11-WLAN
HomeSupportDiagnose & MaintainAlarms ReferencesH3C Wireless Access Controllers Alarm Reference(R16xx)-6W10011-WLAN
01-HH3C-DOT11-APMT-MIB
01-HH3C-DOT11-APMT-MIB 242.05 KB
02-HH3C-DOT11-APMT-MIB
About this MIB
Use this MIB to obtain AP information.
MIB file name
hh3c-dot11-apmt.mib
Notifications
hh3cDot11APMtWorkModeChgTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.1
AP operating mode switchover
N/A
N/A
N/A (N/A)
N/A
Notification triggers
This notification is generated when an error occurs during AP configuration on the AC.
System impact
Configuration deployment fails.
Status control
ON
CLI: snmp-agent trap enable wlan ap
OFF
CLI: undo snmp-agent trap enable wlan ap
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.2.1.1.1.1 (hh3cDot11APID)
Serial number of the AP
N/A
Hh3cDot11ObjectIDType
OCTET STRING (0..127)
1.3.6.1.4.1.25506.2.75.2.1.3.1.2 (hh3cDot11RadioID)
Radio ID
N/A
Integer32
Integer32(0..2147483647)
1.3.6.1.4.1.25506.2.75.2.3.1.1 (hh3cDot11APMtTrapCfgErrReason)
Reason
N/A
Hh3cDot11NotifyReasonType
OCTET STRING(0..255)
Recommended action
No action is required.
hh3cDot11APMtRadioFailTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.3
AP radio down
Informational
Warning
1.3.6.1.4.1.25506.2.75.2.3.0.4 (hh3cDot11APMtRadioFailRecoverTrap)
OFF
When the AC receives the update configuration response message, if the configuration update fails, and the reason is the failure to set the channel, failure to set the RD status, failure to set the hardware retrys, failure to set the beacon interval, failure to set the RD operating mode, or failure to set the preamble, it sends this trap.
System impact
Radio is unavailable.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING(0..127)
Radio ID
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.2 (hh3cDot11APMtTrapRadioFailReason)
Reason for the down event
N/A
INTEGER
config(1) , hh3cerror(2) , swerror(3) , radar(4) , unknown(8)
Recommended action
Redeploy the configuration.
Basic information
OID
Event
Severity
Default status
AP radio up
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a radio comes up.
System impact
Radio is available.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Radio ID
N/A
Integer32
N/A
INTEGER
Recommended action
hh3cDot11APMtRdoChanlChgTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.5
Radio channel change
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the channel of a radio changes.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Radio ID
N/A
Integer32
Standard MIB values.
1.3.6.1.4.1.25506.2.75.2.3.1.5 (hh3cDot11APChannelChgMode)
Channel type change
N/A
Hh3cDot11RFModeType
manual(1),, auto(2)
1.3.6.1.4.1.25506.2.75.2.3.1.3 (hh3cDot11APMtTrapOldChannel)
Previous channel number
N/A
Hh3cDot11ChannelScopeType
Integer32, Standard MIB values.
1.3.6.1.4.1.25506.2.75.2.3.1.4 (hh3cDot11APMtTrapNewChannel)
New channel number
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.16 (hh3cDot11APMtChanlChgCount)
Number of changes
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.24 (hh3cDot11APMtTrapAPMacAddress)
Corresponding MAC
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11APMtTimeSynFail
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.6
AP clock synchronization failed
Informational
Warning
N/A (N/A)
OFF
AC will regularly send clock synchronization requests to all successfully registered APs. If no corresponding response is received, the system will send a "clock synchronization alarm." Only when the AC sends update config to the AP will it carry a timestamp. If the AP response times out, this alarm will be triggered. In other cases, the AP will not respond to this timestamp.
Possible causes include:
If the master AC sends an update config message at master/backup AC switchover, this notification is sent.
When setting echo-interval, the AC will send an update config to the AP, at which point the AP will respond, thus not meeting the alarm sending condition; If the AP is disconnected and then echo-interval is set again, the AP response will inevitably time out, triggering the alarm.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Recommended action
hh3cDot11APMtChlIntfDetected
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.7
Channel interference detected
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the AP detects interference.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan rrm command.
OFF
CLI: Use the undo snmp-agent trap enable wlan rrm command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.2.1.3.1.5 (hh3cDot11Channel)
Channel
N/A
Integer32
Recommended action
hh3cDot11APMtIntfAPDetected
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.8
AP detected
Informational
Warning
1.3.6.1.4.1.25506.2.75.2.3.0.16 (hh3cDot11APInterfClearTrap)
OFF
This notification is generated when the system detects the presence of wireless APs.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Channel
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.7 (hh3cDot11APIntfDevMACAddress)
MAC address
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11APMtIntfStaDetected
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.9
Client detected
N/A
N/A
N/A (N/A)
N/A
This alarm is generated if the AP fails to write data into the flash.
