nd |
ND表项资源 |
nexthoppool1 |
Underlay下一跳资源池资源 |
nexthoppool3 |
局部下一跳资源池资源(组播等本地业务使用的Nexthop资源池) |
openflow |
OpenFlow资源 |
output_flowrate |
出方向报文速率 |
overlay_arp |
Overlay ARP表项资源 |
overlay_nd |
Overlay ND表项资源 |
route |
路由表项资源 |
rport |
三层以太网接口资源 |
stg |
stp实例资源 |
vlaninterface |
VLAN接口资源 |
vrf |
VPN实例资源 |
slot slot-number:表示监测指定单板上的资源。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示监测指定单板上的资源。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
cpu cpu-number:表示监测指定CPU上的资源。cpu-number表示在CPU的编号。
by-percent:以百分比的方式配置告警门限。
minor-threshold minor-threshold:低级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
severe-threshold severe-threshold:高级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
配置本命令后,设备会监测资源的剩余情况,周期采样监测对象的值,并和配置的告警门限进行比较。当达到条件时,设备会生成告警通知。
# 配置slot 1上ARP资源的低级别门限为30%,高级别门限为10%。(独立运行模式)
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
restart standby命令用来重启备用主控板。
restart standby
仅独立运行模式下支持本命令。
仅缺省MDC支持本命令。
执行本命令效果等同于执行reboot slot slot-number(slot-number指定为备用主控板所在的槽位号)。因为无需指定slot参数,所以,使用起来比reboot命令更加便捷。
# 重启备用主控板。
[Sysname] restart standby
Rebooting the standby MPU. Continue?[Y/N]:y
The standby MPU is rebooting. Please wait...
· reboot
restore factory-default命令用来将设备恢复到出厂状态。
使用本命令会将设备恢复到出厂状态,请谨慎使用。
仅缺省MDC支持本命令。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
· reboot
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
· command
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MM。HH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
· YYYY的取值范围为2000~2035;
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
本命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
· 配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
· 配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot at、scheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2015年6月6日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
· scheduler reboot delay
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
· 使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2015年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1) 使用scheduler job命令创建Job。
(2) 在Job视图下,使用command命令配置需要执行的命令。
(3) 使用scheduler schedule命令创建Schedule。
(4) 在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5) 在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6) 在Schedule视图下,使用time at、time once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
· job
· time at
· time once
set asset-info命令用来设置设备的用户资产信息。使用该命令,用户可以根据自定义的规则为设备机箱、单板设置资产信息。
(独立运行模式)
set asset-info { chassis | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
