03-HH3C-SYS-MAN-MIB | 156.69 KB |
hh3cSysLocalClock (1.3.6.1.4.1.25506.2.3.1.1.1)
hh3cSysSummerTimeEnable (1.3.6.1.4.1.25506.2.3.1.1.2.1)
hh3cSysSummerTimeZone (1.3.6.1.4.1.25506.2.3.1.1.2.2)
hh3cSysSummerTimeMethod (1.3.6.1.4.1.25506.2.3.1.1.2.4)
hh3cSysSummerTimeStart (1.3.6.1.4.1.25506.2.3.1.1.2.4)
hh3cSysSummerTimeEnd (1.3.6.1.4.1.25506.2.3.1.1.2.5)
hh3cSysSummerTimeOffset (1.3.6.1.4.1.25506.2.3.1.1.2.6)
hh3cSysLocalClockString (1.3.6.1.4.1.25506.2.3.1.1.3)
hh3cSysReloadSchedule (1.3.6.1.4.1.25506.2.3.1.3.1)
hh3cSysReloadAction (1.3.6.1.4.1.25506.2.3.1.3.2)
hh3cSysReloadTag (1.3.6.1.4.1.25506.2.3.1.3.4)
hh3cSysCFGFileNum (1.3.6.1.4.1.25506.2.3.1.5.1)
hh3cSysPackageNum (1.3.6.1.4.1.25506.2.3.1.7.1)
hh3cSysPackageOperateEntryLimit (1.3.6.1.4.1.25506.2.3.1.7.3)
HH3C-SYS-MAN-MIB
About this MIB
Use this MIB to manage the system time and daylight saving time, obtain the current configuration file and the version file, reboot the device, and upgrade device software. This MIB also contains notifications about configuration changes.
MIB file name
hh3c-sys-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSystemMan(3)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysLocalClock (1.3.6.1.4.1.25506.2.3.1.1.1) |
read-write |
DateAndTime |
OCTET STRING (8) |
System time. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysSummerTimeEnable (1.3.6.1.4.1.25506.2.3.1.1.2.1) |
read-only |
INTEGER |
enable(1) disable(2) |
Enables or disables using daylight saving time. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysSummerTimeZone (1.3.6.1.4.1.25506.2.3.1.1.2.2) |
read-write |
DisplayString |
OCTET STRING (0..255) |
Name for the daylight saving time schedule. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysSummerTimeMethod (1.3.6.1.4.1.25506.2.3.1.1.2.3) |
read-write |
INTEGER |
oneOff(1) repeating(2) |
Implementation method of daylight saving time. |
Supports only the repeating method. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysSummerTimeStart (1.3.6.1.4.1.25506.2.3.1.1.2.4) |
read-write |
DateAndTime |
OCTET STRING (8) |
Start time of the daylight saving time schedule. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysSummerTimeEnd (1.3.6.1.4.1.25506.2.3.1.1.2.5) |
read-write |
DateAndTime |
OCTET STRING (8) |
End time of the daylight saving time schedule. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysSummerTimeOffset (1.3.6.1.4.1.25506.2.3.1.1.2.6) |
read-write |
Integer32 |
Integer32 (0..86399) |
Time to be added to the standard time. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysLocalClockString (1.3.6.1.4.1.25506.2.3.1.1.3) |
read-write |
OCTET STRING |
OCTET STRING (16..24) |
System time in the format of strings. |
As per the MIB. Same as hh3cSysLocalClock. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysReloadSchedule (1.3.6.1.4.1.25506.2.3.1.3.1) |
read-write |
Integer32 |
Integer32 (0..2147483647) |
Reload entry index. |
The device reboots if the value of the object is 1 on the occurrence of the reload operation. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysReloadAction (1.3.6.1.4.1.25506.2.3.1.3.2) |
read-write |
INTEGER |
reloadUnavailable(1) reloadOnSchedule(2) reloadAtOnce(3) reloadCancel(4) |