System impact
Failed to update the AP version.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.17 (hh3cDot11APMtFormerApVersion)
Original version number
N/A
OCTET STRING
OCTET STRING
MAC address of the AP
N/A
MacAddress
OCTET STRING(6)
Recommended action
Identify whether the issue is caused by insufficient memory or insufficient flash.
hh3cDot11APMtAvailChlTooLow
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.13
Low number of available channels
Informational
Warning
1.3.6.1.4.1.25506.2.75.2.3.0.27 (hh3cDot11DFSFreeCntBelowThrRecov)
OFF
When an AP performs auto channel selection and all detected channels are in a bad condition, this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Radio ID
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.18 (hh3cDot11APMtAPID)
AP Identifier
N/A
OCTET STRING(1..127)
MAC address
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11APImgDwldSuccess
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.14
AP image downloading succeeded
Informational
Warning
N/A (N/A)
OFF
If the versions of AP and AC do not match, the AP will automatically download the version. When the version download is complete, the AC will send this alarm.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.2.1.2.1.8 (hh3cDot11CurrAPName)
AP Name
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.75.2.1.2.1.2 (hh3cDot11CurrAPIPAddress)
AP IP Address
N/A
IpAddress
1.3.6.1.4.1.25506.2.75.2.1.2.1.11 (hh3cDot11CurrAPSoftwareVersion)
Current version number of AP
N/A
OCTET STRING
Recommended action
hh3cDot11APInterfDetectedTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.15
Adjacent AP interference
N/A
N/A
N/A (N/A)
N/A
This notification is generated when the AP no longer detects any co-channel AP or when the signal strength of all co-channel APs is less than hh3cDot11IntfTrapThreshold (default value -60dBm).
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Channel
N/A
Integer32
As stipulated in the 802.11x protocol
AP Identifier
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.19 (hh3cDot11APMtRadioID)
Radio ID
N/A
Hh3cDot11RadioScopeType
1.3.6.1.4.1.25506.2.75.2.3.1.21 (hh3cDot11APMtInterfMacAdd)
MAC address
N/A
MacAddress
OCTET STRING(6)
1.3.6.1.4.1.25506.2.75.2.3.1.23 (hh3cDot11APMtFirstTrapTime)
Timestamp.
N/A
Timeticks
Neighbor MAC address
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11StaInterfDetectedTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.17
Client interference detected
N/A
N/A
N/A (N/A)
N/A
When the radio changes from UP to Down, it will trigger this alarm.
Possible reasons for this alarm include:
AP offline when tunnel is down.
When the radio interface is down, for example, radio disable. (Note: When the radio status changes, such as enabling or disabling the radio, and when the CAPWAP tunnel is disconnected, an alarm will be triggered. Removing the last service template for the radio to delete the AP, but not disabling the radio status, will not trigger this alarm.)
When hwSysTrapCollectionPeriod times out, and the time interval since the last trap transmission exceeds hwSysTrapResendPeriod, this alarm will be sent repeatedly.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Radio ID
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.12 (hh3cDot11APRadioDownReason)
N/A
INTEGER
phyicalUnusable(1) , configDisable(2)  operatinUnusable(3) , apTunnelDown(4)
N/A
First occurrence time
N/A
TimeTicks
N/A
MacAddress
OCTET STRING (6)
Recommended action
hh3cDot11APRadioDownRecovTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.24
Wireless link recovered
Informational
Major
N/A (N/A)
OFF
When the Radio of Ap changes from Down to UP, this alarm will be triggered. After a "wireless link disruption" occurs, if the following conditions happen, the system detects that the air interface can provide wireless service, then sends a "link recovery" alarm:
When the radio interface changes from down to up, for example, radio enable. (Note: This trap is sent when the radio status changes, i.e., enabling a previously disabled radio. However, this alarm is not triggered if the radio is enabled for the first time after the AP comes online.)
System impact
The radio is not available.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Radio ID
N/A
Integer32
N/A
INTEGER
N/A
N/A
TimeTicks
N/A
MacAddress
OCTET STRING (6)
Recommended action
hh3cDot11APStaFullTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.25
Client quantity upper limit reached
Informational
Warning
1.3.6.1.4.1.25506.2.75.2.3.0.26 (hh3cDot11APStaFullRecoverTrap)
OFF
When the number of clients is about to exceed the maximum value allowed by the AP, this alarm will be triggered.