set asset-info chassis chassis-number { chassis | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
chassis:设置设备机箱的用户资产信息。
slot slot-number:设置指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn csn-number:设置资产编号信息。csn-number表示用户设置的资产编号信息,为1~64字节的字符串。
custom name value:设置用户自定义的资产信息。name表示用户自定义的资产信息名称,value表示用户设置的资产信息内容。
department department:设置资产的归属部门信息。department表示用户设置的资产归属部门,为1~64字节的字符串。
description description:设置资产的描述信息。description表示用户设置的资产描述信息,为1~64字节的字符串。
location location:设置资产的位置信息。location表示用户设置的资产位置信息,为1~64字节的字符串。
service-date date:设置资产的启用时间信息。date表示用户设置的资产启用时间,为1~25字节的字符串。
state state:设置资产的使用状态信息。state表示用户设置的资产使用状态,为1~64字节的字符串。
chassis chassis-number:设置指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
# 设置设备上0号单板的资产编号为123456。(独立运行模式)
[Sysname] set asset-info slot 0 csn 123456
· reset asset-info
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动检测端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
在开启环路检测功能的网络中,当环路检测的处理模式被设置为“Shutdown模式”后。若设备检测到端口出现环路,会自动关闭该端口并启动一个检测端口状态的定时器。有关环路检测功能的相关介绍,请参见“二层技术-以太网交换配置指导”中的“环路检测”。
在开启BPDU保护功能的网络中,若边缘端口收到了BPDU,则系统就将这些端口关闭并启动一个检测端口状态的定时器,同时通知网管这些端口已被生成树协议关闭。有关BPDU保护功能的相关介绍,请参见“二层技术-以太网交换配置指导”中的“生成树”。
如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,系统会自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口的时间间隔为T。
· 若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
· 若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被生成树协议关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被生成树协议关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
· loopback-detection action(二层技术-以太网交换命令手册/环路检测)
· loopback-detection global action(二层技术-以太网交换命令手册/环路检测)
· stp bpdu-protection(二层技术-以太网交换命令手册/生成树)
· stp port bpdu-protection(二层技术-以太网交换命令手册/生成树)
switch-mode命令用于配置交换机业务板的工作模式。
undo switch-mode命令用于恢复业务板的工作模式为未配置状态。
(独立运行模式)
switch-mode slot slot-number { balance | bridging | enhance | enhance-balance | enhance-bridging | enhance-routing | flex-flow-high | flex-flow-mid | flex-flow-low | normal [ ipv6-64 | user-acl-enhance ] | routing [ ipv6-64 ] | multicast }
undo switch-mode slot slot-number
switch-mode chassis chassis-number slot slot-number { balance | bridging | enhance | enhance-balance | enhance-bridging | enhance-routing | flex-flow-high | flex-flow-mid | flex-flow-low | normal [ ipv6-64 | user-acl-enhance ] | routing [ ipv6-64 ] | multicast }
undo switch-mode chassis chassis-number slot slot-number
业务板的工作模式为normal。
balance:业务板工作模式为均衡模式。
bridging:业务板工作模式为MAC扩展模式。
enhance:业务板工作模式为增强模式。
enhance-balance:业务板工作模式为增强的均衡模式。
enhance-bridging:业务板工作模式为增强的MAC扩展模式。
enhance-routing:业务板工作模式为增强的路由扩展模式。
flex-flow-high:高FlexFlow模式。
