10-Security Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71010-Security Command Reference
01-AAA commands
01-AAA commands 334.46 KB
AAA commands 1
General AAA commands 1
access-limit enable· 1
accounting command· 1
accounting default 2
accounting login· 3
authentication default 5
authentication login· 6
authentication super 7
authorization command· 8
authorization default 9
authorization login· 10
display domain· 12
domain· 13
domain default enable· 14
state (ISP domain view) 15
Local user commands 16
authorization-attribute (local user view/user group view) 16
display local-user 17
display user-group· 19
group· 20
local-user 21
password· 22
service-type· 23
state (local user view) 24
user-group· 25
RADIUS commands 25
accounting-on enable· 25
display radius scheme· 26
display radius statistics 28
key (RADIUS scheme view) 29
nas-ip (RADIUS scheme view) 30
primary accounting (RADIUS scheme view) 31
primary authentication (RADIUS scheme view) 33
radius nas-ip· 34
radius scheme· 35
radius session-control enable· 36
reset radius statistics 36
retry· 37
retry realtime-accounting· 38
secondary accounting (RADIUS scheme view) 39
secondary authentication (RADIUS scheme view) 40
state primary· 42
state secondary· 43
timer quiet (RADIUS scheme view) 44
timer realtime-accounting (RADIUS scheme view) 45
timer response-timeout (RADIUS scheme view) 46
user-name-format (RADIUS scheme view) 46
vpn-instance (RADIUS scheme view) 47
HWTACACS commands 48
display hwtacacs scheme· 48
hwtacacs nas-ip· 50
hwtacacs scheme· 51
key (HWTACACS scheme view) 52
nas-ip (HWTACACS scheme view) 53
primary accounting (HWTACACS scheme view) 54
primary authentication (HWTACACS scheme view) 55
primary authorization· 56
reset hwtacacs statistics 57
secondary accounting (HWTACACS scheme view) 58
secondary authentication (HWTACACS scheme view) 59
secondary authorization· 61
timer quiet (HWTACACS scheme view) 62
timer realtime-accounting (HWTACACS scheme view) 63
timer response-timeout (HWTACACS scheme view) 64
user-name-format (HWTACACS scheme view) 64
vpn-instance (HWTACACS scheme view) 65
AAA commands
access-limit enable
Use access-limit enable to set the maximum number of online users in an ISP domain. After the number of online users reaches the allowed maximum number, no more users are accepted.
Use undo access-limit enable to restore the default.
access-limit enable max-user-number
There is no limit to the number of online users in an ISP domain.
ISP domain view
max-user-number: Maximum number of online users that the ISP domain can accommodate, in the range of 1 to 2147483646.
System resources are limited, and user connections may compete for network resources when there are excessive users. Setting a proper limit to the number of online users helps provide reliable system performance.
# Set a limit of 500 user connections for ISP domain test.
[Sysname] domain test
[Sysname-isp-test] access-limit enable 500
display domain
accounting command
Use accounting command to specify the command line accounting method.
Use undo accounting command to restore the default.
accounting command hwtacacs-scheme hwtacacs-scheme-name
The default accounting method of the ISP domain is used for command line accounting.
ISP domain view
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
The command line accounting function cooperates with the accounting server to record all commands that have been successfully executed on the device.
Command line accounting can use only a remote HWTACACS server.
# Configure ISP domain test to use HWTACACS scheme hwtac for command line accounting.
[Sysname-isp-test] accounting command hwtacacs-scheme hwtac
·           accounting default
·           command accounting (Fundamentals Command Reference)
·           hwtacacs scheme
accounting default
Use accounting default to specify the default accounting method for an ISP domain.
Use undo accounting default to restore the default.
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default accounting method of an ISP domain is local.
ISP domain view
local: Performs local accounting.
none: Does not perform accounting.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
The default accounting method is used for all users who support this method and do not have a specific accounting method configured.
Local accounting is only used for monitoring and controlling the number of local user connections, but does not provide the statistics function that the accounting feature generally provides.
You can specify multiple default accounting methods, one primary and multiple backup methods. When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting default radius-scheme radius-scheme-name local none command specifies the primary default RADIUS accounting method and two backup accounting methods, local accounting and no accounting. With this command, the device performs RADIUS accounting by default, performs local accounting when the RADIUS server is invalid, and does not perform accounting when both of the previous methods are invalid.
# Configure the default accounting method for ISP domain test to use RADIUS scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting default radius-scheme rd local
·           hwtacacs scheme
·           local-user
·           radius scheme
accounting login
Use accounting login to specify the accounting method for login users.
Use undo accounting login to restore the default.
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default accounting method of the ISP domain is used for login users.
ISP domain view
Accounting is not supported for login users who use FTP.
You can specify multiple default accounting methods, one primary and multiple backup methods. When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting login radius-scheme radius-scheme-name local none command specifies a primary default RADIUS accounting method and two backup accounting methods, local accounting and no accounting. With this command, the device performs RADIUS accounting by default, performs local accounting when the RADIUS server is invalid, and does not perform accounting when both of the previous methods are invalid.
# Configure ISP domain test to use local accounting for login users.
[Sysname-isp-test] accounting login local
# Configure ISP domain test to use RADIUS scheme rd for login user accounting and use local accounting as the backup.
[Sysname-isp-test] accounting login radius-scheme rd local
·           hwtacacs scheme
·           local-user
·           radius scheme
Use authentication default to specify the default authentication method for an ISP domain.
Use undo authentication default to restore the default.
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication method of an ISP domain is local.
ISP domain view
ldap-scheme ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters. The switch does not support this parameter.
local: Performs local authentication.
none: Does not perform authentication.
The default authentication method is used for all users who support this method and do not have a specific authentication method configured.
You can specify multiple default authentication methods, one primary and multiple backup methods. When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication default radius-scheme radius-scheme-name local none command specifies a primary default RADIUS authentication method and two backup authentication methods, local authentication and no authentication. With this command, the device performs RADIUS authentication by default, performs local authentication when the RADIUS server is invalid, and does not perform authentication when both of the previous methods are invalid.
# Configure the default authentication method for ISP domain test to use RADIUS scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication default radius-scheme rd local
·           hwtacacs scheme
·           local-user
·           radius scheme
Use authentication login to specify the authentication method for login users.
Use undo authentication login to restore the default.
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication method of the ISP is used for login users.
ISP domain view
You can specify multiple default authentication methods, one primary and multiple backup methods. When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication login radius-scheme radius-scheme-name local none command specifies the default primary RADIUS authentication method and two backup authentication methods, local authentication and no authentication. With this command, the device performs RADIUS authentication by default, performs local authentication when the RADIUS server is invalid, and does not perform authentication when both of the previous methods are invalid.
# Configure ISP domain test to use local authentication for login users.
[Sysname-isp-test] authentication login local
# Configure ISP domain test to use RADIUS scheme rd for login users and use local authentication as the backup.
[Sysname-isp-test] authentication login radius-scheme rd local
·           authentication default
·           hwtacacs scheme
·           local-user
·           radius scheme
Use authentication super to specify the authentication method for user role switching.
Use undo authentication super to restore the default.
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name } *
The default authentication method of the ISP domain is used for user role switching authentication.
ISP domain view
You can specify one authentication method and one backup authentication method to use in case that the previous authentication method is invalid.
If you specify a scheme to provide the method for user role switching authentication, the method applies only to users whose user role is in the format of level-n.
·           If an HWTACACS scheme is specified, the device uses the entered username for role switching authentication. The username must already exist on the HWTACACS server to represent the highest user level to be switched to. For example, to switch to a level-3 user role whose username is test, the device uses test@domain-name or test for role switching authentication, depending on whether the domain name is required.
·           If a RADIUS scheme is specified, the device uses the username $enabn$ on the RADIUS server for role switching authentication, where n is the same as that in the target user role. For example, to switch to a level-3 user role whose username is test, the device uses $enab3@domain-name$ or $enab3$ for role switching authentication, depending on whether the domain name is required.
# Configure ISP domain test to use HWTACACS scheme tac for user role switching authentication.
[Sysname] super authentication-mode scheme
[Sysname-domain-test] authentication super hwtacacs-scheme tac
·           hwtacacs scheme
·           radius scheme
Use authorization command to specify the command authorization method.
Use undo authorization command to restore the default.
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] [ none ] | local [ none ] | none }
The default authorization method of the ISP domain is used for command authorization.
