01-H3C P3100 GPON OLT常用命令介绍
本章节下载: 01-H3C P3100 GPON OLT常用命令介绍 (1.39 MB)
H3C P3100系列GPON OLT交换机
常用命令
资料版本:6W101-20231122
Copyright © 2025 新华三技术有限公司 版权所有,保留一切权利。 非经本公司书面许可,任何单位和个人不得擅自摘抄、复制本文档内容的部分或全部,并不得以任何形式传播。 除新华三技术有限公司的商标外,本手册中出现的其它公司的商标、产品标识及商品名称,由各自权利人拥有。 本文档中的信息可能变动,恕不另行通知。 |
3.2.1 clear counters gpon-olt ont
3.2.2 clear counters gpon-olt nni
3.2.3 clear counters gpon-olt ont-counts
3.3 clear counters giga-ethernet
3.4 clear counters link-aggregation
3.8 clear ip pppoe vlan-option statistics
5.31 monitor pon olt-mismatch-monitor
5.32 monitor pon olt-pause-frames-monitoring
5.36 out-band interface fast-ethernet ip address
5.53 system reserved-vlan-base
6.10 interface link-aggregation
6.11 no interface link-aggregation
6.14 no interface pon-protection-group
6.15 interface pon-protection-group
6.21 ip igmp parameter last-member-query-interval
6.22 ip igmp parameter query-interval
6.23 ip igmp parameter query-response-interval
6.24 ip igmp parameter robustness
6.27 ip igmp mode snooping-with-proxy
6.38 mac-address-table aging-time
6.43 no gpon profile mac-filter
6.44 no gpon profile multicast-dynamic
6.45 no gpon profile multicast-oper
6.46 no gpon profile multicast-static
6.47 no gpon profile multicast-userview
6.49 no gpon profile voip-sip-server
6.50 no gpon profile rate-ctrl
6.52 no gpon profile tcont-svc
6.53 no gpon profile tcont-bind
6.56.2 show ont-authentication-mode
6.56.5 Show gpon profile rate-ctrl
6.56.6 show gpon profile vportsvc
6.56.7 show gpon profile tcont-svc
6.56.8 show gpon profile tcont-bind
6.56.10 show gpon profile multicast-oper
6.56.11 show gpon profile multicast-static
7.1.11 ip igmp last-member-query-interval
7.1.13 ip igmp query-response-interval
7.1.15 ip igmp startup-query-interval
7.1.17 ip igmp unsolicited-report-interval
7.1.26 mls qos map dscp-mutation
7.1.27 mls qos map ip-prec-dscp
7.1.32 spanning-tree link-type
7.1.33 spanning-tree mst <mst-id> cost
7.1.34 spanning-tree mst <mst-id>port-priority
7.1.36 spanning-tree vlan <vlan-id> cost
7.1.37 spanning-tree vlan <vlan-id> port-priority
7.1.38 spanning-tree vlan <vlan-id> portfast
8.1 interface link-aggregation
8.1.9 ip igmp last-member-query-interval
8.1.11 ip igmp query-response-interval
8.1.13 ip igmp startup-query-interval
8.1.15 ip igmp unsolicited-report-interval
8.1.25 mls qos map dscp-mutation
8.1.26 mls qos map ip-prec-dscp
8.1.30 spanning-tree link-type
8.1.31 spanning-tree mst <mst id> cost
8.1.32 spanning-tree mst <mst id>port-priority
8.1.34 spanning-tree vlan <vlan-id> path-cost
8.1.35 spanning-tree vlan <vlan-id> priority
10.1.4 mls qos map dscp-mutation
10.1.5 mls qos map ip-prec-dscp
11.1.5 ip igmp last-member-query-interval
11.1.7 ip igmp query-response-interval
11.1.9 ip igmp startup-query-interval
11.1.11 ip igmp unsolicited-report-interval
12.1.11 ont-discovery-interval
13.1.9 eth-uni activate/deactivate
14.2 show acl-applied-interface
14.14 show database-acl-record
14.19 show interface description
14.20 show interface gpon-olt..broadcast gem-port
14.21 show interface gpon-olt..counters gemport
14.22 show interface gpon-olt..counters mulitcast
14.23 show interface gpon-olt..counters nni
14.24 show interface gpon-olt..ont
14.25 show interface gpon-olt..gpon-link
14.26 show interface gpon-olt..key-exchange-ctrl
14.27 show interface gpon-olt..key-exchange-interval
14.28 show interface gpon-olt..ont..brief
14.29 show interface gpon-olt..ont..capability
14.30 show interface gpon-olt..ont..eth-uni
14.31 show interface gpon-olt..ont..loop-detect
14.32 show interface gpon-olt..ont..mac-address
14.33 show interface gpon-olt..ont..mac-filter
14.34 show interface gpon-olt..ont..optical-info
14.35 show interface gpon-olt..ont..port-vlan
14.36 show interface gpon-olt..ont..profile
14.37 show interface gpon-olt..ont..summary
14.38 show interface gpon-olt..ont..uni-status
14.39 show interface gpon-olt..ont..virtual-port
14.40 show interface gpon-olt..ont-performance
14.41 show interface gpon-olt..ont-range.. mac-address
14.42 show interface gpon-olt..ont-range.. brief
14.43 show interface gpon-olt..ont-range..capability
14.44 show interface gpon-olt..ont-range..loop-detec
14.45 show interface gpon-olt..ont-range..summary
14.46 show interface link-aggregation
14.47 show interface gpon-olt..ont-registered
14.48 show configuration running interface-gpon-olt
14.49 show interface gpon-olt..ont-unbound
14.50 show interface gpon-olt..counters
14.51 show interface gpon-olt…optical-info
14.52 show interface gpon-olt..pon-max-distance
14.53 show interface gpon-olt..transceiver type
14.54 show interface giga-ethernet..counters
14.55 show interface giga-ethernet..optical-info
14.56 show interface giga-ethernet..switchport
14.58 show interface management in-band
14.59 show interface pon-protection-group
14.60 show interface super-vlan
14.62 show ip igmp debug-traces
14.64 show ip igmp static-group
14.67 show ip pppoe vlan-option statistics
14.70 show link-aggregation summary
14.74 show management ip route
14.80 show multicast-group-author
14.83 show multicast-vlan-to-multi-gem
14.84 show ont-authentication-mode
该手册介绍H3C P3108和P3116的CLI命令。
CLI管理PC的COM口可通过Console线直连到P3116串口。通过运行终端仿真程序(如Windows 超级终端)设置如下属性:
每秒比特:115200bps
数据位:8
奇偶校验:无
停止位:1
流量控制:无
登录P3116后会出现下一节中描述的提示。
以下是通过Telnet登录P3116的例子:
从Windows开始菜单选择[开始/运行],输入以下命令。缺省的端口号为23:
> telnet 192.168.2.251
建立与P3116的连接后,屏幕会出现以下POST提示:
Username:
Password:
如果没有出现POST提示,应检查网络连接。输入用户名和口令:
Login: admin
Password: *****
对于P3116,缺省的管理员用户名和口令都是admin。guest(只读)的用户名和口令都是guest。
输入正确的用户名和口令后,会出现以下系统提示,表示登录成功,系统将进入EXEC命令模式接口。根据用户账户的权限,可以进入不同的CLI命令模式。
telnet@P3116>
有两种注销CLI的方式(正常退出与异常退出)。
· 正常退出
任何命令模式都可以采用logout命令终止当前的CLI连接。
· 异常退出
异常退出包括任何连接的断开,包括在配置时段内用户没有任何操作,发生超时中断。
CLI命令分为以下模式:
EXEC: 允许用户查看基本系统信息并对连接进行核实,但不允许更改配置。
在EXEC和较低的模式中,命令提示为telnet@P3116>。
Privileged EXEC: 除了允许用户访问所有EXEC模式命令外,还允许访问不要求保存的配置命令。Privileged EXEC用户不能访问系统配置文件。通过在EXEC提示框中输入enable可以访问Privileged EXEC模式。
在Privileged EXEC 模式中,命令提示为telnet@P3116#。
管理配置模式允许对P3116执行管理任务。可以在Privileged EXEC模式输入configure management进入该模式。
Management Configuration(管理配置)模式的提示为telnet@P3116(config-mgmt)#。
CONFIG Terminal: 该命令模式允许用户更改设备配置。更改的配置可保存到闪存并在重启时恢复。CONFIG 命令模式包含单个端口、VLAN和其他配置区域的子模式。在Privileged EXEC提示框中输入config terminal 可进入Global Configuration (全局配置)模式。请参考CLI命令模式及提示。
Global Configuration(全局配置)模式的提示为telnet@P3116(config-t)#。
OLT子配置模式允许对特定的OLT逻辑参数进行逐个端口的分配和修改。在Global Configuration模式输入interface gpon-olt <module/port>可进入该模式。
OLT Configuration(OLT配置)模式的提示为telnet@P3116(config-if-gpon-olt-module/port)#。
ONT子配置模式允许配置ONU逻辑端口信息。在OLT配置模式输入ont <logical-port>可进入该模式。
ONU Configuration(ONU配置)模式的提示为telnet@P3116(config-if-gpon-ont-module/port/logicalport)#。
表1-1 CLI命令模式和提示
CLI命令模式 |
提示 |
配置内容 |
访问方法 |
访问控制 |
EXEC |
telnet@P3116> |
允许用户查看系统基本信息并对连接进行查验,例如:ping。 |
登录 |
本地账户验证 |
Privileged EXEC |
telnet@P3116# |
允许用户访问所有的EXEC模式命令,也允许访问不需保存的配置命令。 |
在EXEC模式输入enable[口令] |
如果设置了口令,则必须输入。 |
Management Configuration |
telnet@P3116(config-mgmt)# |
配置P3116管理参数。 |
在Privileged EXEC模式输入configure management 命令。 输入exit返回Privileged EXEC模式。 |
Terminal Configuration |
telnet@P3116(config-t)# |
配置pon参数。 |
在Privileged EXEC模式输入configure terminal命令。 输入exit返回Privileged EXEC模式。 |
OLT sub Configuration |
telnet@P3116(config-t-if-olt-1/1)# |
配置OLT参数。 |
在configure terminal模式输入interface epon-olt <module/port>命令。 输入exit返回configure terminal模式。 |
Gigabit interface sub Configuration |
telnet@P3116(config-t-if-ge-1/1)# |
配置千兆以太网参数。 |
在configure terminal模式输入interface giga-ethernet <module/port>命令。 输入exit返回configure terminal模式。 |
linkAggreration interface sub Configuration |
telnet@P3116(config-t-if-lg-1)# |
配置链路汇聚参数。 |
在configure terminal模式输入interface link-aggregation <linkid>命令。 输入exit返回configure terminal模式。 |
Interface range sub Configuration |
telnet@P3116(config-t-if-range-ge2/1-3)# |
配置范围参数。 |
在configure terminal模式输入interface range <rangeid>命令。 输入exit返回configure terminal模式。 |
Interface loopback sub Configuration |
telnet@P3116(config-t-if-lpb-1)# |
配置环回参数。 |
在configure terminal模式输入interface loopback <lookbackid>命令。 输入exit返回configure terminal模式。 |
VLAN sub Configuration |
telnet@P3116(config-t-vlan-333)# |
配置VLAN参数。 |
在configure terminal模式输入接口vlan<vlanid>命令。 输入exit返回configure terminal模式。 |
ONU upgrade sub Configuration |
telnet@P3116(config-t-onu-ugp)# |
配置ONU升级参数。 |
在configure terminal模式输入onu-upgrade命令。 输入exit返回configure terminal模式。 |
ONU sub Configuration |
telnet@P3116(config-if-gpon-ont-1/1/1)# |
配置ONU参数。 |
在配置OLT子模式输入onu<onuid>命令。 输入exit返回配置OLT子模式。 |
退出CLI的说明:
退出(exit):该命令用于退出当前模式并返回下一级模式。如果当前模式为EXEC命令模式,CLI连接会终止。
注销(logout):该命令用于从任何命令模式终止当前的CLI连接。
每个命令都有一个访问级别(0、1、2、10)。以下是访问级别的说明:
访问级别:
0:只读用户:只能读取配置信息
1:端口级用户:用户有权进行端口级别的配置读/写访问,但不允许更改系统配置。
2:Power用户:用户可以控制整个系统,但不包括其他登录账户的配置。
10:管理员:用户可以控制整个系统,包括其他登录账户的配置。
CLI命令包括命令本身以及必需的和/或可选的参数。为了精确地表示完整的CLI命令,采用以下规范:
语法:static-mac-address <MAC-addr> {vlan <VLAN-ID>} {port <port-num>} [cos <value>]
说明:
· 黑体字符表示命令本身或命令关键字
· “<>”中的文本为必选参数
· “{}”中的文本为带关键字的必选参数
· “[]”中的文本为可选参数
· “<>”或 “[]”之外的文本为命令关键字或命令本身
· “|”分隔的多个可选项为多选的必选参数,表示必须选择其中一项。
根据以上定义的规范,命令statis-mac-address,<MAC-addr>为必选参数,{vlan <VLAN-ID>}为带关键字的必选参数,[cos <value>]为可选参数(cos为关键字)。第一个命令中的enable|disable为多选的必选参数。
P3116 CLI提供各种帮助和快捷键。表1-2列出了CLI提供的主要帮助信息。
方法 |
功能 |
在任何LCI命令级别输入“?”。 |
显示该命令级别的所有可用命令。 |
缩略命令项+“?”。 |
显示特定字符串开始的命令列表(命令与问号之间没有空格)。 |
命令+空格+“?”。 |
显示命令的完整语法和简要说明。 |
缩略命令项+<tab> |
系统会自动完成该命令中当前关键字的整个输入。 |
如果输入的命令和/或关键字不完整,但其长度足够使系统识别该命令, |
系统会执行该局部命令,与完整命令一样。 |
在任何LCI命令级别输入“tree”。 |
显示树型格式的CLI命令级别的所有可用命令。 |
“Ctrl-P”或向上光标键↑ |
调用最新的输入命令。用户可采用“↑”查看最后的20个命令。 |
历史 |
输入history显示最新的30个命令。 |
当命令+“?”显示有<cr>但回车无法下发,表明该命令行参数配置不完整,需要继续补充其他参数后再下发。
例1:
telnet@P3116> ?
enable - Turn on privileged commands
cls - Clear the screen
exit - Exit intermediate mode
help - Description of the interactive help system
history - Show command history
logout - Log off this system
ping - Ping command
show - Show running system information
telnet - Telnet to host
traceroute - Trace route to destination
tree - Show command tree
who - Display users currently logged in
telnet@P3116>
例2:
telnet@P3116(config-t)#exp + ?
