| 02-ARP attack protection commands | 136.5 KB |
Unresolvable IP attack protection commands
display arp source-suppression
ARP packet rate limit commands
Source MAC based ARP attack detection commands
ARP packet source MAC consistency check commands
ARP active acknowledgement commands
display arp detection statistics
reset arp detection statistics
ARP automatic scanning and fixed ARP commands
ARP gateway protection commands
The device operates in IRF or standalone (the default) mode. For information about IRF mode, see IRF Configuration Guide.
arp resolving-route enable
Use arp resolving-route enable to enable ARP black hole routing.
Use undo arp resolving-route enable to disable ARP black hole routing.
The ARP black hole routing function is enabled.
Configure this feature on the gateways.
If a device receives a large number of unresolvable IP packets from a host, the following situations can occur:
· The device sends a large number of ARP requests, overloading the target subnets.
· The device keeps trying to resolve destination IP addresses, overloading its CPU.
If the IP packets have different source addresses, you can enable the ARP black hole routing function. After receiving an unresolvable IP packet, the device creates a black hole route destined for the target IP address and drops all matching packets until the black hole route ages out.
# Enable ARP black hole routing.
[Sysname] arp resolving-route enable
arp source-suppression enable
Use arp source-suppression enable to enable the ARP source suppression function.
Use undo arp source-suppression enable to restore the default.
ARP source suppression function is disabled.
Configure this feature on the gateway devices.
# Enable the ARP source suppression function.
[Sysname] arp source-suppression enable
arp source-suppression limit
Use arp source-suppression limit to set the maximum number of unresolvable packets that can be received from a device in 5 seconds.
Use undo arp source-suppression limit to restore the default.
The maximum number is 10.
limit-value: Sets the maximum number of unresolvable packets that can be processed in 5 seconds. It is in the range of 2 to 1024.
If the number of unresolvable packets from a host within 5 seconds exceeds the specified threshold, the device stops processing packets from that host until the 5 seconds elapse.
# Set the maximum number of unresolvable packets that can be received from a device in 5 seconds to 100.
[Sysname] arp source-suppression limit 100
display arp source-suppression.
Use display arp source-suppression to display information about the current ARP source suppression configuration.
# Display information about the current ARP source suppression configuration.
<Sysname> display arp source-suppression
ARP source suppression is enabled
Current suppression limit: 100
Current suppression limit |
Maximum number of unresolvable packets that can be received from a host in 5 seconds. |
arp rate-limit
Use arp rate-limit pps to enable ARP packet rate limit on an interface and configure the rate limit. Exceeded packets are discarded.
Use undo arp rate-limit [ pps ] to disable ARP packet rate limit.
The ARP packet rate limit function is disabled.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
pps: Specifies the upper limit for ARP packet rate in pps. The value is in the range of 10 to 5000.
If you do not specify the pps argument in the arp rate-limit command, ARP packet rate limit is disabled.
# Specify the maximum ARP packet rate on GigabitEthernet 3/0/1 as 50 pps.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] arp rate-limit 50
arp source-mac
Use arp source-mac to enable the source MAC address based ARP attack detection and specify a handling method.
Use undo arp source-mac to restore the default.
arp source-mac { filter | monitor }
undo arp source-mac [ filter | monitor ]
The source MAC address based ARP attack detection function is disabled.
filter: Generates log messages and discards subsequent ARP packets from the MAC address.
monitor: Only generates log message.
This function enables the switch to check the source MAC address of ARP packets received from the same MAC address within 5 seconds against a specific threshold. If the threshold is exceeded, the switch takes the preconfigured method to handle the attack.
If neither the filter nor the monitor keyword is specified in the undo arp anti-attack source-mac command, both handling methods are disabled.
# Enable the source MAC based ARP attack detection and specify the filter handling method.
[Sysname] arp source-mac filter
arp source-mac aging-time
Use arp source-mac aging-time to configure the aging time for ARP attack entries.
Use undo arp anti-attack source-mac aging-time to restore the default.
arp source-mac aging-time time
undo arp source-mac aging-time
The aging time for ARP attack entries is set to 300 seconds (5 minutes).
time: Sets the aging time for ARP attack entries, in the range of 60 to 6000 seconds.
# Set the aging time for ARP attack entries to 60 seconds.
[Sysname] arp source-mac aging-time 60
arp source-mac exclude-mac
Use arp anti-attack source-mac exclude-mac to exclude specified MAC addresses from source MAC address based ARP attack detection.
Use undo arp anti-attack source-mac exclude-mac to remove the excluded MAC addresses.
arp source-mac exclude-mac mac-address&<1-n>
undo arp source-mac exclude-mac [ mac-address&<1-n> ]
No MAC address is excluded from source MAC address based ARP attack detection.
mac-address&<1-n>: MAC address list. The mac-address argument indicates an excluded MAC address in the format H-H-H. &<1-n> indicates the number of excluded MAC addresses that you can configure. The value for the n argument is in the range of 1 to 10.
If you do not specify a MAC address, the undo arp source-mac exclude-mac command removes all excluded MAC addresses.