ISP domain view
local: Performs local authorization.
none: Does not perform authorization. An authenticated user gets the default user role. For more information about the default user role, see Fundamentals Configuration Guide.
Command authorization restricts login users to execute only authorized commands by employing an authorization server to verify whether or not each entered command is permitted.
After login, users can access the command lines permitted by their authorized user roles.
You can specify one command authorization method and multiple backup authorization methods. When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization command hwtacacs-scheme hwtacacs-scheme-name local none command specifies the default HWTACACS authorization method and two backup authorization methods, local authorization and no authorization. With this command, the device performs HWTACACS authorization by default, performs local authorization when the HWTACACS server is invalid, and does not perform command authorization when both of the previous methods are invalid.
# Configure ISP domain test to use local command authorization.
[Sysname-isp-test] authorization command local
# Configure ISP domain test to use HWTACACS scheme hwtac for command authorization and use local authorization as the backup authorization method.
[Sysname-isp-test] authorization command hwtacacs-scheme hwtac local
·           authorization accounting (Fundamentals Command Reference)
·           hwtacacs scheme
·           local-user
Use authorization default to specify the default authorization method for an ISP domain.
Use undo authorization default to restore the default.
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization method of an ISP domain is local.
ISP domain view
none: Does not perform authorization. After passing authentication, non-login users can access the network, FTP users can access the root directory of the device, and other login users get the default user role. For more information about the default user role, see Fundamentals Configuration Guide.
The default authorization method is used for all users who support this method and do not have a specific authorization method are configured.
The RADIUS authorization configuration takes effect only when the authentication method and authorization method of the ISP domain use the same RADIUS scheme.
You can specify one authorization method and multiple backup authorization methods. When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization default radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup authorization methods, local authorization and no authorization. With this command, the device performs RADIUS authorization by default, performs local authorization when the RADIUS server is invalid, and does not perform authorization when both of the previous methods are invalid.
# Configure the default authorization method for ISP domain test to use RADIUS scheme rd for user authorization and use local authorization as the backup.
[Sysname-isp-test] authorization default radius-scheme rd local
·           hwtacacs scheme
·           local-user
·           radius scheme
authorization login
Use authorization login to configure the authorization method for login users.
Use undo authorization login to restore the default.
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization method of the ISP domain is used for login users.
ISP domain view
none: Does not perform authorization. After passing authentication, FTP users can access the root directory of the device, and other login users get the default user role. For more information about the default user role, see Fundamentals Configuration Guide.
You can specify one authorization method and multiple backup authorization methods. When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization login radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup authorization methods, local authorization and no authorization. With this command, the device performs RADIUS authorization by default, performs local authorization when the RADIUS server is invalid, and does not perform authorization when both of the previous methods are invalid.
# Configure ISP domain test to use local authorization for login users.
[Sysname-isp-test] authorization login local
# Configure ISP domain test to use RADIUS scheme rd for login user authorization and use local authorization as the backup.
[Sysname-isp-test] authorization login radius-scheme rd local
·           authorization default
·           hwtacacs scheme
·           local-user
·           radius scheme
display domain
Use display domain to display the ISP domain configuration.
display domain [ isp-name ]
isp-name: ISP domain name, a case-insensitive string of 1 to 24 characters.
If no ISP domain is specified, the command displays the configuration of all ISP domains.
# Display the configuration of all ISP domains.
<Sysname> display domain
Total 2 domain(s)
Domain:system
 State: Active
  Access-limit: Disable
  Access-Count: 0
  default Authentication Scheme:  local
  default Authorization  Scheme:  local
  default Accounting     Scheme:  local
Domain:bbb
 State: Active
 Access-Count: 0
 login   Authentication Scheme:  tacacs: hwtac
 login   Authorization  Scheme:  tacacs: hwtac
 login   Accounting     Scheme:  tacacs: hwtac
Default Domain Name: system
Domain
ISP domain name.
Status of the ISP domain.
Access-limit
Limit to the number of user connections. If the number is not limited, this field displays Disabled.
Access-Count
Number of online users.
Default authentication scheme
Default authentication method.
Default authorization scheme
Default authorization method.
Default accounting scheme
Default accounting method.
Login authentication scheme
Authentication method for login users.
Login authorization scheme
Authorization method for login users.
Login accounting scheme
Accounting method for login users.
radius
RADIUS scheme.
tacacs
HWTACACS scheme.
local
Local scheme.
none
No authentication, no authorization, or no accounting.
Command Authorization Scheme
Command line authorization method.
Command Accounting Scheme
Command line accounting method.
Super Authentication Scheme
Authentication method for user role switching.
domain
Use domain to create an ISP domain and enter its view.
Use undo domain to remove an ISP domain.
domain isp-name
undo domain isp-name
There is a system predefined ISP domain named system.
isp-name: ISP domain name, a case-insensitive string of 1 to 24 characters that cannot contain slash (/), back slash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
All ISP domains are in active state when they are created.
You cannot delete the system predefined ISP domain system, and can only modify its configuration.
To delete the ISP domain that is used as the default ISP domain, you must change it to a non-default ISP domain first by using the undo domain default enable command.
# Create ISP domain test and enter its view.
[Sysname-isp-test]
·           display domain
·           domain default enable
·           state
Use domain default enable to specify the default ISP domain. Users without any domain name carried in the usernames are considered in the default domain.
Use undo domain default enable to restore the default.
domain default enable isp-name
The default ISP domain is the system predefined ISP domain system.
There can be only one default ISP domain.
The specified ISP domain must already exist.
# Create an ISP domain named test, and configure it as the default ISP domain.
[Sysname-isp-test] quit
[Sysname] domain default enable test
·           display domain
·           domain
Use state to set the status of an ISP domain.
Use undo state to restore the default.
state { active | block }
undo state
An ISP domain is in active state.
ISP domain view
active: Places the ISP domain in active state to allow the users in the ISP domain to request network services.
block: Places the ISP domain in blocked state to prevent users in the ISP domain from requesting network services.
By blocking an ISP domain, you disable offline users of the domain from requesting network services. The online users are not affected.
# Place the ISP domain test to blocked state.
[Sysname-isp-test] state block
display domain
Local user commands
Use authorization-attribute to configure authorization attributes for a local user or user group. After the local user or a local user in the user group passes authentication, the device assigns these attributes to the user.
Use undo authorization-attribute to restore the default.
authorization-attribute { acl acl-number | callback-number callback-number | idle-cut minute | user-profile profile-name | user-role role-name | vlan vlan-id | work-directory directory-name } *
undo authorization-attribute { acl | callback-number | idle-cut | user-profile | user-role role-name | vlan | work-directory } *
No authorization attribute is configured for a local user or user group.
Local user view, user group view
acl acl-number: Specifies an authorization ACL in the range of 2000 to 5999. After passing authentication, a local user can access the network resources specified by this ACL.
callback-number callback-number: Specifies the authorized PPP callback number. The callback-number argument is a case-sensitive string of 1 to 64 characters. After a local user passes authentication, the device uses this number to call the user. The switch does not support this parameter.
idle-cut minute: Sets the idle timeout period. With the idle cut function enabled, an online user whose idle period exceeds the specified idle timeout period is logged out. The value range for the minute argument is 1 to 120 minutes.
user-profile profile-name: Specifies the authorization user profile. The profile-name argument is a case-sensitive string of 1 to 32 characters. It must start with an English letter and contain only English letters, digits, and underlines. After a user passes authentication and gets online, the device uses the settings in the user profile to restrict the access behavior of the user. For more information about user profiles, see Security Configuration Guide. The switch does not support this parameter.
user-role role-name: Specifies the authorized user role. The role-name argument is a case-sensitive string of 1 to 63 characters. The default user role for a local user created by a network-admin user is network-operator, and the default user role for a local user created by an mdc-admin or level-15 user is mdc-operator. Up to 64 user roles can be specified for a user. For user role-related commands, see Fundamentals Command Reference for RBAC commands. This option is available only in local user view, and is not available in user group view.
vlan vlan-id: Specifies the authorized VLAN. The value range for the vlan-id argument is 1 to 4094. After a passing authentication and being authorized a VLAN, a local user can access only the resources in this VLAN.
work-directory directory-name: Specifies the work directory for FTP, SFTP, or SCP users. The directory-name argument is a case-insensitive string of 1 to 512 characters. The directory must already exist. By default, an FTP, SFTP, or SCP user can access the root directory of the device.
