08-IP Multicast Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18208-IP Multicast Command Reference
06-PIM Commands
06-PIM Commands 336.59 KB
PIM configuration commands 1
auto-rp enable· 1
bidir-pim enable (PIM view) 1
bsm-fragment enable (PIM view) 2
bsr-policy (PIM view) 3
c-bsr (PIM view) 4
c-bsr admin-scope (PIM view) 5
c-bsr global 5
c-bsr group· 6
c-bsr hash-length (PIM view) 7
c-bsr holdtime (PIM view) 8
c-bsr interval (PIM view) 8
c-bsr priority (PIM view) 9
c-rp (PIM view) 10
c-rp advertisement-interval (PIM view) 11
c-rp holdtime (PIM view) 12
crp-policy (PIM view) 12
display pim bsr-info· 13
display pim claimed-route· 15
display pim control-message counters 17
display pim df-info· 19
display pim grafts 20
display pim interface· 21
display pim join-prune· 23
display pim neighbor 25
display pim routing-table· 27
display pim rp-info· 31
hello-option dr-priority (PIM view) 32
hello-option holdtime (PIM view) 33
hello-option lan-delay (PIM view) 34
hello-option neighbor-tracking (PIM view) 34
hello-option override-interval (PIM view) 35
holdtime assert (PIM view) 36
holdtime join-prune (PIM view) 36
jp-pkt-size (PIM view) 37
jp-queue-size (PIM view) 38
pim·· 39
pim bfd enable· 39
pim bsr-boundary· 40
pim dm·· 41
pim hello-option dr-priority· 41
pim hello-option holdtime· 42
pim hello-option lan-delay· 43
pim hello-option neighbor-tracking· 43
pim hello-option override-interval 44
pim holdtime assert 44
pim holdtime join-prune· 45
pim neighbor-policy· 46
pim require-genid· 46
pim sm·· 47
pim state-refresh-capable· 48
pim timer graft-retry· 48
pim timer hello· 49
pim timer join-prune· 49
pim triggered-hello-delay· 50
probe-interval (PIM view) 50
prune delay (PIM view) 51
register-policy (PIM view) 52
register-suppression-timeout (PIM view) 53
register-whole-checksum (PIM view) 53
reset pim control-message counters 54
source-lifetime (PIM view) 55
source-policy (PIM view) 55
spt-switch-threshold (PIM view) 56
ssm-policy (PIM view) 57
state-refresh-interval (PIM view) 58
state-refresh-rate-limit (PIM view) 59
state-refresh-ttl 59
static-rp (PIM view) 60
timer hello (PIM view) 61
timer join-prune (PIM view) 62
The term "router" in this document refers to both routers and Layer 3 switches.
auto-rp enable
auto-rp enable
undo auto-rp enable
View
Public network PIM view, VPN instance PIM view
Default level
2: System level
None
Use auto-rp enable to enable auto-RP.
Use undo auto-rp enable to disable auto-RP.
By default, auto-RP is disabled.
Related commands: static-rp.
# Enable auto-RP on the public network.
[Sysname] pim
[Sysname-pim] auto-rp enable
# Enable auto-RP in VPN instance mvpn.
[Sysname] pim vpn-instance mvpn
[Sysname-pim-mvpn] auto-rp enable
bidir-pim enable
undo bidir-pim enable
View
Default level
2: System level
None
Use bidir-pim enable to enable BIDIR-PIM.
Use undo bidir-pim enable to disable BIDIR-PIM.
By default, BIDIR-PIM is disabled.
This command takes effect only after multicast routing is enabled.
When the system is operating in standard mode, BIDIR-PIM is not supported. For more information about the system operating mode, see Fundamentals Configuration Guide.
Related commands: pim and multicast routing-enable.
# Enable multicast routing on the public network, enter PIM view, and enable BIDIR-PIM.
[Sysname] multicast routing-enable
[Sysname] pim
[Sysname-pim] bidir-pim enable
# Enable multicast routing in VPN instance mvpn, enter VPN instance PIM view, and enable BIDIR-PIM.
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] route-distinguisher 100:1
[Sysname-vpn-instance-mvpn] multicast routing-enable
[Sysname-vpn-instance-mvpn] quit
[Sysname-pim-mvpn] bidir-pim enable
bsm-fragment enable
undo bsm-fragment enable
View
Default level
2: System level
None
Use bsm-fragment enable to enable bootstrap message (BSM) semantic fragmentation.
Use undo bsm-fragment enable to disable BSM semantic fragmentation.
By default, BSM semantic fragmentation is enabled.
Disable the BSM semantic fragmentation function if devices not supporting this function exist in the PIM-SM domain.
Related commands: c-bsr admin-scope.
# Disable BSM semantic fragmentation on the public network.
[Sysname] pim
[Sysname-pim] undo bsm-fragment enable
# Disable BSM semantic fragmentation in VPN instance mvpn.
[Sysname-pim-mvpn] undo bsm-fragment enable
bsr-policy acl-number
undo bsr-policy
View
Default level
2: System level
acl-number: Specifies a basic ACL number in the range of 2000 to 2999. When an ACL is defined, the source keyword in the rule command specifies a legal BSR source address range.
Use bsr-policy to configure a legal BSR address range to guard against BSR spoofing.
Use undo bsr-policy to remove the restriction of the BSR address range.
By default, no restrictions are defined for the BSR address range. The bootstrap messages from any source are regarded to be valid.
# Configure a legal BSR address range on the public network so that only devices on the segment 10.1.1.0/24 can become the BSR.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.1.1.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] pim
[Sysname-pim] bsr-policy 2000
# Configure a legal BSR address range in VPN instance mvpn so that only devices on the segment 10.1.1.0/24 can become the BSR.
[Sysname-pim-mvpn] bsr-policy 2000
c-bsr (PIM view)
c-bsr interface-type interface-number [ hash-length [ priority ] ]
undo c-bsr
View
Default level
2: System level
hash-length: Specifies a hash mask length in the range of 0 to 32. If this argument is not specified, the corresponding global setting is used.
priority: Specifies the priority of the C-BSR, in the range of 0 to 255. A larger value represents a higher priority. If this argument is not specified, the corresponding global setting is used.
Use c-bsr to configure the specified interface as a C-BSR.
Use undo c-bsr to remove the related C-BSR configuration.
No C-BSR is configured by default.
PIM-SM must be enabled on the interface to be configured as a C-BSR.
Related commands: c-bsr hash-length, c-bsr priority, c-rp, and pim sm.
# Configure VLAN-interface 100 on the public network to be a C-BSR.
[Sysname] pim
[Sysname-pim] c-bsr vlan-interface 100
# Configure VLAN-interface 100 in VPN instance mvpn to be a C-BSR.
[Sysname-pim-mvpn] c-bsr vlan-interface 100
c-bsr admin-scope
undo c-bsr admin-scope
View
Default level
2: System level
None
Use c-bsr admin-scope to enable administrative scoping.
Use undo c-bsr admin-scope to disable administrative scoping.
By default, BSR administrative scoping is disabled and only one BSR exists in a PIM-SM domain.
Related commands: c-bsr, c-bsr global, and c-bsr group.
# Enable administrative scoping on the public network.
[Sysname] pim
[Sysname-pim] c-bsr admin-scope
# Enable administrative scoping in VPN instance mvpn.
[Sysname-pim-mvpn] c-bsr admin-scope
c-bsr global
c-bsr global [ hash-length hash-length | priority priority ] *
undo c-bsr global
View
Default level
2: System level
hash-length: Specifies a hash mask length in the global scope zone, in the range of 0 to 32. If this argument is not specified, the corresponding global setting is used.
priority: Specifies the priority of the C-BSR in the global scope zone, in the range of 0 to 255. A larger value represents a higher priority. If this argument is not specified, the corresponding global setting is used.
Use c-bsr global to configure a C-BSR for the global scope zone.
Use undo c-bsr global to remove the C-BSR configuration for the global scope zone.
By default, no C-BSRs are configured for the global scope zone.
Related commands: c-bsr group, c-bsr hash-length, and c-bsr priority.
