H3C Fixed Port Campus Switches Configuration Examples-6W106
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W106
Table of Contents
Related Documents
03-Software Upgrade Examples
03-Software Upgrade Examples 266.59 KB
Introduction
This document provides software upgrade examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of FTP and TFTP.
General restrictions and guidelines
When you upgrade software, follow these restrictions and guidelines:
·     Make sure the switch has sufficient storage space for the upgrade file. If the switch does not have sufficient storage space, delete unused files by using the delete /unreserved file-url command.
·     Save the configuration before the upgrade for the configuration to survive a reboot.
·     If the switch supports the management Ethernet interface, assign an IP address to the management Ethernet interface. If the switch does not support the management Ethernet interface, assign an IP address to VLAN-interface 1.
Example: Using the switch as a TFTP client to upgrade software
As shown in Figure 1, use TFTP to download a software upgrade file from a TFTP server to upgrade the switch.
Figure 1 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 and later, Release 8106Pxx
S6526XE-HI[EI] switch series
Release 8341P02 and later
S6510 switch series
S6525XE-HI switch series
S5850 switch series
Release 8005 and later, Release 8106Pxx
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Release 63xx
S5000V3-EI switch series
S5000V5-EI switch series
Release 63xx
S5000E-X switch series
S5000X-EI switch series
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Release 63xx
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
IE4520 switch series
Release 66xx
S5135S-EI switch series
Release 6810 and later
S5136S-EI switch series
Release 6817 and later
Procedures
1.     Configure the TFTP server:
# Assign the IP address 192.168.100.14/24 to the TFTP server. (Details not shown.)
# Start the TFTP server and specify a working directory. This example uses the 3CDaemon TFTP server. (Details not shown.)
Figure 2 Configuring the TFTP server
2.     Upgrade the switch:
# (Switches supporting the management Ethernet interface) Assign an IP address to M-GigabitEthernet 0/0/0. Make sure the switch can reach the TFTP server.
<Switch> system-view
[Switch] interface m-gigabitethernet 0/0/0
[Switch-M-GigabitEthernet0/0/0] ip address 192.168.100.66 255.255.255.0
[Switch-M-GigabitEthernet0/0/0] quit
[Switch] quit
# (Switches not supporting the management Ethernet interface) Assign an IP address to VLAN-interface 1. Make sure the switch can reach the TFTP server.
[Switch] interface Vlan-interface1
[Switch-Vlan-interface1] ip address 192.168.100.66 255.255.255.0
[Switch-Vlan-interface1] quit
# Verify that the switch can ping the TFTP server.
<Switch> ping 192.168.100.14
Ping 192.168.100.14 (192.168.100.14): 56 data bytes, press CTRL_C to break
56 bytes from 192.168.100.14: icmp_seq=0 ttl=64 time=10.701 ms
56 bytes from 192.168.100.14: icmp_seq=1 ttl=64 time=2.678 ms
56 bytes from 192.168.100.14: icmp_seq=2 ttl=64 time=2.282 ms
56 bytes from 192.168.100.14: icmp_seq=3 ttl=64 time=1.617 ms
56 bytes from 192.168.100.14: icmp_seq=4 ttl=64 time=1.701 ms
--- Ping statistics for 192.168.100.14 ---
round-trip min/avg/max/std-dev = 1.617/3.796/10.701/3.474 ms
# Save the configuration.
<Switch> save
# Use TFTP to download the upgrade file switch.ipe from the TFTP server to the root directory of the storage medium on the switch.
<Switch> tftp 192.168.100.14 get switch.ipe
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 58.7M  100 58.7M    0     0  1193k      0  0:00:50  0:00:50 --:--:-- 1127k
# Specify switch.ipe as the main startup image file.
<Switch> boot-loader file flash:/switch.ipe slot 1 main
Verifying the file flash:/switch.ipe on slot 1.....Done.
Images in IPE:
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:y
Add images to slot 1.
Decompressing file switch.bin to flash:/boot.bin.........Done.
Decompressing file switch.bin to flash:/system.bin...........................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
# Reboot the switch.
<Switch> reboot
# Verify that the software has been upgraded.
<Switch> display version
H3C Comware Software, Version 7.1.070, Release xxxx
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.
H3C S5130S-52S-HI uptime is 0 weeks, 0 days, 0 hours, 19 minutes
Last reboot reason : User reboot
Boot image: flash:/boot.bin
Boot image version: 7.1.070, Release xxxx
  Compiled Jun 18 2019 17:52:09
System image: flash:/system.bin
System image version: 7.1.070, Release xxxx
---- More ----
# Display the current software images and startup software images.
<Switch> display boot-loader
Software images on slot 1:
Current software images:
  flash:/boot.bin
  flash:/system.bin
Main startup software images:
  flash:/boot.bin
  flash:/system.bin
Backup startup software images:
None
Configuration files
·     Switches supporting the management Ethernet interface:
interface M-GigabitEthernet0/0/0
·     Switches not supporting the management Ethernet interface:
Example: Using the switch as an FTP client to upgrade software
As shown in Figure 3, use FTP to download a software upgrade file from an FTP server to upgrade the switch.
