11-Network Management and Monitoring Command Reference
HomeSupportSwitchesH3C S6300 Switch SeriesReference GuidesCommand ReferencesH3C S6300 Switch Series Command References-Release 243x-6W10011-Network Management and Monitoring Command Reference
07-NQA commands
07-NQA commands 291.21 KB
NQA commands· 1
NQA client commands· 1
advantage-factor 1
codec-type· 1
data-fill 2
data-size· 3
description (any NQA operation type view) 4
destination ip· 5
destination ipv6· 6
destination port 6
display nqa history· 7
display nqa reaction counters· 8
display nqa result 10
display nqa statistics· 16
expect data· 24
expect ip· 25
expect ipv6· 25
expect status· 26
filename· 27
frequency· 27
history-record enable· 28
history-record keep-time· 29
history-record number 30
init-ttl 30
lsr-path· 31
max-failure· 31
mode· 32
next-hop· 33
no-fragment enable· 33
nqa· 34
nqa agent enable· 35
nqa schedule· 35
nqa template· 36
operation (FTP operation view) 37
operation (HTTP operation view) 38
out interface· 38
password· 39
probe count 40
probe packet-interval 41
probe packet-number 42
probe packet-timeout 42
probe timeout 43
raw-request 44
reaction checked-element { jitter-ds | jitter-sd } 45
reaction checked-element { owd-ds | owd-sd } 46
reaction checked-element icpif 47
reaction checked-element mos· 48
reaction checked-element packet-loss· 49
reaction checked-element probe-duration· 50
reaction checked-element probe-fail (for trap) 51
reaction checked-element probe-fail (for trigger) 53
reaction checked-element rtt 53
reaction trap· 55
reaction trigger probe-fail 56
reaction trigger probe-pass· 56
resolve-target 57
resolve-type· 58
route-option bypass-route· 58
source interface· 59
source ip· 60
source ipv6· 61
source port 61
statistics hold-time· 62
statistics interval 63
statistics max-group· 63
target-only· 64
tos· 65
ttl 65
type· 66
url 67
username· 68
version· 69
vpn-instance· 69
NQA server commands· 70
display nqa server 70
nqa server enable· 71
nqa server tcp-connect 71
nqa server udp-echo· 72
NQA commands
NQA client commands
advantage-factor
Use advantage-factor to configure the advantage factor that is used to count Mean Opinion Scores (MOS) and Calculated Planning Impairment Factor (ICPIF) values.
Use undo advantage-factor to restore the default.
advantage-factor factor
The advantage factor is 0.
Voice operation view
factor: Specifies the advantage factor in the range of 0 to 20.
The evaluation of voice quality depends on users' tolerance for voice quality. For users with higher tolerance for voice quality, use the advantage-factor command to configure the advantage factor. When the system calculates the ICPIF value, the specified advantage factor is subtracted to modify ICPIF and MOS values for voice quality evaluation.
# Set the advantage factor to 10 for the voice operation.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] advantage-factor 10
codec-type
Use codec-type to configure the codec type for the voice operation.
Use undo codec-type to restore the default.
codec-type { g711a | g711u | g729a }
undo codec-type
The codec type for the voice operation is G.711 A-law.
g711a: Specifies the G.711 A-law codec type.
g711u: Specifies the G.711 µ-law codec type
g729a: Specifies the G.729 A-law codec type.
# Set the codec type to g729a for the voice operation.
[Sysname-nqa-admin-test-voice] codec-type g729a
data-fill
Use data-fill to configure the string to be filled in the payload of each probe packet.
Use undo data-fill to restore the default.
data-fill string
undo data-fill
The payload fill string is hexadecimal number 00010203040506070809.
ICMP/UDP echo operation view
Path/UDP jitter operation view
ICMP/TCP/UDP template view
string: Specifies a case-sensitive string of 1 to 200 characters.
If the payload length is smaller than the string length, only the first part of the string is filled. For example, if you configure the string as abcd and the payload size as 3 bytes, abc is filled.
If the payload length is greater than the string length, the system fills the payload with the string cyclically until the payload is full. For example, if you configure the string as abcd and the payload size as 6 bytes, abcdab is filled.
How the string is filled depends on the operation type.
·     For the ICMP echo operation, the string fills the whole payload of an ICMP echo request.
·     For the UDP echo operation, the first five bytes of the payload of a UDP packet are for special purpose. The string fills the remaining part of payload.
·     For the UDP jitter operation, the first 68 bytes of the payload of a UDP packet are for special purpose. The string fills the remaining part of the payload.
·     For the voice operation, the first 16 bytes of the payload of a UDP packet are for special purpose. The string fills the remaining part of the payload.
·     For the path jitter operation, the first four bytes of the payload of an ICMP echo request are for special purpose. The string fills the remaining part of payload.
# Specify abcd as the payload fill string for ICMP echo requests.
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] data-fill abcd
# In TCP template view, specify abcd as the payload fill string for probe packets.
[Sysname] nqa template tcp tcptplt
[Sysname-nqatplt-tcp-tcptplt] data-fill abcd
data-size
Use data-size to configure the size of the payload in each ICMP echo request of the ICMP echo and path jitter operations, or in each UDP packet of the UDP echo, UDP jitter, and voice operations.
Use undo data-size to restore the default.
data-size size
undo data-size
The default payload size of a probe packet for different operations is described in Table 1.
Table 1 Default payload size of a probe packet
Operation type
Codec type
Default size (bytes)
ICMP echo
N/A
100
UDP echo
N/A
100
UDP jitter
N/A
100
UDP tracert
N/A
100
Path jitter
N/A
100
Voice
G.711 A-law
172
Voice
G.711 µ-law
172
Voice
G.729 A-law
32
UDP tracert operation view
ICMP/UDP template view
size: Specifies the payload size. Available value ranges include:
·     20 to 8100 for the ICMP echo, UDP echo, or UDP tracert operation..
·     68 to 8100 for the UDP jitter or path jitter operation.
·     16 to 1500 for the voice operation.
In ICMP echo and path jitter operations, the command sets the payload size for each ICMP echo request.
In UDP echo, UDP jitter, UDP tracert, and voice operations, the command sets the payload size for each UDP packet.
# Set the payload size to 80 bytes for each ICMP echo request.
[Sysname-nqa-admin-test-icmp-echo] data-size 80
# In ICMP template view, set the payload size to 80 bytes for each probe packet.
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt] data-size 80
Use description to configure a description for an NQA operation, such as the operation type or purpose.
Use undo description to remove the description.
No description is configured for an NQA operation.
Any NQA operation type view
Any NQA template view
text: Specifies a description, a case-sensitive string of 1 to 200 characters.