# Configure the device to be a C-BSR for the global scope zone on the public network, with the priority of 1.
[Sysname] pim
[Sysname-pim] c-bsr global priority 1
# Configure the device to be a C-BSR for the global scope zone in VPN instance mvpn, with the priority of 1.
[Sysname-pim-mvpn] c-bsr global priority 1
c-bsr group
c-bsr group group-address { mask | mask-length } [ hash-length hash-length | priority priority ] *
undo c-bsr group group-address
View
Default level
2: System level
group-address: Specifies a multicast group address in the range of 239.0.0.0 to 239.255.255.255.
mask: Specifies the address mask.
mask-length: Specifies the address mask length in the range of 8 to 32.
hash-length: Specifies a hash mask length in the admin-scope region corresponding to the specified multicast group, in the range of 0 to 32. If this argument is not specified, the corresponding global setting is used.
priority: Specifies the priority of the C-BSR in the admin-scope region corresponding to a multicast group, in the range of 0 to 255. A larger value represents a higher priority. If this argument is not specified, the corresponding global setting is used.
Use c-bsr group to configure a C-BSR for the admin-scope region associated with the specified group.
Use undo c-bsr group to remove the C-BSR configuration for the admin-scope region associated with the specified group.
By default, no C-BSRs are configured for admin-scope regions.
Related commands: c-bsr admin-scope, c-bsr global, c-bsr hash-length, and c-bsr priority.
# In the public network, configure the device to be a C-BSR in the admin-scope region associated with the multicast group address 239.0.0.0/8, with the priority of 10.
[Sysname] pim
[Sysname-pim] c-bsr group 239.0.0.0 255.0.0.0 priority 10
# In VPN instance mvpn, configure the device to be a C-BSR in the admin-scope region associated with the multicast group address 239.0.0.0/8, with the priority of 10.
[Sysname-pim-mvpn] c-bsr group 239.0.0.0 255.0.0.0 priority 10
c-bsr hash-length hash-length
undo c-bsr hash-length
View
Default level
2: System level
Use c-bsr hash-length to configure the global hash mask length.
Use undo c-bsr hash-length to restore the default.
By default, the hash mask length is 30.
# Set the global hash mask length to 16 on the public network.
[Sysname] pim
[Sysname-pim] c-bsr hash-length 16
# Set the global hash mask length to 16 in VPN instance mvpn.
[Sysname-pim-mvpn] c-bsr hash-length 16
c-bsr holdtime interval
undo c-bsr holdtime
View
Default level
2: System level
interval: Specifies a BS timeout value in seconds, in the range of 1 to 2147483647.
Use c-bsr holdtime to configure the BS timeout (length of time that a C-BSR waits before it must receive a bootstrap message from the BSR).
Use undo c-bsr holdtime to restore the default.
By default, the bootstrap timeout value is determined by this formula: BS timeout = BS period × 2 + 10.
The default BS period is 60 seconds, so the default BS timeout = 60 × 2 + 10 = 130 (seconds).
Related commands: c-bsr and c-bsr interval.
# Set the BS timeout time to 150 seconds on the public network.
[Sysname] pim
[Sysname-pim] c-bsr holdtime 150
# Set the BS timeout time to 150 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] c-bsr holdtime 150
c-bsr interval interval
undo c-bsr interval
View
Default level
2: System level
interval: Specifies a BS period in seconds, in the range of 10 to 2147483647.
Use c-bsr interval to configure the BS period (the interval at which the BSR sends bootstrap messages).
Use undo c-bsr interval to restore the default.
By default, the BS period value is determined by this formula: BS period = (BS timeout – 10) ÷ 2.
The default BS timeout is 130 seconds, so the default BS period = (130 – 10) ÷ 2 = 60 (seconds).
Related commands: c-bsr and c-bsr holdtime.
# Set the BS period to 30 seconds on the public network.
[Sysname] pim
[Sysname-pim] c-bsr interval 30
# Set the BS period to 30 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] c-bsr interval 30
c-bsr priority priority
undo c-bsr priority
View
Default level
2: System level
Use c-bsr priority to configure the global C-BSR priority.
Use undo c-bsr priority to restore the default.
By default, the C-BSR priority is 64.
# Set the global C-BSR priority to 5 on the public network.
[Sysname] pim
[Sysname-pim] c-bsr priority 5
# Set the global C-BSR priority to 5 in VPN instance mvpn.
[Sysname-pim-mvpn] c-bsr priority 5
c-rp (PIM view)
c-rp interface-type interface-number [ group-policy acl-number | priority priority | holdtime hold-interval | advertisement-interval adv-interval ] * [ bidir ]
undo c-rp interface-type interface-number
View
Default level
2: System level
acl-number: Specifies a basic ACL number in the range of 2000 to 2999. This ACL defines a range of multicast groups to which the C-RP is designated, rather than defining a filtering rule. Any group range matching the permit statement in the ACL will be advertised as a group range to which the C-RP is designated, but the configuration matching other statements like deny will not take effect.
priority: Specifies the priority of the C-RP, in the range of 0 to 255. The default value is 192. A larger value represents a lower priority.
hold-interval: Specifies a C-RP timeout time in seconds, in the range of 1 to 65535. If this argument is not specified, the corresponding global setting is used.
adv-interval: Specifies a C-RP-Adv interval in seconds, in the range of 1 to 65535. If this argument is not specified, the corresponding global setting is used.
bidir: Specifies BIDIR-PIM. If this argument is not specified, the PIM mode is PIM-SM.
Use c-rp to configure the specified interface as a C-RP.
Use undo c-rp to remove the related C-RP configuration.
No C-RPs are configured by default.
PIM-SM must be enabled on the interface to be configured as a C-RP.
If the group range for the C-RP is not specified, the C-RP provides services for all multicast groups.
If you want a device to be a C-RP for multiple group ranges, you need to include these multiple group ranges in multiple rules in the ACL corresponding to the group-policy keyword.
If you execute this command multiple times on the same interface, the most recent configuration takes effect.
Related commands: c-bsr.
# Configure VLAN-interface 100 on the public network to be a C-RP for multicast groups 225.1.0.0/16 and 226.2.0.0/16, with a priority of 10.
[Sysname-acl-basic-2000] rule permit source 225.1.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule permit source 226.2.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] c-rp vlan-interface 100 group-policy 2000 priority 10
# Configure VLAN-interface 100 in VPN instance mvpn to be a C-RP for multicast groups 225.1.0.0/16 and 226.2.0.0/16, with a priority of 10.
[Sysname-pim-mvpn] c-rp vlan-interface 100 group-policy 2000 priority 10
c-rp advertisement-interval interval
undo c-rp advertisement-interval
View
Default level
2: System level
Use c-rp advertisement-interval to configure the interval at which C-RP-Adv messages are sent.
Use undo c-rp advertisement-interval to restore the default.
By default, the C-RP-Adv interval is 60 seconds.
Related commands: c-rp.
# Set the global C-RP-Adv interval to 30 seconds on the public network.
[Sysname] pim
[Sysname-pim] c-rp advertisement-interval 30
# Set the global C-RP-Adv interval to 30 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] c-rp advertisement-interval 30
c-rp holdtime interval
undo c-rp holdtime
View
Default level
2: System level
Use c-rp holdtime to configure the global C-RP timeout time (the length of time that the BSR waits before it must receive a C-RP-Adv message).
Use undo c-rp holdtime to restore the default.
By default, the C-RP timeout time is 150 seconds.
Because a non-BSR router refreshes its C-RP timeout time through BSR bootstrap messages, to prevent loss of C-RP information in BSR bootstrap messages, make sure that the C-RP timeout time is not smaller than the interval at which the BSR sends bootstrap messages. The recommended C-RP timeout setting is 2.5 times the BS period or longer.
Related commands: c-bsr interval and c-rp.
# Set the global C-RP timeout time to 200 seconds on the public network.
[Sysname] pim
[Sysname-pim] c-rp holdtime 200
# Set the global C-RP timeout time to 200 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] c-rp holdtime 200
crp-policy acl-number
undo crp-policy
View
Default level
2: System level
acl-number: Specifies an advanced ACL number in the range of 3000 to 3999. When the ACL is defined, the source keyword in the rule command specifies the address of a C-RP and the destination keyword specifies the address range of the multicast groups to which the C-RP is designated.
Use crp-policy to configure a legal C-RP address range and the multicast group range to which the C-RP is designated.
Use undo crp-policy to remove the restrictions in C-RP address ranges and the multicast group range to which the C-RP is designated.
By default, no restrictions are defined for C-RP address ranges and the multicast group range to which the C-RP is designated. All received C-RP messages are accepted.
This command guards against C-RP spoofing.
The crp-policy command filters the multicast group ranges advertised by C-RPs based on the group prefixes. For example, if the multicast group range advertised by a C-RP is 224.1.0.0/16 and the legal group range defined by the crp-policy command is 224.1.0.0/30, the multicast groups in the range of 224.1.0.0/16 are allowed to pass.
