11-WLAN
HomeSupportDiagnose & MaintainAlarms ReferencesH3C Wireless Access Controllers Alarm Reference(R16xx)-6W10011-WLAN
05-HH3C-DOT11-STATION-MIB
05-HH3C-DOT11-STATION-MIB 166.74 KB
12-HH3C-DOT11-STATION-MIB
About this MIB
Use this MIB to manage client configuration and statistics.
MIB file name
hh3c-dot11-station.mib
Notifications
hh3cDot11StationMICErrorTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.1
A client detected a TKIP decryption MIC error.
Informational
Warning
N/A (N/A)
Off
Notification triggers
This notification is triggered when a MIC error occurs.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable wlan usersec command.
OFF
CLI: Use the undo snmp-agent trap enable wlan usersec command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.3.1.2.1.1 (hh3cDot11CurrAPID)
APID
OCTET STRING
OCTET STRING , (0..127)
1.3.6.1.4.1.25506.2.75.3.1.2.1.2 (hh3cDot11CurrRadioID)
Radio ID
Integer32
Standard MIB values.
1.3.6.1.4.1.25506.2.75.3.2.1.1 (hh3cDot11StationTrapBSSID)
BSSID
MacAddress
1.3.6.1.4.1.25506.2.75.3.1.1.1.12 (hh3cDot11StationSSIDName)
SSID
OCTET STRING
OCTET STRING (0..32)
1.3.6.1.4.1.25506.2.75.3.2.1.2 (hh3cDot11StationTrapStaMAC)
Client MAC address.
MacAddress
Recommended action
No action is required.
hh3cDot11StationAuthenErrorTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.2
Client link authentication failed.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when an error occurs during the authentication negotiation process of 802.11 link establishment by a wireless client.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
APID
OCTET STRING
Radio ID
Integer32
BSSID
MacAddress
SSID
OCTET STRING
Client MAC address.
MacAddress
1.3.6.1.4.1.25506.2.75.3.1.1.1.13 (hh3cDot11StationAuthenMode)
Authentication mode.
Hh3cDot11AuthenType
1.3.6.1.4.1.25506.2.75.3.1.1.1.14 (hh3cDot11StationAKMMode)
Key management mode.
Hh3cDot11AKMType
none(1),, psk(2),, dot1x(3),, ext(4)
Recommended action
hh3cDot11StationAuthorFailTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.3
Client authorization failed.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when a client successfully establishes a wireless link but fails access authentication.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.3.1.1.1.3 (hh3cDot11StationUserName)
Username for the client.
OCTET STRING
OCTET STRING, (0..255)
MAC address of the client.
MacAddress
Radio ID
Integer32
SSID
OCTET STRING
hh3cDot11StationAuthorFailCause (hh3cDot11StationAuthorFailCause)
Reasons for client authorization failure.
Hh3cDot11AuthorFailType
1.3.6.1.4.1.25506.2.75.3.2.1.6 (hh3cDot11StationFailCauseDesc)
Fault description for the client.
OCTET STRING
APID
OCTET STRING
1.3.6.1.4.1.25506.2.75.3.2.1.11 (hh3cDot11StationBSSID)
BSSID to which the client is connected.
MacAddress
1.3.6.1.4.1.25506.2.75.3.2.1.13 (hh3cDot11StationAuthMode)
Client authentication mode.
INTEGER
1.3.6.1.4.1.25506.2.75.3.2.1.16 (hh3cDot11StationTrapAPMacAddress)
AP's MAC address.
MacAddress
Recommended action
hh3cDot11StationAssocFailTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.4
Client association failed.
Informational
Warning
N/A (N/A)
Off
This notification is triggered when a wireless client fails to establish a connection with an AP.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan client command.
OFF
CLI: Use the undo snmp-agent trap enable wlan client command.
Object
OID (object name)
Index
Value range
Client MAC address.
MacAddress
Radio ID
Integer32
ESS name.
OCTET STRING
1.3.6.1.4.1.25506.2.75.3.2.1.4 (hh3cDot11StationAssocFailCause)
Reasons for client association failure.
Hh3cDot11AssocFailType
OCTET STRING
To uniquely identify each AP, the relationship between hh3cDot11CurrAPID and the AP device will be static.
OCTET STRING
AP's MAC address.
MacAddress
MacAddress
Recommended action
hh3cDot11StationDeAssocTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.5
A disassociation request was sent to a client.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when a system needs to transmit a disassociation packet to a wireless client.
System impact
N/A
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
MAC address of the client where a MIC error occurred.
MacAddress
1.3.6.1.4.1.25506.2.75.3.1.1.1.11 (hh3cDot11StationVlanId)
VLAN ID associated with the client.
Integer32
Each radio.
Integer32
ESS name.
OCTET STRING
1.3.6.1.4.1.25506.2.75.3.2.1.7 (hh3cDot11StationSessionDuration)
Duration of the client session.
Unsigned32
OCTET STRING
1.3.6.1.4.1.25506.2.75.3.2.1.10 (hh3cDot11StationAPName)
Name of the AP to which the client is connected.
OCTET STRING
MacAddress
Recommended action
hh3cDot11StationAuthorSuccTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.6
Client authorization succeeded.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when the system determines that the client has successfully connected to the WLAN network and completed link negotiation and access authentication.
