08-IP Multicast Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18208-IP Multicast Command Reference
10-MLD Snooping Commands
10-MLD Snooping Commands 181.73 KB
display mld-snooping group
Standalone mode:
display mld-snooping group [ vlan vlan-id ] [ slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display mld-snooping group [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Specifies a VLAN. The value range for the vlan-id argument is 1 to 4094.
slot slot-number: Specifies a card by its slot number. If no slot is specified, the command displays the MLD snooping group information on the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument refers to the ID of the IRF member device, and the slot-number argument refers to the number of the slot where the card resides. If this option is not specified, the command displays the information of MLD snooping groups on all MPUs in the IRF member device. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode.)
verbose: Displays detailed MLD snooping group information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display mld-snooping group to display MLD snooping group information, including both dynamic and static MLD snooping group entries. If you do not specify a VLAN, this command displays MLD snooping group information in all VLANs.
# Display detailed MLD snooping group information in VLAN 4000 on the card in slot 9 on IRF member device 1.
<Sysname> display mld-snooping group vlan 4000 chassis 1 slot 9 verbose
  Total 1 IP Group(s).
  Total 1 IP Source(s).
  Total 1 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):4000.
    Router port unit board: Mask(0x0000000000000000)
    Router port(s):total 0 port(s).
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:FF1E::101
        (::, FF1E::101):
          Attribute:    Host Port
          Host port unit board: Mask(0x0000000000000000)
          Host port(s):total 1 port(s).
            GE1/9/0/48                (D) ( 00:03:35 )
    MAC group(s):
        MAC group address:3333-0000-0101
            GE1/9/0/48
Total number of IPv6 multicast groups.
Total number of IPv6 multicast sources.
Total number of MAC multicast groups.
Port flags:
·     D—A dynamic port.
·     S—A static port.
·     C—A port copied from a (*, G) entry to an (S, G) entry.
·     P—A port that IPv6 PIM snooping adds.
Sub-VLAN flags:
·     R—Real egress sub-VLAN under the current entry.
·     C—Sub-VLAN copied from a (*, G) entry to an (S, G) entry.
Mask indicating a board with a router port residing on it.
Router port(s)
Number of router ports.
( 00:03:35 )
Remaining time of the aging timer for the dynamic member port or router port:
·     In standalone mode, to display the remaining life of a non-aggregation port that does not belong to the MPU, you must specify the number of the slot where the corresponding card resides by using slot slot-number. This is not required for an aggregation port.
·     In IRF mode, to display the remaining life of a non-aggregation port that does not belong to the MPU, you must specify the ID of the IRF member device and the slot number of the card with chassis chassis-number slot slot-number. For an aggregation port, you do not need to do this.
IP group address
Address of IPv6 multicast group.
(::, FF1E::101)
(S, G) entry. If the IPv6 multicast source is not specified, the field in the S position displays the double colon (::).
MAC group address
Address of MAC multicast group.
Attribute
Attribute of IPv6 multicast group.
Mask indicating a board with a member port residing on it.
Host port(s)
Number of member ports.
display mld-snooping host
Standalone mode:
display mld-snooping host vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display mld-snooping host vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group ipv6-group-address: Specifies an IPv6 multicast group. The value range for the ipv6-group-address argument is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where "x" and "y" represent any hexadecimal numbers from 0 to F.
source ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If this option is specified, this command displays information about the hosts tracked by MLD snooping for the specified IPv6 multicast source. If this option is not specified, this commands displays information about the host tracked by MLD snooping for all IPv6 multicast sources.
slot slot-number: Specifies a card by its slot number. If no slot is specified, the command displays the MLD snooping host information on the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument refers to the ID of the IRF member device, and the slot-number argument refers to the number of the slot where the card resides. If this option is not specified, this command displays information about the MLD snooping tracked hosts on all MPUs in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode.)
Use display mld-snooping host to display information about the hosts tracked by MLD snooping.