Reload action. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysReloadTag (1.3.6.1.4.1.25506.2.3.1.3.4) |
read-write |
SnmpTagValue |
Tag of the reload entry. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysCFGFileNum (1.3.6.1.4.1.25506.2.3.1.5.1) |
read-only |
Integer32 |
Number of configuration files. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysPackageNum (1.3.6.1.4.1.25506.2.3.1.7.1) |
read-only |
Integer32 |
Number of packages. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysPackageOperateEntryLimit (1.3.6.1.4.1.25506.2.3.1.7.3) |
read-write |
Integer32 |
Maximum number of package file operation entries. |
Maximum number of instances in hh3cSysPackageOperateTable, in the range of 1 to 128. The default is 32. If the number of the instances reaches the limit, the most recent instance overwrites the earliest one. |
hh3cSysIpeFileNum (1.3.6.1.4.1.25506.2.3.1.8.1)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysIpeFileNum (1.3.6.1.4.1.25506.2.3.1.8.1) |
read-only |
Integer32 |
Number of IPE files. |
As per the MIB. |
Tabular objects
hh3cSysCurTable
About this table
This table contains information about the current system configuration file, device software, and bootrom files.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cSysCurEntPhysicalIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysCurEntPhysicalIndex (1.3.6.1.4.1.25506.2.3.1.2.1.1.1) |
not-accessible |
Integer32 |
Device entity index. |
As per the MIB. |
hh3cSysCurCFGFileIndex (1.3.6.1.4.1.25506.2.3.1.2.1.1.2) |
read-only |
Integer32 |
Configuration file index. |
As per the MIB. |
hh3cSysReloadScheduleTable
About this table
This table specifies reboot entries for device reboot.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
You must specify hh3cSysReloadScheduleIndex, hh3cSysReloadEntity, and hh3cSysReloadRowStatus when you create a row. hh3cSysReloadEntity must be a valid entity. The entity index from hh3cSysReloadScheduleIndex must be the same with the index of hh3cSysReloadEntity.
An entity supports only one reload table. Entries in Active status are not configurable.
Columns
The table index is hh3cSysReloadScheduleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysReloadScheduleIndex (1.3.6.1.4.1.25506.2.3.1.3.3.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Index of the hh3cSysReloadScheduleTable. |
As per the MIB. |
hh3cSysReloadEntity (1.3.6.1.4.1.25506.2.3.1.3.3.1.2) |
read-create |
Integer32 |
Entry in entPhysicalTable, which is the entity to be reloaded. |
As per the MIB. |
hh3cSysReloadCfgFile (1.3.6.1.4.1.25506.2.3.1.3.3.1.3) |
read-create |
Integer32 |
Integer32 (0.. 2147483647) |
Entry in hh3cSysImageFileTable. |
The value 0 indicates that the entity does not specify the next-startup configuration files. |
hh3cSysReloadReason (1.3.6.1.4.1.25506.2.3.1.3.3.1.5) |
read-create |
DisplayString |
Reason for system reloading. |
As per the MIB. |
hh3cSysReloadScheduleTime (1.3.6.1.4.1.25506.2.3.1.3.3.1.6) |
read-create |
DateAndTime |
OCTET STRING (8) |
Time when the reload action will occur. |
As per the MIB. |
hh3cSysReloadRowStatus (1.3.6.1.4.1.25506.2.3.1.3.3.1.7) |
read-create |
