| 02-HH3C-CBQOS2-MIB | 467.85 KB |
hh3cCBQoSRedirectAlarmBehaviorName
hh3cCBQoSRedirectAlarmProtoFamily
hh3cCBQoSClassifierCfgInfoTable
hh3cCBQoSMatchRuleCfgInfoTable
hh3cCBQoSNestPolicyCfgInfoTable
hh3cCBQoSColoredRemarkCfgTable
hh3cCBQoSColorMapDpCfgInfoTable
hh3cCBQoSPolicyClassCfgInfoTable
hh3cCBQoSNestPolicyApplyObjectTable
hh3cCBQoSClassMatchRunInfoTable
hh3cCBQoSAccountingRunInfoTable
hh3cCBQoSPolicyAccRunInfoTable
hh3cCBQoSRedirectInvalidAlarmRecover
HH3C-CBQOS2-MIB
About this MIB
Use this MIB to configure class-based QoS (CBQoS).
CBQoS applies different service quality levels to different classes of packets, enabling multiple service support on the network.
MIB file name
hh3c-cbqos2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cQos2(65)
Scalar objects
hh3cCBQoSClassifierIndexNext
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSClassifierIndexNext (1.3.6.1.4.1.25506.2.65.2.1.1.1) |
read-only |
Integer32 |
Standard MIB values. |
Index of the next available traffic class. |
As per the MIB. |
hh3cCBQoSBehaviorIndexNext
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSBehaviorIndexNext (1.3.6.1.4.1.25506.2.65.2.1.2.1) |
read-only |
Integer32 |
Index of the next available traffic behavior. |
As per the MIB. |
hh3cCBQoSPolicyIndexNext
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPolicyIndexNext (1.3.6.1.4.1.25506.2.65.2.1.3.1) |
read-only |
Integer32 |
Index of the next available QoS policy. |
As per the MIB. |
hh3cCBQoSApplyingStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSApplyingStatus (1.3.6.1.4.1.25506.2.65.2.1.6.1) |
read-only |
INTEGER |
· idle(1) · busy(2) |
QoS policy application status. |
As per the MIB. |
hh3cCBQoSChassis
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSChassis (1.3.6.1.4.1.25506.2.65.2.1.8.1) |
accessible-for-notify |
Integer32 |
0..65534 |
Chassis number. |
hh3cCBQoSSlot
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSSlot (1.3.6.1.4.1.25506.2.65.2.1.8.2) |
Integer32 |
0..65534 |
Slot number. |
hh3cCBQoSCPU
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCPU (1.3.6.1.4.1.25506.2.65.2.1.8.3) |
Integer32 |
0..65534 |
CPU number. |
hh3cCBQoSDirection
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSDirection (1.3.6.1.4.1.25506.2.65.2.1.8.4) |
DirectionType |
Standard MIB values |
Direction. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRedirectAlarmBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.8.5) |
OCTET STRING |
SIZE (1..31) |
Traffic behavior name. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRedirectAlarmProtoFamily (1.3.6.1.4.1.25506.2.65.2.1.8.6) |
InetAddressType |
Protocol type. |
hh3cCBQoSRedirectAlarmNextHop
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRedirectAlarmNextHop (1.3.6.1.4.1.25506.2.65.2.1.8.7) |
InetAddress |
Next-hop address. |
Tabular objects
About this table
This table configures a traffic class.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cCBQoSClassifierIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSClassifierIndex (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.1) |
not-accessible |
Integer32 |
Traffic class index. |
As per the MIB. |
hh3cCBQoSClassifierName (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.2) |
read-create |
OCTET STRING |
SIZE (1..31) |
Traffic class name. |
As per the MIB. |
hh3cCBQoSClassifierRuleCount (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.3) |
read-only |
Integer32 |
Number of match criteria. |
As per the MIB. |
hh3cCBQoSClassifierOperator (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.4) |
read-create |
INTEGER |
· and(1) · or(2) |
Relationship among match criteria. |
As per the MIB. |
hh3cCBQoSClassifierLayer (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.5) |
read-create |
INTEGER |
· unavailable(1) · l2(2) · l3(3) · both(4) |
Protocol layer for the traffic class. |
This object is not configurable and is fixed at unavailable(1). |
hh3cCBQoSClassifierType (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.6) |
read-only |
INTEGER |
· systemDefined(1) · userDefined(2) |
Traffic class type. |
Implementation varies by product. |
hh3cCBQosClassifierMatchRuleNextIndex (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.7) |
read-only |
Integer32 |
Index used to create a match criterion. |
If the value is 2147483647, the a match criterion cannot be created. |
hh3cCBQoSClassifierRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.8) |
read-create |
RowStatus |
Row status. |
· active(1) · createAndGo(4) · destroy(6) |
About this table
This table configures match criteria for a traffic class.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cCBQoSClassifierIndex and hh3cCBQoSMatchRuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSMatchRuleIndex (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.1) |
not-accessible |
Integer32 |
Match criterion index. |
As per the MIB. |
hh3cCBQoSMatchRuleIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.2) |
read-create |
INTEGER |
· match(1) · notMatch (2) |
Match attribute. |
hh3cCBQoSMatchRuleType (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.3) |
read-create |
MatchRuleType |
Match criterion type. |
hh3cCBQoSMatchRuleStringValue (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.4) |