# Display information about the hosts tracked by MLD snooping in multicast group FF1E::101 in VLAN 2.
<Sysname> display mld-snooping host vlan 2 group ff1e::101
VLAN(ID) : 2
  (::, FF1E::101)
    Port : GigabitEthernet3/0/1
      Host                                    Uptime          Expires
      1::1                                    00:02:20        00:00:40
      2::2                                    00:02:21        00:00:39
    Port : GigabitEthernet3/0/2
      Host                                    Uptime          Expires
      3::3                                    00:02:20        00:00:40
(::, FF1E::101)
Port
Member port.
Host
Host IPv6 address.
Uptime
Host running duration.
Expires
Host expiration time. If this host has expired, this field displays timeout.
display mld-snooping statistics
display mld-snooping statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display mld-snooping statistics to display statistics for the MLD messages learned through MLD snooping.
# Display statistics for the MLD messages learned through MLD snooping.
<Sysname> display mld-snooping statistics
  Received MLD general queries:0.
  Received MLDv1 specific queries:0.
  Received MLDv1 reports:0.
  Received MLD dones:0.
  Sent     MLDv1 specific queries:0.
  Received MLDv2 reports:0.
  Received MLDv2 reports with right and wrong records:0.
  Received MLDv2 specific queries:0.
  Received MLDv2 specific sg queries:0.
  Sent     MLDv2 specific queries:0.
  Sent     MLDv2 specific sg queries:0.
  Received error MLD messages:0.
general queries
General query messages.
specific queries
Multicast-address-specific query messages.
reports
Report messages.
dones
Done messages.
Reports containing correct and incorrect records.
specific sg queries
Multicast-address-and-source-specific queries.
entry-limit (MLD-snooping view)
entry-limit limit
undo entry-limit
View
MLD-snooping view
Default level
2: System level
limit: Specifies the maximum number of MLD snooping forwarding entries, in the range of 0 to 2000.
Use entry-limit to set the global maximum number of MLD snooping forwarding entries.
Use undo entry-limit to restore the default.
By default, the upper limit is 2000.
Related commands: multicast-vlan ipv6 entry-limit.
# Set the global maximum number of MLD snooping forwarding entries to 512.
[Sysname] mld-snooping
[Sysname-mld-snooping] entry-limit 512
fast-leave (MLD-snooping view)
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
View
MLD-snooping view
Default level
2: System level
vlan vlan-list: Specifies one or multiple VLANs. You can provide up to 10 VLAN lists. For each list, you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The value range of a VLAN ID is 1 to 4094. If you do not specify any VLAN, the command applies to all VLANs. If you specify one or multiple VLANs, the command applies to the specified VLANs.
Use fast-leave to enable MLD snooping fast-leave processing globally. With this function enabled, when the switch receives an MLD done message on a port, it directly removes that port from the forwarding table entry for a specific group.
Use undo fast-leave to disable MLD snooping fast-leave processing globally.
By default, MLD snooping fast-leave processing is disabled.
This command is also effective on VLANs with MLD enabled on their VLAN interfaces.
Related commands: mld-snooping fast-leave.
# Enable MLD snooping fast-leave processing for VLAN 2.
[Sysname-mld-snooping] fast-leave vlan 2
group-policy (MLD-snooping view)
group-policy acl6-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
View
MLD-snooping view
Default level
2: System level
Acl6-number: Specifies a basic or advanced IPv6 ACL number in the range of 2000 to 3999. A host can join only the IPv6 multicast groups that match the permit statement in the specified ACL. The source address or address range specified in the advanced IPv6 ACL rule matches the IPv6 multicast source address or addresses specified in MLDv2 reports, rather than the source address in the IPv6 packets. The system assumes that an MLDv1 report or an MLDv2 IS_EX or TO_EX report that does not carry an IPv6 multicast source address carries an IPv6 multicast source address of 0::0.
vlan vlan-list: Specifies one or multiple VLANs. You can provide up to 10 VLAN lists. For each list, you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The value range of a VLAN ID is 1 to 4094. If you do not specify any VLAN, the command applies to all VLANs. If you specify one or multiple VLANs, the command applies to the specified VLANs only.