# In the public network, configure a C-RP policy so that only devices in the address range of 1.1.1.1/24 can be C-RPs that provide services for multicast groups in the address range of 225.1.1.0/24.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule permit ip source 1.1.1.1 0.0.0.255 destination 225.1.1.0 0.0.0.255
[Sysname-acl-adv-3000] quit
[Sysname] pim
[Sysname-pim] crp-policy 3000
# In VPN instance mvpn, configure a C-RP policy, so that only devices in the address range of 1.1.1.1/24 can be C-RPs that provide services for multicast groups in the address range of 225.1.1.0/24.
[Sysname-pim-mvpn] crp-policy 3000
display pim [ all-instance | vpn-instance vpn-instance-name ] bsr-info [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all-instance: Specifies all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display pim bsr-info to display BSR information in the PIM domain and the locally configured C-RP information in effect.
If neither all-instance nor vpn-instance is specified, this command will display the information on the public network.
Related commands: c-bsr and c-rp.
# Display the BSR information of the PIM-SM domain on the public network and the locally configured C-RP information in effect.
<Sysname> display pim bsr-info
 VPN-Instance: public net
 Elected BSR Address: 12.12.12.9
     Priority: 64
     Hash mask length: 30
     State: Elected
     Scope: Global
     Uptime: 00:00:56
     Next BSR message scheduled at: 00:01:14
 Candidate BSR Address: 12.12.12.9
     Priority: 64
     State: Elected
     Scope: Global
 Candidate RP: 12.12.12.9(LoopBack1)
     Priority: 192
     HoldTime: 150
     Advertisement Interval: 60
     Next advertisement scheduled at: 00:00:48
 Candidate RP: 3.3.3.3(Vlan-interface100)
     Priority: 200
     HoldTime: 90
     Advertisement Interval: 50
     Next advertisement scheduled at: 00:00:28
 Candidate RP: 5.5.5.5(Vlan-interface101)
     Priority: 192
     HoldTime: 80
Public network.
Elected BSR Address
Address of the elected BSR.
Address of the candidate BSR.
Priority
BSR priority.
Hash mask length
Hash mask length.
BSR state.
Scope
Scope of the BSR.
Uptime
Length of time for which this BSR has been up, in hh:mm:ss.
Length of time in which the BSR will expire, in hh:mm:ss.
Candidate RP
Address of the C-RP.
Priority
Priority of the C-RP.
HoldTime
Timeout time of the C-RP.
Interval at which the C-RP sends advertisement messages.
Length of time in which the C-RP will send the next advertisement message, in hh:mm:ss.
display pim [ all-instance | vpn-instance vpn-instance-name ] claimed-route [ source-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
source-address: Displays the information of the unicast route to a particular multicast source. If this argument is not specified, this command displays information about all unicast routes used by PIM.
Use display pim claimed-route to display information about unicast routes used by PIM.
If neither all-instance nor vpn-instance is specified, this command displays information on the public network.
If an (S, G) is marked SPT, this (S, G) entry uses a unicast route.
# Display information about all unicast routes used by PIM on the public network.
<Sysname> display pim claimed-route
 RPF information about: 172.168.0.0
     RPF interface: Vlan-interface100, RPF neighbor: 172.168.0.2
     Referenced route/mask: 172.168.0.0/24
     Referenced route type: unicast (direct)
     RPF-route selecting rule: preference-preferred
     The (S,G) or (*,G) list dependent on this route entry
     (172.168.0.12, 227.0.0.1)
Public network.
Information of the route to the multicast source 172.168.0.0
RPF interface
RPF interface type and number.
RPF neighbor
IP address of the RPF neighbor.
Address/mask of the referenced route.
Type of the referenced route:
·     igp—IGP unicast route.
·     egp—EGP unicast route.
·     unicast (direct)—Direct unicast route.
·     unicast—Other unicast route (such as static unicast route).
·     mbgp—MBGP route.
·     multicast static—Static multicast route.
Rule of RPF route selection.
(S,G) or (*, G) entry list dependent on this RPF route.
display pim [ all-instance | vpn-instance vpn-instance-name ] control-message counters [ message-type { probe | register | register-stop } | [ interface interface-type interface-number | message-type { assert | bsr | crp | graft | graft-ack | hello | join-prune | state-refresh } ] * ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
probe: Displays the number of null register messages.
register: Displays the number of register messages.
register-stop: Displays the number of register-stop messages.
interface interface-type interface-number: Displays the number of PIM control messages on the specified interface.
assert: Displays the number of assert messages.
bsr: Displays the number of Bootstrap messages.
crp: Displays the number of C-RP-Adv messages.
graft: Displays the number of Graft messages.
graft-ack: Displays the number of Graft-ack messages.
hello: Displays the number of Hello messages.
join-prune: Displays the number of Join/prune messages.
state-refresh: Displays the number of state refresh messages.
Use display pim control-message counters to display statistics for PIM control messages.
If neither all-instance nor vpn-instance is specified, this command displays the information on the public network.
# Display statistics for all PIM control messages on all interfaces on the public network.
<Sysname> display pim control-message counters
 PIM global control-message counters:
                  Received         Sent             Invalid
 Register         20               37               2
 Register-Stop    25               20               1
 Probe            10               5                0
 PIM control-message counters for interface: Vlan-interface100
 Assert           10               5                0
 Graft            20               37               2
 Graft-Ack        25               20               1
 Hello            1232             453              0
 Join/Prune       15               30               21
 State-Refresh    8                7                1
 BSR              3243             589              1
 C-RP             53               32               0
Public network.
Statistics of PIM global control messages.
Interface for which PIM control messages were counted.
Received
Number of messages received.
Sent
Number of messages sent.
Invalid
Number of invalid messages.
Register
Register messages.
Register-Stop
Register-stop messages.
Probe
Null register messages.
Assert
Assert messages.
Graft
Graft messages.
Graft-Ack
Graft-ack messages.
Hello
Hello messages.
Join/Prune
State Refresh
State refresh messages.
BSR
Bootstrap messages.
C-RP
C-RP-Adv messages.
display pim df-info
display pim [ all-instance | vpn-instance vpn-instance-name ] df-info [ rp-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all-instance: Specifies all instances.
vpn-instance vpn-instance-name: Specifies a VPN instance. A VPN instance name is a case-sensitive string of up to 31 characters and must not contain any space.
rp-address: Specifies the RP address of BIDIR-PIM.
exclude: Displays the lines that do not match the specified regular expression.
Use display pim df-info to display the DF information of BIDIR-PIM.
If neither all-instance nor vpn-instance is specified, this command displays the DF information of BIDIR-PIM on the public network.
# Display the DF information of BIDIR-PIM on the public network.
<Sysname> display pim df-info
 RP Address: 1.1.1.1
  Interface           State   DF-Pref    DF-Metric  DF-Uptime DF-Address
  Loop0               Win     150        1          00:32:59  4.4.4.4 (local)
  Vlan106             Win     150        1          00:32:59  6.0.0.1 (local)
Public network.
RP Address
BIDIR-PIM RP address.
Interface type and number.
DF election state: Win or lose.
DF-Pref
Route priority of DF.
DF-Metric
Route metric of DF.
DF-Uptime
Existence duration of DF.
DF-Address
IP address of DF. If a local address is used, this field displays local in brackets ( ) after the IP address.
display pim grafts
display pim [ all-instance | vpn-instance vpn-instance-name ] grafts [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display pim grafts to display information about unacknowledged PIM-DM graft messages.
# Display information about unacknowledged PIM-DM graft messages on the public network.
<Sysname> display pim grafts
 Source             Group             Age           RetransmitIn
 192.168.10.1       224.1.1.1         00:00:24      00:00:02
Table 5 Command output
Public network.
Source
Multicast source address in the graft message.
Group
Multicast group address in the graft message.
Age
Time in which the graft message will get aged out, in hh:mm:ss.
RetransmitIn
Time in which the graft message will be retransmitted, in hh:mm:ss.
display pim [ all-instance | vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Displays the PIM information on a particular interface.
verbose: Displays detailed PIM information.
Use display pim interface to display PIM information on the specified interface or all interfaces.
# Display PIM information on all interfaces on the public network.
<Sysname> display pim interface
 Interface           NbrCnt HelloInt   DR-Pri     DR-Address
 Vlan100              1      30         1          10.1.1.2
 Vlan101              0      30         1          172.168.0.2    (local)
 Vlan102              1      30         1          20.1.1.2
Table 6 Command output
Public network.
Interface name.
NbrCnt
Number of PIM neighbors.
HelloInt
Hello interval.
DR-Pri
Priority for DR election.