# Configure the description as icmp-probe for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] description icmp-probe
# In ICMP template view, configure the description as icmp-probe.
[Sysname-nqatplt-icmp-icmptplt] description icmp-probe
destination ip
Use destination ip to configure the destination IP address for the operation.
Use undo destination ip to remove the destination IP address.
destination ip ip-address
undo destination ip
No destination IP address is configured for the operation.
DHCP/DLSw/DNS/SNMP/TCP/voice operation view
DNS/ICMP/TCP/UDP template view
ip-address: Specifies the destination IP address for the operation.
# Specify 10.1.1.1 as the destination IPv4 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
# In ICMP template view, specify 10.1.1.1 as the destination IPv4 address for the ICMP echo operation.
[Sysname-nqatplt-icmp-icmptplt] destination ip 10.1.1.1
destination ipv6
Use destination ipv6 to configure the destination IPv6 address for the operation.
Use undo destination ipv6 to remove the destination IPv6 address.
destination ipv6 ipv6-address
No destination IPv6 address is configured for the operation.
DNS template view
ICMP template view
TCP template view
UDP template view
ipv6-address: Specifies the destination IPv6 address for the operation. IPv6 link-local addresses are not supported.
# In ICMP template view, specify 1::1 as the destination IPv6 address for the operation.
[Sysname-nqatplt-icmp-icmptplt] destination ipv6 1::1
destination port
Use destination port to configure the destination port number for the operation.
Use undo destination port to remove the destination port number.
destination port port-number
The destination port number is 33434 for the UDP tracert operation.
The destination port number is 53 for the DNS template.
No destination port number is configured for other types of operations.
DNS/TCP/UDP template view
port-number: Specifies the destination port number for the operation, in the range of 1 to 65535.
# Set the destination port number to 9000 for the UDP echo operation.
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] destination port 9000
# In TCP template view, set the destination port number to 9000 for the NQA operation.
[Sysname-nqatplt-tcp-tcptplt] destination port 9000
display nqa history
Use display nqa history to display the history records of NQA operations.
display nqa history [ admin-name operation-tag ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays the history records of all NQA operations.
The display nqa history command does not display the results or statistics of UDP jitter and voice operations. Use the display nqa result or display nqa statistics command to verify the UDP jitter and voice operations.
# Display the history records of the UDP tracert operation with administrator name administrator and operation tag tracert.
<Sysname> display nqa history administrator tracert
NQA entry (admin administrator, tag tracert) history records:
Index      TTL  Response  Hop IP          Status          Time
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:06.2
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:05.2
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:04.2
1          1    328       3.1.1.2         Succeeded       2013-09-09 14:46:03.2
1          1    328       3.1.1.1         Succeeded       2013-09-09 14:46:02.2
1          1    328       3.1.1.1         Succeeded       2013-09-09 14:46:01.2
# Display the history records of the NQA operation with administrator name administrator and operation tag test.
<Sysname> display nqa history administrator test
NQA entry (admin administrator, tag test) history records:
  Index      Response     Status           Time
  10         329          Succeeded        2011-04-29 20:54:26.5
  9          344          Succeeded        2011-04-29 20:54:26.2
  8          328          Succeeded        2011-04-29 20:54:25.8
  7          328          Succeeded        2011-04-29 20:54:25.5
  6          328          Succeeded        2011-04-29 20:54:25.1
  5          328          Succeeded        2011-04-29 20:54:24.8
  4          328          Succeeded        2011-04-29 20:54:24.5
  3          328          Succeeded        2011-04-29 20:54:24.1
  2          328          Succeeded        2011-04-29 20:54:23.8
  1          328          Succeeded        2011-04-29 20:54:23.4
Index
History record ID.
The history records in one UDP tracert operation have the same ID.
TTL
TTL value in the probe packet.
Response
Round-trip time if the operation succeeds, timeout time upon timeout, or 0 if the operation cannot be completed, in milliseconds.
Hop IP
IP address of the node that sent the reply packet.
Status
Status of the operation result:
·     Succeeded.
·     Unknown error.
·     Internal error.
·     Timeout.
Time
Time when the operation was completed.
Use display nqa reaction counters to display the current monitoring results of reaction entries.
display nqa reaction counters [ admin-name operation-tag [ item-number ] ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays the current monitoring results of reaction entries for all NQA operations.
item-number: Specifies a reaction entry by its ID in the range of 1 to 10. If you do not specify a reaction entry, the command displays the results of all reaction entries.
The result fields display hyphens (-) in one of the following conditions:
·     The threshold type is the average value.
·     The monitored performance metric is ICPIF or MOS of the voice operation.
The monitoring results of an operation are accumulated, and are not cleared after the operation completes.
# Display the monitoring results of all reaction entries of the ICMP echo operation with administrator name admin and operation tag test.
<Sysname> display nqa reaction counters admin test
NQA entry (admin admin, tag test) reaction counters:
  Index  Checked Element  Threshold Type  Checked Num  Over-threshold Num
  1      probe-duration   accumulate      12           4
  2      probe-duration   average         -            -
  3      probe-duration   consecutive     160          56
  4      probe-fail       accumulate      12           0
  5      probe-fail       consecutive     162          2
Index
ID of a reaction entry.
Checked Element
Monitored performance metric.
Threshold Type
Threshold type.
Checked Num
Number of targets that have been monitored for data collection.
Over-threshold Num
Number of threshold violations.
Table 4 Description of the threshold monitoring fields
Threshold type
Collect data in
Checked Num
Over-threshold Num
probe-duration
accumulate
Probes after the operation starts.
Number of completed probes.
Number of probes with duration exceeding the threshold.
average
N/A
N/A
N/A
consecutive
probe-fail
accumulate
Number of probe failures.
consecutive
RTT
accumulate
Packets sent after the operation starts.
Number of sent packets.
Number of packets with round-trip time exceeding threshold.
average
N/A
N/A
N/A
jitter-DS/jitter-SD
accumulate
Number of packets with the one-way jitter exceeding the threshold.
average
N/A
N/A
N/A
OWD-DS/OWD-SD
N/A
Number of packets with the one-way delay exceeding the threshold.
packet-loss
accumulate
Total packet loss.
ICPIF
N/A
N/A
N/A
N/A
MOS
N/A
N/A
N/A
N/A
display nqa result
Use display nqa result to display the most recent result of the specified NQA operation.
display nqa result [ admin-name operation-tag ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays the most recent results of all NQA operations.
