05-三层技术-IP路由命令参考
02-静态路由命令
本章节下载: 02-静态路由命令  (149.25 KB)
02-静态路由命令
1 静态路由
1.1  静态路由配置命令
1.1.1  delete static-routes all
delete [ vpn-instance vpn-instance-name ] static-routes all
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:删除指定VPN的所有静态路由。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
【描述】
delete static-routes all命令用来删除所有静态路由。
使用本命令删除静态路由时,系统会提示确认,确认后才会删除所配置的所有静态路由。
使用undo ip route-static命令可以删除一条静态路由,而使用delete static-routes all命令可以删除包括缺省路由在内的所有静态路由。
需要注意的是:如果没有指定VPN实例名称,则删除公网中的静态路由。
相关配置可参考命令ip route-static,“三层技术-IP路由命令参考/IP路由基础”中的display ip routing-table。
# 删除所有静态路由。
[Sysname] delete static-routes all
This will erase all ipv4 static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]:y
1.1.2  ip route-static
ip route-static dest-address { mask | mask-length } { next-hop-address [ bfd control-packet [ bfd-source ip-address ] | track track-entry-number ] | interface-type interface-number [ next-hop-address ] [ bfd { control-packet [ bfd-source ip-address ] | echo-packet } ] | vpn-instance d-vpn-instance-name next-hop-address  [ bfd control-packet bfd-source ip-address | track track-entry-number ] } [ preference preference-value ] [ tag tag-value ] [ permanent ] [ description description-text ]
undo ip route-static dest-address { mask | mask-length } [ next-hop-address | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } { next-hop-address [ public ] [ bfd control-packet [ bfd-source ip-address ] | track track-entry-number ] | interface-type interface-number [ next-hop-address ] [ bfd { control-packet [ bfd-source ip-address ] | echo-packet } ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ip-address | track track-entry-number ] } [ preference preference-value ] [ tag tag-value ] [ permanent ] [ description description-text ]
undo ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } [ next-hop-address [ public ] | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
【缺省级别】
2:系统级
vpn-instance s-vpn-instance-name&<1-6>:指定源VPN。s-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。&<1-6>表示前面的参数最多可以输入6次。每个VPN都有自己的路由表,配置的静态路由将被加入指定VPN的路由表。
dest-address:静态路由的目的IP地址,点分十进制格式。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
next-hop-address:指定路由的下一跳的IP地址,点分十进制格式。
interface-type interface-number:指定静态路由的出接口类型和编号。对于接口类型为非P2P接口(包括NBMA类型接口或广播类型接口,如以太网接口、VLAN接口等),必须指定下一跳地址。
vpn-instance d-vpn-instance-name:指定目的VPN。d-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果指定目的VPN,静态路由将根据配置的next-hop-address在目的VPN中查找出接口。
next-hop-address public:此参数表示指定的next-hop-address是公网地址,不是源VPN实例地址。
preference preference-value:指定静态路由的优先级。preference-value取值范围为1~255,缺省值为60。如果在配置静态路由时没有指定优先级,就会使用缺省优先级。重新设置缺省优先级后,新设置的缺省优先级仅对新增的静态路由有效。
tag tag-value:静态路由Tag值,用于标识该条静态路由,以便在路由策略中根据Tag对路由进行灵活的控制。tag-value的取值范围为1~4294967295,缺省值为0。关于路由策略的详细信息,请参见“三层技术-IP路由配置指导”中的“路由策略”。
permanent:指定为永久静态路由。即使在出接口down时,配置的永久静态路由仍然保持active状态。
description description-text:静态路由描述信息。description-text为1~60个字符的字符串,除“?”外,可以包含空格等特殊字符。
bfd:使能BFD(Bidirectional Forwarding Detection,双向转发检测)功能,对静态路由下一跳的可达性进行快速检测,当下一跳不可达时可以快速切换到备份路由。
