06-WLAN access
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10506-WLAN access
05-Example for Configuring Policy-Based Forwarding with Dual Gateways
Example: Configuring policy-based forwarding with dual gateways
Introduction
The following information provides a configuration example for configuring policy-based forwarding with dual gateways.
As shown in Figure 1, the AC is deployed at the headquarters and an AP is deployed at the branch. Router A and Router B act as the gateways for the branch and the headquarters, respectively. The AP associates with the AC across the Internet.
Configure network settings to meet the following requirements:
·     Packets destined to the headquarters are forwarded by the AC and packets destined to the branch or Internet are forwarded by the AP.
·     The AP obtains IP addresses from Router A and the client obtains IP addresses from the AC.
Figure 1 Network diagram
Analysis
·     For the AP to discover the AC through the Internet, configure Option 43 and manually specify the IP address of the AC on Router A.
·     For the AP to communicate with the AC, configure NAT on both Router A and Router B.
·     To simplify configurations when a large number of APs are deployed at branches, enable auto AP and auto AP conversion on the AC.
·     For both the AP and the AC to forward packets, configure policy-based forwarding on the AC.
·     For the AP to obtain configurations automatically from the AC, use a text editor to create an AP configuration file and upload the file to the AC.
Make sure devices in the network can reach each other.
Procedures
Configuring Router A
1.     Configure DHCP:
# Enable DHCP.
[RouterA] dhcp enable
# Create DHCP address pool ap, specify the subnet for dynamic allocation as 192.168.10.0/24, specify the gateway address as 192.168.10.1.
[RouterA] dhcp server ip-pool ap
[RouterA-dhcp-pool-ap] network 192.168.10.0 mask 255.255.255.0
[RouterA-dhcp-pool-ap] gateway-list 192.168.10.1
# Configure Option 43 that specifies the Router B's IP address 202.202.1.22/24.
[RouterA-dhcp-pool-ap] option 43 hex 8007000001CACA0116
[RouterA-dhcp-pool-ap] quit
2.     Configure NAT:
# Create NAT address group 0, and add address 202.20.1.20 to the group.
[RouterA] nat address-group 0
[RouterA-address-group-0] address 202.20.1.20 202.20.1.20
[RouterA-address-group-0] quit
# Create IPv4 basic ACL 2000 to permit only packets from source IP subnet 192.168.10.0/24.
[RouterA] acl basic 2000
[RouterA-acl-ipv4-basic-2000] rule permit source 192.168.10.0 0.0.0.255
[RouterA-acl-ipv4-basic-2000] quit
# Configure interface GigabitEthernet1/0/2 to translate the source addresses of outgoing packets permitted by ACL 2000 into the addresses in address group 0.
[RouterA-GigabitEthernet1/0/2] nat outbound 2000 address-group 0
[RouterA] quit
Configuring Router B
1.     Configure NAT:
# Create IPv4 ACL 3000 to permit only packets from 202.20.1.0/24 to 202.202.1.22.
<RouterB> system-view
[RouterB] acl advanced 3000
[RouterB-acl-ipv4-adv-3000] rule 0 permit ip source 202.20.1.0 0.0.0.255 destination 202.202.1.22 0
[RouterB-acl-ipv4-adv-3000] quit
# Configure interface GigabitEthernet1/0/1 to allow users permitted by ACL 3000 to access the internal server at 192.168.1.111.
[RouterB-GigabitEthernet1/0/1] nat server global 3000 inside 192.168.1.111
[RouterB] quit
Configuring the AC
1.     Create AP configuration file map-OnAP.txt as follows and then upload the file to the AC.
vlan 2
interface Vlan-interface1
 nat outbound 3000
 port link-type trunk
 port trunk permit vlan 1
interface Vlan-interface2
 ip address 172.16.4.3 255.255.255.0
acl advanced 3000
 rule 0 permit ip source 172.16.4.0 0.0.0.255
2.     Configure basic AC functions:
# Configure interface IP addresses. (Details not shown.)
# Create VLAN 2 and VLAN-interface 2, and assign an IP address to the VLAN interface.
<AC> system-view
[AC] vlan 2
[AC-vlan2] quit
[AC] interface vlan-interface 2
[AC-Vlan-interface2] ip address 172.16.4.1 255.255.255.0
[AC-Vlan-interface2] quit
# Configure interface GigabitEthernet1/0/2 to operate in Layer 2 mode, set the port link type to trunk, remove the port from VLAN 1, and add the port to VLAN 2.