Use group-policy to configure a global IPv6 multicast group filter to control the IPv6 multicast groups that a host can join.
Use undo group-policy to remove the configured global IPv6 multicast group filter.
By default, no IPv6 multicast group filter is configured globally, and a host can join any valid IPv6 multicast group.
If the specified IPv6 ACL does not exist or the ACL rule is null, all IPv6 multicast groups will be filtered out.
You can configure different IPv6 ACL rules for each port in different VLANs. For a given VLAN, a newly configured IPv6 ACL rule will override the existing one.
Related commands: mld-snooping group-policy.
# Apply ACL 2000 as an IPv6 multicast group filter so that hosts in VLAN 2 can join FF03::101 only.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source ff03::101 16
[Sysname-acl6-basic-2000] quit
[Sysname-mld-snooping] group-policy 2000 vlan 2
host-aging-time (MLD-snooping view)
host-aging-time interval
undo host-aging-time
View
MLD-snooping view
Default level
2: System level
interval: Specifies a dynamic member port aging time in seconds, in the range of 200 to 1000.
Use host-aging-time to set the global aging timer for dynamic member ports.
Use undo host-aging-time to restore the default.
By default, the aging timer of a dynamic member port is 260 seconds.
Related commands: mld-snooping host-aging-time.
# Set the global aging timer for dynamic member ports to 300 seconds.
[Sysname-mld-snooping] host-aging-time 300
host-tracking (MLD-snooping view)
host-tracking
undo host-tracking
View
MLD-snooping view
Default level
2: System level
None
Use host-tracking to enable the MLD snooping host tracking function globally.
Use undo host-tracking to disable the MLD snooping host tracking function globally.
By default, this function is disabled.
Related commands: display mld-snooping host and mld-snooping host-tracking.
# Enable the MLD snooping host tracking function globally.
[Sysname-mld-snooping] host-tracking
last-listener-query-interval (MLD-snooping view)
undo last-listener-query-interval
View
MLD-snooping view
Default level
2: System level
interval: Specifies an MLD last listener query interval (length of time that the device waits between sending MLD multicast-address-specific queries) in the range of 1 to 5 seconds.
Use last-listener-query-interval to set the global MLD last-listener query interval.
Use undo last-listener-query-interval to restore the default.
By default, the global MLD last-listener query interval is 1 second.
Related commands: mld-snooping last-listener-query-interval.
# Set the global MLD last-listener query interval to 3 seconds.
[Sysname-mld-snooping] last-listener-query-interval 3
max-response-time (MLD-snooping view)
max-response-time interval
undo max-response-time
View
MLD-snooping view
Default level
2: System level
interval: Specifies the maximum response time for MLD general queries, in the range of 1 to 25 seconds.
Use max-response-time to set the global maximum response time for MLD general queries.
Use undo max-response-time to restore the default.
By default, the global maximum response time for MLD general queries is 10 seconds.
Related commands: mld-snooping max-response-time and mld-snooping query-interval.
# Set the global maximum response time for MLD general queries to 5 seconds.
[Sysname-mld-snooping] max-response-time 5
mld-snooping
mld-snooping
undo mld-snooping
View
Default level
2: System level
None
Use mld-snooping to enable MLD snooping globally and enter MLD-snooping view.
Use undo mld-snooping to disable MLD snooping globally.
By default, MLD snooping is disabled.
Related commands: mld-snooping enable.
# Enable MLD snooping globally and enter MLD-snooping view.
mld-snooping done source-ip
mld-snooping done source-ip { ipv6-address | current-interface }
undo mld-snooping done source-ip
View
VLAN view
Default level
2: System level
ipv6-address: Specifies a source IPv6 address for the MLD done messages sent by the MLD snooping proxy, which can be any legal IPv6 link-local address.
current-interface: Specifies the IPv6 link-local address of the current VLAN interface as the source address of MLD done messages sent by the MLD snooping proxy. If no IPv6 address has been assigned to the current interface, the default IPv6 address FE80::02FF:FFFF:FE00:0001 is used.
