- 10-Security Configuration Guide
- 01-AAA configuration
- 02-Password control configuration
- 03-Public key management configuration
- 04-PKI configuration
- 05-IPsec configuration
- 06-SSH configuration
- 07-IP source guard configuration
- 08-ARP attack protection configuration
- 09-uRPF configuration
- 10-SSL configuration
- 11-Crypto engine configuration
- 12-FIPS configuration
- 13-Portal configuration
- 14-MACsec configuration
- 15-Attack detection and prevention configuration
- 16-Object group configuration
| 07-IP source guard configuration | 198.94 KB |
Configuring the IPv4SG feature
Enabling IPv4SG on an interface
Configuring a static IPv4SG binding
Configuring the IPv6SG feature
Enabling IPv6SG on an interface
Configuring a static IPv6SG binding
Displaying and maintaining IPSG
Static IPv4SG configuration example
Dynamic IPv4SG using DHCP snooping configuration example
Dynamic IPv4SG using DHCP relay configuration example
Static IPv6SG configuration example
Dynamic IPv6SG using DHCPv6 snooping configuration example
In this documentation, EB, EC1, EC2, FD, and FG cards refer to the cards suffixed with EB, EC1, EC2, FD, and FG, respectively.
Overview
IP source guard (IPSG) prevents spoofing attacks by using an IPSG binding table to match legitimate packets. It drops all packets that do not match the table.
The IPSG binding table can include the following bindings:
· IP-interface.
· MAC-interface.
· IP-MAC-interface.
· IP-VLAN-interface.
· MAC-VLAN-interface.
· IP-MAC-VLAN-interface.
IPSG bindings include static bindings that are configured manually and dynamic bindings that are generated based on information from other modules.
As shown in Figure 1, IPSG on the user access interface forwards only the packets that match one of the IPSG bindings.
Figure 1 Diagram for the IPSG feature
IPSG is a per-interface packet filter. Configuring the feature on one interface does not affect packet forwarding on another interface.
Static IPSG bindings
Static IPSG bindings are configured manually. They are suitable for scenarios where few hosts exist on a LAN and their IP addresses are manually configured. For example, you can configure a static IPSG binding on an interface that connects to a server. This binding allows the interface to receive packets only from the server.
Static IPSG bindings on an interface implements the following functions:
· Filter incoming IPv4 or IPv6 packets on the interface.
· Cooperate with ARP detection in IPv4 and ND detection in IPv6 for user validity checking.
For information about ARP detection, see "Configuring ARP attack protection."
Dynamic IPSG bindings
IPSG automatically obtains user information from other modules to generate dynamic bindings. The source modules include DHCP relay, DHCP snooping, DHCPv6 snooping, and DHCP server.
DHCP-based IPSG bindings are suitable for scenarios where hosts on a LAN obtain IP addresses through DHCP. IPSG is configured on the DHCP snooping device or the DHCP relay agent. It generates dynamic bindings based on the DHCP snooping entries or DHCP relay entries. IPSG allows only packets from the DHCP clients to pass through.
Dynamic IPv4SG
Dynamic bindings generated based on different source modules are for different usages:
Interface types |
Source modules |
Binding usage |
Layer 2 Ethernet port |
DHCP snooping |
Packet filtering. |
Layer 3 Ethernet interface/VLAN interface |
DHCP relay agent |
Packet filtering. |
DHCP server |
For cooperation with modules (such as the ARP detection module) to provide security services. |
For information about DHCP snooping, DHCP relay, and DHCP server, see Layer 3—IP Services Configuration Guide.
Dynamic IPv6SG
IPv6SG on an interface obtains information from DHCPv6 snooping entries to generate bindings for packet filtering.
For more information about DHCPv6 snooping, see Layer 3—IP Services Configuration Guide.
IPSG configuration task list
To configure IPv4SG, perform the following tasks:
Tasks at a glance |
(Required.) Enabling IPv4SG on an interface |
(Optional.) Configuring a static IPv4SG binding |
To configure IPv6SG, perform the following tasks:
Tasks at a glance |
(Required.) Enabling IPv6SG on an interface |
(Optional.) Configuring a static IPv6SG binding |
When an EB, EC2, or FD card is operating in standard ACL mode, the card does not support IP-MAC-interface binding entries or IP-MAC-VLAN-interface binding entries. For more information about the standard ACL mode, see ACL and QoS Configuration Guide.