DR-Address
DR IP address. If a local address is used, local is displayed in brackets ( ) after the IP address.
# Display detailed PIM information on VLAN-interface 100 on the public network.
<Sysname> display pim interface Vlan-interface100 verbose
 Interface: Vlan-interface100, 10.1.1.1
     PIM version: 2
     PIM mode: Sparse
     PIM DR: 10.1.1.2
     PIM DR Priority (configured): 1
     PIM neighbor count: 1
     PIM hello interval: 30 s
     PIM LAN delay (negotiated): 500 ms
     PIM LAN delay (configured): 500 ms
     PIM override interval (negotiated): 2500 ms
     PIM override interval (configured): 2500 ms
     PIM neighbor tracking (negotiated): disabled
     PIM neighbor tracking (configured): disabled
     PIM generation ID: 0xF5712241
     PIM require generation ID: disabled
     PIM hello hold interval: 105 s
     PIM assert hold interval: 180 s
     PIM triggered hello delay: 5 s
     PIM J/P interval: 60 s
     PIM J/P hold interval: 210 s
     PIM BSR domain border: disabled
     Number of routers on network not using DR priority: 0
     Number of routers on network not using LAN delay: 0
     Number of routers on network not using neighbor tracking: 2
Table 7 Command output
Public network.
Interface name and its IP address.
PIM version
Running PIM version.
PIM mode
PIM mode, dense or sparse.
PIM DR
DR IP address.
Configured priority for DR election.
PIM neighbor count
Total number of PIM neighbors.
PIM hello interval
Hello interval.
Negotiated prune message delay.
Configured prune message delay.
Negotiated prune override interval.
Configured prune override interval.
Negotiated neighbor tracking status: enabled/disabled.
Configured neighbor tracking status: enabled/disabled.
PIM generation ID
Generation_ID value.
Whether the function of dropping Hello messages without Generation_ID is enabled.
PIM neighbor timeout time.
Assert timeout time.
Maximum delay of sending hello messages.
PIM J/P interval
Join/prune interval.
Join/prune timeout time.
Status of PIM domain border configuration (enabled/disabled).
Number of routers not using the DR priority field on the subnet where the interface resides.
Number of routers not using the LAN delay field on the subnet where the interface resides.
Number of routers not using neighbor tracking on the subnet where the interface resides.
display pim [ all-instance | vpn-instance vpn-instance-name ] join-prune mode { sm [ flags flag-value ] | ssm } [ interface interface-type interface-number | neighbor neighbor-address ] * [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mode: Displays the information of join/prune messages to send in the specified PIM mode.
·     sm: Specifies PIM-SM.
·     ssm: Specifies PIM-SSM.
flags flag-value: Displays routing entries containing the specified flag.
·     rpt: Specifies routing entries on the RPT.
·     spt: Specifies routing entries on the SPT.
·     wc: Specifies wildcard routing entries.
interface-type interface-number: Displays the information of join/prune messages to send on the specified interface.
neighbor-address: Displays the information of join/prune messages to send to the specified PIM neighbor.
verbose: Displays detailed information about join/prune messages to send.
Use display pim join-prune to display information about the join/prune messages to send.
# In the public network view information about join/prune messages to send in the PIM-SM mode.
<Sysname> display pim join-prune mode sm
 Expiry Time: 50 sec
 Upstream nbr: 10.1.1.1 (Vlan-interface100)
 1 (*, G) join(s), 0 (S, G) join(s), 1 (S, G, rpt) prune(s)
 Total (*, G) join(s): 1, (S, G) join(s): 0, (S, G, rpt) prune(s): 1
Table 8 Command output
Public network.
Expiry Time:
Expiration time of sending join/prune messages.
Upstream nbr:
IP address of the upstream PIM neighbor and the interface connecting to it.
(*, G) join(s)
Number of (*, G) joins to send.
(S, G) join(s)
Number of (S, G) joins to send.
Number of (S, G, rpt) prunes.
display pim [ all-instance | vpn-instance vpn-instance-name ] neighbor [ interface interface-type interface-number | neighbor-address | verbose ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Displays PIM neighbor information on a particular interface.
neighbor-address: Displays the information of a particular PIM neighbor.
verbose: Displays detailed PIM neighbor information.
Use display pim neighbor to display the PIM neighbor information.
# Display the information of all PIM neighbors on the public network.
<Sysname> display pim neighbor
 Total Number of Neighbors = 2
 Neighbor        Interface           Uptime   Expires  Dr-Priority  Mode
 10.1.1.2        Vlan100             02:50:49 00:01:31 1            B
 20.1.1.2        Vlan101             02:49:39 00:01:42 1            B
# In the public network, view detailed information about the PIM neighbor whose IP address is 11.110.0.20.
<Sysname> display pim neighbor 11.110.0.20 verbose
 Neighbor: 11.110.0.20
     Uptime: 00:00:10
     Expiry time: 00:00:30
     DR Priority: 1
     Generation ID: 0x2ACEFE15
     Holdtime: 105 s
     LAN delay: 500 ms
     Override interval: 2500 ms
     State refresh interval: 60 s
     Neighbor tracking: Disabled
     Bidirectional PIM: Enabled
     Neighbor Secondary Address(es):
     167.100.1.2
     167.100.2.2
     167.100.3.2
     167.100.4.2
     167.100.5.2
Table 9 Command output
Public network.
Neighbor
IP address of the PIM neighbor.
Interface connecting the PIM neighbor.
Uptime
Length of time for which the PIM neighbor has been up, in hh:mm:ss.
Expires/Expiry time
Remaining time of the PIM neighbor, in hh:mm:ss. If the PIM neighbor is always up and reachable, this field displays never.
Dr-Priority/DR Priority
Priority of the PIM neighbor.
Mode
Mode of the PIM neighbor. If the PIM mode is BIDIR-PIM, this field displays B. If a PIM mode other than BIDIR-PIM is used, this field is blank.
Generation ID
Generation ID of the PIM neighbor. A random value indicating a status change of the PIM neighbor.
Holdtime
Holdtime of the PIM neighbor. If the PIM neighbor is always up and reachable, this field displays forever.
LAN delay
Prune message delay.
Override interval
Prune override interval.
Interval for sending state refresh messages.
Displayed only when the PIM neighbor operates in PIM-DM mode and the state refresh capability is enabled.
Neighbor tracking
Neighbor tracking status: enabled/disabled.
Bidirectional PIM
BIDIR-PIM status: enabled/disabled.
Secondary address of the PIM neighbor
display pim [ all-instance | vpn-instance vpn-instance-name ] routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | incoming-interface [ interface-type interface-number | register ] | outgoing-interface { include | exclude | match } { interface-type interface-number | register } | mode mode-type | flags flag-value | fsm ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Specifies a multicast group address in the range of 224.0.0.0 to 239.255.255.255.
source-address: Specifies a multicast source address.
mask: Specifies the address mask, 255.255.255.255 by default.
mask-length: Specifies the address mask length in the range of 0 to 32. The default is 32.
incoming-interface: Displays PIM routing entries that contain the specified interface as the incoming interface.
register: Specifies the register interface. This keyword is valid only if mode-type is not specified or is sm.
outgoing-interface: Displays PIM routing entries of which the outgoing interface is the specified interface.
include: Displays PIM routing entries of which the outgoing interface list includes the specified interface.
exclude: Displays PIM routing entries of which the outgoing interface list excludes the specified interface.
match: Displays PIM routing entries of which the outgoing interface list includes only the specified interface.
mode mode-type: Specifies a PIM mode:
·     dm: Specifies PIM-DM.
flags flag-value: Displays PIM routing entries containing the specified flag or flags:
·     2msdp: Specifies PIM routing entries to be contained in the next SA message to notify an MSDP peer.
·     act: Specifies PIM routing entries that have been used for routing data.
·     bidir: Specifies PIM routing entries created by BIDIR-PIM.
·     del: Specifies PIM routing entries scheduled to be deleted.
·     exprune: Specifies PIM routing entries containing outgoing interfaces pruned by other multicast routing protocols.
·     ext: Specifies PIM routing entries containing outgoing interfaces provided by other multicast routing protocols.
·     loc: Specifies PIM routing entries on the devices that directly connect to the same subnet as the multicast source.
·     msdp: Specifies PIM routing entries learned from MSDP SA messages.
·     niif: Specifies PIM routing entries containing unknown incoming interfaces.
·     nonbr: Specifies PIM routing entries with PIM neighbor searching failure.
·     rpt: Specifies PIM routing entries on RPT branches where (S, G) prunes have been sent to the RP.
