- 06-WLAN access
- 01-Example for Configuring WEP Encryption
- 02-Example for Configuring PSK Encryption
- 03-Example for Configuring WPA3-SAE PSK Encryption
- 04-Example for Configuring WLAN Access (IPv6)
- 05-Example for Configuring Policy-Based Forwarding with Dual Gateways
- 06-Example for Configuring Scheduled Configuration Deployment by AP Group
- 07-Example for Configuring Inter-AC Roaming with Static Client VLAN Allocation
- 08-Example for Binding service templates with different SSIDs to radios
- 09-Example for Configuring Scheduled WLAN Access Services
- 10-Example for Configuring a Dual-Stack Wireless Service
- 11-Example for Configuring different SSIDs for office use and guests
| 02-Example for Configuring PSK Encryption | 120.93 KB |
Example: Configuring PSK encryption
Introduction
The following information provides an example for configuring PSK encryption.
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the client. Perform the following tasks:
· Configure PSK on the AC to enable the client to use PSK for encryption.
· Configure open system authentication and bypass authentication so that the client can access the WLAN without being authenticated.
· Configure PSK as the authentication and key management (AKM) mode.
· Set the cipher suite to CCMP.
· Set the security IE to RSN.
When you configure PSK encryption, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· Configure a pre-shared key if the AKM mode is PSK.
Procedures
Configuring the AC
1. Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The client will use this VLAN to access the WLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2. Configure wireless services:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Configure the SSID as service.
[AC-wlan-st-1] ssid service
# Specify VLAN 200 for clients to access the WLAN defined by the service template.
[AC-wlan-st-1] vlan 200
# Set the AKM mode to PSK, and configure simple character string of 12345678 as the PSK.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Set the cipher suite to CCMP and set the security IE to RSN.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-1] client forwarding-location ac
# Enable the service template.
[AC-wlan-st-1] quit
3. Configure the AP:
NOTE: In a large-scale network, configure AP groups instead of single APs as a best practice. |
# Create manual AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA6320
[AC-wlan-ap-officeap] serial-id 219801A28N819CE0002T
[AC-wlan-ap-officeap] quit
# Create AP group group1, and add the AP to the AP group.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap officeap
# Bind service template 1 to radio 2.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
Configuring the switch
1. Configure switch interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward packets between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.1.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use VLAN 200 to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.1.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100 and 200.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as a trunk port, remove the port from VLAN 1, set the PVID to VLAN 100, and assign the port to VLAN 100.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/2.
2. Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP address pool vlan100 to assign an IP address to the AP, and specify subnet 192.1.0.0/16 in the DHCP address pool.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.0.0 mask 255.255.0.0
# Exclude IP address 192.1.1.1 from dynamic allocation in the address pool.
[Switch-dhcp-pool-vlan100] forbidden-ip 192.1.1.1
# Specify the gateway address as 192.1.1.2 in the DHCP address pool.
[Switch-dhcp-pool-vlan100] gateway-list 192.1.1.2
[Switch-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200 to assign an IP address to the client, and specify subnet 192.2.1.0/24 in the DHCP address pool.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.1.0 mask 255.255.255.0
# Exclude IP address 192.2.1.1 from dynamic allocation in the address pool.
[Switch-dhcp-pool-vlan200] forbidden-ip 192.2.1.1
# Specify the gateway address as 192.2.1.2 and specify the DNS server address in the DHCP address pool. In this example, the gateway also acts as a DNS server.
[Switch-dhcp-pool-vlan200] gateway-list 192.2.1.2
[Switch-dhcp-pool-vlan200] dns-list 192.2.1.2
[Switch-dhcp-pool-vlan200] quit
# Verify that the client has been associated with the WLAN and the AKM mode is PSK.
[AC] display wlan client verbose
Total number of clients: 1
MAC address : 0024-d705-c608
IPv4 address : 192.2.1.3
IPv6 address : N/A
Username : N/A
AID : 1
AP ID : 2
AP name : officeap
Radio ID : 2
SSID : service
BSSID : 80f6-2eaf-5190
VLAN ID : 200
Sleep count : 137
Wireless mode : 802.11g
Supported rates : 1, 2, 5.5, 6, 9, 11,
12, 18, 24, 36, 48, 54 Mbps
QoS mode : WMM
Listen interval : 100
RSSI : 20
Rx/Tx rate : 2/1
Authentication method : Open system
Security mode : PRE-RSNA
AKM mode : N/A
Security mode : RSN
AKM mode : PSK
Cipher suite : CCMP
User authentication mode : Bypass
Authorization ACL ID : N/A
Authorization user profile : N/A
Roam status : N/A
Key derivation : N/A
PMF status : N/A
Forwarding policy name : N/A
Online time : 0days 0hours 21minutes 55seconds
FT status : Inactive
Configuration files
· AC:
vlan 100
vlan 200
ssid service
vlan 200
akm mode psk
preshared-key pass-phrase cipher $c$3$N//5BVbsOqdBTxi+7MJZKT6Zqh5MAmYs2ZzM
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
ip address 192.1.1.1 255.255.0.0
interface Vlan-interface200
ip address 192.2.1.1 255.255.255.0
ap officeap
ap-model WA6320
radio 2
radio enable
service-template 1
· Switch:
dhcp enable
vlan 100
vlan 200
dns-list 192.2.1.2
poe enable
Related documentation
· WLAN Access Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
