20-Network Management and Monitoring
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10020-Network Management and Monitoring
15-RMON-MIB
15-RMON-MIB 56.02 KB
RMON-MIB
About this MIB
Use this MIB to monitor data traffic on a network segment or the entire network.
MIB file name
rfc2819-rmon.mib
Notifications
risingAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.16.0.1
A variable of an alarm entry crossed its rising threshold.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when a variable of an alarm entry crosses its rising threshold and the triggered event is to send SNMP notifications.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the rmon event entry-number [ description string ] { log-trap security-string | trap security-string } [ owner text ] command.
OFF
CLI: Use the rmon event entry-number [ description string ] { log | none } [ owner text ] command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.16.3.1.1.1 (alarmIndex)
Index of the alarm entry
alarmIndex
Integer32
1..65535
1.3.6.1.2.1.16.3.1.1.3 (alarmVariable)
Variable to be sampled
alarmIndex
OBJECT IDENTIFIER
Standard MIB values.
1.3.6.1.2.1.16.3.1.1.4 (alarmSampleType)
Sampling type
alarmIndex
INTEGER
absoluteValue(1), deltaValue(2)
1.3.6.1.2.1.16.3.1.1.5 (alarmValue)
Sampled value
alarmIndex
Integer32
1.3.6.1.2.1.16.3.1.1.7 (alarmRisingThreshold)
Rising threshold
alarmIndex
Integer32
Recommended action
To resolve the issue:
1.Execute the display rmon alarm command in any view to check information about the monitored variable and rising threshold. Locate and remove the reason causing the notification.
If the rising threshold is inappropriate, execute the rmon alarm command in system view to change the rising threshold.
2.If the issue persists, collect alarm information and configuration data and then contact H3C Support for help.
fallingAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.16.0.2
A variable of an alarm entry fell to or below its falling threshold.
Informational
Warning
N/A (N/A)
ON
This notification is generated when a variable of an alarm entry falls to or below its falling threshold and the triggered event is to send SNMP notifications.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
alarmIndex
Integer32
1..65535
alarmIndex
OBJECT IDENTIFIER
Sampling type
alarmIndex
INTEGER
Sampled value
alarmIndex
Integer32
1.3.6.1.2.1.16.3.1.1.8 (alarmFallingThreshold)
Falling threshold
alarmIndex
Integer32
Recommended action
1.Execute the display rmon alarm command in any view to check information about the monitored variable and falling threshold. Locate and remove the reason causing the notification.
If the falling threshold is inappropriate, execute the rmon alarm command in system view to change the falling threshold.