Figure 3 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
S6510 switch series
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 66xx
Procedures
1.     Configure the FTP server:
# Assign the IP address 192.168.100.14/24 to the FTP server. (Details not shown.)
# Start the FTP server and specify a working directory. This example uses the 3CDaemon FTP server. (Details not shown.)
# Add a local user account. (Details not shown.)
# Set the username to 123456 and the password to 123456 for the user account.
Figure 4 Configuring the FTP server
# (Switches supporting the management Ethernet interface) Assign an IP address to M-GigabitEthernet 0/0/0. Make sure the switch can reach the FTP server.
[Switch] quit
# Verify that the switch can ping the FTP server.
<Switch> save
Configuration is saved to  mainboard device successfully.
# Use the username 123456 and the password 123456 to log in to the FTP server.
<Switch> ftp 192.168.100.14
Connected to 192.168.100.14 (192.168.100.14).
220 3Com 3CDaemon FTP Server Version 2.0
User (192.168.100.14:(none)): 123456
331 User name ok, need password
Password:
230 User logged in
Remote system type is UNIX.
Using binary mode to transfer files.
# Use FTP to download the upgrade file switch.ipe from the FTP server to the root directory of the storage medium on the switch.
ftp> get switch.ipe
227 Entering passive mode (192,168,100,14,8,86)
125 Using existing data connection
226 Closing data connection; File transfer successful.
50445056 bytes received in 53.6 seconds (1.25 Mbyte/s)
ftp> quit
Images in IPE:
  boot.bin
  system.bin
Decompressing file switch.bin to flash:/system.bin.................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on on slot 1.
<Switch> reboot
---- More ----
  flash:/boot.bin
  flash:/system.bin
  flash:/boot.bin
  flash:/system.bin
None
Configuration files
Example: Using the switch as an FTP server to upgrade software
As shown in Figure 5:
·     Enable the FTP server on the switch.
·     Use FTP to upload a software upgrade file from an FTP client to upgrade the switch.
Figure 5 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
S6510 switch series
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 66xx
Analysis
To use the switch as an FTP server, you must create a local user account on the switch to provide FTP service.
You must set the file transfer mode to binary for FTP to transfer files correctly.
Procedures
# Add a local user account. Set the username to abc and the password to a123456789.
[Switch] local-user abc
[Switch-luser-abc] password simple a123456789
# Assign the network-admin user role to the user account.
[Switch-luser-abc] authorization-attribute user-role network-admin
# Remove the default network-operator user role.
[Switch-luser-abc] undo authorization-attribute user-role network-operator
# Assign FTP service to the user account.
[Switch-luser-abc] service-type ftp
[Switch-luser-abc] quit
# Enable the FTP server.
[Switch] ftp server enable
[Switch] quit
<Switch> save
2.     Configure the FTP client:
# Assign the IP address 192.168.100.14/24 to the FTP client. Make sure the FTP client can reach the switch. (Details not shown.)
# Use the username abc and the password a123456789 to log in to the FTP server.
C:\Documents and Settings\Administrator> ftp 192.168.100.66
Connected to 192.168.100.66.
220 FTP service ready.
User (192.168.100.66:(none)): abc
331 Password required for abc.
Password:
230 User logged in.
# Access the directory that contains the upgrade file.
ftp> lcd E:\
Local directory now E:\
# Set the file transfer mode to binary.
ftp> binary
200 TYPE is now 8-bit binary
# Transfer the upgrade file switch.ipe to the root directory of the storage medium on the FTP server.
ftp> put switch.ipe
200 PORT command successful
150 Connecting to port 2903
226 File successfully transferred
ftp: 50445056 sent in 1.05Seconds 67282.77Kbytes/sec.
# Verify that the image file is saved on the FTP server.
ftp> ls switch.ipe
150 Connecting to port 3391
switch.ipe
226 1 matches total
ftp: 24 bytes received in 0.00Seconds 24000.00Kbytes/sec.
# Close the FTP connection.
ftp> bye
3.     Upgrade the switch:
Verifying the IPE file and the images.....Done.
Images in IPE:
  boot.bin
  system.bin
<Switch> reboot
---- More ----
  flash:/boot.bin
  flash:/system.bin
  flash:/boot.bin
  flash:/system.bin
None
Configuration files
local-user abc class manage
 password hash $h$6$YMVbbwFL/vviWcQu$+CuTbYCehNZtZo5RCXiadpYbXYWa2omt5TUtEh3UPCg3fZjxYCp5WzbuE2GoowVi2YA/BK+mnSZJZqi5jRDuCg==
 service-type ftp
 ftp server enable
 service-type ftp
 ftp server enable
Example: Using the device as a TFTP client to upgrade software
As shown in Figure 6, the device cannot start up.
Use TFTP to upgrade the device from the BootWare menu.
Figure 6 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
S6510 switch series
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 66xx
When you upgrade software, make sure the device has sufficient storage space for the upgrade file. If the device does not have sufficient storage space, delete unused files by using the delete /unreserved file-url command.
