H3C Fixed Port Campus Switches Configuration Examples-6W106
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W106
Table of Contents
Related Documents
70-MPLS OAM Configuration Examples
70-MPLS OAM Configuration Examples 236.47 KB
Introduction
This document provides MPLS Operation, Administration, and Maintenance (OAM) configuration examples.
MPLS OAM provides the following fault management tools for LSPs:
·     MPLS data plane connectivity verification.
·     MPLS data plane and control plane consistency verification.
·     Failure detection and locating.
This document assumes that you have basic knowledge of MPLS OAM.
Example: Configuring BFD for an LSP
As shown in Figure 1, a company has two branches that are connected to the MPLS backbone. It requires the MPLS backbone to establish LSPs for communication between the branches, and to provide high availability services for uninterrupted business between the branches.
To meet the requirements:
·     Establish LSPs by using LDP.
·     Configure OSPF FRR on the MPLS backbone so LDP can establish a primary LSP and a backup LSP.
·     Configure BFD for the primary LSP. When the primary LSP fails, BFD can quickly detect the failure and notify LDP of the failure, so LDP can immediately switch traffic to the backup LSP.
Figure 1 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx switch series, Release 6628Pxx switch series
S6550XE-HI switch series
Release 8106Pxx
S6526XE-HI[EI] switch series
Not supported
S6510 switch series
Not supported
S6525XE-HI switch series
Release 8106Pxx
S5850 switch series
Not supported
S5570S-EI switch series
Not supported
S5560X-EI switch series
Release 65xx switch series, Release 6615Pxx switch series, Release 6628P
S5560X-HI switch series
Release 65xx switch series, Release 6615Pxx switch series, Release 6628Pxx
S5500V2-EI switch series
Release 65xx switch series, Release 6615Pxx switch series, Release 6628Pxx switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Not supported
S6520X-HI switch series
S6520X-EI switch series
Release 65xx switch series, Release 6615Pxx switch series, Release 65xx switch series, Release 6628Pxx switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Not supported
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI switches)
Not supported
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Not supported
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI switches)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Not supported
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC & IE4300-12P-PWR switches
IE4300-M switch series
IE4320 switch series
Not supported
IE4520 switch series
Not supported
S5135S-EI switch series
Not supported
Before configuration, disable the spanning tree feature globally or map each VLAN to an MSTI.
Procedures
1.     Configure IP addresses for interfaces:
# On PE 1, configure IP addresses and masks for interfaces, including the loopback interface, as shown in Figure 1.
<PE1> system-view
[PE1] vlan 10
[PE1-vlan10] port gigabitethernet 1/0/3
[PE1-vlan10] quit
[PE1] interface vlan-interface 10
[PE1-Vlan-interface10] ip address 192.168.10.1 24
[PE1] vlan 12
[PE1-vlan12] port gigabitethernet 1/0/1
[PE1-vlan12] quit
[PE1-Vlan-interface12] ip address 12.12.12.1 24
[PE1-Vlan-interface12] quit
[PE1] vlan 14
[PE1-vlan14] port gigabitethernet 1/0/2
[PE1-vlan14] quit
[PE1] interface vlan-interface 14
[PE1-Vlan-interface14] ip address 14.14.14.1 24
[PE1-Vlan-interface14] quit
[PE1] interface loopback 0
[PE1-LoopBack0] quit
# Configure other devices in the same way that PE 1 is configured. (Details not shown.)
2.     Configure OSPF to ensure IP connectivity within the MPLS backbone, and enable OSPF FRR:
# Configure PE 1.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 192.168.10.0 0.0.0.255
[PE1-ospf-1] fast-reroute lfa
[PE1-ospf-1] quit
# Configure P 1.
[P1] ospf
[P1-ospf-1] area 0
[P1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] quit
[P1-ospf-1] quit
# Configure PE 2.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 34.34.34..0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[PE2-ospf-1] fast-reroute lfa
[PE2-ospf-1] quit
# Configure P 2.
[P2] ospf
[P2-ospf-1] area 0
[P2-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[P2-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] network 34.34.34.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] quit
[P2-ospf-1] quit
# On P 2, set the OSPF cost to 10 for VLAN-interface 14 and VLAN-interface 34. This setting ensures that the backup LSP has a larger OSPF cost than the primary LSP.