[AC] interface gigabitethernet 1/0/2
[AC-GigabitEthernet1/0/2] port link-mode bridge
[AC-GigabitEthernet1/0/2] port link-type trunk
[AC-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/2] port trunk permit vlan 2
[AC-GigabitEthernet1/0/2] quit
# Configure static routes to GigabitEthernet1/0/2 of Router A, GigabitEthernet1/0/1 of Router B, and headquarters' network segment 172.16.5.0/24.
[AC] ip route-static 202.20.1.0 24 192.168.1.22
[AC] ip route-static 202.202.1.0 24 192.168.1.22
[AC] ip route-static 172.16.5.0 24 172.16.4.2
3.     Configure DHCP:
# Enable DHCP.
[AC] dhcp enable
# Create DHCP address pool sta, specify the subnet for dynamic allocation as 172.16.4.0/24, and specify the gateway address as 172.16.4.1.
[AC] dhcp server ip-pool sta
[AC-dhcp-pool-sta] network 172.16.4.0 mask 255.255.255.0
[AC-dhcp-pool-sta] gateway-list 172.16.4.1
# Specify the DNS server address as 192.168.1.10.
[AC-dhcp-pool-sta] dns-list 192.168.1.10
# Exclude IP addresses 172.16.4.1 and 172.16.4.3 from dynamic allocation in DHCP address pool sta.
[AC-dhcp-pool-sta] forbidden-ip 172.16.4.1 172.16.4.3
[AC-dhcp-pool-sta] quit
4.     Enable auto AP and auto AP conversion.
[AC] wlan auto-ap enable
[AC] wlan auto-persistent enable
5.     Configure policy-based forwarding:
# Create IPv4 advanced ACL 3001, and configure ACL rules to permit DNS, BOOTPC, and BOOTPS packets and packets from 172.16.4.0/24 to 172.16.4.0/24 or 172.16.5.0/24.
[AC] acl advanced 3001
[AC-acl-ipv4-adv-3001] rule 0 permit udp source-port eq dns
[AC-acl-ipv4-adv-3001] rule 1 permit udp destination-port eq dns
[AC-acl-ipv4-adv-3001] rule 2 permit udp source-port eq bootpc
[AC-acl-ipv4-adv-3001] rule 3 permit udp destination-port eq bootps
[AC-acl-ipv4-adv-3001] rule 4 permit ip source 172.16.4.0 0.0.0.255 destination 172.16.4.0 0.0.0.255
[AC-acl-ipv4-adv-3001] rule 5 permit ip source 172.16.4.0 0.0.0.255 destination 172.16.5.0 0.0.0.255
[AC-acl-ipv4-adv-3001] quit
# Create forwarding policy remote, and configure the forwarding policy to perform centralized forwarding on packets that match ACL 3001.
[AC] wlan forwarding-policy remote
[AC-wlan-fp-remote] classifier acl 3001 behavior remote
[AC-wlan-fp-remote] quit
# Create service template chn, set the SSID to CHN, and assign clients coming online through the service template to VLAN 2.
[AC] wlan service-template chn
[AC-wlan-st-chn] ssid CHN
[AC-wlan-st-chn] vlan 2
# Enable APs to forward client traffic, apply forwarding policy remote to the service template, and enable the forwarding policy.
[AC-wlan-st-chn] client forwarding-location ap
[AC-wlan-st-chn] client forwarding-policy-name remote
[AC-wlan-st-chn] client forwarding-policy enable
# Set the PSK AKM mode and specify plaintext string 12345678 as the preshared key.
[AC-wlan-st-chn] akm mode psk
[AC-wlan-st-chn] preshared-key pass-phrase simple 12345678
# Set the CCMP cipher suite and enable RSN security IE.
[AC-wlan-st-chn] cipher-suite ccmp
[AC-wlan-st-chn] security-ie rsn
# Enable the service template.
[AC-wlan-st-chn] service-template enable
[AC-wlan-st-chn] quit
# Deploy configuration file map-OnAP.txt to WA6320 APs in the default AP group.
[AC] wlan ap-group default-group
[AC-wlan-ap-group-default-group] ap-model WA6320
[AC-wlan-ap-group-default-group-ap-model-WA6320] map-configuration flash:/map-OnAP.txt
# Bind service template chn to radio 1 and enable radio 1.
[AC-wlan-ap-group-default-group-ap-model-WA6320] radio 1
[AC-wlan-ap-group-default-group-ap-model-WA6320-radio-1] service-template chn
[AC-wlan-ap-group-default-group-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-default-group-ap-model-WA6320-radio-1] quit