Every configurable authorization attribute has its definite application environments and purposes. Consider the service types of users when assigning authorization attributes:
·           For Telnet and terminal users, only the authorization attribute user-role is effective.
·           For SSH and FTP users, only the authorization attributes user-role and work-directory are effective.
·           For other types of local users, no authorization attribute is effective.
Authorization attributes configured for a user group are intended for all local users in the group. You can group local users to improve configuration and management efficiency. An authorization attribute configured in local user view takes precedence over the same attribute configured in user group view.
To make sure that FTP, SFTP, and SCP users can access the directory after a switchover between the main card and the backup card, do not specify slot information for the work directory.
To make the user have only the user role authorized by this command, use the undo authorization-attribute user-role command to remove the predefined user roles.
# Configure the authorized VLAN of the device management user abc as VLAN 2.
[Sysname] local-user abc class manage
[Sysname-luser-manage-abc] authorization-attribute vlan 2
# Configure the authorized VLAN of user group abc as VLAN 3.
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
·           display local-user
·           display user-group
display local-user
Use display local-user to display the local user configuration and online user statistics.
display local-user [ class { manage | network } | idle-cut { disable | enable } | service-type { dvpn | ftp | lan-access | pad | portal | ppp | ssh | telnet | terminal } | state { active | block } | user-name user-name | vlan vlan-id ]
class: Specifies the local user type.
·           manage: Device management user.
·           network: Network access user. The switch does not support this keyword.
idle-cut { disable | enable }: Specifies local users with the idle cut function disabled or enabled.
service-type: Specifies the local users who use a specified type of service.
·           dvpn: DVPN tunnel users. The switch does not support this keyword.
·           ftp: FTP users.
·           lan-access: LAN users, mainly users accessing the network through an Ethernet, such as 802.1X users. The switch does not support this keyword.
·           pad: X.25 PAD users. The switch does not support this keyword.
·           portal: Portal users. The switch does not support this keyword.
·           ppp: PPP users. The switch does not support this keyword.
·           ssh: SSH users.
·           telnet: Telnet users.
·           terminal: Terminal users, users logging in through a console or AUX port.
state { active | block }: Specifies local users in active or blocked state. A local user in active state can access network services, but a local user in blocked state cannot.
user-name user-name: Specifies all local users using the specified username. The username must be a case-sensitive string of 1 to 55 characters that does not contain the domain name.
vlan vlan-id: Specifies all local users in a VLAN. The value range for the vlan-id argument is 1 to 4094.
If no parameter is specified, the command displays information about all local users.
# Display information about all local users
<Sysname> display local-user
Total 2 local users matched.
Device management user root:
 State:                    Active
 Service Type:             SSH/Telnet/Terminal
 User Group:               system
 Bind Attributes:
 Authorization Attributes:
  Work Directory:          flash:
  User Role List:          network-admin
Device management user jj:
 State:                    Active
 Service Type:             FTP/SSH
 User Group:               system
 Bind Attributes:
  IP Address:              2.2.2.2
  Location Bound:          3/0/2 (slot/subslot/port)
  MAC Address:             0001-0001-0001
  VLAN ID:                 2
  Idle TimeOut:            33 (min)
  ACL Number:              2000
  User Role List:          network-operator, level-0, level-3
Status of the local user: active or blocked.
Service Type
Service types that the local user can use, including FTP, SSH, Telnet, and terminal.
User Group
Group to which the local user belongs.
Bind attributes
Binding attributes of the local user.
Authorization attributes of the local user.
Idle TimeOut
Idle timeout period of the user, in minutes.
Work Directory
Directory that the FTP, SFTP, or SCP user can access.
ACL Number
Authorization ACL of the local user.
VLAN ID
Authorized VLAN of the local user.
User Role List
Authorized roles of the local user.
display user-group
Use display user-group to display the user group configuration.
display user-group [ group-name ]
group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
If no user group name is specified, the command displays the configuration of all user groups.
# Display the configuration of all user groups.
<Sysname> display user-group
Total 2 user groups matched.
The contents of user group system:
The contents of user group jj:
  Idle TimeOut:            2 (min)
  Work Directory:          flash:/
  ACL Number:              2000
  VLAN ID:                 2
Idle TimeOut
Idle timeout period, in minutes.
Work Directory
Directory that FTP/SFTP users in the group can access.
ACL Number
Authorization ACL.
VLAN ID
Authorized VLAN.
group
Use group to assign a local user to a user group.
Use undo group to restore the default.
group group-name
undo group
A local user belongs to the system predefined user group system.
Local user view
group-name: User group name, a case-insensitive string of 1 to 32 characters.
# Assign device management user 111 to user group abc.
[Sysname] local-user 111 class manage
[Sysname-luser-manage-111] group abc
display local-user
local-user
Use local-user to add a local user and enter local user view.
Use undo local-user to remove local users.
local-user user-name [ class { manage | network } ]
undo local-user { user-name class { manage | network } | all [ service-type { dvpn | ftp | lan-access | pad | portal | ppp | ssh | telnet | terminal } | class { manage | network } ] }
No local user exists.
user-name: Name for the local user, a case-sensitive string of 1 to 55 characters that does not contain the domain name. It cannot contain back slash (\), slash (/), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@), and cannot be a, al, or all.
·           manage: Device management user, who can configure and monitor the device after login. Device management users can use FTP, Telnet, SSH, and terminal services.
·           network: Network access user, who accesses network resources through the device. Network access users can use DVPN, LAN, portal, and PPP services. The switch does not support this keyword.
all: Specifies all users.
·           ftp: FTP users.
·           ssh: SSH users.
# Add a device management user named user1.
[Sysname-luser-manage-user1]
·           service-type
password
Use password to configure a password for a local user.
Use undo password to delete the password of a local user.
password [ { cipher | hash | simple } password ]
undo password
There is no password configured for a local user and a local user can pass authentication after entering the correct username and passing attribute checks.
Local user view
cipher: Sets a ciphertext password. The switch does not support this keyword.
hash: Sets a hashed password.
simple: Sets a plaintext password.
password: Specifies the password string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 63 characters. If hash is specified, it must be a string of 1 to 110 characters. If cipher is specified, it must be a ciphertext string of 1 to 117 characters.
If none of the parameters is specified, you enter the interactive mode to set a plaintext password.
A local user with no password configured directly passes authentication after providing the valid local username and attributes. To enhance security, configure a password for each local user.
For secrecy, all passwords, including passwords configured in plain text, are saved in hashed cipher text.
# Set the password of the device management user user1 to 123456 in plain text.
[Sysname-luser-manage-user1] password simple 123456
# Set the password of the device management user test in interactive mode.
[Sysname-luser-manage-test] password
Password:
Confirm :
Updating user information. Please wait... ...
# Set the password of the network access user user2 to getapp in plain text.
[Sysname] local-user user2 class network
[Sysname-luser-network-user2] password simple getapp
·           local-user password-display-mode
service-type
Use service-type to specify the service types that a local user can use.
Use undo service-type to delete service types configured for a local user.
service-type { dvpn | ftp | lan-access | { pad | ssh | telnet | terminal } * | portal | ppp }
undo service-type { dvpn | ftp | lan-access | { pad | ssh | telnet | terminal } * | portal | ppp }
A local user is authorized with no service and cannot use any service.
Local user view
dvpn: Authorizes the user to use the DVPN service. The switch does not support this keyword.
ftp: Authorizes the user to use the FTP service. The user can use the root directory of the FTP server by default. The authorized directory can be modified by using the authorization-attribute work-directory command.
lan-access: Authorizes the user to use the LAN access service. Such users are mainly Ethernet users, for example, 802.1X users. The switch does not support this keyword.
pad: Authorizes the user to use the PAD service. The switch does not support this keyword.
ssh: Authorizes the user to use the SSH service.
telnet: Authorizes the user to use the Telnet service.
terminal: Authorizes the user to use the terminal service, allowing the user to log in from a console or AUX port.
portal: Authorizes the user to use the portal service. The switch does not support this keyword.
ppp: Authorizes the user to use the PPP service. The switch does not support this keyword.
You can assign multiple service types to a user.
# Authorize the device management user user1 to use the Telnet and FTP services.
[Sysname-luser-manage-user1] service-type telnet
[Sysname-luser-manage-user1] service-type ftp
display local-user
Use state to set the status of a local user.
undo state
A local user is in active state.