flex-flow-mid:中FlexFlow模式。
flex-flow-low:低FlexFlow模式。
normal:业务板工作模式为普通模式。
user-acl-enhance:业务板工作模式为大acl用户可用资源模式。
routing:业务板工作模式为路由扩展模式。
ipv6-64:业务板工作模式为IPv6路由扩展模式。
multicast:业务板工作模式为组播扩展模式。
slot slot-number:业务板所在槽位号。
chassis chassis-number:表示IRF中设备的成员编号。(IRF模式)
业务板工作模式配置完毕后需保存配置并重启该业务板,所做配置才会生效。
LSCM1GT48SC0业务板只支持配置normal、bridging、routing和balance。
SF系列接口板不支持增强的工作模式。
仅LSCM2系列SC单板、SD系列接口板和SF系列接口板支持user-acl-enhance模式。
LSCM2系列SC单板和SD系列接口板不支持IPv6路由扩展模式。
非实时生效模式(独占模式和私有模式)系统视图下,不支持命令。
# 配置设备2号槽位接口板的工作模式为MAC扩展模式(bridging)。(独立运行模式)
[Sysname] switch-mode bridging slot 2
· display switch-mode status
sysid命令用来配置设备的网元信息。
undo sysid命令用来恢复缺省情况。
sysid system-id
undo sysid
未配置设备的网元信息。
system-id:表示设备的网元信息,可用于表示设备的位置信息、功能信息、用户自定义的名字标记等。
# 配置网元信息为position-hall,表明设备位置在大厅。
[Sysname] sysid positon-hall
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C。
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
system handshake timeout命令用来配置主控板与接口板之间握手的超时时长。
undo system handshake timeout命令用来恢复缺省情况。
system handshake timeout timeout
缺省情况下,设备主控板与接口板之间握手的超时时长为60秒。
timeout:主控板与接口板之间一次握手的超时时长。取值范围为10~60,单位为秒。
接口板启动完成后,会主动向主控板注册,以便接受主控板的管理。在设备运行期间,主控板会定期向接口板发送握手报文,来确认接口板是否运行正常。如果接口板在本命令设置的握手超时时长内未回复报文,主控板将认为该接口板故障,则会重启该接口板。
在一些对此握手时间有要求的场景(比如板卡重启断流时间要求短的场景),可以通过本命令调整主控板与接口板之间握手的超时时长,实现缩短握手时间,尽早发现接口板故障。
# 配置主控板与接口板之间握手的超时时长为40秒。
[Sysname] system handshake timeout 40
system switchover命令用来手工触发主用主控板和备用主控板的主备倒换。
system switchover
仅独立运行模式下支持本命令。
仅缺省MDC支持本命令。
手工触发主备倒换时,原主用主控板会自动重启,所以,在执行本命令前,建议先保存当前配置。
# 当前配置跟启动配置文件比较无变化时,手工触发主用主控板和备用主控板的主备倒换。
[Sysname] system switchover
Switching to the standby MPU. Continue? [Y/N]:y
This command will perform a switchover. Continue? [Y/N]:y
# 当前配置跟启动配置文件比较有变化时,手工触发主用主控板和备用主控板的主备倒换。
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
Please input the file name(*.cfg)[flash:/mqc.cfg]
flash:/mqc.cfg exists, overwrite? [Y/N]:y
system-working-mode命令用来配置设备的工作模式。
undo system-working-mode命令用来恢复缺省情况。
system-working-mode { advance | expert | standard }
设备工作在标准模式。
advance:将设备的系统工作模式配置为高级模式。
expert:将设备的系统工作模式配置为专家模式。
standard:将设备的系统工作模式配置为标准模式。
仅缺省MDC支持本命令。
不同模式下设备支持的特性不同,或者相同的特性支持的规格不同,详细描述请参见“基础配置指导”中的“设备管理”。
要使修改的工作模式生效,必须重启设备。
系统工作模式切换到advance时,需要预留足够的IFP ACL资源,否则会导致切换失败。可以使用display qos-acl resource命令查看当前剩余的IFP ACL资源。有关display qos-acl resource命令的介绍,请参见“ACL和QoS”中的“ACL”。
LSCM1GT48SC0接口板不支持advance模式。
LSCM2系列SC主控板不支持expert模式,命令行下发后设备上会提示不支持。同时,当系统工作在expert模式下时,不支持如下单板:
· LSCM2系列SC接口板
· SE系列接口板
· LSCM1GT48SC0单板
若设备处于其他模式下并正在使用上述单板,当设备切换为expert模式后,上述单板将会重启且无法再次启动。
# 将设备工作模式配置为高级模式。
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the system to make it effective.
