10-Security Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71010-Security Command Reference
04-SSH commands
04-SSH commands 209.97 KB
SSH commands
SSH server configuration commands
display ssh server
Use display ssh server on an SSH server to display the SSH server status or sessions.
session: Displays the SSH server sessions.
status: Displays the SSH server status.
# Display the SSH server status.
<Sysname> display ssh server status
 SSH server: Disable
 SSH version : 1.99
 SSH authentication-timeout : 60 second(s)
 SSH server key generating interval : 0 hour(s)
 SSH authentication retries : 3 time(s)
 SFTP server: Disable
 SFTP server Idle-Timeout: 10 minute(s)
SSH server
Whether the SSH server function is enabled.
SSH version
SSH protocol version.
When the SSH supports SSH1, the protocol version is 1.99. Otherwise, the protocol version is 2.
Authentication timeout timer.
SSH server key pair update interval.
Maximum number of authentication attempts for SSH users.
SFTP server
Whether the SFTP server function is enabled.
SFTP connection idle timeout timer.
# Display the SSH server sessions.
<Sysname> display ssh server session
UserPid   SessID Ver   Encrypt    State          Retries  Serv     Username
 184       0     2.0   aes128-cbc Established    1        Stelnet  abc@123
UserPid
User process ID.
SessID
Session ID.
Ver
Protocol version of the SSH server.
Encrypt
Encryption algorithm used on the SSH server.
Session state:
·       Init—Initialization.
·       Ver-exchange—Version negotiation.
·       Keys-exchange—Keys exchange.
·       Auth-request—Authentication request.
·       Serv-request—Session service request.
·       Established—The session is established.
·       Disconnected—The session is disconnected.
Retries
Number of authentication failures.
Serv
Service type, including SCP, SFTP, and Stelnet.
Username
Name of a user for logging in to the server.
display ssh user-information
Use display ssh user-information to display information about SSH users on an SSH server.
username: Specifies an SSH username, a case-sensitive string of 1 to 80 characters. If no SSH user is specified, this command displays information about all SSH users.
This command only displays information about SSH users configured through the ssh user command on the SSH server.
# Display information about all SSH users.
<Sysname> display ssh user-information
 Total ssh users:2
 Username            Authentication-type  User-public-key-name  Service-type
 yemx                password             null                  Stelnet|SFTP
 test                publickey            pubkey                SFTP
Total ssh users
Total number of SSH users.
Authentication-type
Authentication methods, including password authentication, publickey authentication, password-publickey authentication, and any authentication. If password authentication is used, the public key of the user displays as "null."
Public key name of the user.
Service-type
Service types, including Stelnet, SFTP, and SCP.
If multiple service types are displayed at the same time, it indicates that these services are available for SSH users.
ssh user
sftp server enable
Use sftp server enable to enable the SFTP server function.
Use undo sftp server enable to disable the SFTP server function.
sftp server enable
The SFTP server function is disabled.
# Enable the SFTP server function.
[Sysname] sftp server enable
display ssh server
sftp server idle-timeout
Use sftp server idle-timeout to set the idle timeout timer for SFTP user connections on an SFTP server.
Use undo sftp server idle-timeout to restore the default.
The idle timeout timer is 10 minutes.
time-out-value: Specifies a timeout timer (in minutes), in the range of 1 to 35791.
If an SFTP connection is idle when the idle timeout timer expires, the system automatically terminates the connection. If many SFTP connections are established, you can set a small value so that the connection resources can be properly released.
# Set the idle timeout timer for SFTP user connections to 500 minutes.
[Sysname] sftp server idle-timeout 500
display ssh server
ssh server acl
Use ssh server acl to set an ACL for IPv4 SSH clients.
Use undo ssh server acl to restore the default.
ssh server acl acl-number
undo ssh server acl
All IPv4 SSH clients are allowed to initiate connections to the device.
acl-number: Specifies an ACL by its number, in the range of 2000 to 4999.
Use this command to specify an ACL to filter the IPv4 SSH clients' request packets. The filtering process is as follows:
·           If an ACL is specified, only the IPv4 SSH clients that match the permit statement in this ACL can access the device.
