08-IP Multicast Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18208-IP Multicast Command Reference
12-IPv6 Multicast VLAN Commands
12-IPv6 Multicast VLAN Commands 59.48 KB
IPv6 multicast VLAN configuration commands···························································································································· 1
display multicast-vlan ipv6············································································································································· 1
multicast-vlan ipv6···························································································································································· 2
multicast-vlan ipv6 entry-limit········································································································································· 2
subvlan (IPv6 multicast VLAN view)···························································································································· 3
display multicast-vlan ipv6 [ vlan-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan-id: Specifies an IPv6 multicast VLAN in the range of 1 to 4094. If this argument is not specified, information about all IPv6 multicast VLANs will be displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display multicast-vlan ipv6 to view information about the specified IPv6 multicast VLAN or all IPv6 multicast VLANs.
# View information about all IPv6 multicast VLANs.
<Sysname> display multicast-vlan ipv6
 Total 1 IPv6 multicast-vlan(s)
 IPv6 Multicast vlan 100
   subvlan list:
    vlan 2  4-6
Total number of IPv6 multicast VLANs.
subvlan list
List of sub-VLANs of the IPv6 multicast VLAN.
multicast-vlan ipv6
multicast-vlan ipv6 vlan-id
undo multicast-vlan ipv6 { all | vlan-id }
View
Default level
2: System level
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
all: Deletes all IPv6 multicast VLANs.
Use multicast-vlan ipv6 to configure the specified VLAN as an IPv6 multicast VLAN and enter IPv6 multicast VLAN view.
Use undo multicast-vlan ipv6 to remove the specified VLAN as an IPv6 multicast VLAN.
No VLAN is an IPv6 multicast VLAN by default.
The specified VLAN to be configured as an IPv6 multicast VLAN must exist.
The IPv6 multicast VLAN feature cannot be enabled on a device with IPv6 multicast routing enabled.
You need to enable MLD snooping only in the IPv6 multicast VLAN.
Related commands: mld-snooping enable and multicast ipv6 routing-enable.
# Enable MLD snooping in VLAN 100. Configure it as an IPv6 multicast VLAN and enter IPv6 multicast VLAN view.
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 100
[Sysname-vlan100] mld-snooping enable
[Sysname-vlan100] quit
[Sysname] multicast-vlan ipv6 100
[Sysname-ipv6-mvlan-100]
multicast-vlan ipv6 entry-limit limit
undo multicast-vlan ipv6 entry-limit
View
Default level
2: System level
limit: Specifies the maximum number of entries in the MLD snooping forwarding table of IPv6 multicast VLANs. The value range for this argument varies with the system operating modes. For more information, see Fundamentals Configuration Guide.
Use multicast-vlan ipv6 entry-limit to configure the maximum number of MLD snooping forwarding entries of IPv6 multicast VLANs.
Use undo multicast-vlan ipv6 entry-limit to restore the default.
The default upper limit depends on the system operating mode. For more information, see Fundamentals Configuration Guide.
Related commands: entry-limit.
# Configure the MLD snooping forwarding table of the IPv6 multicast VLANs to contain 512 entries at most.
[Sysname] multicast-vlan ipv6 entry-limit 512
subvlan vlan-list
undo subvlan { all | vlan-list }
View
Default level
2: System level
vlan-list: Specifies a VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The value range of a VLAN ID is 1 to 4094.
all: Deletes all the sub-VLANs of the current IPv6 multicast VLAN.
Use subvlan to configure sub-VLAN or sub-VLANs for the current IPv6 multicast VLAN.
Use undo subvlan to remove the specified sub-VLAN or sub-VLANs or all sub-VLANs from the current IPv6 multicast VLAN.
An IPv6 multicast VLAN has no sub-VLANs by default.
The VLANs to be configured as the sub-VLANs of the IPv6 multicast VLAN must exist and must not be IPv6 multicast VLANs or sub-VLANs of any other IPv6 multicast VLAN.
The number of sub-VLANs of the IPv6 multicast VLAN must not exceed 1024.
# Configure VLAN 10 through VLAN 15 as sub-VLANs of IPv6 multicast VLAN 100.
[Sysname-ipv6-mvlan-100] subvlan 10 to 15