control-packet:通过BFD控制报文方式实现BFD功能。
bfd-source ip-address:BFD源IP地址。建议配置为Loopback接口IP地址。
echo-packet:通过BFD echo报文方式实现BFD功能。
track track-entry-number:将静态路由与Track项相关联,track-entry-number为Track项的序号,取值范围为1~1024。关于Track的详细介绍,请参见“可靠性配置指导”中的“Track”。
【描述】
ip route-static命令用来配置单播静态路由。undo ip route-static命令用来删除单播静态路由配置。
缺省情况下,没有配置单播静态路由。
配置单播静态路由时应注意以下几点:
(1)     如果目的IP地址和掩码都为0.0.0.0(或掩码为0),则配置的路由为缺省路由。当没有匹配的路由表项时,将使用缺省路由进行报文转发。
(2)     对不同的优先级配置,可采用不同的路由管理策略。例如,为同一目的地配置多条路由,如果指定相同的优先级,则实现路由负载分担;如果指定不同的优先级,则实现路由备份。
(3)     配置静态路由时,可根据实际需要指定出接口或下一跳地址,下一跳地址不能为本地接口IP地址。需要注意的是:
·     对于Null0接口,配置了出接口就不需要配置下一跳地址。
·     对于广播类型接口(如以太网接口、VLAN接口),因为可能有多个下一跳,配置时必须同时指定出接口和下一跳IP地址。
相关配置可参考命令ip route-static default-preference,“三层技术-IP路由命令参考/IP路由基础”中的display ip routing-table。
·     如果静态路由中指定的下一跳地址被配置为本地接口的IP地址,那么静态路由不会生效。
·     路由振荡时,使能BFD检测功能可能会加剧振荡,需谨慎使用。关于BFD的详细介绍,请参考“可靠性配置指导”中的“BFD”。
·     如果Track模块通过NQA探测私网静态路由中下一跳的可达性,静态路由下一跳的VPN实例号与NQA测试组配置的实例号必须相同,才能进行正常的探测。
·     在静态路由进行迭代时,Track项监测的应该是静态路由真正的下一跳,而不是配置的下一跳。否则,可能导致错误地将有效路由判断为无效路由。
·     参数permanent不能和bfd、track一起进行配置。
# 配置静态路由,其目的地址为1.1.1.1/24,指定下一跳为2.2.2.2,Tag值为45,描述信息为“for internet & intranet”。
[Sysname] ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description for internet & intranet
# 为名为vpn1的VPN实例配置一条静态路由,其目的地址为1.1.1.1/16,下一跳地址为此VPN实例的地址1.1.1.2。
[Sysname] ip route-static vpn-instance vpn1 1.1.1.1 16 vpn-instance vpn1 1.1.1.2
1.1.3  ip route-static default-preference
ip route-static default-preference default-preference-value
undo ip route-static default-preference
【缺省级别】
2:系统级
default-preference-value:静态路由缺省优先级的值,取值范围为1~255。
【描述】
ip route-static default-preference命令用来配置静态路由的缺省优先级。undo ip route-static default-preference命令用来恢复缺省情况。
缺省情况下,静态路由的缺省优先级为60。
·     如果在配置静态路由时没有指定优先级,就会使用缺省优先级。
·     重新设置缺省优先级后,新设置的缺省优先级仅对新增的静态路由有效。
# 配置静态路由的缺省优先级为120。
[Sysname] ip route-static default-preference 120
1.1.4  ip route-static fast-reroute
ip route-static [ vpn-instance vpn-instance-name ] fast-reroute route-policy route-policy-name
undo ip route-static [ vpn-instance vpn-instance-name ] fast-reroute
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:为指定VPN的所有静态路由配置快速重路由功能。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示为公网的所有静态路由配置快速重路由功能。
route-policy route-policy-name:为通过策略的静态路由指定备份下一跳信息。route-policy-name为路由策略名,为1~63个字符的字符串,区分大小写。
【描述】
ip route-static fast-reroute命令用来配置静态路由支持快速重路由功能。undo ip route-static fast-reroute命令用来恢复缺省情况。
缺省情况下,没有配置静态路由支持快速重路由功能。
·     要为静态路由配置快速重路由功能,除了使能静态路由快速重路由功能,还需要配置路由策略,通过apply fast-reroute backup-interface命令在路由策略中指定备份下一跳;关于apply fast-reroute backup-interface命令以及路由策略的相关配置,请参考“三层技术-IP路由配置指导”中的“路由策略”。
·     静态路由支持快速重路由功能仅对在配置中同时指定了出接口和下一跳的静态路由有效
·     静态路由快速重路由功能不能和静态路由与BFD联动功能同时使用。
# 为通过路由策略frr的静态路由指定备份下一跳信息。
[Sysname] ip ip-prefix abc index 10 permit 100.1.1.0 24
[Sysname] route-policy frr permit node 10
[Sysname-route-policy] if-match ip-prefix abc
[Sysname-route-policy] apply fast-reroute backup-interface vlan-interface 1 backup-nexthop 193.1.1.8
[Sysname-route-policy] quit
[Sysname] ip route-static fast-reroute route-policy frr
