12-ACL and QoS
HomeSupportReference GuidesMIB CompanionH3C S9850-G&S6530X Switch Series MIB References-R8307Pxx-6W10012-ACL and QoS
03-HH3C-IFQOS2-MIB
03-HH3C-IFQOS2-MIB 627.21 KB
HH3C-IFQOS2-MIB· 1
About this MIB· 1
MIB file name· 2
Root object 2
Scalar objects· 2
hh3cIfQoSChassis· 2
hh3cIfQoSSlot 2
hh3cIfQoSCPU· 2
hh3cIfQoSChip· 2
hh3cIfQoSIfName· 2
hh3cIfQoSDirection· 3
hh3cIfQoSPassPacketRate· 3
hh3cIfQoSCoppProtocol 3
hh3cIfQoSBandwidth· 3
hh3cIfQoSServiceName· 3
hh3cIfQoSApplyObject 3
hh3cIfQoSFailReason· 4
hh3cIfQoSBandwidthUnit 4
Tabular objects· 4
hh3cIfQoSQSModeTable· 4
hh3cIfQoSQSWeightTable· 5
hh3cIfQoSHardwareQueueRunInfoTable· 5
hh3cIfQoSHQueueTcpRunInfoTable· 7
hh3cIfQoSLRConfigTable· 9
hh3cIfQoSLRRunInfoTable· 10
hh3cIfQoSAggregativeCarConfigTable· 11
hh3cIfQoSAggregativeCarApplyTable· 12
hh3cIfQoSAggregativeCarRunInfoTable· 13
hh3cIfQoSTricolorCarConfigTable· 14
hh3cIfQoSTricolorCarRunInfoTable· 15
hh3cIfQoSGTSConfigTable· 16
hh3cIfQoSGTSRunInfoTable· 18
hh3cIfQoSWredGroupTable· 18
hh3cIfQoSWredGroupContentTable· 19
hh3cIfQoSWredGroupApplyIfTable· 20
hh3cIfQoSPortPriorityTable· 21
hh3cIfQoSPortPirorityTrustTable· 21
hh3cIfQoSPrePriMapTable· 22
hh3cQoSRemarkTcpPortPriTable· 23
hh3cQoSRemarkUdpPortPriTable· 24
hh3cQoSRemarkIPv4AddrPriTable· 25
hh3cQoSRemarkIPv6AddrPriTable· 26
hh3cQoSRemarkProtocolPriTable· 27
hh3cQoSRemarkVlanPriTable· 27
hh3cIfQoSCoppFlowStatTable· 28
Notifications· 29
hh3cIfQoS8QueueResouceOverAlarm·· 29
hh3cIfQoS8QueueResouceOverRecover 30
hh3cIfQoS8QueueResoucePreAlarm·· 31
hh3cIfQoS8QueueResoucePreRecover 32
hh3cIfQoSBufferOverAlarm·· 33
hh3cIfQoSBufferOverRecover 34
hh3cIfQoSModeChannelOverPortShapAlarm·· 35
hh3cIfQoSModeChannelOverPortShapRecover 36
hh3cIfQoSExclusiveBandApplyFailAlarm·· 37
hh3cIfQoSExclusiveBandApplyFailRecover 38
hh3cIfQoSExclusiveBandOverAlarm·· 39
hh3cIfQoSExclusiveBandOverRecover 40
hh3cIfQoSLRDiscardAlarm·· 41
hh3cIfQoSLRDiscardAlarmRecover 41
hh3cIfQoSCarDiscardAlarm·· 42
hh3cIfQoSCarDiscardAlarmRecover 43
hh3cIfQoSCoppDropPktAlarm·· 44
hh3cIfQoSCoppDropPktAlarmRecover 45
hh3cIfQoSQueExcpAlarm·· 46
hh3cIfQoSQueExcpAlarmRecover 47
hh3cIfQoSBoardL3AclResLack· 47
hh3cIfQoSAclResAlarm·· 48
hh3cIfQoSAclResAlarmRecover 49
hh3cIfQoSAclMemFullAlarm·· 50
hh3cIfQoSAclMemFullAlarmRecover 51
HH3C-IFQOS2-MIB
About this MIB
Use this MIB to configure or obtain settings for the following modules:
·      Hardware queuing.
·      Software queuing.
·      Rate limit.
·      CAR.
·      GTS.
·      WRED.
·      Port priority and priority trust mode.
·      Priority map.
CAR includes aggregate CAR and three-color CAR. WRED includes table-based WRED and interface WRED.
WRED
WRED avoids global TCP synchronization by randomly dropping packets before a queue is full. WRED sets an upper threshold and lower threshold for each queue, and processes the packets in a queue as follows:
·     When the queue size is shorter than the lower threshold, no packet is dropped.
·     When the queue size reaches the upper threshold, all subsequent packets are dropped.
·     When the queue size is between the lower threshold and the upper threshold, the received packets are dropped at random. The drop probability in a queue increases along with the queue size under the maximum drop probability.
WRED can discard packets based on the IP precedence, DSCP, or MPLS EXP value and selectively discard low-priority packets.
Through combining WRED with WFQ, the flow-based WRED can be realized.
WRED has the following types:
·     Port-based WRED: Applies WRED to all packets on a port.
·     Queue-based WRED: Applies WRED to only packets on WRED-enabled queues.
·     Drop level-based WRED: Applies different WRED parameters to packets with different WRED parameters.
·     ACL-based WRED: Applies different WRED parameters to packets matching different ACLs.
·     802.1p-based WRED: Applies different WRED parameters to packets with different 802.1p priorities.
·     EXP-based WRED: Applies different WRED parameters to packets with different EXP priorities.
·     ATM CLP-based WRED: Applies different WRED parameters to packets with different CLP priorities.
·     DSCP-based WRED: Applies different WRED parameters to packets with different DSCP values.
·     IP precedence-based WRED: Applies different WRED parameters to packets with different IP precedences.
·     FR DE-based WRED: Applies different WRED parameters to packets with different DE bit settings.
ComwareV500R002 supports two WRED configuration approaches:
·     Interface configuration—Configure WRED parameters on an interface or PVC and enable WRED.
·     WRED table configuration—Configure a WRED table in system view and then apply the WRED table to an interface. A maximum number of 64 WRED tables is supported.
