- H3C Router Software Upgrade Guide-6W100
- 01-About software upgrade
- 02-Upgrade restrictions and guidelines
- 03-Upgrade workflow
- 04-Preparing for the upgrade
- 05-Upgrading the BootWare
- 06-Upgrading the startup software
- 07-Installing patches and features
- 08-Verifying the upgrade
- 09-Rolling back the running software images
- 10-Troubleshooting
- 11-Appendix A Downloading the upgrade file
- 12-Appendix B Software upgrade record form
- 13-Appendix C Acronyms
| 05-Upgrading the BootWare | 94.66 KB |
Upgrading the BootWare at the CLI on a single-MPU device (distributed devices in standalone mode)
Upgrading the BootWare at the CLI on a dual-MPU device (distributed devices in standalone mode)
Upgrading the BootWare at the CLI (distributed devices in IRF mode)
Upgrading the BootWare at the CLI (centralized devices)
Upgrading the BootWare from the BootWare menu
You can upgrade the BootWare at the CLI or from the BootWare menu.
· Upgrading the BootWare at the CLI on a single-MPU device (distributed devices in standalone mode)
· Upgrading the BootWare at the CLI on a dual-MPU device (distributed devices in standalone mode)
· Upgrading the BootWare at the CLI (distributed devices in IRF mode)
· Upgrading the BootWare at the CLI (centralized devices)
· Upgrading the BootWare from the BootWare menu
Upgrade workflow
Figure 1 Upgrade workflow
Upgrade procedure
Commands might slightly vary by router model. This section uses a CR16000-F router as an example.
See "Preparing for the upgrade."
Download the upgrade file from an PC to the router. For more information, see "Appendix A Downloading the upgrade file."
Decompressing the .ipe file
If the upgrade file for upgrading the BootWare is in an .ipe file, decompress the .ipe file and save the decompressed files in the root directory of the storage medium on the router.
<Sysname>install add cfa0:/newest.ipe cfa0:
Verifying image file...Done.
This operation will take several minutes, please wait...........................
....................................................Done.
A boot image and a system image are generated in in the root directory of the storage medium after decompression.
# Upgrade the BootWare on the MPU in slot 0.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin slot 0
This command will update bootrom file on the specified board(s),
Continue? [Y/N]:y
Now updating the Boot ROM, please wait........... ...........Done
# Upgrade the BootWare on the service module in slot 3. The upgrade step for other service modules is the same.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin slot 3
Continue? [Y/N]:y
# Upgrade the BootWare on the switching fabric module in slot 6. The upgrade step for other switching fabric modules is the same.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin slot 6
Continue? [Y/N]:y
Rebooting the router
# Reboot the router to complete the BootWare upgrade.
<Sysname> reboot
Start to check configuration with next startup configuration file, please wait.
........DONE!
Now rebooting, please wait...
Upgrade workflow
Figure 2 Upgrade workflow
Upgrade procedure
# Upgrade the BootWare on the active MPU in slot 0 and standby MPU in slot 1.
Continue? [Y/N]:y
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin slot 1
Continue? [Y/N]:y
Continue? [Y/N]:y
Continue? [Y/N]:y
<Sysname> reboot
........DONE!
NOTE: · In this section, the IRF fabric has two member devices, and each member device has two MPUs. · The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. |
Upgrade workflow
Figure 3 Upgrade workflow
Upgrade procedure
# Upgrade the BootWare on the all MPUs in the IRF fabric.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 1 slot 0
Continue? [Y/N]:y
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 1 slot 1
Continue? [Y/N]:y
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 2 slot 0
Continue? [Y/N]:y
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 2 slot 1
Continue? [Y/N]:y
# Upgrade the BootWare on the service module in slot 3 of chassis 1. The upgrade step for other service modules is the same.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 1 slot 3
Continue? [Y/N]:y
# Upgrade the BootWare on the switching fabric module in slot 6 of chassis 1. The upgrade step for other switching fabric modules is the same.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 1 slot 6
Continue? [Y/N]:y
<Sysname> reboot
........DONE!
Upgrade workflow
Figure 4 Upgrade workflow
Upgrade procedure
Commands might slightly vary by router model. This section uses an MSR 2600 router as an example.
<Sysname>install add flash:/newest.ipe flash:
# Upgrade the BootWare on the router.
<Sysname> bootrom update file flash:/msr26-CMW710-BOOT-R0821P18.bin slot 1
This command will update the Boot ROM file on the specified board(s), Continue? [Y/N]:y
Now updating the Boot ROM, please wait................Done.
<Sysname> reboot
........DONE!