·           If the specified ACL does not exist, or the ACL does not have any statement, all the IPv4 SSH clients can access the device.
The ACL only filters new SSH connections after the configuration.
If you execute this command multiple times, the last configuration takes effect.
# Specify an ACL to only permit an IPv4 SSH client 1.1.1.1 to initiate the connection to the device.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 1.1.1.1 0
[Sysname-acl-basic-2001] quit
[Sysname] ssh server acl 2001
display ssh server
ssh server ipv6 acl
Use ssh server ipv6 acl to set an ACL for IPv6 SSH clients.
Use undo ssh server ipv6 acl to restore the default.
ssh server ipv6 acl [ ipv6 ]acl-number
All IPv6 SSH clients are allowed to initiate connections to the device.
ipv6: Specifies ACL type as IPv6. If this keyword is not specified, Layer 2 ACL is applied.
acl-number: Specifies an ACL by its number. If the ipv6 keyword is specified, the value of this argument is in the range of 2000 to 3999. If the ipv6 keyword is not specified, the value of this argument is in the range of 4000 to 4999.
Use this command to specify an ACL to filter the IPv6 SSH clients' request packets. The filtering process is as follows:
·           If an ACL is specified, only the IPv6 SSH clients that match the permit statement in this ACL can access the device.
·           If the specified ACL does not exist, or the ACL does not have any statement, all the IPv6 SSH clients can access the device.
# Specify an ACL to only permit an IPv6 SSH client 1::1/64 to initiate the connection to the device.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source 1::1 64
[Sysname-acl6-basic-2001] quit
[Sysname] ssh server ipv6 acl 2001
display ssh server
ssh server authentication-retries
Use ssh server authentication-retries to set the maximum number of authentication attempts for SSH users.
Use undo ssh server authentication-retries to restore the default.
ssh server authentication-retries times
The maximum number of authentication attempts for SSH users is 3.
times: Specifies the maximum number of authentication attempts for SSH users, in the range of 1 to 5.
You can set this limit to prevent malicious hacking of usernames and passwords.
This configuration takes effect only for the users at next login.
The any authentication fails if the total number of authentication attempts (including both publickey and password authentication attempts) exceeds the upper limit configured by the ssh server authentication-retries command.
If the authentication method of SSH users is password-publickey, the server first uses publickey authentication, and then uses password authentication to authenticate SSH users. The process is regarded as one authentication attempt.
# Set the maximum number of authentication attempts for SSH users to 4.
[Sysname] ssh server authentication-retries 4
display ssh server
ssh server authentication-timeout
Use ssh server authentication-timeout to set the SSH user authentication timeout timer on the SSH server.
Use undo ssh server authentication-timeout to restore the default.
The authentication timeout timer is 60 seconds.
time-out-value: Specifies an authentication timeout timer (in seconds), in the range of 1 to 120.
If a user does not finish the authentication when the timeout timer expires, the connection is down.
You can set a small value for the timeout timer to prevent malicious occupation of TCP connections while authentications are suspended.
# Set the SSH user authentication timeout timer to 10 seconds.
[Sysname] ssh server authentication-timeout 10
display ssh server
ssh server compatible-ssh1x enable
Use ssh server compatible-ssh1x enable to enable the SSH server to support SSH1 clients.
Use undo ssh server compatible-ssh1x to disable the SSH server from supporting SSH1 clients.
The SSH server supports SSH1 clients.
The configuration only takes effect for the clients at next login.
# Enable the SSH server to support SSH1 clients.
[Sysname] ssh server compatible-ssh1x enable
display ssh server
ssh server enable
Use ssh server enable to enable the SSH server function so that the SSH clients use SSH to communicate with the server.
Use undo ssh server enable to disable the SSH server function.
ssh server enable
SSH server function is disabled.
# Enable SSH server function.
[Sysname] ssh server enable
display ssh server
ssh server rekey-interval
Use ssh server rekey-interval to set an interval for updating the RSA server key pair.