Aggregate CAR
Some switch models support aggregate CAR.
An aggregate CAR action is created globally. It can be directly applied to interfaces or used in the traffic behaviors associated with different traffic classes to police multiple traffic flows as a whole. The total rate of the traffic flows must conform to the traffic policing specifications set in the aggregate CAR action.
MIB file name
hh3c-ifqos2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).huawei(2011).hh3c(10).hh3cCommon(2).hh3cQos2(65).hh3cIfQos2(1)
Scalar objects
hh3cIfQoSChassis
Object (OID)
Access
Value range
Implementation
hh3cIfQoSChassis
(1.3.6.1.4.1.25506.2.65.1.15.1)
accessible-for-notify
Integer32
0..65534
Chassis number.
hh3cIfQoSSlot
Object (OID)
Access
Value range
Implementation
hh3cIfQoSSlot
(1.3.6.1.4.1.25506.2.65.1.15.2)
Integer32
0..65534
Slot number.
hh3cIfQoSCPU
Object (OID)
Access
Value range
Implementation
hh3cIfQoSCPU
 (1.3.6.1.4.1.25506.2.65.1.15.3)
Integer32
0..65534
CPU number.
hh3cIfQoSChip
Object (OID)
Access
Value range
Implementation
hh3cIfQoSChip
(1.3.6.1.4.1.25506.2.65.1.15.4)
Integer32
0..65534
Chip number.
hh3cIfQoSIfName
Object (OID)
Access
Value range
Implementation
hh3cIfQoSIfName (1.3.6.1.4.1.25506.2.65.1.15.5)
OCTET STRING
SIZE (1..47)
Interface name.
hh3cIfQoSDirection
Object (OID)
Access
Value range
Implementation
hh3cIfQoSDirection
(1.3.6.1.4.1.25506.2.65.1.15.6)
Direction
Standard MIB values.
Direction.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSPassPacketRate (1.3.6.1.4.1.25506.2.65.1.15.7)
read-only
Unsigned32
Traffic rate.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSCoppProtocol (1.3.6.1.4.1.25506.2.65.1.15.8)
read-only
OCTET STRING
SIZE (1..31)
Protocol type.
hh3cIfQoSBandwidth
Object (OID)
Access
Value range
Implementation
hh3cIfQoSBandwidth (1.3.6.1.4.1.25506.2.65.1.15.9)
read-only
Unsigned32
Bandwidth.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSServiceName (1.3.6.1.4.1.25506.2.65.1.15.10)
read-only
OCTET STRING
SIZE (1..63)
Service name.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSApplyObject (1.3.6.1.4.1.25506.2.65.1.15.11)
read-only
OCTET STRING
SIZE (1..127)
Application object.
hh3cIfQoSFailReason
Object (OID)
Access
Value range
Implementation
hh3cIfQoSFailReason (1.3.6.1.4.1.25506.2.65.1.15.12)
read-only
OCTET STRING
SIZE (1..127)
Failure causes.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSBandwidthUnit (1.3.6.1.4.1.25506.2.65.1.15.13)
read-only
INTEGER
·     unitUnavailable (0)
·     unitAbsolute (1)
·     unitAbsolutePPS (4)
Bandwidth unit.
Tabular objects
About this table
This table specifies the queuing mode. This table and hh3cIfQoSQSWeightTable together configure the queuing settings.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSQSMode (1.3.6.1.4.1.25506.2.65.1.1.1.1.1.1)
read-write
INTEGER
·     sp(1)
·     sp0(2)
·     sp1(3)
·     sp2(4)
·     wrr(5)
·     hwfq(6)
·     wrr-sp(7)
·     byteCountWrr(8)byteCountWfq(9)
·     gmb(10)
Queuing mode.
Implementation varies by product.
About this table
This table configures attributes for non-SP queues. This table and hh3cIfQoSQSModeTable together configure the queuing settings.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cIfQoSQueueID.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSQueueID (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.1)
not-accessible
Integer32
Queue ID.
As per the MIB.
hh3cIfQoSQueueGroupType (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.2)
read-write
INTEGER
·     group0(1)
·     group1(2)
·     group2(3)
·     group3(4)
·     group4(5)
WRR group.
hh3cIfQoSQSType (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.3)
read-write
INTEGER
·     weight(1)
·     byte-count(2)
Queuing type.
As per the MIB.
hh3cIfQoSQSValue (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.4)
read-write
Integer32
Scheduling weight.
As per the MIB.
hh3cIfQoSQSMaxDelay (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.5)
read-write
Integer32
Maximum delay.
Not supported.
The value is fixed at 9.
hh3cIfQoSQSMinBandwidth (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.6)
read-write
Integer32
Minimum guaranteed bandwidth.
hh3cIfQoSQSMinBandwidthPercent(1.3.6.1.4.1.25506.2.65.1.1.1.2.1.7)
read-write
Unsigned32
·     0..100
·     255
Percentage of the minimum guaranteed bandwidth to the available bandwidth.
About this table
This table contains queue-based traffic statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSPassPackets (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.1)
read-only
Counter64
Number of forwarded packets.
As per the MIB.
hh3cIfQoSDropPackets (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.2)
read-only
Counter64
Number of dropped packets.
As per the MIB.
hh3cIfQoSPassBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.3)
read-only
Counter64
Number of forwarded bytes.
As per the MIB.
hh3cIfQoSPassPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.4)
read-only
Unsigned32
Packet forwarding rate in packets per second.
As per the MIB.
hh3cIfQoSPassBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.5)
read-only
Unsigned32
Packet forwarding rate in bytes per second.
As per the MIB.
hh3cIfQoSDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.6)
read-only
Counter64
Number of dropped bytes.
As per the MIB.
hh3cIfQoSQueueLengthInPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.7)
read-only
Unsigned32
Maximum queue length in packets.
As per the MIB.
hh3cIfQoSQueueLengthInBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.8)
read-only
Unsigned32
Maximum queue length in bytes.
Not supported
hh3cIfQoSCurQueuePkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.9)
read-only
Unsigned32
Current queue length in packets.
Not supported
hh3cIfQoSCurQueueBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.10)
read-only
Unsigned32
Current queue length in bytes.
Not supported
hh3cIfQoSCurQueuePPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.11)
read-only
Unsigned32
Number of packets enqueued per second.