Local user view
active: Places the local user in active state to allow the local user to request network services.
block: Places the local user in blocked state to prevent the local user from requesting network services.
This command only applies to the local user. It affects no other users.
# Place the device management user user1 to the blocked state.
[Sysname-luser-manage-user1] state block
display local-user
user-group
Use user-group to create a user group and enter its view.
Use undo user-group to delete a user group.
user-group group-name
undo user-group group-name
There is a user group named system in the system.
group-name: Specifies the user group name, a case-insensitive string of 1 to 32 characters.
A user group consists of a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized management of user attributes for the local users in the group. Configurable user attributes are authorization attributes.
A user group with one or more local users cannot be deleted.
The system predefined user group system cannot be deleted but you can modify its configuration.
# Create a user group named abc and enter its view.
display user-group
RADIUS commands
Use accounting-on enable to configure the accounting-on feature.
Use undo accounting-on enable to disable the accounting-on feature.
accounting-on enable [ interval seconds | send send-times ] *
The accounting-on feature is disabled.
RADIUS scheme view
interval seconds: Specifies the time interval for retransmitting an accounting-on packet in seconds, in the range of 1 to 15. The default setting is 3.
send send-times: Specifies the maximum number of accounting-on packet transmission attempts, in the range of 1 to 255. The default setting is 50.
The accounting-on feature enables the device to, after rebooting, automatically send an accounting-on packet to the RADIUS accounting server indicated by the RADIUS scheme to stop accounting for and log out online users.
After executing the accounting-on enable command, execute the save command to make sure that the command takes effect after the device reboots. For information about the save command, see Fundamentals Command Reference.
Parameters set with the accounting-on enable command take effect immediately.
# Enable the accounting-on feature for RADIUS scheme radius1, and set the retransmission interval to 5 seconds and the transmission attempts to 15.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] accounting-on enable interval 5 send 15
Use display radius scheme to display the configuration of RADIUS schemes.
display radius scheme [ radius-scheme-name ]
If no RADIUS scheme is specified, the command displays the configuration of all RADIUS schemes.
# Display the configuration of all RADIUS schemes.
<Sysname> display radius scheme
Total 1 RADIUS schemes
RADIUS Scheme Name  : radius1
  Index : 0
  Primary Auth Server:
    IP  : 2.2.2.2                                  Port: 1812   State: Active
    VPN : vpn1
  Primary Acct Server:
    IP: 1.1.1.1                                    Port: 1813   State: Active
    VPN : Not configured
  Second Auth Server:
    IP: Not configured                             Port: 1812   State: Block
    VPN : vpn1
  Second Acct Server:
    IP: Not configured                             Port: 1813   State: Block
  Security Policy Server:
    Server: 0     IP: 2.2.2.2         VPN: Not configured
    Server: 1     IP: 3.3.3.3         VPN: 2
  Accounting-On function                     : Enabled
    retransmission times                     : 5
    retransmission interval(seconds)         : 2
  Timeout Interval(seconds)                  : 3
  Retransmission Times                       : 3
  Retransmission Times for Accounting Update : 5
  Server Quiet Period(minutes)               : 5
  Realtime Accounting Interval(minutes)      : 22
  NAS IP Address                             : 1.1.1.1
Index
Index number of the RADIUS scheme.
Primary Auth Server
Information about the primary authentication server.
Primary Acct Server
Information about the primary accounting server.
Second Auth Server
Information about the secondary authentication server.
Second Acct Server
Information about the secondary accounting server.
IP
IP address of the server. If no server is configured, this field displays Not configured.
Port
Service port number of the server. If no port number is specified, this field displays the default port number.
Status of the server: active or blocked.
VPN
VPN to which the server belongs. If no VPN is specified for the server, this field displays Not configured.
Server: n
Member ID of the security policy server.
IP
IP address of the security policy server.
VPN
VPN to which the security policy server belongs. If no VPN is specified for the server, this field displays Not configured.
Whether the accounting-on feature is enabled.
Number of accounting-on packet transmission attempts.
Interval at which the device retransmits accounting-on packets, in seconds.
RADIUS server response timeout period, in seconds.
Retransmission times
Maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server.
Maximum number of accounting attempts.
Quiet period for the servers, in minutes.
Interval for sending real-time accounting updates, in minutes.
NAS IP Address
Source IP address for outgoing RADIUS packets.
VPN
VPN to which the RADIUS scheme belongs. If no VPN is specified for the server, this field displays Not configured.
Use display radius statistics to display RADIUS packet statistics.
# Display RADIUS packet statistics.
<Sysname> display radius statistics
                                 Auth.         Acct.       SessCtrl.
          Request Packet:          0             0             0
            Retry Packet:          0             0             -
          Timeout Packet:          0             0             -
        Access Challenge:          0             -             -
           Account Start:          -             0             -
          Account Update:          -             0             -
            Account Stop:          -             0             -
       Terminate Request:          -             -             0
              Set Policy:          -             -             0
    Packet With Response:          0             0             0
 Packet Without Response:          0             0             -
          Access Rejects:          0             -             -
          Dropped Packet:          0             0             0
          Check Failures:          0             0             0
Table 5 Command output
Auth.
Authentication packets.
Acct.
Accounting packets.
SessCtrl.
Session-control packets.
Request Packet
Number of request packets.
Retry Packet
Number of retransmitted request packets.
Timeout Packet
Number of request packets timed out.
Access Challenge
Number of access challenge packets.
Account Start
Number of start-accounting packets.
Account Update
Number of accounting update packets.
Account Stop
Number of stop-accounting packets.
Terminate Request
Number of packets for logging off users forcibly.
Set Policy
Number of packets for updating user authorization information.
Number of packets for which responses were received.
Number of packets for which no responses were received.
Access Rejects
Number of Access-Reject packets.
Dropped Packet
Number of discarded packets.
Check Failures
Number of packets with checksum errors.
Use key to set the shared key for secure RADIUS communication.
Use undo key to restore the default.
key { accounting | authentication } { cipher | simple } string
undo key { accounting | authentication }
No shared key is configured.
RADIUS scheme view
accounting: Sets the shared key for secure RADIUS accounting communication.
authentication: Sets the shared key for secure RADIUS authentication communication.
cipher: Sets a cipher text shared key.
simple: Sets a plain text shared key.
string: Specifies the shared key string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 64 characters. If cipher is specified, it must be a ciphertext string of 1 to 117 characters.
The shared keys configured by using this command apply to all servers in the scheme. The shared keys specified for specific RADIUS servers, if any, take precedence.
The shared keys configured on the device must match those configured on the RADIUS servers.
For secrecy, all shared keys, including shared keys configured in plain text, are saved in cipher text.
# For RADIUS scheme radius1, set the shared key for secure accounting communication to ok in plain text.
[Sysname-radius-radius1] key accounting simple ok
Use nas-ip to specify a source IP address for outgoing RADIUS packets.
Use undo nas-ip to delete a source IP address for outgoing RADIUS packets.
nas-ip { ipv4-address | ipv6 ipv6-address }
undo nas-ip [ ipv6 ]
The source IP address of an outgoing RADIUS packet is that specified by using the radius nas-ip command in system view. If the radius nas-ip command is not configured, the source IP address is the IP address of the outbound interface.
RADIUS scheme view
ipv4-address: Specifies an IPv4 address, which must be an address of the device and cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
The source IP address of the RADIUS packets that a NAS sends must match the IP address of the NAS that is configured on the RADIUS server. A RADIUS server identifies a NAS by its IP address. Upon receiving a RADIUS packet, a RADIUS server checks whether the source IP address of the packet is the IP address of a managed NAS. If yes, the server processes the packet. If not, the server drops the packet.
The setting configured by using the nas-ip command in RADIUS scheme view is effective only for the RADIUS scheme, whereas that configured by using the radius nas-ip command in system view is effective for all RADIUS schemes. The setting in RADIUS scheme view takes precedence.
If no source IP address is specified for outgoing RADIUS packets, packets returned from the server cannot reach the device due to a physical port error. H3C recommends you to configure a loopback interface address as the source IP address for outgoing RADIUS packets.
A RADIUS scheme can have only one source IP address for outgoing RADIUS packets. If you specify a new source IP address for the same RADIUS scheme, the new one overwrites the old one.