export
telnet@P3116(config-t)#export
例3:
telnet@P3116# configure t + <Tab>
telnet@P3116# configure terminal
热键 |
功能 |
Enter |
执行命令/输入中间模式 |
Ctrl-z |
输入命令并返回根提示框。如果没有输入命令,将返回根提示框。 |
Ctrl-e |
将光标移到一行字符的结尾。 |
Esc-b |
将光标向后移一个字。 |
Esc-f |
将光标向前移一个字。 |
Backspace |
光标左移同时删除字符,直到删除整行字符。 |
Ctrl-d |
删除当前字符。 |
Ctrl-u |
删除光标前的文本。 |
Ctrl-k |
删除光标后的文本。 |
Ctrl-a |
将光标移到一行字符的开始。 |
Esc-d |
删除该字的剩余部分。 |
Ctrl-w |
删除光标前的字。 |
Ctrl-p |
获取前一个命令历史。 |
Ctrl-n |
获取下一个命令历史。 |
Up arrow |
向上逐个查看命令历史。 |
Down arrow |
向下逐个查看命令历史。直到出现当前命令。 |
Ctrl-t |
将当前字符与上一个字符换位。 |
该命令用于激活privileged EXEC级别。如果用户的访问级别等于或大于2,那么不需要检查激活口令。
语法:enable
访问级别:0
说明:激活privileged EXEC级别。
语法:clear counters
访问级别:2
说明:将系统中的所有计数器清零。
语法:clear counters gpon-olt <1/port>|<all>
取值范围:
<1/port>|<all>:{1/1..1/16} | all
说明:将特定或所有OLT的计数器清零。
访问级别:0
语法1:clear counters gpon-olt <1/port> ont<ont port> [gemport <ont port/vport>]
取值范围:
<1/port>:{1..16}
<ont port/vport>:{{1..64}/{1..16}}
说明:重置相应OLT下相应onu的所有或者特定的gemport计数器。
访问级别:0
语法1:clear counters gpon-olt <1/port> nni
取值范围:
<1/port>:{1..16}
说明:重置相应OLT下的nni计数器。
访问级别:0
语法1:clear counters gpon-olt <1/port> ont-counts <ontid>
取值范围:
<1/port>:{1..16}
<ontid>: {1..64}
说明:重置相应OLT下的onu计数器。
访问级别:2
语法:clear counters giga-ethernet <module/port>
取值范围:
<module/port>:单接口,如:1/2 或者接口范围{1/{1-16}或2/{1-4}}
说明:将特定千兆以太网的计数器清零。
访问级别:2
语法:clear counters link-aggregation <linkid>
取值范围:
< linkid >:{1..32}
说明:将特定链路汇聚接口的计数器清零。
访问级别:2
语法:clear counters loopback <lid>
取值范围:
<lid>:<0..16>
说明:将特定环回接口的计数器清零。
访问级别:2
语法:clear counters vlan <vid>
取值范围:
< vid >: {1..4094}
说明:将特定VLAN的计数器清零。
访问级别:2
语法:clear igmp-statistics
说明:清除所有IGMP统计。
访问级别:2
该命令用于重置L2 PPPOE中继计数器。
语法:clear ip pppoe vlan-option statistics
访问级别:2
语法:clear pon-mac-addresses [1/port]
取值范围:
[1/port] :port{1..16}
说明:该命令用于删除所有gpon动态MAC地址。
访问级别:2
该命令用于删除所有动态MAC地址。
语法:clear mac-addresses
访问级别:2
该命令用于将所有或特定接口的生成树计数器清零。
语法1:clear spanning-tree counters
语法2:clear spaaning-tree counters interface { giga-ethernet< mdule/port> } | {link-aggregation <1..32>}
访问级别:2
该命令用于进入管理配置模式。
语法:configure management
访问级别:1
该命令用于进入终端配置模式。
语法:configure terminal
访问级别:1
该命令用于进入DEBUG模式。
语法:debug
访问级别:10
除了本章介绍的命令,详细说明请参考第五章“调测命令”。
该命令用于关闭特权级别。
语法:disable
访问级别:0
该命令用于把屏幕清空。
语法:cls
访问级别:0
该命令用于退出中间模式。
语法:exit [all]
说明:采用参数[all]返回EXEC模式。
访问级别:0
该命令用于显示命令帮助。
语法:help
访问级别:0
该命令用于显示命令历史。
语法:history
访问级别:0
该命令用于注销系统。
语法:logout
访问级别:0
该命令用于发送ICMP echo数据包,可携带的参数选项用于:
· 设置源IP;
· 设置TX数据包的数量;
· 设置数据包长度;
· 支持连续模式。
语法:ping <destination-ip-address> [source-ip-address]
ping <destination-ip-address> [source-ip-address] pklen <packet-length> [repeat <repeat-count >]
ping <destination-ip-address> [source-ip-address] repeat <repeat-count > [pklen <packet-length> ]
取值范围:
packet-length:28-4096字节
repeat-count:1..65500
说明:如果<ip-address>不是路由IP,则指定缺省网关。
访问级别:0
该命令用于显示运行系统信息。
语法:show
<parameters>
说明:显示运行系统信息。
访问级别:0
该命令用于通过特定端口telnet远端主机或服务器。
语法:telnet <A.B.C.D> <port-number>
说明:通过带端口号的端口Telnet到IP地址为<A.B.C.D>的主机。
访问级别:2
该命令用于跟踪路由IP地址。源IP地址可随意指定。最大跳数(TTL)也可随意指定。
语法:traceroute <destination-ip-address> [source-ip-address] [max-hops <hops-number>]
取值范围:
hops-number:生存时间(TTL)值,范围是1-128
访问级别:2
该命令用于显示带有可选命令语法的命令树。
语法:tree [-syntax]
说明:
无参数时,将以树型结构显示当前的所有命令。若使用参数[-syntax],将显示该命令的详细信息,包括命令中可使用的所有参数及其范围。
访问级别:0
该命令用于显示当前的登录用户。
语法:who
访问级别:0
该命令用于应用/关闭管理接口的ACL配置文件。运行该命令可防止软件或硬件受到攻击。
语法:[no] anti-attack <software|hardware>
访问级别:2
该命令用于应用管理ACL配置文件。
语法:anti-mac-spoofing <enable|disable>
访问级别:2
取值范围:
<enable|disable>:启用或禁用MAC伪装。
该命令用于应用管理ACL配置文件。
语法:apply-mgmt-acl-access-list <files-string>
访问级别:2
取值范围:
<files-string>:
ACL单个文件(<file1>),如:a1,或
ACL多个文件(<file1、file2..file7..>),如:a1、a2..a5...
这是最多有200个字符的字符串。
该命令用于将ACL配置文件应用到管理接口。
语法:
apply-mgmt-acl-profile <profileid>
[no] apply-mgmt-acl-profile
取值范围:
Profile id:ACL配置文件号,(1..32)
访问级别:2
该命令用于配置登录横幅。
语法:banner
访问级别:0
该命令用于配置从闪存启动系统时的映像文件。
语法:boot system flash <filename>
取值范围:
<filename>:最多20个字符
访问级别:2
该命令用于配置从FTP服务器启动系统。
语法:boot system ftp <A.B.C.D> <user-name> <user-password> <system-image-file-name>
访问级别:2
取值范围:
A.B.C.D:下载文件的IP地址
user-name:登录用户名—最多20个字符(包括文字和数字)的字符串
user-password:登录用户口令—最多20个字符(包括文字和数字)的字符串
system-image-file-name:系统映像文件名—最多64个字符的字符串
该命令用于更新bootrom映像文件。
语法:bootrom-update <host IP address> <user-name> <user-password> < boot-rom-file-name>
取值范围:
user-name:登录用户名—最多23个字符(包括文字和数字)的字符串
user-password:登录用户口令—最多15个字符(包括文字和数字)的字符串
boot-rom-file-name:boot rom文件名—最多63个字符的字符串
访问级别:2
说明:话单服务器配置。
该命令用于诊断ONT信息。
语法:diagnose ont-info <1/port> <ont id>
取值范围:
<1/port>:port{1..16}
<ont id>:{1..64}
访问级别:2
该命令用于光路诊断。
语法:diagnose optical-path <1/port>
取值范围:
访问级别:2
该命令用于诊断系统信息。
语法:diagnose system
取值范围:
访问级别:2
设置/清除命令enable的登录用户名和口令。
语法:
enable password <login-username> <password>
no enable password <login-username>
取值范围:
<login-username>:登录用户名—最多15个字符的字符串
<password>:明文(cleartext)的“enable”口令—最多15个字符的字符串。
访问级别:2
进行文件系统的一致性检查。
语法:file-system chkdsk <volname>
取值范围:
<volname>:目录名,请参考flash或nvm。取值范围是:nvm:、nvm:/、flash:或flash:/。
访问级别:2
拷贝文件。
语法:file-system copy <src> <dst>
取值范围:
<src>:源文件名,最多254个字符
<dst>:目的文件名,最多254个字符
访问级别:2
将内存格式化。
语法:file-system format <dst-device>
取值范围:
<dst-device>:目录名,最多254个字符。请参考闪存或NVM内存。
访问级别:2
列出BBS系统中的所有文件或某个目录中的文件。
语法:file-system list [directory]
取值范围:
[directory]:目录名, /tffs/ or /ramdisk:0/ 最多64个字符
访问级别:2
创建BBS系统中的目录。
语法:file-system mkdir <directory>
取值范围:
<directory>:最多64个字符的目录名
访问级别:2
删除文件。
语法:file-system remove <filename>
取值范围:
<filename>:需要删除的文件名称,最多254个字符
访问级别:2
将文件重命名。
语法:file-system rename <src> <dst>
取值范围:
<src>:带路径的原文件名称,最多254个字符
<dst>:带路径的新文件名称,最多254个字符
访问级别:2
该命令用于配置告警过滤。
语法:filter-alarm <index>
[class <none | communication | qos | equipment | procerror | environment>]
缺省值:none
[severity <none | critical | major | minor | warning | clear>]
缺省值:none
[status <disabled | enabled>]
缺省值:disable
[entity <entity-value>] [slot<instance-slot-value>] [port <instance-port-value>] [lport <instance-lport-value>] [uinport<instance-uniport-value>] [group <instance-group-value>]
[pc<pc-value>] [sp<sp-value>]
取值范围:
<index>:<1-64>,告警过滤的索引号。
<entity-value>:<0 -5000>
¡ 2001- node
¡ 2002 - module
¡ 2003 - Fan module
¡ 2004 - Power module
¡ 2005 - shelf
¡ 2006 - shelf groupid
¡ 2007 - port
¡ 2008 - onu
¡ 2009 - onu uni port
<instance-slot-value>:<0 - 1>
<instance-port-value>:<0 - 4>
<instance-lport-value>:<0-64>
<instance-uniport-value>:<0 - 24>
<instance-group-value>:<0 - 64>
<pc-value>:<0 - 5000>
<sp-value>:<0 - 5000>
访问级别:2
配置模式:CONFIG Management模式
该命令用于上载或下载文件。
语法:ftp <ftp-host-ip> <get|put> <login-user-name> <login-password> <local-file-name-with-path> <remote-file- name-string >
取值范围:
<get|put>:
¡ get:从远端主机获取文件
¡ put:将文件放到远端主机
<login-user-name>:登录用户名,为最多23个字符的字符串
<login-password>:登录口令,为最多15个字符的字符串
<local-file-name-with-path>:格式:闪存:/文件名,为最多63个字符的字符串
<remote-file-name-string>:最多63个字符的字符串
访问级别:2
该命令用于配置telnet访问列表。
语法:[no] ip access-list <telnet> <A.B.C.D> <net mask>
访问级别:2
该命令用于关闭当前运行会话外的其它telnet会话。
语法:kill
访问级别:10
该命令用于配置日志告警门限。
语法1:logging alarm-threshold cpu <cpu_usage_percentage>
说明:设置总的CPU利用率。
语法2:logging alarm-threshold memory < memory_usage_percentage>
说明:设置总的内存利用率。
语法3:logging alarm-threshold task-cpu <task_cpu_usage_percentage>
说明:设置某个CPU进程的利用率。
取值范围:
< cpu_usage_percentage>:0-89、<task_cpu_usage_percentage>: 0-49、
< memory_usage_permillage>:0-949
访问级别:2
该命令用于设置控制台日志告警级别。
语法:logging console <severity-level>
取值范围:
<severity-level>:有两种方式设置告警级别。
· alerts|critical|debugging|emergencies|errors|informational|notifications|warnings
· <1..8>的告警级别。
名称 |
级别 |
含义 |
alerts |
2 |
需要马上采取行动。 |
critical |
3 |
危急情况 |
debugging |
8 |
调测消息 |
emergencies |
1 |
系统不能用。 |
errors |
4 |
错误情况 |
informational |
7 |
上报消息 |
notifications |
6 |
正常但有重要的情况 |
warnings |
5 |
警告情况 |
缺省值:debugging
访问级别:2
设置闪存日志告警级别。
语法:logging flash <alarm|event|others> <severity-level>
取值范围:
· alerts|critical|emergencies|errors
· <1..8>的告警级别。
名称 |
级别 |
含义 |
alerts |
2 |
需要马上采取行动。 |
critical |
3 |
危急情况 |
emergencies |
1 |
系统不能用。 |
errors |
4 |
错误情况 |
缺省值:alerts
访问级别:2
该命令用于设置系统日志格式。
语法:logging format <non-rfc3164|rfc3164>
取值范围:
non-rfc3164或rfc3164
缺省值:non-rfc3164
访问级别:2
语法:logging host <ip> [port-number] facility <facility code> <severity-level>
取值范围:
<port-number>:1-65535
<facility code >:auth; dhcp; eth; pon; sys; syslog; user
名称 |
含义 |
auth |
授权系统 |
dhcp |
动态主机配置协议 |
eth |
以太网接口 |
pon |
无源光网络 |
sys |
系统 |
syslog |
系统日志 |
user |
用户进程 |
· alerts|critical|debuggibg|emergencies|errors|informational|notifications|warnings
· <1..8>的告警级别。
名称 |
级别 |
含义 |
alerts |
2 |
需要马上采取行动。 |
critical |
3 |
危急情况 |
debugging |
8 |
调测消息 |
emergencies |
1 |
系统不能用。 |
errors |
4 |
错误情况 |
informational |
7 |
消息 |
notifications |
6 |
正常但有重要的情况 |
warnings |
5 |
警告情况 |
访问级别:2
取消命令或设置为缺省值。
语法:logging no host <ip>
访问级别:2
添加或修改支持升级的onu类型。
语法:modify-upgrade-ont-list <hw-type> <description> <epuipment-id> [hw_rv]
取值范围:
<hw-type> :ont硬件类型
<description> :ont的表述
<epuipment-id>:ont的设备id
[hw_rv]:ont硬件版本(如果ont 硬件版本不是0)
访问级别:0
该命令用于OLT不匹配监测。
语法:monitor pon olt-mismatch-monitoring <disabled|enabled>
取值范围:
<disabled|enabled> 是否开启OLT不匹配监测
访问级别:10
该命令用于是否监视OLT暂停帧。
语法:monitor pon olt-pause-frames-monitoring <disabled|enabled>
取值范围:
<disabled|enabled> 是否开启OLT暂停帧监视。
访问级别:10
该命令用于删除详细通话记录。
语法1:no cdr logging
语法2:no cdr server
说明:语法1 用于禁用cdr日志记录;语法2 用于删除服务器上的呼叫详细记录
访问级别:2
该命令用于删除告警过滤。
语法:no filter-alarm <index>
取值范围:
<index>:{1..64}
访问级别:2
该命令用于配置ONT管理IP地址。
语法: onu-mngt-ip <ip> <ipmask> <gateway>
取值范围:
<ip> :<A.B.C.D> ONU管理IP地址
<ipmask>:<A.B.C.D> ONU管理IP MASK地址
<gateway>:<A.B.C.D> ONU管理IP Geteway地址
访问级别:2
语法:
out-band interface fast-ethernet ip address <ip> <mask>
out-band interface fast-ethernet no ip address
访问级别:2
该命令用于使能[去使能]性能管理信息。
语法1:[no] pm interface gpon-olt <module/port>
语法2:[no] pm interface gpon-olt <module/port> onu <onuid>
语法3:[no] pm interface giga-ethernet <module/port>
访问级别:2
取值范围:
<module/port>:({1}/{1..16}),最多31个字符的字符串
<onuid>:1-64
<module/port>:接口范围{1/{1-16}或2/{1-4}}
该命令用于配置Pon路由功能。
语法: pon-routing <operation>
取值范围:
<operation> :enable|disable
访问级别:0
该命令用于重启P3116系统。
语法:reboot
访问级别:10
该命令用于该命令用于更新ONT List 表项。
语法:reload-upgrade-ont-list
访问级别:0
该命令用于将运行配置保存到启动配置文件。
语法:save
访问级别:1
说明:将运行配置保存到闪存文件系统。
该命令用于将系统配置重置为出厂初始值。系统重启后生效。
语法:set factory default
访问级别:2
该命令用于设置CLI命令显示的选项。
语法:show-option < all | partial >
说明:
all | partial:该可选参数指示系统一次显示某个显示命令的所有或部分结果。