Not supported
hh3cIfQoSCurQueueBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.12)
read-only
Unsigned32
Number of bytes enqueued per second.
Not supported
hh3cIfQoSTailDropPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.13)
read-only
Counter64
Number of packets dropped by tail drop.
Not supported
hh3cIfQoSTailDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.14)
read-only
Counter64
Number of bytes dropped by tail drop.
Not supported
hh3cIfQoSTailDropPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.15)
read-only
Unsigned32
Number of packets dropped per second by tail drop.
Not supported
hh3cIfQoSTailDropBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.16)
read-only
Unsigned32
Number of bytes dropped per second by tail drop.
Not supported
hh3cIfQoSWredDropPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.17)
read-only
Counter64
Number of packets dropped by WRED.
Not supported
hh3cIfQoSWredDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.18)
read-only
Counter64
Number of bytes dropped by WRED.
Not supported
hh3cIfQoSWredDropPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.19)
read-only
Unsigned32
Number of packets dropped per second by WRED.
Not supported
hh3cIfQoSWredDropBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.20)
read-only
Unsigned32
Number of bytes dropped per second by WRED.
Not supported
hh3cIfQoSPeakPassPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.24)
read-only
Unsigned32
Peak number of packets forwarded.
As per the MIB.
hh3cIfQoSPeakPassBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.25)
read-only
Unsigned32
Peak number of bytes forwarded.
As per the MIB.
About this table
This table contains queue-based traffic statistics on TCP packets and non-TCP packets.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSWredDropLPreNTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.1)
read-only
Counter64
Number of low-priority non-TCP packets dropped by WRED.
As per the MIB.
hh3cIfQoSWredDropLPreNTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.2)
read-only
Counter64
Number of low-priority non-TCP bytes dropped by WRED.
As per the MIB.
hh3cIfQoSWredDropLPreNTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.3)
read-only
Unsigned32
Number of low-priority non-TCP packets dropped by WRED per second.
As per the MIB.
hh3cIfQoSWredDropLPreNTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.4)
read-only
Unsigned32
Number of low-priority non-TCP bytes dropped by WRED per second.
As per the MIB.
hh3cIfQoSWredDropLPreTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.5)
read-only
Counter64
Number of low-priority TCP packets dropped by WRED.
As per the MIB.
hh3cIfQoSWredDropLPreTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.6)
read-only
Counter64
Number of low-priority TCP bytes dropped by WRED.
As per the MIB.
hh3cIfQoSWredDropLPreTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.7)
read-only
Unsigned32
Number of low-priority TCP packets dropped by WRED per second.
As per the MIB.
hh3cIfQoSWredDropLPreTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.8)
read-only
Unsigned32
Number of low-priority TCP bytes dropped by WRED per second.
As per the MIB.
hh3cIfQoSWredDropHPreNTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.9)
read-only
Counter64
Number of high-priority non-TCP packets dropped by WRED.
As per the MIB.
hh3cIfQoSWredDropHPreNTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.10)
read-only
Counter64
Number of high-priority non-TCP bytes dropped by WRED.
As per the MIB.
hh3cIfQoSWredDropHPreNTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.11)
read-only
Unsigned32
Number of high-priority non-TCP packets dropped by WRED per second.
As per the MIB.
hh3cIfQoSWredDropHPreNTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.12)
read-only
Unsigned32
Number of high-priority non-TCP bytes dropped by WRED per second.
As per the MIB.
hh3cIfQoSWredDropHPreTcpPkts (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.13)
read-only
Counter64
Number of high-priority TCP packets dropped by WRED.
As per the MIB.
hh3cIfQoSWredDropHPreTcpBytes (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.14)
read-only
Counter64
Number of high-priority TCP bytes dropped by WRED.
As per the MIB.
hh3cIfQoSWredDropHPreTcpPPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.15)
read-only
Unsigned32
Number of high-priority TCP packets dropped by WRED per second.
As per the MIB.
hh3cIfQoSWredDropHPreTcpBPS (1.3.6.1.4.1.25506.2.65.1.1.2.2.1.16)
read-only
Unsigned32
Number of high-priority TCP bytes dropped by WRED per second.
As per the MIB.
About this table
This table configures the inbound or outbound rate limit on an interface.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ifIndex and hh3cIfQoSLRDirection.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSLRDirection (1.3.6.1.4.1.25506.2.65.1.3.1.1.1)
not-accessible
Direction
Rate limit direction.
hh3cIfQoSLRCir (1.3.6.1.4.1.25506.2.65.1.3.1.1.2)
read-create
Unsigned32
CIR.
hh3cIfQoSLRCbs (1.3.6.1.4.1.25506.2.65.1.3.1.1.3)
read-create
Unsigned32
CBS.
hh3cIfQoSLREbs (1.3.6.1.4.1.25506.2.65.1.3.1.1.4)
read-create
Unsigned32
EBS.
hh3cIfQoSRowStatus (1.3.6.1.4.1.25506.2.65.1.3.1.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cIfQoSLRPir (1.3.6.1.4.1.25506.2.65.1.3.1.1.6)
read-create
Unsigned32
PIR.
hh3cIfQoSLRUnit (1.3.6.1.4.1.25506.2.65.1.3.1.1.7)
read-create
INTEGER
·     unitAbsolute(1)
·     unitPercent(2)
Rate limit unit.
About this table
This table contains rate limit statistics on an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSLRRunInfoPassedPackets (1.3.6.1.4.1.25506.2.65.1.3.2.1.1)
read-only
Counter64
As per the MIB.
hh3cIfQoSLRRunInfoPassedBytes (1.3.6.1.4.1.25506.2.65.1.3.2.1.2)
read-only
Counter64
As per the MIB.
hh3cIfQoSLRRunInfoDelayedPackets (1.3.6.1.4.1.25506.2.65.1.3.2.1.3)
read-only
Counter64
Number of delayed packets.
As per the MIB.
hh3cIfQoSLRRunInfoDelayedBytes (1.3.6.1.4.1.25506.2.65.1.3.2.1.4)
read-only
Counter64
Number of delayed bytes.
As per the MIB.
hh3cIfQoSLRRunInfoActiveShaping (1.3.6.1.4.1.25506.2.65.1.3.2.1.5)
read-only
INTEGER
·     active(1)
·     inactive(2)
Rate limit configuration status.