·     rq: Specifies PIM routing entries of the receiving side of the switch-MDT switchover.
·     spt: Specifies PIM routing entries on the SPT.
·     sq: Specifies PIM routing entries of the originator side of switch-MDT switchover.
·     swt: Specifies PIM routing entries in the process of RPT-to-SPT switchover.
fsm: Displays the information of the state machine.
Use display pim routing-table to display PIM routing table information.
Related commands: display multicast routing-table.
# Display the content of the PIM routing table on the public network.
<Sysname> display pim routing-table
     RP: 2.2.2.2
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: Vlan-interface100
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: Vlan-interface101
             Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
# Display the state machine information in the PIM routing table on the public network.
<Sysname> display pim routing-table fsm
 Abbreviations for FSM states:
     NI - no info, J - joined, NJ - not joined, P - pruned,
     NP - not pruned, PP - prune pending, W - winner, L - loser,
     F - forwarding, AP - ack pending, DR - designated router,
     NDR - non-designated router, RCV - downstream receivers
     RP: 2.2.2.2
     UpTime: 02:54:43
     Upstream interface: GigabitEthernet3/0/1
         Join/Prune FSM: [SPT: J] [RPT: NP]
         1: GigabitEthernet3/0/2
             DR state: [DR]
             Join/Prune FSM: [NI]
             Assert FSM: [NI]
     FSM information for non-downstream interfaces: None
Table 10 Command output
Public network.
Number of (S,G) and (*, G) entries in the PIM routing table.
(172.168.0.2, 227.0.0.1)
(S, G) entry in the PIM routing table.
RP
IP address of the RP.
Protocol
PIM mode.
Flag
Flag of the (S, G) or (*, G) entry in the PIM routing table:
·     2MSDPThe entry is contained in the next SA message to notify an MSDP peer.
·     ACTThe entry has been used for routing data.
·     BIDIRThe entry was created by BIDIR-PIM.
·     DELThe entry will be removed.
·     EXPRUNESome outgoing interfaces are pruned by other multicast routing protocols.
·     EXTThe entry contains outgoing interfaces provided by other multicast routing protocols.
·     LOCThe entry is on a router directly connected to the same subnet with the multicast source.
·     MSDPThe entry is learnt from MSDP SA messages.
·     NIIFThe entry contains unknown incoming interfaces.
·     NONBRThe entry has a PIM neighbor searching failure.
·     RPTThe entry is on a RPT branch where (S, G) prunes have been sent to the RP.
·     RQThe entry is on the receiving side of the switch-MDT switchover.
·     SPTThe entry is on the SPT.
·     SQThe entry is on the originator side of switch-MDT switchover.
·     SWTThe entry is in the process of RPT-to-SPT switchover.
·     WCWildcard routing entry.
Uptime
Length of time for which the (S, G) or (*, G) entry has been existing.
Upstream interface
Upstream (incoming) interface of the (S, G) or (*, G) entry.
Upstream neighbor
Upstream neighbor of the (S, G) or (*, G) entry.
RPF prime neighbor
RPF neighbor of the (S, G) or (*, G) entry:
·     For a (*, G) entry, if this router is the RP, the RPF neighbor of this (*, G) entry is NULL.
·     For a (S, G) entry, if this router directly connects to the multicast source, the RPF neighbor of this (S, G) entry is NULL.
Information about the downstream interfaces:
·     Number of downstream interfaces.
·     Downstream interface name.
·     Protocol type on the downstream interfaces.
·     Uptime of the downstream interfaces.
·     Expiration time of the downstream interfaces.
display pim rp-info
display pim [ all-instance | vpn-instance vpn-instance-name ] rp-info [ group-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255. If no group address is specified, this command displays the RP information corresponding to all multicast groups.
Use display pim rp-info to display the RP information.
The RP information includes the information of RPs dynamically found by the BSR mechanism and static RPs.
# Display RP information corresponding to the multicast group 224.0.1.1 on the public network.
<Sysname> display pim rp-info 224.0.1.1
 BSR RP Address is: 2.2.2.2
     Priority: 192
     HoldTime: 150
     Uptime: 03:01:10
     Expires: 00:02:30
 RP mapping for this group is: 2.2.2.2
# Display RP information corresponding to all multicast groups on the public network.
 PIM-SM BSR RP information:
 Group/MaskLen: 224.0.0.0/4 [B]
     RP: 2.2.2.2
     Priority: 192
     HoldTime: 150
     Uptime: 03:01:36
     Expires: 00:02:29
Table 11 Command output
Public network.
BSR RP Address is
Group/MaskLen
Multicast group to which the RP is designated.
[B]
The RP provides services for multicast groups in BIDIR-PIM. If this field is not displayed, the RP provides services for multicast groups in PIM-SM.
RP
Priority
RP priority.
HoldTime
RP timeout time.
Uptime
Length of time for which the RP has been up, in hh:mm:ss.
Expires
Length of time in which the RP will expire, in hh:mm:ss.
IP address of the RP that provides services for the current multicast group.
undo hello-option dr-priority
View
Default level
2: System level
priority: Specifies the router priority for DR election, in the range of 0 to 4294967295. A larger value represents a higher priority.
Use hello-option dr-priority to configure the global value of the router priority for DR election.
Use undo hello-option dr-priority to restore the default.
By default, the router priority for DR election is 1.
Related commands: pim hello-option dr-priority.
# Set the router priority for DR election to 3 on the public network.
[Sysname] pim
[Sysname-pim] hello-option dr-priority 3
# Set the router priority for DR election to 3 in VPN instance mvpn.
[Sysname-pim-mvpn] hello-option dr-priority 3
hello-option holdtime interval
undo hello-option holdtime
View
Default level
2: System level
interval: Specifies a PIM neighbor timeout time in seconds, in the range of 1 to 65535. If the value for this argument is 65535, the PIM neighbor is always reachable.
Use hello-option holdtime to configure the PIM neighbor timeout time.
Use undo hello-option holdtime to restore the default.
By default, the PIM neighbor timeout time is 105 seconds.
Related commands: pim hello-option holdtime.
# Set the global value of the PIM neighbor timeout time to 120 seconds on the public network.
[Sysname] pim
[Sysname-pim] hello-option holdtime 120
# Set the global value of the PIM neighbor timeout time to 120 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] hello-option holdtime 120
hello-option lan-delay interval
undo hello-option lan-delay
View
Default level
2: System level
interval: Specifies a LAN-delay time in milliseconds, in the range of 1 to 32767.
Use hello-option lan-delay to configure the global value of the LAN-delay time (the period of time that the device waits before forwarding a received prune message).
Use undo hello-option lan-delay to restore the default.
By default, the LAN-delay time is 500 milliseconds.
This command takes effect on both PIM-DM and PIM-SM.
Related commands: hello-option override-interval, pim hello-option lan-delay, and pim hello-option override-interval.
# Set the LAN-delay time to 200 milliseconds globally on the public network.
[Sysname] pim
[Sysname-pim] hello-option lan-delay 200
# Set the LAN-delay time to 200 milliseconds globally in VPN instance mvpn.
[Sysname-pim-mvpn] hello-option lan-delay 200
undo hello-option neighbor-tracking
View
Default level
2: System level
None
Use hello-option neighbor-tracking to disable join suppression globally and enable neighbor tracking.
Use undo hello-option neighbor-tracking to enable join suppression.
By default, join suppression is enabled and neighbor tracking is disabled.
Related commands: pim hello-option neighbor-tracking.
# Disable join suppression globally on the public network.
[Sysname] pim
[Sysname-pim] hello-option neighbor-tracking
# Disable join suppression globally in VPN instance mvpn.
[Sysname-pim-mvpn] hello-option neighbor-tracking
undo hello-option override-interval
View
Default level
2: System level
interval: Specifies a prune override interval in milliseconds, in the range of 1 to 65535.
Use hello-option override-interval to configure the global value of the prune override interval.
Use undo hello-option override-interval to restore the default.
By default, the prune override interval is 2500 milliseconds.
Related commands: hello-option lan-delay, pim hello-option lan-delay, and pim hello-option override-interval.
# Set the prune override interval to 2000 milliseconds globally on the public network.
[Sysname] pim
[Sysname-pim] hello-option override-interval 2000
# Set the prune override interval to 2000 milliseconds globally in VPN instance mvpn.
[Sysname-pim-mvpn] hello-option override-interval 2000
holdtime assert interval
undo holdtime assert
View
Default level
2: System level
interval: Specifies an assert timeout time in seconds, in the range of 7 to 2147483647.
Use holdtime assert to configure the global value of the assert timeout time.
Use undo holdtime assert to restore the default.