RowStatus |
active(1) notInService(2) notReady(3) createAndGo(4) createAndWait(5) destroy(6) |
Row status. |
As per the MIB. |
hh3cSysReloadScheduleTagList (1.3.6.1.4.1.25506.2.3.1.3.3.1.8) |
read-create |
SnmpTagList |
Tag list for the entry. |
If the value of hh3cSysReloadSchedule is valid, the value of hh3cSysReloadScheduleTagList is ignored. |
hh3cSysCFGFileTable
About this table
This table contains information about the configuration files of the system, including file names and file sizes.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cSysCFGFileIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysCFGFileIndex (1.3.6.1.4.1.25506.2.3.1.5.2.1.1) |
not-accessible |
Integer32 |
As per the MIB. |
hh3cSysCFGFileName (1.3.6.1.4.1.25506.2.3.1.5.2.1.2) |
read-only |
DisplayString |
Configuration file name. |
As per the MIB. |
hh3cSysCFGFileSize (1.3.6.1.4.1.25506.2.3.1.5.2.1.3) |
read-only |
Integer32 |
Configuration file size. |
As per the MIB. |
hh3cSysCFGFileLocation (1.3.6.1.4.1.25506.2.3.1.5.2.1.4) |
read-only |
DisplayString |
Configuration file path. |
As per the MIB. |
hh3cSysPackageTable
About this table
This table contains information about package files of the operating system, including basic package file information and operations on package files.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cSysPackageIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysPackageIndex (1.3.6.1.4.1.25506.2.3.1.7.2.1.1) |
not-accessible |
Integer32 |
Table index. |
As per the MIB. |
hh3cSysPackageName (1.3.6.1.4.1.25506.2.3.1.7.2.1.2) |
read-only |
DisplayString |
Package file name. |
As per the MIB. |
hh3cSysPackageSize (1.3.6.1.4.1.25506.2.3.1.7.2.1.3) |
read-only |
Unsigned32 |
Unsigned32 (1..4294967295) |
Package file size, in bytes. |
As per the MIB. |
hh3cSysPackageLocation (1.3.6.1.4.1.25506.2.3.1.7.2.1.4) |
read-only |
DisplayString |
Package file path. |
As per the MIB. |
hh3cSysPackageType (1.3.6.1.4.1.25506.2.3.1.7.2.1.5) |
read-only |
INTEGER |
boot(1) system(2) feature(3) patch(4) |
Type of the package file. |
As per the MIB. |
hh3cSysPackageAttribute (1.3.6.1.4.1.25506.2.3.1.7.2.1.6) |
read-write |
INTEGER |
none(1) primary(2) secondary(3) primarySecondary(4) |
Attribute of the package file. |
As per the MIB. |
hh3cSysPackageStatus (1.3.6.1.4.1.25506.2.3.1.7.2.1.7) |
read-only |
INTEGER |
active(1) inactive(2) |
Status of the package file. |
As per the MIB. |
hh3cSysPackageDescription (1.3.6.1.4.1.25506.2.3.1.7.2.1.8) |
read-only |
DisplayString |
Description of the package file. |
As per the MIB. |
hh3cSysPackageFeature (1.3.6.1.4.1.25506.2.3.1.7.2.1.9) |
read-only |
DisplayString |
Feature of the package file. |
As per the MIB. |
hh3cSysPackageVersion (1.3.6.1.4.1.25506.2.3.1.7.2.1.10) |
read-only |
DisplayString |
Version of the package file. |
As per the MIB. |
About this table
This table manages package files.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
You must specify hh3cSysPackageOperateIndex, hh3cSysPackageOperateIndex, hh3cSysPackageOperateStatus, and hh3cSysPackageOperateRowStatus when you create a row. The package file specified by hh3cSysPackageOperateIndex must a valid feature package.
