06-WLAN access
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10506-WLAN access
01-Example for Configuring WEP Encryption
01-Example for Configuring WEP Encryption 116.21 KB
Example: Configuring WEP encryption
Introduction
The following information provides an example for configuring WEP encryption.
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the client. Configure WEP on the AC to enable the client to use WEP for encryption.
Figure 1 Network diagram
When you configure WEP encryption, follow these restrictions and guidelines:
·     Use the actual serial ID of an AP to uniquely identify that AP.
·     Make sure the WEP key IDs configured on the client and the AC are the same. As a best practice, set the key ID to 1 on the AC because some clients only support key ID 1.
Procedures
Configuring the AC
1.     Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The client will use this VLAN to access the WLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure wireless services:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Configure the SSID as service.
[AC-wlan-st-1] ssid service
# Specify VLAN 200 for clients to access the WLAN defined by the service template.
[AC-wlan-st-1] vlan 200
# Set the WEP40 cipher suite for frame encryption, and configure plain text 12345 as WEP key 1.
[AC-wlan-st-1] cipher-suite wep40
[AC-wlan-st-1] wep key 1 wep40 pass-phrase simple 12345
[AC-wlan-st-1] wep key-id 1
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-1] client forwarding-location ac
# Enable the service template.
[AC-wlan-st-1] quit
3.     Configure the AP:
In a large-scale network, configure AP groups instead of single APs as a best practice.
# Create manual AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA6320
[AC-wlan-ap-officeap] serial-id 219801A28N819CE0002T
[AC-wlan-ap-officeap] quit
# Create AP group group1 and add the AP to the AP group.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap officeap
# Bind service template 1 to radio 2.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
Configuring the switch
1.     Configure switch interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward packets between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.1.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use VLAN 200 to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.1.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100 and 200.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as a trunk port, remove the port from VLAN 1, set the PVID to VLAN 100, and assign the port to VLAN 100.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/2.
2.     Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP address pool vlan100 to assign an IP address to the AP, and specify subnet 192.1.0.0/16 in the DHCP address pool.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.0.0 mask 255.255.0.0
# Exclude IP address 192.1.1.1 from dynamic allocation in the address pool.
[Switch-dhcp-pool-vlan100] forbidden-ip 192.1.1.1
# Specify the gateway address as 192.1.1.2 in the DHCP address pool.
[Switch-dhcp-pool-vlan100] gateway-list 192.1.1.2
[Switch-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200 to assign an IP address to the client, and specify subnet 192.2.1.0/24 in the DHCP address pool.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.1.0 mask 255.255.255.0
# Exclude IP address 192.2.1.1 from dynamic allocation in the address pool.
[Switch-dhcp-pool-vlan200] forbidden-ip 192.2.1.1
# Specify the gateway address as 192.2.1.2 and specify the DNS server address in the DHCP address pool. In this example, the gateway also acts as the DNS server.
[Switch-dhcp-pool-vlan200] gateway-list 192.2.1.2
[Switch-dhcp-pool-vlan200] dns-list 192.2.1.2
[Switch-dhcp-pool-vlan200] quit
# Verify that the client has been associated with the WLAN by using the WEP40 cipher suite.
[AC] display wlan client verbose
Total number of clients: 1
 MAC address                       : 0024-d705-c608
 IPv4 address                      : 192.2.1.3
 IPv6 address                      : N/A
 Username                          : N/A
 AID                               : 1
 AP ID                             : 2
 AP name                           : officeap
 Radio ID                          : 2
 SSID                              : service
 BSSID                             : 80f6-2eaf-5190
 VLAN ID                           : 200
 Sleep count                       : 137
 Wireless mode                     : 802.11g
 Supported rates                   : 1, 2, 5.5, 6, 9, 11,
                                     12, 18, 24, 36, 48, 54 Mbps
QoS mode                          : WMM
 Listen interval                   : 100
 RSSI                              : 20
 Rx/Tx rate                        : 2/1
 Authentication method             : Open system
 Security mode                     : PRE-RSNA
 AKM mode                          : N/A
 Cipher suite                      : WEP40
 User authentication mode          : Bypass
 Authorization ACL ID              : N/A
 Authorization user profile        : N/A
 Roam status                       : N/A
 Key derivation                    : N/A
 PMF status                        : N/A
 Forwarding policy name            : N/A
 Online time                       : 0days 0hours 21minutes 55seconds
 FT status                         : Inactive
Configuration files
·     AC:
vlan 100
vlan 200
 ssid service
 vlan 200
 cipher-suite wep40
 wep key 1 wep40 pass-phrase cipher $c$3$3biXGrrILUAd5QTBAPer4VkW7K1rLoGn
interface Vlan-interface100
 ip address 192.1.1.1 255.255.0.0
interface Vlan-interface200
 ip address 192.2.1.1 255.255.255.0
 ap officeap
 ap-model WA6320
  radio 2
   radio enable
   service-template 1
·     Switch:
 dhcp enable
vlan 100
vlan 200
 dns-list 192.2.1.2
 port link-mode bridge
Related documentation
·     WLAN Access Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
