- 10-Security Configuration Guide
- 01-AAA configuration
- 02-Password control configuration
- 03-Public key management configuration
- 04-PKI configuration
- 05-IPsec configuration
- 06-SSH configuration
- 07-IP source guard configuration
- 08-ARP attack protection configuration
- 09-uRPF configuration
- 10-SSL configuration
- 11-Crypto engine configuration
- 12-FIPS configuration
- 13-Portal configuration
- 14-MACsec configuration
- 15-Attack detection and prevention configuration
- 16-Object group configuration
| 08-ARP attack protection configuration | 283.44 KB |
Configuring ARP attack protection
ARP attack protection configuration task list
Configuring unresolvable IP attack protection
Configuring ARP source suppression
Configuring ARP blackhole routing
Displaying and maintaining unresolvable IP attack protection
Configuring ARP packet rate limit
Configuring source MAC-based ARP attack detection
Displaying and maintaining source MAC-based ARP attack detection
Configuring ARP packet source MAC consistency check
Configuring ARP active acknowledgement
Configuration example (on a DHCP server)
Configuration example (on a DHCP relay agent)
Configuring user validity check
Configuring ARP packet validity check
Configuring ARP restricted forwarding
Displaying and maintaining ARP detection
User validity check and ARP packet validity check configuration example
ARP restricted forwarding configuration example
Configuring ARP scanning and fixed ARP
Configuring ARP gateway protection
Although ARP is easy to implement, it provides no security mechanism and is vulnerable to network attacks. An attacker can exploit ARP vulnerabilities to attack network devices in the following ways:
· Acts as a trusted user or gateway to send ARP packets so the receiving devices obtain incorrect ARP entries.
· Sends a large number of unresolvable IP packets to have the receiving device busy with resolving IP addresses until its CPU is overloaded. Unresolvable IP packets refer to IP packets for which ARP cannot find corresponding MAC addresses.
· Sends a large number of ARP packets to overload the CPU of the receiving device.
For more information about ARP attack features and types, see ARP Attack Protection Technology White Paper.
Tasks at a glance |
Flood prevention: · Configuring unresolvable IP attack protection (configured on gateways) ¡ Configuring ARP source suppression ¡ Configuring ARP blackhole routing · Configuring ARP packet rate limit (configured on access devices) · Configuring source MAC-based ARP attack detection (configured on gateways) |
User and gateway spoofing prevention: · Configuring ARP packet source MAC consistency check (configured on gateways) · Configuring ARP active acknowledgement (configured on gateways) · Configuring authorized ARP (configured on gateways) · Configuring ARP detection (configured on access devices) · Configuring ARP scanning and fixed ARP (configured on gateways) · Configuring ARP gateway protection (configured on access devices) · Configuring ARP filtering (configured on access devices) |
If a device receives a large number of unresolvable IP packets from a host, the following situations can occur.
· The device sends a large number of ARP requests, overloading the target subnets.
· The device keeps trying to resolve target IP addresses, overloading its CPU.
To protect the device from such unresolvable IP attacks, you can configure the following features:
· ARP source suppression—Stops resolving packets from a host if the upper limit on unresolvable IP packets from the host is reached within an interval of 5 seconds. The device continues ARP resolution when the interval elapses. This feature is applicable if the attack packets have the same source addresses.
· ARP blackhole routing—Creates a blackhole route destined for an unresolved IP address. The device drops all matching packets until the blackhole route is deleted. A blackhole route is deleted when its aging timer (25 seconds) is reached or the route becomes reachable.
After a blackhole route is created for an unresolved IP address, the device immediately starts the first ARP blackhole route probe by sending an ARP request. If the resolution fails, the device continues probing according to the probe settings. If the IP address resolution succeeds in a probe, the device converts the blackhole route to a normal route. If an ARP blackhole route ages out before the device finishes all probes, the device deletes the blackhole route and does not perform the remaining probes.
This feature is applicable regardless of whether the attack packets have the same source addresses.