read-create |
OCTET STRING |
SIZE (1..255) |
Match criterion type string value. The corresponding match criterion types include: · IPv4acl · MACACL · UserACL · IPv6acl · Source-MAC · Destination-MAC · Classifier · Inbound-interface · VlanID · SourceIp · MplsLabel · SecondMplsLabel |
As per the MIB. |
hh3cCBQoSMatchRuleIntValue1 (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.5) |
read-create |
Unsigned32 |
Match criterion type integer value. The corresponding match criterion types include: · IPv4acl · MACACL · UserACL · IPv6acl · Software QoS · Hardware Qos · RtpPort · IpPrec · Dscp · Vlan8021p · Mplsexp · SourceIp · QosLocalID · AtmClp · FrDe · LocalPrecedence · DropPriority · ServiceDot1p · SecondMplsExp · PacketLength · ForwardingLayer |
As per the MIB. |
hh3cCBQoSMatchRuleIntValue2 (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.6) |
read-create |
Unsigned32 |
Match criterion type integer value. The corresponding match criterion types include: · RTP-PORT · DSCP · PacketLength |
As per the MIB. |
hh3cCBQoSMatchIpAddressType (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.7) |
read-create |
InetAddressType |
Match criterion type integer value. The corresponding match criterion type is SourceIP. |
Not supported. The value is fixed at unknown(0). |
hh3cCBQoSMatchIpAddress (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.8) |
read-create |
InetAddress |
Match criterion type integer value. The corresponding integer value is a source IP address. |
Not supported. The value is fixed at zero length. |
hh3cCBQoSMatchRuleRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.9) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSMatchCpProtoCfgTable
About this table
Use this MIB to configure a match criterion to match protocol traffic to a control plane.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSMatchCpProtoIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.1) |
read-create |
INTEGER |
· match(1) · matchNot(2) |
Match attribute. |
hh3cCBQoSMatchCpProtoValue (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.2) |
read-create |
OCTET STRING |
SIZE (0..255) |
Control plane protocol. |
hh3cCBQoSMatchCpProtoRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.3) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSMatchCpGroupCfgTable
About this table
Use this MIB to configure a match criterion to match protocol group traffic to a control plane.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSMatchCpGroupIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.1) |
read-create |
INTEGER |
Match attribute. |
hh3cCBQoSMatchCpGroupValue (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.2) |
read-create |
INTEGER |
· critical(1) · important(2) · management(3) · normal(4) · redirect(5) · monitor(6) · exception(7) |
Control plane protocol group. |
hh3cCBQoSMatchCpGroupRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.3) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSBehaviorCfgInfoTable
About this table
This table configures match criteria for a traffic behavior.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cCBQoSBehaviorIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSBehaviorIndex (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.1) |
not-accessible |
Integer32 |
Traffic behavior index. |
As per the MIB. |
hh3cCBQoSBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.2) |
read-create |
OCTET STRING |
SIZE (1..31) |
As per the MIB. |
hh3cCBQoSBehaviorType (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.3) |
read-only |
INTEGER |
Traffic behavior type. |
hh3cCBQoSBehaviorRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.4) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSCarCfgInfoTable
About this table
This table configures a CAR action for a traffic behavior.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCarCir (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.1) |
read-create |
Unsigned32 |
CIR. |
hh3cCBQoSCarCbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.2) |
read-create |
Unsigned32 |
CBS. |
hh3cCBQoSCarEbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.3) |
read-create |
Unsigned32 |
EBS. |
hh3cCBQoSCarPir (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.4) |
read-create |
Unsigned32 |
PIR. |
hh3cCBQoSCarPbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.5) |
read-create |
Unsigned32 |
PBS. |
Not supported. The value is fixed at 4294967295. |
hh3cCBQoSCarGreenAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.6) |
read-create |
CarAction |
Action to take on green packets. |
hh3cCBQoSCarGreenRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.7) |
read-create |
Integer32 |
· 0..63 · 255 |
Value to mark for green packets. |
As per the MIB. |
hh3cCBQoSCarYellowAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.8) |
read-create |
CarAction |
Action to take on yellow packets. |
hh3cCBQoSCarYellowRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.9) |
read-create |
Integer32 |
· 0..63 · 255 |
Value to mark for yellow packets. |
As per the MIB. |
hh3cCBQoSCarRedAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.10) |
read-create |
CarAction |