When you enable IPSG on an interface, the static and dynamic IPSG are both enabled.
· Static IPv4SG uses static bindings configured by using the ip source binding command.
· Dynamic IPv4SG generates dynamic bindings from related source modules. IPv4SG uses the bindings to filter incoming IPv4 packets based on the matching criteria specified in the ip verify source command.
To implement dynamic IPv4SG, make sure the DHCP snooping or DHCP relay feature operates correctly on the network.
To enable the IPv4SG feature on an interface:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enter interface view. |
The following interface types are supported: Layer 2 Ethernet port, Layer 3 Ethernet interface, VLAN interface, Layer 3 aggregate interface. |
3. Enable the IPv4SG feature. |
ip verify source { ip-address | ip-address mac-address | mac-address } |
By default, the IPv4SG feature is disabled on an interface. If you configure this command on an interface multiple times, the most recent configuration takes effect. |
You can configure global static and interface-specific static IPv4SG bindings.
Global static bindings take effect on all interfaces.
Interface-specific static bindings take priority over global static bindings. An interface first uses the static bindings on the interface to match packets. If no match is found, the interface uses the global bindings.
Configuring a global static IPv4SG binding
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a global static IPv4SG binding. |
ip source binding ip-address ip-address mac-address mac-address |
No global static IPv4SG binding exists. |
Configuring a static IPv4SG binding on an interface
Step |
Command |
Remarks |
system-view |
N/A |
The following interface types are supported: Layer 2 Ethernet port, Layer 3 Ethernet interface, VLAN interface. |
3. Configure a static IPv4SG binding. |
ip source binding { ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ] |
By default, no static IPv4SG binding is configured on an interface. The vlan vlan-id option is supported only in Layer 2 Ethernet interface view. To configure a static IPv4SG binding for the ARP detection function, the vlan vlan-id option must be specified, and ARP detection must be enabled for the specified VLAN. You can configure the same static IPv4SG binding on different interfaces. |
An EB, EC2, or FD card does not support the following types of binding entries:
· MAC-interface.
· IP-MAC-interface.
Use the acl hardware-mode advanced command before you configure the IPv6SG feature.
To configure IPv6SG on an EC1, EF, or FG card, configure the acl hardware-mode ipv6 enable command first. For information about this command, see ACL and QoS Command Reference.
When you enable IPv6SG on an interface, the static and dynamic IPv6SG are both enabled.
· Static IPv6SG uses static bindings configured by using the ipv6 source binding command.
· Dynamic IPv6SG generates dynamic bindings from related source modules. IPv6SG uses the bindings to filter incoming IPv6 packets based on the matching criteria specified in the ipv6 verify source command.
To implement dynamic IPv6SG, make sure DHCPv6 snooping operates correctly on the network.
To enable the IPv6SG feature on an interface:
Step |
Command |
Remarks |
system-view |
N/A |
3. Enable the IPv6SG feature. |
ipv6 verify source { ip-address | ip-address mac-address | mac-address } |
By default, the IPv6SG feature is disabled on an interface. If you configure this command on an interface multiple times, the most recent configuration takes effect. |
You can configure global static and interface-specific static IPv6SG bindings.
In an IPv6SG binding, the MAC address cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address. The IPv6 address must be a unicast address and cannot be all 0s, all Fs, or a loopback address.
Configuring a global static IPv6SG binding
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a global static IPv6SG binding. |
ipv6 source binding ip-address ipv6-address mac-address mac-address |
No global static IPv6SG binding exists. |
Configuring a static IPv6SG binding on an interface
Step |
Command |
Remarks |
system-view |
N/A |
3. Configure a static IPv6SG binding. |
ipv6 source binding { ip-address ipv6-address | ip-address ipv6-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ] |
By default, no static IPv6SG binding is configured on an interface. The vlan vlan-id option is supported only in Layer 2 Ethernet interface view. To configure a static IPv6 binding for the ND detection function, the vlan vlan-id option must be specified, and ND detection must be enabled for the specified VLAN. You can configure the same static IPv6SG binding on different interfaces. |
Task |
Command |
Display IPv4SG bindings (in standalone mode). |
display ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcp-relay | dhcp-server | dhcp-snooping | dot1x ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ] |
Display IPv4SG bindings (in IRF mode). |
display ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcp-relay | dhcp-server | dhcp-snooping | dot1x ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ] |
Display IPv6SG bindings (in standalone mode). |
display ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcpv6-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ] |
Display IPv6SG bindings (in IRF mode). |
display ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcpv6-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ] |
IPSG configuration examples
By default, Ethernet, VLAN, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up. The examples assume that all these interfaces are already up.