Use mld-snooping done source-ip to configure the source IPv6 address of the MLD done messages sent by the MLD snooping proxy.
Use undo mld-snooping done source-ip to restore the default.
By default, the source IPv6 address of the MLD done messages sent by the MLD snooping proxy is FE80::02FF:FFFF:FE00:0001.
Before you configure this command in a VLAN, enable MLD snooping for the VLAN.
The source IPv6 address configured in the mld-snooping done source-ip command also applies when the simulated host sends MLD done messages.
# Enable MLD snooping in VLAN 2 and configure the source IPv6 address of MLD done messages sent by the MLD snooping proxy in VLAN 2 to FE80:0:0:1::1.
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] mld-snooping done source-ip fe80:0:0:1::1
mld-snooping drop-unknown
undo mld-snooping drop-unknown
View
VLAN view
Default level
2: System level
None
Use mld-snooping drop-unknown to enable dropping unknown IPv6 multicast data in the current VLAN.
Use undo mld-snooping drop-unknown to disable dropping unknown IPv6 multicast data in the current VLAN.
By default, this function is disabled, unknown IPv6 multicast data is flooded in the VLAN.
This command takes effect only if MLD snooping is enabled for the VLAN.
After you enable dropping unknown IPv6 multicast data, the switch does not drop the unknown IPv6 multicast data with the multicast MAC address of 3333-0000-00xx or 3333-FFxx-xxxx (where "x" represents any hexadecimal numbers from 0 to F). Instead, the device floods the IPv6 multicast data in the VLANs to which they belong.
# Enable MLD snooping and the function for dropping unknown IPv6 multicast data in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping drop-unknown
mld-snooping enable
mld-snooping enable
undo mld-snooping enable
View
VLAN view
Default level
2: System level
None
Use mld-snooping enable to enable MLD snooping in the current VLAN.
Use undo mld-snooping enable to disable MLD snooping in the current VLAN.
By default, MLD snooping is disabled in a VLAN.
MLD snooping must be enabled globally before it can be enabled in a VLAN
Related commands: mld-snooping.
# Enable MLD snooping in VLAN 2.
[Sysname] vlan 2
undo mld-snooping fast-leave [ vlan vlan-list ]
View
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
Default level
2: System level
Use mld-snooping fast-leave to enable MLD snooping fast-leave processing on a port. With this function enabled, when the port receives an MLD done message, the switch directly removes the port from the forwarding table entry for a specific group.
Use undo mld-snooping fast-leave to disable MLD snooping fast-leave processing on a port.
If you do not specify any VLAN when using this command in Layer 2 Ethernet interface view or Layer 2 aggregate interface view, the command takes effect on all VLANs to which the interface belongs. If you specify one or multiple VLANs, the command takes effect on the specified VLANs to which the interface belongs.
If you do not specify any VLAN when using this command in port group view, the command takes effect on all the ports in this group. If you specify one or multiple VLANs, the command takes effect only on those ports in this group that belong to the specified VLANs.
Related commands: fast-leave.
# Enable MLD snooping fast-leave processing on GigabitEthernet 3/0/1 in VLAN 2.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] mld-snooping fast-leave vlan 2
mld-snooping general-query source-ip
mld-snooping general-query source-ip { ipv6-address | current-interface }
undo mld-snooping general-query source-ip
View
VLAN view
Default level
2: System level
ipv6-address: Specifies the source IPv6 address of MLD general queries, which can be any legal IPv6 link-local address.
current-interface: Sets the source IPv6 link-local address of MLD general queries to the IPv6 address of the current VLAN interface. If the current VLAN interface does not have an IPv6 address, the default IPv6 address FE80::02FF:FFFF:FE00:0001 will be used as the source IPv6 address of MLD general queries.