· For VRP: Action to take on packets exceeding the CIR. · For 10G: Action to take on packets exceeding the PIR. |
hh3cCBQoSCarRedRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.11) |
read-create |
Integer32 |
· 0..63 · 255 |
Value to mark for red packets. |
As per the MIB. |
hh3cCBQoSCarPolicedPriorityMapType (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.12) |
read-create |
INTEGER |
· none (0) · policed-service-map (1) · local-precedence-dot1p-map (2) · drop-precedence-map (3) |
Priority map type. |
Not supported. The value is fixed at none(0). |
hh3cCBQoSCarRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.13) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSGtsCfgInfoTable
About this table
This table contains GTS configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSGtsCir (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.1) |
read-create |
Unsigned32 |
CIR. |
hh3cCBQoSGtsCbs (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.2) |
read-create |
Unsigned32 |
CBS. |
hh3cCBQoSGtsEbs (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.3) |
read-create |
Unsigned32 |
EBS. |
hh3cCBQoSGtsQueueLength (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.4) |
read-create |
Integer32 |
1..1024 |
Queue length. |
As per the MIB. |
hh3cCBQoSGtsRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.5) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSGtsPir (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.6) |
read-create |
Unsigned32 |
PIR. |
hh3cCBQoSRemarkCfgInfoTable
About this table
This table contains marking configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cCBQoSBehaviorIndex and hh3cCBQoSRemarkType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRemarkType (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.1) |
not-accessible |
RemarkType |
Marking type. |
hh3cCBQoSRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.2) |
read-create |
Integer32 |
0..4095 |
As per the MIB. |
hh3cCBQoSRemarkRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.3) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSQueueCfgInfoTable
About this table
This table contains queuing configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSQueueType (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.1) |
read-create |
QueueType |
Queuing type. |
hh3cCBQoSQueueDropType (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.2) |
read-create |
INTEGER |
· unavailable(0) · tail-drop(1) · wred(2) |
Packet drop type. |
Not supported. |
hh3cCBQoSQueueLength (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.3) |
read-create |
Integer32 |
1..2147483647 |
Queue length. |
hh3cCBQoSQueueBandwidthUnit (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.4) |
read-create |
QueueBandwidthUnit |
Bandwidth unit. |
hh3cCBQoSQueueBandwidthValue (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.5) |
read-create |
Integer32 |
· 1..100000000 · 2147483647 |
Bandwidth value. |
hh3cCBQoSQueueCbs (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.6) |
read-create |
Integer32 |
· 32..1000000000 · 2147483647 |
CBS. |
hh3cCBQoSQueueQueueNumber (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.7) |
read-create |
INTEGER |
· unavailable(0) · a16(16) · a32(32) · a64(64) · a128(128) · a256(256) · a512(512) · a1024(1024) · a2048(2048) · a4096(4096) |
Maximum number of queues. |
hh3cCBQoSQueueCbsRatio (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.8) |
read-create |
Integer32 |
· 25..500 · 2147483647 |
Allowed burst ratio. |
hh3cCBQoSQueueRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.9) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSFirewallCfgInfoTable
About this table
This table contains firewall configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSFirewallAction (1.3.6.1.4.1.25506.2.65.2.1.2.12.1.1) |
read-create |
INTEGER |
· permit(1) · deny(2) |
Firewall behavior. |
As per the MIB. |
hh3cCBQoSFirewallRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.12.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cCBQoSAccountCfgInfoTable
About this table
This table contains accounting configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSAccounting (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.1) |
read-create |
INTEGER |
· true(1) · false(2) |
Accounting. |
Not supported. The value is fixed at true(1). |
hh3cCBQoSAccountRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.2) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSAccountingMode (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.3) |
read-create |
INTEGER |
· auto(1) · packet(2) · byte(3) · both(4) |
Accounting mode. |
hh3cCBQoSRedirectCfgInfoTable
About this table
This table configures a redirecting action for a traffic behavior.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRedirectType (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.1) |
read-create |
INTEGER |
· cpu(1) · interface(2) · nextHop(3) |
Redirecting destination. |
hh3cCBQoSRedirectIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.2) |
read-create |
Integer32 |
Interface index. |
As per the MIB. |
hh3cCBQoSRedirectIpAddressType |
read-create |
InetAddressType |
Next-hop address type. |
hh3cCBQoSRedirectIpAddress1 |
read-create |
InetAddress |