Network requirements
As shown in Figure 2, all hosts use static IP addresses.
Configure static IPv4SG bindings on Switch A and Switch B to meet the following requirements:
· GigabitEthernet 3/0/2 of Switch A allows only IP packets from Host C to pass.
· GigabitEthernet 3/0/1 of Switch A allows only IP packets from Host A to pass.
· All interfaces of Switch B allow IP packets from Host A to pass.
· GigabitEthernet 3/0/1 of Switch B allows IP packets from Host B to pass.
Configuration procedure
1. Configure Switch A:
# Configure IP addresses for the interfaces. (Details not shown.)
# Enable IPv4SG on GigabitEthernet 3/0/2.
[SwitchA] interface GigabitEthernet 3/0/2
[SwitchA-GigabitEthernet3/0/2] ip verify source ip-address mac-address
# On GigabitEthernet 3/0/2, configure a static IPv4SG binding for Host C.
[SwitchA-GigabitEthernet3/0/2] ip source binding ip-address 192.168.0.3 mac-address 0001-0203-0405
[SwitchA-GigabitEthernet3/0/2] quit
# Enable IPv4SG on GigabitEthernet 3/0/1.
[SwitchA] interface GigabitEthernet 3/0/1
[SwitchA-GigabitEthernet3/0/1] ip verify source ip-address mac-address
# On GigabitEthernet 3/0/1, configure a static IPv4SG binding for Host A.
[SwitchA-GigabitEthernet3/0/1] ip source binding ip-address 192.168.0.1 mac-address 0001-0203-0406
[SwitchA-GigabitEthernet3/0/1] quit
2. Configure Switch B:
# Configure an IP address for each interface. (Details not shown.)
[SwitchB] interface GigabitEthernet 3/0/2
[SwitchB-GigabitEthernet3/0/2] ip verify source ip-address mac-address
[SwitchB-GigabitEthernet3/0/2] quit
# Configure a static IPv4SG binding for Host A.
[SwitchB] ip source binding ip-address 192.168.0.1 mac-address 0001-0203-0406
[SwitchB] interface GigabitEthernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] ip verify source ip-address mac-address
# On GigabitEthernet 3/0/1, configure a static IPv4SG binding for Host B.
[SwitchB-GigabitEthernet3/0/1] ip source binding mac-address 0001-0203-0407
[SwitchB-GigabitEthernet3/0/1] quit
# Verify that the static IPv4SG bindings are configured successfully on Switch A.
<SwitchA> display ip source binding static
Total entries found: 2
IP Address MAC Address Interface VLAN Type
192.168.0.1 0001-0203-0405 GE3/0/2 N/A Static
192.168.0.3 0001-0203-0406 GE3/0/1 N/A Static
# Verify that the static IPv4SG bindings are configured successfully on Switch B.
<SwitchB> display ip source binding static
192.168.0.1 0001-0203-0406 N/A N/A Static
N/A 0001-0203-0407 GE3/0/1 N/A Static
As shown in Figure 3, the host (the DHCP client) obtains an IP address from the DHCP server.
Enable DHCP snooping on the switch to record the IPv4 address and the MAC address of the host in a DHCP snooping entry.
Enable dynamic IPv4SG on GigabitEthernet 3/0/1 to filter received packets based on DHCP snooping entries. Only packets from the client that obtains an IP address from the DHCP server are allowed to pass.
1. Configure the DHCP server:
For information about DHCP server configuration, see Layer 3—IP Services Configuration Guide.