[P2] interface vlan-interface 14
[P2-Vlan-interface14] ospf cost 10
[P2-Vlan-interface14] quit
[P2] interface vlan-interface 34
[P2-Vlan-interface34] ospf cost 10
[P2-Vlan-interface34] quit
3.     Configure basic MPLS and MPLS LDP:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Vlan-interface12] mpls enable
[PE1-Vlan-interface12] mpls ldp enable
[PE1-Vlan-interface14] mpls enable
[PE1-Vlan-interface14] mpls ldp enable
# Configure P 1.
[P1] mpls lsr-id 2.2.2.2
[P1] mpls ldp
[P1-ldp] quit
[P1] interface vlan-interface 12
[P1-Vlan-interface12] mpls enable
[P1-Vlan-interface12] mpls ldp enable
[P1-Vlan-interface12] quit
[P1] interface vlan-interface 23
[P1-Vlan-interface23] mpls enable
[P1-Vlan-interface23] mpls ldp enable
[P1-Vlan-interface23] quit
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.3
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface vlan-interface 23
[PE2-Vlan-interface23] mpls enable
[PE2-Vlan-interface23] mpls ldp enable
[PE2-Vlan-interface23] quit
[PE2] interface vlan-interface 34
[PE2-Vlan-interface34] mpls enable
[PE2-Vlan-interface34] mpls ldp enable
[PE2-Vlan-interface34] quit
# Configure P 2.
[P2] mpls lsr-id 4.4.4.4
[P2] mpls ldp
[P2-ldp] quit
[P2-Vlan-interface14] mpls enable
[P2-Vlan-interface14] mpls ldp enable
[P2-Vlan-interface34] mpls enable
[P2-Vlan-interface34] mpls ldp enable
# Verify that LDP sessions in Operational state have been established on each device. The following shows the output on PE 1.
[PE1] display mpls ldp peer
Total number of peers: 2
Peer LDP ID             State         Role     GR   MD5  KA Sent/Rcvd
2.2.2.2:0               Operational   Passive  Off  Off  55/55
4.4.4.4:0               Operational   Passive  Off  Off  6/6
4.     Configure LSP generation policies to establish LSPs to destinations 192.168.10.0/24, 192.168.20.0/24, 1.1.1.1/32, and 3.3.3.3/32:
# On PE 1, create IP prefix list PE1, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[PE1] ip prefix-list PE1 index 10 permit 192.168.10.0 24
[PE1] ip prefix-list PE1 index 20 permit 192.168.20.0 24
[PE1] ip prefix-list PE1 index 30 permit 1.1.1.1 32
[PE1] ip prefix-list PE1 index 40 permit 3.3.3.3 32
[PE1] mpls ldp
[PE1-ldp] lsp-trigger prefix-list PE1
[PE1-ldp] quit
# On P 1, create IP prefix list P1, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[P1] ip prefix-list P1 index 10 permit 192.168.10.0 24
[P1] ip prefix-list P1 index 20 permit 192.168.20.0 24
[P1] ip prefix-list P1 index 30 permit 1.1.1.1 32
[P1] ip prefix-list P1 index 40 permit 3.3.3.3 32
[P1] mpls ldp
[P1-ldp] lsp-trigger prefix-list P1
[P1-ldp] quit
# On PE 2, create IP prefix list PE2, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[PE2] ip prefix-list PE2 index 10 permit 192.168.10.0 24
[PE2] ip prefix-list PE2 index 20 permit 192.168.20.0 24
[PE2] ip prefix-list PE2 index 30 permit 1.1.1.1 32
[PE2] ip prefix-list PE2 index 40 permit 3.3.3.3 32
[PE2] mpls ldp
[PE2-ldp] lsp-trigger prefix-list PE2
[PE2-ldp] quit
# On P 2, create IP prefix list P2, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[P2] ip prefix-list P2 index 10 permit 192.168.10.0 24
[P2] ip prefix-list P2 index 20 permit 192.168.20.0 24
[P2] ip prefix-list P2 index 30 permit 1.1.1.1 32
[P2] ip prefix-list P2 index 40 permit 3.3.3.3 32
[P2] mpls ldp
[P2-ldp] lsp-trigger prefix-list P2
[P2-ldp] quit
# Verify that LSPs to destination 192.168.20.0/24 have been established on PE 1. The primary LSP uses VLAN-interface 12 as the outgoing interface and the backup LSP uses VLAN-interface 14 as the outgoing interface.