Use undo ssh server rekey-interval to restore the default.
ssh server rekey-interval hours
The interval for updating the RSA server key pair is 0, and the system does not update the RSA server key pair.
hours: Specifies an interval (in hours) for updating the server key pair, in the range of 1 to 24.
Updating the RSA server key pair periodically can prevent malicious hacking to the key pair and enhance security of the SSH connections.
This command only takes effect to SSH users that use SSH1 client software.
# Set the RSA server key pair update interval to 3 hours.
[Sysname] ssh server rekey-interval 3
display ssh server
ssh user
Use ssh user to create an SSH user and specify the service type and authentication method.
Use undo ssh user to delete an SSH user.
ssh user username service-type { all | scp | sftp | stelnet } authentication-type { password | { any | password-publickey | publickey } assign publickey keyname }
undo ssh user username
No SSH users exist.
username: Specifies an SSH username, a case-sensitive string of 1 to 80 characters. If the username contains ISP domain name, the form is pureusername@domain.
service-type: Specifies a service type for an SSH user:
·           all—Specifies Stelnet, SFTP, and SCP.
·           scp—Specifies the service type as SCP.
·           sftp—Specifies the service type as SFTP.
·           stelnet—Specifies the service type of Stelnet.
authentication-type: Specifies an authentication method for an SSH user:
·           passwordSpecifies password authentication. This authentication method features easy and fast encryption, but it is vulnerable. It can work with AAA to implement user authentication, authorization, and accounting.
·           anySpecifies either password authentication or publickey authentication.
·           password-publickey: Specifies both password authentication and publickey authentication (featuring higher security) if the client runs SSH2, and specifies either type of authentication if the client runs SSH1.
·           publickeySpecifies publickey authentication. This authentication method has complicated and slow encryption, but it provides strong authentication that can defend against brute-force attacks. This authentication method is easy to use. If this method is configured, the authentication process completes automatically without the need of entering any password.
assign publickey keyname: Assigns an existing host public key to an SSH user. The keyname argument is a string of 1 to 64 characters.
To configure an SSH user that uses publickey authentication, you must create a local user that has the same username as the SSH user to assign the working directory and user role.
To configure an SSH user that uses password authentication, you must configure a local user account by using the local-user command for local authentication, or configure an SSH user account on an authentication server, for example, a RADIUS server, for remote authentication. For password-only SSH users, you do not need to execute this command to configure them unless you want to use the display ssh user-information command to display all SSH users, including the password-only SSH users, for centralized management.
If you use the ssh user command to configure a host public key for a user who has already had a host public key, the new one overwrites the old one.
You can change the authentication method, service type, and host public key for an SSH user when the user is communicating with the SSH server, but your changes only take effect for the clients at next login.
For an SFTP or SCP user, the working directory depends on the authentication method:
·           If only password authentication is used, the working directory is authorized by AAA.
·           If publickey authentication, whether with password authentication or not, is used, the working directory is specified by the authorization-attribute command in the associated local user view.
For an SFTP or Stelnet user, the user role also depends on the authentication method:
·           If only password authentication is used, the user role is authorized by the remote AAA server or the local device.
·           If publickey authentication, whether with password authentication or not, is used, the user role is specified by the authorization-attribute command in the associated local user view.
# Create an SSH user named user1, set the service type as sftp and the authentication method as publickey, and assign a host public key named key1 to the user.
[Sysname] ssh user user1 service-type sftp authentication-type publickey assign publickey key1
# Create a local device management user named user1, set the password as123456 in plain text and the service type as ssh, and assign the working directory as flash:, the user role as network-admin.
[Sysname-luser-manage-user1] password simple 123456
[Sysname-luser-manage-user1] service-type ssh
[Sysname-luser-manage-user1] authorization-attribute work-directory flash: user-role network-admin
·           authorization-attribute
·           display ssh user-information
·           local-user
SSH client configuration commands
bye
Use bye to terminate the connection with an SFTP server and return to user view.
bye
SFTP client view
This command functions as the exit and quit commands.