First next-hop address. |
Not supported. The value is fixed at zero-length. |
hh3cCBQoSRedirectIpAddress2 |
read-create |
InetAddress |
Second next-hop address. |
hh3cCBQoSRedirectRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.6) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSRedirectIpv6Interface1 |
read-create |
Integer32 |
Outgoing interface for the first next-hop IPv6 address. |
Not supported. The value is fixed at 0. |
hh3cCBQoSRedirectIpv6Interface2 |
read-create |
Integer32 |
Outgoing interface for the second next-hop IPv6 address. |
hh3cCBQoSRedirectIfVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.9) |
read-create |
Integer32 |
0..4094|65535 |
VLAN ID. |
hh3cCBQoSMirrorCfgInfoTable
About this table
This table contains flow mirroring configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSMirrorType (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.1) |
read-create |
INTEGER |
· interface(1) · cpu(2) · vlan(3) |
Mirroring destination. |
hh3cCBQoSMirrorIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.2) |
read-create |
OCTET STRING |
SIZE (1..255) |
Destination interface index. |
hh3cCBQoSMirrorVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.3) |
read-create |
Integer32 |
0..4094 |
Destination VLAN ID. |
hh3cCBQoSMirrorRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.4) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSNestCfgInfoTable
About this table
This table configures nesting for VLAN mapping.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSNestServiceVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.1) |
read-create |
Integer32 |
· 1..4094 · 65535 |
Service provider VLAN ID. |
As per the MIB. |
hh3cCBQoSNestServiceDot1pValue (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.2) |
read-create |
Integer32 |
· 0..7 · 65535 |
Outer 802.1p priority value. |
hh3cCBQoSNestCustomerVlanID |
read-create |
Integer32 |
· 1..4094 · 65535 |
Customer VLAN ID. |
Not supported. The value is fixed at 65535. |
hh3cCBQoSNestCustomerDot1pValue |
read-create |
Integer32 |
· 0..7 · 65535 |
Inner 802.1p priority value. |
hh3cCBQoSNestRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.5) |
read-create |
RowStatus |
Row status. |
About this table
This table nests a QoS policy.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSNestPolicyName (1.3.6.1.4.1.25506.2.65.2.1.2.19.1.1) |
read-create |
OCTET STRING |
SIZE (1..31) |
Nested policy name. |
As per the MIB. |
hh3cCBQoSNestPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.19.1.2) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSMirrorIfCfgInfoTable
About this table
This table contains information about flow mirroring to an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSMirrorIfMainIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.1) |
not-accessible |
Integer32 |
As per the MIB. |
hh3cCBQoSMirrorIfMainIfStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.2) |
read-only |
INTEGER |
· inactive(1) · active(2) |
Destination interface status. |
As per the MIB. |
hh3cCBQoSMirrorIfBackupIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.3) |
read-create |
Integer32 |
Backup destination interface index. |
hh3cCBQoSMirrorIfBackupIfStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.4) |
read-only |
INTEGER |
Backup destination interface status. |
As per the MIB. |
hh3cCBQoSMirrorIfRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.5) |
read-create |
RowStatus |
Row status. |
About this table
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cCBQoSBehaviorIndex, hh3cCBQoSColoredRemarkType, and hh3cCBQoSColoredRemarkColor.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSColoredRemarkType (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.1) |
not-accessible |
RemarkType |
Marking type. |
hh3cCBQoSColoredRemarkColor (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.2) |
not-accessible |
INTEGER |
· green(1) · yellow(2) · red(3) |
Marking color. |
hh3cCBQoSColoredRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.3) |
read-create |
Integer32 |
0..4095 |
Value to mark for packets. |
As per the MIB. |
hh3cCBQoSColoredRemarkRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.4) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSPrimapCfgInfoTable
About this table
This table contains information about predefined priority maps. The system modifies the priority of matching packets according to the predefined priority map.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPrimapColorType (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.1) |
not-accessible |
INTEGER |
· noColorMap(1) · colorMap(2) |
Predefined priority map color attribute. |
hh3cCBQoSPrePriMapTableType(1.3.6.1.4.1.25506.2.65.2.1.2.22.1.2) |
not-accessible |
INTEGER |
· invalid(0) · dot1pToLp(1) · dot1pToDp(2) · expToLp(3) · dscpToLp(4) · expToDp(5) · dscpToDp(6) · dscpToDot1p(7) · dot1pToDscp(8) · dscpToDscp(9) · dscpToExp(10) · expToDscp(11) · expToDot1p(12) · expToExp(13) · lpToDot1p(14) · dot1pToRpr(15) · dscpToRpr(16) · expToRpr(17) · ippreToRpr(18) · upToDot1p(19) · upToDscp(20) · upToExp(21) · upToDp(22) · upToLp(23) · upToRpr(24) · upToFc(25) · lpTodscp(26) · dot11eToLp(27) · lpToDot11e(28) · lpToLp(29) · dot1pToExp(30) · lpToExp(31) · lpToDp(32) · upToUp(33) · dot1pToDot1p(34) |
