08-IPv6静态路由命令
本章节下载: 08-IPv6静态路由命令 (109.09 KB)
delete ipv6 static-routes all命令用来删除所有IPv6静态路由。
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
vpn-instance vpn-instance-name:删除指定VPN的所有IPv6静态路由。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则删除公网实例下的所有IPv6静态路由。
使用本命令删除IPv6静态路由时,系统会提示确认,确认后才会删除所配置的所有IPv6静态路由。
# 删除所有IPv6静态路由。
[Sysname] delete ipv6 static-routes all
Delete all IPv6 static routes. Continue?[Y/N]y
· ipv6 route-static
ipv6 route-static命令用来配置IPv6静态路由。
undo ipv6 route-static命令用来删除已配置的IPv6静态路由。
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] [ bfd { control-packet | echo-packet } | permanent ] | next-hop-address [ bfd control-packet bfd-source ip-address | permanent ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ip-address | permanent ] } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] [ bfd { control-packet | echo-packet } | permanent ] | next-hop-address [ public ] [ bfd control-packet bfd-source ip-address | permanent ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ip-address | permanent ] } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
undo ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
没有配置IPv6静态路由。
ipv6-address prefix-length:IPv6地址及前缀长度。
interface-type interface-number:路由出接口的类型和编号。对于接口类型为非P2P接口(包括NBMA类型接口或广播类型接口,如VLAN接口),必须指定下一跳地址。
next-hop-address:下一跳IPv6地址。
bfd:使能BFD(Bidirectional Forwarding Detection,双向转发检测)功能,对静态路由下一跳的可达性进行快速检测,当下一跳不可达时可以快速切换到备份路由。
control-packet:通过BFD控制报文方式实现BFD功能。
bfd-source ipv6-address:BFD源IPv6地址。建议配置为Loopback接口IPv6地址。
echo-packet:通过BFD echo报文方式实现BFD功能。
permanent:指定为永久IPv6静态路由。即使在出接口down时,配置的永久IPv6静态路由仍然保持active状态。
public:指定静态路由下一跳处于公网实例。
vpn-instance d-vpn-instance-name:指定目的VPN。d-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果指定目的VPN,IPv6静态路由将根据配置的下一跳IPv6地址在目的VPN中查找出接口。
preference preference-value:路由的优先级,取值范围为1~255,缺省值为60。
tag tag-value:静态路由Tag值,用于标识该条静态路由,以便在路由策略中根据Tag对路由进行灵活的控制。tag-value的取值范围为1~4294967295,缺省值为0。关于路由策略的详细信息,请参见“三层技术-IP路由配置指导”中的“路由策略”。
description description-text:静态路由描述信息。description-text为1~60个字符的字符串,除“?”外,可以包含空格等特殊字符。
vpn-instance s-vpn-instance-name:指定源VPN。s-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。每个VPN都有自己的路由表,配置的IPv6静态路由将被加入指定VPN的路由表。
如果配置的IPv6静态路由指定目的地址为::/0(前缀长度为0),则表示配置了一条IPv6缺省路由。如果报文的目的地址无法匹配路由表中的任何一项,设备将选择IPv6缺省路由来转发IPv6报文。
在配置静态路由时, 如果出接口类型为广播(如VLAN接口),必须指定下一跳地址。
配置IPv6静态路由时需要注意的是:
· 路由振荡时,使能BFD检测功能可能会加剧振荡,需谨慎使用。关于BFD的详细介绍,请参考“可靠性配置指导”中的“BFD”。
· 配置BFD echo报文方式时,下一跳IPv6地址必须为全球单播地址。
· 参数permanent不能和bfd、track一起进行配置。
# 配置IPv6静态路由,该路由的目的地址为1:1:2::/64,下一跳地址为1:1:3::1。
[Sysname] ipv6 route-static 1:1:2:: 64 1:1:3::1
· display ipv6 routing-table protocol(三层技术-IP路由命令参考/IP路由基础)
ipv6 route-static default-preference命令用来配置IPv6静态路由的缺省优先级。
undo ipv6 route-static default-preference命令用来恢复缺省情况。
ipv6 route-static default-preference default-preference-value
IPv6静态路由的缺省优先级为60。
default-preference-value:IPv6静态路由缺省优先级的值,取值范围为1~255。
· 如果在配置IPv6静态路由时没有指定优先级,就会使用缺省优先级。
· 重新配置缺省优先级后,新设置的缺省优先级仅对新增的IPv6静态路由有效。
# 配置IPv6静态路由的缺省优先级为120。
[Sysname] ipv6 route-static default-preference 120