Upgrade workflow
Figure 5 Upgrade workflow
Upgrade procedure
Downloading and upgrading the BootWare from the BootWare menu
NOTE: · The BootWare menu varies by router model and BootWare version. This section uses a CR16000-F router as an example. · The operation of downloading an image file through FTP is similar to that through TFTP. This section uses FTP as an example. |
1. Run the FTP server program on a PC (its IP address is 192.168.0.23), set the working directory, FTP username, and password. Store the upgrade file on the working directory of the FTP server.
2. Run the terminal emulation program on the PC, and power on the router. Press Ctrl+B at prompt to access the EXTENDED-BOOTWARE menu.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
3. (Optional.) Set the default storage medium.
IMPORTANT: If the storage medium storing the BootWare image file is not the default storage medium, set it as the default storage medium. |
# Enter 9 to access the storage device submenu.
==============================<DEVICE CONTROL>==============================
|<1> Display All Available Nonvolatile Storage Device(s) |
|<2> Set The Operating Device |
|<3> Set The Default Boot Device |
|<0> Exit To Main Menu |
Enter your choice(0-3):
# Enter 2 to set the storage medium for storing the BootWare image file.
Please set the operating device:
|Note:the operating device is cfa0 |
|NO. Device Name File System Total Size Available Space |
|1 flash JFFS2 262144KB 224937KB |
|2 cfa0 FAT 2044256KB 1173684KB |
|0 Exit |
Enter your choice(0-2):
# Enter 2 to configure the CF card as the storage medium for storing the BootWare image file.
# Enter 3 to set the default storage medium.
Please set the default device:
|Note:the default device is cfa0 |
|0 Exit |
# Enter 2 to configure the CF card as the default storage medium.
# Enter 0 to exit the storage device submenu.
4. Download and upgrade the BootWare.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
# Enter 7 to access the BootWare Operation submenu.
=========================<BootWare Operation Menu>==========================
|<1> Backup Full BootWare |
|<2> Restore Full BootWare |
|<3> Update BootWare By Serial |
|<4> Update BootWare By Ethernet |
Enter your choice(0-4):
# Enter 4 to access the Ethernet submenu.
===================<BOOTWARE OPERATION ETHERNET SUB-MENU>===================
|<1> Update Full BootWare |
|<2> Update Extended BootWare |
|<3> Update Basic BootWare |
|<4> Modify Ethernet Parameter |
# Enter 4 to configure the network settings.
NOTE: To use the existing setting for a field, press Enter without modifying the setting. |
==========================<ETHERNET PARAMETER SET>==========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :ftp
Load File Name :test.btw
:mpu.btw
Target File Name :test.btw
:mpu.btw
Server IP Address :192.168.0.23
Local IP Address :192.168.0.105
Subnet Mask :255.255.255.0
Gateway IP Address :0.0.0.0
FTP User Name :xxx
FTP User Password :***
Table 1 Network parameter fields and shortcut keys
'.' = Clear field |
Press a dot (.) and then press Enter to clear the setting for a field. |
'-' = Go to previous field |
Press a hyphen (-) and then press Enter to return to the previous field. |
Ctrl+D = Quit |
Press Ctrl+D to exit the ETHERNET PARAMETER SET menu. |
Protocol (FTP or TFTP) |
Set the file transfer protocol to FTP or TFTP. |
Load File Name |
Set the name of the file to be downloaded. |
Target File Name |
Set a file name for saving the file on the router. The target file name must have the same extension as the source file. By default, the target file name is the same as the source file name. |
Server IP Address |
Set the IP address of the FTP or TFTP server. |
Local IP Address |
Set the IP address of the Ethernet interface that connects to the TFTP server. |
Subnet Mask |
Set the IP address mask. |
Gateway IP Address |
Set a gateway IP address if the router is on a different network than the server. |
After you finish setting the FTP parameters, the system returns to the BOOTWARE OPERATION ETHERNET submenu.
# Choose an option from options 1 to 3. For example, enter 1 to upgrade the entire BootWare image.
Loading...........Done!
447612 bytes downloaded!
Updating Basic BootWare? [Y/N]
# Enter Y to upgrade the basic BootWare segment.
Updating Basic BootWare.........Done!
Updating Extended BootWare? [Y/N]
# Enter Y to upgrade the extended BootWare segment.
Updating Extended BootWare.........Done!
# Enter 0 to return to the BootWare Operation menu.
# Enter 0 in the BootWare Operation menu to return to the EXTENDED-BOOTWARE menu.
# Enter 0 in the EXTENDED-BOOTWARE menu to reboot the router.
NOTE: For a modular router that has an active MPU and a standby MPU, you must access the BootWare menus of them through the console port to upgrade their BootWares. You also need to connect to the management Ethernet ports on both MPUs. |
