| 02-HH3C-DOT11-CFG-MIB | 62.19 KB |
04-HH3C-DOT11-CFG-MIB
About this MIB
Use this MIB to configure wireless settings.
MIB file name
hh3c-dot11-cfg.mib
Notifications
hh3cDot11CfgCipherChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.75.4.9.0.1 |
Wireless service encryption type changed |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
This alarm is generated if the configured encryption algorithm for a wireless service changes.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable wlan usersec command.
OFF
CLI: Use the undo snmp-agent trap enable wlan usersec command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.4.2.2.1.2 (hh3cDot11SSIDName) |
SSID |
Hh3cDot11SSIDStringType |
Hh3cDot11SSIDStringType(1..32) |
1.3.6.1.4.1.25506.2.75.4.2.3.1.3 (hh3cDot11SecurityCiphers) |
Cipher suite |
Integer32 |
Standard MIB values. |
Recommended action
No action is required.
hh3cDot11CfgPSKChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.4.9.0.2 |
Wireless service PSK changed |
Informational |
Warning |
N/A (N/A) |
OFF |
This alarm is generated if the configured PSK changes for a service template configured with PSK encryption and authentication.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
SSID |
Recommended action
hh3cDot11SSIDWepIDConflictTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.4.9.0.3 |
AP WEP key configuration conflict |
Informational |
Warning |
N/A (N/A) |
OFF |
This alarm is generated if two service templates bound to an AP are configured with the same WEP key ID.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.4.9.1.1 (hh3cDot11PreConflictTemplateNum) |
In the password configuration, when the wireless radio frequency binding service policy conflicts with the current service policy and the previous service policy, the previous service policy ID |
Integer32 |
Integer32 (1..1024) |
1.3.6.1.4.1.25506.2.75.4.9.1.2 (hh3cDot11CurrConflictTemplateNum) |
In the password configuration, when the wireless radio frequency binding service policy conflicts with the current service policy and the previous service policy, the current service policy ID |
Integer32 |
1.3.6.1.4.1.25506.2.75.4.9.1.3 (hh3cDot11ConflictCipherIdx) |
Conflicting wep ID |
Integer32 |
Integer32 (1..4) |
1.3.6.1.4.1.25506.2.75.4.9.1.4 (hh3cDot11ConfigureAPID) |
Configured AP. |
Hh3cDot11ObjectIDType |
Hh3cDot11ObjectIDType (0..127) |
1.3.6.1.4.1.25506.2.75.4.9.1.5 (hh3cDot11ConfigureRadioID) |
Wireless radio configured on the AP |
Hh3cDot11RadioScopeType |
1.3.6.1.4.1.25506.2.75.4.9.1.6 (hh3cDot11ConfigureAPMacAddress) |
MAC address of the AP. |
MacAddress |
MacAddress(6) |
1.3.6.1.4.1.25506.2.75.4.9.1.7 (hh3cDot11PreConflictTemplateSSID) |
Previous SSID of the AP. |
1.3.6.1.4.1.25506.2.75.4.9.1.8 (hh3cDot11CurrConflictTemplateSSID) |
Current SSID of the AP. |
Recommended action