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
(独立运行模式)
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number{ hotspot | inflow | outflow } sensor-number
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
不同温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
slot slot-number:配置指定单板上温度传感器的温度门限。slot-number表示单板所在的槽位号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
outflow:配置出风传感器的温度门限。出风传感器一般置于出风口附近,监测设备温度。
sensor-number:温度传感器的编号,输入该参数的值时可通过输入?,来获取该参数的取值范围。
lowlimit:低温告警门限,单位为摄氏度。不同温度传感器的低温告警门限取值范围不同,输入该参数的值时可通过输入?,来获取该参数的取值范围。
warninglimit:一般级高温告警门限,单位为摄氏度,必须大于低温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
alarmlimit:严重级高温告警门限,单位为摄氏度,必须大于一般级高温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
本命令仅缺省MDC支持。
# 配置指定slot上热点1号温度传感器,低温门限为-10摄氏度,一般级高温门限为50摄氏度,严重级高温门限为60摄氏度。(独立运行模式)
[sysname] temperature-limit slot 1 hotspot 1 -10 50 60
· display environment
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time at、time once或time repeating命令时,最后一次执行的命令生效。
# 配置2015年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
· 使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
transceiver health check enable命令用来开启光模块健康度检测功能。
undo transceiver health check enable命令用来关闭光模块健康度检测功能。
光模块健康度检测功能处于关闭状态。
# 开启光模块健康度检测功能。
[Sysname] transceiver health check enable
· display transceiver health
transceiver health weight命令用来配置光模块健康度的计算权重。
undo transceiver health命令用来恢复缺省情况。
transceiver health weight temp temp-weight voltage volage-weight bias bias-weight rxpower rxpower-weight txpower txpower-weight
undo transceiver health weight
光模块健康度的计算权重如下:temp权重值为15,voltage权重值为5,bias权重值为30,rxpower权重值为10,txpower权重值为40。
temp temp-weight:表示光模块的温度在健康度中的计算权重,取值范围为1~96。
voltage volage-weight:表示光模块的电压在健康度中的计算权重,取值范围为1~96。
bias bias-weight:表示光模块的偏置电流在健康度中的计算权重,取值范围为1~96。
rxpower rxpower-weight:表示光模块的发送光功率健康度在健康度中的计算权重,取值范围为1~96。
txpower txpower-weight:表示光模块的接收光功率健康度在健康度中的计算权重,取值范围为1~96。
本命令可配置用于光模块健康度检测计算的5个诊断参数的计算权重。诊断参数分别为temp、voltage、bias、rxpower和txpower。
光模块健康度的各个诊断参数的计算权重值之和必须为100。
# 配置光模块健康度的计算权重,temp、voltage、bias、rxpower和txpower的计算权重值均为20。
[Sysname] transceiver health weight temp 20 voltage 20 bias 20 rxpower 20 txpower 20
transceiver monitor enable命令用来开启光模块监控功能。
undo transceiver monitor enable命令用来关闭光模块监控功能。
光模块监控功能处于关闭状态。
仅缺省MDC支持本命令。
开启光模块监控功能后,设备会按周期检查光模块的参数(例如光模块的输出功率、输入功率等),当参数的采样值达到软件设定的阈值时,会生成相应的日志提醒用户。
# 使能光模块监控功能。
[Sysname] transceiver monitor enable
· transceiver monitor interval
transceiver monitor interval命令用来配置光模块的监控周期。
undo transceiver monitor interval命令用来恢复缺省情况。
transceiver monitor interval interval
光模块的监控周期是600秒。
interval:表示光模块的监控周期,取值范围为300~3600,单位为秒。
仅缺省MDC支持本命令。
开启光模块监控功能后,本命令才生效。