# Set the source IP address for outgoing RADIUS packets to 10.1.1.1.
[Sysname-radius-radius1] nas-ip 10.1.1.1
·           display radius scheme
·           radius nas-ip
Use primary accounting to specify the primary RADIUS accounting server.
Use undo primary accounting to remove the configuration.
primary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name ] *
No primary RADIUS accounting server is specified.
RADIUS scheme view
ipv4-address: Specifies the IPv4 address of the primary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS accounting server.
port-number: Specifies the service port number of the primary RADIUS accounting server, a UDP port number in the range of 1 to 65535. The default setting is 1813.
key { cipher | simple } string: Sets the shared key for secure communication with the primary RADIUS accounting server.
·           cipher string: Sets a ciphertext shared key, a case-sensitive ciphertext string of 1 to 117 characters.
·           simple string: Sets a plaintext shared key, a case-sensitive string of 1 to 64 characters.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the primary RADIUS accounting server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary RADIUS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical IP address, port number, and VPN settings.
The shared key configured by using this command takes precedence over that configured by using the key accounting command.
If the specified server resides on an MPLS L3VPN, specify the VPN by using the vpn-instance vpn-instance-name option. The VPN specified by this command takes precedence over the VPN specified for the RADIUS scheme.
If you use the primary accounting command to modify or delete the primary accounting server to which the device is sending a start-accounting request, communication with the primary server times out, and the device looks for an active server with the highest priority for accounting.
If you remove an accounting server being used by online users, the device no longer sends real-time accounting requests and stop-accounting requests for the users and does not buffer the stop-accounting requests. The device can generate incorrect accounting results.
# Specify the primary accounting server with IP address 10.110.1.2, UDP port number 1813, and plaintext shared key 123456 for RADIUS scheme radius1.
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813 key simple 123456
·           key (RADIUS scheme view)
·           secondary accounting
·           vpn-instance (RADIUS scheme view)
Use primary authentication to specify the primary RADIUS authentication server.
Use undo primary authentication to remove the configuration.
primary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name ] *
No primary RADIUS authentication server is specified.
RADIUS scheme view
ipv4-address: Specifies the IPv4 address of the primary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS authentication server.
port-number: Specifies the service port number of the primary RADIUS authentication server, a UDP port number in the range of 1 to 65535. The default setting is 1812.
key { cipher | simple } string: Sets the shared key for secure communication with the primary RADIUS authentication server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the primary RADIUS authentication server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure that the service port and shared key settings of the primary RADIUS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical IP address, port number, and VPN settings.
The shared key configured by this command takes precedence over that configured by using the key authentication command.
If you use the primary authentication command to modify or delete the primary authentication server during an authentication process, communication with the primary server times out, and the device looks for an active server with the highest priority for authentication.
# Specify the primary authentication server with IP address 10.110.1.1, UDP port number 1812, and plaintext shared key hello for RADIUS scheme radius1.
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812 key simple hello
·           secondary authentication
radius nas-ip
Use radius nas-ip to specify a source address for outgoing RADIUS packets.
Use undo radius nas-ip to delete a source address for outgoing RADIUS packets.
radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
The source IP address of an outgoing RADIUS packet is the IP address of the outbound interface.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the source IPv4 address belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. To configure a public-network source IPv4 address, do not specify this option.
The source IP address of RADIUS packets that a NAS sends must match the IP address of the NAS that is configured on the RADIUS server. A RADIUS server identifies a NAS by its IP address. Upon receiving a RADIUS packet, a RADIUS server checks whether the source IP address of the packet is the IP address of a managed NAS. If yes, the server processes the packet. If not, the server drops the packet.
You can specify up to 16 source IP addresses, including zero or one public-network source IPv4 address, zero or one public-network source IPv6 address, and private-network source IP addresses. A newly specified public-network source IP address overwrites the previous one. Each VPN can have at most one private-network source IPv4 address and one private-network source IPv6 address.
The setting configured by the nas-ip command in RADIUS scheme view is only for the RADIUS scheme, whereas that configured by the radius nas-ip command in system view is for all RADIUS schemes. The setting in RADIUS scheme view takes precedence.
# Set the IP address for the device to use as the source address of the RADIUS packets to 129.10.10.1.
[Sysname] radius nas-ip 129.10.10.1
radius scheme
Use radius scheme to create a RADIUS scheme and enter its view.
Use undo radius scheme to delete a RADIUS scheme.
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
No RADIUS scheme is defined.
radius-scheme-name: RADIUS scheme name, a case-insensitive string of 1 to 32 characters.
A RADIUS scheme can be referenced by more than one ISP domain at the same time.
The switch supports at most 16 RADIUS schemes.
# Create a RADIUS scheme named radius1 and enter its view.
Use radius session-control enable to enable the session-control feature.
Use undo radius session-control enable to restore the default.
The session-control feature is disabled.
The session-control feature enables the device to receive RADIUS session-control packets on UDP port 1812 from a RADIUS server that runs on IMC.
# Enable the session-control feature.
[Sysname] radius session-control enable
Use reset radius statistics to clear RADIUS statistics.
# Clear RADIUS statistics.
<Sysname> reset radius statistics
retry
Use retry to set the maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server.
Use undo retry to restore the default.
retry retry-times
undo retry
The maximum number of RADIUS packet transmission attempts is 3.
RADIUS scheme view
retry-times: Maximum number of RADIUS packet transmission attempts, in the range of 1 to 20.
Because RADIUS uses UDP packets to transmit data, the communication is not reliable. If the device does not receive a response to its request from the RADIUS server within the response timeout period, it retransmits the RADIUS request. If the number of transmission attempts exceeds the limit but the device still receives no response from the RADIUS server, the device considers the request a failure.
The maximum number of packet transmission attempts multiplied by the RADIUS server response timeout period cannot be greater than 75.
# Set the maximum number of RADIUS packet transmission attempts to 5 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry 5
·           radius scheme
·           timer response-timeout
Use retry realtime-accounting to set the maximum number of accounting attempts.
Use undo retry realtime-accounting to restore the default.
retry realtime-accounting retry-times
The maximum number of accounting attempts is 5.
RADIUS scheme view
retry-times: Maximum number of accounting attempts, in the range of 1 to 255.
A RADIUS accounting server usually checks whether a user is online by using a timeout timer. If it receives no real-time accounting request for a user in the timeout period from the NAS, it considers that there may be line or device failures and stops accounting for the user. This may happen when some unexpected failure occurs. To cooperate with the RADIUS server, the NAS needs to send real-time accounting requests to the server before the timer on the server expires and to keep pace with the server in disconnecting the user when a failure occurs. The maximum number of accounting attempts, together with some other parameters, controls how the NAS sends accounting requests and enables the NAS to disconnect the user when a failure occurs.
Suppose that the RADIUS server response timeout period is 3 seconds (set with the timer response-timeout command), the maximum number of RADIUS packet transmission attempts is three (set with the retry command), the real-time accounting interval is 12 minutes (set with the timer realtime-accounting command), and the maximum number of accounting attempts is 5 (set with the retry realtime-accounting command). In this case, the device generates an accounting request every 12 minutes, and retransmits the request if it sends the request but receives no response within 3 seconds. If the device receives no response after transmitting the request 3 times, it considers the accounting attempt a failure, and makes another accounting attempt. If 5 consecutive accounting attempts fail, the device cuts the user connection.
# Set the maximum number of accounting attempts to 10 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry realtime-accounting 10
·           retry
·           timer realtime-accounting
Use secondary accounting to specify a secondary RADIUS accounting server.
Use undo secondary accounting to remove a secondary RADIUS accounting server.
secondary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name ] *
undo secondary accounting [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary RADIUS accounting server is specified.
RADIUS scheme view
ipv4-address: Specifies the IPv4 address of the secondary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary RADIUS accounting server.
port-number: Specifies the service port number of the secondary RADIUS accounting server, a UDP port number in the range of 1 to 65535. The default setting is 1813.
key { cipher | simple } string: Sets the shared key for secure communication with the secondary RADIUS accounting server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the secondary RADIUS accounting server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure that the port number and shared key settings of each secondary RADIUS accounting server are the same as those configured on the corresponding server.
You can configure up to 16 secondary RADIUS accounting servers for a RADIUS scheme. With the configuration, if the primary server fails, the device looks for a secondary server in active state (a secondary RADIUS accounting server configured earlier has a higher priority) and tries to communicate with it.
The shared key configured by this command takes precedence over that configured by using the key accounting command.