As per the MIB.
About this table
This table contains aggregate CAR configuration, which can police the traffic on multiple ports.  Routers do not support aggregate CAR. Some switch models support aggregate CAR.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cIfQoSAggregativeCarIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSAggregativeCarIndex (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.1)
not-accessible
Integer32
1..65534
Aggregate CAR index.
As per the MIB.
hh3cIfQoSAggregativeCarName (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
Aggregate CAR name.
As per the MIB.
hh3cIfQoSAggregativeCarCir (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.3)
read-create
Unsigned32
CIR.
As per the MIB.
hh3cIfQoSAggregativeCarCbs (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.4)
read-create
Unsigned32
CBS.
hh3cIfQoSAggregativeCarEbs (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.5)
read-create
Unsigned32
EBS.
hh3cIfQoSAggregativeCarPir (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.6)
read-create
Unsigned32
PIR.
hh3cIfQoSAggregativeCarGreenActionType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.7)
read-create
Hh3cIfCarAction
Action to take on green packets.
hh3cIfQoSAggregativeCarGreenActionValue (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.8)
read-create
Integer32
·     0..63
·     255
Value to mark for green packets.
hh3cIfQoSAggregativeCarYellowActionType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.9)
read-create
Hh3cIfCarAction
Action to take on yellow packets.
hh3cIfQoSAggregativeCarYellowActionValue (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.10)
read-create
Integer32
·     0..63
·     255
Value to mark for yellow packets.
hh3cIfQoSAggregativeCarRedActionType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.11)
read-create
Hh3cIfCarAction
Action to take on red packets.
hh3cIfQoSAggregativeCarRedActionValue (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.12)
read-create
Integer
·     0..63
·     255
Value to mark for red packets.
hh3cIfQoSAggregativeCarType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.13)
read-create
INTEGER
·     aggregative(1)
·     NotAggregative(2)
·     hierarchy(3)
Aggregate CAR type.
hh3cIfQoSAggregativeCarRowStatus (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.14)
read-create
RowStatus
Row status.
As per the MIB.
About this table
This table contains aggregate CAR application information for an interface.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ifIndex, hh3cIfQoSAggregativeCarApplyDirection, hh3cIfQoSAggregativeCarApplyRuleType, and hh3cIfQoSAggregativeCarApplyRuleValue.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSAggregativeCarApplyDirection (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.1)
not-accessible
Direction
CAR direction.
hh3cIfQoSAggregativeCarApplyRuleType (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.2)
not-accessible
INTEGER
·     ipv4acl(1)
·     ipv6acl(2)
·     carl(3)
·     any(4)
CAR type.
hh3cIfQoSAggregativeCarApplyRuleValue (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.3)
not-accessible
Integer32
0..2147483647
CAR type value.
.Implementation varies by product.
hh3cIfQoSAggregativeCarApplyCarIndex (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.4)
read-create
Integer32
1..65534
As per the MIB.
hh3cIfQoSAggregativeCarApplyRowStatus (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.5)
read-create
RowStatus
Row status.
As per the MIB.
About this table
This table contains aggregate CAR statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSAggregativeCarGreenPackets (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.1)
read-only
Counter64
Number of green packets.
hh3cIfQoSAggregativeCarGreenBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.2)
read-only
Counter64
Number of green bytes.
hh3cIfQoSAggregativeCarYellowPackets (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.3)
read-only
Counter64
Number of yellow packets.
hh3cIfQoSAggregativeCarYellowBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.4)
read-only
Counter64
Number of yellow bytes.
hh3cIfQoSAggregativeCarRedPackets (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.5)
read-only
Counter64
Number of red packets.
hh3cIfQoSAggregativeCarRedBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.6)
read-only
Counter64
Number of red bytes.
About this table
This table contains three-color CAR configuration.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSTricolorCarDirection (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.1)
not-accessible
Direction
hh3cIfQoSTricolorCarType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.2)
not-accessible
INTEGER
·     ipv4acl(1)
·     ipv6acl(2)
·     carl(3)
·     any(4)
Aggregate CAR name.
hh3cIfQoSTricolorCarValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.3)
not-accessible
Integer32
0..2147483647
CAR.
hh3cIfQoSTricolorCarCir (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.4)
read-create
Unsigned32
CIR.
hh3cIfQoSTricolorCarCbs (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.5)
read-create
Unsigned32
CBS.
hh3cIfQoSTricolorCarEbs (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.6)
read-create
Unsigned32
EBS.
hh3cIfQoSTricolorCarPir (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.7)
read-create
Unsigned32
PIR.
hh3cIfQoSTricolorCarGreenActionType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.8)
read-create
Hh3cIfCarAction
hh3cIfQoSTricolorCarGreenActionValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.9)
read-create
Integer32
·     0..63
·     255
hh3cIfQoSTricolorCarYellowActionType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.10)
read-create
Hh3cIfCarAction
hh3cIfQoSTricolorCarYellowActionValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.11)
read-create
Integer32
·     0..63
·     255
hh3cIfQoSTricolorCarRedActionType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.12)
read-create
Hh3cIfCarAction
hh3cIfQoSTricolorCarRedActionValue (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.13)
read-create
Integer32
·     0..63
·     255
hh3cIfQoSTricolorCarRowStatus (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.14)
read-create
RowStatus
Row status.
As per the MIB.
hh3cIfQoSTricolorCarUnitType (1.3.6.1.4.1.25506.2.65.1.4.2.1.1.15)
read-create
INTEGER
·     unitAbsolute(1)
·     unitPercent(2)
Rate limit unit.
About this table
This table contains three-color CAR statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ifIndex, hh3cIfQoSTricolorCarDirection, hh3cIfQoSTricolorCarType, and hh3cIfQoSTricolorCarValue.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSTricolorCarGreenPackets (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.1)
read-only
Counter64
hh3cIfQoSTricolorCarGreenBytes (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.2)
read-only
Counter64
hh3cIfQoSTricolorCarYellowPackets (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.3)
read-only
Counter64
hh3cIfQoSTricolorCarYellowBytes (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.4)
read-only
Counter64
hh3cIfQoSTricolorCarRedPackets (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.5)
read-only
Counter64
hh3cIfQoSTricolorCarRedBytes (1.3.6.1.4.1.25506.2.65.1.4.2.2.1.6)
read-only
Counter64
About this table
This table contains GTS configuration information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ifIndex, hh3cIfQoSGTSClassRuleType, and hh3cIfQoSGTSClassRuleValue.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.65.1.5.1.1.1)
not-accessible
INTEGER
·     any(1)
·     ipv4acl(2)
·     ipv6acl(3)
·     queue(4)
GTS type.
