H3C Router Software Upgrade Guide-6W100
HomeSupportInstall & UpgradeUpgrade GuidesH3C Router Software Upgrade Guide-6W100
00-Preface
00-Preface 101.04 KB
Preface
H3C Router Software Upgrade Guide guides you through the upgrade of your routers. The guide contains the following sections:
·     About software upgrade
·     Upgrade restrictions and guidelines
·     Preparing for the upgrade
·     Upgrading the BootWare
·     Upgrading the startup software
·     Installing patches and features
·     Verifying the upgrade
·     Rolling back the running software images
·     Troubleshooting
·     Downloading the upgrade file
·     Software upgrade record form
·     Acronyms
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the routers
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