[PE1]display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup
Statistics:
  FECs: 4      Ingress LSPs: 4     Transit LSPs: 4     Egress LSPs: 2
FEC                In/Out Label        Nexthop         OutInterface
1.1.1.1/32         3/-
                   -/1151(L)
                   -/1279(L)
3.3.3.3/32         -/1150              12.12.12.2      Vlan12
                   1150/1150           12.12.12.2      Vlan12
                   -/1150(B)           12.12.12.2      Vlan14
                   1150/1150(B)        12.12.12.2      Vlan14
192.168.10.0/24    1141/-
                   -/1141(L)
                   -/1141(L)
192.168.20.0/24    -/1133              12.12.12.2      Vlan12
                   1133/1133           12.12.12.2      Vlan12
                   -/1133(B)           14.14.14.4      Vlan14
                   1133/1133(B)        14.14.14.4      Vlan14
5.     Enable BFD for MPLS and use BFD to verify LSP connectivity:
# Configure PE 1.
[PE1] mpls bfd enable
[PE1] mpls bfd 3.3.3.3 32
# Configure PE 2.
[PE2] mpls bfd enable
[PE2] mpls bfd 1.1.1.1 32
1.     Display BFD information for LSPs on PE 1 and PE 2. The following shows the output on PE 1.
[PE1] display mpls bfd
 Total number of sessions: 2, 2 up, 0 down, 0 init
 FEC Type: LSP
 FEC Info:
   Destination: 1.1.1.1
   Mask Length: 32
 NHLFE ID: -
 Local Discr: 1026                   Remote Discr: 514
 Source IP: 1.1.1.1                  Destination IP: 3.3.3.3
 Session State: Up                   Session Role: Active
 Template Name: -
 FEC Type: LSP
 FEC Info:
   Destination: 3.3.3.3
   Mask Length: 32
 NHLFE ID: 1028
 Local Discr: 1025                   Remote Discr: -
 Source IP: 1.1.1.1                  Destination IP: 127.0.0.1
 Session State: Up                   Session Role: Passive
 Template Name: -
2.     Execute the tracert mpls ipv4 command on PE 1. The output shows that the primary LSP is in use.
Before you use the tracert feature, enable sending ICMP time exceeded messages on intermediate devices, and enable sending ICMP destination unreachable messages on the destination device.
[PE1] tracert mpls -a 192.168.10.1 ipv4 192.168.20.0 24
MPLS trace route FEC 192.168.20.0/24
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   12.12.12.2/[1148]
  1     12.12.12.2         2 ms    Transit   23.23.23.3/[1148]
  2     23.23.23.3         2 ms    Egress
3.     Verify that the ping operation from PE 1 to PE 2 will not fail after VLAN-interface 23 on P 1 is shut down during the ping operation:
# Ping PE 2 from PE 1.
[PE1] ping -c 100000 -a 192.168.10.1 192.168.20.1
Ping 192.168.20.1 (192.168.20.1) from 192.168.10.1: 56 data bytes, press CTRL_C
to break
56 bytes from 192.168.20.1: icmp_seq=0 ttl=254 time=2.576 ms
56 bytes from 192.168.20.1: icmp_seq=1 ttl=254 time=1.996 ms
# Shut down VLAN-interface 23 on P 1.
[P1-Vlan-interface23] shutdown
# View the ping command output. The output shows that the communication was interrupted, and then immediately resumed.
to break
56 bytes from 192.168.20.1: icmp_seq=7 ttl=254 time=2.214 ms
Request time out
56 bytes from 192.168.20.1: icmp_seq=9 ttl=254 time=2.659 ms
56 bytes from 192.168.20.1: icmp_seq=10 ttl=254 time=5.049 ms
56 bytes from 192.168.20.1: icmp_seq=11 ttl=254 time=2.098 ms
56 bytes from 192.168.20.1: icmp_seq=12 ttl=254 time=2.225 ms
56 bytes from 192.168.20.1: icmp_seq=13 ttl=254 time=2.187 ms
--- Ping statistics for 192.168.20.1 ---
14 packet(s) transmitted, 13 packet(s) received, 7.1% packet loss
round-trip min/avg/max/std-dev = 1.990/2.455/5.049/0.772 ms
4.     Execute the tracert mpls ipv4 command on PE 1. The output shows that the backup LSP is in use.
  0                                Ingress   14.14.14.4/[1276]
  1     14.14.14.4         2 ms    Transit   34.34.34.3/[1148]
  2     34.34.34.3         2 ms    Egress
Configuration files
·     PE 1:
ospf 1
 fast-reroute lfa
 area 0.0.0.0
 mpls lsr-id 1.1.1.1
vlan 10
vlan 12
vlan 14
mpls ldp
 mpls bfd enable
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
interface Vlan-interface10
 ip address 192.168.10.1 255.255.255.0
interface Vlan-interface12
 ip address 12.12.12.1 255.255.255.0
 mpls enable
 mpls ldp enable
interface Vlan-interface14
 ip address 14.14.14.1 255.255.255.0
 mpls enable
 mpls ldp enable
 port link-mode bridge
 port access vlan 12
 port access vlan 14
 port access vlan 10
 mpls bfd 3.3.3.3 32
·     PE 2:
ospf 1
 fast-reroute lfa
 area 0.0.0.0
vlan 23
vlan 30
vlan 34
 mpls lsr-id 3.3.3.3
mpls ldp
 mpls bfd enable
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
interface Vlan-interface23
 ip address 23.23.23.3 255.255.255.0
 mpls enable
 mpls ldp enable
interface Vlan-interface30
 ip address 192.168.20.1 255.255.255.0
interface Vlan-interface34
 ip address 34.34.34.3 255.255.255.0
 mpls enable
 mpls ldp enable
 port access vlan 34
 port access vlan 23
 port access vlan 30
 mpls bfd 1.1.1.1 32
·     P 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.2
vlan 12
vlan 23
mpls ldp
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 ip address 12.12.12.2 255.255.255.0
 mpls enable
 mpls ldp enable
 ip address 23.23.23.2 255.255.255.0
 mpls enable
 mpls ldp enable
 port access vlan 12
 port access vlan 23
·     P 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.4
vlan 14
vlan 34
mpls ldp
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 ip address 14.14.14.4 255.255.255.0
 ospf cost 10
 mpls enable
 mpls ldp enable
 ip address 34.34.34.4 255.255.255.0
 ospf cost 10
 mpls enable
 mpls ldp enable
 port access vlan 34
 port access vlan 14
Example: Configuring SBFD for an LSP
As shown in Figure 2, a company has two branches that are connected to the MPLS backbone. It requires the MPLS backbone to establish LSPs for communication between the branches, and to provide high availability services for uninterrupted business between the branches.
·     Configure SBFD for the primary LSP. When the primary LSP fails, SBFD can quickly detect the failure and notify LDP of the failure, so LDP can immediately switch traffic to the backup LSP.
Figure 2 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
Release 8106Pxx
Not supported
S6510 switch series
Not supported
Release 8106Pxx
S5850 switch series
Not supported
Not supported
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Procedures
# On PE 1, configure IP addresses and masks for interfaces, including the loopback interface, as shown in Figure 2.
<PE1> system-view
[PE1] vlan 10
[PE1-vlan10] quit
[PE1] vlan 12
[PE1-vlan12] quit
[PE1] vlan 14
[PE1-vlan14] quit
# Configure PE 1.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure P 1.
[P1] ospf
[P1-ospf-1] area 0
[P1-ospf-1] quit
# Configure PE 2.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Configure P 2.
[P2] ospf
[P2-ospf-1] area 0
[P2-ospf-1] quit
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure P 1.
[P1] mpls ldp
[P1-ldp] quit
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
# Configure P 2.
[P2] mpls ldp
[P2-ldp] quit
[PE1] mpls ldp
[PE1-ldp] quit
[P1] mpls ldp
[P1-ldp] quit
[PE2] mpls ldp
[PE2-ldp] quit
[P2] mpls ldp
[P2-ldp] quit
Statistics:
1.1.1.1/32         3/-
                   -/1151(L)
                   -/1279(L)
                   -/1141(L)
                   -/1141(L)
5.     Enable BFD for MPLS and use SBFD to verify LSP connectivity:
# Configure PE 1.
[PE1] sbfd local-discriminator 3000000
[PE1] mpls sbfd 3.3.3.3 32 remote 2000000
# Configure PE 2.
[PE2] sbfd local-discriminator 2000000
[PE2] mpls sbfd 1.1.1.1 32 remote 3000000
1.     Display SBFD information for LSPs on PE 1 and PE 2. The following shows the output on PE 1.
[PE1] display mpls sbfd
 Total number of sessions: 1, 1 up, 0 down, 0 init
 FEC Type: LSP
 FEC Info:
   Mask Length: 32
 NHLFE ID: 2
 Local Discr: 513                    Remote Discr: 2000000
 Session State: Up
 Template Name: -
to break
to break
Request time out
Configuration files
·     PE 1:
ospf 1
 fast-reroute lfa
 area 0.0.0.0
 mpls lsr-id 1.1.1.1
vlan 10
vlan 12
vlan 14
mpls ldp
 mpls bfd enable
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 port access vlan 12
 port access vlan 14
 port access vlan 10
·     PE 2:
ospf 1
 fast-reroute lfa
 area 0.0.0.0
vlan 23
vlan 30
vlan 34
 mpls lsr-id 3.3.3.3
mpls ldp
 mpls bfd enable
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 port access vlan 34
 port access vlan 23
 port access vlan 30
 mpls bfd 1.1.1.1 32
·     P 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.2
vlan 12
vlan 23
mpls ldp
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 port access vlan 12
 port access vlan 23
·     P 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.4
vlan 14
vlan 34
mpls ldp
interface LoopBack0
 ospf cost 10
 mpls enable
 mpls ldp enable
 ospf cost 10
 mpls enable
 mpls ldp enable
 port access vlan 34
 port access vlan 14