[AC-wlan-ap-group-default-group-ap-model-WA6320] quit
[AC-wlan-ap-group-default-group] quit
# Verify that the AP has associated with the AC.
[AC] display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 2048
Remaining APs: 2047
Total AP licenses: 32
Local AP licenses: 32
Server AP licenses: 0
Remaining local AP licenses: 31
Sync AP licenses: 0
                                 AP information
 State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
         C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name                        APID  State Model           Serial ID
0015-005e-9348                 2     R/M   WA6320          219801A28N819CE0002T
# Verify that the AP is in Run state, the discovery type is DHCP, and the AP's IP address is 202.20.1.20.
[AC] display wlan ap name 0015-005e-9348 verbose
AP name : 0015-005e-9348
AP ID : 2
AP group name : default-group
State : Run
Backup type : Master
Online time : 1 days 5 hours 25 minutes 22 seconds
System up time : 1 days 6 hours 30 minutes 4 seconds
Model : WA6320
Region code : CN
Region code lock : Disabled
Serial ID : 219801A28N819CE0002T
MAC address : 70f9-6dd3-61e0
IP address : 202.20.1.20
UDP control port number : 1099
UDP data port number : 1102
H/W version : Ver.C
S/W version : R2215
Boot version : 7.10
USB state : N/A
Power Level : N/A
PowerInfo : N/A
Description : Not configured
Priority : 4
Echo interval : 10 seconds
Echo count : 3 counts
Keepalive interval : 10 seconds
Statistics report interval : 50 seconds
Fragment size (data) : 1500
Fragment size (control) : 1450
MAC type : Local MAC & Split MAC
Tunnel mode : Local Bridging & 802.3 Frame & Native Frame
Discovery type : DHCP
Retransmission count : 3
Retransmission interval : 5 seconds
Firmware upgrade : Enabled
Sent control packets : 34001
Received control packets : 34001
Echo requests : 10591
Lost echo responses : 3
Average echo delay : 3
Last reboot reason : User soft reboot
Latest IP address : 202.20.1.20
Tunnel down reason : Processed join request in Run state
Connection count : 15
Backup Ipv4 : Not configured
Backup Ipv6 : Not configured
Tunnel encryption : Disabled
LED mode : Normal
Remote configuration : Disabled
Radio 1:
    Basic BSSID : 70f9-6dd3-61e0
    Admin state : Up
    Radio type : 802.11ac
    Antenna type : internal
    Client dot11ac-only : Disabled
    Client dot11n-only : Disabled
    Channel band-width : 20/40/80MHz
    Active band-width : 20/40/80MHz
    Secondary channel offset : SCA
    Short GI for 20MHz : Supported
    Short GI for 40MHz : Supported
    Short GI for 80MHz : Supported
    Short GI for 160MHz : Not supported
    A-MSDU : Enabled
    A-MPDU : Enabled
    LDPC : Not Supported
    STBC : Supported
    Operational VHT-MCS Set:
        Mandatory : Not configured
        Supported : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
        Multicast : Not configured
    Operational HT MCS Set:
        Supported : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15
    Channel : 149(auto)
    Channel usage(%) : 0
    Max power : 20 dBm
    Operational rate:
        Mandatory : 6, 12, 24 Mbps
        Multicast : Auto
        Supported : 9, 18, 36, 48, 54 Mbps
        Disabled : Not configured
    Distance : 1 km
    ANI : Enabled
    Fragmentation threshold : 2346 bytes
    Beacon interval : 100 TU
    Protection threshold : 2346 bytes
    Long retry threshold : 4
    Short retry threshold : 7
    Maximum rx duration : 2000 ms
    Noise floor : -105 dBm
    Smart antenna : Enabled
    Smart antenna policy : Auto
    Protection mode : cts-to-self
    Continuous mode : N/A
    HT protection mode : No protection
Radio 2:
    Basic BSSID : 70f9-6dd3-61f0
    Admin state : Down
    Radio type : 802.11n(2.4GHz)
    Channel band-width : 20MHz
    Active band-width : 20MHz
    Secondary channel offset : SCN
    A-MSDU : Enabled
    A-MPDU : Enabled
    STBC : Supported
    Channel : 6(auto)
    Max power : 20 dBm
    Preamble type : Short
    Operational rate:
        Mandatory : 1, 2, 5.5, 11 Mbps
        Multicast : Auto
        Supported : 6, 9, 12, 18, 24, 36, 48, 54 Mbps
    Distance : 1 km
    ANI : Enabled
    Noise floor : 0 dBm
# Verify that the client has come online with an IP address in subnet 172.16.4.0/24, and the forwarding policy is remote.
