| 04-HH3C-QOS-CAPABILITY-MIB | 50.16 KB |
About this MIB
Use this MIB to obtain QoS capabilities.
MIB file name
hh3c-qos-capability.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei(2011).h3c(10).h3cSNMPAgCpb(7).h3cQosCapability(1)
Tabular objects
hh3cQoSSysCapabilityTable
About this table
This table obtains global QoS feature values.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are h3cQoSSysCapModuleIndex and h3cQoSSysCapCharacteristicsIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQoSSysCapModuleIndex (1.3.6.1.4.1.25506.7.1.1.1.2.1.1) |
not-accessible |
Integer32 |
1..2147483647 |
QoS module index. |
As per the MIB. |
hh3cQoSSysCapCharacteristicsIndex (1.3.6.1.4.1.25506.7.1.1.1.2.1.2) |
not-accessible |
Integer32 |
1..2147483647 |
QoS system feature index. |
As per the MIB. |
hh3cQoSSysCapCharacteristicsValue (1.3.6.1.4.1.25506.7.1.1.1.2.1.3) |
read-only |
Unsigned32 |
Standard MIB values. |
QoS feature value. |
As per the MIB. |
hh3cQoSIfCapabilityTable
About this table
This table obtains interface QoS feature values.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are h3cQoSIfCapIfIndex, h3cQoSIfCapModuleIndex, and h3cQoSIfCapCharacteristicsIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQoSIfCapIfIndex (1.3.6.1.4.1.25506.7.1.1.1.3.1.1) |
not-accessible |
Integer32 |
0..2147483647 |
Interface index. |
As per the MIB. |
hh3cQoSIfCapModuleIndex (1.3.6.1.4.1.25506.7.1.1.1.3.1.2) |
not-accessible |
Integer32 |
1..2147483647 |
QoS module index. |
As per the MIB. |
hh3cQoSIfCapCharacteristicsIndex (1.3.6.1.4.1.25506.7.1.1.1.3.1.3) |
not-accessible |
Integer32 |
1..2147483647 |
QoS interface feature index. |
As per the MIB. |
hh3cQoSIfCapCharacteristicsValue (1.3.6.1.4.1.25506.7.1.1.1.3.1.4) |
read-only |
Unsigned32 |
As per the MIB. |
