H3C Router Software Upgrade Guide-6W100
HomeSupportInstall & UpgradeUpgrade GuidesH3C Router Software Upgrade Guide-6W100
08-Verifying the upgrade
08-Verifying the upgrade 53.40 KB
This chapter includes the following sections:
·     Verifying that the router is running the new BootWare image
·     Verifying that the router is running the new software images
·     Verifying that a patch or feature image is installed successfully
·     Verifying that the cards and subcards are in normal state (modular router)
·     Verifying that the router is in stable state
·     Verifying that the configuration has been recovered
·     Verifying that the services are normal
The verification is required only if the BootWare image has been upgraded.
Use one of the following methods:
·     Reboot the router to check whether the router is running the new BootWare image.
If not, examine the upgrade steps and perform the upgrade steps again.
The command output might vary by router model. This section uses a CR16000-F router as an example.
*                         BootWare, Version 1.51                           *
·     Use the display version command to verify that the router is running the new BootWare image. If not, examine the upgrade steps and perform the upgrade steps again.
The verification is required only if the startup software has been upgraded.
# Use the display boot-loader command to check whether the router is running the new software images.
<Sysname>display boot-loader
Software images on slot 0:
Current software images:
  cfa0:/CR16000-CMW710-BOOT-R8260P22.bin
  cfa0:/CR16000-CMW710-SYSTEM-R8260P22.bin
Main startup software images:
Backup startup software images:
  None
The verification is required only if a patch or feature image has been installed.
# Use the display install active command to check whether a patch or feature image has been installed successfully.
If the command output does not have a patch or feature image, no patch or feature image has been installed or the patch or feature image installation fails.
<Sysname>display install active
Active packages on slot 0:
  cfa0:/CR16000-CMW710-SYSTEM-WEAK-R8260P22H01.bin
Active packages on slot 6:
Active packages on slot 13:
# Use the display device command to check whether the cards and subcards are in normal state.
The Brd Status field indicates the card or subcard status.
<Sysname>display device
Slot No. Brd Type           Brd Status   Software Version
 0       CSR05SRP1P3        Master       CR16000-CMW710-R8260P22
 1       NONE               Absent       NONE
 2       NONE               Absent       NONE
 3       NONE               Absent       NONE
 4       CSPEX-1504X        Normal       CR16000-CMW710-R8260P22
 5       NONE               Absent       NONE
 6       CSPEX-1504X        Normal       CR16000-CMW710-R8260P22
 7       NONE               Absent       NONE
 8       NONE               Absent       NONE
 9       NONE               Absent       NONE
 10      NONE               Absent       NONE
 11      NONE               Absent       NONE
 12      NONE               Absent       NONE
 13      CSFC-08E1          Normal       CR16000-CMW710-R8260P22
 14      NONE               Absent       NONE
# Use the display system stable state command to check whether the router is in stable state.
The router is stable if the System State field displays Stable.
<Sysname> display system stable state
System state     : Stable
Redundancy state : No redundancy
  Slot    CPU    Role       State
  0       0      Active     Stable
  6       0      Other      Stable
  6       1      Other      Stable
  13      0      Other      Stable
# Use the display current-configuration command to view the current configuration.
# Use the display diff current-configuration startup-configuration command to check whether configurations are lost or modified.
# Collect entries (such as routing entries, FIB entries, and MAC address entries) and compare them with the entries before the upgrade to check whether entries are lost.
# Check whether the service traffic before and after the upgrade is the same.
# Check whether the servers such as NMS servers are working correctly.
Before verifying the services, do not execute the save command.