访问级别:2
该命令用于设置dhcp option82 接入节点编号。
语法:system access-node-id <name>
取值范围:
<name>: dhcp option82接入节点编号,最多可达50chars。
访问级别:2
该命令用于管理系统时钟。
语法:system clock <time> <date>
取值范围:
<time>:当前时间,小时:分钟:秒(HH:MM:SS),为最多8个字符的字符串
<date>:当前日期,年-月-日(YYYY-MM-DD),为最多10个字符的字符串
访问级别:2
该命令用于设置系统联系信息。
语法:system contact <contact>
取值范围:
<contact>:最多255个字符(包括文字与数字)的系统联系信息文本字符串
访问级别:2
该命令用于识别mib对象系统说明的文本。
语法:system description <description>
取值范围:
<description>:最多255个字符(包括文字与数字)的系统说明文本字符串
访问级别:2
该命令用于配置系统设备ID。
语法:system device-id <ID-string>
取值范围:
<ID-string>:系统设备ID,为最多30个字符的字符串。
访问级别:2
该命令用于重命名该交换路由器。
语法:system hostname <name>
取值范围:
<name>:最多31个字符(包括文字与数字)的系统主机名文本字符串
访问级别:2
该命令用于配置系统IP过滤器。
语法:system ip-filter <enable|disable>
取值范围:enable|disable ,缺省值:disable
说明:激活/关闭系统IP过滤器配置。
访问级别:2
该命令配置系统位置字符串,作为mib对象中的sysContact。
语法:system location <location>
取值范围:
<location>:最多255个字符(包括文字与数字)的系统位置文本字符串
访问级别:2
该命令用于配置系统管理的ttl值。
语法:system management-ttl <value>
取值范围:
<1..255>
访问级别:2
该命令用于配置系统保留的VLAN号。
语法:system reserved-vlan-base <vlan-id>
取值范围:2..4085
访问级别:2
该命令用于设置系统超时,单位为秒。
语法:system timeout <sys-time>
取值范围:
sys-time:60-3600秒
访问级别:2
该命令设置系统的TPID值。
语法:system tpid <tpid-value>
取值范围:
<tpid-value>:x8100-0xffff, 缺省为0x88a8,最多达6 chars。
访问级别:2
该命令用于设定系统运营商。
语法:system vendor <vendor-name>
取值范围:
<vendor-name>:运营商,最多16个字符。
访问级别:2
该命令用于配置设备温度极限值。
语法:temperature ceiling < temperature -value>
取值范围:
温度值:0-70
缺省值:70
访问级别:1
该命令用于上载或下载映像。
语法:tftp <host-ip> <get|put> <local-file- name-with-path> <remote-file- name-string >
访问级别:2
取值范围:
<local-file-name-with-path>:格式:闪存:/文件名(最多63个字符的字符串)
访问级别:2
该命令用于设置上行模式。
语法:uplink-mode<internal|external>
取值范围:
<internal|external>:内部为前端,外部为CSM。
访问级别:0
该命令用于更改用户的访问级别。
语法:user accesslevel <usename> <0|1|2|10>
取值范围:
<usename>:用户登录名,为最多15个字符的字符串
10:管理员
2:完全访问(超级用户)
1:端口配置访问
0:只读访问
访问级别:10
该命令用于添加新的用户账户。
语法:user add <username> <password> <0|1|2|10>
取值范围:
< password >:用户登录口令,为最多15个字符的字符串
10:管理员
2:完全访问(超级用户)
1:端口配置访问
0:只读访问
该命令用于删除用户账户。
语法:user delete <username>
访问级别:10
该命令用于更改用户名为<username>的用户口令。
语法:user password <username> [new-password <newpasswordvalue> confirm-password <newpasswordvalue>]
取值范围:
<username>:用户名,为最多15个字符的字符串。
< newpasswordvalue >:用户登录口令,为最多15个字符的字符串。
访问级别:10
说明:当按下<cr>键时,会显示“输入新口令”。输入口令后,会显示“确认新口令”。然后再次输入口令。
该命令用于配置CLI登录用户身份验证方法。
语法:user-auth-method system-database
访问级别:2
配置地址解析协议(ARP)、IP或MAC访问列表。
语法1:[no] access-list arp <arp-access-file-name>
语法2:[no] access-list ip <extended|standard> <ip-access-file-name>
语法3:[no] access-list mac <mac-access-file-name>
取值范围:
<arp-access-file-name>:ARP ACL存储文件名,为最多20个字符的字符串。
<ip-access-file-name>:IP扩展/标准ACL存储文件名,为最多20个字符的字符串。
<mac-access-file-name>:MAC ACL存储文件名,为最多20个字符的字符串。
访问级别:2
配置模式:CONFIG Terminal模式
以下CLI命令用于定义MAC访问列表的ACL规则。
语法1:
[no] deny | permit <untag|tag> <ether-type_value> smac <any |src-addr> dmac <any |dst-addr> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法2:
[no] remark <new_prio> <new_vlan> <untag|tag> <ether-type_value> smac <any |src-addr> dmac <any |dst-addr> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法3:
[no] redirect_ucast <out_untag|out_tag> <out_port> <untag|tag> <ether-type_value> smac <any |src-addr> dmac <any |dst-addr> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法4:
[no] rate_limit <bandwidth> <burst-size> <untag|tag> <ether-type_value> smac <any |src-addr> dmac <any |dst-addr> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
取值范围:
· <type_value>, <length_value>:
¡ <0~0xFFFF>, 指定包的类型,长度;
¡ <0~0xFFFF/0~0xFFFF>,指定包的类型,长度以及掩码;
· <new_prio>:<0..7>,新优先级;
· <bandwidth>:<1..10000000>,速率限制的带宽,单位为kbps。
· <burst-size>:<0..7> , 突发大小, (4 << {0~7}) Kbps。
· {vlan|priority} <value>: 指定可选值;
¡ Vlan: 1~4094/NULL,掩码:1~0xfff
¡ Priority: 0~7/NULL,掩码:0x0~0x7
以下CLI命令用于定义IP标准访问列表的ACL规则。
语法1:
[no]deny|permit{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}sip<any|host/A.B.C.D|A.B.C.D/A.B.C.D> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法2:
[no]remark<new_prio> <next-hop-value>{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}sip<any|host/A.B.C.D|A.B.C.D/A.B.C.D> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法3:
[no]redirect_ucast<out_untag|out_tag> <out_port>{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}sip<any|host/A.B.C.D|A.B.C.D/A.B.C.D> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法4:
[no]rate_limit<bandwidth> <burst-size>{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}sip<any|host/A.B.C.D|A.B.C.D/A.B.C.D> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
取值范围:
· <new_prio>:<0..7|NULL>,新优先级;
· <bandwidth>:<1..1048567>,速率限制的带宽,单位为kbps。
· <next-hop-value>:
¡ <A.B.C.D>,下一跳地址;
¡ <A.B.C.D/A.B.C.D> ,下一跳地址及其掩码;
¡ <NULL>,没有下一跳。
¡ Vlan: 1~4094,掩码:1~0xfff
¡ Priority: 0~7,掩码:0x0~0x7
以下CLI命令用于定义IP扩展访问列表的ACL规则。
语法1:
[no]deny| permit {EtherII-untag|EtherII-tag|802_3-untag|802_3-tag} protocol <protocol> src<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|host/A.B.C.D|A.B.C.D/A.B.C.Dt>dst<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|any|host/A.B.C.D|A.B.C.D/A.B.C.D>[opt1{vlan|dscp|priority|option|fragment} <value>] [opt2{vlan|dscp|priority|option|fragment} <value> ] [opt3 {vlan|dscp|priority|option|fragment} <value> ] [opt4 {vlan|dscp|priority|option|fragment} <value> ] [opt5 {vlan|dscp|priority|option|fragment} <value> ]
语法2:
no] remark {<new_prio|new_dscp> <value>} <next-hop-value> protocol <protocol> src<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|host/A.B.C.D|A.B.C.D/A.B.C.Dt>dst<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|any|host/A.B.C.D|A.B.C.D/A.B.C.D>[opt1{vlan|dscp|priority|option|fragment} <value>] [opt2{vlan|dscp|priority|option|fragment} <value> ] [opt3 {vlan|dscp|priority|option|fragment} <value> ] [opt4 {vlan|dscp|priority|option|fragment} <value> ] [opt5 {vlan|dscp|priority|option|fragment} <value> ]
语法3:
语法4:
[no]rate_limit<bandwidth> <burst-size>{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}protocol<protocol>src<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|host/A.B.C.D|A.B.C.D/A.B.C.Dt>dst<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|any|host/A.B.C.D|A.B.C.D/A.B.C.D>[opt1{vlan|dscp|priority|option|fragment} <value>] [opt2{vlan|dscp|priority|option|fragment} <value>] [opt3{vlan|dscp|priority|option|fragment} <value>] [opt4{vlan|dscp|priority|option|fragment} <value> ] [opt5 {vlan|dscp|priority|option|fragment} <value> ]
取值范围:
· <bandwidth>:<1..1048576>,速率限制的带宽,单位为kbps。
· <new_dscp>:<0..63|NULL>,新dscp;
· <next-hop-value>:
¡ <A.B.C.D>,下一跳地址;
¡ <NULL>,没有下一跳。
· <protocol>:
<1..255>,指定IP头中的协议号
<TCP|UDP|ICMP|IGMP|IPINIP|EGP|IGP|OSPF>,指定IP头中的协议名
<IP>,指定IP头为任意协议
{vlan|dscp|priority|option|fragment} <value>: 指定可选值:
¡ Vlan:1~4094 ,掩码:1~0xfff
¡ Dscp:0~63 ,掩码: 0~0x3f
¡ Priority:0~7 ,掩码:0x0~0x7
¡ Option:1-2,1表示带option,2表示不带option
¡ Fragment:1-2;1表示有1- more fragment, 2-no fragment
该命令用于配置功能反流氓onu。
语法:anti-rogueont <linkid> <enable/disable> [manual|auto]
取值范围:
<linkid>:{1..16}
<enable/disable>: 是否开启反流氓onu 功能
[manual|auto]:配置反流氓onu模式:手动/自动
访问级别:2
该命令用于清楚系统告警。
语法:clear-alarm <index>
取值范围:
<index>:单个数字,取值范围为:1~512。
访问级别:2
该命令用于清除数据库ACL配置文件、字段和规则。
语法:clear-database-acl [profileid|name_string]
取值范围:
[profileid]:<1..32>
[name_string]:访问列表中的ACL文件名,为最多20个字符的字符串。
访问级别:2
该命令用于将数据库中的ACL配置文件导出到文件系统。
语法:export < profile-name&path >
取值范围:
<profile-name&path>:带目录的ACL配置文件名,如:flash:/abc.txt,最多64个字符(带目录)。文件应保存于闪存。
访问级别:2
该命令用于添加主机路由。
语法1:host-route <A.B.C.D> interface giga-interface <module/port>
取值范围:
<A.B.C.D>:主机路由项的IP地址
<module/port>:单接口,(1/{1..16} or 2/{1..4})如:2/2,为最多32个字符的字符串
语法2:host-route <A.B.C.D> interface link-aggregation <lag-ID>
取值范围:
<lag-ID>:链路汇聚接口号:1至32
语法3:host-route <A.B.C.D> interface vlan <VLAN-ID> [sub-vlan <sub-VLAN-ID>] {member <ge<module#/port#> or lg#>}
取值范围:
<VLAN-ID>:超级VLAN ID,范围为1至4094
<sub-VLAN-ID>:子VLAN ID,范围为1至4094
<ge<module#/port#> or lg#>:单接口(ge<module#/port#> or lg#),为最多256个字符的ASCII字符串
访问级别:2
语法4: no host-route <A.B.C.D>
说明:删除路由。
访问级别:2
该命令用于从文件系统导入ACL配置文件。
语法:import <ACL-porfile-name> to <[classfier <class-id>] [profile<profile-id>]
取值范围:
<ACL-porfile-name>:string,64
<class-id>:1..32
<profile-id>:1..360
访问级别:2
该命令用于配置特定的GPON-OLT接口。
语法:interface gpon-olt <port>
取值范围:
<port>:单接口,{1-16}
系统提示:
telnet@P3116(config-t)# interface gpon-olt 1/1
telnet@P3116(config-t-if-gpon-olt-1/1)#
访问级别:1
有关GPON OLT接口配置模式下的命令的详细说明请参见Interface GPON-OLT命令。
该命令用于进入GE端口配置模式。
语法:interface giga-ethernet <module/port>
取值范围:
<module/port>:单接口,(module {1-2}/port {1-16})如:1/2,
系统提示:
telnet@P3116(config-t)# interf giga-ethernet 1/1
访问级别:1
有关接口千兆以太网配置模式下的命令的详细说明请参见GE 接口命令。
该命令用于进入链路汇聚配置模式。
语法:interface link-aggregation <interface ID>
取值范围:
<interface ID>:链路汇聚接口类型:组ID(1至32)
系统提示:
telnet@P3116(config-t)# interface link-aggregation 1
访问级别:1
有关链路汇聚接口配置模式下的命令的详细说明请参见Link Aggregation命令。
该命令用于删除链路汇聚配置模式。
语法:no interface link-aggregation <interface ID>
取值范围:
访问级别:1
该命令用于进入环回接口配置模式。
语法:interface loopback <loopback-interface-number>
取值范围:
<loopback-interface-number>:1-16, 环回接口号
系统提示:
telnet@P3116(config-t)# interface loopback 1
访问级别:2
有关环回接口配置模式下的命令的详细说明请参见Loopback命令。
该命令用于删除环回接口配置模式。
语法:no interface loopback <loopback-interface-number>
取值范围:
<loopback-interface-number>:1-16 环回接口号
访问级别:2
该命令用于删除pon保护组。
语法:no interface pon-protection-group <psg-id>
取值范围:
<psg-id>:1..8
访问级别:1
该命令用于创建pon保护组。
语法:interface pon-protection-group <psg-id>
取值范围:
<psg-id>:1..8
系统提示:
telnet@P3108(config-t)# interface pon-protection-group 1
telnet@P3108(config-pon-protection-grp-1)#
访问级别:1
该命令用于设置相互保护的端口。
语法:member-ports <workpon> <protcetpon> <typeB>
取值范围:
<workpon> work pon port <module/port> (module {1}/port). for example, 1/2 String
up to 8 chars
<protcetpon> work pon port <module/port> (module {1}/port). for example, 1/2 String
up to 8 chars
访问级别:2
该命令用于切换 work ponlink 至protect ponlink。
语法:manual-switch <w2p>
访问级别:1
该命令用于进入VLAN接口配置模式。
语法:interface vlan <VLAN interface ID>
取值范围:
<Interface ID>:VLAN接口ID:1- 4094
系统提示:
telnet@P3116(config-t)# interface vlan 4094
telnet@P3116(config-t-if-vlan-4094)#
访问级别:1
有关超级VLAN接口配置模式下的命令的详细说明请参见Interface VLAN命令。
该命令用于删除VLAN接口配置模式。
语法:no interface vlan <VLAN interface ID>
取值范围:
访问级别:1
该命令用于进入配置范围参数模式。
语法:interface range <range-value>
取值范围:
<range-value>:Interface range, Example, 'ge2/1,ge2/2-4' or 'lg2,lg4-6'.
