20-Network Management and Monitoring
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10020-Network Management and Monitoring
13-HH3C-SNMP-EXT-MIB
13-HH3C-SNMP-EXT-MIB 110.55 KB
HH3C-SNMP-EXT-MIB
About this MIB
This MIB adds objects to extend SNMP management.
MIB file name
hh3c-snmp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSnmpExt(104)
Scalar objects
hh3cSnmpExtMaxContextNum (1.3.6.1.4.1.25506.2.104.1.4)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32 (1..65535)
Maximum number of SNMP contexts supported by the system.
As per the MIB.
hh3cSnmpExtVersion (1.3.6.1.4.1.25506.2.104.1.5)
Object (OID)
Access
Value range
Implementation
read-write
BITS
BITS { snmpV1(0), snmpV2c(1), snmpV3(2) }
SNMP version.
As per the MIB.
hh3cSnmpExtTargetAddress (1.3.6.1.4.1.25506.2.104.1.12)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
OCTET STRING (0..255)
Address of the target host that receives SNMP notifications.
As per the MIB.
hh3cSnmpExtFallingThreshold (1.3.6.1.4.1.25506.2.104.1.13)
Object (OID)
Access
Value range
Implementation
Integer32
Integer32(1..2147483647)
Falling threshold for the number of users in the SNMPv3 user denylist.
As per the MIB.
hh3cSnmpExtRisingThreshold (1.3.6.1.4.1.25506.2.104.1.14)
Object (OID)
Access
Value range
Implementation
Integer32
Rising threshold for the number of users in the SNMPv3 user denylist.
As per the MIB.
Tabular objects
hh3cSnmpExtCommunityTable
About this table
Use this table to configure the extended properties for SNMP communities (SNMPv1 or SNMPv2c) and SNMP users (SNMPv3).
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cSnmpExtCommunitySecurityLevel and hh3cSnmpExtCommunitySecurityName.
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtCommunitySecurityLevel (1.3.6.1.4.1.25506.2.104.2.1.1.1)
not-accessible
SnmpSecurityModel
INTEGER (0..3)
Security model of a community or user.
As per the MIB.
hh3cSnmpExtCommunitySecurityName (1.3.6.1.4.1.25506.2.104.2.1.1.2)
not-accessible
SnmpAdminString
OCTET STRING (1..32)
Security name of the community or user.
As per the MIB.
hh3cSnmpExtCommunityName (1.3.6.1.4.1.25506.2.104.2.1.1.3)
read-only
OCTET STRING
Community name or username.
As per the MIB.
hh3cSnmpExtCommunityAclNum (1.3.6.1.4.1.25506.2.104.2.1.1.4)
read-write
Integer32
Integer32 (0 | 2000..3999)
IPv4 ACL number used by the community or the user.
As per the MIB.
hh3cSnmpExtCommunityIPv6AclNum (1.3.6.1.4.1.25506.2.104.2.1.1.5)
read-write
Integer32
IPv6 ACL number used by the community or the user.
As per the MIB.
hh3cSnmpExtContextTable
About this table
Use this table to configure SNMP context extended properties.
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is hh3cSnmpExtContextName.
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtContextName (1.3.6.1.4.1.25506.2.104.2.3.1.1)
not-accessible
SnmpAdminString
Context name.
As per the MIB.
hh3cSnmpExtContextRowStatus (1.3.6.1.4.1.25506.2.104.2.3.1.2)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Status of this entry.
Supports only action, createAndGo, and destroy.
Notifications
hh3cSnmpExtTargetHostDel
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.104.3.0.1
An SNMP notification target host configuration was cancelled.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the undo snmp-agent target-host command is executed to cancel an SNMP notification target host configuration. This notification is sent only to the canceled target host.
System impact
No negative impact on the system.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
Standard MIB values.
Recommended action
No action is required.
hh3cSnmpExtLockThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.104.3.0.2
The number of users in the SNMPv3 user denylist exceeded the rising threshold.
Informational
Warning
hh3cSnmpExtLockThresholdResume (hh3cSnmpExtLockThresholdResume)
ON
This notification is generated when the number of users in the SNMPv3 user denylist exceeds the rising threshold (40% of the maximum number of users in the SNMPv3 user denylist).
System impact
The device is subject to many authorized user access attacks, which can result in network management connection failure in worst cases.
Status control
ON
CLI: Use the snmp-agent trap enable command.
OFF
CLI: Use the undo snmp-agent trap enable command.
Object
OID (object name)
Index
Value range
N/A
Integer32
Recommended action
Check the users in the denylist for attack sources and filter attack sources through firewall or other means.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.104.3.0.3
The number of users in the SNMPv3 denylist fell below the falling threshold.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the number of users in the SNMPv3 user denylist falls below the falling threshold (10% of the maximum number of users in the SNMPv3 user denylist).
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Integer32
Recommended action