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable ARP source suppression. |
arp source-suppression enable |
By default, ARP source suppression is disabled. |
3. Set the maximum number of unresolvable packets that the device can receive from a host within 5 seconds. |
arp source-suppression limit limit-value |
By default, the maximum number is 10. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable ARP blackhole routing. |
arp resolving-route enable |
By default, ARP blackhole routing is enabled. |
3. (Optional.) Set the interval at which the device probes ARP blackhole routes. |
arp resolving-route probe-interval interval |
The default setting is 1 second. |
4. (Optional.) Set the number of ARP blackhole route probes for each unresolved IP address. |
arp resolving-route probe-count count |
The default setting is one probe. |
Task |
Command |
Display ARP source suppression configuration information. |
display arp source-suppression |
Network requirements
As shown in Figure 1, a LAN contains two areas: an R&D area in VLAN 10 and an office area in VLAN 20. Each area connects to the gateway (Switch) through an access switch.
A large number of ARP requests are detected in the office area and are considered as the consequence of an unresolvable IP attack. To prevent the attack, configure ARP source suppression and ARP blackhole routing.
Configuration considerations
If the attack packets have the same source address, configure the ARP source suppression feature as follows:
1. Enable ARP source suppression.
2. Set the threshold to 100. If the number of unresolvable IP packets received from a host within 5 seconds exceeds 100, the device stops resolving packets from the host until the 5 seconds elapse.
If the attack packets have different source addresses, enable the ARP blackhole routing feature on the gateway.
Configuration procedure
# Enable ARP source suppression and set the threshold to 100.
<Switch> system-view
[Switch] arp source-suppression enable
[Switch] arp source-suppression limit 100
# Enable ARP blackhole routing.
[Switch] arp resolving-route enable
The ARP packet rate limit feature allows you to limit the rate of ARP packets delivered to the CPU. An ARP detection enabled device will send all received ARP packets to the CPU for inspection. Processing excessive ARP packets will make the device malfunction or even crash. To solve this problem, configure ARP packet rate limit.
Configuration guidelines
Configure this feature when ARP detection, ARP snooping, or ARP fast-reply is enabled, or when ARP flood attacks are detected.
This task sets a rate limit for ARP packets received on an interface. When the receiving rate of ARP packets on the interface exceeds the rate limit, those packets are discarded.
You can enable sending notifications to the SNMP module or enable logging for ARP packet rate limit.
· If notification sending is enabled, the device sends the highest threshold-crossed ARP packet rate within the sending interval in a notification to the SNMP module. You must use the snmp-agent target-host command to set the notification type and target host. For more information about notifications, see Network Management and Monitoring Command Reference.
· If logging for ARP packet rate limit is enabled, the device sends the highest threshold-crossed ARP packet rate within the sending interval in a log message to the information center. You can configure the information center module to set the log output rules. For more information about information center, see Network Management and Monitoring Configuration Guide.
To configure ARP packet rate limit:
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Enable notification sending for ARP packet rate limit. |
snmp-agent trap enable arp [ rate-limit ] |
By default, notification sending for ARP packet rate limit is disabled. |
3. (Optional.) Enable logging for ARP packet rate limit. |
arp rate-limit log enable |
By default, logging for ARP packet rate limit is disabled. |
4. (Optional.) Set the notification and log message sending interval. |
arp rate-limit log interval seconds |
By default, the device sends notifications and log messages at an interval of 60 seconds. |
5. Enter Layer 2 Ethernet interface or Layer 2 aggregate interface view. |
N/A |
6. Enable ARP packet rate limit. |
arp rate-limit [ pps ] |
By default, ARP packet rate limit is enabled. |
NOTE: If you enable notification sending and logging for ARP packet rate limit on a Layer 2 aggregate interface, the functions apply to all aggregation member ports. |
This feature checks the number of ARP packets delivered to the CPU. If the number of packets from the same MAC address within 5 seconds exceeds a threshold, the device adds the MAC address in an ARP attack entry. Before the entry is aged out, the device handles the attack by using either of the following methods:
· Monitor—Only generates log messages.
· Filter—Generates log messages and filters out subsequent ARP packets from that MAC address.
You can exclude the MAC addresses of some gateways and servers from this detection. This feature does not inspect ARP packets from those devices even if they are attackers.