# Terminate the connection with the SFTP server.
sftp> bye
<Sysname>
cd
Use cd to change the working path on an SFTP server.
cd [ remote-path ]
SFTP client view
remote-path: Specifies the name of a path on the server.
You can use the cd .. command to return to the upper-level directory.
You can use the cd / command to return to the root directory of the system.
# Change the working path to new1.
sftp> cd new1
Current Directory is:/new1
sftp> pwd
Remote working directory: /new1
sftp>
cdup
Use cdup to return to the upper-level directory.
cdup
SFTP client view
Example
# Return to the upper-level directory from the current working directory /test1.
sftp> cd test1
Current Directory is:/test1
sftp> pwd
Remote working directory: /test1
sftp> cdup
sftp> pwd
sftp>
delete
Use delete to delete the specified files from the SFTP server.
delete remote-file
SFTP client view
remote-file: Specifies the files to delete from the server.
This command functions as the remove command.
# Delete the file temp.c from the server.
sftp> delete temp.c
Removing /temp.c
dir
Use dir to display information about the files and sub-directories under a specified directory.
SFTP client view
-a: Displays the names of the files and sub-directories under a specified directory.
-l: Displays detailed information about the files and sub-directories under a specified directory in the form of a list.
remote-path: Specifies the name of the directory to be queried.
If the –a and –l keywords are not specified, the command displays the names of the files and sub-directories under a specified directory.
If the remote-path argument is not specified, the command displays detailed information about the files and sub-directories under the current working directory.
This command functions as the ls command.
# Display the names of the files and sub-directories under the current working directory.
sftp> dir –a
config.cfg
pubkey2
pubkey1
pub1
new1
new2
pub2
# Display detailed information about the files and sub-directories under the current working directory in the form of a list.
sftp> dir –l
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:28 pub1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:24 new1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:18 new2
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:30 pub2
display sftp client source
Use display sftp client source to display the source IP address or source interface configured for the SFTP client.
# Display the source IP address configured for the SFTP client.
<Sysname> display sftp client source
The source IP address of the SFTP client is 192.168.0.1.
The source IPv6 address of the SFTP client is 2:2::2:2.
·           sftp client ipv6 source
·           sftp client source
display ssh client source
Use display ssh client source to display the source IP address or source interface configured for the Stelnet client.
# Display the source IP address configured for the Stelnet client.
<Sysname> display ssh client source
The source IP address of the SSH client is 192.168.0.1.
The source IPv6 address of the SSH client is 2:2::2:2.
·           ssh client ipv6 source
·           ssh client source
exit
Use exit to terminate the connection with an SFTP server and return to user view.
exit
SFTP client view
This command functions as the bye and quit commands.
sftp> exit
<Sysname>
get
Use get to download a file from an SFTP server and save it locally.
SFTP client view
remote-file: Specifies the name of a file on the SFTP server.
local-file: Specifies the name for the local file.
If the local-file argument is not specified, the file will be saved locally with the same name as that on the server.
# Download the file temp1.c and save it as temp.c locally.
sftp> get temp1.c temp.c
Fetching /temp1.c to temp.c
/temp.c                                                 100% 1424     1.4KB/s   00:00
help
Use help to display help information of an SFTP client command.
help
SFTP client view
The help command functions as entering the question mark (?).
# Display help information.
sftp> help
Available commands:
  bye                          Quit sftp
  cd [path]                    Change remote directory to 'path'
  cdup                         Change remote directory to the parent directory
  delete path                  Delete remote file
  dir [-a|-l][path]            Display remote directory listing
       -a                        List all filenames
       -l                        List filename including the specific
                                 information of the file
  exit                         Quit sftp
  get remote-path [local-path] Download file
  help                         Display this help text
  ls [-a|-l][path]             Display remote directory
  mkdir path                   Create remote directory
  put local-path [remote-path] Upload file
  pwd                          Display remote working directory
  quit                         Quit sftp
  rename oldpath newpath       Rename remote file
  remove path                  Delete remote file
  rmdir path                   Delete remote empty directory
  ?                            Synonym for help
ls
Use ls to display information about the files and sub-directories under a specified directory.