Use mld-snooping general-query source-ip to configure the source IPv6 address of MLD general queries.
Use undo mld-snooping general-query source-ip to restore the default.
By default, the source IPv6 address of MLD general queries is FE80::02FF:FFFF:FE00:0001.
# In VLAN 2, enable MLD snooping and specify FE80:0:0:1::1 as the source IPv6 address of MLD general queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping general-query source-ip fe80:0:0:1::1
mld-snooping group-limit
undo mld-snooping group-limit [ vlan vlan-list ]
View
Default level
2: System level
limit: Specifies the maximum number of IPv6 multicast groups that a port can join, in the range of 1 to 1024.
Use mld-snooping group-limit to set the maximum number of IPv6 multicast groups that a port can join.
Use undo mld-snooping group-limit to restore the default.
By default, the upper limit is 1024.
For a switch that supports both MLD snooping and MLD, you can also use the mld group-limit command to limit the number of IPv6 multicast groups that an interface can join. However, if you configure the limit both on a VLAN and on a VLAN interface of this VLAN by using these two commands, inconsistencies might exist between Layer 2 and Layer 3 table entries. Therefore, H3C recommends that you configure the limit only on the VLAN interface.
Related commands: mld group-limit.
# Configure to allow GigabitEthernet 3/0/1 in VLAN 2 to join up to 10 IPv6 multicast groups.
[Sysname-GigabitEthernet3/0/1] mld-snooping group-limit 10 vlan 2
mld-snooping group-policy acl6-number [ vlan vlan-list ]
undo mld-snooping group-policy [ vlan vlan-list ]
View
Default level
2: System level
acl6-number: Specifies a basic or advanced IPv6 ACL number in the range of 2000 to 3999. A host can join only the IPv6 multicast groups that match the permit statement in the specified ACL. The IPv6 source address or address range specified in the advanced IPv6 ACL rule is the IPv6 multicast source address or addresses specified in MLDv2 reports, rather than the source address in the IPv6 packets. The system assumes that an MLDv1 report or an MLDv2 IS_EX or TO_EX report that does not carry an IPv6 multicast source address carries an IPv6 multicast source address of 0::0.
Use mld-snooping group-policy to configure an IPv6 multicast group filter on a port to control the multicast groups that the port can join.
Use undo mld-snooping group-policy to remove the configured IPv6 multicast group filter on a port.
By default, no IPv6 multicast group filter is configured on a port and a host can join any valid IPv6 multicast group.
If the specified ACL does not exist or the ACL rule is null, all IPv6 multicast groups will be filtered out.
Related commands: group-policy.
# Apply ACL 2000 as an IPv6 multicast group filter so that hosts on GigabitEthernet 3/0/1 in VLAN 2 can join FF03::101 only.
[Sysname-GigabitEthernet3/0/1] mld-snooping group-policy 2000 vlan 2
mld-snooping host-aging-time interval
undo mld-snooping host-aging-time
View
VLAN view
Default level
2: System level
interval: Specifies a dynamic member port aging timer in seconds, in the range of 200 to 1000.
Use mld-snooping host-aging-time to set the aging timer for the dynamic member ports in a VLAN.
Use undo mld-snooping host-aging-time to restore the default.
By default, the dynamic member port aging timer is 260 seconds.
Related commands: host-aging-time and mld-snooping enable.
# Enable MLD snooping and set the aging timer for the dynamic member ports in VLAN 2 to 300 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-aging-time 300
mld-snooping host-join
undo mld-snooping host-join ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
View
Default level
2: System level
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where "x" and "y" represent any hexadecimal numbers from 0 to F.
ipv6-source-address: Specifies an IPv6 multicast source address.
Use mld-snooping host-join to configure a port as a simulated member host for the specified IPv6 multicast group or source and group.
Use undo mld-snooping host-join to remove a simulated member host.
By default, no ports are configured as static member ports for any IPv6 multicast group or source and group.