To configure source MAC-based ARP attack detection:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable source MAC-based ARP attack detection and specify the handling method. |
arp source-mac { filter | monitor } |
By default, this feature is disabled. |
3. Configure the threshold. |
arp source-mac threshold threshold-value |
By default, the maximum number of ARP packets received from the same MAC address within 5 seconds is 30. |
4. Configure the aging timer for ARP attack entries. |
arp source-mac aging-time time |
By default, the lifetime is 300 seconds. |
5. (Optional.) Exclude specific MAC addresses from this detection. |
arp source-mac exclude-mac mac-address&<1-n> |
By default, no MAC address is excluded. The value range of the n argument is 1 to 64. |
NOTE: When an ARP attack entry is aged out, ARP packets sourced from the MAC address in the entry can be processed correctly. |
Task |
Command |
Display ARP attack entries detected by source MAC-based ARP attack detection (in standalone mode). |
display arp source-mac { slot slot-number | interface interface-type interface-number } |
Display ARP attack entries detected by source MAC-based ARP attack detection (in IRF mode). |
display arp source-mac { chassis chassis-number slot slot-number | interface interface-type interface-number } |
As shown in Figure 2, the hosts access the Internet through a gateway (Device). If malicious users send a large number of ARP requests to the gateway, the gateway might crash and cannot process requests from the clients. To solve this problem, configure source MAC-based ARP attack detection on the gateway.
Figure 2 Network diagram
An attacker might forge a large number of ARP packets by using the MAC address of a valid host as the source MAC address. To prevent such attacks, configure the gateway in the following steps:
1. Enable source MAC-based ARP attack detection and specify the handling method as filter.
2. Set the threshold.
3. Set the lifetime for ARP attack entries.
4. Exclude the MAC address of the server from this detection.
# Enable source MAC-based ARP attack detection, and specify the handling method as filter.
[Switch] arp source-mac filter
# Set the threshold to 30.
[Switch] arp source-mac threshold 30
# Set the lifetime for ARP attack entries to 60 seconds.
[Switch] arp source-mac aging-time 60
# Exclude MAC address 0012-3f86-e94c from this detection.
[Switch] arp source-mac exclude-mac 0012-3f86-e94c
This feature enables a gateway to filter out ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body. This feature allows the gateway to learn correct ARP entries.
To enable ARP packet source MAC address consistency check:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable ARP packet source MAC address consistency check. |
arp valid-check enable |
By default, ARP packet source MAC address consistency check is disabled. |
Configure this feature on gateways to prevent user spoofing.
Without ARP active acknowledgement enabled, the gateway, upon receiving an ARP packet, searches existing ARP entries for the sender IP address of the ARP packet:
· If no match is found, the gateway creates an ARP entry with the sender IP and MAC addresses of the ARP packet.
· If a match is found, the gateway updates the ARP entry with the sender IP and MAC addresses of the ARP packet.
ARP active acknowledgement works before creating an ARP entry or modifying an ARP entry.
Active acknowledgement before creating an ARP entry
Before creating an ARP entry, the gateway broadcasts an ARP request in which the target IP address is the sender IP address of the received ARP packet. If no ARP reply is received within three seconds, the gateway does not create the ARP entry. If an ARP reply is received within three seconds, the gateway compares the ARP reply with the formerly received ARP packet, including the sender IP address, sender MAC address, and the receiving interface.
· If the two packets are consistent, the gateway considers the formerly received ARP packet valid and creates the corresponding ARP entry.
· If the two packets are inconsistent, the gateway considers the formerly received ARP packet as an attack and does not create the corresponding ARP entry.
Active acknowledgement before modifying an ARP entry
Upon receiving an ARP packet (Packet A), the gateway checks the existing ARP entries for the sender IP address of Packet A. If an ARP entry with a matched IP address but an unmatched MAC address is found, the gateway performs the following steps:
1. Checks whether the ARP entry validity should be examined.
To prevent frequent updating of the ARP entry for the same IP address, the gateway checks whether the ARP entry has been updated within the last minute:
¡ If yes, the gateway does not update the ARP entry.
¡ If no, the gateway checks the validity of the ARP entry.
2. Checks the validity of the ARP entry.
The gateway unicasts an ARP request to the MAC address in the ARP entry.
¡ If no ARP reply is received within five seconds, the gateway does not update the ARP entry.
¡ If an ARP reply is received within five seconds, the gateway checks whether the sender IP and MAC addresses in the ARP reply are identical with those in the ARP entry:
- If yes, the gateway considers Packet A as an attack and does not update the ARP entry.