By default, the assert timeout time is 180 seconds.
Related commands: holdtime join-prune, pim holdtime assert, and pim holdtime join-prune.
# Set the global value of the assert timeout time to 100 seconds on the public network.
[Sysname] pim
[Sysname-pim] holdtime assert 100
# Set the global value of the assert timeout time to 100 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] holdtime assert 100
holdtime join-prune interval
undo holdtime join-prune
View
Default level
2: System level
interval: Specifies a join/prune timeout time in seconds, in the range of 1 to 65535.
Use holdtime join-prune to configure the global value of the join/prune timeout time.
Use undo holdtime join-prune to restore the default.
By default, the join/prune timeout time is 210 seconds.
Related commands: holdtime assert, pim holdtime assert, and pim holdtime join-prune.
# Set the global value of the join/prune timeout time to 280 seconds on the public network.
[Sysname] pim
[Sysname-pim] holdtime join-prune 280
# Set the global value of the join/prune timeout time to 280 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] holdtime join-prune 280
jp-pkt-size packet-size
undo jp-pkt-size
View
Default level
2: System level
packet-size: Specifies the maximum size of join/prune messages in bytes, in the range of 100 to 8100.
Use jp-pkt-size to configure the maximum size of join/prune messages.
Use undo jp-pkt-size to restore the default.
By default, the maximum size of join/prune messages is 8100 bytes.
Related commands: jp-queue-size.
# Set the maximum size of join/prune messages to 1500 bytes on the public network.
[Sysname] pim
[Sysname-pim] jp-pkt-size 1500
# Set the maximum size of join/prune messages to 1500 bytes in VPN instance mvpn.
[Sysname-pim-mvpn] jp-pkt-size 1500
jp-queue-size queue-size
undo jp-queue-size
View
Default level
2: System level
queue-size: Specifies the maximum number of (S, G) entries in a join/prune message, in the range of 1 to 4096.
Use jp-queue-size to configure the maximum number of (S, G) entries in a join/prune message.
Use undo jp-queue-size to restore the default.
By default, a join/prune messages contains a maximum of 1020 (S, G) entries.
When you use this command, take the following into account:
·     The size of the forwarding table. In a network that does not support packet fragmentation, if you configure a large queue-size, a join/prune message might contain a large number of groups, causing the message length to exceed the MTU of the network. As a result, the products that do not support fragmentation will drop the join/prune message.
·     The (S, G) join/prune timeout time on the upstream device. If you configure a small queue size, the outgoing interface of the corresponding entry might have been pruned due to timeout before the last join/prune message in a queue reaches the upstream device.
Related commands: holdtime join-prune, jp-pkt-size, and pim holdtime join-prune.
# Configure a join/prune messages to contain a maximum of 2000 (S, G) entries on the public network.
[Sysname] pim
[Sysname-pim] jp-queue-size 2000
# Configure a join/prune messages to contain a maximum of 2000 (S, G) entries in VPN instance mvpn.
[Sysname-pim-mvpn] jp-queue-size 2000
pim
pim [ vpn-instance vpn-instance-name ]
undo pim [ vpn-instance vpn-instance-name ]
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command applies to the public network.
Use pim to enter public network PIM view or VPN instance PIM view.
Use undo pim to remove all configurations in public network PIM view or VPN instance PIM view.
IP multicast routing must be enabled in the corresponding instance before this command takes effect.
Related commands: multicast routing-enable.
# Enable IP multicast routing on the public network and enter public network PIM view.
[Sysname] pim
[Sysname-pim]
# Enable IP multicast routing in VPN instance mvpn and enter PIM view of VPN instance mvpn.
[Sysname-pim-mvpn]
pim bfd enable
pim bfd enable
undo pim bfd enable
View
Interface view
Default level
2: System level
None
Use pim bfd enable to enable BFD for PIM.
Use undo pim bfd enable to disable this feature.
You must enable PIM-DM or PIM-SM on an interface before you configure this feature on the interface. Otherwise, this feature does not take effect.
Related commands: pim dm and pim sm.
# Enable IP multicast routing on the public network, enable PIM-SM on interface VLAN-interface 100, and enable BFD for PIM on the interface.
[Sysname-Vlan-interface100] pim sm
[Sysname-Vlan-interface100] pim bfd enable
pim bsr-boundary
pim bsr-boundary
undo pim bsr-boundary
View
Interface view
Default level
2: System level
None
Use pim bsr-boundary to configure a PIM domain border (a bootstrap message boundary).
Use undo pim bsr-boundary to remove the configured PIM domain border.
By default, no PIM domain border is configured.
Related commands: c-bsr and multicast boundary.
# Configure VLAN-interface 100 as a PIM domain border.
[Sysname-Vlan-interface100] pim bsr-boundary
pim dm
pim dm
undo pim dm
View
Interface view
Default level
2: System level
None
Use pim dm to enable PIM-DM.
Use undo pim dm to disable PIM-DM.
By default, PIM-DM is disabled.
This command takes effect only after IP multicast routing is enabled in the corresponding instance.
PIM-DM cannot be used for multicast groups in the SSM group range.
When the system is operating in standard mode, you must configure a reserved VLAN before you configure PIM-DM for a VPN instance. For more information about the system operating mode, see Fundamentals Configuration Guide. For more information about the configuration and commands about a reserved VLAN, see MPLS Configuration Guide and MPLS Command Reference.
Related commands: multicast routing-enable, pim sm, and ssm-policy.
# Enable IP multicast routing on the public network, and enable PIM-DM on VLAN-interface 100.
[Sysname-Vlan-interface100] pim dm
pim hello-option dr-priority priority
undo pim hello-option dr-priority
View
Interface view
Default level
2: System level
Use pim hello-option dr-priority to configure the router priority for DR election on the current interface.
Use undo pim hello-option dr-priority to restore the default.
Related commands: hello-option dr-priority.
# Set the router priority for DR election to 3 on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option dr-priority 3
pim hello-option holdtime interval
undo pim hello-option holdtime
View
Interface view
Default level
2: System level
Use pim hello-option holdtime to configure the PIM neighbor timeout time on the current interface.
Use undo pim hello-option holdtime to restore the default.
Related commands: hello-option holdtime.
# Set the PIM neighbor timeout time to 120 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option holdtime 120
pim hello-option lan-delay interval
undo pim hello-option lan-delay
View
Interface view
Default level
2: System level
Use pim hello-option lan-delay to configure the LAN-delay time (the length of time that the device waits before forwarding a received prune message) on the current interface.
Use undo pim hello-option lan-delay to restore the default.
By default, the LAN-delay time to 500 milliseconds.
Related commands: hello-option lan-delay, hello-option override-interval, and pim hello-option override-interval.
# Set the LAN-delay time to 200 milliseconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option lan-delay 200
undo pim hello-option neighbor-tracking
View
Interface view
Default level
2: System level
None
Use pim hello-option neighbor-tracking to disable join suppression and enable neighbor tracking on the current interface.
Use undo pim hello-option neighbor-tracking to enable join suppression.
Related commands: hello-option neighbor-tracking.
# Disable join suppression on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option neighbor-tracking
pim hello-option override-interval interval
undo pim hello-option override-interval
View
Interface view
Default level
2: System level
Use pim hello-option override-interval to configure the prune override interval on the current interface.
Use undo pim hello-option override-interval to restore the default.
Related commands: hello-option lan-delay, hello-option override-interval, and pim hello-option lan-delay.
# Set the prune override interval to 2000 milliseconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option override-interval 2000
pim holdtime assert
pim holdtime assert interval
undo pim holdtime assert
View
Interface view
Default level
2: System level
Use pim holdtime assert to configure the assert timeout time on the current interface.
Use undo pim holdtime assert to restore the default.
Related commands: holdtime assert, holdtime join-prune, and pim holdtime join-prune.
# Set the assert timeout time to 100 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim holdtime assert 100
pim holdtime join-prune interval
undo pim holdtime join-prune
View
Interface view
Default level
2: System level
Use pim holdtime join-prune to configure the join/prune timeout time on the interface.
Use undo pim holdtime join-prune to restore the default.
Related commands: holdtime assert, holdtime join-prune, and pim holdtime assert.
# Set the join/prune timeout time to 280 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim holdtime join-prune 280
pim neighbor-policy
pim neighbor-policy acl-number
undo pim neighbor-policy
View
Interface view
Default level
2: System level
acl-number: Specifies a basic ACL number in the range of 2000 to 2999. When the ACL is defined, the source keyword in the rule command specifies a legal source address range for hello messages.