Predefined priority map type. |
hh3cCBQoSPrimapRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.3) |
read-create |
RowStatus |
Row status. |
About this table
This table contains information about packet color-to-drop priority mappings. The system assigns drop priority to packets according to the packet color.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSColorMapDpEnable (1.3.6.1.4.1.25506.2.65.2.1.2.23.1.1) |
read-create |
INTEGER |
Color-to-drop priority mapping enable status. |
As per the MIB. |
hh3cCBQoSColorMapDpRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.23.1.2) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSPolicyCfgInfoTable
About this table
This table configures a QoS policy.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPolicyIndex (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.1) |
not-accessible |
Integer32 |
Policy index. |
As per the MIB. |
hh3cCBQoSPolicyName (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.2) |
read-create |
OCTET STRING |
SIZE (1..31) |
Policy name. |
As per the MIB. |
hh3cCBQoSPolicyClassCount (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.3) |
read-only |
Integer32 |
Number of traffic classes in the QoS policy. |
As per the MIB. |
hh3cCBQoSPolicyConfigMode (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.4) |
read-create |
INTEGER |
· unavailable(0) · config(1) · auto(2) |
Policy mode. |
Not supported. The value is fixed at unavailable(0). |
hh3cCBQoSPolicyType (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.5) |
read-only |
INTEGER |
Policy type. |
hh3cCBQoSPolicyClassNextIndex (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.6) |
read-only |
Integer32 |
Traffic class index used to create a traffic class. |
If the value is 2147483647, no traffic class can be created for hh3cCBQoSPolicyClassCfgInfoTable. |
hh3cCBQoSPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.7) |
read-create |
RowStatus |
Row status. |
About this table
This table describes CB association information for a QoS policy.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cCBQoSPolicyIndex and hh3cCBQoSPolicyClassIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPolicyClassIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.1) |
not-accessible |
Integer32 |
As per the MIB. |
hh3cCBQoSPolicyClassClassifierIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.2) |
read-create |
Integer32 |
As per the MIB. |
hh3cCBQoSPolicyClassClassifierName (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.3) |
read-only |
OCTET STRING |
SIZE (1..31) |
As per the MIB. |
hh3cCBQoSPolicyClassBehaviorIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.4) |
read-create |
Integer32 |
As per the MIB. |
hh3cCBQoSPolicyClassBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.5) |
read-only |
OCTET STRING |
SIZE (1..31) |
As per the MIB. |
hh3cCBQoSPolicyClassPrecedence (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.6) |
read-create |
Integer32 |
· 0..16383 · 2147483647 |
Traffic class priority. |
Not supported. The value is fixed at 2147483647. |
hh3cCBQoSPolicyClassRowStatus (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.7) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSPolicyClassMode (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.8) |
read-create |
INTEGER |
· modeNo(1) · modeDot1q(2) · modeQppb(3) · modeIpSourceGuard(4) · modeVoiceVlan(5) · modeDcbx(6) |
CB association mode. |
hh3cCBQoSPolicyClassCfgOrder (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.9) |
read-only |
Integer32 |
CB association configuration order. |
Not supported |
hh3cCBQoSIfApplyPolicyTable
About this table
.This table applies a QoS policy to an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cCBQoSIfApplyPolicyIfIndex and hh3cCBQoSIfApplyPolicyDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSIfApplyPolicyIfIndex (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.1) |
Integer32 |
Index of the interface to which a QoS policy is applied. |
As per the MIB. |
hh3cCBQoSIfApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.2) |
DirectionType |
Application direction. |
As per the MIB. |
hh3cCBQoSIfApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.3) |
read-create |
OCTET STRING |
SIZE (1..31) |
Policy name. |
As per the MIB. |
hh3cCBQoSIfApplyPolicyEnableDynamic (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.4) |
read-create |
INTEGER |
· unavailable(1) · true(2) · false(3) |
Dynamic QoS |
Not supported. The value is fixed at unavailable(1). |
hh3cCBQoSIfApplyPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.5) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSIfApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.6) |
read-only |
INTEGER |
· processing (0) · success (1) · partialItemFailed (2) |
Application status. |
As per the MIB. |
hh3cCBQoSVlanApplyPolicyTable
About this table
This table applies a QoS policy to a VLAN interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cCBQoSVlanApplyPolicyVlanid and hh3cCBQoSVlanApplyPolicyDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSVlanApplyPolicyVlanid (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.1) |