# Display the most recent result of the TCP operation.
<Sysname> display nqa result admin test
NQA entry (admin admin, tag test) test results:
    Send operation times: 1              Receive response times: 1
    Min/Max/Average round trip time: 35/35/35
    Square-Sum of round trip time: 1225
    Last succeeded probe time: 2011-05-29 10:50:33.2
  Extended results:
    Packet loss ratio: 0%
    Failures due to timeout: 0
    Failures due to disconnect: 0
    Failures due to no connection: 0
    Failures due to internal error: 0
    Failures due to other errors: 0
# Display the most recent result of the UDP jitter operation.
    Send operation times: 10             Receive response times: 10
    Min/Max/Average round trip time: 15/46/26
    Square-Sum of round trip time: 8103
    Last packet received time: 2011-05-29 10:56:38.7
  Extended results:
    Packets out of sequence: 0
    Packets arrived late: 0
  UDP-jitter results:
   RTT number: 10
    Min positive SD: 8                     Min positive DS: 8
    Max positive SD: 18                    Max positive DS: 8
    Positive SD number: 5                  Positive DS number: 2
    Positive SD sum: 75                    Positive DS sum: 32
    Positive SD average: 15                Positive DS average: 16
    Positive SD square-sum: 1189           Positive DS square-sum: 640
    Min negative SD: 8                     Min negative DS: 1
    Max negative SD: 24                    Max negative DS: 30
    Negative SD number: 4                  Negative DS number: 7
    Negative SD sum: 56                    Negative DS sum: 99
    Negative SD average: 14                Negative DS average: 14
    Negative SD square-sum: 946            Negative DS square-sum: 1495
  One way results:
    Max SD delay: 22                       Max DS delay: 23
    Min SD delay: 7                        Min DS delay: 7
    Number of SD delay: 10                 Number of DS delay: 10
    Sum of SD delay: 125                   Sum of DS delay: 132
    Square-Sum of SD delay: 1805           Square-Sum of DS delay: 1988
    SD lost packets: 0                     DS lost packets: 0
    Lost packets for unknown reason: 0
# Display the most recent result of the voice operation.
    Send operation times: 1000           Receive response times: 0
    Min/Max/Average round trip time: 0/0/0
    Square-Sum of round trip time: 0
    Last packet received time: 0-00-00 00:00:00.0
  Extended results:
    Packet loss ratio: 100%
    Failures due to timeout: 1000
  Voice results:
   RTT number: 0
    Min positive SD: 0                     Min positive DS: 0
    Max positive SD: 0                     Max positive DS: 0
    Positive SD number: 0                  Positive DS number: 0
    Positive SD sum: 0                     Positive DS sum: 0
    Positive SD average: 0                 Positive DS average: 0
    Positive SD square-sum: 0              Positive DS square-sum: 0
    Min negative SD: 0                     Min negative DS: 0
    Max negative SD: 0                     Max negative DS: 0
    Negative SD number: 0                  Negative DS number: 0
    Negative SD sum: 0                     Negative DS sum: 0
    Negative SD average: 0                 Negative DS average: 0
    Negative SD square-sum: 0              Negative DS square-sum: 0
  One way results:
    Max SD delay: 0                        Max DS delay: 0
    Min SD delay: 0                        Min DS delay: 0
    Number of SD delay: 0                  Number of DS delay: 0
    Sum of SD delay: 0                     Sum of DS delay: 0
    Square-Sum of SD delay: 0              Square-Sum of DS delay: 0
    Lost packets for unknown reason: 1000
  Voice scores:
    MOS value: 0.99                        ICPIF value: 87
# Display the most recent result of the path jitter operation.
  Hop IP 192.168.40.210
    Basic Results:
      Min/Max/Average round trip time: 1/1/1
      Square-Sum of round trip time: 10
    Extended Results:
    Path-Jitter Results:
      Jitter number: 9
        Min/Max/Average jitter: 0/0/0
      Positive jitter number: 0
        Min/Max/Average positive jitter: 0/0/0
        Sum/Square-Sum positive jitter: 0/0
      Negative jitter number: 0
        Min/Max/Average negative jitter: 0/0/0
        Sum/Square-Sum negative jitter: 0/0
  Hop IP 192.168.50.209
    Basic Results:
    Extended Results:
      Jitter number: 9
# Display the most recent result of the UDP tracert operation with administrator name admin and operation tag test.
    Send operation times: 6              Receive response times: 6
    Last succeeded probe time: 2013-09-09 14:23:24.5
  Extended results:
  UDP-tracert results:
    TTL    Hop IP             Time
    1      3.1.1.1            2013-09-09 14:23:24.5
    2      4.1.1.1            2013-09-09 14:23:24.5
Table 5 Command output
Number of operations.
Number of response packets received.
Minimum/maximum/average round-trip time in milliseconds.
Square sum of round-trip time.
Time when the last successful probe was completed. If no probes are successful in an operation, the field displays 0.
This field is not available for UDP jitter, path jitter, and voice operations.
Time when the last response packet was received. If no response packets in a probe were received, the field displays 0.
This field is available only for UDP jitter and voice operations.
Packet loss ratio
Average packet loss ratio.
Number of timeout occurrences in an operation.
Number of disconnections by the peer.
Number of failures to connect with the peer.
Number of failures due to internal errors.
Failures due to other errors.
Number of failures due to out-of-sequence packets.
Number of response packets received after a probe times out.
UDP-jitter results
UDP jitter operation results.
This field is available only for the UDP jitter operation.
Voice results
Voice operation results.
This field is available only for the voice operation.
RTT number
Min positive SD
Minimum positive jitter from source to destination.
Min positive DS
Minimum positive jitter from destination to source.
Max positive SD
Maximum positive jitter from source to destination.
Max positive DS
Maximum positive jitter from destination to source.
Positive SD number
Number of positive jitters from source to destination.
Positive DS number
Number of positive jitters from destination to source.
Positive SD sum
Sum of positive jitters from source to destination.
Positive DS sum
Sum of positive jitters from destination to source.
Positive SD average
Average positive jitters from source to destination.
Positive DS average
Average positive jitters from destination to source.
Square sum of positive jitters from source to destination.
Square sum of positive jitters from destination to source.
Min negative SD
Minimum absolute value among negative jitters from source to destination.
Min negative DS
Minimum absolute value among negative jitters from destination to source.
Max negative SD
Maximum absolute value among negative jitters from source to destination.
Max negative DS
Maximum absolute value among negative jitters from destination to source.
Negative SD number
Number of negative jitters from source to destination.
Negative DS number
Number of negative jitters from destination to source.
Negative SD sum
Sum of absolute values of negative jitters from source to destination.
Negative DS sum
Sum of absolute values of negative jitters from destination to source.