Columns
The table index is hh3cSysPackageOperateIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysPackageOperateIndex (1.3.6.1.4.1.25506.2.3.1.7.4.1.1) |
not-accessible |
Integer32 |
Entry index. |
As per the MIB. |
hh3cSysPackageOperatePackIndex (1.3.6.1.4.1.25506.2.3.1.7.4.1.2) |
read-create |
Integer32 |
Index of the specified package file. |
As per the MIB. |
hh3cSysPackageOperateStatus(1.3.6.1.4.1.25506.2.3.1.7.4.1.3) |
read-create |
INTEGER |
Activation or deactivation of the package file. |
As per the MIB. |
hh3cSysPackageOperateRowStatu (1.3.6.1.4.1.25506.2.3.1.7.4.1.4) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cSysPackageOperateResult(1.3.6.1.4.1.25506.2.3.1.7.4.1.5) |
read-only |
INTEGER |
opInProgress(1) opSuccess(2) opUnknownFailure(3) opInvalidFile(4) opNotSupport(5) |
Operation result. |
As per the MIB. |
hh3cSysIpeFileTable
About this table
This table contains information about IPE files.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cSysIpeFileIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysIpeFileIndex (1.3.6.1.4.1.25506.2.3.1.8.2.1.1) |
not-accessible |
Integer32 |
Index of an IPE file. |
As per the MIB. |
hh3cSysIpeFileName (1.3.6.1.4.1.25506.2.3.1.8.2.1.2) |
read-only |
DisplayString |
IPE file name. |
As per the MIB. |
hh3cSysIpeFileSize (1.3.6.1.4.1.25506.2.3.1.8.2.1.3) |
read-only |
Unsigned32 |
IPE file size, in bytes. |
As per the MIB. |
hh3cSysIpeFileLocation (1.3.6.1.4.1.25506.2.3.1.8.2.1.4) |
read-only |
DisplayString |
IPE file path. |
As per the MIB. |
hh3cSysIpePackageTable
About this table
This table contains information about packages in IPE files.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are hh3cSysIpeFileIndex and hh3cSysIpePackageIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysIpePackageIndex (1.3.6.1.4.1.25506.2.3.1.8.3.1.1) |
not-accessible |
Integer32 |
IPE package index. |
As per the MIB. |
hh3cSysIpePackageName (1.3.6.1.4.1.25506.2.3.1.8.3.1.2) |
read-only |
DisplayString |
As per the MIB. |
hh3cSysIpePackageSize (1.3.6.1.4.1.25506.2.3.1.8.3.1.3) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cSysIpePackageType (1.3.6.1.4.1.25506.2.3.1.8.3.1.4) |
read-only |
INTEGER |
As per the MIB. |
hh3cSysPackageDescription (1.3.6.1.4.1.25506.2.3.1.8.3.1.5) |
read-only |
DisplayString |
As per the MIB. |
hh3cSysIpePackageFeature (1.3.6.1.4.1.25506.2.3.1.8.3.1.6) |
read-only |
DisplayString |
As per the MIB. |
hh3cSysIpePackageVersion (1.3.6.1.4.1.25506.2.3.1.8.3.1.7) |
read-only |
DisplayString |
As per the MIB. |
hh3cSysIpeFileOperateTable
About this table
This table manages IPE files.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
You must specify hh3cSysIpeFileOperateInde, hh3cSysIpeFileOperateIndex, hh3cSysIpeFileOperateAttribute, and hh3cSysIpeFileOperateRowStatus when you create a row.
Columns
The table index is hh3cSysIpeFileOperateIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysIpeFileOperateIndex (1.3.6.1.4.1.25506.2.3.1.8.4.1.1) |
not-accessible |
Integer32 |
Entry index. |
If the entity index is 1, IPE files will be decompressed to the active MPU. |
hh3cSysIpeFileOperateFileIndex (1.3.6.1.4.1.25506.2.3.1.8.4.1.2) |
read-create |
Integer32 |
The value of this object is an instance index in hh3cSysIpeFileTable. |
hh3cSysIpeFileOperateAttribute(1.3.6.1.4.1.25506.2.3.1.8.4.1.3) |
read-create |
INTEGER |
Attribute of the IPE file. |
As per the MIB. |
hh3cSysIpeFileOperateRowStatus (1.3.6.1.4.1.25506.2.3.1.8.4.1.4) |
read-create |
INTEGER |
Row status. |
As per the MIB. |
hh3cSysIpeFileOperateResult (1.3.6.1.4.1.25506.2.3.1.8.4.1.5) |
read-only |
INTEGER |
opInProgress(1) opSuccess(2) opUnknownFailure(3) opInvalidFile(4) opDeviceFull(5) opFileOpenError(6) |
Operation result. |
As per the MIB. |