SFTP client view
This command functions as the dir command.
sftp> ls –a
config.cfg
pubkey2
pubkey1
pub1
new1
new2
pub2
sftp> ls -l
mkdir
Use mkdir to create a directory on an SFTP server.
mkdir remote-path
SFTP client view
remote-path: Specifies the name for the directory on an SFTP server
# Create a directory named test on the SFTP server.
sftp> mkdir test
put
Use put to upload a local file to an SFTP server.
SFTP client view
local-file: Specifies the name of a local file.
remote-file: Specifies the name of a file on an SFTP server.
If the remote-file argument is not specified, the file will be remotely saved with the same name as the local one.
# Upload the local file startup.bak to the SFTP server and save it as startup01.bak.
sftp> put startup.bak startup01.bak
Uploading startup.bak to /startup01.bak
startup01.bak                                   100% 1424     1.4KB/s   00:00
pwd
Use pwd to display the current working directory of an SFTP server.
pwd
SFTP client view
# Display the current working directory of the SFTP server.
sftp> pwd
The output shows that the current working directory is the root directory.
Use quit to terminate the connection with an SFTP server and return to user view.
SFTP client view
This command functions as the bye and exit commands.
sftp> quit
<Sysname>
remove
Use remove to delete the specified files from an SFTP server.
remove remote-file
SFTP client view
remote-file: Specifies the files to delete from an SFTP server.
This command functions as the delete command.
# Delete the file temp.c from the SFTP server.
sftp> remove temp.c
Removing /temp.c
rename
Use rename to change the name of a specified file or directory on an SFTP server.
rename old-name new-name
SFTP client view
oldname: Specifies the name of an existing file or directory.
newname: Specifies the new name for the file or directory.
# Change the name of a file on the SFTP server from temp1.c to temp2.c.
sftp> dir
aa.pub  temp1.c
sftp> rename temp1.c temp2.c
sftp> dir
aa.pub  temp2.c
rmdir
Use rmdir to delete the specified directories from an SFTP server.
rmdir remote-path
SFTP client view
remote-path: Specifies the directories to delete from an SFTP server.
# Delete the sub-directory temp1 under the current directory on the SFTP server.
sftp> rmdir temp1
scp
Use scp to transfer files with an SCP server.
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 }] * [ publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
server: Specifies an IPv4 server by its address or host name, a case-insensitive string of 1 to 20 characters.
port-number: Specifies the port number of the server, in the range of 0 to 65535. The default is 22.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN that the server belongs to, where the vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
get: Downloads the file.
put: Uploads the file.
source-file-path: Specifies the directory of the source file.
destination-file-path: Specifies the directory of the target file. If this argument is not specified, the directory names of the source and target files are same.
identity-key: Specifies the public key algorithm for the client, either dsa or rsa. The default is dsa. If the server uses publickey authentication, this keyword must be specified.
·           dsa: Specifies the public key algorithm dsa.
·           rsa: Specifies the public key algorithm rsa.
prefer-compress: Specifies the preferred compression algorithm between the server and the client. By default, compression is not supported.
zlib: Specifies the compression algorithm zlib.
prefer-ctos-cipher: Specifies the preferred client-to-server encryption algorithm, defaulting to aes128.
Algorithms des, 3des, and aes128 are arranged in ascending order in the aspects of security strength and calculation time.
·           3des: Specifies the encryption algorithm 3des-cbc.
·           aes128: Specifies the encryption algorithm aes128-cbc.
·           des: Specifies the encryption algorithm des-cbc.
prefer-ctos-hmac: Specifies the preferred client-to-server HMAC algorithm, defaulting to sha1. Algorithm sha1 features stronger security but costs more time in calculation than md5.
·           md5: Specifies the HMAC algorithm hmac-md5.
·           md5-96: Specifies the HMAC algorithm hmac-md5-96.
·           sha1: Specifies the HMAC algorithm hmac-sha1.
·           sha1-96: Specifies the HMAC algorithm hmac-sha1-96.
prefer-kex: Specifies the preferred key exchange algorithm, defaulting to dh-group-exchange.