Supports only queue(4).
hh3cIfQoSGTSClassRuleValue (1.3.6.1.4.1.25506.2.65.1.5.1.1.2)
not-accessible
Integer32
0..2147483647
GTS type value.
The value range is 0 to 7.
hh3cIfQoSGTSCir (1.3.6.1.4.1.25506.2.65.1.5.1.1.3)
read-create
Unsigned32
CIR.
·     The value range is 300 to 1000000 for GE interfaces.
·     The value range is 300 to 10000000 for 10-GE interfaces.
·     The value range is 300 to 40000000 for 40-GE interfaces.
·     The value range is 300 to 100000000 for 100-GE interfaces.
hh3cIfQoSGTSCbs (1.3.6.1.4.1.25506.2.65.1.5.1.1.4)
read-create
Unsigned32
CBS.
·     The value range is 4096 to 133169152 for GE interfaces.
·     The value range is 4096 to 133169152 for 10-GE interfaces.
·     The value range is 4096 to 535822336 for 40-GE interfaces.
·     The value range is 4096 to 1341128704 for 100-GE interfaces.
hh3cIfQoSGTSEbs (1.3.6.1.4.1.25506.2.65.1.5.1.1.5)
read-create
Unsigned32
EBS in bytes.
Not supported.
hh3cIfQoSGTSQueueLength (1.3.6.1.4.1.25506.2.65.1.5.1.1.6)
read-create
Integer32
Queue length.
Not supported.
hh3cIfQoSGTSConfigRowStatus (1.3.6.1.4.1.25506.2.65.1.5.1.1.7)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cIfQoSGTSPir (1.3.6.1.4.1.25506.2.65.1.5.1.1.8)
read-create
Unsigned32
PIR.
Not supported.
hh3cIfQoSGTSUnitType (1.3.6.1.4.1.25506.2.65.1.5.1.1.9)
read-create
INTEGER
·     unitAbsolute (1)
·     unitPercent(2)
GTS unit.
Supports only unitAbsolute(1).
About this table
This table contains GTS statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSGTSQueueSize (1.3.6.1.4.1.25506.2.65.1.5.2.1.1)
read-only
Integer32
Current number of packets in the queue.
As per the MIB.
hh3cIfQoSGTSPassedPackets (1.3.6.1.4.1.25506.2.65.1.5.2.1.2)
read-only
Counter64
As per the MIB.
hh3cIfQoSGTSPassedBytes (1.3.6.1.4.1.25506.2.65.1.5.2.1.3)
read-only
Counter64
As per the MIB.
hh3cIfQoSGTSDiscardPackets (1.3.6.1.4.1.25506.2.65.1.5.2.1.4)
read-only
Counter64
As per the MIB.
hh3cIfQoSGTSDiscardBytes (1.3.6.1.4.1.25506.2.65.1.5.2.1.5)
read-only
Counter64
As per the MIB.
hh3cIfQoSGTSDelayedPackets (1.3.6.1.4.1.25506.2.65.1.5.2.1.6)
read-only
Counter64
As per the MIB.
hh3cIfQoSGTSDelayedBytes (1.3.6.1.4.1.25506.2.65.1.5.2.1.7)
read-only
Counter64
As per the MIB.
About this table
This table creates a WRED table.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cIfQoSWredGroupIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSWredGroupIndex (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.1)
not-accessible
Integer32
0..256
WRED table index.
hh3cIfQoSWredGroupName (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.2)
read-create
OCTET STRING
SIZE (1..32)
WRED table name.
As per the MIB.
hh3cIfQoSWredGroupType (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.3)
read-create
INTEGER
·     userdefined(0)
·     dot1p(1)
·     ippre(2)
·     dscp(3)
·     localpre(4)
·     atmclp(5)
·     frde(6)
·     exp(7)
·     queue(8)
·     dropLevel(9)
WRED table type.
hh3cIfQoSWredGroupWeightingConstant (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.4)
read-create
Integer32
1..15
WRED exponent for average queue size calculation.
The default value is 9.
hh3cIfQoSWredGroupRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.6)
read-create
RowStatus
Row status.
As per the MIB.
About this table
This table configures a WRED table.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cIfQoSWredGroupIndex, hh3cIfQoSWredGroupContentIndex, and hh3cIfQoSWredGroupContentSubIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSWredGroupContentIndex (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.1)
not-accessible
Integer32
0..63
Second index.
hh3cIfQoSWredGroupContentSubIndex (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.2)
not-accessible
Integer32
0..63
Third index.
hh3cIfQoSWredLowLimit (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.3)
read-create
Integer32
Lower limit.
hh3cIfQoSWredHighLimit (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.4)
read-create
Integer32
Higher limit.
hh3cIfQoSWredDiscardProb (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.5)
read-create
Integer32
Drop probability.
hh3cIfQoSWredGroupExponent (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.6)
read-create
Integer32
0..15
hh3cIfQoSWredRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.7)
read-create
RowStatus
Row status.
As per the MIB.
About this table
This table contains WRED table application information for an interface.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSWredGroupApplyIndex (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.1)
read-create
Integer32
0..256
WRED table index.
As per the MIB.
hh3cIfQoSWredGroupApplyName (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.2)
read-only
OCTET STRING
SIZE (1..32)
WRED table name.
As per the MIB.
hh3cIfQoSWredGroupIfRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.3)
read-create
RowStatus
Row status.
As per the MIB.
About this table
This table contains the port priority. After the switch receives a packet, it performs priority mapping according to the configured priority trust mode. If no local precedence is successfully assigned or no packet priority is trusted, the switch uses the priority of the input interface as the local precedence or 802.1p priority for priority mapping. Routers do not support this table.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSPortPriorityValue (1.3.6.1.4.1.25506.2.65.1.7.1.1.1.1)
read-write
Integer32
0..7
Port priority.