# 配置光模块监控周期为500秒。
[Sysname] transceiver monitor interval 500
· transceiver monitor enable
transceiver power-mode命令用来配置可插拔光模块的功耗模式。
undo transceiver power-mode命令用来恢复缺省情况。
transceiver power-mode { high | low }
本命令的缺省情况与光模块的型号有关,请以光模块的实际情况为准。
以太网接口视图
通常情况下,光模块处于高功耗工作模式。当光模块长时间不需要工作时,可将光模块切换到低功耗工作模式,节省能耗。低功耗模式下,光模块不能传输信号,如果有流量传输需求,需要手工将光模块调整到高功耗工作模式。
本配置会保存在光模块内部的寄存器中,不会保存到配置文件中。
仅可插拔QSFP系列光模块支持本命令。
# 将HundredGigE1/0/1上插入的QSFP系列光模块设置为高功耗模式。
[Sysname] interface fourhundredgige 1/0/1
[Sysname-FourHundredGigE1/0/1] transceiver power-mode high
# 将HundredGigE1/0/1上插入的QSFP系列光模块设置为低功耗模式。
[Sysname-FourHundredGigE1/0/1] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
· display transceiver status
transceiver rx-power high-threshold命令用来配置光模块接收功率告警上限。
undo transceiver rx-power high-threshold命令用来恢复缺省情况。
transceiver rx-power high-threshold power-value
未配置光模块接收功率告警上限。
以太网接口视图
power-value:表示光模块接收功率的告警阈值,单位为dBm,精度为0.01。
通过执行transceiver rx-power high-threshold命令,用户可以在光模块接收功率的固有预警门限和固有告警门限范围内设置告警阈值。当光模块接收功率超过用户设置的告警阈值时,系统将打印告警信息。例如,当前光模块的告警上限范围为3.00dBm~5.00dBm,用户可以设置告警上限为4.40dBm。
可以通过display transceiver diagnosis命令查看光模块的告警门限值,确保设置的告警阈值配置成功。
本命令仅适用于支持数字诊断功能的SFP、SFP+、SFP28、QSFP+、QSFP28系列光模块,且不适用于400G ZR光模块、400G ZR+光模块和光转电模块。
当光模块为多通道模块,则配置对所有通道生效。
# 设置Ten-GigabitEthernet3/0/1上插入的光模块接收功率的告警上限为4.40dBm。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] transceiver rx-power high-threshold 4.40
· display transceiver diagnosis
· transceiver rx-power change-threshold
· transceiver rx-power low-threshold
transceiver rx-power low-threshold命令用来配置光模块接收功率告警下限。
undo transceiver rx-power low-threshold命令用来恢复缺省情况。
transceiver rx-power low-threshold power-value
未配置光模块接收功率告警下限。
以太网接口视图
通过执行transceiver rx-power low-threshold命令,用户可以在光模块接收功率的固有预警门限和固有告警门限范围内设置告警阈值。当光模块接收功率低于用户设置的告警阈值时,系统将打印告警信息。例如,当前光模块的告警下限范围为-14.00dBm~-11.00dBm,用户可以设置告警下限为-13.00dBm。
可以通过display transceiver diagnosis命令查看光模块的告警阈值,确保设置的告警阈值配置成功。
# 设置Ten-GigabitEthernet3/0/1上插入的光模块接收功率的告警下限为-13.00dBm。
[Sysname-Ten-GigabitEthernet3/0/1] transceiver rx-power low-threshold -13.00
· transceiver rx-power high-threshold
transceiver rx-power change-threshold命令用来配置光模块接收功率变化幅值的告警阈值。
undo transceiver rx-power change-threshold命令用来恢复缺省情况。
transceiver rx-power change-threshold power-value
光模块接收功率变化幅值的告警阈值为5.00dBm。
以太网接口视图
power-value:表示光模块接收功率变化幅值的告警阈值。取值范围为0~48,单位为dBm,精度为0.01。
通过设置光模块接收功率变化幅值的告警阈值,系统能够在光模块接收功率发生显著变化时及时提供告警。
光模块在链路首次启动并稳定后的初始接收光功率被设定为基准值。执行transceiver rx-power change-threshold命令后,系统将周期性地检查光模块的发送光功率。如果发现接收光功率相对于基准值的变化超过用户设定的阈值,系统将判断为接收光功率发生了重大变化,从而触发告警。例如,用户设置的告警阈值为20.00dBm,链路首次启动并稳定后的初始接收光功率为-15.00dBm,若当前接收光功率降到-36.00dBm或升高到6.00dBm时,系统会触发告警。