# Exclude a MAC address from source MAC based ARP attack detection.
[Sysname] arp source-mac exclude-mac 2-2-2
arp source-mac threshold
Use arp source-mac threshold to configure the threshold for source MAC address based ARP attack detection. If the number of ARP packets sent from a MAC address within 5 seconds exceeds this threshold, the device recognizes this as an attack.
Use undo arp source-mac threshold to restore the default.
arp source-mac threshold threshold-value
The threshold for source MAC address based ARP attack detection is 30.
threshold-value: Specifies the threshold for source MAC address based ARP attack detection. The value is in the range of 1 to 5000.
# Configure the threshold for source MAC address based ARP attack detection as 30.
[Sysname] arp source-mac threshold 30
display arp source-mac
Use display arp source-mac to display ARP attack entries detected by source MAC address based ARP attack detection.
In standalone mode:
display arp source-mac { slot slot-number | interface interface-type interface-number }
In IRF mode:
display arp source-mac { chassis chassis-number slot slot-number | interface interface-type interface number }
interface interface-type interface-number: Displays ARP attack entries detected on the specified interface.
slot slot-number: Displays ARP attack entries detected on an IRF member device. The slot-number argument specifies the ID of the IRF member device. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ARP attack entries detected on the specified card of an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
# Display the ARP attack entries detected by source MAC address based ARP attack detection.
<Sysname> display arp source-mac
Source-MAC VLAN ID Interface Aging-time
23f3-1122-3344 4094 GE3/0/1 10
23f3-1122-3355 4094 GE3/0/2 30
23f3-1122-33ff 4094 GE3/0/3 25
23f3-1122-33ad 4094 GE3/0/4 30
23f3-1122-33ce 4094 GE3/0/5 2
arp valid-check enable
Use arp valid-check enable to enable ARP packet source MAC address consistency check on the gateway.
Use undo arp valid-check enable to disable ARP packet source MAC address consistency check.
ARP packet source MAC address consistency check is disabled.
Configure this feature on gateway devices.
After you execute this command, the gateway device can filter out ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body.
# Enable ARP packet source MAC address consistency check.
[Sysname] arp valid-check enable
arp active-ack enable
Use arp active-ack enable to enable the ARP active acknowledgement function.
Use undo arp active-ack enable to restore the default.
The ARP active acknowledgement function is disabled.
Configure this feature on gateway devices to prevent user spoofing.
# Enable the ARP active acknowledgement function.
[Sysname] arp active-ack enable
Authorized ARP commands
NOTE: This feature can be configured only on Layer 3 Ethernet interfaces. For information about the operating mode of Ethernet interfaces, see Interface Configuration Guide. |
arp authorized enable
Use arp authorized enable to enable authorized ARP on an interface.
Use undo arp authorized enable to restore the default.
Authorized ARP is not enabled on the interface.
Layer 3 Ethernet interface view, Layer 3 Ethernet subinterface view, Layer 3 aggregate interface view, Layer 3 aggregate subinterface view
# Enable authorized ARP on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] port link-mode route
[Sysname-GigabitEthernet3/0/1] arp authorized enable
ARP detection commands
arp detection enable
Use arp detection enable to enable ARP detection.
Use undo arp detection enable to restore the default.
ARP detection is disabled.
VLAN view
# Enable ARP detection for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp detection enable
arp detection trust
Use arp detection trust to configure a port as an ARP trusted port.
Use undo arp detection trust to restore the default.
arp detection trust
An interface is an ARP untrusted interface.
# Configure GigabitEthernet 3/0/1 as an ARP trusted interface.
[Sysname-GigabitEthernet3/0/1] arp detection trust
arp detection validate
Use arp detection validate to enable ARP packet validity check. You can specify one or more objects to be checked in one command line.
Use undo arp detection validate to disable ARP packet validity check. If no keyword is specified, this command deletes all objects.
undo arp detection validate [ dst-mac | ip | src-mac ] *
ARP packet validity check is disabled.
dst-mac: Checks the target MAC address of ARP responses. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
ip: Checks the sender and target IP addresses of ARP replies, and the sender IP address of ARP requests. All-zero, all-one, or multicast IP addresses are considered invalid and the corresponding packets are discarded.
src-mac: Checks whether the sender MAC address in the message body is identical to the source MAC address in the Ethernet header. If they are identical, the packet is forwarded. Otherwise, the packet is discarded.
# Enable ARP packet validity check by checking the MAC addresses and IP addresses of ARP packets.
[Sysname] arp detection validate dst-mac src-mac ip
Use arp restricted-forwarding enable to enable ARP restricted forwarding.
Use undo arp restricted-forwarding enable to disable ARP restricted forwarding.
ARP restricted forwarding is disabled.
VLAN view
# Enable ARP restricted forwarding in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp restricted-forwarding enable
Use display arp detection to display the VLANs enabled with ARP detection.
# Display the VLANs enabled with ARP detection.
<Sysname> display arp detection
ARP detection is enabled in the following VLANs:
1-2, 4-5
Use display arp detection statistics to display ARP detection statistics.
display arp detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Displays the ARP detection statistics of a specific interface.