About this table
This table contains the priority trust mode.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSPortPriorityTrustTrustType (1.3.6.1.4.1.25506.2.65.1.7.1.2.1.1)
read-write
INTEGER
·     untrust(1)
·     dot1p(2)
·     dscp(3)
·     exp(4)
·     ipPrecedence (5)
·     dot11e(6)
·     auto(7)
Priority trust mode.
hh3cIfQoSPortPriorityTrustOvercastType (1.3.6.1.4.1.25506.2.65.1.7.1.2.1.2)
read-write
INTEGER
·     noOvercast(1)
·     overcastDSCP(2)
·     overcastCOS(3)
·     overcast(4)
Overwrite mode.
About this table
This table configures a priority map.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cIfQoSPrePriMapTableType, hh3cIfQoSPrePriMapTableColor, hh3cIfQoSPrePriMapTableDirection, and hh3cIfQoSPrePriMapTableImportValue.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSPrePriMapTableType (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.1)
not-accessible
INTEGER
·     dot1pToLp(1)
·     dot1pToDp(2)
·     expToLp(3)
·     dscpToLp(4)
·     expToDp(5)
·     dscpToDp(6)
·     dscpToDot1p(7)
·     dot1pToDscp(8)
·     dscpToDscp(9)
·     dscpToExp(10)
·     expToDscp(11)
·     expToDot1p(12)
·     expToExp(13)
·     lpToDot1p(14)
·     dot1pToRpr(15)
·     dscpToRpr(16)
·     expToRpr(17)
·     ippreToRpr(18)
·     upToDot1p(19)
·     upToDscp(20)
·     upToExp(21)
·     upToDp(22)
·     upToLp(23)
·     upToRpr(24)
·     upToFc(25)
·     lpTodscp(26)
·     dot11eToLp(27)
·     lpToDot11e(28)
·     lpToLp(29)
·     dot1pToExp(30)
·     lpToExp(31)
·     lpToDp(32)
·     upToUp(33)
·     dot1pToDot1p(34)
Priority map type.
hh3cIfQoSPrePriMapTableColor (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.2)
not-accessible
INTEGER
·     nocolor(1)
·     green(2)
·     yellow(3)
·     red(4)
Priority map color.
hh3cIfQoSPrePriMapTableDirection (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.3)
not-accessible
INTEGER
·     nodirection(1)
·     inbound(2)
·     outbound(3)
Priority map direction.
hh3cIfQoSPrePriMapTableImportValue (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.4)
not-accessible
Integer32
0..63
Input values of the priority map.
As per the MIB.
hh3cIfQoSPrePriMapTableExportValue (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.5)
read-write
Integer32
0..63
Output values of the priority map.
As per the MIB.
About this table
This table contains TCP port-based priority information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cQoSRemarkTcpPortStart.
Object (OID)
Access
Value range
Implementation
hh3cQoSRemarkTcpPortStart(1.3.6.1.4.1.25506.2.65.1.12.1.1.1)
not-accessible
Integer32
0..65535
Start port number of a TCP port range.
As per the MIB.
hh3cQoSRemarkTcpPortEnd (1.3.6.1.4.1.25506.2.65.1.12.1.1.2)
read-create
Integer32
0..65535
End port number of a TCP port range.
As per the MIB.
hh3cQoSRemarkTcpPortType (1.3.6.1.4.1.25506.2.65.1.12.1.1.3)
read-create
INTEGER
·     ipAll(1)
·     ipv4(2)
·     ipv6(3)
IP type of matching packets.
As per the MIB.
hh3cQoSRemarkTcpPortDot1p (1.3.6.1.4.1.25506.2.65.1.12.1.1.4)
read-create
Unsigned32
·     0..7
·     255
802.1p priority value of matching packets.
As per the MIB.
hh3cQoSRemarkTcpPortDscp (1.3.6.1.4.1.25506.2.65.1.12.1.1.5)
read-create
Unsigned32
·     0..63
·     255
DSCP value of matching packets.
As per the MIB.
hh3cQoSRemarkTcpPortRowStatus (1.3.6.1.4.1.25506.2.65.1.12.1.1.6)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains UDP port-based priority information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Columns
The table index is hh3cQoSRemarkUdpPortStart.
Object (OID)
Access
Value range
Implementation
hh3cQoSRemarkUdpPortStart (1.3.6.1.4.1.25506.2.65.1.12.2.1.1)
not-accessible
Integer32
0..65535
Start port number of a UDP port range.
As per the MIB.
hh3cQoSRemarkUdpPortEnd (1.3.6.1.4.1.25506.2.65.1.12.2.1.2)
read-create
Integer32
0..65535
End port number of the UDP port range.
As per the MIB.
hh3cQoSRemarkUdpPortType (1.3.6.1.4.1.25506.2.65.1.12.2.1.3)
read-create
INTEGER
·     ipAll(1)
·     ipv4(2)
·     ipv6(3)
As per the MIB.
hh3cQoSRemarkUdpPortDot1p (1.3.6.1.4.1.25506.2.65.1.12.2.1.4)
read-create
Unsigned32
·     0..7
·     255
As per the MIB.
hh3cQoSRemarkUdpPortDscp (1.3.6.1.4.1.25506.2.65.1.12.2.1.5)
read-create
Unsigned32
·     0..63
·     255
As per the MIB.
hh3cQoSRemarkUdpPortRowStatus(1.3.6.1.4.1.25506.2.65.1.12.2.1.6)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains IPv4 address-based priority information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cQoSRemarkIPv4AddrValue.
Object (OID)
Access
Value range
Implementation
hh3cQoSRemarkIPv4AddrValue (1.3.6.1.4.1.25506.2.65.1.12.3.1.1)
not-accessible
IpAddress
IPv4 address.
As per the MIB.
hh3cQoSRemarkIPv4AddrMask (1.3.6.1.4.1.25506.2.65.1.12.3.1.2)
read-create
IpAddress
Mask for the IPv4 address.