系统提示:
telnet@P3116(config-t)# interface range ge2/1
telnet@P3116(config-t-if-range-ge2/1)#
访问级别:2
该命令用于定义网关地址。
语法1:ip default-gateway <ip address>
访问级别:2
该命令用于删除网关地址。
语法2:no ip default-gateway
访问级别:2
该命令用于配置IGMP模式。
语法:ip igmp mode <control | snooping-with-proxy | standard-snooping>
访问级别:2
该命令用于配置IGMP最后成员查询间隔。
语法: ip igmp parameter last-member-query-interval <sec>
取值范围:
<sec>:1..25
访问级别:1
该命令用于配置IGMP查询间隔。
语法: ip igmp parameter query-interval <sec>
取值范围:
<sec>:10..3600,默认125秒
访问级别:1
该命令用于配置IGMP最大查询响应间隔。
语法: ip igmp parameter query-response-interval <sec>
取值范围:
<sec>:1..25,缺省值:10
访问级别:1
该命令用于配置IGMP重试时间。
语法: ip igmp parameter robustness <sec>
取值范围:
<retry>:2..10
访问级别:1
该命令用于激活整个系统的IGMPsnooping。
语法:[no] ip igmp snooping
访问级别:2
该命令用于配置IGMP静态组。
语法:[no] ip igmp static-group <group-address> <multicast-vlan>
取值范围:
group-address:<A.B.C.D>
multicast-vlan:<1..4094>
访问级别:2
该命令用于激活整个系统的IGMP代理。
访问级别:2
该命令用于配置IP组播VLAN。
语法:ip multicast vlan <vid> <multi-vlan> <start> <end>
取值范围:
<vid>:1..256
<multi-vlan> :vlan id 1..4094
<start> :组播开始ip地址 范围 224.0.1.0到 239.255.255.255
<end> :组播结束ip地址 范围 224.0.1.0到 239.255.255.255
访问级别:2
该命令用于删除IP组播VLAN。
语法:[no] ip multicast vlan <vid>
取值范围:
<vid>:1..256
访问级别:2
该命令用于将多播VLAN配置为映射到多播GEM端口。
语法1:ip multicast vlan-to-gem <id> <start> <end> <multi-to-gem>
取值范围:
<id>:1..256
<start> :开始vlan 1..4094
<end> :结束vlan 1..4094
<multi-to-gem> :组播gemport 3800..3999
访问级别:2
该命令用于删除多播VLAN配置为映射到多播GEM端口。
语法2:no ip multicast vlan-to-gem <id>
取值范围:
<id>:1..256
访问级别:2
该命令用于在全局范围激活IP组播路由功能。
语法:[no] ip multicast-routing
访问级别:2
该命令用于在PPPOE (Point To Point Protocol Over Ethernet,以太网承载PPP协议) REQUEST 消息中删除/插入选项字段。
语法:[no] ip pppoe vlan-option <VLAN ID>
取值范围:
<VLAN ID>:1..4094
访问级别:0
该命令用于配置IP SNTP轮询间隔,单位为秒。
语法:ip sntp poll-interval <time>
取值范围:
<time>:IP SNTP轮询间隔值,16至16284(秒)
访问级别:2
该命令用于进行SNTP同步。
语法:ip sntp sync
访问级别:2
该命令用于配置IP SNTP时区。
语法:ip sntp time-zone <zone> [minutes]
取值范围:
<zone>:SNTP时区,-12至13
[minutes] :0..59
访问级别:2
该命令用于设置检测消息的以太网类型。
语法:loop-detect ether-type <ethertype>
取值范围:
<ethertype> :<0x600-0xffff>
访问级别:0
该命令用于设置检测周期。
语法:loop-detect interval <interval-value>
取值范围:
<interval-value> :10..86400秒
访问级别:0
该命令用于设置检测循环恢复时间。
语法:loop-detect recover-time<time>
取值范围:
<time> :1..1440分钟
访问级别:0
该命令用于设置动态MAC老化时间。
语法:mac-address-table aging-time <age-time>
取值范围:
<age-time>:动态老化时间值,范围60至86400秒。
缺省值:300秒
访问级别:2
该命令为每个接口添加静态MAC地址。
语法1:mac-address-table static <mac-address> vlan <VLAN-ID> interface <interface-type> <interface-ID>
取值范围:
<mac-address>:48位十六进制,格式:H:H:H:H:H:H
<VLAN-ID>:VLAN ID 1-4094
<interface-type>:千兆以太网(gigabitEthernet)或链路汇聚(linkAggregation)的关键字。
<interface-ID>:当<interface-type>为gigabitEthernet时,<interface-ID>应为接口千兆以太网<module/port> (1/port {1-16} or 2/port {1-4}),如:3/2,最多8个字符的ASCII字符串。
当<interface-type>为linkAggregation时,<interface-ID>应为1至32之间的整数。
说明:配置GE接口或LAG接口上的静态MAC地址。
访问级别:2
该命令用于在“config terminal”模式下为每个接口删除所有动态MAC地址。
语法2:no mac-address-table dynamic
说明:删除所有接口的动态MAC地址。
该命令用于删除一个或多个接口上的所有动态MAC地址。在configure terminal模式下采用该命令。
访问级别:2
语法3:no mac-address-table dynamic interface <interface-type> <interface-ID > (for each interface)
取值范围:
<interface-ID>:单板/端口(如:2/2)或链路汇聚组ID(如:5)。当<interface-type>为gigabitEthernet时,<interface-ID>的格式应为: ([module{1}/ports{1..16}] or [module{2}/ports{1..4}])。
当<interface-type>为linkAggregation时,<interface-ID>应为类似({1..32})(3,5-9)的字符串,最多64个字符。
说明:删除接口的动态MAC地址。
访问级别:2
该命令删除所有动态MAC地址。
语法:no mac-address-table dynamic mac <mac-address>
取值范围:
<mac-address>:MAC地址,格式为:<H:H:H:H:H:H>
访问级别:2
该命令从单个VLAN中删除所有动态MAC地址。在VLAN模式下采用该命令。
语法4:no mac-address-table dynamic vlan <VLAN-ID>
取值范围:
访问级别:2
该命令用于在configure terminal模式下删除系统中所有静态MAC地址或从单个VLAN删除某个MAC地址。
语法5:no mac-address-table static
语法6:no mac-address-table static [<mac-address>] interface <interface-type> <interface-ID>
Syntax7: no mac-address-table static [<mac-address>] vlan <VLAN-ID>
取值范围:
<mac-address>:48位十六进制,格式为:H:H:H:H:H:H
<interface-ID>:单板/端口(如:2/2)或链路汇聚组ID(如:5)。当<interface-type>为gigabitEthernet时,<interface-ID>的格式应为([module 1/port {1-16} or 2/port {1-4}])。
访问级别:2
该命令用于静态配置MAC转发表或过滤表的表项。
语法1:mac-filter <ge interface> <deny|permit> <MAC address>
取值范围:
<ge interface>:单接口(ge<module#/port#>)如:ge1/1,最多为256个字符的字符串。
Deny:静态配置MAC过滤表。
Permit:静态配置MAC转发表
<MAC address>:源MAC地址,格式为<H:H:H:H:H:H>。
访问级别:2
该命令用于删除静态配置MAC转发表或过滤表的表项。
语法2:no mac-filter <ge interface>
取值范围:
访问级别:2
该命令用于启用用户配置的qos设置。
语法1:mls qos cos-queue-map <cos> to <queueID>
取值范围:
<cos>:0..7
<queueID>:0..7
访问级别:2
该命令用于禁用用户配置的qos设置。
语法2:no mls qos cos-queue-map <cos> to<queueID>
取值范围:
<cos>:0..7
<queueID>:0..7
访问级别:2
该命令用于启用/关闭SPAN会话。
语法1:monitor session <value> <active|deactive>
取值范围:
<value>: 1
访问级别:2
该命令用于配置SPAN目标千兆位以太网接口。
语法2:monitor session<value> destination interface gigabitEthernet <interface>
取值范围:
<interface> :单一上行链路接口,<mode/port>(2/port{1-4})
访问级别:2
该命令用于配置SPAN源千兆位以太网接口。
语法3:monitor session <value> source interface gigabitEthernet <interface> [both|tx|rx]
取值范围:
<interface> :单一上行链路接口,<module/ports> (1/port {1-16} or 2/port {1-4})
[both|tx|rx]:both:监视接受和传输的流量;tx:只监视传输的流量;rx:只监视接受的;流量
访问级别:2
该命令用于删除SPAN会话配置。
语法4:no monitor session
访问级别:2
该命令用于删除ont mac地址筛选器或转发。
语法:no gpon profilemac-filter id <profile-id> <entry-id>
取值范围:
<profile-id>:1..16
<entry-id>:1..16
访问级别:0
该命令用于删除ONT动态多播模板。
语法:no gpon profile multicast-dynamic <profile-id> <profile-id2>
取值范围:
<profile-id>: 1..256
<profile-id2>:0..31
访问级别:0
命令用于删除ONU组播业务操作的模板。
语法:no pon profile multicast-oper <profile-id>
取值范围:
<profile-id>:1..256
访问级别:0
命令用于删除ONT静态组播的模板。
语法:no gpon profile multicast-static <profile-id1> <profile-id2>
取值范围:
<profile-id1>:1..256
<profile-id2>:0..31
访问级别:2
该命令用于删除多播用户视图配置。
语法:no gpon profile multicast-userview
访问级别:2
此命令用于删除DBA模板。
语法:no gpon profile dba <profile-id>
取值范围:
<profile-id>:1..256
访问级别:2
命令用于删除SIP代理配置文件。
语法:no gpon profile voip-sip-server <profile-id>
取值范围:
<profile-id>:1..2
访问级别:2
命令用于删除ONT 流量控制的模板。
语法:no gpon profile rate-ctrl <profile-id>
取值范围:
<profile-id>:1..128
访问级别:2
命令用于删除virtual port svc的模板
语法:no gpon profile vportsvc <profile-id>
取值范围:
<profile-id>:1..128
访问级别:2
命令用于删除一条tcont service profile。
语法:no gpon ptofile tcont-svc <profile-id>
取值范围:
<profile-id>:1..128}
访问级别:2
命令用于为T-CONT解绑定模板(vportsvc-profile,tcont-svc-profile)。
语法:no gpon profile tcont-bind <profile-id> { v-port <vport-vlaue> }
取值范围:
<profile-id>:1..128
<vport-vlaue>:1..16
访问级别:2
命令用于删除ONU业务流的模板。
语法:no gpon profile flow <profile-id1> <profile-id2>
取值范围:
<profile-id1>:1..128
<profile-id1>:0..127
访问级别:2
该命令用于设置OPM配置。
语法:olt-opm
系统提示:
telnet@P3116(config-t)# olt-opm
telnet@P3116(config-t-olt-opm)#
访问级别:2
该命令用于配置opm告警配置。
语法1:alarm <type> threshold<raise> <clear>
取值范围:
<type> :告警类型,如下:
VccHighAlarm
VccLowAlarm
VccHighWarning
VccLowWarning
TXBiasHighAlarm
TXBiasLowAlarm
TXBiasHighWarning
TXBiasLowWarning
TempHighAlarm
TempLowAlarm
TempHighWarning
TempLowWarning
TXPowerHighAlarm
TXPowerLowAlarm
TXPowerHighWarning
TXPowerLowWarning
RXPowerHighAlarm
RXPowerLowAlarm
RXPowerHighWarning
RXPowerLowWarning
<raise> :
temperature <-140..120>单位为1摄氏度,默认为零
voltage <0..65535>单位为1毫伏,默认为零
voltaic <0..100000>单位为1微安,默认为零
power <-65535..65535>单位为0.01 dBm,默认为零
<clear>:
访问级别:2
该命令用于删除opm告警配置。
语法2:no alarm <type> threshold
取值范围:
<type> :告警类型,如下:
VccHighAlarm
VccLowAlarm
VccHighWarning
VccLowWarning
TXBiasHighAlarm
TXBiasLowAlarm
TXBiasHighWarning
TXBiasLowWarning
TempHighAlarm
TempLowAlarm
TempHighWarning
TempLowWarning
TXPowerHighAlarm
TXPowerLowAlarm
TXPowerHighWarning
TXPowerLowWarning
RXPowerHighAlarm
RXPowerLowAlarm
RXPowerHighWarning
RXPowerLowWarning
访问级别:2
该命令用于设置/删除olt端口opm配置。
语法:[no] olt-port <mode/port>
取值范围:
<mode/port> :单接口,<1/port> (port{1..16}).
访问级别:2
该命令用于设置/删除ont opm配置。
语法:[no] ont <mod/port/lport>
取值范围:
<mod/port/lport> :module{1}/port{1..16}/lport{1..64}, or range, format 1-2/2-3/1-9.
访问级别:2
该命令用于设置opm状态。
语法:status <enable|disable>.缺省值:disable。
访问级别:2
该命令用于设置opm开始时间和结束时间。
语法:time <start-time> <period>
取值范围:
<start-time>:开始时间,格式为hh:mm字符串,最多64个字符
<period>: 1..8640 OLT OPM的循环周期。以10秒为单位
访问级别:2
该命令用于进入GPON配置模式。
语法:gpon
系统提示:
telnet@P3116(config-t)# gpon
telnet@P3116(config-t-gpon)#
访问级别:2
以下命令需要在GPON配置模式下运行。
该命令用于配置系统全局ONT的认证方式。
语法:ont authentication-mode < snonly | snandpassword | disable | passwordonly | loidonly | loidandcheckcode>
取值范围:
snOnly := Serial number only
snAndPassword = Serial number and password
disable = All ONU/ONTs are allowed to be activated always
PasswordOnly = Password only
loidoOnly = LOID only
loidAndcheCkcode = LOID and checkcode
缺省值:
snonly
访问级别:2
命令用于显示ONT的认证方式。
语法:show ont-authentication-mode
访问级别:0
此命令用于设置配置文件。
语法:profile
系统提示:
P3116(config-t-gpon)# profile
P3116(config-t-gpon-pro)#
访问级别:0
以下命令需要在profile配置模式下运行。
此命令用于增加DBA(Dynamic Bandwidth Assignment)模板。T-CONT是ONT上的物理资源,只有绑定了DBA模板后,才能够用于承载业务。当系统缺省的DBA模板不能够满足业务需求时,使用此命令新增一个DBA模板。
语法:dab id <profile-id> [name <profile-name>]
[ type1 fix <fix-bandwidth> ] [type2 assure <assure-bandwidth>]
[ type3 assure <assure-bandwidth> max <max-bandwidth> ]
[ type4 max <max-bandwidth> ]
[ type5 fix <fix-bandwidth> assure <assure-bandwidth> max <max-bandwidth>]
取值范围:
参数 |
参数说明 |
取值 |
id <profile-id> |
DBA模板编号。 |
数值类型,取值范围:1-256。 |
name <profile-name> |
DBA模板名称。 |
字符串类型,可输入的字符串长度为1-48个字符。 |
type1 |
配置类型为固定带宽的DBA模板。 |
type2 |
配置类型为保证带宽的DBA模板。 |
type3 |
配置类型为保证带宽+最大带宽的DBA模板。 |
type4 |
配置类型为最大带宽的DBA模板。 |
type5 |
配置类型为固定带宽+保证带宽+最大带宽的DBA模板。 |
fix fix-bandwidth |
固定带宽。此部分带宽固定分配给用户,即使该用户不使用,其他用户也不可以占用。 |
数值类型,取值范围:256Kbit/s- 1237248Kbit/s。 单位:Kbit/s。
assure assure-bandwidth |
保证带宽。此部分带宽分配给用户,如果用户没有使用,其他用户可以占用此部分带宽。 |
max max-bandwidth |
最大带宽。此带宽指某用户可以使用的最大的带宽值。 在type3类型的DBA模板中,最大带宽必须大于或等于保证带宽。 在type5类型的DBA模板中,最大带宽必须大于或等于固定带宽与保证带宽之和。 |
数值类型,取值范围:256Kbit/s-1244160Kbit/s。 单位:Kbit/s。 缺省值:1024 |
访问级别:2
命令用于建立ONU业务流的模板。
语法:flow id <profile-id1> <profile-id2>
[name <profile-name> ]
[uni-type <uni-type-value>]
[uni-port-bitmap <uni-port-bitmap-vlaue>]
[upmap-type <upmap-type-value>]
[ <vlan-start-value>]
[<vlan-stop-value>]
[pri-bitmap <pri-bitmap-vlaue>]
[vport-num <vport-num-vlaue>]
取值范围:
<profile-id2>:1..127
<profile-name>:string,1..48
<uni-type-value>:<ethernet-uni | ip-host|vei)>
<uni-port-bitmap-vlaue> 缺省值0xff,十六进制,以‘0x’开头
<upmap-type-value> <vlanId|priorityBits|vlanIdAndPriorityBits>
<vlan-start-value>:1..4095 缺省 101
<vlan-stop-value>:1..4095 缺省 101
<pri-bitmap-vlaue>:十六进制,以‘0x’开头 缺省 0xf
<vport-num-vlaue>:1..16 缺省 1
访问级别:2
该命令用于定义ont mac地址筛选器或转发。
语法:mac-filter id <profile-id> <entry-id> name <profile-name>
direction <source|destination>
<mac-address>
<forward|filter>
取值范围:
<profile-id>:1..16
<entry-id>:1..16
<profile-name>:string,1..32
<source|destination> mac地址模式 源地址|目标地址
<mac-address> :<xx:xx:xx:xx:xx:xx>MAC地址
<forward|filter>:设置mac过滤器类型 转发|筛选
访问级别:2
该命令用于创建ONT动态多播模板。
语法:multicast-dynamic id <profile-id> <profile-id2> name <profile-name>
gemport<gemport-value>
vlanid<vlanid-vlaue>
[srcip <srcip -value>]
[grpaddr-start <grpaddr-start-value>]
[grpaddr-stop <grpaddr-stop-vlaue>]
[grpbw<grpbw-vlaue>]
取值范围:
<profile-id2>:0..31
<profile-name>:string, 1..48
<gemport-value>:3800..3999
<vlanid-vlaue>:2..4093
<srcip -value>:<A.B.C.D> 源ip地址
<grpaddr-start-value>:<A.B.C.D>组播开始地址:(ip limit:224.0.1.0 - 239.255.255.255)
<grpaddr-stop-vlaue>:<A.B.C.D>组播结束地址:(ip limit:224.0.1.0 - 239.255.255.255)
<grpbw-vlaue>:0..31 设置组播bandwidth 值
访问级别:2
命令用于建立ONU组播业务操作的模板。
语法:multicast-oper id <profile-id> name <profile-name>
igmp-ver <igmp-ver-value>
ctrl-mode <ctrl-mode-vlaue>
fastleave <enable|disable>
[us-tci-pbits <us-tci-pbits-value>]
[us-tag-ctrl-grp <us-tag-ctrlp-vlaue>]
[ds-tci-pbits <ds-tci-pbits-vlaue>]
[ds-tag-ctrl <ds-tci-pbits-vlaue>]
[ds-tci-vlanId <ds-tci-vlanId-vlaue>]
[us-tci-vlanId <us-tci-vlanIdvlaue>]
取值范围:
<profile-id>:1..256
<igmp-ver-value>:<v1| v2| v3>
<ctrl-mode-vlaue>:<snooping-only>
<enabled|disabled> :< enabled|disabled>
<us-tci-pbits-value>:0..7
<us-tag-ctrl-vlaue>: <pass(0)|add(1)|replace(2)|rep-vid-only(3)>
<ds-tci-pbits-vlaue>:0..7
<ds-tci-pbits-vlaue>:<pass(0)|add(1)|replace(2)|rep-vid-only(3)>
<ds-tci-vlanId-vlaue>:0..4094
<us-tci-vlanIdvlaue>:0..4094
访问级别:2
命令用于建立ONT静态组播的模板。
语法:multicast-static id <profile-id1> <profile-id2>
gemport <gemport-value>
vlanid <vlanid-vlaue>
[srcip <srcip-value>]
[grpaddr-start<grpaddr-start-value>]
[grpaddr-stop <grpaddr-stop-value>]
[grpbw <grpbw-vlaue>]
取值范围:
<profile-id2>:0..31
<srcip-value> :IPaddress
<grpaddr-start-value> IPaddress:(ip limit:224.0.1.0 - 239.255.255.255)
<grpaddr-stop-value> IPaddress:(ip limit:224.0.1.0 - 239.255.255.255)
<grpbw-vlaue> 0..31
访问级别:2
命令用于使用指定的速率控制(PIR、CIR值)和调度策略(SP、WRR等)创建ONU配置文件。
语法:rate-ctrl id <profile-id1>
name <profile-name>
sir<sir-value>
pir <pir-vlaue>
取值范围:
<sir-value>:128..1244160
<pir-vlaue>:128..1244160
访问级别:0
命令用于为T-CONT绑定模板(vportsvc-profile,tcont-svc-profile)。T-CONT是ONT上的物理资源,只有绑定了模板后,才能够用于承载业务。绑定成功后,T-CONT可以依据绑定模板中的不同配置,提供灵活的动态带宽分配方案。
语法:tcont-bind id <profile-id> { v-port <vport-vlaue> }
[ profile-name <profile-name> ]
[vportsvc-id <vportsvc-id-value>]
[tcon-id <tont-id-vlaue>]
[tcontsvc-id <tcontsvc-id-value>]
取值范围:
<profile-id>:1..128
<vport-vlaue>:1..16
<vportsvc-id-value>:1..128
<tont-id-vlaue>:1..8
<tcontsvc-id-value>:1..128
访问级别:0
命令用于创建一条tcont svc-profile,关联dba-profile。
语法:tcont svc id <profile-id> [name <profile-name> ] [ dba-id <dba-profile-id> ]
取值范围:
<profile-id>:1..128
<profile-name>:1..48
<dba-profile-id>:1-256
访问级别:2
命令用于创建SIP代理配置文件。
语法:voip-sip-server id <profile-id> name <name-value>
proxy-addr<proxy-addr-value>
external-proxy-addr<vportsvc-id-value>
registering-addr<registering-addr-vlaue>
[tcp-port <tcp-port-value>]
取值范围:
<profile-id>:1..4
<name-value>:string
<proxy-addr>:string
<external-proxy-addr>:string
<registering-addrvalue> :string
<tcp-port-vlaue>:0..65535
访问级别:2
命令用于创建virtual port svc的模板。
语法:vportsvc id <profile-id> [name <profile-name> ] [ us-pri < us-pri-value> ] [ usratectrl-id<usratectrl-id-value> ] [ dsratectrl-id <dsratectrl-id-value> ]
取值范围:
<profile-id>:1..128
<profile-name> :string
<us-pri-value> :0..7
<usratectrl-idvalue> :0..128
<dsratectrl-id-value> :0..128
访问级别:2
命令用于显示DBA(Dynamic Bandwidth Assignment)模板参数。
语法:show gpon profile dba <profile-id | all>
取值范围:
<profile-id | all>:string ,.1..256 | all=全部
访问级别:0
命令用于显示ONT流量控制的模板的参数。
语法:show gpon profile rate-ctrl <profile-id | all>
取值范围:
<profile-id | all>:1..128 | all=全部
访问级别:1
命令用于显示指定的或者全部的virtual port svc的模板的配置参数。
语法:show gpon profile vportsvc <profile-id | all>
取值范围:
<profile-id>:{1..128}| all 显示所有的
访问级别:2
命令用于显示tcont service profile。
语法:show gpon profile tcont-svc <profile-id | all>
取值范围:
<profile-id | all>:string ,.1..128 | all=全部
访问级别:1
命令用于为显示T-CONT绑定模板(vportsvc-profile,tcont-svc-profile)的参数。
语法:show gpon profile tcont-bind <profile-id | all>
取值范围:
访问级别:1
命令用于显示指定ONU业务流的模板的参数。
语法:show gpon profile flow < profile-id1> | all>
取值范围:
<< profile-id1 | all>:string ,.{1..128 } | all=全部
访问级别:1
命令用于显示指定ONT组播业务操作的模板参数。
语法:show gpon profile multicast-oper < profile-id> | all>
取值范围:
<< profile-id> | all>:string ,1..256 | all=全部
访问级别:1
命令用于显示指定ONT静态组播的模板的参数。
语法:show gpon profile multicast-static < profile-id1 / profile-id2 {1..256}/{0,31}|all>
访问级别:1
该命令用于进入ONU升级配置模式。
语法:ont-upgrade
系统提示:
P3116(config-t)# ont-upgrade
P3116(config-t-ont-ugp)#
访问级别:2
以下命令需要在ONU升级配置模式下运行。
该命令用于启用ONU自动升级。
语法1:auto-upgarde <mod/port> start <start-time> end <end-time> filename <filename-vlaue> equip-id <equip-id-value>
取值范围:
<mod/port>:单接口,<1/port> (port{1..16})
<start-time>:开始时间(小时)0..23
<end-time>:结束时间(小时)0..23
<filename-vlaue> :onu升级包文件名,文件名字符串最多64个字符
<equip-id-value>:设置onu设备id,最多64个字符
访问级别:0
该命令用于启用ONU手动升级。
语法1:manual-upgrade <mod/port/lport> filename <filename-vlaue> equip-id <equip-id-value>
取值范围:
<mod/port/lport>:mode{1}/port{1..16}/lport{1..64},或范围,格式1-2/2-3/1-9,最多256个字符
<filename-vlaue>:onu升级包文件名,文件名字符串最多64个字符
访问级别:0
该命令用于配置ONU升级的ftp server(如果升级文件在本地没有,则去ftp获取)。
语法:upgrade-ftp <A.B.C.D> <username> <password>
取值范围:<A.B.C.D> 合法的IP地址
<username> 字符串,长度小于23.