This command displays numbers of packets discarded by user validity check and ARP packet validity check. If you do not specify any interface, the command displays statistics for all interfaces.
# Display the ARP detection statistics for all interfaces.
<Sysname> display arp detection statistics
State: U-Untrusted T-Trusted
ARP packets dropped by ARP inspect checking:
Interface(State) IP Src-MAC Dst-MAC Inspect
GE3/0/1(U) 40 0 0 78
GE3/0/2(U) 0 0 0 0
GE3/0/3(T) 0 0 0 0
GE3/0/4(U) 0 0 30 0
State |
State of an interface: · U—ARP untrusted interface. · T—ARP trusted interface. |
Interface(State) |
Inbound interface of ARP packets. State specifies the port state, trusted or untrusted. |
IP |
Number of ARP packets discarded due to invalid source and destination IP addresses. |
Src-MAC |
Number of ARP packets discarded due to invalid source MAC address. |
Dst-MAC |
Number of ARP packets discarded due to invalid destination MAC address. |
Inspect |
Number of ARP packets failed to pass user validity check. |
Use reset arp detection statistics to clear ARP detection statistics.
reset arp detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Clears the ARP detection statistics for the specified interface.
If you do not specify any interface, this command clears the statistics of all interfaces.
# Clear the ARP detection statistics of all interfaces.
<Sysname> reset arp detection statistics
arp fixup
Use arp fixup to change the existing dynamic ARP entries into static ARP entries. You can use this command again to change the dynamic ARP entries learned later into static.
arp fixup
The static ARP entries changed from dynamic ARP entries have the same attributes as the manually configured static ARP entries.
The number of static ARP entries changed from dynamic ARP entries is restricted by the number of static ARP entries that the device supports. As a result, the device may fail to change some dynamic ARP entries into static ARP entries.
Suppose that the number of dynamic ARP entries is D and that of the existing static ARP entries is S. When the dynamic ARP entries are being changed into static, new dynamic ARP entries may be created (suppose the number is M) and some of the dynamic ARP entries may be aged out (suppose the number is N). After the change process is completed, the number of static ARP entries is D + S + M – N.
To delete a specific static ARP entry changed from a dynamic one, use the undo arp ip-address [ vpn-instance-name ] command. To delete all such static ARP entries, use the reset arp all or reset arp static command.
# Enable fixed ARP.
[Sysname] arp fixup
arp scan
Use arp scan to enable ARP automatic scanning in the specified address range.
arp scan [ start-ip-address to end-ip-address ]
Layer 3 Ethernet interface view, Layer 3 Ethernet subinterface view, VLAN interface view, Layer 3 aggregate interface view, Layer 3 aggregate subinterface view
start-ip-address: Specifies the start IP address of the scanning range.
end-ip-address: Specifies the end IP address of the scanning range. The end IP address must be higher than or equal to the start IP address.
If the start and end IP addresses are specified, the device scans the neighbor IP addresses in the specified address range to learn ARP entries. If the sending interface has multiple IP addresses falling within the specified address range, the sender IP address in the sent ARP requests is the interface address on the smallest network segment.
If you do not specify any address range, the device only scans neighbors on the network where the primary IP address of the interface resides. The sender IP address in the ARP requests is the primary IP address of the interface.
The start IP address and end IP address must be on the same network as the primary IP address or manually configured secondary IP addresses of the interface.
IP addresses already exist in ARP entries are not scanned.
ARP automatic scanning may take some time. To stop an ongoing scan, press Ctrl + C. Dynamic ARP entries are created based on ARP replies received before the scan is terminated.
# Configure the device to scan the neighbors on the network where the primary IP address of VLAN-interface 2 resides.
[Sysname-Vlan-interface2] arp scan
# Configure the device to scan neighbors on the specified address range.
[Sysname-Vlan-interface2] arp scan 1.1.1.1 to 1.1.1.20
arp filter source
Use arp filter source to enable ARP gateway protection for a specific gateway.
Use undo arp filter source to disable ARP gateway protection for the specified gateway.
arp filter source ip-address
undo arp filter source ip-address
ARP gateway protection is disabled.
ip-address: Specifies the IP address of a protected gateway.
You can enable ARP gateway protection for up to eight gateways on an interface.
You cannot configure both arp filter source and arp filter binding commands on the same interface.
# Enable ARP gateway protection for the gateway with IP address 1.1.1.1.
[Sysname-GigabitEthernet3/0/1] arp filter source 1.1.1.1
ARP filtering commands
arp filter binding
Use arp filter binding to configure an ARP permitted entry. If the sender IP and MAC addresses of an ARP packet match an ARP permitted entry, the ARP packet is permitted. If not, it is discarded.
Use undo arp filter binding to remove an ARP permitted entry.
undo arp filter binding ip-address
No ARP permitted entry is configured.
ip-address: Permitted sender IP address.
mac-address: Permitted sender MAC address.
You can configure up to eight ARP permitted entries on an interface.
You cannot configure both the arp filter source and arp filter binding commands on the same interface.
# Configure an ARP permitted entry.
[Sysname-GigabitEthernet3/0/1] arp filter binding 1.1.1.1 2-2-2