Use pim neighbor-policy to configure a legal source address range for hello messages to guard against hello message spoofing.
Use undo pim neighbor-policy to restore the default.
By default, no source address range for hello messages is configured. All the received hello messages are considered legal.
# Configure a legal source address range for hello messages on VLAN-interface 100 so that only the devices on the 10.1.1.0/24 subnet can become PIM neighbors of this switch.
[Sysname-Vlan-interface100] pim neighbor-policy 2000
pim require-genid
pim require-genid
undo pim require-genid
View
Interface view
Default level
2: System level
None
Use pim require-genid to enable rejection of hello messages without Generation_ID.
Use undo pim require-genid to restore the default.
By default, hello messages without Generation_ID are accepted.
# Enable VLAN-interface 100 to reject hello messages without Generation_ID.
[Sysname-Vlan-interface100] pim require-genid
pim sm
pim sm
undo pim sm
View
Interface view
Default level
2: System level
None
Use pim sm to enable PIM-SM.
Use undo pim sm to disable PIM-SM.
By default, PIM-SM is disabled.
When the system is operating in standard mode, you must configure a reserved VLAN before you configure PIM-SM for a VPN instance. For more information about the system operating mode, see Fundamentals Configuration Guide. For more information about the configuration and commands about a reserved VLAN, see MPLS Configuration Guide and MPLS Command Reference.
Related commands: multicast routing-enable and pim dm.
# Enable IP multicast routing on the public network, and enable PIM-SM on VLAN-interface 100.
undo pim state-refresh-capable
View
Interface view
Default level
2: System level
None
Use pim state-refresh-capable to enable the state fresh feature on the interface.
Use undo pim state-refresh-capable to disable the state fresh feature.
By default, the state refresh feature is enabled.
Related commands: state-refresh-interval, state-refresh-rate-limit, and state-refresh-ttl.
# Disable state refresh on VLAN-interface 100.
[Sysname-Vlan-interface100] undo pim state-refresh-capable
pim timer graft-retry interval
undo pim timer graft-retry
View
Interface view
Default level
2: System level
interval: Specifies a graft retry period in seconds, in the range of 1 to 65535.
Use pim timer graft-retry to configure the graft retry period.
Use undo pim timer graft-retry to restore the default.
By default, the graft retry period is 3 seconds.
# Set the graft retry period to 80 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer graft-retry 80
pim timer hello
pim timer hello interval
undo pim timer hello
View
Interface view
Default level
2: System level
interval: Specifies a hello interval in seconds, in the range of 1 to 2147483647.
Use pim timer hello to configure on the current interface the interval at which hello messages are sent.
Use undo pim timer hello to restore the default.
By default, hello messages are sent at the interval of 30 seconds.
Related commands: timer hello.
# Set the hello interval to 40 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer hello 40
pim timer join-prune interval
undo pim timer join-prune
View
Interface view
Default level
2: System level
interval: Specifies a join/prune interval in seconds, in the range of 1 to 2147483647.
Use pim timer join-prune to configure on the current interface the interval at which join/prune messages are sent.
Use undo pim timer join-prune to restore the default.
By default, the join/prune interval is 60 seconds.
Related commands: timer join-prune.
# Set the join/prune interval to 80 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer join-prune 80
pim triggered-hello-delay interval
undo pim triggered-hello-delay
View
Interface view
Default level
2: System level
interval: Specifies the maximum delay in seconds between hello messages, in the range of 1 to 60.
Use pim triggered-hello-delay to configure the maximum delay between hello messages.
Use undo pim triggered-hello-delay to restore the default.
By default, the maximum delay between hello messages is 5 seconds.
# Set the maximum delay between hello messages to 3 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim triggered-hello-delay 3
probe-interval (PIM view)
probe-interval interval
undo probe-interval
View
Default level
2: System level
interval: Specifies the register probe time in seconds, in the range of 1 to 1799.
Use probe-interval to configure the register probe time.
Use undo probe-interval to restore the default.
By default, the register probe time is 5 seconds.
Related commands: register-suppression-timeout.
# Set the register probe time to 6 seconds on the public network.
[Sysname] pim
[Sysname-pim] probe-interval 6
# Set the register probe time to 6 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] probe-interval 6
prune delay (PIM view)
prune delay interval
undo prune delay
View
Public network PIM view, VPN instance PIM view
Default level
2: System level
interval: Specifies a prune delay time in the range 1 to 128 seconds.
Use prune delay to configure the prune delay (the length of time that the device waits between receiving a prune message and taking a prune action).
Use undo prune delay to restore the default.
By default, the prune delay is 3 seconds, which equals the prune pending time.
# Set the prune delay to 75 seconds on the public network.
[Sysname] pim
[Sysname-pim] prune delay 75
# Set the prune delay time to 75 seconds in VPN instance mvpn.
[Sysname] pim vpn-instance mvpn
[Sysname-pim-mvpn] prune delay 75
register-policy (PIM view)
register-policy acl-number
undo register-policy
View
Default level
2: System level
acl-number: Specifies an advanced ACL number in the range of 3000 to 3999. Only register messages that match the permit statement of the ACL can be accepted by the RP.
Use register-policy to configure an ACL rule to filter register messages.
Use undo register-policy to remove the configured register filtering rule.
By default, no register filtering rule is configured.
# In the public network, configure the RP to accept only those register messages from multicast sources on the subnet of 10.10.0.0/16 for multicast groups on the subnet of 225.1.0.0/16.
[Sysname-acl-adv-3000] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] register-policy 3000
# In VPN instance mvpn, configure the RP to accept only those register messages from multicast sources on the subnet of 10.10.0.0/16 for multicast groups on the subnet of 225.1.0.0/16.
[Sysname-pim-mvpn] register-policy 3000
register-suppression-timeout (PIM view)
undo register-suppression-timeout
View
Default level
2: System level
interval: Specifies a register suppression time in seconds, in the range of 1 to 65535.
Use register-suppression-timeout to configure the register suppression time.
Use undo register-suppression-timeout to restore the default.
By default, the register suppression time is 60 seconds.
Related commands: probe-interval and register-policy.
# Set the register suppression time to 70 seconds on the public network.
[Sysname] pim
[Sysname-pim] register-suppression-timeout 70
# Set the register suppression time to 70 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] register-suppression-timeout 70
register-whole-checksum (PIM view)
undo register-whole-checksum
View
Default level
2: System level
None
Use register-whole-checksum to configure the router to calculate the checksum based on the entire register message.
Use undo register-whole-checksum to restore the default.
By default, the checksum is calculated based on the header in the register message.
Related commands: register-policy and register-suppression-timeout.
# Configure the router to calculate the checksum based on the entire register message on the public network.
[Sysname] pim
[Sysname-pim] register-whole-checksum
# Configure the router to calculate the checksum based on the entire register message in VPN instance mvpn.
[Sysname-pim-mvpn] register-whole-checksum
reset pim control-message counters
reset pim [ all-instance | vpn-instance vpn-instance-name ] control-message counters [ interface interface-type interface-number ]
View
Default level
1: Monitor level
interface interface-type interface-number: Specifies to reset the PIM control message counter on a particular interface. If no interface is specified, this command reset PIM control message counters on all interfaces.
Use reset pim control-message counters to reset PIM control message counters.
If neither all-instance nor vpn-instance is specified, this command resets PIM control message counters on the public network.
# Reset PIM control message counters on all interfaces on the public network.
<Sysname> reset pim control-message counters
source-lifetime (PIM view)
source-lifetime interval
undo source-lifetime
View
Default level
2: System level
interval: Specifies a multicast source lifetime in seconds, in the range of 1 to 31536000.
Use source-lifetime to configure the multicast source lifetime.
Use undo source-lifetime to restore the default.
By default, the lifetime of a multicast source is 210 seconds.
# Set the multicast source lifetime to 200 seconds on the public network.
[Sysname] pim
[Sysname-pim] source-lifetime 200
# Set the multicast source lifetime to 200 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] source-lifetime 200
source-policy (PIM view)
source-policy acl-number
undo source-policy
View
Default level
2: System level
acl-number: Specifies a basic or advanced ACL number in the range of 2000 to 3999.
Use source-policy to configure a multicast data filter.
Use undo source-policy to remove the configured multicast data filter.
By default, no multicast data filter is configured.
If you specify a basic ACL, the device filters all the received multicast packets based on the source address, and discards packets that fail the source address match. If you specify an advanced ACL, the device filters all the received multicast packets based on the source and group addresses, and discards packets that fail the match.