If you use the secondary accounting command to modify or delete a secondary accounting server to which the device is sending a start-accounting request, communication with the secondary server times out, and the device looks for an active server with the highest priority for accounting.
If you remove an accounting server being used by online users, the device no longer sends real-time accounting requests and stop-accounting requests for the users, and does not buffer the stop-accounting requests.
# For RADIUS scheme radius1, specify a secondary accounting server with the IP address 10.110.1.1 and the UDP port 1813.
[Sysname-radius-radius1] secondary accounting 10.110.1.1 1813
# For RADIUS scheme radius2, specify two secondary accounting servers with the server IP addresses of 10.110.1.1 and 10.110.1.2 and the UDP port number of 1813.
[Sysname] radius scheme radius2
[Sysname-radius-radius2] secondary accounting 10.110.1.1 1813
[Sysname-radius-radius2] secondary accounting 10.110.1.2 1813
·           primary accounting
secondary authentication (RADIUS scheme view)
Use secondary authentication to specify a secondary RADIUS authentication server.
Use undo secondary authentication to remove a secondary RADIUS authentication server.
secondary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name ] *
undo secondary authentication [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary RADIUS authentication server is specified.
RADIUS scheme view
ipv4-address: Specifies the IPv4 address of the secondary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary RADIUS authentication server.
port-number: Sets the service port number of the secondary RADIUS authentication server, a UDP port number in the range of 1 to 65535. The default setting is 1812.
key { cipher | simple } string: Sets the shared key for secure communication with the secondary RADIUS authentication server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the secondary RADIUS authentication server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure that the port number and shared key settings of each secondary RADIUS authentication server are the same as those configured on the corresponding server.
You can configure up to 16 secondary RADIUS authentication servers for a RADIUS scheme. With the configuration, if the primary server fails, the device looks for a secondary server in active state (a secondary RADIUS authentication server configured earlier has a higher priority) and tries to communicate with it.
If you use the secondary authentication command to modify or delete a secondary authentication server during an authentication process, communication with the secondary server times out, and the device looks for an active server with the highest priority for authentication.
# For RADIUS scheme radius1, specify a secondary authentication server with the IP address 10.110.1.2 and the UDP port 1812.
[Sysname-radius-radius1] secondary authentication 10.110.1.2 1812
# Specify two secondary authentication servers for RADIUS scheme radius2, with the server IP addresses of 10.110.1.1 and 10.110.1.2, and the UDP port number of 1812.
[Sysname-radius-radius2] secondary authentication 10.110.1.1 1812
[Sysname-radius-radius2] secondary authentication 10.110.1.2 1812
·           primary authentication
state primary
Use state primary to set the status of a primary RADIUS server.
state primary { accounting | authentication } { active | block }
The primary RADIUS server specified for a RADIUS scheme is in active state.
RADIUS scheme view
accounting: Sets the status of the primary RADIUS accounting server.
authentication: Sets the status of the primary RADIUS authentication server.
active: Specifies the active state, the normal operation state.
block: Specifies the blocked state, the out-of-service state.
During an authentication or accounting process, the device first tries to communicate with the primary server if the primary server is in active state. If the primary server is unavailable, the device changes the status of the primary server to blocked, starts a quiet timer for the server, and then tries to communicate with a secondary server in active state (a secondary RADIUS server configured earlier has a higher priority). When the quiet timer of the primary server times out, the status of the server changes to active automatically. If you set the status of the server to blocked before the quiet timer times out, the status of the server cannot change back to active automatically unless you set the status to active manually.
When the primary server and all secondary servers are in blocked state, authentication or accounting fails.
# Set the status of the primary authentication server in RADIUS scheme radius1 to blocked.
[Sysname-radius-radius1] state primary authentication block
·           state secondary
state secondary
Use state secondary to set the status of a secondary RADIUS server.
state secondary { accounting | authentication } [ ip-address [ port-number | vpn-instance vpn-instance-name ] * ] { active | block }
Every secondary RADIUS server specified in a RADIUS scheme is in active state.
RADIUS scheme view
accounting: Sets the status of a secondary RADIUS accounting server.
authentication: Sets the status of a secondary RADIUS authentication server.
ip-address: Specifies the IPv4 address of a secondary RADIUS server.
port-number: Service port number of a secondary RADIUS server, a UDP port number in the range of 1 to 65535. The default port number of a secondary accounting server is 1813 and that of a secondary authentication is 1812.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the secondary RADIUS server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters.
If no IP address is specified, this command changes the status of all configured secondary RADIUS servers.
If the device finds that a secondary server in active state is unreachable, the device changes the status of the secondary server to blocked, starts a quiet timer for the server, and continues to try to communicate with the next secondary server in active state (a secondary RADIUS server configured earlier has a higher priority). When the quiet timer of a server times out, the status of the server changes to active automatically. If you set the status of the server to blocked before the quiet timer times out, the status of the server cannot change back to active automatically unless you set the status to active manually. If all configured secondary servers are unreachable, the device considers the authentication or accounting attempt a failure.
# Set the status of all the secondary authentication servers in RADIUS scheme radius1 to blocked.
[Sysname-radius-radius1] state secondary authentication block
·           state primary
timer quiet (RADIUS scheme view)
Use timer quiet to set the quiet timer for the servers specified in an RADIUS scheme.
Use undo timer quiet to restore the default.
timer quiet minutes
undo timer quiet
The server quiet period is 5 minutes.
RADIUS scheme view
minutes: Server quiet period in minutes, in the range of 1 to 255.
Be sure to set the server quiet timer properly. Too short a quiet timer may result in frequent authentication or accounting failures because the device keeps trying to communicate with an unreachable server that is in active state.
# Set the quiet timer for the servers to 10 minutes.
[Sysname-radius-radius1] timer quiet 10
timer realtime-accounting (RADIUS scheme view)
Use timer realtime-accounting to set the real-time accounting interval.
Use undo timer realtime-accounting to restore the default.
timer realtime-accounting minutes
The real-time accounting interval is 12 minutes.
RADIUS scheme view
minutes: Real-time accounting interval in minutes, in the range of 0 to 60.
When the real-time accounting interval configured on the device is not zero, the device sends online user accounting information to the RADIUS accounting server at the configured interval. When the real-time accounting interval on the device is zero, the device sends online user accounting information to the RADIUS accounting server at the real-time accounting interval configured on the server (if any) or does not send online user accounting information.
Different real-time accounting intervals impose different performance requirements on the device and the RADIUS server. A shorter interval helps achieve higher accounting precision but requires higher performance. Use a longer interval when there are a large number of users (1000 or more).
Table 6 Recommended real-time accounting intervals
Number of users
1 to 99
3 minutes
100 to 499
6 minutes
500 to 999
12 minutes
1000 or more
15 minutes or longer
# Set the real-time accounting interval to 51 minutes for RADIUS scheme radius1.
[Sysname-radius-radius1] timer realtime-accounting 51
timer response-timeout (RADIUS scheme view)
Use timer response-timeout to set the RADIUS server response timeout timer.
Use undo timer response-timeout to restore the default.
timer response-timeout seconds
The RADIUS server response timeout period is 3 seconds.
RADIUS scheme view
seconds: RADIUS server response timeout period in seconds, in the range of 1 to 10.
If a NAS receives no response from the RADIUS server in a period of time after sending a RADIUS request, it resends the request so that the user has more opportunity to obtain the RADIUS service. The NAS uses the RADIUS server response timeout timer to control the transmission interval.
The maximum number of RADIUS packet transmission attempts multiplied by the RADIUS server response timeout period cannot be greater than 75.
# Set the RADIUS server response timeout timer to 5 seconds for RADIUS scheme radius1.
[Sysname-radius-radius1] timer response-timeout 5
·           retry
user-name-format (RADIUS scheme view)
Use user-name-format to specify the format of the username to be sent to a RADIUS server.
Use undo user-name-format to restore the default.
user-name-format { keep-original | with-domain | without-domain }
The ISP domain name is included in the username.
RADIUS scheme view
keep-original: Sends the username to the RADIUS server as it is entered.
with-domain: Includes the ISP domain name in the username sent to the RADIUS server.
without-domain: Excludes the ISP domain name from the username sent to the RADIUS server.
A username is generally in the format userid@isp-name, of which isp-name is used by the device to determine the ISP domain to which a user belongs. Some earlier RADIUS servers, however, cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such a RADIUS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username sent to a RADIUS server.
