04-HH3C-UI-MAN-MIB | 57.69 KB |
hh3cTerminalUserName (1.3.6.1.4.1.25506.2.2.1.1.2.1)
HH3C-UI-MAN-MIB
About this MIB
Use this MIB to define alarms on user authentication. This MIB also contains notifications about user login changes.
MIB file name
hh3c-ui-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUIMgt(2)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTerminalUserName (1.3.6.1.4.1.25506.2.2.1.1.2.1) |
accessible-for-notify |
DisplayString |
Standard MIB values. |
Name of a login user. |
As per the MIB. |
hh3cTerminalSource (1.3.6.1.4.1.25506.2.2.1.1.2.2)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTerminalSource (1.3.6.1.4.1.25506.2.2.1.1.2.2) |
DisplayString |
Login method, including Console, AUX, TTY, and VTY. |
As per the MIB. |
Notifications
hh3cLogIn
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.2.1.1.3.0.1 |
User login |
Informational |
Warning |
ON |
Notification triggers
This notification is generated when a user logs in to the system.
System impact
No impact on the system.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.2.1.1.2.1 (hh3cTerminalUserName) |
Username. |
N/A |
DisplayString |
OCTET STRING (SIZE (0..255)) |
1.3.6.1.4.1.25506.2.2.1.1.2.2 (hh3cTerminalSource) |
User line, including console, AUX, TTY, and VTY. |
N/A |
DisplayString |
Recommended action
No action is required.
hh3cLogOut
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.2.1.1.3.0.2 |
User logout |
Informational |
Warning |
N/A |
ON |
This notification is generated when a user logs out of the system.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Username. |
N/A |
DisplayString |
User line, including AUX, TTY, and VTY. |
N/A |
DisplayString |
Recommended action