Negative SD average
Average absolute value of negative jitters from source to destination.
Negative DS average
Average absolute value of negative jitters from destination to source.
Square sum of negative jitters from source to destination.
Square sum of negative jitters from destination to source.
One way results
Unidirectional delay.
This field is available only for the UDP jitter and voice operations.
Max SD delay
Maximum delay from source to destination.
Max DS delay
Maximum delay from destination to source.
Min SD delay
Minimum delay from source to destination.
Min DS delay
Minimum delay from destination to source.
Number of SD delay
Number of delays from source to destination.
Number of DS delay
Number of delays from destination to source.
Sum of SD delay
Sum of delays from source to destination.
Sum of DS delay
Sum of delays from destination to source.
Square sum of delays from source to destination.
Square sum of delays from destination to source.
SD lost packets
Number of lost packets from the source to the destination.
DS lost packets
Number of lost packets from the destination to the source.
Number of lost packets for unknown reasons.
Voice scores
Voice parameters.
MOS value
MOS value calculated for the voice operation.
ICPIF value
ICPIF value calculated for the voice operation.
Hop IP
IP address of the hop.
This field is available only for path jitter operation.
Path-jitter results
Path jitter operation results.
This field is available only for the path jitter operation.
Jitter number
Number of jitters.
Minimum/maximum/average jitter in milliseconds.
Number of positive jitter.
Minimum/maximum/average positive jitter in milliseconds.
Sum/square sum of the positive jitter.
Number of negative jitter.
Minimum/maximum/average negative jitter in milliseconds.
Sum/square sum of the negative jitter.
TTL
TTL value in the received reply packet.
Hop IP
Time
Time when the NQA client received the reply packet.
Use display nqa statistics to display NQA operation statistics.
display nqa statistics [ admin-name operation-tag ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays statistics for all NQA operations.
The statistics are generated after the NQA operation completes. If you execute the display nqa statistics command before the operation completes, the statistics are displayed as all 0s.
If a reaction entry is configured, the command displays the monitoring results of the reaction entry in the period specified by the statistics interval command. The result fields display hyphens (-) in one of the following conditions:
·     The threshold type is average value.
·     The monitored performance metric is ICPIF or MOS for the voice operation.
This command does not display statistics for the UDP tracert operation.
# Display statistics for the TCP operation.
<Sysname> display nqa statistics admin test
NQA entry (admin admin, tag test) test statistics:
  NO. : 1
    Start time: 2007-01-01 09:30:20.0
    Life time: 2 seconds
    Min/Max/Average round trip time: 13/13/13
    Square-Sum of round trip time: 169
  Extended results:
# Display statistics for the UDP jitter operation.
  NO. : 1
    Start time: 2007-01-01 09:33:22.3
    Life time: 23 seconds
    Send operation times: 100            Receive response times: 100
    Min/Max/Average round trip time: 1/11/5
    Square-Sum of round trip time: 24360
  Extended results:
  UDP-jitter results:
   RTT number: 550
    Min positive SD: 1                     Min positive DS: 1
    Max positive SD: 7                     Max positive DS: 1
    Positive SD number: 220                Positive DS number: 97
    Positive SD sum: 283                   Positive DS sum: 287
    Positive SD average: 1                 Positive DS average: 2
    Positive SD square-sum: 709            Positive DS square-sum: 1937
    Min negative SD: 2                     Min negative DS: 1
    Max negative SD: 10                    Max negative DS: 1
    Negative SD number: 81                 Negative DS number: 94
    Negative SD sum: 556                   Negative DS sum: 191
    Negative SD average: 6                 Negative DS average: 2
    Negative SD square-sum: 4292           Negative DS square-sum: 967
  One way results:
    Max SD delay: 5                        Max DS delay: 5
    Min SD delay: 1                        Min DS delay: 1
    Number of SD delay: 550                Number of DS delay: 550
    Sum of SD delay: 1475                  Sum of DS delay: 1201
    Square-Sum of SD delay: 5407           Square-Sum of DS delay: 3959
  Reaction statistics:
    1      jitter-DS        accumulate      90           25
    2      jitter-SD        average         -            -
    3      OWD-DS           -               100          24
    4      OWD-SD           -               100          13
    5      packet-loss      accumulate      0            0
    6      RTT              accumulate      100          52
# Display statistics for the voice operation.
  NO. : 1
    Start time: 2007-01-01 09:33:45.3
    Life time: 120 seconds
    Min/Max/Average round trip time: 1/12/7
    Square-Sum of round trip time: 620
  Extended results:
  Voice results:
   RTT number: 10
    Min positive SD: 3                     Min positive DS: 1
    Max positive SD: 10                    Max positive DS: 1
    Positive SD number: 3                  Positive DS number: 2
    Positive SD sum: 18                    Positive DS sum: 2
    Positive SD average: 6                 Positive DS average: 1
    Positive SD square-sum: 134            Positive DS square-sum: 2
    Min negative SD: 3                     Min negative DS: 1
    Max negative SD: 9                     Max negative DS: 1
    Negative SD number: 4                  Negative DS number: 2
    Negative SD sum: 25                    Negative DS sum: 2
    Negative SD average: 6                 Negative DS average: 1
    Negative SD square-sum: 187            Negative DS square-sum: 2
  One way results:
  Voice scores:
    Max MOS value: 4.40                    Min MOS value: 4.40
    Max ICPIF value: 0                     Min ICPIF value: 0
    1      ICPIF            -               -            -
    2      MOS              -               -            -
# Display statistics for the path jitter operation.
  NO. : 1
  Path 1:
    Basic Results:
    Extended Results:
      Jitter number: 9
    Basic Results:
    Extended Results:
      Jitter number: 9
Table 6 Command output
No.
Statistics group ID.
Start time
Time when the operation started.
Life time
Duration of the operation in seconds.
Number of probe packets sent.
Packet loss ratio
UDP-jitter results
Voice results
RTT number
Min positive SD
Min positive DS
Max positive SD
Max positive DS
Positive SD number
Positive DS number
Positive SD sum
Positive DS sum
Positive SD average
Positive DS average
Min negative SD
Min negative DS
Max negative SD
Max negative DS
Negative SD number
Negative DS number
Negative SD sum
Negative DS sum
Negative SD average
Negative DS average
One way results
Unidirectional delay result.
Max SD delay
Max DS delay
Min SD delay
Min DS delay
Number of SD delay
Number of DS delay
Sum of SD delay
Sum of DS delay
SD lost packets
DS lost packets
Voice scores
Voice parameters.
Max MOS value
Maximum MOS value.
Min MOS value
Minimum MOS value.