If a RADIUS scheme defines that the username is sent without the ISP domain name, do not apply the RADIUS scheme to more than one ISP domain. The RADIUS server regards two users in different ISP domains but with the same userid as one.
# Configure the device to remove the domain name from the username sent to the RADIUS servers specified in RADIUS scheme radius1.
[Sysname-radius-radius1] user-name-format without-domain
Use vpn-instance to specify a VPN for a RADIUS scheme.
Use undo vpn-instance to remove the configuration.
undo vpn-instance
The RADIUS scheme belongs to the public network.
RADIUS scheme view
vpn-instance-name: Name of the MPLS L3VPN, a case-sensitive string of 1 to 31 characters.
The VPN specified here applies to all servers in the RADIUS scheme for which no VPN is specified.
# Specify VPN test for RADIUS scheme radius1.
[Sysname-radius-radius1] vpn-instance test
HWTACACS commands
display hwtacacs scheme
Use display hwtacacs scheme to display the configuration or statistics of HWTACACS schemes.
display hwtacacs scheme [ hwtacacs-scheme-name [ statistics ] ]
hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
statistics: Displays the HWTACACS service statistics. If this option is not specified, the command displays the configuration of the HWTACACS scheme.
If no HWTACACS scheme name is specified, the command displays the configuration of all HWTACACS schemes.
# Displays the configuration of all HWTACACS schemes.
<Sysname> display hwtacacs scheme
Total 1 TACACS schemes
HWTACACS Scheme Name  : hwtac
  Index : 0
    IP  : 2.2.2.2         Port: 49     State: Active
    VPN Instance: 2
  Primary Author Server:
    VPN Instance: 2
    IP  : Not Configured  Port: 49     State: Block
    VPN Instance: Not configured
  VPN Instance                          : 2
  NAS IP Address                        : 2.2.2.3
  Realtime Accounting Interval(minutes) : 12
  Response Timeout Interval(seconds)    : 5
  Username Format                       : with-domain
Table 7 Command output
Index
Index number of the HWTACACS scheme.
Primary Auth Server
Primary HWTACACS authentication server.
Primary HWTACACS authorization server.
Primary Acct Server
Primary HWTACACS accounting server.
Secondary Auth Server
Secondary HWTACACS authentication server.
Secondary Author Server
Secondary HWTACACS authorization server.
Secondary Acct Server
Secondary HWTACACS accounting server.
IP
IP address of the HWTACACS server. If no server is configured, this field displays Not configured.
Port
Service port of the HWTACACS server. If no port configuration is performed, this field displays the default port number.
Status of the HWTACACS server: active or blocked.
VPN Instance
MPLS L3VPN to which the HWTACACS server or scheme belongs. If no VPN is specified for the server or scheme, this field displays Not configured.
NAS IP Address
Source IP address for outgoing HWTACACS packets.
Server Quiet Period
Quiet period for the primary servers, in minutes.
Real-time accounting interval, in minutes.
HWTACACS server response timeout period, in seconds.
Username Format
Format for the usernames sent to the HWTACACS server. Possible values include:
·       With-domain—Includes the domain name.
·       Without-domain—Excludes the domain name.
·       Keep-original—Forwards the username as it is entered.
reset hwtacacs statistics
hwtacacs nas-ip
Use hwtacacs nas-ip to specify a source IP address for outgoing HWTACACS packets.
Use undo hwtacacs nas-ip to delete a source IP address for outgoing HWTACACS packets.
hwtacacs nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo hwtacacs nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
The source IP address of a packet sent to the server is the IP address of the outbound interface.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the source IP address belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. To configure a public-network source IPv4 address, do not specify this option.
The source IP address of HWTACACS packets that a NAS sends must match the IP address of the NAS that is configured on the HWTACACS server. An HWTACACS server identifies a NAS by IP address. Upon receiving an HWTACACS packet, an HWTACACS server checks whether the source IP address of the packet is the IP address of a managed NAS. If yes, the server processes the packet. If not, the server drops the packet.
The setting configured by using the nas-ip command in HWTACACS scheme view is only for the HWTACACS scheme, whereas that configured by using the hwtacacs nas-ip command in system view is for all HWTACACS schemes. The setting in HWTACACS scheme view takes precedence.
# Set the IP address for the device to use as the source address for HWTACACS packets to 129.10.10.1.
[Sysname] hwtacacs nas-ip 129.10.10.1
nas-ip
hwtacacs scheme
Use hwtacacs scheme to create an HWTACACS scheme and enter its view.
Use undo hwtacacs scheme to delete an HWTACACS scheme.
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
No HWTACACS scheme exists.
hwtacacs-scheme-name: HWTACACS scheme name, a case-insensitive string of 1 to 32 characters.
An HWTACACS scheme can be referenced by more than one ISP domain at the same time.
You can configure up to 16 HWTACACS schemes.
# Create an HWTACACS scheme named hwt1 and enter its view.
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1]
key (HWTACACS scheme view)
Use key to set the shared key for secure HWTACACS authentication, authorization, or accounting communication.
Use undo key to remove the configuration.
key { accounting | authentication | authorization } { cipher | simple } string
undo key { accounting | authentication | authorization } string
accounting: Sets the shared key for secure HWTACACS accounting communication.
authentication: Sets the shared key for secure HWTACACS authentication communication.
authorization: Sets the shared key for secure HWTACACS authorization communication.
cipher: Sets a ciphertext shared key.
simple: Sets a plaintext shared key.
string: Specifies the shared key string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 255 characters. If cipher is specified, it must be a ciphertext string of 1 to 373 characters.
The shared keys configured on the device must match those configured on the HWTACACS servers.
# Set the shared key for secure HWTACACS authentication communication to 123456 in plain text for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] key authentication simple 123456
# Set the shared key for secure HWTACACS authorization communication to ok in plain text.
[Sysname-hwtacacs-hwt1] key authorization simple ok
# Set the shared key for secure HWTACACS accounting communication to hello in plain text.
[Sysname-hwtacacs-hwt1] key accounting simple hello
nas-ip (HWTACACS scheme view)
Use nas-ip to specify a source address for outgoing HWTACACS packets.
Use undo nas-ip to delete a source address for outgoing HWTACACS packets.
The source IP address of an outgoing HWTACACS packet is that configured by using the hwtacacs nas-ip command in system view. If the hwtacacs nas-ip command is not configured, the source IP address is the IP address of the outbound interface.
The source IP address of the HWTACACS packets that a NAS sends must match the IP address of the NAS that is configured on the HWTACACS server. An HWTACACS server identifies a NAS by IP address. Upon receiving an HWTACACS packet, an HWTACACS server checks whether the source IP address of the packet is the IP address of a managed NAS. If yes, the server processes the packet. If not, the server drops the packet.
The setting configured by using the nas-ip command in HWTACACS scheme view is effective only for the HWTACACS scheme, whereas that configured by using the hwtacacs nas-ip command in system view is effective for all HWTACACS schemes. The setting in HWTACACS scheme view takes precedence.
If you execute the command multiple times, the most recent configuration takes effect.
# Set the source address for outgoing HWTACACS packets to 10.1.1.1 for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
hwtacacs nas-ip
primary accounting (HWTACACS scheme view)
Use primary accounting to specify the primary HWTACACS accounting server.
No primary HWTACACS accounting server is specified.
ipv4-address: Specifies an IPv4 address of the primary HWTACACS accounting server.
ipv6 ipv6-address: Specifies an IPv6 address of the primary HWTACACS accounting server.
port-number: Specifies the service port number of the primary HWTACACS accounting server, a TCP port number in the range of 1 to 65535. The default setting is 49.
key { cipher | simple } string: Sets the shared key for secure communication with the primary HWTACACS accounting server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the primary HWTACACS accounting server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure that the port number and shared key settings of the primary HWTACACS accounting server are the same as those configured on the server.
If the specified server resides on an MPLS L3VPN, specify the VPN by using the vpn-instance vpn-instance-name option. The VPN specified by this command takes precedence over the VPN specified for the HWTACACS scheme.
You can remove an accounting server only when it is not used for user accounting. Removing an accounting server affects only accounting processes that occur after the remove operation.
# Specify the primary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456 for HWTACACS scheme test1.
[Sysname] hwtacacs scheme test1
[Sysname-hwtacacs-test1] primary accounting 10.163.155.12 49 key simple 123456
·           display hwtacacs scheme
·           key (HWTACACS scheme view)
·           vpn-instance (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
Use primary authentication to specify the primary HWTACACS authentication server.