Algorithm dh-group14 features stronger security but costs more time in calculation than dh-group1.
·           dh-group-exchange: Specifies the key exchange algorithm diffie-hellman-group-exchange-sha1.
·           dh-group1: Specifies the key exchange algorithm diffie-hellman-group1-sha1.
·           dh-group14: Specifies the key exchange algorithm diffie-hellman-group14-sha1.
prefer-stoc-cipher: Specifies the preferred server-to-client encryption algorithm, defaulting to aes128.
prefer-stoc-hmac: Specifies the preferred server-to-client HMAC algorithm, defaulting to sha1.
publickey keyname: Specifies the host public key of the sever, which is used to authenticate the server. The keyname argument is a case-insensitive string of 1 to 64 characters.
source: Specifies a source IP address or source interface to connect to the server. By default, the device automatically selects a source IP address based on the routing entry. To avoid the communication failure between the client and the server due to interface faults, use the specified loopback interface as the source interface, and IP address of this interface as the source IP address.
interface interface-type interface-number: Specifies a source interface. The interface-type interface-number argument specifies a source interface by its type and number. The IPv4 address of this interface is the source IP address to send packets.
ip ip-address: Specifies a source IPv4 address.
When the client's authentication method is publickey, the client must get the local private key for digital signature. Because the publickey authentication uses either RSA or DSA algorithm, you must specify an algorithm (by using the identity-key keyword) in order to get the correct data for the local private key.
# Connect an SCP client to the SCP server 200.1.1.1, specify the public key of the server as svkey, and download the file abc.txt from the server. The SCP client uses publickey authentication. Use the following algorithms:
·           The preferred key exchange algorithm is dh-group1.
·           The preferred server-to-client encryption algorithm is aes128.
·           The preferred client-to-server HMAC algorithm is md5.
·           The preferred server-to-client HMAC algorithm is sha1-96.
·           The preferred compression algorithm between the server and client is zlib.
<Sysname> scp 200.1.1.1 get abc.txt prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey
scp ipv6
Use scp ipv6 to transfer files with an IPv6 SCP server.
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 }] * [ publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
server: Specifies an IPv6 server by its address or host name, a case-insensitive string of 1 to 46 characters.
port-number: Specifies the port number of the server, in the range of 1 to 65535. The default is 22.
-i interface-type interface-number: Specifies the outgoing interface used by the client to connect to the server. The argument interface-type interface-number specified the outgoing interface by its type and number. This option is only used when the server uses a link-local address and the specified outgoing interface on the client must have a link-local address.
source: Specifies a source IPv6 address or source interface to connect to the server. By default, the device automatically selects a source IPv6 address based on the routing entry. To avoid the communication failure between the client and the server due to interface faults, use the specified loopback interface as the source interface, and IPv6 address of this interface as the source IPv6 address.
interface interface-type interface-number: Specifies a source interface. The interface-type interface-number argument specifies a source interface by its type and number. The IPv6 address of this interface is the source IPv6 address to send packets.
Ipv6 ipv6-address: Specifies a source IPv6 address.
# Connect an SCP client to the SCP server 2000::1, specify the public key of the server as svkey, and download the file abc.txt from the server. The SCP client uses publickey authentication. Use the following algorithms:
<Sysname> scp ipv6 2000::1 get abc.txt prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey
sftp
Use sftp to establish a connection to an IPv4 SFTP server and enter SFTP client view.
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number s | ip ip-address} ] *
server: Specifies a server by its IPv4 address or host name, a case-insensitive string of 1 to 20 characters.
port-number: Specifies a port number of the server, in the range of 1 to 65535. The default is 22.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN that the server belongs to, where vpn-instance-name is a case-sensitive string of 1 to 31 characters.
·           dsa: Specifies the public key algorithm DSA.