Integer32 |
VLAN ID. |
As per the MIB. |
hh3cCBQoSVlanApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.2) |
DirectionType |
As per the MIB. |
hh3cCBQoSVlanApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.3) |
read-create |
OCTET STRING |
SIZE (0..31) |
Policy name. |
As per the MIB. |
hh3cCBQoSVlanApplyPriority (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.4) |
read-create |
Integer32 |
0..4095 |
Policy priority. |
hh3cCBQoSVlanApplyPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.5) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSVlanApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.6) |
read-only |
INTEGER |
· processing (1) · success (2) · partialItemFailed (3) |
As per the MIB. |
hh3cCBQoSGlobalApplyTable
About this table
This table applies a QoS policy globally.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cCBQoSGlobalApplyDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSGlobalApplyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.1) |
not-accessible |
DirectionType |
As per the MIB. |
hh3cCBQoSGlobalApplyName (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.2) |
read-create |
OCTET STRING |
SIZE (1..31) |
Policy name. |
As per the MIB. |
hh3cCBQoSGlobalApplyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.3) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSGlobalApplyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.4) |
read-only |
INTEGER |
As per the MIB. |
hh3cCBQoSCpApplyPolicyTable
About this table
This table describes application information for a QoS policy applied to a control plane.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cCBQoSCpApplyPolicyChassis, hh3cCBQoSCpApplyPolicySlot, and hh3cCBQoSCpApplyPolicyDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCpApplyPolicyChassis (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.1) |
not-accessible |
Unsigned32 |
Chassis number for the control plane. |
As per the MIB. |
hh3cCBQoSCpApplyPolicySlot (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.2) |
not-accessible |
Unsigned32 |
Slot number for the control plane. |
As per the MIB. |
hh3cCBQoSCpApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.3) |
not-accessible |
DirectionType |
As per the MIB. |
hh3cCBQoSCpApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.4) |
read-create |
OCTET STRING |
SIZE (1..31) |
Policy name. |
As per the MIB. |
hh3cCBQoSCpApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.5) |
read-only |
INTEGER |
As per the MIB. |
hh3cCBQoSCpApplyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.6) |
read-create |
RowStatus |
Row status. |
hh3cCBQoSApplyObjectTable
About this table
This table obtains the application entity information for a QoS policy.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cCBQoSApplyObjectIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.1) |
not-accessible |
Unsigned32 |
Application entity index. |
As per the MIB. |
hh3cCBQoSApplyObjectType (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.2) |
read-only |
ApplyObjectType |
Application entity type. |
· interface(1) · vlan(2) · controlPlane(5) |
hh3cCBQoSApplyObjectDirection (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.3) |
read-only |
DirectionType |
Application entity direction. |
As per the MIB. |
hh3cCBQoSApplyObjectMainSite (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.4) |
read-only |
Unsigned32 |
Main index of the application entity. |
As per the MIB. |
hh3cCBQoSApplyObjectSubChannel (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.5) |
read-only |
Unsigned32 |
Subchannel ID of the application entity. |
As per the MIB. |
hh3cCBQoSApplyObjectSubClass (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.6) |
read-only |
Unsigned32 |
Level-1 subclass number for level-2 nesting. |
As per the MIB. |
hh3cCBQoSApplyObjectSubClassSec (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.7) |
read-only |
Unsigned32 |
Level-2 subclass number for level-3 nesting. |
As per the MIB. |
hh3cCBQoSIntApplyObjectTable
About this table
This table obtains the application entity index for a QoS policy applied to an interface.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cCBQoSIntApplyObjectIfIndex and hh3cCBQoSApplyObjectDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSIntApplyObjectIfIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.1) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cCBQoSIntApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cCBQoSVlanApplyObjectTable
About this table
This table obtains the application entity index for a QoS policy applied to a VLAN or globally.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cCBQoSVlanApplyObjectVlanID and hh3cCBQoSApplyObjectDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSVlanApplyObjectVlanID (1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.1) |
not-accessible |
Unsigned32 |
0..4094 |
ID of the VLAN to which a QoS policy is applied. |
When the value is 0, the QoS policy is applied globally. |
hh3cCBQoSVlanApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.2) |
read-only |
Unsigned32 |
As per the MIB. |
About this table