<password> 字符串,长度小于15.
访问级别:2
该命令用于激活/关闭SNTP客户端。
语法:[no] service sntp client
访问级别:2
该命令用于配置SNTP服务器。
语法:
sntp server <server-ip-addr> [version-number]
no sntp server <server-ip-address>
取值范围:
<server-ip-addr>:SNTP 服务器IP地址
[version-number]:SNTP服务器版本号(1至4)
访问级别:2
该命令用于设置生成树操作模式。
语法1:spanning-tree mode rstp
访问级别:2
该命令用于删除生成树操作模式。
语法2:no spanning-tree mode
访问级别:2
该命令用于设置VLAN交换机生成树。
语法1:spanning-tree vlan <vlanId> [802dot1t-support<enable|disable>] [forward-delay-time <delayTime>] [hello-time <helloTime>] [max-age-time <maxAgeTime>] [priority <priority>]
取值范围:
<vlanId>:1
<delayTime>:4..30秒 该VLAN设置转发延迟时间
<helloTime>:1..10秒 该VLAN设置Hello时间
<maxAgeTime>:6..40秒 设置最大老化时间
<priority>:0..65535 设置桥接优先级 该值必须为4096的倍数。
允许的值为:
0 4096 8192 12288 16384 20480 24576 28672 32768 36864 40960 45056 49152 53248 57344 61440
访问级别:2
该命令用于删除VLAN交换机生成树。
语法2:no spanning-tree vlan <vlanId>
取值范围:
<vlanId>:1
访问级别:2
该命令用于用户隔离控制。
语法:user-isolation <enable|disable-standard|disable-enhanced>
访问级别:2
该命令用于创建VLAN并进入VLAN配置模式。
语法:vlan {VLAN-ID} [VLAN-name]
取值范围:
{VLAN-ID}:1-4094。VLAN 1为缺省值,不需要配置。
[VLAN-name]:最多16个字符的ASCII字符串。
系统提示:
telnet@P3116(config-t)# vlan 333
访问级别:2
以下命令需要在VLAN配置模式下运行。
语法:name <VLAN-name>
取值范围:
<VLANname>:最多16个字符的ASCII字符串。
说明:VLAN的ASCII字符串格式名称。
访问级别:2
该命令用于将L2接口(GE端口或链路汇聚组)分配到IEEE 802.1Q VLAN。
语法:
member <member -list> {tagged | untagged}
no member <member -list>
取值范围:
<member-list>:接口ID或接口范围、单板/端口格式或范围格式,如“ge2/2”或“ge2/1-2, ge2/4, lg6”,其中“ge”表示“Giga-Ethernet”,“lg”表示“链路汇聚组”,为最多32个字符的字符串。
{tagged}:添加VLAN为标签端口。
{untagged}:添加VLAN为非标签端口。
访问级别:2
如果要从某个VLAN删除成员,删除的成员必须属于该VLAN。否则会出现以下提示:“错误:端口xxx不属于VLAN yyy”。
该命令用于配置接口的PVID,包括链路汇聚组和当前VLAN ID。
语法:pvid <member-list>
取值范围:
<member-list>:单接口(ge<module#/port#> or lg#) 如:ge3/2;或接口范围(ge<module#/port#>[-port#],.lg# [-#],)为最多32个字符的ASCII字符串。
访问级别:2
该命令用于激活并配置VLAN的IGMP snooping(带特殊参数)。
语法1: ip igmp snooping <fast-leave|last-member-age-timer <last-member-age-time>
|mc-age-timer <mc-age-time>|router-age-timer <router-age-time>
|src-only-mc-age-timer <src-only-mc-age-time>|{static <static-ip> interface <list>}>
取值范围:
<fast-leave>:配置IGMP Fast Leave(快速离开)。
<last-member-age-time>:最后的组成员的老化时间,单位为秒。 1..65535
<mc-age-time>:组播组时长。如果没有刷新,组播组在创建后经过了“组播老化时间”后会消失。 1..65535
<router-age-time>:路由器老化时间,单位为秒。1..65535
<src-only-mc-age-time>:源端组播老化时间,单位为秒。取值范围:1..65535
<static-ip>:配置静态组播IP地址。224.0.0.1 .. 239.255.255.255
<list>:单接口(ge<module#/port#>或lg#)例如,ge3/2或接口范围(ge<module#/port#>[-port#],..lg#[-#],..)字符串最多32个字符
访问级别:2
该命令用于关闭VLAN的IGMP snooping(带特殊参数)。
语法2:[no] ip igmp snooping <fast-leave|last-member-age-timer |mc-age-timer |router-age-timer|src-only-mc-age-timer |{static <static-ip> interface <list>}>
取值范围:
访问级别:2
IGMP snooping可按VLAN或整个系统激活。有关整个系统的IGMP snooping,请参见ip igmp snooping。
语法 1:vlan-option circuit <circuitId> remote <remoteId>
取值范围:
<circuitId>:DHCP和PPPOE包的选项字段的内容。允许的字段有"slot", "port", "lport", "vlan", "mac"。前缀为"$"。例如:$slot$port$vlan。
<remoteId>:DHCP和PPPOE包的选项字段的内容。允许的字段有"slot", "port", "lport", "vlan", "mac"。前缀为"$"。例如:$slot$port$vlan。
访问级别:2
说明:circuitId和remoteId可从允许字段中选择不同的字段。
语法 2: vlan-option mode ctc
访问级别:2
说明: 设置VLAN选择为CTC模式
语法 3: no vlan-option
访问级别:2
说明: 删除VLAN设置选择字段
语法 4:no vlan-option mode
访问级别:2
说明: 恢复缺省模式
该命令用于配置VLAN范围。
语法:vlan-option <Starting vlan ID> <Ending vlan ID>
取值范围:
<Starting vlan ID>:2..4094
<Ending vlan ID>:2..4094
访问级别:2
该命令用于删除配置VLAN范围。
语法:no vlan-option <Starting vlan ID> <Ending vlan ID>
取值范围:
访问级别:2
该命令用于进入接口千兆以太网(interface giga-ethernet)配置模式。
语法:interface <interface type> <moudle/port>
取值范围:
<interface type>:千兆以太网的关键字
<module/port>:单接口,({1-2}/{1-16})如:2/2
访问级别:2
GE接口配置模式下可运行以下命令。
Module:1 internal port <1-16>
Module:2 uplink port <1-4>, 1-2 : 10G port /3-4 Ge port
该命令用于使一个端口同时加入多个VLAN
语法: add-to vlan <vlan ID> {tagged | untagged}
取值范围:
<vlan ID>: for example: 3,5,7-9. String up to 64chars
访问级别:2
该命令用于将储存在数据库中的ACL列表应用/不应用于接口。
语法:[no] apply-access-list filename1
取值范围:
<filename1>:ACL列表名称,ACL单个文件(<file1>),例如a1或多个文件(<file1,file2..file7..>),例如a1,a2..a5....
访问级别:2
该命令用于将储存在数据库中的ACL配置文件应用/不应用于接口。
语法1:apply-acl-profile <profile-ID>
语法2:no apply-acl-profile
取值范围:
<profile-ID>:1~32
访问级别:2
该命令用于激活/关闭端口速率自协商功能。
语法:[no] auto-negotiation
访问级别:2
该命令用于从单个或多个VLAN中删除接口。
语法:delete-from vlan <vlan-list>
取值范围:
<vlan-list>: VLAN列表,最多可达32个字符。如:3,5,7-9 。
访问级别:2
语法:description <des-string>
取值范围:
des-string:描述该接口的字符串(最多255个字符)
访问级别:2
该命令用于激活/关闭流量控制。
语法:[no] flowcontrol receive|transmit
访问级别:2
该命令用于启用/禁用当前接口的vlan筛选器。
语法:[no] ingress-filter
访问级别:2
该命令用于设置所需的接口工作模式。
语法:interface-mode <mode>
取值范围:
<mode>:<SGMII|FIBER|XGMII>
访问级别:2
该命令用于配置千兆以太网接口的主备IP地址。
语法:[no] ip address <ip-address> <subnet-mask> [secondary]
取值范围:
[secondary]:可选参数。采用该关键字指定接口IP地址为备用IP地址。如果没有该选项,所配置的地址为主用IP地址。
系统最多支持32个备用IP地址。
说明:设置接口的IP地址。在分配IP地址之前,接口必须处于3层模式。
访问级别:2
必须在端口处于3层模式时分配IP地址,即,在运行该命令前运行“no switchport”命令。如果处于2层模式,会出现错误提示“错误:当前交换模式不能配置该特性”。
该命令用于配置IP IGMP最后成员查询间隔,单位为秒。
语法:ip igmp last-member-query-interval <sec>
取值范围:
<sec>:1-25
缺省值:1
访问级别:2
该命令用于配置IP IGMP查询间隔,单位为秒。
语法:ip igmp query-interval <sec>
取值范围:
<sec>:10-3600秒
缺省值:125秒
访问级别:2
该命令用于配置IP IGMP查询响应间隔,单位为秒。
语法:ip igmp query-response-interval <sec>
取值范围:
<sec>:1-25秒
缺省值:10秒
访问级别:2
该命令用于配置IP IGMP的重传次数。
语法:ip igmp robutness <2-10>
取值范围:2-10
缺省值:2
访问级别:2
该命令用于配置IP IGMP启动查询间隔,单位为秒。
语法:ip igmp startup-query-interval <sec>
取值范围:
<sec>:10-3600秒
缺省值:1/4查询间隔
访问级别:2
该命令用于激活/关闭IP IGMP静态组IP地址。
语法:[no] ip igmp static-group <A.B.C.D>
取值范围:
<A.B.C.D>:组IP地址,224.0.1.0至239.255.255.255
访问级别:1
该命令用于配置IP IGMP未请求的上报间隔,单位为秒。
语法:ip igmp unsolicited-report-interval <sec>
取值范围:
<sec>:10-3600秒
缺省值:10秒
访问级别:2
该命令用于激活/关闭IP IGMP版本。
语法:[no] ip igmp version <ver#>
取值范围:
<ver#>:1-3
当前只支持版本2。如果用户输入其他版本号,应出现错误提示:“错误:系统只支持igmp v2。”
缺省值:2
访问级别:2
该命令用于激活当前接口的IGMP代理。
语法:[no] ip igmp-proxy
访问级别:1
该命令用于设置IP组播过滤器状态。
语法:[no] ip multicast filter
访问级别:2
该命令用于设置上行端口的“Inter-Packet Gap”值。
语法:ipg <gap-value>
取值范围:
gap-value:数据包之间的间隙值,单位为字节<8..31>。
访问级别:2
该命令用于配置当前接口的最大帧大小。
语法:max-frame <maximum frame-size>
缺省值:1532
取值范围:<64..12288>
访问级别:2
该命令用于激活/关闭MLS QoS配置模式。
语法:[no] mls qos
访问级别:2
缺省值:MLS Qos disable。
该命令用于配置mls qos trust。
语法:[no] mls qos map trust < dscp | ip-prec >
缺省值:no trust。
访问级别:2
该命令用于配置dscp到cos映射。
语法:[no] mls qos map dscp-cos < dscp-value> to <cos-value>
取值范围:
<dscp-value>:0 ..63
<cos-value>:0..7
访问级别:2
该命令用于配置dscp到mutation映射。
语法:[no] mls qos map dscp-mutation< dscp-value> to <mutation-value>
取值范围:
<dscp-value>:0 ..63
<mutation-value>:0..63
访问级别:2
该命令用于配置ip prec到dscp映射。
语法:[no] mls qos map ip-prec-dscp< ip-prec-dscp-value> to <dscp-value>
取值范围:
<ip-prec-dscp-value>:0..7
<dscp-value>:0 ..63
访问级别:2
该命令用于配置优先级队列的严格优先级或权重。
语法1:mls qos queue-set output <queue ID> strict-priority
语法2:mls qos queue-set output <queue ID> wrr <weight>
取值范围:
<queue ID>:0 - 7
strict-priority:给该队列分配严格优先级。
Wrr:权重轮询关键字
<weight>:1 - 127
缺省值:
Cos队列:0 1 2 3
Weights: 2 4 6 8
访问级别:2
该命令用于删除某个队列已分配的优先级。
语法3:no mls qos queue-set output <queue ID>
取值范围:
<queue ID>:0 - 7
访问级别:2
该命令用于配置当前接口基于端口的VLAN ID(PVID)。
语法:pvid <VLAN-ID>
取值范围:
<VLAN-ID>:VLAN ID 1 - 4094
访问级别:1
该命令用于设置最大的输入/输出帧大小,单位为百兆字节。
语法1:rate-limit <input|output> <limit-rate>
语法2:rate-limit <input|output> <limit-rate> burst-size <burstSize>
取值范围:
< limit-rate >:<1..10000>。速率限制带宽(M)。
<burstSize>:<<4|8|16|32|64|128|256|512>
访问级别:2
该命令用于清除最大的输入/输出帧大小配置。
语法3:no rate-limit <input|output>
访问级别:2
该命令用于激活/关闭接口管理状态。
语法:[no] shutdown
访问级别:1
该命令用于指定生成树协议所使用的链路类型。
语法:spanning-tree link-type <p2p|shared>
访问级别:2
该命令用于更改实例的接口生成树通道代价。
语法:spanning-tree mst <mst-id> cost <pathcost>
取值范围:
<mst-id>:0..15
<pathcost>:1..200000000
访问级别:2
该命令用于更改实例的接口生成树端口优先级。
语法:spanning-tree mst <mst-id> port-priority <priority>
取值范围:
<mst-id>:0..15
<priority>:0..240,该值必须为16的倍数。
访问级别:2
该命令用于激活接口上的portfast。
语法1:spanning-tree portfast
语法2:no spanning-tree portfast
访问级别:2
该命令用于设置该VLAN该端口的通道代价。
语法:spanning-tree vlan <vlan-id> cost <cost>
取值范围:
<vlan-id>:1..1
<cost>:1..200000000
访问级别:2
该命令用于设置该端口的端口优先级。
语法:spanning-tree vlan <vlan-id> port-priority <priority>
取值范围:
<vlan-id>:1...1
访问级别:2
语法:spanning-tree vlan <vlan-id> portfast
取值范围:
<vlan-id>:1...1
访问级别:2
该命令用于配置业务风暴控制。低于每个接口配置级别。
语法:storm-control {broadcast|multicast|unicast} {<value>|<disable>}
取值范围:
broadcast:广播地址风暴控制
multicast:组播地址风暴控制
unicast:单播地址风暴控制
<value>:0-1000000,单位pps
<disable>:关闭风暴控制功能。
缺省值:
broadcast:enable,value值为131
multicast:disable
unicast:enable,value值为131
访问级别:1
说明:每次配置更改时,系统将提示如下警告。
Warning: Arbitrary dropping of certain types of broadcast frames can result in networks instability that in some cases can melt down the network.