Max ICPIF value
Maximum ICPIF value.
Min ICPIF value
Minimum ICPIF value.
Reaction statistics
Statistics about the reaction entry in the counting interval.
Index
Checked Element
Monitored element.
Threshold Type
Threshold type.
Checked Num
Over-threshold Num
Path
Serial number for the path in the path jitter operation.
Hop IP
Path-jitter results
Jitter number
Number of jitters.
Number of positive jitters.
Sum/square sum of positive jitters.
Number of negative jitters.
Sum/square sum of negative jitters.
Table 7 Description of the threshold monitoring fields
Threshold type
Collect data in
Checked Num
Over-threshold Num
probe-duration
accumulate
Probes in the counting interval.
Number of probes of which the duration exceeds the threshold.
average
N/A
N/A
N/A
consecutive
probe-fail
accumulate
consecutive
RTT
accumulate
Packets sent in the counting interval.
Number of packets of which the round-trip time exceeds the threshold.
average
N/A
N/A
N/A
jitter-DS/jitter-SD
accumulate
Number of packets of which the one-way jitter exceeds the threshold.
average
N/A
N/A
N/A
OWD-DS/OWD-SD
N/A
Number of packets of which the one-way delay exceeds the threshold.
packet-loss
accumulate
Number of packet loss.
ICPIF
N/A
N/A
N/A
N/A
MOS
N/A
N/A
N/A
N/A
statistics interval
expect data
Use expect data to configure the expected data.
Use undo expect data to restore the default.
expect data expression [ offset number ]
undo expect data
No expected data is configured.
HTTP template view
TCP template view
UDP template view
expression: Specifies the expected data, a case-sensitive string of 1 to 200 characters.
offset number: Specifies the offset between the expected data and the actual data. The value range for the number argument is 0 to 1000, and the default value is 0.
Upon receiving a response packet, the NQA client examines the target payload for the expected data.
·     If a match is found, the NQA client verifies the NQA destination device as legal.
·     If no match is found, the NQA client looks up the entire payload for a match. If no match is found again, the NQA destination device is verified as illegal. The NQA client does not perform the second round if no offset is specified. It verifies the NQA destination as illegal directly if no match is found for the first round.
Expected data check takes place in the following conditions:
·     For features that use the HTTP template, the NQA client checks for the expected data if the response contains the Content-Length header.
·     For features that use the TCP template, the NQA client checks for the expected data if the data-fill command is configured.
The first five bytes of the UDP packet payload identify the probe packet type. The start byte of the offset is the sixth byte of the UDP payload.
# In HTTP template view, set the expected data to welcome!.
[Sysname] nqa template http httptplt
[Sysname-nqatplt-http-httptplt] expect data welcome!
expect ip
Use expect ip to specify the expected IP address.
Use undo expect ip to remove all expected IP addresses.
expect ip ip-address
undo expect ip
No expected IP address is configured.
DNS template view
ip-address: Specifies the expected IP address for a DNS echo request.
During a DNS operation, the NQA client compares the expected IP address with the IP address resolved by the DNS server. If they are the same, it considers the DNS server legal.
# In DNS template view, specify 1.1.1.1 as the expected IPv4 address.
[Sysname] nqa template dns dnstplt
[Sysname-nqatplt-dns-dnstplt] expect ip 1.1.1.1
expect ipv6
Use expect ipv6 to specify the expected IPv6 address.
Use undo expect ipv6 to remove all expected IPv6 addresses.
expect ipv6 ipv6-address
undo expect ipv6
No expected IPv6 address is configured.
DNS template view
ip-address: Specifies the expected IPv6 address for a DNS echo request.
During a DNS operation, the NQA client compares the expected IPv6 address with the IPv6 address resolved by the DNS server. If they are the same, it considers the DNS server legal.
# In DNS template view, specify 1::1 as the expected IPv6 address.
[Sysname-nqatplt-dns-dnstplt] expect ipv6 1::1
expect status
Use expect status to configure the expected status code.
Use undo expect status to restore the default.
expect status status-list
undo expect status [ status-list ]
No expected status code is configured.
HTTP template view
status-list: Specifies a space-separated list of up to 10 status code items. Each item specifies a status code or a range of status codes in the form of status-num1 to status-num2. The value ranges for both the status-num1 and status-num2 arguments are 0 to 999. The value for the status-num2 argument must be equal to or greater than the value for the status-num1 argument.
The status code of the HTTP packet is a three-digit field in decimal notation and it includes the status information for the HTTP server. The first digit defines the class of response, and the last two digits do not have any categorization role.
# In HTTP template view, set the expected status codes to 200, 300, and 400 to 500.
[Sysname-nqatplt-http-httptplt] expect status 200 300 400 to 500
filename
Use filename to specify a file to be transferred between the FTP server and the FTP client.
Use undo filename to restore the default.
filename filename
undo filename
No file is specified.
FTP operation view
FTP template view
filename: Specifies the name of a file, a case-sensitive string of 1 to 200 characters that cannot contain slashes (/).
# Specify config.txt as the file to be transferred between the FTP server and the FTP client for the FTP operation.
[Sysname-nqa-admin-test] type ftp
[Sysname-nqa-admin-test-ftp] filename config.txt
# In FTP template view, specify config.txt as the file to be transferred between the FTP server and the FTP client.
[Sysname] nqa template ftp ftptplt
[Sysname-nqatplt-ftp-ftptplt] filename config.txt
frequency
Use frequency to specify the interval at which the NQA operation repeats.
Use undo frequency to restore the default.
frequency interval
undo frequency
In NQA operation view, the interval between two consecutive voice or path jitter operations is 60000 milliseconds. The interval between two consecutive operations of other types is 0 milliseconds. Only one operation is performed.
In NQA template view, the interval between two consecutive operations is 5000 milliseconds.
Any NQA operation view
interval: Specifies the interval between two consecutive operations, in the range of 0 to 604800000 milliseconds. An interval of 0 milliseconds sets NQA to perform the operation only once, and not to generate any statistics.
If an operation is not completed when the interval is reached, the next operation does not start.
# Configure the ICMP echo operation to repeat at an interval of 1000 milliseconds.
[Sysname-nqa-admin-test-icmp-echo] frequency 1000
# In DNS template view, configure the DNS operation to repeat at an interval of 1000 milliseconds.
[Sysname-nqatplt-dns-dnstplt] frequency 1000
Use history-record enable to enable the saving of history records for the NQA operation.
Use undo history-record enable to disable the saving of history records.
The saving of history records is enabled only for the UDP tracert operation.
