08-IP Multicast Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18208-IP Multicast Command Reference
00-Preface
00-Preface 120.73 KB
Preface
The H3C S9500E documentation set includes 14 command references, which describe the commands and command syntax options available for the H3C S9500E Series Routing Switches.
The IP Multicast Command Reference describes multicast configuration commands for the Layer 3 multicast protocols (such as IGMP, MLD, PIM, IPv6 PIM, MSDP, MBGP, and IPv6 MBGP) and the Layer 2 multicast protocols (such as IGMP snooping, MLD snooping, multicast VLAN, and IPv6 multicast VLAN).
This preface includes:
·     Audience
·     Conventions
·     About the H3C S9500E documentation set
·     Obtaining documentation
·     Technical support
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators working with the S9500E series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
Represents a security product, such as a firewall, UTM, multiservice security gateway, or load-balancing device.
Represents a security card, such as a firewall, load-balancing, NetStream, SSL VPN, IPS, or ACG card.
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S9500E documentation set includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
Card datasheets
Describe card specifications, features, and standards.
Hardware specifications and installation
Regulatory compliance and safety information
Provides regulatory information and the safety instructions that must be followed during installation.
Installation guide
Provides a complete guide to hardware installation and hardware specifications.
H3C Pluggable SFP [SFP+][XFP] Transceiver Modules Installation Guide
Guides you through installing SFP/SFP+/XFP transceiver modules.
Adjustable Slider Rail Installation Guide
Guides you through installing adjustable slider rails to a rack.
H3C Transceiver Modules User Guide
Describes transceiver modules available for the H3C high-end network products, their external views, and specifications.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
System log messages
Explains the system log messages.
Trap messages
Explains the trap messages.
MIB Companion
Describes the MIBs for the software release.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
Access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download]—Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
We appreciate your comments.