- If no, the gateway checks the validity of Packet A.
3. Checks the validity of Packet A.
The gateway unicasts an ARP request to the sender MAC address in Packet A.
¡ If an ARP reply is received within five seconds, the gateway checks whether the sender IP and MAC addresses in the ARP reply are identical with those in Packet A:
- If yes, the gateway considers Packet A valid and updates the ARP entry.
- If no, the gateway considers Packet A an attack and does not update the ARP entry.
In strict mode, a gateway performs more strict validity checks before creating an ARP entry:
· Upon receiving an ARP request destined for the gateway, the gateway sends an ARP reply but does not create an ARP entry.
· Upon receiving an ARP reply, the gateway determines whether it has resolved the sender IP address:
¡ If yes, the gateway performs active acknowledgement. When the ARP reply is verified as valid, the gateway creates an ARP entry.
¡ If no, the gateway discards the packet.
To configure ARP active acknowledgement:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the ARP active acknowledgement feature. |
arp active-ack [ strict ] enable |
By default, the ARP active acknowledgement feature is disabled. |
Authorized ARP entries are generated based on the DHCP clients' address leases on the DHCP server or dynamic client entries on the DHCP relay agent. For more information about DHCP server and DHCP relay agent, see Layer 3—IP Services Configuration Guide.
The authorized ARP feature can enable an interface to prevent user spoofing and allow only authorized clients to access network resources.
To enable authorized ARP:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
The following interface types are supported: · Layer 3 Ethernet interface. · Layer 3 Ethernet subinterface. · Layer 3 aggregate interface. · Layer 3 aggregate subinterface. · VLAN interface. |
3. Enable authorized ARP on the interface. |
arp authorized enable |
By default, authorized ARP is disabled. |
By default, Ethernet, VLAN, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up. This example assumes that all these interfaces are already up.
As shown in Figure 3, configure authorized ARP on GigabitEthernet 3/0/1 of Switch A (a DHCP server) to ensure user validity.
1. Configure Switch A:
# Specify the IP address for GigabitEthernet 3/0/1.
[SwitchA] interface GigabitEthernet 3/0/1
[SwitchA-GigabitEthernet3/0/1] ip address 10.1.1.1 24
[SwitchA-GigabitEthernet3/0/1] quit
# Configure DHCP.
[SwitchA] dhcp enable
[SwitchA] dhcp server ip-pool 1
[SwitchA-dhcp-pool-1] network 10.1.1.0 mask 255.255.255.0
[SwitchA-dhcp-pool-1] quit
# Enter Layer 3 Ethernet interface view.
# Enable authorized ARP.
[SwitchA-GigabitEthernet3/0/1] port link-mode route
[SwitchA-GigabitEthernet3/0/1] arp authorized enable
2. Configure Switch B:
[SwitchB] interface GigabitEthernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] ip address dhcp-alloc
[SwitchB-GigabitEthernet3/0/1] quit
# Display authorized ARP entry information on Switch A.
[SwitchA] display arp all
Type: S-Static D-Dynamic O-Openflow M-Multiport I-Invalid
IP Address MAC Address VLAN Interface Aging Type
10.1.1.2 0012-3f86-e94c N/A GE3/0/1 20 D
The output shows that IP address 10.1.1.2 has been assigned to Switch B.
Switch B must use the IP address and MAC address in the authorized ARP entry to communicate with Switch A. Otherwise, the communication fails. Thus user validity is ensured.
As shown in Figure 4, configure authorized ARP on GigabitEthernet 3/0/2 of Switch B (a DHCP relay agent) to ensure user validity.