DHCP/DLSw/DNS/FTP/HTTP/SNMP/TCP operation view
To display the history records of the NQA operation, use the display nqa history command.
The undo form of the command also removes existing history records of an NQA operation.
# Enable the saving of history records for the NQA operation.
[Sysname-nqa-admin-test-icmp-echo] history-record enable
display nqa history
Use history-record keep-time to set the lifetime of history records for an NQA operation.
Use undo history-record keep-time to restore the default.
history-record keep-time keep-time
The history records of an NQA operation are kept for 120 minutes.
keep-time: Specifies how long the history records can be saved. The value is in the range of 1 to 1440 minutes.
When an NQA operation completes, the timer starts. All records are removed when the lifetime is reached.
# Set the lifetime of the history records for an NQA operation to 100 minutes.
[Sysname-nqa-admin-test-icmp-echo] history-record keep-time 100
Use history-record number to set the maximum number of history records that can be saved for an NQA operation.
Use undo history-record number to restore the default.
history-record number number
A maximum of 50 records can be saved for an NQA operation.
number: Specifies the maximum number of history records that can be saved for an NQA operation. The value is in the range of 0 to 50.
If the number of history records for an NQA operation exceeds the maximum number, earliest history records are removed.
# Set the maximum number of history records to 10 for an NQA operation.
[Sysname-nqa-admin-test-icmp-echo] history-record number 10
init-ttl
Use init-ttl to set the initial TTL value for UDP packets in the UDP tracert operation.
Use undo init-ttl to restore the default.
init-ttl value
undo init-ttl
The initial TTL value is 1 for UDP packets in the UDP tracert operation.
value: Specifies the initial TTL value in the range of 1 to 255.
# Set the initial TTL value to 5 for UDP packets in the UDP tracert operation.
[Sysname-nqa-admin-test] type udp-tracert
[Sysname-nqa-admin-test-udp-tracert] init-ttl 5
lsr-path
Use lsr-path to set a loose source routing (LSR) path.
Use undo lsr-path to restore the default.
lsr-path ip-address&<1-8>
undo lsr-path
No LSR path is configured.
Path jitter operation view
ip-address&<1-8>: Specifies a space-separated list of up to eight IP addresses. Each IP address represents a hop on the path.
The path jitter operation first uses tracert to detect each hop to the destination. It then sends ICMP echo requests to measure the delay and jitters from the source to each node. If multiple routes exist between the source and destination, the operation uses the path specified by using lsr-path command.
# Specify 10.1.1.20 and 10.1.2.10 as the hops on the LSR path for the path jitter operation.
[Sysname-nqa-admin-test] type path-jitter
[Sysname-nqa-admin-test- path-jitter] lsr-path 10.1.1.20 10.1.2.10
max-failure
Use max-failure to set the maximum number of consecutive probe failures for the UDP tracert operation.
Use undo max-failure to restore the default.
max-failure times
undo max-failure
A UDP tracert operation stops and fails when it detects five consecutive probe failures.
times: Specifies the maximum number in the range of 0 to 255. When this argument is set to 0 or 255, the UDP tracert operation does not stop when consecutive probe failures occur.
When a UDP tracert operation detects the maximum number of consecutive probe failures, the operation fails and stops probing the path.
# Set the maximum number of consecutive probe failures to 20 for the UDP tracert operation.
[Sysname-nqa-admin-test-udp-tracert] max-failure 20
mode
Use mode to set the data transmission mode for the FTP operation.
Use undo mode to restore the default.
mode { active | passive }
undo mode
The FTP operation uses the active data transmission mode.
FTP operation view
FTP template view
active: Sets the data transmission mode to active. The FTP server initiates a connection request.
passive: Sets the data transmission mode to passive. The FTP client initiates a connection request.
# Set the data transmission mode to passive for the FTP operation.
[Sysname-nqa-admin-test-ftp] mode passive
# In FTP template view, set the data transmission mode to passive for the FTP operation.
[Sysname-nqatplt-ftp-ftptplt] mode passive
next-hop
Use next-hop to specify the next hop for the ICMP echo operation.
Use undo next-hop to remove the next hop IP address.
next-hop ip-address
undo next-hop
No next hop IP address is configured for the ICMP echo operation.
ICMP echo operation view
ip-address: Specifies the IP address of the next hop.
# Specify 10.1.1.1 as the next hop IP address  for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] next-hop 10.1.1.1
no-fragment enable
Use no-fragment enable to enable the no-fragmentation feature.
Use undo no-fragment enable to disable the no-fragmentation feature.
no-fragment enable
The no-fragmentation feature is disabled.
The no-fragmentation feature sets the DF field in probe packets to 1. Packets with the DF field set cannot be fragmented during the forwarding process.
You can use this command to test the path MTU of a link.
# Enable the no-fragmentation feature for the UDP tracert operation.
[Sysname-nqa-admin-test-udp-tracert] no-fragment enable
nqa
Use nqa to create an NQA operation and enter its view.
Use undo nqa to remove the operation.
nqa entry admin-name operation-tag
undo nqa { all | entry admin-name operation-tag }
No NQA operation is created.
all: Removes all NQA operations.
If the operation type has been configured for the operation, the command directly places you to NQA operation view.
# Create an NQA operation with administrator name admin and operation tag test, and enter NQA operation view.
nqa agent enable
Use nqa agent enable to enable the NQA client.
Use undo nqa agent enable to disable the NQA client and stop all operations being performed.
nqa agent enable
The NQA client is enabled.
# Enable the NQA client.
[Sysname] nqa agent enable
nqa server enable
nqa schedule
Use nqa schedule to configure scheduling parameters for an NQA operation.
Use undo nqa schedule to stop the operation.
nqa schedule admin-name operation-tag start-time { hh:mm:ss [ yyyy/mm/dd | mm/dd/yyyy ] | now } lifetime { lifetime | forever } [ recurring ]
undo nqa schedule admin-name operation-tag
No schedule is configured for an NQA operation.
start-time: Specifies the start time and date of the NQA operation.
hh:mm:ss: Specifies the start time of an NQA operation.
yyyy/mm/dd: Specifies the start date of an NQA operation. The default value is the current system time, and the value for the yyyy argument is in the range of 2000 to 2035.
mm/dd/yyyy: Specifies the start date of an NQA operation. The default value is the current system time, and the value for the yyyy argument is in the range of 2000 to 2035.
now: Starts the operation immediately.
lifetime: Specifies the duration of an operation.
lifetime: Specifies the duration of an operation in seconds, in the range of 1 to 2147483647.
forever: Performs the operation until you stop it by using the undo nqa schedule command.
recurring: Runs the operation automatically at the start time and for the specified duration.