The version of MLD on the simulated host is consistent with the version of MLD snooping running on the VLAN.
This command is also effective on VLANs with MLD enabled on their VLAN interfaces. The version of MLD on the simulated host is consistent with the version of MLD running on the VLAN interfaces.
The source-ip ipv6-source-address option in the command is meaningful only for MLDv2 snooping. If MLDv1 snooping is running, the source-ip ipv6-source-address option does not take effect although you can include source-ip ipv6-source-address in the command.
In Layer 2 Ethernet interface view or Layer 2 aggregate interface view, this feature takes effect only if the interface belongs to the specified VLAN. In port group view, this feature takes effect only on those ports in this port group that belong to the specified VLAN.
# Configure GigabitEthernet 3/0/1 in VLAN 2 to join (2002::22, FF3E::101) as a simulated host.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping version 2
[Sysname-vlan2] quit
[Sysname-GigabitEthernet3/0/1] mld-snooping host-join ff3e::101 source-ip 2002::22 vlan 2
undo mld-snooping host-tracking
View
VLAN view
Default level
2: System level
None
Use mld-snooping host-tracking to enable the MLD snooping host tracking function in a VLAN.
Use undo mld-snooping host-tracking to disable the MLD snooping host tracking function in a VLAN.
Before you configure this command, enable MLD snooping for the VLAN first.
Related commands: display mld-snooping host, host-tracking, and mld-snooping enable.
# Enable MLD snooping and the MLD snooping host tracking function for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-tracking
undo mld-snooping last-listener-query-interval
View
VLAN view
Default level
2: System level
Use mld-snooping last-listener-query-interval to set the MLD last-listener query interval in the VLAN.
Use undo mld-snooping last-listener-query-interval to restore the default.
By default, the MLD last listener query interval is 1 second.
Related commands: last-listener-query-interval and mld-snooping enable.
# Enable MLD snooping and set the MLD last-listener query interval to 3 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping last-listener-query-interval 3
mld-snooping max-response-time interval
undo mld-snooping max-response-time
View
VLAN view
Default level
2: System level
interval: Specifies the maximum response time for MLD general queries in seconds, in the range of 1 to 25.
Use mld-snooping max-response-time to set the maximum response time for MLD general queries in the VLAN.
Use undo mld-snooping max-response-time to restore the default.
By default, the maximum response time for MLD general queries is 10 seconds.
Related commands: max-response-time, mld-snooping enable, and mld-snooping query-interval.
# Enable MLD snooping and set the maximum response time for MLD general queries to 5 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping max-response-time 5
mld-snooping overflow-replace
undo mld-snooping overflow-replace [ vlan vlan-list ]
View
Default level
2: System level
Use mld-snooping overflow-replace to enable the IPv6 multicast group replacement function on a port.
Use undo mld-snooping overflow-replace to disable the IPv6 multicast group replacement function on a port.
By default, the IPv6 multicast group replacement function is disabled.
Related commands: overflow-replace.
# Enable the IPv6 multicast group replacement function on GigabitEthernet 3/0/1 in VLAN 2.
[Sysname-GigabitEthernet3/0/1] mld-snooping overflow-replace vlan 2
mld-snooping proxying enable
undo mld-snooping proxying enable
View
VLAN view
Default level
2: System level
None
Use mld-snooping proxying enable to enable the MLD snooping proxying function in a VLAN.
Use undo mld-snooping proxying enable to disable the MLD snooping proxying function in a VLAN.
By default, MLD snooping proxying is disabled in all VLANs.
# Enable MLD snooping and then MLD snooping proxying in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping proxying enable
mld-snooping querier
undo mld-snooping querier
View
VLAN view
Default level
2: System level
None
Use mld-snooping querier to enable the MLD snooping querier function.
Use undo mld-snooping querier to disable the MLD snooping querier function.
By default, the MLD snooping querier function is disabled.