该命令用于将物理千兆以太网口配置为2层端口。
语法1:switchport
访问级别:2
该命令用于将物理千兆以太网口配置为3层端口。
语法2:no switchport
访问级别:2
该命令用于进入链路汇聚配置模式。
语法:[no] interface link-aggregation <group ID>
取值范围:
<group ID>:链路汇聚接口类型:组ID为1至32。
说明:使用[no]命令删除链路汇聚组成员。
访问级别:2
链路汇聚接口配置模式下,可运行以下命令。
该命令用于将链路汇聚组以标签或非标签模式添加到多个VLAN。VLAN的范围必须为递增顺序而不是递减顺序。
语法:add-to vlan <VLANID> <tagged | untagged>
取值范围:
<VLANID>:1-4094。一组VLAN(如:101-200),为最多12个字符的ASCII字符串
{tagged | untagged}:VLAN中的标签/非标签链路汇聚组
访问级别:2
该命令将数据库存储的ACL列表应用于/不应用于接口。
语法:[no] apply-access-list filename1,[filename2..]
取值范围:
<filename1>:ACL列表名称
访问级别:2
该命令用于将数据库存储的ACL配置文件应用于接口。
语法:
取值范围:
<profile-ID>:配置文件的标识号为1至32。
说明:使用[no]命令关闭将数据库存储的ACL配置文件应用于接口。
访问级别:2
该命令用于从多个VLAN删除链路汇聚组,无论其为标签或非标签模式。VLAN的范围必须为递增顺序而不是递减顺序。
语法:delete-from vlan <VLANID>
取值范围:
VLANID:1-4094,一组VLAN(如:101-200),为最多32个字符的ASCII字符串
访问级别:2
该命令用于添加当前链路汇聚接口的说明。
语法:
no description
取值范围:
<des-string>:描述该接口的ASCII字符串,最多16个字符
说明:使用[no]命令删除当前链路汇聚接口的说明。
访问级别:2
该命令用于设置接收/发送流量控制功能。
语法:[no] flowcontrol <receive | transmit>
说明:使用[no]命令重设接收/发送流量控制功能。
访问级别:2
该命令用于激活/关闭入口过滤器。
访问级别:2
该命令用于配置接口的IP地址。
语法1:ip address <ip-address> <subnet-mask> [secondary]
取值范围:
[secondary]:可选参数。用该关键字指定接口IP地址为备用IP地址。如果没有该选项,所配置的地址为主用IP地址。
系统支持最多32个备用IP地址。
访问级别:2
该命令用于配置接口的IP地址。
语法2:no ip address <ip-address> <subnet-mask>[secondary]
取值范围:
系统支持最多32个备用IP地址。
访问级别:2
取值范围:
<sec>:1-3600秒
缺省值:1秒
访问级别:2
取值范围:
<sec>:10-3600秒
缺省值:125秒
访问级别:2
取值范围:
<sec>:1-25秒
缺省值:10秒
访问级别:2
取值范围:2-10
缺省值:2
访问级别:2
该命令用于配置IP IGMP的启动查询间隔,单位为秒。
取值范围:
<sec>:10-3600秒
缺省值:1/4查询间隔
访问级别:2
取值范围:
<A.B.C.D>:组IP地址,224.0.2.0至239.255.255.255
访问级别:2
取值范围:
<sec>:10-3600秒
缺省值:10秒
访问级别:2
取值范围:
<ver#>:1-3
访问级别:2
该命令用于激活当前接口的IGMP代理。
访问级别:1
该命令用于设置IP组播过滤器状态。
访问级别:2
该命令用于创建负载均衡方法(只在创建链路汇聚组时需要)。
语法:load-balance <src-MAC | dst-MAC | src-IP | dst-IP | src-dst-IP | src-dst-MAC >
取值范围:
dst-IP:目的IP地址
dst-MAC:目的MAC地址
src-dst-IP:源/目的IP地址
src-dst-MAC:源/目的MAC地址
src-IP:源IP地址
src-mac:源MAC地址
说明:创建汇聚组后不可配置。
访问级别:2
该命令用于设置当前接口接收的最大帧的大小。
语法:max-frame <64..65535>
访问级别:2
该命令用于在“接口链路汇聚<groupID>”模式添加链路汇聚组的成员。
语法:[no] member <member-list>
取值范围:
<member-list>:最多32个字符的字符串。<slot/port>:<2/1-4>
访问级别:2
语法:[no] mls qos
访问级别:2
缺省值:mls qos disable。
该命令用于配置MLS QoS map trust。
缺省值:No trust
访问级别:2
该命令用于配置dscp到cos映射。
取值范围:
<dscp-value>:0 ..63
<cos-value>:0..7
访问级别:2
取值范围:
<dscp-value>:0 ..63
访问级别:2
取值范围:
<dscp-value>:0 ..63
访问级别:2
该命令用于选择需要分配优先级的队列。
取值范围:
<queue ID>:0 - 3
wrr:权重轮询关键字
<weight>:1 - 127
缺省值:
Cos队列:0 1 2 3
权重: 2 4 6 8 0
访问级别:2
该命令用于删除某个队列所分配的优先级。
取值范围:
<queue ID>:0 - 3
访问级别:2
语法:pvid <VLAN-ID>
取值范围:
访问级别:1
该命令用于配置链路汇聚的管理状态。
语法:[no] shutdown
访问级别:2
访问级别:2
语法:spanning-tree mst <MST id> cost <pathcost>
取值范围:
<MST id>:0..15
访问级别:2
语法:spanning-tree mst <MST id> port-priority <priority>
取值范围:
<MST id>:0..15
访问级别:2
该命令用于激活/关闭端口的spanning-tree属性为portfast。
语法:[no] spanning-tree portfast
访问级别:2
该命令用于设置该VLAN该端口的路径开销。
语法:spanning-tree vlan <vlan-id> path-cost <cost>
取值范围:
<vlan-id>:1...1
<cost>:1..200000000
访问级别:2
该命令用于设置该端口的端口优先级。
语法3:spanning-tree vlan <vlan-id> port-priority <priority>
取值范围:
<vlan-id>:1...1
访问级别:2
取值范围:
broadcast:广播地址风暴控制
multicast:组播地址风暴控制
unicast:单播地址风暴控制
<disable>:关闭风暴控制功能。
缺省值:
multicast:disable
访问级别:1
说明:每次配置更改时会出现以下警告提示。
该命令用于倒换/不倒换3层与2层模式之间的接口。
语法:[no] switchport
说明:设置倒换模式特性。
访问级别:2
该命令用于进入环回接口配置模式。
语法:[no] interface loopback <loopback-interface-number>
取值范围:
<loopback-interface-number>:1-16,环回接口号
访问级别:2
环回接口配置模式下可运行以下命令。
该命令用于描述环回接口。
取值范围:
<des-string>:描述环回接口的ASCII字符串,最多255个字符
访问级别:2
该命令用于设置环回接口的接口IP地址。
取值范围:
<ip-address>:IP地址
<subnet-mask>:子网掩码
系统支持最多32个备用IP地址。
访问级别:2
说明:使用[no]命令删除环回接口的接口IP地址。
该命令用于配置接口管理状态。
语法:[no] shutdown
说明:使用[no]命令关闭环回接口管理状态。
访问级别:2
该命令用于进入接口范围配置模式。
语法:interface range <interface range>
取值范围:
<interface range>:接口范围格式,如:“ge2/1,ge2/2-4”或“lg2,lg4-6”。但接口必须是同样的类型。GE接口范围只包含GE端口。LG组范围只包含LG组。是最多256个字符的字符串。
说明:必须是相同类型的一组接口,(ge[ports{1..16}]),如:ge1、ge2-4。
接口范围配置模式下可运行以下命令。
访问级别:2
该命令用于激活/关闭 MLS QoS配置模式。
语法:[no] mls qos
访问级别:2
缺省值:No trust
访问级别:2
该命令用于配置dscp到cos映射。
取值范围:
<dscp-value>:0 ..63
<cos-value>:0..7
访问级别:2
取值范围:
<dscp-value>:0 ..63
访问级别:2
取值范围:
<dscp-value>:0 ..63
访问级别:2
该命令用于选择需要分配优先级的队列。
取值范围:
<queue ID>:0 - 3
wrr:权重轮询关键字
<weight>:1 - 15
缺省值:
Cos队列:0 1 2 3
权重: 2 4 6 8
访问级别:2
该命令用于删除某个队列所分配的优先级。
取值范围:
<queue ID>:0 - 3
访问级别:2
语法:pvid <VLAN-ID>
取值范围:
访问级别:1
语法:[no] switchport
访问级别:2
该命令用于进入VLAN接口配置模式。
语法:[no] interface vlan <VLAN interface ID>
取值范围:
<Interface ID>:VLAN接口ID 1- 4094
说明:使用[no]命令删除交换虚拟接口或超级SVI。
访问级别:2
VLAN接口配置模式下可运行以下命令。
该命令用于将储存在数据库中的ACL列表应用/不应用于VLAN接口。
取值范围:
<filename1>:ACL列表名称。
访问级别:2
该命令用于将储存在数据库中的ACL配置文件应用/不应用于SVI接口。
取值范围:
<profile-ID>:1~32
访问级别:2
该命令用于描述VLAN接口。
取值范围:
<des-string>:描述该VLAN的字符串(最多255个字符)
访问级别:2
该命令用于配置SVI接口的主备IP地址。
取值范围:
系统最多支持32个备用IP地址。
访问级别:2
取值范围:
<sec>:1-25秒
缺省值:1秒
访问级别:2
取值范围:
<sec>:10-3600秒
缺省值:125秒
访问级别:2
取值范围:
<sec>:10-25秒
缺省值:10秒
访问级别:2
取值范围:2-10
缺省值:2
访问级别:2
取值范围:
<sec>:10-3600秒
缺省值:1/4查询间隔
访问级别:2
取值范围:
访问级别:2
取值范围:
<sec>:10-3600秒
缺省值:10秒
访问级别:2
该命令用于激活/关闭 IP IGMP版本。
取值范围:
<ver#>:1-3
访问级别:2
该命令用于激活当前接口的IGMP代理。
访问级别:1
该命令用于配置超级SVI的成员。
语法:[no] member-vlan <member-list>
访问级别:2
该命令用于激活/关闭VLAN接口管理状态。
语法:[no] shutdown
访问级别:1
该命令用于配置SVI到超级SVI。
语法:[no] super-svi
访问级别:2
采用超级SVI的主要目的是减少3层模式下使用的IP地址的数量。
该命令用于进入GPON-OLT槽位配置模式。
语法:interface gpon-olt <1/port>
取值范围:
<1/port>:port{1...16}
访问级别:1
接口gpon-olt配置模式下可运行以下命令。
该命令用于批量激活ONU。
语法:active <logical-port>
取值范围:
<logical-port> onu范围, 格式1、1-2、1、3、4,最多256个字符
访问级别:2
该命令用于去批量锁定ONU。
语法1:deactive <logical-port>
取值范围:
访问级别:2
该命令用于配置所有ont。
语法1:all-ont <mode>
取值范围:
<mode> : <enable>
访问级别:2
该命令用于配置接口特定描述。
语法1:description <description-value>
取值范围:
<description-value> : string,最多256个字节
访问级别:0
该命令用于禁用序列号ont。
语法1:description <logical-port>
取值范围:
<logical-port> : onu范围, 格式1、1-2、1、3、4,最多256个字符
访问级别:0
该命令用于批量启用序列号。
语法1:enable <logical-port>
取值范围:
访问级别:2
该命令用于关闭/启用下游FEC功能。
语法1:[no] fec-tx
访问级别:2
该命令用于使能/去使能PON 链路上激活的ONU的安全密钥重协商周期。
语法:key-exchange-ctrl <enabled/disabled>
取值范围:
<enabled/disabled>
缺省值:
disabled
访问级别:2
帮助信息:
Enable/Disable a periodic process of key exchange for active ONUs
该命令用于配置PON 链路的安全密钥重协商周期。
语法:key-exchange-interval <interval-value>
取值范围:
<interval-value>:1000 - 36000
缺省值:
10000 ms
访问级别:2
帮助信息:
Key exchange process interval in milliseconds.