# Configure DHCP.
[SwitchA-dhcp-pool-1] network 10.10.1.0 mask 255.255.255.0
[SwitchA-dhcp-pool-1] gateway-list 10.10.1.1
[SwitchA] ip route-static 10.10.1.0 24 10.1.1.2
# Enable DHCP.
[SwitchB] dhcp enable
# Specify the IP addresses of GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2.
[SwitchB-GigabitEthernet3/0/1] ip address 10.1.1.2 24
[SwitchB] interface GigabitEthernet 3/0/2
[SwitchB-GigabitEthernet3/0/2] ip address 10.10.1.1 24
# Enable DHCP relay agent on GigabitEthernet 3/0/2.
[SwitchB-GigabitEthernet3/0/2] dhcp select relay
# Add the DHCP server 10.1.1.1 to DHCP server group 1.
[SwitchB-GigabitEthernet3/0/2] dhcp relay server-address 10.1.1.1
[SwitchB-GigabitEthernet3/0/1] port link-mode route
[SwitchB-GigabitEthernet3/0/2] arp authorized enable
[SwitchB-GigabitEthernet3/0/2] quit
# Enable recording of relay entries on the relay agent.
[SwitchB] dhcp relay client-information record
3. Configure Switch C:
[SwitchC] ip route-static 10.1.1.0 24 10.10.1.1
[SwitchC] interface GigabitEthernet 3/0/2
[SwitchC-GigabitEthernet3/0/2] ip address dhcp-alloc
[SwitchC-GigabitEthernet3/0/2] quit
# Display authorized ARP information on Switch B.
[SwitchB] display arp all
10.10.1.2 0012-3f86-e94c N/A GE3/0/2 20 D
The output shows that Switch A assigned the IP address 10.10.1.2 to Switch C.
Switch C must use the IP address and MAC address in the authorized ARP entry to communicate with Switch B. Otherwise, the communication fails. Thus the user validity is ensured.
ARP detection enables access devices to block ARP packets from unauthorized clients to prevent user spoofing and gateway spoofing attacks. ARP detection does not check ARP packets received from ARP trusted ports.
ARP detection provides the user validity check, ARP packet validity check, and ARP restricted forwarding functions.
If both ARP packet validity check and user validity check are enabled, the former one applies first, and then the latter applies.
Upon receiving an ARP packet from an ARP untrusted interface, the device matches the sender IP and MAC addresses with the following entries:
· Static IP source guard binding entries
· DHCP snooping entries
If a match is found, the ARP packet is considered valid and is forwarded. If no match is found, the ARP packet is considered invalid and is discarded.
Static IP source guard binding entries are created by using the ip source binding command. For more information, see "Configuring IP source guard."
DHCP snooping entries are automatically generated by DHCP snooping. For more information, see Layer 3—IP Services Configuration Guide.
· Make sure at least one among static IP source guard binding entries and DHCP snooping entries is available for user validity check. Otherwise, ARP packets received from ARP untrusted ports are discarded.
· You must specify a VLAN for an IP source guard binding entry. Otherwise, no ARP packets can match the IP source guard binding entry.
To configure user validity check:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter VLAN view. |
vlan vlan-id |
N/A |
3. Enable ARP detection. |
arp detection enable |
By default, ARP detection is disabled. |
4. Return to system view. |
quit |
N/A |
5. Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view. |
N/A |
6. (Optional.) Configure the interface as a trusted interface excluded from ARP detection. |
arp detection trust |
By default, an interface is untrusted. |
Enable validity check for ARP packets received on untrusted ports and specify the following objects to be checked:
· src-mac—Checks whether the sender MAC address in the message body is identical to the source MAC address in the Ethernet header. If they are identical, the packet is forwarded. Otherwise, the packet is discarded.
· dst-mac—Checks the target MAC address of ARP replies. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
· ip—Checks the sender and target IP addresses of ARP replies, and the sender IP address of ARP requests. All-one or multicast IP addresses are considered invalid and the corresponding packets are discarded.
To configure ARP packet validity check:
Step |
Command |
Remarks |
system-view |
N/A |
vlan vlan-id |
N/A |
quit |
N/A |
5. Enable ARP packet validity check and specify the objects to be checked. |
arp detection validate { dst-mac | ip | src-mac } * |
By default, ARP packet validity check is disabled. |
6. Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view. |
N/A |
7. (Optional.) Configure the interface as a trusted interface excluded from ARP detection. |
NOTE: ARP restricted forwarding does not apply to ARP packets with multiport MAC as their destination MAC addresses. |
ARP restricted forwarding controls the forwarding of ARP packets that are received on untrusted interfaces and have passed user validity check as follows:
· If the packets are ARP requests, they are forwarded through the trusted interface.
· If the packets are ARP replies, they are forwarded according to their destination MAC address. If no match is found in the MAC address table, they are forwarded through the trusted interface.
