00-Preface | 74.62 KB |
Preface
This installation guide describes the installation procedures for the H3C WX3820X access controller, including preparing for installing the controller, installing and accessing the controller, troubleshooting the controller, and maintaining the controller.
· Audience
Audience
· Network planners.
· Network administrators working with the WX3820X access controller.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
Your comments or suggestions would be highly appreciated.
