H3C SOHO交换机 典型配置举例(Comware V5)-6W102
14-IPv6基础典型配置举例
本章节下载 14-IPv6基础典型配置举例  (100.18 KB)
14-IPv6基础典型配置举例
1  IPv6基础典型配置举例
1.1  简介
本章介绍了使用IPv6地址实现IPv6设备间通信的典型配置案例。
1.2  IPv6基础典型配置举例
1.2.1  组网需求
图1所示,Switch作为网关设备,在2001::/64网段内发布地址前缀信息,该网段内的主机根据获取的前缀信息自动配置IPv6地址,生成指向Switch A的缺省路由,实现与外部网络的通信。
图1 IPv6基础配置组网图
1.2.2  配置步骤
1. Switch的配置
# 使能交换机的IPv6转发功能。
<Switch> system-view
[Switch] ipv6
# 配置VLAN接口1采用EUI-64格式的IPv6地址,并允许其发布RA消息。(缺省情况下,所有的接口不会发布RA消息)
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ipv6 address 2001::/64 eui-64
[Switch-Vlan-interface1] undo ipv6 nd ra halt
[Switch-Vlan-interface1] quit
# 配置VLAN接口2的全球单播地址。
[Switch] vlan 2
[Switch-vlan2] port GigabitEthernet 1/0/2
[Switch-vlan2] quit
[Switch-Vlan-interface2] ipv6 address 3001::1 64
[Switch-Vlan-interface2] quit
2. Host的配置
进入Host的cmd命令窗口,安装IPv6协议栈。
C:\Documents and Settings\aa>ipv6 install
1.2.3  验证配置
# 在Host上查看IPv6地址,发现生成以2001::/64为前缀的IPv6地址,网关指定为Switch。
# 在Switch上显示接口信息,可以看到接口配置的IPv6地址。
<Switch> display ipv6 interface
Vlan-interface1 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::223:89FF:FE5F:958C
  Global unicast address(es):
    2001::223:89FF:FE5F:958C, subnet is 2001::/64
  Joined group address(es):
FF02::1:FF00:0
FF02::1:FF00:1
    FF02::1:FF5F:958C
    FF02::2
    FF02::1
  MTU is 1500 bytes
IPv6 Packet statistics:
  InReceives:                    67
  InTooShorts:                   0
  InTruncatedPkts:               0
  InHopLimitExceeds:             0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    26
  OutRequests:                   36
  OutForwDatagrams:              0
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   22
  InMcastNotMembers:             41
  OutMcastPkts:                  21
Vlan-interface2 current state :UP
    3001::1, subnet is 3001::/64
    FF02::1:FF00:0
    FF02::1:FF00:1
    FF02::1:FF5F:958C
    FF02::2
    FF02::1
  MTU is 1500 bytes
  InReceives:                    8
  InTooShorts:                   0
  InTruncatedPkts:               0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    6
  OutRequests:                   8
  OutForwDatagrams:              0
  InNoRoutes:                    0
  InTooBigErrors:                0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   3
  InMcastNotMembers:             2
  OutMcastPkts:                  4
  InDiscards:                    0
1.2.4  配置文件
 ipv6
vlan 1 to 2
interface Vlan-interface1
interface Vlan-interface2
 ipv6 address 3001::1/64
 port access vlan 2