该命令用于设置ont 发现的模式。
语法:ont-discovery-mode < auto | disabled>
取值范围:
< auto | disabled>:
访问级别:2
该命令用于设置ont 自动发现的周期。
语法:ont-discovery-intervlal <interval-value>
取值范围:<interval-value>:1..180
访问级别:2
该命令用于配置transceiver 的类型。
语法:transceiver type <type-value>
取值范围:
Value list:
1.sps-43-48h-hp-cde-sd
2.sog4321-psgb
3.lte3680m
4.source-photonics
5.lte3680p-type-c-plus
6.any
7.any-reset-guard
8.any-reset-preamble
9.wtd-rtxm167-526-c-plus
10.wtd-rtxm167-522-b-plus
11.lte3680p-bc
12.superxon-c-plus
13.wtd-rtxm167-521
14.lte3678
15.sogp-4321-psga
16.gpon-general-1
17.gpon-general-2
18.gpon-general-3
19.gpon-general-4
20.gpon-general-5
21.gpon-general-6
22.gpon-general-7
23.gpon-general-8
24.gpon-general-9
访问级别:2
该命令用于输入ONT配置级别。Sn或password 由 6.52.1的命令ont authentication mode来决定。
语法:ont <logical-port> [ sn <sn-value> ] [ password <password-value> ]
[loid-auth<loid-auth-value>] [checkcode-auth<checkcode-auth-value>]
取值范围:
<logical-prot>:<1-64>
<sn-value>:string,12
<password-value>:string,10
<loid-auth-value>:string,24
<checkcode-auth>:string,12
系统提示:
telnet@P3108(config-if-gpon-ont-1/8/)# ont 1
telnet@P3108(config-if-gpon-ont-1/8/1)#
访问级别:2
该命令用于删除ont。
语法:no ont <logical-port>
取值范围:
<logical-port> <1-64>
访问级别:2
该命令用于设置pon最大测距距离。
语法:pon-max-distance <max-log-distance>
取值范围:
<max-log-distance> 20..60
访问级别:2
该命令用于批量重置onu。
语法:reset <logical-port>
取值范围:
<logical-port> onu 范围, 格式1, 1-2, 1,3,4 最多256个字节
访问级别:2
该命令用于激活/关闭Pon Link管理状态。
语法:[no] shutdown
访问级别:2
该命令用于设置服务vlan和ONU vlan交换。
语法:vlantranslate <vport> <cvid> <mode> <svid> [new-cvid] [cos_act] [cos_val]
取值范围:
<vport> ont port{1..64}/vport{1..16}
<cvid> 1..4095
<mode> to
<svid> 1..4095
[new-cvid] 1..4095
[cos_act] <copy|replace>
[cos_val] 0..7
访问级别:2
该命令用于输入ONT配置级别。(这里面有组合关系的,需要根据此命令ont authentication-mode的结果来判断)
语法:onu <logical-port> [ sn <sn-value> ] [ password <password-value> ]
取值范围:
<logical-port> :1..64
<sn-value>: string,12 固定长度 help <The serial number is unique for ::::each ONT.>
<password-value> :string,10 固定长度 help <The password expected of the ::::ONU.>
<loid-auth-value>: string,24
<checkcode-auth>: string,12
系统提示:
telnet@P3116(config-t-if-gpon-olt-1/1)# ont 2
telnet@P3116(config-if-gpon-ont-1/1/2)#
该命令用于重置ONT。
语法:reset
Help : <Reset ONT.>
访问级别:2
该命令用于激活ONT。
语法:active
Help: <Lock ONT.>
访问级别:2
该命令用于关闭ONT。
语法:deactive
Help: <Unlock ONT.>
访问级别:2
该命令用于接口特定描述。
语法:description <description-value>
取值范围:
<description-value> :string,最多256个字节
该命令用于显示ONT的上线信息,如果没有上线,各参数显示空。
语法:show ont-info
Help: <Display the ONT information.>
访问级别:1
该命令用于增加一个virtual port。
语法:virtual-port <vitual-portid> [port <unlock|lock>]
[encrypt <enabled|disabled>]
[rate-limit <downstream|upstream> <value> [burst]]
取值范围:
<vitual-portid> 1..16
<enaled|disabled> <1|2>
<value> 0..1244160
[burst]] 0..4095,缺省值:128
Help: <Add a virtual port >
访问级别:2
该命令用于删除一个virtual port。
语法:no virtual-port <vitual-portid>
取值范围:
访问级别:2
该命令用于激活/去激活ONT的ethernet UNI。
语法:eth-uni <phy-portid> <activate|deactivate>
取值范围:
<phy-portid> :1..24
访问级别:2
该命令用于配置ethernet UNI。
语法:eth-uni <phy-portid> config [mtu<mtu-value>] [pause-time<pause-time-value>] [speed<speed-value>] [duplex<duplex-value>]
取值范围:
<phy-portid> :1..24
<mtu-value> 64..8192
<pause-time-value> 0..65535
<speed-value> <10m|100m|1000m|10g|20g|5g|25g|40g|auto>
<duplex-value> <full|half|auto>
访问级别:2
该命令用于配置POE。
语法:eth-uni <phy-portid> poe [<option-value>] [mode<mode-value>]
[priority<priority-value>] [max-power-class<max-power-class-value>]
取值范围:
<phy-portid> :1..24
<option-value> <enable|disable>
<mode-value> <signal|spare>
<priority-value> <critical|high|low>
<max-power-class-value> <default|class0|class1|class2|class3|class4>
访问级别:2
该命令用于删除eth-uni。
语法:no eth-uni <1-24,127,128>
取值范围:
<1-24,127,128> :1-24 for phy-port,127 for veip,128 for voip
访问级别:2
该命令用于开启/关闭 ONU 上行 FEC 。
语法:[no] fec-tx
取值范围:
访问级别:2
该命令用于设置ont 主机ip。
语法:ip-host <ip> <ipmask> <gateway> [DHCP-mode] [id]
取值范围:
<ip> :ont的IP地址,A.B.C.D
<ipmask>:ont的MASK 地址,A.B.C.D
<gateway>:ont的Gateway地址,A.B.C.D
[DHCP-mode] :DHCP模式,dynami|static
[id]:ip-host 索引
访问级别:2
该命令用于删除ip-host。
语法:no ip-host <id>
取值范围:
<id>
访问级别:2
该命令用于配置ont以太网单环路检测。
语法:loop-detect [state<state-value>] [auto-shutdown<auto-shutdown-value>]
[msg-freq<msg-freq-value>] [revert-time<revert-time-value>]
[msg index<index-value>] [eth-uni <eth-uni-value>] [svlan<svlan-value>]
[cvlan<cvlan-value>]
取值范围:
<state-value> ::<enable|disable>,缺省值:enable
<auto-shutdown-value> <enable|disable>,缺省值:enable
<msg-freq-value> 1..65535
<revert-time-value> 1..65535
<index-value> 1..32
<eth-uni-value> 1..24
<svlan-value> 0..4095
<cvlan-value> 0..4095
访问级别:2
该命令用于绑定mac筛选器配置文件。
语法1:mac-filter eth-uni <1-24,127,128> profile <profileid>
取值范围:
<profileid> :1..16
访问级别:2
语法2:mac-filter eth-uni <1-24,127,128> pre-assign [appletalk<filter-type>] [arp<filter-type>] [bridge-management-info<filter-type>] [ipv4-broadcast<filter-type>]
[ipv4-multicast<filter-type>] [ipv6-multicast<filter-type>] [ipx<filter-type>]
[netbeui<filter-type>] [pppoe-broadcast<filter-type>]
[rarp<filter-type>]
取值范围:
<filter-type> :<forward | filter>
访问级别:2
该命令用于删除ont eth uni mac筛选器配置文件。
语法:no mac-filter eth-uni<1-24,127,128>profile
取值范围:
访问级别:2
该命令用于设置从ont学习的最大允许MAC条目数。
语法:mac-limit [eth-uni <1-24,127,128>] <maclimit>
取值范围:
<maclimit> :0..192
访问级别:2
该命令用于配置onu的组播表。
语法:multicast <port-type> <port-list> oper-profile <oper-profile-value>
<proftype-value> <pro-id>
取值范围:
<port-type> :<eth-uni|ip-host|veip>
<port-list> :1-24 for phy-port, 127 for veip, 128 for ip-host
<oper-profile-value> 1..256
<proftype-value> <dynamic-profile|static-profile>
<pro-id> 1..256
访问级别:2
该命令用于配置onu的组播表。
语法:no multicast <port-type> <port-list>
取值范围:
访问级别:2
该命令用于使能ONT。
语法:enable
Help: <Enable ONT>
访问级别:2
该命令用于使能ONT。
语法:deactive
Help: <Disable ONT.>
访问级别:2
该命令用于ONU pots-uni配置。
语法:ont-pots-uni <phy-id> <phone-num> <username> <password> <displayname>
<voip-sip-profile> [ip-host<id>]
取值范围:
<phy-id> :1..2
<phone-num> string,32
<username> string,32
<password> string,32
<displayname> string,32
<voip-sip-profile> 1..2
<id> 0..24
访问级别:2
该命令用于删除ONU POTS UNI配置。
语法:no ont-post-uni <phy-id>
取值范围:
<port-type> :1..2
访问级别:2
配置ONT的valn转换表
该命令用于删除vlan 转换。
语法:no port-vlan <phy-portid> [trans-index]
取值范围:
<phy-portid> <1-24,127,128>1-24 for phy-port,127 for veip,128 for voip
[trans-index] 1..100
访问级别:2
该命令用于配置VLAN转换表的下行流模式属性。
语法:port-vlan <phy-portid> downstram <mode> intpid <intpid-value> outtpid <outtpid-value>
取值范围:
<mode>:
enumerate,<inverse-upstream|forward|filter-vid-pbit-forward|filter-vid-only-forward|filter-pbit-only-forward|filter-vid-pbit-discard|filter-vid-only-discard|filter-pbit-only-discard|discad>
<intpid-value>:string,hex start‘0x’< outtpid-value> string,hex start ‘0x’
访问级别:0
该命令用于配置port vlan 规则。
语法:
port-vlan <phy-portid> rule <index>
<double-tag|single-tag|untag>
取值范围:
<phy-portid>:<1-24,127,128>1-24 for phy-port,127 for veip,128 for voip
<index>:1..100
<double-tag|single-tag|untag>:{ double-tag,single-tag,untag }
访问级别:0
该命令用于设置port vlan 规则为双vlan-tag。
语法:
port-vlan <phy-portid> rule <index> double-tag [inner-pri <inner-pri-value>|inner-vid <inner-vid-value>|inner-tpid <inner-tpid-value>|outer-pri <outer-pri-value>|outer-vid <outer-vid-value>|outer-tpid <outer-tpid-value>]
取值范围:
<index>:1..100
<inner-pri-value>:0..8
<inner-vid-value>:0..4094
<inner-tpid-value>:{ mode0 mode4 mode5 mode6 mode7}
<outer-pri-value>:0..7
<outer-vid-value>:0..4094
<outer-tpid-value>:{ mode0 mode4 mode5 mode6 mode7 }
访问级别:0
该命令用于在双tag下丢弃该port vlan 。
语法:port-vlan <phy-portid> rule <index> double-tag discard
[ether-type<ether-type-value>]
取值范围:
<index>:1..100
<ether-type-value>
ether-type-value list:
0 - Do not filter on Ethertype
1 - Ethertype = 0x0800 (filter IPoE frames)
2 - Ethertype = 0x8863 or 0x8864 (filter PPPoE frames)
3 - Ethertype = 0x0806 (filter ARP frames)
4 - Ethertype = 0x86DD (filter IPv6 IpoE frames)
5 - Ethertype = 0x888E (filter EAPOL frames)
访问级别:0
该命令用于在双tag下删除inter与outer。
语法:
port-vlan <phy-portid> rule <index> double-tag remove-both
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
该命令用于在双tag下删除该port vlan 规则外部vlan。
语法:
port-vlan <phy-portid> rule <index> double-tag remove-outer
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
该命令用于在双tag下进行vlan转换。
语法:
port-vlan <phy-portid> rule <index> double-tag translate [inner-pri <inner-pri-value>|inner-vid <inner-vid-value>|inner-tpid <inner-tpid-value>|outer-pri <outer-pri-value>|outer-vid <outer-vid-value>|outer-tpid <outer-tpid-value>|ether-type<ether-type-value>]
取值范围:
<index>:1..100
<inner-pri-value>:0-7|copy-inner|copy-outer
<inner-vid-value> :0..4094|4096|4097
<inner-tpid-value>:{ mode0 mode1 mode2 mode3 mode4 mode5 mode6 mode7 }
<outer-pri-value>:0-7|copy-inner|copy-outer
<outer-vid-value>:0..4094|4096|4097
<outer-tpid-value>:{ mode0 mode1 mode2 mode3 mode4 mode5 mode6 mode7 }
<ether-type-value>:ether-type-value list:
访问级别:0
该命令用于在双tag规则下进行vlan穿透。
语法:port-vlan <phy-portid> rule <index> double-tag transparent
取值范围:
<index>:1..100
访问级别:0
该命令用于设置port vlan 规则为单vlan-tag。
语法:
port-vlan <phy-portid> rule <index> signle-tag [inner-pri <inner-pri-value>|inner-vid <inner-vid-value>|inner-tpid <inner-tpid-value>]
取值范围:
<index>:1..100
<inner-tpid-value> :{ mode0 mode4 mode5 mode6 mode7 }
访问级别:0
该命令用于在单 tag下丢弃该port vlan 。
语法:
signle-tag discard[ether-type<ether-type-value>]
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
该命令用于在单 tag下增加一层vlan。
语法:
port-vlan <phy-portid> rule <index> signle-tag q-in-q[inner-pri <inner-pri-value>|inner-vid <inner-vid-value>|inner-tpid
取值范围:
<index>:1..100
<inner-vid-value>:0..4096
<inner-tpid-value> :{ mode0 mode1 mode2 mode3 mode4 mode5 mode6 mode7 }
<outer-vid-value>:0..4096
<outer-tpid-value> :{ mode0 mode1 mode2 mode3 mode4 mode5 mode6 mode7 }
<ether-type-value>
访问级别:0
该命令用于在单vlan tag下删除该port vlan。
语法:
port-vlan <phy-portid> rule <index> signle-tag remove-tag[ether-type<ether-type-value>]
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
该命令用于在单tag下进行vlan 转换。
语法:
port-vlan <phy-portid> rule <index> signle-tag translate[inner-pri <inner-pri-value>|inner-vid <inner-vid-value>|inner-tpid <inner-tpid-value>
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
该命令用于在单 tag下进行vlan 穿透。
语法:port-vlan <phy-portid> rule <index> signle-tag transparent
取值范围:
<index>:1..100
访问级别:0
该命令用于在untag下添加vid。
语法:
port-vlan <phy-portid> rule <index> untag add-vid[inner-pri <inner-pri-value>
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
该命令用于在untag下丢弃该port vlan 。
语法:
port-vlan <phy-portid> rule <index> untag discard
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
该命令用于在untag下在该vlan下再添加一条vlan。
语法:
port-vlan <phy-portid> rule <index> untag q-in-q [inner-pri <inner-pri-value> |inner-vid <inner-vid-value> |inner-tpid <inner-tpid-value> |outer-pri <outer-pri-value>|outer-vid <outer-vid-value> |outer-tpid <outer-tpid-value>|ether-type<ether-type-value>]
取值范围:
<index>:1..100
<inner-tpid-value>:{ mode0 mode1 mode2 mode3 mode4 mode5 mode6mode7 }
<ether-type-value>
访问级别:0
该命令用于在untag下进行vlan穿透。
语法:port-vlan <phy-portid> rule <index> untag transparent
取值范围:
<phy-portid>:<1-24,127,128>, 1-24 for phy-port,127 for veip,128 for voip
<index>:1..100
访问级别:0
该命令用于删除 ont eth-un的速率限制。
语法:no rate-limit eth-uni<eth-uni-value> <direction>
取值范围:
<eth-uni-value>:<1-24,127,128>, 1-24 for phy-port,127 for veip,128 for voip
<direction>:<upstream|downstream>
访问级别:2
该命令用于设置ONT以太网端口的下游流量控制。
语法:rate-linlit eth-uni <eth-uni-value>
downstream <ds-rate-limit-cir> <ds-rate-limit-pir>
取值范围:
<ds-rate-limit-cir>:128..1244160
<ds-rate-limit-pir>:128..1244160
访问级别:2
该命令用于设置ONT以太网端口的上游流量控制。
upstream <ds-rate-limit-cir> <ds-rate-limit-pir>
取值范围:
访问级别:2
该命令用于是否开启流氓onu检测。
语法:rogue ont<mode>
取值范围:
<mode> : <enable/disable>,缺省值:disable
访问级别:2
该命令用于绑定业务配置文件。
语法: service flow-profile <flow-profile-id> tcont-bind-profile <tcont-bind-profile-id>
取值范围:
<flow-profile-id>: 1..128
<tcont-bind-profile-id>:1..128
访问级别:2
该命令用于删除业务绑定。
语法:no service
访问级别:2
该命令用于配置ONT的vlan筛选器。
语法:vlan-filter <port-type> <port-list> vlan-start<vlan-start-value>
vlan-end <vlan-end-value> [tagged<tagged-value>] [untagged<untagged-value>]
取值范围:
<port-list>:<1-24,127,128>1-24 for phy-port, 127 for veip, 128 for ip-host
<vlan-end-value>:1..4095
<tagged-value>:<transparent|discard|vlan-filter>
<untagged-value>:<transparent|discard>
访问级别:2
该命令用于删除ONT的vlan筛选器。
语法:no vlan-filter <port-type> <port-list>
取值范围:
<port-type>:<eth-uni|ip-host|veip>
访问级别:2
该命令用于显示P3116系统中的访问列表。
语法:show access-lists
访问级别:0
该命令用于显示已应用了ACL规则的所有接口。
语法:show acl-applied-interface
访问级别:0
该命令用于显示单板上的当前告警列表。
语法1:show alarm
访问级别:0
该命令用于显示单板上的当前告警列表详细信息。
语法2:show alarm detail
访问级别:0
该命令用于显示alarm的过滤器。
语法:show alarm-filter <filter-index>
取值范围:
<filter-index>:<1-64>
访问级别:0
该命令用于显示告警历史。
语法:show alarm-history
访问级别:0
该命令用于显示告警日志。
语法:show alarm-log
访问级别:0
该命令用于流氓onu状态。
语法:show anti-rogueont
访问级别:0
该命令用于显示登录横幅。
语法:show banner
访问级别:0
该命令用于显示启动及相关环境变量。
语法:show boot attributes
访问级别:0
该命令用于显示系统时钟。
语法:show clock
访问级别:0
该命令用于显示当前运行配置信息。
所显示的信息包括用户针对产品所做出的任何最新的更改。
语法:
show configuration running [gpon-profile| interface-ge | { interface-gpon-olt <port> <ontid>} | system| vlan]
取值范围:
<port> :单接口,<1/port> (port{1..16}).