System impact
Status control
ON
CLI: snmp-agent trap enable wlan client
OFF
CLI: undo snmp-agent trap enable wlan client
Object
OID (object name)
Index
Value range
APID
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.11 (hh3cDot11StaLimitNumber)
Maximum number of clients on the AP.
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.10 (hh3cDot11StaFullReason)
Reasons for the number of clients reaching the upper limit
N/A
INTEGER
ap(1), bss(2), radio(3), radioConcur(4), radiopolicy(5), ac(6), acConcur(7), aid(8)
First alarm time
N/A
TimeTicks
MAC address of the AP.
N/A
MacAddress
OCTET STRING (6)
Recommended action
Check the configuration or add more APs.
Basic information
OID
Event
Severity
Default status
Upper limit-reaching alarm removed for associated client quantity
Informational
Warning
N/A (N/A)
OFF
The number of clients dropped below the maximum allowed number.    .
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
APID
N/A
N/A
Integer32
Reason
N/A
INTEGER
First alarm time
N/A
TimeTicks
N/A
MacAddress
OCTET STRING (6)
Recommended action
Basic information
OID
Event
Severity
Default status
Alarm removed for low number of available channels
Informational
Warning
N/A (N/A)
OFF
If the available channel condition recovers, this alarm will be generated.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Radio ID
N/A
Integer32
AP Identifier
N/A
MAC address
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11APCpuUsageHigh
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.28
AP CPU usage exceeding threshold
N/A
N/A
N/A (N/A)
N/A
When the number of terminals on an AP exceeds the set threshold (hh3cDot11APUserThreshold), the system will generate this alarm.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
APID
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.14 (hh3cDot11APTrapUserCnt)
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.15 (hh3cDot11APTrapUserThreshold)
Threshold for online users of AP
N/A
Integer32
Recommended action
hh3cDot11APMtDetectedIntfAP
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.33
Co-channel interference from adjacent APs
Informational
Warning
OFF
When the AP detects that the signal strength of the neighboring AP on the same channel is greater than hh3cDot11IntfTrapThreshold (default value is -60dbm), this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
AP Identifier
N/A
RADIO
N/A
1.3.6.1.4.1.25506.2.75.2.3.1.20 (hh3cDot11APMtChannel)
Channel
N/A
Integer32
MAC address
N/A
MacAddress
OCTET STRING(6)
Timestamp.
N/A
Timeticks
N/A
MacAddress
OCTET STRING(6)
Recommended action
hh3cDot11APMtDetectedIntfSTA
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.34
N/A
N/A
N/A (N/A)
N/A
The AP detects that there are adjacent frequency channels AP and the signal strength of the adjacent AP is greater than hh3cDot11AdjIntfTrapThreshold (default value is -60dbm), then this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
AP ID
N/A
Radio ID
N/A
Channel
N/A
Integer32
1.3.6.1.4.1.25506.2.75.2.3.1.22 (hh3cDot11APMtAdjChannel)
Neighbor channel
N/A
Integer32
MAC address
N/A
MacAddress
OCTET STRING(6)
Timestamp.
N/A
Timeticks
Recommended action
hh3cDot11DetcAdjChlIntfAPClear
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.37
Neighbor AP co-channel interference cleared
Informational
Warning
N/A (N/A)
OFF
When the AP no longer detects any AP on the same channel or when the signal strength of all APs on the same channel is less than hh3cDot11IntfTrapThreshold (default value is -60dbm), this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
AP Identifier
N/A
Radio ID
N/A
Channel
N/A
Integer32
Neighbor channel
N/A
Integer32
MAC address
N/A
MacAddress
OCTET STRING(6)
Timestamp.
N/A
Timeticks
Recommended action
hh3cDot11APPowerOffTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.38
AP power outage
N/A
N/A
N/A (N/A)
N/A
System impact
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.2.3.0.38 (1.3.6.1.4.1.25506.2.75.2.3.0.38)
AP power outage
N/A
N/A
N/A
Recommended action
OID
Event
Severity
Default status
AP power outage
N/A
N/A
N/A
N/A
hh3cDot11APPowerOnTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.39
AP power-on
N/A
N/A
N/A (N/A)
N/A
System impact
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.2.3.0.39 (1.3.6.1.4.1.25506.2.75.2.3.0.39)
AP power-on
N/A
N/A
N/A
Recommended action
OID
Event
Severity
Default status
AP power-on
N/A
N/A
N/A
N/A
hh3cDot11UpLinkSwitchTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.2.3.0.40
Uplink switchover 3G/4G
N/A
N/A
N/A (N/A)
N/A
System impact
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.2.3.0.40 (1.3.6.1.4.1.25506.2.75.2.3.0.40)
N/A
N/A
N/A
Recommended action
OID
Event
Severity
Default status
N/A
N/A
N/A
N/A