Configure user validity check before you configure ARP restricted forwarding.
To enable ARP restricted forwarding:
Step |
Command |
Remarks |
system-view |
N/A |
vlan vlan-id |
N/A |
3. Enable ARP restricted forwarding. |
arp restricted-forwarding enable |
By default, ARP restricted forwarding is disabled. |
Task |
Command |
Display the VLANs enabled with ARP detection. |
display arp detection |
Display the ARP detection statistics. |
display arp detection statistics [ interface interface-type interface-number ] |
Clear the ARP detection statistics. |
reset arp detection statistics [ interface interface-type interface-number ] |
As shown in Figure 5, configure Switch B to perform ARP packet validity check and user validity check based on static IP source guard binding entries and DHCP snooping entries for connected hosts.
1. Add all interfaces on Switch B to VLAN 10, and specify the IP address of VLAN-interface 10 on Switch A. (Details not shown.)
2. Configure the DHCP server on Switch A, and configure DHCP address pool 0.
[SwitchA] dhcp server ip-pool 0
[SwitchA-dhcp-pool-0] network 10.1.1.0 mask 255.255.255.0
3. Configure Host A (DHCP client) and Host B. (Details not shown.)
4. Configure Switch B:
# Enable DHCP snooping.
[SwitchB] dhcp snooping enable
[SwitchB] interface GigabitEthernet 3/0/3
[SwitchB-GigabitEthernet3/0/3] dhcp snooping trust
[SwitchB-GigabitEthernet3/0/3] quit
# Enable recording of client information in DHCP snooping entries on GigabitEthernet 3/0/1.
[SwitchB-GigabitEthernet3/0/1] dhcp snooping binding record
# Enable ARP detection for VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] arp detection enable
# Configure the upstream interface as a trusted interface. By default, an interface is an untrusted interface.
[SwitchB-vlan10] interface GigabitEthernet 3/0/3
[SwitchB-GigabitEthernet3/0/3] arp detection trust
# Configure a static IP source guard binding entry on interface GigabitEthernet 3/0/2 for user validity check.
[SwitchB-GigabitEthernet3/0/2] ip source binding ip-address 10.1.1.6 mac-address 0001-0203-0607 vlan 10
# Enable ARP packet validity check by checking the MAC addresses and IP addresses of ARP packets.
[SwitchB] arp detection validate dst-mac ip src-mac
After the configurations are completed, Switch B first checks the validity of ARP packets received on GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2. If the ARP packets are confirmed valid, the switch performs user validity check by using the static IP source guard binding entries and finally DHCP snooping entries.
As shown in Figure 6, configure ARP restricted forwarding on Switch B where ARP detection is configured so that port isolation configured on Switch B can take effect for broadcast ARP requests.
1. Configure VLAN 10, add interfaces to VLAN 10, and specify the IP address of the VLAN-interface. (Details not shown.)
# Enable DHCP snooping, and configure GigabitEthernet 3/0/3 as a DHCP-trusted port.
# Enable ARP detection for user validity check.
[SwitchB] vlan 10
# Configure GigabitEthernet 3/0/3 as an ARP-trusted port.
# Configure a static IP source guard entry on interface GigabitEthernet 3/0/2.
# Configure port isolation.
[SwitchB] port-isolate group 1
[SwitchB-GigabitEthernet3/0/1] port-isolate enable group 1
[SwitchB-GigabitEthernet3/0/2] port-isolate enable group 1
After the configurations are complete, Switch B first checks the validity of ARP packets received on GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2. If the ARP packets are confirmed valid, the switch performs user validity check by using the static IP source guard binding entries and finally DHCP snooping entries. However, ARP broadcast requests sent from Host A can pass the check on Switch B and reach Host B. Port isolation fails.
# Enable ARP restricted forwarding.
[SwitchB] vlan 10
[SwitchB-vlan10] arp restricted-forwarding enable
[SwitchB-vlan10] quit
After the configuration, Switch B forwards ARP broadcast requests from Host A to Switch A through the trusted interface GigabitEthernet 3/0/3, and thus Host B cannot receive such packets. Port isolation functions correctly.
ARP scanning is typically used together with the fixed ARP feature in small-scale networks.