<ontid>:1..64
访问级别:0
该命令用于显示cpld版本。
语法:show cpld
访问级别:0
该命令用于显示CPU利用率信息。
语法:show cpu <delay time>
取值范围:
<delay time>:延迟时间,5、60或300秒
访问级别:0
该命令用于显示保存在数据库的ACL配置文件。
语法:show database-acl-record
访问级别:0
该命令用于显示事件日志。
语法:show event-log
访问级别:0
该命令用于显示风扇状态。
语法:show fan
访问级别:0
该命令用于显示gpon的配置。
语法:
show gpon profile dba <profile-id>
show gpon profile flow <profile-id1>
show gpon profile multicast-dynamic <profile-id1 / profile-id2>
show gpon profile multicast-oper <profile-id>
show gpon profile multicast-static <profile-id1 / profile-id2>
show gpon profile multicast-userview
show gpon profile ont-uni-cfg [id]
show gpon profile rate-ctrl <profile-id>
show gpon profile tcont-bind <profile-id>
show gpon profile tcont-svc<profile-id>
show gpon profile vportsvc <profile-id>
取值范围:
<profile-id> 1..256|all
<profile-id1> 1..256|all
<profile-id1 / profile-id2> {1..256 }/{0,31}|all
[id] <1..32>,e例如1 或 1-2 ,最多256个字节
<profile-id3> :1..128
访问级别:0
该命令用于显示主机路由表。
语法:
show host-route interface giga-interface <module/port>
show host-route interface link-aggregation <lag-ID>
show host-route interface vlan <VLAN-ID>
取值范围:
<module/port>:单接口千兆以太网<单板/端口>(单板{1-2}/端口{1-16}),如:3/2,为最多32个字符的ASCII字符串。
<lag-ID>:链路汇聚接口号,<1..32>。
<VLAN-ID>:VLAN ID,范围是1至4094。
访问级别:0
该命令用于显示2层接口状态或计数器。
语法:show interface description
访问级别:0
该命令用于显示广播信息。
语法:show interface gpon-olt< module/port> broadcast gem-port
取值范围:
module/port:1/1..1/16 string
访问级别:0
该命令用于显示GEM端口计数器。
语法:show interface gpon-olt < module/port> counters gemport [vport]
取值范围:
[vport] :ont port{1..64}/vport{1..16}
访问级别:0
该命令用于显示多播GEM端口计数器。
语法:show interface gpon-olt< module/port>counters mulitcast
取值范围:
访问级别:0
该命令用于显示nni口计数器。
语法:show interface gpon-olt < module/port> counters nni
取值范围:
访问级别:0
该命令用于显示ont 计数器。
语法:show interface gpon-olt< module/port> counters ont [ontid]
取值范围:
[ontid] :1..64
访问级别:0
该命令用于显示GPON LINK状态。
语法:show interface gpon-olt< module/port> gpon-link
取值范围:
[ontid] :1..64
访问级别:0
该命令用于显示用/禁用活动ONU的定期密钥交换过程。
语法:show interface gpon-olt < module/port>key-exchange-ctrl
取值范围:
访问级别:0
该命令用于显示密钥交换进程间隔(毫秒)。
语法:show interface gpon-olt < module/port> kkey-exchange-interval
取值范围:
访问级别:0
该命令用于显示ONU的主要信息。
语法:show interface gpon-olt [ module/port ] ont <logical-port> brief
取值范围:
logical-port:1..64
访问级别:0
该命令用于显示ont功能。
语法:show interface gpon-olt < module/port> ont <logical-port> capability
取值范围:
logical-port:1..64
访问级别:0
该命令用于显示ONU统计。
语法:show interface gpon-olt< module/port> ont <logical-port> eth-uni <id>
取值范围:
logical-port:1..64
Id: ONT eth-port list<1-24,127,128|all>, 例如: 1,3,6-8
访问级别:0
该命令用于显示循环检测的配置。
语法:show interface gpon-olt< module/port> ont <logical-port> loop-detect
取值范围:
logical-port:1..64
访问级别:0
该命令用于显示ont网桥端口mac地址。
语法:show interface gpon-olt< module/port> ont <logical-port> mac-address
取值范围:
logical-port:1..64
访问级别:0
该命令用于显示ont eth uni 的mac地址筛选器。
语法:show interface gpon-olt< module/port> ont <logical-port> mac-filter pre-assign|profile <phy-portid>
取值范围:
logical-port:1..64
<phy-portid>: 1..128
访问级别:0
该命令用于显示当前ONT的光学状态。
语法:show interface gpon-olt< module/port> ont <logical-port> optical-info
取值范围:
logical-port:1..64
访问级别:0
语法showinterface gpon-olt< module/port> ont <logical-port> port-vlan <1-24,127,128>
取值范围:
logical-port:1..64
<1-24,127,128>: 1-24 for phy-port,127 for veip,128 for voip
访问级别:2
该命令用于显示应用的配置文件信息。
语法:show interface gpon-olt< module/port> ont <logical-port> profile
取值范围:
logical-port:1..64
访问级别:0
该命令用于显示ONU摘要。
语法:show interface gpon-olt< module/port> ont <logical-port>summary
取值范围:
logical-port:1..64
访问级别:0
该命令用于显示ONT UNI端口状态。
语法:show interface gpon-olt< module/port> ont <logical-port> uni-status
取值范围:
logical-port:1..64
访问级别:0
该命令用于显示ONT UNI端口状态。
语法:show interface gpon-olt< module/port> ont <logical-port> virtual-port <vitual-portid>
取值范围:
logical-port:1..64
<vitual-portid> ONT virtual-port list, e.g. 1,3,6-9
访问级别:0
该命令用于显示ont性能当前/历史-15分钟。
语法:show interface gpon-olt< module/port> ont-performance <logical-port> <type>
取值范围:
logical-port 1..64
<type> <current-15minutes|historic-15minutes>
访问级别:0
语法:show interface gpon-olt < module/port> ont-range <logical-port> mac-address
取值范围:
logical-port 1..64
访问级别:0
该命令用于显示ONU的主要信息。
语法:show interface gpon-olt < module/port> ont-range <logical-port> brief
取值范围:
logical-port 1..64
访问级别:0
该命令用于显示ONU的功能。
语法:show interface gpon-olt < module/port> ont-range <logical-port>capability
取值范围:
logical-port 1..64
访问级别:0
该命令用于显示循环检测的配置。
语法:show interface gpon-olt < module/port> ont-range <logical-port>loop-detec
取值范围:
logical-port 1..64
访问级别:2
该命令用于显示ont 的 summary。
语法:show interface gpon-olt < module/port> ont-range <logical-port>summary
取值范围:
logical-port 1..64
访问级别:0
该命令用于显示链路聚合类型接口。
语法:show interface link-aggregation<group> [counters|switchport]
取值范围:
<group> :1..32
访问级别:0
该命令用于显示所有注册的ONU。
语法:show interface gpon-olt< module/port> ont-registered
取值范围:
访问级别:0
该命令用于显示OLT的运行配置信息。
语法:show configuration running interface-gpon-olt
访问级别:0
该命令用于显示某个端口下的未捆绑的ONU
语法:show interface gpon-olt<module/port> ont-unbound
取值范围:
访问级别:0
该命令用于显示OLT统计计数器。
语法:show interface gpon-olt <module/port> counters
取值范围:
访问级别:0
该命令用于显示当前PON/ONT的光路状态。
语法1:show interface gpon-olt <module/port> optical-info
语法2:show interface gpon-olt <module/port> ont <ont_id>optical-info
ont_id: 1-64
该命令用于显示pon最大距离。
语法:show interface gpon-olt <module/port>pon-max-distance
取值范围:
访问级别:0
该命令用于显示transceiver 的类型。
语法:show interface gpon-olt <module/port>transceiver type
取值范围:
访问级别:0
该命令用于显示GE接口上的计数器。
语法:show interface giga-ethernet [module/port] counters
取值范围:
module/port:<module/port> (module {1-2}/port {1-16})Module:1 internal port <1-16>.Module:2 uplink port <1-4>, 1-2 : 10G port /3-4 Ge port. for example, 1/2
访问级别:0
该命令用于显GE口示激光(SFP)测量参数。
语法:show interface giga-ethernet [module/port] optical-info
取值范围:
访问级别:0
该命令用于显示GE接口的交换信息。
语法:show interface giga-ethernet [module/port] switchport
取值范围:
访问级别:0
该命令用于显示环回接口。
语法:show interface loopback <loopback-id>
取值范围:
loopback-id:1-16
访问级别:0
该命令用于显示带内管理接口。
语法:show interface management in-band
访问级别:0
该命令用于显示pon保护组。
语法:show interface pon-protection-group [psg-id]
取值范围:
psg-id ;1..8
访问级别:0
该命令用于显示接口Super VLAN信息。
语法:show interface super-vlan
访问级别:0
该命令用于显示接口VLAN信息。
语法:show interface vlan [VLAN-ID]
取值范围:
[VLAN-ID]:VLAN ID,1至4094。
访问级别:0
该命令用于显示IGMP调试跟踪。
语法:show ip igmp debug-traces
访问级别:0
该命令用于显示VLAN的IGMP snooping参数,并列出所snooping的组信息。
语法:show ip igmp snooping [vlan <vlan-id>]
取值范围:
<VLAN-ID>:VLAN ID,范围是<1..4094>
访问级别:0
该命令用于显示ip igmp静态组。
语法:show ip igmp static-group
访问级别:0
该命令用于显示IGMP统计信息。
语法:
show ip igmp statistics [ total | vlan <VLAN-ID>]
取值范围:
total:显示总的IGMP统计的关键字
vlan:指定VLAN ID的 VLAN关键字
访问级别:0
该命令用于显示IP接口简要信息。
语法:show ip interface brief
访问级别:0
该命令用于显示L2 PPPOE中继计数器。
语法:show ip pppoe vlan-option statistics
访问级别:0
该命令用于显示SNTP的信息,包括SNTP服务端和SNTP客户端。
语法:show ip sntp
访问级别:0
该命令用于显示指示灯状态。
语法:show leds
访问级别:0
该命令用于显示链路汇聚组端口中继信息。
语法:show link-aggregation summary
访问级别:0
该命令用于显示所有MAC表,包括动态及静态的MAC地址。
语法:
show mac-address-table
show mac-address-table satic
show mac-address-table interface giga-ethernet <module/port>
show mac-address-table vlan <vlan-id>
取值范围:
static:显示静态MAC表。
<module/port> module# (1..2), port# (1..16), eg.,2/4<cr>
<vlan-id> :1..4094 通过vlanid显示MAC地址筛选表
访问级别:0
该命令用于显示MAC老化时间。
语法:show mac-age-time
访问级别:0
该命令用于显示MAC过滤表。
语法:show mac-filter
访问级别:0
该命令用于显示管理IP路由表。
语法:show management ip route
访问级别:0
该命令用于显示系统内存的信息。
语法:show memory
访问级别:0
该命令用于显示MLS qos信息。
语法:
show mls qos
show mls qos interface {giga-ethernet<range> | link-aggregation <link-ID>}
取值范围:
giga-ethernet<range>:GE类型接口范围,如:1/2、2/1-4,为最多32个字符的ASCII字符串
link-aggregation <link-ID>:链路汇聚接口号,1至32
访问级别:0
该命令用于显示MLS qos映射信息。
语法:
show mls qos maps
show mls qos maps {dscp-cos | dscp-mutation | ip-prec-dscp } interface {giga-ethernet<range> | link-aggregation <link-ID>}
取值范围:
dscp-cos:DSCP到CoS的映射关键字
dscp-mutation:DSCP到DSCP的转化映射关键字
ip-prec-dscp:IP优先到DSCP的映射关键字
访问级别:0
该命令用于显示MLS qos队列集信息。
语法:
show mls qos queue-set interface {giga-ethernet<range> | link-aggregation <link-ID>}
取值范围:
queue-set:队列集关键字
访问级别:0
该命令用于显示系统中的监控会话,包括保存在缓存中的和已激活的。
语法:show monitor session [session-id]
取值范围:
session-id:1-4
说明:不带参数时,将显示系统中配置的所有监控会话。当带参数时,将显示参数指定的监控会话。显示的监控会话是基于登录的CLI用户进程的。
访问级别:0
该命令用于显示多播组作者。
语法:show multicast-group-author <port-id>
取值范围:
<port-id> :1..16
访问级别:0
该命令用于显示多播有日志。
语法:show multicast-log
访问级别:0
该命令用于显示组播VLAN。
语法:show multicast-vlan
访问级别:0
该命令用于显示组播VLAN 到gemport。
语法:show multicast-vlan-to-multi-gem
访问级别:0
该命令用于显示ont身份验证方法。
访问级别:0
该命令用于显示所有未绑定的onu数据。
语法:
show ont-unbound
访问级别:0
该命令用于显示ONU升级信息。
语法1:
show onu-upgrade result {auto|manual } [detail]
语法2:
show onu-upgrade config
取值范围:
result:ONU升级结果
detail: onu升级结果详细信息
config:onu升级配置信息。
访问级别:0
该命令用于显示性能管理。
语法1:show pm interface
访问级别:0
E.g
Total Monitored ports: 3
Index Interface type Interface PM state
1 ONU_UNI 1/1/1/2 Enable
2 GEM 1/2 Enable
3 OLT 1/3 Enable
该命令用于显示PM GPON OLT 的历史。
语法2:show pm interface gpon-olt <port> history
取值范围:
port :<1/port> (port{1..16})
访问级别:0
该命令用于显示PM GPON OLT 的eth uni/gemport历史。
语法2:show pm interface gpon-olt <port> ont <ont-id> {eth-history|gem-history <olt|ont>}
取值范围:
ont-id:1..64
访问级别:0
show preview-group 1 1
该命令用于显示预览组。
语法2:show preview-group <port-id>
取值范围:
port-id :1..16
访问级别:0
该命令用于显示多生成树信息。
语法1:show spanning-tree mst configuration
语法2:show spanning-tree mst instance [MST id] [detail]
语法3:show spanning-tree mst instance [MST id] interface {giga-ethernet <module/port> | link-aggregation <linkid> } [detail]
取值范围:
MST id:0..15
module/port:接口千兆以太网<单板/端口>(单板{1-2}/端口{1-16}),如:2/2,为最多8个字符的字符串
linkid:<1..32>
访问级别:0
该命令用于显示VLAN的详细RSTP信息。
语法:show spanning-tree vlan <vlan id > [detail]
取值范围:<1..1>
访问级别:0
该命令用于显示系统日志及运行配置。
语法:show syslog [flash {all|kernel|alarm|event|others<decimal>} | running-config
取值范围:
flash:显示保存于闪存的系统日志
running-config:显示日志及运行配置。
{all|kernel|syslog}:需要显示的单板
<decimal>:<1..1024> 需要显示log的条数。
访问级别:0
该命令用于显示系统信息,包括任何配置模式下的单板、硬件、软件版本信息。
语法:show system
访问级别:0
该命令用于显示当前运行任务的信息。
语法1:show task
访问级别:0
该命令用于显示制定的运行任务的信息。
语法2:show task <taskname>
取值范围:
<taskname> :最多32个字符
访问级别:0
该命令用于显示设备温度。
语法:show temperature
访问级别:0
该命令用于显示用户账户列表。
语法:show user
访问级别:0
该命令用于显示用户隔离配置。
语法:show user-isolation
访问级别:0
该命令用于显示版本信息,包括单板、硬件、软件版本信息。
语法:show version
访问级别:0
该命令用于显示所有VLAN的信息或特定VLAN的信息。
语法1:show vlan
语法2:show vlan <VLAN-ID>
取值范围:
<VLAN-ID>:VLAN ID,1至4094
该命令用于显示所有ONT的状态和在线信息。
语法1:show ont-info
语法2:show ont-info <pon_id>
语法3:show ont-info <pon_id> detail
取值范围:
<pon_id>:pon ni id,1..16
示例:telnet@P3116> show ont-info
ONT SN Status Find Auth Reason
1/8/1 GPON005f2ab1 online auto auto ----
1/8/2 GPON005f2be1 offline auto auto ----
1/8/3 GPON005f2ad1 online auto auto ----
缩略语 |
英文解释 |
中文解释 |
ACL |
Access Control List |
访问控制列表 |
ARP |
Address Resolution Protocol |
地址解析协议 |
DBA |
Dynamic Bandwidth Allocation |
动态带宽分配 |
DHCP |
Dynamic Host Configuration Protocol |
动态主机配置协议 |
DMZ |
Demilitarized Zone |
自治区域 |
EAPOL |
Extensible Authentication Protocol Over LAN |
扩展的LAN认证协议 |
GEPON |
Gigabit Ethernet Passive Optical Network |
千兆以太无源光网络 |
ICMP |
Internet Control Message Protocol |
互联网控制消息协议 |
IGMP |
Internet Group Management Protocol |
互联网组管理协议 |
LTM |
Line Terminal Modules |
线路终端模块 |
OAM |
Operation, Administration and Maintenance |
配置、管理和维护 |
OID |
Object Identifier |
实体标识 |
OLT |
Optical Line Terminal |
光线路终端 |
ONU |
Optical Network Unit |
光网络单元 |
PON |
无源光网络 |
RADIUS |
Remote Authentication Dial in User Service |
远程认证服务器 |
SLA |
Service Level Agreement |
服务协议水平 |
VLAN |
Virtual Local Area Network |
虚拟本地网 |