This command takes effect only if MLD snooping is enabled for the VLAN, and it does not take effect in a sub-VLAN of an IPv6 multicast VLAN.
Related commands: mld-snooping enable and subvlan.
# Enable MLD snooping and the MLD snooping querier function in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier
undo mld-snooping query-interval
View
VLAN view
Default level
2: System level
interval: Specifies an MLD query interval (length of time that the device waits between sending MLD general queries) in the range of 2 to 300 seconds.
Use mld-snooping query-interval to set the MLD query interval.
Use undo mld-snooping query-interval to restore the default.
By default, the MLD query interval is 125 seconds.
Related commands: max-response-time, mld-snooping enable, mld-snooping max-response-time, and mld-snooping querier.
# Enable MLD snooping and set the MLD query interval to 20 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping query-interval 20
mld-snooping report source-ip
mld-snooping report source-ip { ipv6-address | current-interface }
undo mld-snooping report source-ip
View
VLAN view
Default level
2: System level
ipv6-address: Specifies a source IPv6 address for the MLD reports sent by the MLD snooping proxy, which can be any legal IPv6 link-local address.
current-interface: Specifies the IPv6 link-local address of the current VLAN interface as the source address of MLD reports sent by the MLD snooping proxy. If no IPv6 address has been assigned to the current interface, the default IPv6 address FE80::02FF:FFFF:FE00:0001 is used.
Use mld-snooping report source-ip to configure the source IPv6 address of the MLD reports sent by the MLD snooping proxy.
Use undo mld-snooping report source-ip to restore the default.
By default, the source IPv6 address of the MLD reports sent by the MLD snooping proxy is FE80::02FF:FFFF:FE00:0001.
The source IPv6 address configured in the mld-snooping report source-ip command also applies when the simulated host sends MLD reports.
# Enable MLD snooping in VLAN 2 and configure the source IPv6 address of MLD reports sent by the MLD snooping proxy in VLAN 2 to FE80:0:0:1::1.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping report source-ip fe80:0:0:1::1
mld-snooping router-aging-time
mld-snooping router-aging-time interval
undo mld-snooping router-aging-time
View
VLAN view
Default level
2: System level
interval: Specifies a dynamic router port aging timer in seconds, in the range of 1 to 1000.
Use mld-snooping router-aging-time to set the aging timer for the dynamic router ports in a VLAN.
Use undo mld-snooping router-aging-time to restore the default.
By default, the dynamic router port aging timer is 260 seconds.
Related commands: mld-snooping enable and router-aging-time.
# Enable MLD snooping and set the aging timer for the dynamic router ports in VLAN 2 to 100 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping router-aging-time 100
mld-snooping router-port-deny
undo mld-snooping router-port-deny [ vlan vlan-list ]
View
Default level
2: System level
Use mld-snooping router-port-deny to disable a port from becoming a dynamic router port.
Use undo mld-snooping router-port-deny to restore the default.
By default, a port can become a dynamic router port.
# Disable GigabitEthernet 3/0/1 from becoming a dynamic router port in VLAN 2.
[Sysname-GigabitEthernet3/0/1] mld-snooping router-port-deny vlan 2
mld-snooping special-query source-ip
mld-snooping special-query source-ip { ipv6-address | current-interface }
undo mld-snooping special-query source-ip
View
VLAN view
Default level
2: System level
ipv6-address: Specifies an IPv6 link-local address as the source IPv6 address of MLD multicast-address-specific queries.
current-interface: Specifies the source IPv6 link-local address of the VLAN interface of the current VLAN as the source IPv6 address of MLD multicast-address-specific queries. If the current VLAN interface does not have an IPv6 address, the default IPv6 address FE80::02FF:FFFF:FE00:0001 will be used as the source IPv6 address of MLD multicast-address-specific queries.
Use mld-snooping special-query source-ip to configure the source IPv6 address of MLD multicast-address-specific queries.
Use undo mld-snooping special-query source-ip to restore the default.