·           rsa: Specifies the public key algorithm RSA.
prefer-ctos-cipher: Specifies the preferred client-to-server encryption algorithm. The default is aes128. Algorithms des, 3des, and aes128 are arranged in ascending order in the aspects of security strength and calculation time.
prefer-ctos-hmac: Specifies the preferred client-to-server HMAC algorithm. The default is sha1. Algorithm sha1 features stronger security but costs more time in calculation than md5.
prefer-kex: Specifies the preferred key exchange algorithm. The default is dh-group-exchange. Algorithm dh-group14 features stronger security but costs more time in calculation than dh-group1.
prefer-stoc-cipher: Specifies the preferred server-to-client encryption algorithm. The default is aes128.
prefer-stoc-hmac: Specifies the preferred server-to-client HMAC algorithm. The default is sha1.
source: Specifies a source IP address or source interface to connect to the server. By default, the packet to send gets the primary IP address of its outbound interface from the routing table and uses it as the source IP address. To avoid the communication failure between the client and the server due to interface faults, use the specified loopback interface as the source interface, and either IP address of the two interfaces as the source IP address.
interface interface-type interface-number: Specifies a source interface. The interface-type interface-number argument specifies a source interface by its type and number. The primary IPv4 address of this interface is the source IP address to send packets.
When the server adopts publickey authentication to authenticate a client, the client must get the local private key for digital signature. Because publickey authentication uses RSA or DSA algorithm, you must specify a public key algorithm (by using the identity-key keyword) in order to get the correct data for the local private key.
# Connect an SFTP client to the IPv4 SFTP server (10.1.1.2) and specify the public key of the server as svkey. The SFTP client uses publickey authentication. Use the following algorithms:
<Sysname> sftp 10.1.1.2 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey
Use sftp client ipv6 source to specify the source IPv6 address or source interface for the SFTP client.
Use undo sftp client ipv6 source to remove the configuration.
sftp client ipv6 source { interface interface-type interface-number | ipv6 ipv6-address }
The SFTP client uses the IPv6 address of the interface specified by the route of the device to access the SFTP server.
interface interface-type interface-number: Specifies the IPv6 address of the interface which matches the destination address of the outbound packets using the longest match criteria as the source IPv6 address. The interface-type interface-number argument specifies a source interface by its type and number.
ipv6 ipv6-address: Specifies a source IPv6 address.
The SFTP client uses the specified source IPv6 address to communicate with the server.
If you execute the sftp client ipv6 source command multiple times, the most recent configuration takes effect.
If you use the sftp ipv6 command to connect to an SFTP server and specify another source IPv6 address, the SFTP client uses the new source IPv6 address for the current connection instead of that specified by the sftp client ipv6 source command.
The source address specified by the sftp client ipv6 source command applies to all SFTP connections, but the source address specifies by the sftp ipv6 command applies only to the current connection.
# Specify the source IPv6 address for the SFTP client as 2:2::2:2.
[Sysname] sftp client ipv6 source ipv6 2:2::2:2
sftp client source
Use sftp client source to specify the source IPv4 address or source interface for the SFTP client.
Use undo sftp client source to remove the configuration.
sftp client source { interface interface-type interface-number | ip ip-address }
The SFTP client uses the IPv4 address of the interface specified by the route of the device to access the SFTP server.
interface interface-type interface-number: Specifies the primary IP address of the interface as the source address. The interface-type interface-number argument specifies a source interface by its type and number.
The SFTP client uses the specified source interface and source IP address to communicate with the server.
If you execute the sftp client source command multiple times, the most recent configuration takes effect.
If you use the sftp command to connect to an SFTP server and specify another source IP address, the SFTP client uses the new source IPv6 address for the current connection instead of that specified by the sftp client source command.
The source address specified by the sftp client source command applies to all SFTP connections, but the source address specifies by the sftp command applies only to the current connection.
# Specify the source IP address for the SFTP client as 192.168.0.1.
[Sysname] sftp client source ip 192.168.0.1
sftp ipv6
Use sftp ipv6 to connect an SFTP client to an IPv6 SFTP server and enter SFTP client view.
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address} ] *
server: Specifies a server by its IPv6 address or host name, a case-insensitive string of 1 to 46 characters.