System impact
N/A
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
MacAddress
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.3 (hh3cDot11StationSessionStartTime)
How long the client has been connected to the wireless network.
DateAndTime
Each radio.
Integer32
ESS name.
OCTET STRING
OCTET STRING
OCTET STRING
MacAddress
Recommended action
hh3cDot11StationRoamingTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.7
A client roamed to another AP.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when a client roams from one AP to another.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan mobility command.
OFF
CLI: Use the undo snmp-agent trap enable wlan mobility command.
Object
OID (object name)
Index
Value range
OCTET STRING
OCTET STRING
MacAddress
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.8 (hh3cDot11StationRoamingTime)
Time when the client roamed to another AP.
Unsigned32
Each radio.
Integer32
ESS name.
OCTET STRING
1.3.6.1.4.1.25506.2.75.3.2.1.9 (hh3cDot11StationACIPAddress)
IP address of the home AC for roaming clients.
IP address of the foreign AC for roaming clients.
IpAddress
1.3.6.1.4.1.25506.2.75.3.2.1.14 (hh3cDot11StationACIPv6Add)
IPv6 address of the home AC for roaming clients.
IPv6 address of the foreign AC for roaming clients.
OCTET STRING
Recommended action
hh3cDot11StationDisconnectTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.8
A client went offline.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when the system detects that a client is no longer present after the client successfully registers to the system, regardless of how the client left the network.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
MacAddress
ESS name.
OCTET STRING
Unsigned32
Integer32
OCTET STRING
Each radio.
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.12 (hh3cDot11StaDisconnectReason)
Reasons for disconnection between the client and the AP.
OCTET STRING
MacAddress
Recommended action
hh3cDot11UserDisconnectTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.9
A user went offline unexpectedly.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when a client times out. Set the idle-time to 60 seconds. For a PC, if it goes offline unexpectedly, it will be forcibly shut down. For a client other than a PC, a disassociation packet will be sent. If no username exists, the packet is empty.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
MacAddress
1.3.6.1.4.1.25506.2.75.3.2.1.15 (hh3cDot11UserName)
Username.
OCTET STRING
Recommended action
hh3cDot11StaAntennaChgTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.10
A client has connected to a new antenna.
Informational
Major
N/A (N/A)
N/A
System impact
Status control
ON
CLI:
OFF
CLI:
Object
OID (object name)
Index
Value range
OCTET STRING
Each radio.
Integer32
The event occurred on the AP's BSSID.
MacAddress
ESS name.
OCTET STRING
MacAddress
1.3.6.1.4.1.25506.2.75.3.2.1.17 (hh3cDot11StationTrapOldAntennaID)
ID of the old antenna associated with the client.
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.18 (hh3cDot11StationTrapNewAntennaID)
ID of the new antenna associated with the client.
Integer32
Recommended action
hh3cDot11StationAuditTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.11
Client behavior notification.
Informational
Warning
N/A (N/A)
Off
This notification is triggered when a client comes online, goes offline, roams, or obtains an IP address.
System impact
N/A
Status control
ON
CLI: Use the snmp-agent trap enable wlan client-audit command.
OFF
CLI: Use the undo snmp-agent trap enable wlan client-audit command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.3.2.1.21 (hh3cDot11StationAuditTrapOpType)
Client operation type.
Unsigned32
MacAddress
1.3.6.1.4.1.25506.2.75.3.2.1.22 (hh3cDot11StationTrapStaIPAddress)
IP address of the client.
IpAddress
AP's MAC address.
MacAddress
1.3.6.1.4.1.25506.2.75.3.2.1.19 (hh3cDot11StationTrapAPIPAddress)
AP's IP address.
IpAddress
1.3.6.1.4.1.25506.2.75.3.2.1.23 (hh3cDot11StationTrapRadioID)
ID of each channel.
Hh3cDot11RadioScopeType
1.3.6.1.4.1.25506.2.75.3.2.1.24 (hh3cDot11StationTrapRadioMode)
Radio type supported by the client.
Hh3cDot11RadioType2
1.3.6.1.4.1.25506.2.75.3.2.1.25 (hh3cDot11StationTrapWlanID)
WLAN ID of the BSS associated with the client.
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.26 (hh3cDot11StationTrapSSIDName)
ESS name.
Hh3cDot11SSIDStringType
1.3.6.1.4.1.25506.2.75.3.2.1.27 (hh3cDot11StationTrapVlan)
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.28 (hh3cDot11StationTrapChannel)
Current channel used by the client.
Hh3cDot11ChannelScopeType
1.3.6.1.4.1.25506.2.75.3.2.1.29 (hh3cDot11StationTrapRSSI)
Strength of the received signal.
The maximum value is defined by the chipset vendor.
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.20 (hh3cDot11StationTrapStartTime)
Time when the device starts connecting to the client.
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.75.3.2.1.30 (hh3cDot11StationTrapRxFrameKbit)
Number of data frames bits received from the client.
Counter64
1.3.6.1.4.1.25506.2.75.3.2.1.31 (hh3cDot11StationTrapTxFrameKbit)
Number of data frame bits sent to the client.
Counter64
Recommended action
