06-WLAN access
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10506-WLAN access
03-Example for Configuring WPA3-SAE PSK Encryption
Example: Configuring WPA3-SAE PSK encryption
Introduction
The following information provides an example for configuring PSK encryption with the WPA3-SAE security mode.
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the client. Perform the following tasks:
·     Configure PSK on the AC to enable the client to use PSK for encryption.
·     Configure open system authentication and bypass authentication so that the client can access the WLAN without being authenticated.
·     Configure PSK as the authentication and key management (AKM) mode.
·     Set the cipher suite to CCMP.
·     Set the security IE to RSN.
·     Set the security mode to WPA3-SAE.
Figure 1 Network diagram
When you configure PSK encryption with the WPA3-SAE security mode, follow these restrictions and guidelines:
·     Use the actual serial ID of an AP to uniquely identify that AP.
·     Configure a pre-shared key if the AKM mode is PSK.
Procedures
Configuring the AC
1.     Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The client will use this VLAN to access the WLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure wireless services:
# Create service template wpa3_personal and enter its view.
[AC] wlan service-template wpa3_personal
# Configure the SSID as wpa3_personal.
[AC-wlan-st-wpa3_personal] ssid wpa3_personal
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-wpa3_personal] vlan 200
# Set the AKM mode to PSK and configure simple character string of 12345678 as the PSK.
[AC-wlan-st-wpa3_personal] akm mode psk
[AC-wlan-st-wpa3_personal] preshared-key pass-phrase simple 12345678
# Set the cipher suite to CCMP and set the security IE to RSN.
[AC-wlan-st-wpa3_personal] cipher-suite ccmp
[AC-wlan-st-wpa3_personal] security-ie rsn
# Set the WPA3 security mode to personal (WPA3-SAE) and specify the mandatory mode.
[AC-wlan-st-wpa3_personal] wpa3 personal mandatory
# Enable mandatory management frame protection.
[AC-wlan-st-wpa3_personal] pmf mandatory
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-wpa3_personal] client forwarding-location ac
# Enable the service template.
[AC-wlan-st-wpa3_personal] service-template enable
[AC-wlan-st-wpa3_personal] quit
3.     Configure the AP:
In a large-scale network, configure AP groups instead of single APs as a best practice.
# Create manual AP office, and specify the AP model and serial ID.
[AC] wlan ap office model WA6320
[AC-wlan-ap-office] serial-id 219801A28N819CE0002T
[AC-wlan-ap-office] quit
# Create AP group group1, and add the AP to the AP group.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap office
# Bind service template wpa3_personal to radio 2.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template wpa3_personal
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
Configuring the switch
1.     Configure switch interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward packets between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.1.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.1.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100, and 200.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as an access port, and assign the port to VLAN 100.
# Enable PoE on GigabitEthernet 1/0/2.
2.     Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP address pool vlan100 to assign an IP address to the AP, specify subnet 192.1.0.0/16 in the DHCP address pool, and specify the gateway address as 192.1.1.2.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan100] gateway-list 192.1.1.2
[Switch-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200 to assign an IP address to the AP, and specify subnet 192.2.1.0/24 in the DHCP address pool. Specify the gateway address as 192.2.1.2 and specify the DNS server address in the DHCP address pool. In this example, the gateway also acts as the DNS server.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.1.0 mask 255.255.255.0
[Switch-dhcp-pool-vlan200] gateway-list 192.2.1.2
[Switch-dhcp-pool-vlan200] dns-list 192.2.1.2
[Switch-dhcp-pool-vlan200] quit
# Verify that the client has been associated with the WLAN and the AKM mode is PSK.
[AC] display wlan client verbose
Total number of clients: 1
 MAC address                       : ccc9-5de2-512d
 IPv4 address                      : 192.2.1.3
 IPv6 address                      : N/A
 Username                          : N/A
 AID                               : 1
 AP ID                             : 1
 AP name                           : office
 Radio ID                          : 2
 Channel                           : 149
 SSID                              : wpa3_personal
 BSSID                             : f474-8879-ea70
 VLAN ID                           : 200
 Sleep count                       : 0
 Wireless mode                     : 802.11ax
 Channel bandwidth                 : 80MHz
 SM power save                     : Disabled
 Short GI for 20MHz                : Supported
 Short GI for 40MHz                : Supported
 Short GI for 80MHz                : Supported
 Short GI for 160/80+80MHz         : Not supported
 STBC RX capability                : Not supported
 STBC TX capability                : Not supported
 LDPC RX capability                : Supported
 Beamformee STS capability         : N/A
 Number of Sounding Dimensions     : N/A
 SU beamformee capability          : Not supported
 MU beamformee capability          : Not supported
 Block Ack                         : N/A
 Supported VHT-MCS set             : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
 Supported HT MCS set              : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15
 Supported rates                   : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
 5G 40And80MHz Channel bandwidth   : Supported
 5G 160MHz Channel bandwidth       : Not Supported
 5G 8080MHz Channel bandwidth      : Not Supported
 OFDMA random access RUs           : Not supported
 Supported HE-MCS set              : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11
 TWT scheduled                     : no
 QoS mode                          : WMM
 Listen interval                   : 20
 RSSI                              : 0
 Rx/Tx rate                        : 0/0 Mbps
 Speed                             : N/A
 Authentication method             : SAE
 Security mode                     : RSN
 AKM mode                          : PSK
 Cipher suite                      : CCMP
 User authentication mode          : Bypass
 WPA3 status                       : Enabled
 Authorization CAR                 : N/A
 Authorization ACL ID              : N/A
 Authorization user profile        : N/A
 Roam status                       : N/A
 Key derivation                    : SHA256
 PMF status                        : Enabled
 Forwarding policy name            : Not configured
 Online time                       : 0days 0hours 0minutes 10seconds
 FT status                         : Inactive
 BTM mode                          : Inactive
Configuration files
·     AC:
vlan 100
vlan 200
 ssid wpa3_personal
vlan 200
akm mode psk
 preshared-key pass-phrase cipher $c$3$N//5BVbsOqdBTxi+7MJZKT6Zqh5MAmYs2ZzM
 cipher-suite ccmp
 pmf mandatory
 security-ie rsn
interface Vlan-interface100
 ip address 192.1.1.1 255.255.0.0
interface Vlan-interface200
 ip address 192.2.1.1 255.255.255.0
 ap office
 ap-model WA6320
  radio 2
   radio enable
 gigabitethernet 1
 ten-gigabitethernet 1
·     Switch:
 dhcp enable
vlan 100
vlan 200
 dns-list 192.2.1.2
poe enable
Related documentation
·     WLAN Access Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Authentication Command Reference in H3C Access Controllers Command References
·     WLAN Authentication Configuration Guide in H3C Access Controllers Configuration Guides