As per the MIB.
hh3cQoSRemarkIPv4AddrMaskLength (1.3.6.1.4.1.25506.2.65.1.12.3.1.3)
read-create
Unsigned32
·     1..32
·     4294967295
Mask length for the IPv4 address
As per the MIB.
hh3cQoSRemarkIPv4AddrDot1p (1.3.6.1.4.1.25506.2.65.1.12.3.1.4)
read-create
Unsigned32
·     0..7
·     255
As per the MIB.
hh3cQoSRemarkIPv4AddrDscp (1.3.6.1.4.1.25506.2.65.1.12.3.1.5)
read-create
Unsigned32
·     0..63
·     255
As per the MIB.
hh3cQoSRemarkIPv4AddrRowStatus (1.3.6.1.4.1.25506.2.65.1.12.3.1.6)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains IPv6 address-based priority information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cQoSRemarkIPv6AddrValue.
Object (OID)
Access
Value range
Implementation
hh3cQoSRemarkIPv6AddrValue (1.3.6.1.4.1.25506.2.65.1.12.4.1.1)
not-accessible
InetAddressIPv6
IPv6 address.
As per the MIB.
hh3cQoSRemarkIPv6AddrPrefixLength (1.3.6.1.4.1.25506.2.65.1.12.4.1.2)
read-create
InetAddressPrefixLength
Prefix length for the IPv6 address.
As per the MIB.
hh3cQoSRemarkIPv6AddrDot1p (1.3.6.1.4.1.25506.2.65.1.12.4.1.3)
read-create
Unsigned32
·     0..7
·     255
As per the MIB.
hh3cQoSRemarkIPv6AddrDscp (1.3.6.1.4.1.25506.2.65.1.12.4.1.4)
read-create
Unsigned32
·     0..63
·     255
As per the MIB.
hh3cQoSRemarkIPv6AddrRowStatus (1.3.6.1.4.1.25506.2.65.1.12.4.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains Layer 3 protocol-based priority information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cQoSRemarkProtocolValue.
Object (OID)
Access
Value range
Implementation
hh3cQoSRemarkProtocolValue (1.3.6.1.4.1.25506.2.65.1.12.5.1.1)
not-accessible
Integer32
·     ip(1)
·     ipx(2)
·     arp(3)
·     appletalk(4)
·     sna(5)
·     netbeui(6)
Layer 3 protocol type.
As per the MIB.
hh3cQoSRemarkProtocolDot1p (1.3.6.1.4.1.25506.2.65.1.12.5.1.2)
read-create
Unsigned32
·     0..7
·     255
As per the MIB.
hh3cQoSRemarkProtocolRowStatus (1.3.6.1.4.1.25506.2.65.1.12.5.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains VLAN-based priority information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cQoSRemarkVlanStart.
Object (OID)
Access
Value range
Implementation
hh3cQoSRemarkVlanStart (1.3.6.1.4.1.25506.2.65.1.12.6.1.1)
not-accessible
Ingeter32
1..4094
Start VLAN of a VLAN range.
As per the MIB.
hh3cQoSRemarkVlanEnd (1.3.6.1.4.1.25506.2.65.1.12.6.1.2)
read-create
Ingeter32
1..4094
End VLAN of the VLAN range.
As per the MIB.
hh3cQoSRemarkVlanDot1p (1.3.6.1.4.1.25506.2.65.1.12.6.1.3)
read-create
Unsigned32
·     0..7
·     255
As per the MIB.
hh3cQoSRemarkVlanDscp (1.3.6.1.4.1.25506.2.65.1.12.6.1.4)
read-create
Unsigned32
·     0..63
·     255
As per the MIB.
hh3cQoSRemarkVlanRowStatus (1.3.6.1.4.1.25506.2.65.1.12.6.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains protocol traffic statistics for a control plane.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cIfQoSCoppFlowStatChassis, hh3cIfQoSCoppFlowStatSlot, and hh3cIfQoSCoppFlowStatProType.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSCoppFlowStatChassis (1.3.6.1.4.1.25506.2.65.1.14.1.1.1)
not-accessible
Unsigned32
Chassis number for the control plane.
As per the MIB.
hh3cIfQoSCoppFlowStatSlot (1.3.6.1.4.1.25506.2.65.1.14.1.1.2)
not-accessible
Unsigned32
Slot number for the control plane.
As per the MIB.
hh3cIfQoSCoppFlowStatProType (1.3.6.1.4.1.25506.2.65.1.14.1.1.3)
not-accessible
Unsigned32
1..65
Protocol type.
As per the MIB.
hh3cIfQoSCoppFlowPassPackets (1.3.6.1.4.1.25506.2.65.1.14.1.1.4)
read-only
Counter64
As per the MIB.
hh3cIfQoSCoppFlowPassBytes (1.3.6.1.4.1.25506.2.65.1.14.1.1.5)
read-only
Counter64
As per the MIB.
hh3cIfQoSCoppFlowDropPackets (1.3.6.1.4.1.25506.2.65.1.14.1.1.6)
read-only
Counter64
As per the MIB.
hh3cIfQoSCoppFlowDropBytes (1.3.6.1.4.1.25506.2.65.1.14.1.1.7)
read-only
Counter64
As per the MIB.
Notifications
The following information describes the notifications included in the HH3C-IFQOS2-MIB module.
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.1
The downlink resources of an 8-queue scheduling profile are insufficient.
Error
Major
OFF
Notification triggers
The notification is generated when the downlink (network side to user side) resources of an 8-queue scheduling profile are insufficient.
System impact
The qos user-queue command might not take effect.
Status control
ON
·     CLI: Use the snmp-agent trap enable qos command.
OFF
·     CLI: Use the undo snmp-agent trap enable qos command.
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
hh3cIfQoSDirection
Direction
N/A
Direction
As per the MIB
Recommended action
To resolve the issue:
1.     Delete or optimized related configuration.
2.     If you cannot identify the configuration to be deleted or optimized, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.2
The resources of an 8-queue user-queue profile are sufficient.
Recovery
Major
N/A
OFF
The notification is generated when the resources of an 8-queue user-queue profile are sufficient.
System impact
No negative impact on the system.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
hh3cIfQoSDirection
Direction
N/A
Direction
As per the MIB
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.3
The resource usage of an 8-queue scheduling profile exceeds 90%.
Error
Minor
OFF
The notification is generated when the resource usage of an 8-queue scheduling profile exceeds 90%.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
hh3cIfQoSDirection
Direction
N/A
Direction
As per the MIB
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.4
The resource usage of an 8-queue scheduling profile fell below 90%.