[AC] display wlan client
Total number of clients: 1
MAC address    User name  AP name         RID IP address      VLAN
0015-005e-9348 N/A        0015-005e-9348  1   172.16.4.11     2
[AC] display wlan client verbose
 MAC address : 0015-005e-9348
 IPv4 address : 172.16.4.11
 IPv6 address : N/A
 Username : N/A
 AID : 1
 AP ID : 2
 Radio ID : 1
 SSID : CHN
 VLAN ID : 2
 Sleep count : 0
 Wireless mode : 802.11an
 Channel bandwidth : 40MHz
 20/40 BSS Coexistence Management : Not supported
 SM power save : Disabled
 STBC RX capability : Supported
 STBC TX capability : Not supported
 LDPC RX capability : Not supported
 Block Ack : N/A
 Supported HT MCS set : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15
 Supported rates : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
 QoS mode : WMM
 Listen interval : 100
 RSSI : 0
 Rx/Tx rate : 0/0
 Authentication method : Open system
 Security mode : PRE-RSNA
 AKM mode : N/A
 Cipher suite : N/A
 User authentication mode : Bypass
 Authorization ACL ID : N/A
 Authorization user profile : N/A
 Roam status : N/A
 Key derivation : N/A
 PMF status : N/A
 Forwarding policy name : remote
 Online time : 0days 0hours 0minutes 33seconds
 FT status : Inactive
# Verify that IP addresses (172.16.4.2, 172.16.5.1, and 172.16.5.2) in the headquarters' network can be pinged successfully.
C:\Users\h3c>ping 172.16.4.2
Pinging 172.16.4.2 with 32 bytes of data:
Reply from 172.16.4.2: bytes=32 time=6ms TTL=255
Reply from 172.16.4.2: bytes=32 time=3ms TTL=255
Reply from 172.16.4.2: bytes=32 time=1ms TTL=255
Ping statistics for 172.16.4.2:
    Minimum = 1ms, Maximum = 6ms, Average = 4ms
C:\Users\h3c>ping 172.16.5.1
Pinging 172.16.5.1 with 32 bytes of data:
Reply from 172.16.5.1: bytes=32 time=9ms TTL=255
Reply from 172.16.5.1: bytes=32 time=1ms TTL=255
Reply from 172.16.5.1: bytes=32 time=5ms TTL=255
Ping statistics for 172.16.5.1:
    Minimum = 1ms, Maximum = 9ms, Average = 4ms
C:\Users\h3c>ping 172.16.5.2
Pinging 172.16.5.2 with 32 bytes of data:
Reply from 172.16.5.2: bytes=32 time=8ms TTL=255
Reply from 172.16.5.2: bytes=32 time=2ms TTL=255
Reply from 172.16.5.2: bytes=32 time=5ms TTL=255
Reply from 172.16.5.2: bytes=32 time=3ms TTL=255
Ping statistics for 172.16.5.2:
    Minimum = 2ms, Maximum = 8ms, Average = 4ms
# Verify that a website on the Internet (for example, www.baidu.com) can be pinged successfully.
C:\Users\h3c>ping www.baidu.com
Pinging www.baidu.com [202.202.1.188] with 32 bytes of data:
Reply from 202.202.1.188: bytes=32 time=7ms TTL=255
Reply from 202.202.1.188: bytes=32 time=3ms TTL=255
Reply from 202.202.1.188: bytes=32 time=2ms TTL=255
Ping statistics for 202.202.1.188:
    Minimum = 2ms, Maximum = 7ms, Average = 3ms
Configuration files
·     Router A:
nat address-group 0
 dhcp enable
 option 43 hex 8007000001caca0116
acl basic 2000
 rule 0 permit source 192.168.10.0 0.0.0.255
·     Router B:
acl advanced 3000
·     AC:
 dhcp enable
vlan 2
 forbidden-ip 172.16.4.3
 ssid CHN
 vlan 2
 akm mode psk
 preshared-key pass-phrase cipher $c$3$4T2hQpGTY8qC3U4KL3G2sMgv9RNfRZdZfDqY
 cipher-suite ccmp
 security-ie rsn
acl advanced 3001
 wlan auto-ap enable
 ap-model WA6320
  radio 1
   radio enable
  radio 2
  gigabitethernet 1
  gigabitethernet 2
Related documentation
·     Network Connectivity Command Reference in H3C Access Controllers Command References
·     Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Access Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