By default, the source IPv6 address of MLD multicast-address-specific queries is FE80::02FF:FFFF:FE00:0001.
# In VLAN 2, enable MLD snooping and specify FE80:0:0:1::1 as the source IPv6 address of MLD multicast-address-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping special-query source-ip fe80:0:0:1::1
mld-snooping static-group
undo mld-snooping static-group ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
View
Default level
2: System level
ipv6-source-address: Specifies an IPv6 source address.
Use mld-snooping static-group to configure a port as a static member port for an IPv6 multicast group or IPv6 multicast source and group.
Use undo mld-snooping static-group to restore the default.
By default, no ports are static member ports.
# Configure GigabitEthernet 3/0/1 in VLAN 2 as a static member port for the IPv6 multicast source and group (2002::22, FF3E::101).
[Sysname] vlan 2
[Sysname-GigabitEthernet3/0/1] mld-snooping static-group ff3e::101 source-ip 2002::22 vlan 2
mld-snooping static-router-port
undo mld-snooping static-router-port vlan vlan-id
View
Default level
2: System level
Use mld-snooping static-router-port to configure a port as a static router port.
Use undo mld-snooping static-router-port to restore the default.
By default, no ports are static router ports.
This command does not take effect in a sub-VLAN of an IPv6 multicast VLAN.
Related commands: subvlan.
# Enable the static router port function on GigabitEthernet 3/0/1 in VLAN 2.
[Sysname-GigabitEthernet3/0/1] mld-snooping static-router-port vlan 2
undo mld-snooping version
View
VLAN view
Default level
2: System level
version-number: Specifies an MLD snooping version, 1 or 2.
Use mld-snooping version to specify the MLD snooping version.
Use undo mld-snooping version to restore the default.
By default, the MLDv1 snooping is used.
# Enable MLD snooping in VLAN 2, and specify the MLD snooping version as MLDv2 snooping.
[Sysname] vlan 2
overflow-replace (MLD-snooping view)
undo overflow-replace [ vlan vlan-list ]
View
MLD-snooping view
Default level
2: System level
Use overflow-replace to enable the IPv6 multicast group replacement function globally.
Use undo overflow-replace to disable the IPv6 multicast group replacement function globally.
By default, the IPv6 multicast group replacement function is disabled globally.
Related commands: mld-snooping overflow-replace.
# Enable the IPv6 multicast group replacement function globally in VLAN 2.
[Sysname-mld-snooping] overflow-replace vlan 2
report-aggregation (MLD-snooping view)
report-aggregation
undo report-aggregation
View
MLD-snooping view
Default level
2: System level
None
Use report-aggregation to enable MLD report suppression.
Use undo report-aggregation to disable MLD report suppression.
By default, MLD report suppression is enabled.
# Disable MLD report suppression.
[Sysname-mld-snooping] undo report-aggregation
reset mld-snooping group
reset mld-snooping group { ipv6-group-address | all } [ vlan vlan-id ]
View
Default level
2: System level
all: Specifies all IPv6 multicast groups.
Use reset mld-snooping group to remove the dynamic group entries of an MLD snooping group or all MLD snooping groups.
This command cannot remove the static group entries of MLD snooping groups.
# Remove the dynamic group entries of all MLD snooping groups.
<Sysname> reset mld-snooping group all
reset mld-snooping statistics
View
Default level
2: System level
None
Use reset mld-snooping statistics to clear statistics for the MLD messages learned through MLD snooping.
# Clear statistics for all MLD messages learned through MLD snooping.
<Sysname> reset mld-snooping statistics
router-aging-time (MLD-snooping view)
undo router-aging-time
View
MLD-snooping view
Default level
2: System level
Use router-aging-time to set the aging timer for dynamic router ports globally.
Use undo router-aging-time to restore the default.
Related commands: mld-snooping router-aging-time.
# Set the aging timer for dynamic router ports globally to 100 seconds.
[Sysname-mld-snooping] router-aging-time 100