Recovery
Minor
N/A
OFF
The notification is generated when the resource usage of an 8-queue scheduling profile falls below 90%.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
hh3cIfQoSDirection
Direction
N/A
Direction
As per the MIB
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.5
Queue buffer usage alarm.
Error
Minor
OFF
An alarm is generated when the queue buffer usage reaches or exceeds 90%.
System impact
Packet loss occurs on high-priority queues.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
hh3cIfQoSDirection
Direction
N/A
Direction
As per the MIB
Recommended action
1.     Reduce deployed services.
2.     If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.6
Queue buffer usage alarm recovery.
Recovery
Minor
N/A
OFF
The notification is generated when the queue buffer usage alarm recovers.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.7
The channelized bandwidth exceeds the interface rate limit.
Error
Major
OFF
The notification is generated when the channelized bandwidth exceeds the interface rate limit.
System impact
The channelized bandwidth does not take effect.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSIfName
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
1.     Use the mode channel-bandwidth command to set a smaller channelized bandwidth.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.8
The channelized bandwidth is smaller than the interface rate limit.
Recovery
Major
N/A
OFF
The notification is generated when the channelized bandwidth is smaller than the interface rate limit.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSIfName
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.9
Exclusive bandwidth application failure alarm.
Error
Major
OFF
The notification is generated when the exclusive bandwidth fails to be applied.
System impact
The exclusive bandwidth does not take effect.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSIfName
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.10
Exclusive bandwidth application failure alarm recovery.
Recovery
Major
N/A
OFF
The notification is generated when the exclusive bandwidth application failure alarm recovers.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSIfName
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.11
Exclusive bandwidth exceeding maximum interface bandwidth.
Error
Major
OFF
The notification is generated when the exclusive bandwidth value exceeds the maximum interface bandwidth. The configuration will also become ineffective.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSIfName
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
Configure an exclusive bandwidth value that is smaller than the maximum interface bandwidth.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.12
Exclusive bandwidth exceeding maximum interface bandwidth alarm recovery.
Recovery
Major
N/A
OFF
The notification is generated when the alarm that the configured exclusive bandwidth value exceeds the maximum interface bandwidth recovers.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSIfName
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.13
The outgoing traffic of an interface exceeds the configured CIR
Error
Major
OFF
The notification is generated when the outgoing traffic of an interface exceeds the configured CIR.
System impact
The outgoing traffic of an interface might be dropped.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
CIR
N/A
Unsigned32
Outgoing traffic rate of the interface
N/A
Unsigned32
Recommended action
Increase the CIR on the interface.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.14
The outgoing traffic rate of an interface drops below the configured CIR
Recovery
Major
N/A
OFF
The notification is generated when the outgoing traffic rate of an interface drops below the configured CIR.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
CIR
N/A
Unsigned32
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.15
Packets are dropped by CAR on an interface
Error
Major
OFF
The notification is generated when packets are dropped by CAR on an interface.
System impact
Traffic might be dropped.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cIfQoSChassis (1.3.6.1.4.1.25506.2.65.1.15.1)
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot (1.3.6.1.4.1.25506.2.65.1.15.2)
Slot number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
hh3cIfQoSDirection (1.3.6.1.4.1.25506.2.65.1.15.6)
Direction
N/A
Direction
Recommended action
Cancel the CAR settings or increase the CIR.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.16
Packets dropped by CAR on an interface have been recovered
Recovery
Major
N/A
OFF
The notification is generated when packets dropped by CAR on an interface have been recovered.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Direction
N/A
Direction
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.17
Packets are dropped by CAR on the control plane
Error
Major
OFF
The notification is generated when packets are dropped by CAR on the control plane.
System impact
Packets are dropped by CAR on the control plane, and services or internal control information might not be able to be processed.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
Bandwidth
N/A
Unsigned32
1.3.6.1.4.1.25506.2.65.1.15.13 (hh3cIfQoSBandwidthUnit)
Bandwidth unit
N/A
INTEGER
·     unitAbsolute (1)
Recommended action
Cancel the CAR settings for the control plane.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.18
Packets dropped by CAR on the control plane have been recovered
Recovery
Major
N/A
OFF
The notification is generated when packets dropped by CAR on the control plane have been recovered.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
Bandwidth
N/A
Unsigned32
Bandwidth unit
N/A
INTEGER
·     unitAbsolute (1)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.19
Packets fail to be forwarded due to queue exceptions.
Error
Major
OFF
The notification is generated when packets fail to be forwarded due to queue exceptions.
System impact
Packets cannot be forwarded.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.20
Packets failing to be forwarded due to queue exceptions have been recovered.
Recovery
Major
N/A
OFF
The notification is generated when packets failing to be forwarded due to queue exceptions have been recovered.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.21
Layer 3 ACL resources are insufficient.
Error
Major
N/A
OFF
The notification is generated when Layer 3 ACL resources are insufficient.
System impact
ACL rules do not take effect or fail to be matched.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Service name
N/A
OCTET STRING
SIZE (1 to 63)
Failure reason
N/A
OCTET STRING
SIZE (1 to 127)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.22
Error
Major
OFF
The notification is generated when ACL resources are insufficient.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Service name
N/A
OCTET STRING
SIZE (1 to 63)
Application object
N/A
OCTET STRING
SIZE (1 to 127)
Direction
N/A
Direction
Failure reason
N/A
OCTET STRING
SIZE (1 to 127)
Recommended action
Basic information
OID
Event
Severity
Default status
The ACL resource alarm is cleared.
Recovery
Major
N/A
OFF
The notification is generated when the ACL resource alarm is cleared.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Service name
N/A
OCTET STRING
SIZE (1 to 63)
Application object
N/A
OCTET STRING
SIZE (1 to 127)
Direction
N/A
Direction
Failure reason
N/A
OCTET STRING
SIZE (1 to 127)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.24
The ACL forwarding engine memory is exhausted.
Error
Major
OFF
The notification is generated when the ACL forwarding engine memory is exhausted.
System impact
ACL rules fail to be matched.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.25
The ACL forwarding engine memory is recovered.
Recovery
Major
N/A
OFF
The notification is generated when the ACL forwarding engine memory is recovered.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Recommended action