You cannot enter the operation view or operation type view of a scheduled NQA operation.
Specify a lifetime long enough for an operation to complete.
# Schedule the operation with administrator name admin and operation tag test to start on 08:08:08 2008/08/08 and last 1000 seconds.
[Sysname] nqa schedule admin test start-time 08:08:08 2008/08/08 lifetime 1000 recurring
·     destination ip
·     nqa entry
·     type
nqa template
Use nqa template to create an NQA template and enter its view.
Use undo nqa template to remove the NQA template.
nqa template { dns | ftp | http | icmp | tcp | udp } name
undo nqa template { dns | ftp | http | icmp | tcp | udp } name
No NQA template is created.
dns: Specifies the DNS template.
ftp: Specifies the FTP template.
http: Specifies the HTTP template.
icmp: Specifies the ICMP template.
tcp: Specifies the TCP template.
name: Specifies the name of the NQA template, a case-insensitive string of 1 to 32 characters.
# Create an ICMP template named icmptplt, and enter its view.
Use operation to specify the operation type for the FTP operation.
Use undo operation to restore the default.
operation { get | put }
undo operation
The FTP operation type is get.
FTP operation view
FTP template view
get: Gets a file from the FTP server.
put: Transfers a file to the FTP server.
When you perform the put operation with the filename command configured, make sure the file exists on the NQA client.
If you get a file from the FTP server, make sure the file specified in the URL exists on the FTP server. The NQA client does not save the file obtained from the FTP server.
Use a small file for the FTP operation. A big file might result in transfer failure because of timeout, or might affect other services for occupying much network bandwidth.
# Set the operation type to put for the FTP operation.
[Sysname-nqa-admin-test-ftp] operation put
# In FTP template view, set the FTP operation type to put.
[Sysname-nqatplt-ftp-ftptplt] operation put
Use operation to specify the operation type for the HTTP operation.
operation { get | post | raw }
undo operation
The HTTP operation type is get.
HTTP operation view
HTTP template view
get: Gets data from the HTTP server.
post: Transfers data to the HTTP server.
raw: Sends the HTTP request specified by the raw-request command to the HTTP server.
For the HTTP get or post operation, the content in the HTTP request is obtained from the URL specified by the URL command.
For the HTTP raw operation, the content in the HTTP request is specified by the raw-request command.
# Set the operation type to raw for the HTTP operation.
[Sysname-nqa-admin-test] type http
[Sysname-nqa-admin-test-http] operation raw
# In HTTP template view, set the operation type to raw.
[Sysname-nqatplt-http-httptplt] operation raw
out interface
Use out interface to specify the output interface for probe packets.
Use undo out interface to restore the default.
out interface interface-type interface-number
undo out interface
The output interface for probe packets is not specified. The NQA client determines the output interface based on the routing table lookup.
DHCP operation view
For successful operation, the specified output interface must be up.
If both the next-hop and out interface commands are configured for the ICMP echo operation, the out interface command does not take effect.
# Specify VLAN-interface 2 as the output interface for probe packets in the UDP tracert operation.
[Sysname-nqa-admin-test-udp-tracert] out interface vlan-interface 2
password
Use password to specify the FTP or HTTP login password.
Use undo password to remove the configuration.
password { cipher | simple } password
undo password
No FTP or HTTP login password is configured.
FTP/HTTP operation view
FTP/HTTP template view
password: Specifies the password string. The plaintext form of the password is a case-sensitive string of 1 to 32 characters. The encrypted form of the password is a case-sensitive string of 1 to 73 characters.
# Set the FTP login password to ftpuser.
[Sysname-nqa-admin-test-ftp] password simple ftpuser
# Set the FTP login password to ftpuser in FTP template view.
[Sysname-nqatplt-ftp-ftptplt] password simple ftpuser
·     operation
·     username
probe count
Use probe count to specify the probe times.
Use undo probe count to restore the default.
probe count times
undo probe count
In the UDP tracert operation, the NQA client performs three probes to each hop along the path.
In other types of operations, the NQA client performs one probe to the destination per operation.
times: Specifies the probe times in the range of 1 to 15.
The following describes how NQA performs different types of operations:
·     A TCP or DLSw operation sets up a connection.
·     A UDP jitter operation sends a number of probe packets. The number of probe packets is set by using the probe packet-number command.
·     An FTP operation uploads or downloads a file.
·     An HTTP operation gets a Web page.
·     A DHCP operation gets an IP address through DHCP.
·     A DNS operation translates a domain name to an IP address.
·     An ICMP echo operation sends an ICMP echo request.
·     A UDP echo operation sends a UDP packet.
·     An SNMP operation sends one SNMPv1 packet, one SNMPv2c packet, and one SNMPv3 packet.
·     A path jitter operation is accomplished in the following steps:
a.     The operation uses tracert to obtain the path from the NQA client to the destination. A maximum of 64 hops can be detected.
b.     The NQA client sends ICMP echo requests to each hop along the path. The number of ICMP echo requests is set by using the probe packet-number command.
·     A UDP tracert operation sends a UDP packet to each hop along the path per probe. Use the probe count command to set the number of probes performed on each hop.
If an operation is to perform multiple probes, the NQA client starts a new probe in one of the following conditions:
·     The NQA client receives responses to packets sent in the last probe.
·     The probe timeout time expires.
This command is not available for the voice and path jitter operations. Each of these operations performs only one probe.
# Configure the ICMP echo operation to perform 10 probes.
[Sysname-nqa-admin-test-icmp-echo] probe count 10
Use probe packet-interval to configure the interval for sending packets in the probe.
Use undo probe packet-interval to restore the default.
probe packet-interval packet-interval
The interval is 20 milliseconds.
packet-interval: Specifies the interval for sending packets, in the range of 10 to 60000 milliseconds.
# Configure the UDP jitter operation to send packets at an interval of 100 milliseconds.
[Sysname-nqa-admin-test] type udp-jitter
[Sysname-nqa-admin-test-udp-jitter] probe packet-interval 100
probe packet-number
Use probe packet-number to configure the number of packets to be sent in a UDP jitter, path jitter, or voice probe.
Use undo probe packet-number to restore the default.
probe packet-number packet-number
A UDP jitter or path jitter probe sends 10 packets and a voice probe sends 1000 packets.
packet-number: Specifies the number of packets to be sent per probe. Available value ranges include:
·     10 to 1000 for the UDP jitter or path jitter operation.
·     10 to 60000 for the voice operation.
# Configure the UDP jitter operation to send 100 packets per probe.
[Sysname-nqa-admin-test-udp-jitter] probe packet-number 100
Use probe packet-timeout to configure the timeout time for waiting for a response in the UDP jitter, path jitter, or voice operation.
