H3C Fixed Port Campus Switches Configuration Examples-6W106
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W106
Table of Contents
Related Documents
67-Congestion Avoidance and Queue Scheduling Configuration Examples
Introduction
This document provides examples for configuring congestion avoidance and queue scheduling profiles.
This document assumes that you have basic knowledge of congestion avoidance and queue scheduling profiles.
Example: Configuring congestion avoidance and queue scheduling
As shown in Figure 1, three types of traffic come from the Internet to the device through the gateway.
·     Voice traffic—Transmitted in VLAN 6 and carries 802.1p priority 6.
·     Video traffic—Transmitted in VLAN 4 and carries 802.1p priority 4.
·     Data traffic—Transmitted in VLAN 2 and carries 802.1p priority 2.
Configure congestion avoidance and queue scheduling on the device to meet the following requirements:
·     The voice traffic, video traffic, and data traffic are scheduled in the ratio of 1:2:2 when congestion occurs.
·     WRED drop is used when serious congestion occurs.
Figure 1 Network diagram
Analysis
To configure congestion avoidance and queue scheduling, you must perform the following tasks:
·     To assign different types of traffic to different queues, configure the inbound interface to trust the 802.1p priority in packets.
·     To schedule the three types of traffic in the ratio of 1:2:2, assign their queues to one WRR group and configure weights for these queues.
·     To minimize performance degradation for different types of traffic, use the drop parameters in Table 1.
Table 1 Drop parameters
Traffic type
Packet color
Lower limit
Upper limit
Drop probability
Voice
Yellow
1000
1500
3%
Red
500
1000
30%
Video
Yellow
1000
1500
2%
Red
500
1000
20%
Data
Yellow
1000
1500
1%
Red
500
1000
10%
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI series
Release 6008 and later, Release 8106Pxx
S6526XE-HI[EI] switch series
Release 8341P02 and later
S6510 switch series
S6525XE-HI series
S5850 series
Release 8005 and later, Release 8106Pxx
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Not supported
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI
S5500V3-48P-SI
Not supported
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C
E152C
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC
IE4300-12P-PWR
IE4300-M switch series
IE4320 switch series
Not supported
IE4520 switch series
Release 66xx
S5135S-EI switch series
Release 6810 and later
S5136S-EI switch series
Release 6817 and later
Procedures
1.     Allow VLANs for different types of traffic to pass through:
# Create three VLANs .
[Device] vlan 2
[Device-vlan2] quit
[Device] vlan 4
[Device-vlan4] quit
[Device] vlan 6
[Device-vlan6] quit
# Assign interfaces to VLANs.
[Device] interface ten-gigabitethernet 1/0/28
[Device-Ten-Gigabitethernet1/0/28] port link-type trunk
[Device-Ten-Gigabitethernet1/0/28] port trunk permit vlan 2 4 6
[Device-Ten-Gigabitethernet1/0/28] quit
[Device-Gigabitethernet1/0/1] port link-type trunk
[Device-Gigabitethernet1/0/1] port trunk permit vlan 2 4 6
[Device-Gigabitethernet1/0/1] quit
[Device-Gigabitethernet1/0/2] port link-type trunk
[Device-Gigabitethernet1/0/2] port trunk permit vlan 2 4 6
[Device-Gigabitethernet1/0/2] quit
2.     Configure interface Gigabitethernet 1/0/28 to trust the 802.1p priority in packets.
[Device-Ten-Gigabitethernet1/0/28] qos trust dot1p
3.     Configure WRR on Gigabitethernet 1/0//1 and Gigabitethernet 1/0//2:
# Display the 802.1p-to-local precedence map to determine the local precedence for each type of traffic.
[Device] display qos map-table inbound dot1p-lp
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
# Enable weight-based WRR on Gigabitethernet 1/0/1.
[Device-Gigabitethernet1/0/1] qos wrr weight
# Configure the weights of queue 1 (for data traffic), queue 4 (for video traffic), and queue 6 (for voice traffic) as 2, 2, and 1, respectively.
[Device-Gigabitethernet1/0/1] qos wrr 1 group 1 weight 2
[Device-Gigabitethernet1/0/1] qos wrr 4 group 1 weight 2
[Device-Gigabitethernet1/0/1] qos wrr 6 group 1 weight 1
# Enable weight-based WRR on Gigabitethernet 1/0/2.
[Device-Gigabitethernet1/0/2] qos wrr weight
[Device-Gigabitethernet1/0/2] qos wrr 1 group 1 weight 2
[Device-Gigabitethernet1/0/2] qos wrr 4 group 1 weight 2
[Device-Gigabitethernet1/0/2] qos wrr 6 group 1 weight 1
4.     Configure congestion avoidance:
# Configure a WRED table.
[Device] qos wred queue table droppolicy
[Device-wred-table-droppolicy] queue 6 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 3
[Device-wred-table-droppolicy] queue 6 drop-level 2 low-limit 500 high-limit 1000 discard-probability 30
[Device-wred-table-droppolicy] queue 4 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 2
[Device-wred-table-droppolicy] queue 4 drop-level 2 low-limit 500 high-limit 1000 discard-probability 20
[Device-wred-table-droppolicy] queue 1 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 1
[Device-wred-table-droppolicy] queue 1 drop-level 2 low-limit 500 high-limit 1000 discard-probability 10
[Device-wred-table-droppolicy] quit
# Apply the WRED table to interfaces Gigabitethernet 1/0/1 and Gigabitethernet 1/0/2.
[Device-Gigabitethernet1/0/1] qos wred apply droppolicy
[Device-Gigabitethernet1/0/2] qos wred apply droppolicy
# Verify the WRR configuration on interfaces Gigabitethernet 1/0/1 and Gigabitethernet 1/0/2.
[Device] display qos queue wrr interface
Interface: Gigabitethernet1/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID     Queue name     Group     Weight
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         2
 5            ef             1         9
 6            cs6            1         1
 7            cs7            1         15
Interface: Gigabitethernet1/0/2
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         2
 5            ef             1         9
 6            cs6            1         1
 7            cs7            1         15
# Display the WRED table configuration.
Table name: droppolicy
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
0     100   1000  10     100   1000  10     100   1000  10     9         N
1     100   1000  10     1000  1500  1      500   1000  10     9         N
2     100   1000  10     100   1000  10     100   1000  10     9         N
3     100   1000  10     100   1000  10     100   1000  10     9         N
4     100   1000  10     1000  1500  2      500   1000  20     9         N
5     100   1000  10     100   1000  10     100   1000  10     9         N
6     100   1000  10     1000  1500  3      500   1000  30     9         N
7     100   1000  10     100   1000  10     100   1000  10     9         N
Configuration files
vlan 1
vlan 2
vlan 4
vlan 6
interface Gigabitethernet1/0/1
 port link-mode bridge
 port trunk permit vlan 1 to 2 4 6
 qos wrr weight
 qos wrr af1 group 1 weight 2
 qos wrr af4 group 1 weight 2
 qos wrr cs6 group 1 weight 1
interface Gigabitethernet1/0/2
 qos wrr weight
interface Ten-Gigabitethernet1/0/28
return