ARP scanning automatically creates ARP entries for devices in an address range. The device performs ARP scanning in the following steps:
1. Sends ARP requests for each IP address in the address range.
2. Obtains their MAC addresses through received ARP replies.
3. Creates dynamic ARP entries.
Fixed ARP converts existing dynamic ARP entries (including those generated through ARP scanning) to static ARP entries. This feature prevents ARP entries from being modified by attackers. Static ARP entries can also be manually configured by the arp static command.
When you configure ARP scanning and fixed ARP, follow these restrictions and guidelines:
· IP addresses in existing ARP entries are not scanned.
· ARP scanning will take some time. To stop an ongoing scan, press Ctrl + C. Dynamic ARP entries are created based on ARP replies received before the scan is terminated.
· The arp fixup command is a one-time operation. You can use this command again to convert the dynamic ARP entries learned later to static.
· Due to the limit on the total number of static ARP entries, some dynamic ARP entries might fail the conversion.
· To delete a static ARP entry converted from a dynamic one, use the undo arp ip-address [ vpn-instance-name ] command. Use the reset arp all command to delete all ARP entries or the reset arp static command to delete all static ARP entries.
To configure ARP scanning and fixed ARP:
Step |
Command |
system-view |
3. Enable ARP scanning. |
arp scan [ start-ip-address to end-ip-address ] |
quit |
5. Enable fixed ARP. |
arp fixup |
Configure this feature on interfaces not connected with a gateway to prevent gateway spoofing attacks.
When such an interface receives an ARP packet, it checks whether the sender IP address in the packet is consistent with that of any protected gateway. If yes, it discards the packet. If not, it handles the packet correctly.
When you configure ARP gateway protection, follow these guidelines:
· You can enable ARP gateway protection for a maximum of eight gateways on an interface.
· Do not configure both the arp filter source and arp filter binding commands on an interface.
· If ARP gateway protection works with ARP detection, ARP snooping, and ARP fast-reply, ARP gateway protection applies first.
To configure ARP gateway protection:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 2 Ethernet interface and Layer 2 aggregate interface view. |
N/A |
3. Enable ARP gateway protection for the specified gateway. |
arp filter source ip-address |
By default, ARP gateway protection is disabled. |
As shown in Figure 7, Host B launches gateway spoofing attacks to Switch B. As a result, traffic that Switch B intends to send to Switch A is sent to Host B.
Configure Switch B to block such attacks.
# Configure ARP gateway protection on Switch B.
[SwitchB-GigabitEthernet3/0/1] arp filter source 10.1.1.1
[SwitchB-GigabitEthernet3/0/2] arp filter source 10.1.1.1
# Verify that GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2 discard the incoming ARP packets whose sender IP address is the IP address of the gateway.
The ARP filtering feature can prevent gateway spoofing and user spoofing attacks.
An interface enabled with this feature checks the sender IP and MAC addresses in a received ARP packet against permitted entries. If a match is found, the packet is handled correctly. If not, the packet is discarded.
When you configure ARP filtering, follow these guidelines:
· You can configure a maximum of eight permitted entries on an interface.
· If ARP filtering works with ARP detection, ARP snooping, and ARP fast-reply, ARP filtering applies first.
To configure ARP filtering:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 2 Ethernet interface or Layer 2 aggregate interface view. |
N/A |
3. Enable ARP filtering and configure a permitted entry. |
arp filter binding ip-address mac-address |
By default, ARP filtering is disabled. |
As shown in Figure 8, the IP and MAC addresses of Host A are 10.1.1.2 and 000f-e349-1233, respectively. The IP and MAC addresses of Host B are 10.1.1.3 and 000f-e349-1234, respectively.
Configure ARP filtering on GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2 of Switch B to permit ARP packets from only the two hosts.
# Configure ARP filtering on Switch B.
[SwitchB-GigabitEthernet3/0/1] arp filter binding 10.1.1.2 000f-e349-1233
[SwitchB-GigabitEthernet3/0/2] arp filter binding 10.1.1.3 000f-e349-1234
# Verify that GigabitEthernet 3/0/1 permits ARP packets from Host A and discards other ARP packets. # Verify that GigabitEthernet 3/0/2 permits ARP packets from Host B and discards other ARP packets.