This table obtains the application entity index for a child QoS policy.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cCBQoSApplyObjectIndex and hh3cCBQoSNestPolicyClassIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSNestPolicyClassIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.5.1.1) |
not-accessible |
Unsigned32 |
Policy class index. |
As per the MIB. |
hh3cCBQoSNestPolicyApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.5.1.2) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cCBQoSCpApplyObjectTable
About this table
This table obtains QoS policy application information for a control plane.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cCBQoSCpApplyObjectChassis, hh3cCBQoSCpApplyObjectSlot, and hh3cCBQoSApplyObjectDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCpApplyObjectChassis (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.1) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cCBQoSCpApplyObjectSlot (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.2) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cCBQoSCpApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.3) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cCBQoSCbqRunInfoTable
About this table
This table obtains CBQ queue statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCbqQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.1) |
read-only |
Integer32 |
Current CBQ queue size. |
As per the MIB. |
hh3cCBQoSCbqDiscard (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.2) |
read-only |
Counter64 |
Number of packets dropped by the CBQ queue. |
As per the MIB. |
hh3cCBQoSCbqEfQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.3) |
read-only |
Integer32 |
EF queue size. |
As per the MIB. |
hh3cCBQoSCbqAfQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.4) |
read-only |
Integer32 |
AF queue size. |
As per the MIB. |
hh3cCBQoSCbqBeQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.5) |
read-only |
Integer32 |
BE queue size. |
As per the MIB. |
hh3cCBQoSCbqBeActiveQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.6) |
read-only |
Integer32 |
Number of active BE queues. |
As per the MIB. |
hh3cCBQoSCbqBeMaxActiveQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.7) |
read-only |
Integer32 |
Maximum number of active BE queues that have existed. |
As per the MIB. |
hh3cCBQoSCbqBeTotalQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.8) |
read-only |
Integer32 |
Total number of BE queues. |
As per the MIB. |
hh3cCBQoSCbqAfAllocatedQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.9) |
read-only |
Integer32 |
Number of AF queues that have been allocated. |
As per the MIB. |
About this table
This table obtains matching statistics about a traffic class.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cCBQoSApplyObjectIndex and hh3cCBQoSPolicyClassIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSClassMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.1) |
read-only |
Counter64 |
Number of matching packets. |
As per the MIB. |
hh3cCBQoSClassMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.2) |
read-only |
Counter64 |
Number of matching bytes. |
As per the MIB. |
hh3cCBQoSClassFwdPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.3) |
read-only |
Unsigned32 |
Number of packets sent per second during the last collection interval. |
Not supported |
hh3cCBQoSClassFwdPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.4) |
read-only |
Unsigned32 |
Number of bits sent per second during the last collection interval. |
Not supported |
hh3cCBQoSClassDropPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.5) |
read-only |
Unsigned32 |
Number of packets dropped per second during the last collection interval. |
Not supported |
hh3cCBQoSClassDropPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.6) |
read-only |
Unsigned32 |
Number of bits dropped per second during the last collection interval. |
Not supported |
hh3cCBQoSClassFlowStatInterval (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.7) |
read-only |
Unsigned32 |
Statistics collection interval. |
Not supported |
hh3cCBQoSClassBehaviorStatus (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.8) |
read-only |
INTEGER |
· success(1) · failure(2) · partialSuccess(3) |
CB association application status. |
As per the MIB. |
hh3cCBQoSCarRunInfoTable
About this table
This table obtains CAR statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSCarGreenPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.1) |
read-only |
Counter64 |
Number of packets matching the CAR configuration |
As per the MIB. |
hh3cCBQoSCarGreenBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.2) |
read-only |
Counter64 |
Number of bytes matching the CAR configuration |
As per the MIB. |
hh3cCBQoSCarRedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.3) |
read-only |
Counter64 |
Number of red packets. |
As per the MIB. |
hh3cCBQoSCarRedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.4) |
read-only |
Counter64 |
Number of red bytes. |
As per the MIB. |
hh3cCBQoSCarYellowPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.5) |
read-only |
Counter64 |
Number of yellow packets. |
As per the MIB. |
hh3cCBQoSCarYellowBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.6) |
read-only |
Counter64 |