No primary HWTACACS authentication server is specified.
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authentication server.
port-number: Specifies the service port number of the primary HWTACACS authentication server, a TCP port number in the range of 1 to 65535. The default setting is 49.
key { cipher | simple } string: Sets the shared key for secure communication with the primary HWTACACS authentication server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the primary HWTACACS authentication server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure that the port number and shared key settings of the primary HWTACACS authentication server are the same as those configured on the server.
You can remove an authentication server only when it is not used for user authentication. Removing an authentication server affects only authentication processes that occur after the remove operation.
# Specify the primary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key abc for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49 key simple abc
primary authorization
Use primary authorization to specify the primary HWTACACS authorization server.
Use undo primary authorization to remove the configuration.
primary authorization { ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name ] *
No primary HWTACACS authorization server is specified.
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authorization server.
port-number: Specifies the service port number of the primary HWTACACS authorization server, a TCP port number in the range of 1 to 65535. The default setting is 49.
key { cipher | simple } string: Sets the shared key for secure communication with the primary HWTACACS authorization server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the primary HWTACACS authorization server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure that the port number and shared key settings of the primary HWTACACS authorization server are the same as those configured on the server.
Two authorization servers specified for a scheme, primary or secondary, cannot have identical IP address, port number, and VPN settings.
You can remove an authorization server only when it is not used for user authorization. Removing an authorization server affects only authorization processes that occur after the remove operation.
# Specify the primary accounting server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key abc for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49 key simple abc
·           secondary authorization
Use reset hwtacacs statistics to clear HWTACACS statistics.
reset hwtacacs statistics { accounting | all | authentication | authorization }
accounting: Clears the HWTACACS accounting statistics.
all: Clears all HWTACACS statistics.
authentication: Clears the HWTACACS authentication statistics.
authorization: Clears the HWTACACS authorization statistics.
# Clear all HWTACACS statistics.
<Sysname> reset hwtacacs statistics all
secondary accounting (HWTACACS scheme view)
Use secondary accounting to specify a secondary HWTACACS accounting server.
Use undo secondary accounting to remove a secondary HWTACACS accounting server.
No secondary HWTACACS accounting server is specified.
ipv4-address: Specifies the IPv4 address of the secondary HWTACACS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary HWTACACS accounting server.
port-number: Specifies the service port number of the secondary HWTACACS accounting server, a TCP port number in the range of 1 to 65535. The default setting is 49.
key { cipher | simple } string: Specifies the shared key for secure communication with the secondary HWTACACS accounting server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the secondary HWTACACS accounting server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure that the port number and shared key settings of the secondary HWTACACS accounting server are the same as those configured on the server.
You can configure up to 16 secondary HWTACACS accounting servers for an HWTACACS scheme. With the configuration, if the primary server fails, the device looks for a secondary server in active state (a secondary HWTACACS accounting server configured earlier has a higher priority) and tries to communicate with it.
If you use the undo secondary accounting command without specifying any parameter, the command removes all secondary accounting servers.
# Specify a secondary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key abc for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49 key simple abc
secondary authentication (HWTACACS scheme view)
Use secondary authentication to specify a secondary HWTACACS authentication server.
Use undo secondary authentication to remove a secondary HWTACACS authentication server.
secondary authentication { ipv4-address | ipv6 ipv6-address } [ port-number I key { cipher | simple } string | vpn-instance vpn-instance-name ] *
undo secondary authentication [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ]* ]
No secondary HWTACACS authentication server is specified.
ipv4-address: Specifies the IPv4 address of the secondary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary HWTACACS authentication server.
port-number: Specifies the service port number of the secondary HWTACACS authentication server, a TCP port number in the range of 1 to 65535. The default setting is 49.
key { cipher | simple } string: Sets the shared key for secure communication with the secondary HWTACACS authentication server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the secondary HWTACACS authentication server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure that the port number and shared key settings of each secondary HWTACACS authentication server are the same as those configured on the corresponding server.
You can configure up to 16 secondary HWTACACS authentication servers for an HWTACACS scheme. With the configuration, if the primary server fails, the device looks for a secondary server in active state (a secondary HWTACACS authentication server configured earlier has a higher priority) and tries to communicate with it.
If you use the undo secondary authentication command without specifying any parameter, the command removes all secondary authentication servers.
# Specify a secondary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key abc for HWTACACS scheme hwt1
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49 key simple abc
Use secondary authorization to specify a secondary HWTACACS authorization server.
Use undo secondary authorization to remove a secondary HWTACACS authorization server.
secondary authorization { ipv4-address | ipv6 ipv6-address } [ port-number I key { cipher | simple } string | vpn-instance vpn-instance-name ] *
undo secondary authorization [ { ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ]* ]
No secondary HWTACACS authorization server is specified.
ipv4-address: Specifies the IPv4 address of the secondary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of the secondary HWTACACS authorization server.
port-number: Specifies the service port number of the secondary HWTACACS authorization server, a TCP port number in the range of 1 to 65535. The default setting is 49.
key { cipher | simple } string: Sets the shared key for secure communication with the secondary HWTACACS authorization server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the secondary HWTACACS authorization server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure that the port number and shared key settings of the secondary HWTACACS authorization server are the same as those configured on the server.
You can configure up to 16 secondary HWTACACS authorization servers for an HWTACACS scheme. With the configuration, if the primary server fails, the device looks for a secondary server in active state (a secondary HWTACACS authorization server configured earlier has a higher priority) and tries to communicate with it.
If you use the undo secondary authorization command without specifying any parameter, the command removes all secondary authorization servers.
# Specify a secondary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key abc for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49 key simple abc
·           primary authorization
timer quiet (HWTACACS scheme view)
Use timer quiet to set the quiet timer for the servers specified in an HWTACACS scheme.
timer quiet minutes
undo timer quiet
# Set the server quiet timer to 10 minutes.
[Sysname-hwtacacs-hwt1] timer quiet 10
timer realtime-accounting (HWTACACS scheme view)
minutes: Real-time accounting interval in minutes, in the range of 0 to 60. Setting this interval to 0 disables the device from sending online user accounting information to the HWTACACS accounting server.
For real-time accounting, a NAS must transmit the accounting information of online users to the HWTACACS accounting server periodically. This command is used to set the interval.
Different real-time accounting intervals impose different performance requirements on the device and the HWTACACS server. A shorter interval helps achieve higher accounting precision but requires higher performance. Use a longer interval when there are a large number of users (1000 or more).
Table 8 Recommended real-time accounting intervals
Number of users
1 to 99
3 minutes
100 to 499
6 minutes
500 to 999
12 minutes
1000 or more
# Set the real-time accounting interval to 51 minutes for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] timer realtime-accounting 51
timer response-timeout (HWTACACS scheme view)
Use timer response-timeout to set the HWTACACS server response timeout timer.
The HWTACACS server response timeout time is 5 seconds.
seconds: HWTACACS server response timeout time in seconds, in the range of 1 to 300.
HWTACACS is based on TCP. When the server response timeout timer or the TCP timeout timer times out, the device is disconnected from the HWTACACS server.
# Set the HWTACACS server response timeout timer to 30 seconds for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] timer response-timeout 30
user-name-format (HWTACACS scheme view)
Use user-name-format to specify the format of the username to be sent to an HWTACACS server.
keep-original: Sends the username to the HWTACACS server as it is entered.
with-domain: Includes the ISP domain name in the username sent to the HWTACACS server.
without-domain: Excludes the ISP domain name from the username sent to the HWTACACS server.
A username is generally in the format userid@isp-name, of which isp-name is used by the device to determine the ISP domain to which a user belongs. However, some HWTACACS servers cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such an HWTACACS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username to be sent to an HWTACACS server.
If an HWTACACS scheme defines that the username is sent without the ISP domain name, do not apply the HWTACACS scheme to more than one ISP domain. The HWTACACS server regards two users in different ISP domains but with the same userid as one.
# Configure the device to remove the ISP domain name from the username sent to the HWTACACS servers specified in HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] user-name-format without-domain
Use vpn-instance to specify a VPN for an HWTACACS scheme.
undo vpn-instance
The HWTACACS scheme belongs to the public network.
The VPN specified here takes effect for all servers in the HWTACACS scheme for which no VPN is specified.
# Specify VPN test for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] vpn-instance test