-i interface-type interface-number: Specifies the outgoing interface used by the client to connect to the server. The argument interface-type interface-number specified the outgoing interface by its type and number. This option is only used when the server uses a link-local address, and the specified outgoing interface on the client must have a link-local address.
·           3de: Specifies the encryption algorithm 3des-cbc.
publickey keyname: Specifies the host public key of the server, which is used to authenticate the server. The keyname argument is a case-insensitive string of 1 to 64 characters.
source: Specifies a source IP address or source interface to connect to the server. By default, the device automatically selects the source IP address from the routing table. To avoid the communication failure between the client and the server due to interface faults, use the specified loopback interface as the source interface, and either IP address of the two interfaces as the source IP address.
interface interface-type interface-number: Specifies a source interface. The interface-type interface-number argument specifies a source interface by its type and number. The IPv6 address of this interface is the source IP address to send packets.
When the server adopts publickey authentication to authenticate a client, the client must get the local private key for digital signature. Because publickey authentication uses either RSA or DSA algorithm, you must specify a public key algorithm (by using the identity-key keyword) in order to get the correct data for the local private key.
# Connect an SFTP client to the IPv6 SFTP server (2:5::8:9) and specify the public key of the server as svkey. The SFTP client uses publickey authentication. Use the following algorithms:
<Sysname> sftp ipv6 2:5::8:9 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey
Username:
Use ssh client ipv6 source to specify the source IPv6 address or source interface for the Stelnet client.
Use undo ssh client ipv6 source to remove the configuration.
The Stelnet client uses the IPv6 address of the interface specified by the route of the device to access the Stelnet server.
The Stelnet client uses the specified source address to communicate with the server.
If you execute the ssh client ipv6 source command multiple times, the most recent configuration takes effect.
If you use the ssh2 ipv6 command to connect to an Stelnet server and specify another source IPv6 address, the Stelnet client uses the new source IPv6 address for the current connection instead of that specified by the ssh client ipv6 source command.
The source address specified by the ssh client ipv6 source command applies to all Stelnet connections, and the source address specifies by the ssh2 ipv6 command applies only to the current connection.
# Specify the source IPv6 address as 2:2::2:2 for the Stelnet client.
[Sysname] ssh client ipv6 source ipv6 2:2::2:2
ssh client source
Use ssh client source to specify the source IPv4 address or source interface for the Stelnet client.
Use undo ssh client source to remove the configuration.
The Stelnet client uses the IPv4 address of the interface specified by the route of the device to access the Stelnet server.
If you execute the ssh client source command multiple times, the most recent configuration takes effect.
If you use the ssh2 command to connect to an Stelnet server and specify another source IP address, the Stelnet client uses the new source IPv6 address for the current connection instead of that specified by the ssh client source command.
The source address specified by the ssh client source command applies to all Stelnet connections, but the source address specifies by the ssh2 command applies only to the current Stelnet connection.
# Specify the source IPv4 address for the Stelnet client as 192.168.0.1.
[Sysname] ssh client source ip 192.168.0.1
ssh2
Use ssh2 to establish a connection to an IPv4 Stelnet server.
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
port-number: Specifies the port number of the server, in the range 1 to 65535. The default is 22.
interface interface-type interface-number: Specifies a source interface by its type and number. The primary IPv4 address of this interface is the source IP address to send packets.
# Establish a connection to the IPv4 Stelnet server (3.3.3.3) and specify the public key of the server as svkey. The Stelnet client uses publickey authentication. Use the following algorithms:
<Sysname> ssh2 3.3.3.3 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey
ssh2 ipv6
Use ssh2 ipv6 to establish a connection to an IPv6 Stelnet server.
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 }] * [ publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
publickey keyname: Specifies the server by its host public key, which is used to authenticate the server. The keyname argument is a case-insensitive string of 1 to 64 characters.
# Establish a connection to the IPv6 Stelnet server (2000::1) and specify the public key of the server as svkey. The SSH client uses publickey authentication. Use the following algorithms:
<Sysname> ssh2 ipv6 2000::1 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96 prefer-compress zlib publickey svkey