# 设置Ten-GigabitEthernet3/0/1上插入的光模块接收功率变化幅值的告警阈值为4.00dBm。
[Sysname-Ten-GigabitEthernet3/0/1] transceiver rx-power change-threashold 4.00
transceiver tx-power high-threshold命令用来配置光模块发送功率告警上限。
undo transceiver tx-power high-threshold命令用来恢复缺省情况。
transceiver tx-power high-threshold power-value
未配置光模块发送功率告警上限。
以太网接口视图
power-value:表示光模块发送功率的告警阈值,单位为dBm,精度为0.01。
通过执行transceiver tx-power high-threshold命令,用户可以在光模块发送功率的固有预警门限和固有告警门限范围内设置告警阈值。当光模块发送功率超过用户设置的告警阈值时,系统将打印告警信息。例如,当前光模块的告警上限范围为3.00dBm~5.00dBm,用户可以设置告警上限为4.40dBm。
# 设置Ten-GigabitEthernet3/0/1上插入的光模块发送功率的告警上限为4.40dBm。
[Sysname-Ten-GigabitEthernet3/0/1] transceiver tx-power high-threshold 4.40
· transceiver tx-power change-threshold
· transceiver tx-power low-threshold
transceiver tx-power low-threshold命令用来配置光模块发送功率告警下限。
undo transceiver tx-power low-threshold命令用来恢复缺省情况。
transceiver tx-power low-threshold power-value
未配置光模块发送功率告警下限。
以太网接口视图
通过执行transceiver tx-power low-threshold命令,用户可以在光模块发送功率的固有预警门限和固有告警门限范围内设置告警阈值。当光模块发送功率低于用户设置的告警阈值时,系统将打印告警信息。例如,当前光模块的告警下限范围为-14.00dBm~-11.00dBm,用户可以设置告警下限为-13.00dBm。
# 设置Ten-GigabitEthernet3/0/1上插入的光模块发送功率的告警下限为-13.00dBm。
[Sysname-Ten-GigabitEthernet3/0/1] transceiver tx-power low-threshold -13.00
· transceiver tx-power high-threshold
transceiver tx-power change-threshold命令用来配置光模块发送功率变化幅值的告警阈值。
undo transceiver tx-power change-threshold命令用来恢复缺省情况。
transceiver tx-power change-threshold power-value
光模块发送功率变化幅值的告警阈值为4.00dBm。
以太网接口视图
power-value:表示光模块发送功率变化幅值的告警阈值。取值范围为0~48,单位为dBm,精度为0.01。
通过设置光模块发送功率变化幅值的告警阈值,系统能够在光模块发送功率发生显著变化时及时提供告警。
光模块在链路首次启动并稳定后的初始发送光功率被设定为基准值。执行transceiver tx-power change-threshold命令后,系统将周期性地检查光模块的发送光功率。如果发现发送光功率相对于基准值的变化超过用户设定的阈值,系统将判断为发送光功率发生了重大变化,从而触发告警。例如,用户设置的告警阈值为20.00dBm,链路首次启动并稳定后的初始发送光功率为-15.00dBm,若当前发送光功率降到-36.00dBm或升高到6.00dBm时,系统会触发告警。
# 设置Ten-GigabitEthernet3/0/1上插入的光模块发送功率变化幅值的告警阈值为5.00dBm。
[Sysname-Ten-GigabitEthernet3/0/1] transceiver tx-power change-threashold 5.00
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、mdc-admin、mdc-operator、level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
# 配置执行定时任务test时使用的用户角色为rolename。
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
· command
xbar命令用来配置主控板的负载模式。
(独立运行模式)
xbar { load-balance | load-single }
xbar chassis chassis-number { load-balance | load-single }
主控板的负载模式为load-balance。
chassis chassis-number:用来配置指定成员设备上主用主控板和备用主控板的负载模式。chassis-number表示设备在IRF中的成员编号。(IRF模式)
load-balance:设备的主用主控板和备用主控板共同参与报文的处理和转发。
load-single:只有主用主控板能处理和转发报文,备用主控板仅备份主用主控板的数据、监控主用主控板的状态。
仅缺省MDC支持本命令。
当设备上只有一块主控板时,只支持load-single模式,即便配置了load-balance模式,主控板也会自动切换到load-single模式。
对于S7503X-G、S7503X-M-G设备,本命令配置后不生效。
# 配置主用主控板和备用主控板的负载模式为load-balance。(独立运行模式)
[Sysname] xbar load-balance
· display xbar