2. Configure the switch:
# Enable DHCP snooping.
<Switch> system-view
[Switch] dhcp snooping enable
# Configure GigabitEthernet 3/0/2 as a trusted interface.
[Switch] interface GigabitEthernet3/0/2
[Switch-GigabitEthernet3/0/2] dhcp snooping trust
[Switch-GigabitEthernet3/0/2] quit
# Enable IPv4SG on GigabitEthernet 3/0/1 and verify the source IP address and MAC address for dynamic IPSG.
[Switch] interface GigabitEthernet 3/0/1
[Switch-GigabitEthernet3/0/1] ip verify source ip-address mac-address
# Enable recording of client information in DHCP snooping entries on GigabitEthernet 3/0/1.
[Switch-GigabitEthernet3/0/1] dhcp snooping binding record
[Switch-GigabitEthernet3/0/1] quit
# Verify that a dynamic IPv4SG binding is generated based on a DHCP snooping entry.
[Switch] display ip source binding dhcp-snooping
Total entries found: 1
192.168.0.1 0001-0203-0406 GE3/0/1 1 DHCP snooping
As shown in Figure 4, DHCP relay is enabled on the switch. The host obtains an IP address from the DHCP server through the DHCP relay agent.
Enable dynamic IPv4SG on VLAN-interface 100 to filter received packets based on the DHCP relay entry generated on the switch.
1. Configure dynamic IPv4 source guard:
# Enable IPv4SG on VLAN-interface 100 to and verify the source IP address and MAC address for dynamic IPSG.
[Switch-Vlan-interface100] ip verify source ip-address mac-address
2. Configure the DHCP relay agent:
# Enable the DHCP service.
[Switch] dhcp enable
# Enable recording DHCP relay client entries.
[Switch] dhcp relay client-information record
# Configure VLAN-interface 100 to work in DHCP relay mode.
[Switch-Vlan-interface100] dhcp select relay
# Specify the IP address of the DHCP server.
[Switch-Vlan-interface100] dhcp relay server-address 10.1.1.1
# Verify that a dynamic IPv4SG binding is generated based on a DHCP relay entry.
[Switch] display ip source binding dhcp-relay
192.168.0.1 0001-0203-0406 Vlan100 100 DHCP relay
As shown in Figure 5, configure a static IPv6SG binding for GigabitEthernet 3/0/1 of the device to allow only IPv6 packets from the host to pass.
# Enable IPv6SG on GigabitEthernet 3/0/1.
[Switch-GigabitEthernet3/0/1] ipv6 verify source ip-address mac-address
# On GigabitEthernet 3/0/1, configure a static IPv6SG binding for the host.
[Switch-GigabitEthernet3/0/1] ipv6 source binding ip-address 2001::1 mac-address 0001-0202-0202
# Verify that the static IPv6SG binding is configured successfully on the switch.
[Switch] display ipv6 source binding static
IPv6 Address MAC Address Interface VLAN Type
2001::1 0001-0202-0202 GE3/0/1 N/A Static
As shown in Figure 6:
· Enable DHCPv6 snooping on the device to record the IPv6 address and the MAC address of the host in a DHCPv6 snooping entry.
· Enable dynamic IPv6SG on GigabitEthernet 3/0/1 to filter received packets based on DHCPv6 snooping entries. Only packets from a client that obtains an IP address from the DHCPv6 server are allowed to pass.
1. Configure DHCPv6 snooping:
# Enable DHCPv6 snooping globally.
[Switch] ipv6 dhcp snooping enable
# Configure the interface that connects to the DHCP server as a trusted interface.
[Switch] interface GigabitEthernet 3/0/2
[Switch-GigabitEthernet3/0/2] ipv6 dhcp snooping trust
2. Enable IPv6SG:
# Enable IPv6SG on GigabitEthernet 3/0/1 and verify the source IP address and MAC address for dynamic IPv6SG.
# Enable recording of client information in DHCPv6 snooping entries on GigabitEthernet 3/0/1.
[Switch-GigabitEthernet3/0/1] ipv6 dhcp snooping binding record
# Verify that a dynamic IPv6SG binding is generated based on a DHCPv6 snooping entry.
[Switch] display ipv6 source binding dhcpv6-snooping
2001::1 040a-0000-0001 GE3/0/1 1 DHCPv6 snooping