Procedures
1.     Configure the host:
# Use a console cable to connect console port 0 on the device to the configuration terminal. (Details not shown.)
# To access the device through the console port, you must run a terminal emulator program (HyperTerminal, PuTTY, or Tera Term) on the host. For information about using a terminal emulator program, see the program's user guide.
The following are the required terminal settings:
¡     Baud rate—9600.
¡     Data bits—8.
¡     Stop bits—1.
¡     Parity—none.
¡     Flow control—none.
2.     Configure the TFTP server:
3.     Upgrade the device:
The BootWare menu varies by device model. This section uses S6550XE-56HF-HI as an example.
# Use a straight-through Ethernet cable to connect the management Ethernet interface (M-GigabitEthernet 0/0/0) on the device to the TFTP server.
# Save the running configuration.
[Device] save
[Device] quit
# Reboot the device.
<Device> reboot
# Press Ctrl+B at prompt to access the EXTEND-BOOTWARE menu.
Starting......
Press Ctrl+D to access BASIC BOOT MENU...
Press Ctrl+T to start heavy memory test
Booting extended BootRom
The extended BootRom is self-decompressing......Done.
*                   H3C S6550XE-56HF-HI BOOTROM, Version 103                   *
Copyright (c) 2004-2021 New H3C Technologies Co., Ltd.
Creation Date         : Mar 30 2021
Memory Type           : DDR4 SDRAM
Memory Size           : 3072MB
Memory Speed          : 800MHz
Flash Size            : 1024MB
CPLD 1 Version        : 001
CPLD 2 Version        : 001
CPLD 3 Version        : 001
PCB 1 Version         : Ver.A
PCB 2 Version         : Ver.B
Mac Address           : 346b5bebf2ed
Press Ctrl+B to access EXTENDED BOOT MENU...0
Password recovery capability is enabled.
   EXTENDED BOOT MENU
1. Download image to flash
2. Select image to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set switch startup mode
9. Set The Operating Device
0. Reboot
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format file system
Ctrl+P: Change authentication for console login
Ctrl+R: Download image to SDRAM and run
Enter your choice(0-9):
# Press 1 to access the file transfer protocol menu.
Enter your choice(0-9): 1
1. Set TFTP protocol parameters
2. Set FTP protocol parameters
3. Set XMODEM protocol parameters
0. Return to boot menu
Enter your choice(0-3):
# Press 1 to configure the network parameters.
Enter your choice(0-3): 1
Load File Name     : s6550xe-h3c-test.ipe
Server IP Address  :192.168.0.30
Local IP Address   :192.168.0.20
Subnet Mask        :0.0.0.0
Gateway IP Address :0.0.0.0
Loading... Done.
Table 1 Network parameter fields
Load File Name
Set the name of the file to be downloaded.
Server IP Address
Set the IP address of the TFTP server.
Local IP Address
Set the IP address of the interface that connects to the TFTP server.
Subnet Mask
Set the IP address mask.
Target File Name
Set a file name for saving the file on the device. By default, the target file name is the same as the source file name.
Gateway IP Address
Set a gateway IP address if the router is on a different network from the server.
# Press Enter and enter Y at prompt to download the file.
Are you sure to download file to flash? Yes or No (Y/N):Y
Loading.........................................................................
................................................................Done.
# Assign image file attribute main (M) to the file. The EXTEND-BOOTWARE menu appears again.
Please input the file attribute (Main/Backup/None) M
Image file boot.bin is self-decompressing...
Free space: 534980608 bytes
Writing flash...................................................................
...................................................................Done.
Image file system.bin is self-decompressing...
Free space: 525981696 bytes
.......................................................................Done.
   EXTENDED BOOT MENU
0. Reboot
Ctrl+C: Display Copyright
# Enter 0 in the EXTEND-BOOTWARE menu to reboot the device.
Enter your choice(0-9): 0
Loading the main image files...
Loading file flash:/s6550xe-cmw710-system-test.bin........................
Loading file flash:/s6550xe-cmw710-boot-test.bin..........................
....Done.
Image file flash:/s6550xe-cmw710-boot-test.bin is self-decompressing......
System image is starting...
Line aux1 is available.
Press ENTER to get started.
1.     Verify that the software has been upgraded.
<Device> display version
H3C Comware Software, Version 7.1.070, Release 8106P22
Copyright (c) 2004-2022 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S6550XE-56HF-HI uptime is 0 weeks, 0 days, 5 hours, 45 minutes
Boot image: flash:/s6550xe-cmw710-boot-test.bin
Boot image version: 7.1.070, Release 8106P22
  Compiled Nov 19 2022 11:00:00
System image: flash:/s6550xe-cmw710-system-test.bin
System image version: 7.1.070, Release 8106P22
---- More ----
2.     Verify that the startup software images are as configured.
<Device> display boot-loader slot 1
  flash:/s6550xe-cmw710-boot-old.bin
  flash:/s6550xe-cmw710-system- old.bin
Configuration files
The system does not save the commands used in this procedure to a configuration file.