Number of yellow bytes. |
As per the MIB. |
hh3cCBQoSCarClassName (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.7) |
read-only |
OCTET STRING |
SIZE (1..31) |
As per the MIB. |
hh3cCBQoSRemarkRunInfoTable
About this table
This table obtains marking statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSRemarkedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.5.1.1) |
read-only |
Counter64 |
Number of packets marked. |
As per the MIB. |
hh3cCBQoSQueueRunInfoTable
About this table
.This table obtains queue-related traffic statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSQueueMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.1) |
read-only |
Counter64 |
Number of packets matching a queue. |
As per the MIB. |
hh3cCBQoSQueueMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.2) |
read-only |
Counter64 |
Number of bytes matching the queue. |
As per the MIB. |
hh3cCBQoSQueueEnqueuedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.3) |
read-only |
Counter64 |
Number of packets enqueued. |
As per the MIB. |
hh3cCBQoSQueueEnqueuedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.4) |
read-only |
Counter64 |
Number of bytes enqueued. |
As per the MIB. |
hh3cCBQoSQueueDiscardedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.5) |
read-only |
Counter64 |
Number of packets dropped by the queue. |
As per the MIB. |
hh3cCBQoSQueueDiscardedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.6) |
read-only |
Counter64 |
Number of bytes dropped by the queue. |
As per the MIB. |
About this table
This table obtains traffic statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSAccountingPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.1) |
read-only |
Counter64 |
Number of packets. |
As per the MIB. |
hh3cCBQoSAccountingBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.2) |
read-only |
Counter64 |
Number of bytes. |
As per the MIB. |
hh3cCBQoSAccountingPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.3) |
read-only |
Counter64 |
Traffic rate in pps. |
As per the MIB. |
hh3cCBQoSAccountingPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.4) |
read-only |
Counter64 |
Traffic rate in bps. |
As per the MIB. |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cCBQoSPolicyAccPackets |
read-only |
Counter64 |
As per the MIB. |
hh3cCBQoSPolicyAccBytes |
read-only |
Counter64 |
Number of bytes. |
As per the MIB. |
Notifications
The following information describes the notifications included in the HH3C-CBQOS2-MIB module.
hh3cCBQoSGlobalAclNotSupport
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.3 |
The global ACL is not supported. |
Informational |
Warning |
N/A |
OFF |
Notification triggers
This notification is generated when you apply a QoS policy globally and a card does not support the ACL used in the QoS policy.
System impact
The QoS policy applied globally does not take effect on the card.
Status control
ON
· CLI: Use the snmp-agent trap enable qos command.
OFF
· CLI: Use the undo snmp-agent trap enable qos command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0..65534 |
Slot number |
N/A |
Integer32 |
0..65534 |
CPU number |
N/A |
Integer32 |
0..65534 |
Application direction |
N/A |
DirectionTyp |
Recommended action
No action is required.
hh3cCBQoSGlobalQPPBNotSupport
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.4 |
QPPB is not supported. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when you apply a QoS policy globally in QPPB mode and a card does not support QPPB.
System impact
The QoS policy applied globally in QPPB mode does not take effect on the card.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0..65534 |
Slot number |
N/A |
Integer32 |
0..65534 |
CPU number |
N/A |
Integer32 |
0..65534 |
N/A |
DirectionTyp |
Recommended action
Apply a QoS policy in QPPB mode to the interfaces on the card that support the QPPB mode.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.5 |
The redirection next hop is unreachable. |
Error |
Major |
hh3cCBQoSRedirectInvalidAlarmRecover |
OFF |
This notification is generated when the redirection next hop is unreachable.
System impact
The QoS policy containing the redirection action does not take effect.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.65.2.1.8.5 (hh3cCBQoSRedirectAlarmBehaviorName) |
Traffic behavior name |
N/A |
OCTET STRING |
SIZE (1..31) |
1.3.6.1.4.1.25506.2.65.2.1.8.6 (hh3cCBQoSRedirectAlarmProtoFamily) |
Protocol family of the next-hop address |
N/A |
InetAddressType |
1.3.6.1.4.1.25506.2.65.2.1.8.7 (hh3cCBQoSRedirectAlarmNextHop) |
Next-hop address |
N/A |
InetAddress |
Recommended action
To resolve the issue, identify whether the next hop exists in the routing table. If the next hop does not exist in the routing table, configure a routing protocol for the next hop to be learned to the routing table.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.6 |
The redirection next hop is reachable. |
Recovery |
Major |
N/A |
OFF |
This notification is generated when the redirection next hop is reachable.
System impact
No negative impact on the system.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
SIZE (1..31) |
N/A |
InetAddressType |
Next-hop address |
N/A |
InetAddress |
Recommended action