# In the public network, configure the router to accept multicast packets originated from 10.10.1.2 and discard multicast packets originated from 10.10.1.1.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.10.1.2 0
[Sysname-acl-basic-2000] rule deny source 10.10.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname] pim
[Sysname-pim] source-policy 2000
# In VPN instance mvpn, configure the router to accept multicast packets originated from 10.10.1.2 and discard multicast packets originated from 10.10.1.1.
[Sysname-pim-mvpn] source-policy 2000
spt-switch-threshold (PIM view)
spt-switch-threshold infinity [ group-policy acl-number [ order order-value ] ]
undo spt-switch-threshold [ infinity ] [ group-policy acl-number ]
View
Default level
2: System level
infinity: Disables SPT switchover.
group-policy acl-number: Specifies a basic ACL number in the range of 2000 to 2999. If this option is not specified, the configuration will apply on all multicast groups.
order order-value: Specifies the order of the ACL in the group-policy list. The value range for the order-value argument is 1 to the largest order value in the existing group-policy list plus 1, but it should not include the original order value of the ACL in the group-policy list. If you have assigned an order-value to a certain ACL, do not specify the same order-value for another ACL. Otherwise the system will give error information. If you do not specify the order-value argument, the order value of the ACL will remain the same in the group-policy list.
Use spt-switch-threshold to configure the SPT switchover parameters.
Use undo spt-switch-threshold to restore the default.
By default, the device switches to the SPT immediately after it receives the first multicast packet.
CAUTION
CAUTION:
If the switch is an RP, disabling switchover to SPT might cause multicast traffic forwarding failures on the source-side DR. When disabling switchover to SPT, be sure you fully understand its impact on your network.
To adjust the order of an existing ACL in the group-policy list, you can use the acl-number argument to specify this ACL and set its order-value. This will insert the ACL to the position of order-value in the group-policy list. The order of the other existing ACLs in the group-policy list will remain unchanged.
To use an ACL that does not exist in the group-policy list, you can use the acl-number argument to specify an ACL and set its order-value. This will insert the ACL to the position of order-value in the group-policy list. If you do not include the order order-value option in your command, the ACL will be appended to the end of the group-policy list.
If you use this command multiple times on the same multicast group, the first traffic rate configuration matched in sequence will take effect.
# In the public network, disable the SPT switchover on a switch that will never become an RP.
[Sysname] pim
[Sysname-pim] spt-switch-threshold infinity
# In VPN instance mvpn, disable the SPT switchover on a switch that will never become an RP.
[Sysname-pim-mvpn] spt-switch-threshold infinity
ssm-policy (PIM view)
ssm-policy acl-number
undo ssm-policy
View
Default level
2: System level
Use ssm-policy to configure the SSM multicast group range.
Use undo ssm-policy to restore the default.
By default, the SSM group range is 232.0.0.0/8.
This command allows you to define an address range of permitted or denied multicast groups. If the match succeeds, the multicast mode is PIM-SSM. Otherwise, the multicast mode is PIM-SM.
# Configure the SSM group range to be 232.1.0.0/16 on the public network.
[Sysname-acl-basic-2000] rule permit source 232.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] ssm-policy 2000
# Configure the SSM group range to be 232.1.0.0/16 in VPN instance mvpn.
[Sysname-pim-mvpn] ssm-policy 2000
state-refresh-interval (PIM view)
undo state-refresh-interval
View
Default level
2: System level
interval: Specifies a state refresh interval in seconds, in the range of 1 to 255.
Use state-refresh-interval to configure the interval between state refresh messages.
Use undo state-refresh-interval to restore the default.
By default, the state refresh interval is 60 seconds.
Related commands: pim state-refresh-capable, state-refresh-rate-limit, and state-refresh-ttl.
# Set the state refresh interval to 70 seconds on the public network.
[Sysname] pim
[Sysname-pim] state-refresh-interval 70
# Set the state refresh interval to 70 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] state-refresh-interval 70
state-refresh-rate-limit (PIM view)
state-refresh-rate-limit interval
undo state-refresh-rate-limit
View
Default level
2: System level
interval: Specifies a time to wait before receiving a new refresh message, in the range of 1 to 65535 seconds.
Use state-refresh-rate-limit to configure the time the router must wait before receiving a new state refresh message.
Use undo state-refresh-rate-limit to restore the default.
By default, the device waits 30 seconds before receiving a new state refresh message.
Related commands: pim state-refresh-capable, state-refresh-interval, and state-refresh-ttl.
# In the public network, configure the device to wait 45 seconds before receiving a new state refresh message.
[Sysname] pim
[Sysname-pim] state-refresh-rate-limit 45
# In VPN instance mvpn, configure the device to wait 45 seconds before receiving a new state refresh message.
[Sysname-pim-mvpn] state-refresh-rate-limit 45
state-refresh-ttl
state-refresh-ttl ttl-value
undo state-refresh-ttl
View
Default level
2: System level
ttl-value: Specifies a TTL value of state refresh messages, in the range of 1 to 255.
Use state-refresh-ttl to configure the TTL value of state refresh messages.
Use undo state-refresh-ttl to restore the default.
By default, the TTL value of state refresh messages is 255.
Related commands: pim state-refresh-capable, state-refresh-interval, and state-refresh-rate-limit.
# In the public network, configure the device to send PIM state refresh messages with a TTL of 45.
[Sysname] pim
[Sysname-pim] state-refresh-ttl 45
# In VPN instance mvpn, configure the device to send PIM state refresh messages with a TTL of 45.
[Sysname-pim-mvpn] state-refresh-ttl 45
static-rp (PIM view)
static-rp rp-address [ acl-number ] [ preferred ] [ bidir ]
undo static-rp rp-address
View
Default level
2: System level
rp-address: Specifies the IP address of the static RP to be configured. This address must be a real, valid unicast IP address, rather than an address on the 127.0.0.0/8 segment. For a static RP that provides services for BIDIR-PIM, you can specify a virtual IP address.
acl-number: Specifies a basic ACL number in the range of 2000 to 2999. If this argument is not specified, the configured static RP provides services for only those groups that pass the ACL filtering. Otherwise, the configured static RP provides services for the all-system group 224.0.0.0/4.
preferred: Specifies to give priority to the static RP if the static RP conflicts with the dynamic RP. If you do not include the preferred keyword in your command, the dynamic RP will be given priority, and the static RP takes effect only if no dynamic RP exists in the network or when the dynamic RP fails.
bidir: Specifies BIDIR-PIM. If this argument is not specified, the PIM mode is PIM-SM.
Use static-rp to configure a static RP.
Use undo static-rp to configure a static RP.
By default, no static RP is configured.
PIM-SM or PIM-DM cannot be enabled on an interface that serves as a static RP.
When the ACL rule applied on a static RP changes, a new RP must be elected for all the multicast groups.
You can configure multiple static RPs by using this command multiple times. However, if you execute this command multiple times and specify the same static RP address or reference the same ACL rule, the most recent configuration takes effect. If multiple static RPs have been configured for the same multicast group, the one with the highest IP address will be chosen to provide services for the multicast group.
You can configure up to 50 static RPs on the same device.
Related commands: auto-rp enable and display pim rp-info.
# In the public network, configure the interface with the IP address 11.110.0.6 to be a static RP that provides services for the multicast groups in the address range of 225.1.1.0/24 defined in basic ACL 2001, and give priority to this static RP in the case of static/dynamic RP conflict.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] pim
[Sysname-pim] static-rp 11.110.0.6 2001 preferred
# In VPN instance mvpn, configure the interface with the IP address 11.110.0.6 to be a static RP that provides services for the multicast groups in the address range of 225.1.1.0/24 defined in basic ACL 2001, and give priority to this static RP in the case of static/dynamic RP conflict.
[Sysname-pim-mvpn] static-rp 11.110.0.6 2001 preferred
timer hello (PIM view)
undo timer hello
View
Default level
2: System level
Use timer hello to configure the hello interval globally.
Use undo timer hello to restore the default.
Related commands: pim timer hello.
# Set the global hello interval to 40 seconds on the public network.
[Sysname] pim
[Sysname-pim] timer hello 40
# Set the global hello interval to 40 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] timer hello 40
timer join-prune (PIM view)
undo timer join-prune
View
Default level
2: System level
Use timer join-prune to configure the join/prune interval globally.
Use undo timer join-prune to restore the default.
Related commands: pim timer join-prune.
# Set the global join/prune interval to 80 seconds on the public network.
[Sysname] pim
[Sysname-pim] timer join-prune 80
# Set the global join/prune interval to 80 seconds in VPN instance mvpn.
[Sysname-pim-mvpn] timer join-prune 80