Use undo probe packet-timeout to restore the default.
probe packet-timeout packet-timeout
The response timeout time in the UDP jitter or path jitter operation is 3000 milliseconds.
The response timeout time in the voice operation is 5000 milliseconds.
packet-timeout: Specifies the timeout time in milliseconds. The value range is 10 to 3600000.
# Configure the timeout time for waiting for a response as 100 milliseconds in the UDP jitter operation.
[Sysname-nqa-admin-test-udp-jitter] probe packet-timeout 100
probe timeout
Use probe timeout to specify the probe timeout time.
Use undo probe timeout to restore the default.
probe timeout timeout
undo probe timeout
The timeout time of a probe is 3000 milliseconds.
timeout: Specifies the probe timeout time in milliseconds. Available value ranges include:
·     10 to 86400000 for the FTP or HTTP operation.
·     10 to 3600000 for the DHCP, DNS, DLSw, ICMP echo, SNMP, TCP, UDP echo, or UDP tracert operation.
If a probe does not complete within the period, the probe is timed out.
# Set the probe timeout time for the DHCP operation to 10000 milliseconds.
[Sysname-nqa-admin-test] type dhcp
[Sysname-nqa-admin-test-dhcp] probe timeout 10000
# In HTTP template view, set the probe timeout time for the HTTP operation to 10000 milliseconds.
[Sysname-nqatplt-http-httptplt] probe timeout 10000
raw-request
Use raw-request to enter raw-request view and specify the content of an HTTP request.
Use undo raw-request to delete the content of an HTTP request.
raw-request
undo raw-request
No contents are specified.
HTTP operation view
HTTP template view
This command places you in raw request view and deletes the previously configured request content.
# Enter raw request view and specify the content of a request for the HTTP operation.
[Sysname-nqa-admin-test-http] raw-request
[Sysname-nqa-admin-test-http-raw-request]
# In HTTP template view, enter raw request view and specify the content of a request for the HTTP operation.
[Sysname-nqatplt-http-httptplt] raw-request
[Sysname-nqatplt-http-httptplt-raw-request]
Use reaction checked-element { jitter-ds | jitter-sd } to configure a reaction entry for monitoring one-way jitter in the NQA operation.
Use undo reaction to delete the specified reaction entry.
reaction item-number checked-element { jitter-ds | jitter-sd } threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
undo reaction item-number
No reaction entry for monitoring one-way jitter is configured.
item-number: Assigns an ID to the reaction entry, in the range of 1 to 10.
jitter-ds: Specifies the destination-to-source jitter of each probe packet as the monitored element (or performance metric).
jitter-sd: Specifies source-to-destination jitter of each probe packet as the monitored element.
threshold-type: Specifies a threshold type.
accumulate accumulate-occurrences: Checks the total number of threshold violations in the operation. The value is in the range of 1 to 14999 for the UDP jitter operation, and 1 to 59999 for the voice operation.
average: Checks the average one-way jitter.
threshold-value: Specifies threshold range in milliseconds.
upper-threshold: Specifies the upper limit in the range of 0 to 3600000.
lower-threshold: Specifies the lower limit in the range of 0 to 3600000. It must not be greater than the upper limit.
action-type: Specifies what action to be triggered. The default action is none.
none: Specifies the action of displaying results on the terminal display.
trap-only: Specifies the action of displaying results on the terminal display and meanwhile sending SNMP trap messages to the NMS.
You cannot edit a reaction entry after it is created. To change the attributes in a reaction entry, use the undo reaction command to delete the entry, and then configure a new one.
Only successful probe packets are monitored. Statistics about failed probe packets are not collected.
# Create reaction entry 1 for monitoring the average destination-to-source jitter of UDP jitter packets, and set the upper limit to 50 milliseconds and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average destination-to-source jitter is checked against the threshold range. If it exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element jitter-ds threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the destination-to-source jitter of UDP jitter probe packets, and set the upper limit to 50 milliseconds, and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the destination-to-source jitter is checked against the threshold range. If the total number of threshold violations reaches or exceeds 100, the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 2 checked-element jitter-ds threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
Use reaction checked-element { owd-ds | owd-sd } to configure a reaction entry for monitoring the one-way delay.
reaction item-number checked-element { owd-ds | owd-sd } threshold-value upper-threshold lower-threshold
No reaction entry for monitoring the one-way delay is configured.
owd-ds: Specifies the destination-to-source delay of each probe packet as the monitored element.
owd-sd: Specifies the source-to-destination delay of each probe packet as the monitored element.
No actions can be configured for a reaction entry of monitoring one-way delays. To display the monitoring results and statistics, use the display nqa reaction counters and display nqa statistics commands.
# Create reaction entry 1 for monitoring the destination-to-source delay of every UDP jitter packet, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. The destination-to-source delay is calculated after the response to the probe packet arrives. If the delay exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element owd-ds threshold-value 50 5
Use reaction checked-element icpif to configure a reaction entry for monitoring the ICPIF value in the voice operation.
reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entry for monitoring ICPIF values is configured.
threshold-value: Specifies threshold range.
upper-threshold: Specifies the upper limit in the range of 1 to 100.
lower-threshold: Specifies the lower limit in the range of 1 to 100. It must not be greater than the upper limit.
# Create reaction entry 1 for monitoring the ICPIF value in the voice operation, and set the upper limit to 50 and lower limit to 5. Before the voice operation starts, the initial state of the reaction entry is invalid. After the operation, the ICPIF value is checked against the threshold range. If it exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-voice] reaction 1 checked-element icpif threshold-value 50 5 action-type trap-only
reaction checked-element mos
Use reaction checked-element mos to configure a reaction entry for monitoring the MOS value in the voice operation.
reaction item-number checked-element mos threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entry for monitoring the MOS value is configured.
upper-threshold: Specifies the upper limit in the range of 1 to 500.
lower-threshold: Specifies the lower limit in the range of 1 to 500. It must not be greater than the upper limit.
For the MOS threshold, the number is expressed in three digits representing ones, tenths, and hundredths. For example, to express a MOS threshold of 1, enter 100.
# Create reaction entry 1 for monitoring the MOS value of the voice operation, and set the upper limit to 2 and lower limit to 1. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the MOS value is checked against the threshold range. If it exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] reaction 1 checked-element mos threshold-value 200 100 action-type trap-only
reaction checked-element packet-loss
Use reaction checked-element packet-loss to configure a reaction entry for monitoring packet loss in UDP jitter or voice operation.
reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences [ action-type { none | trap-only } ]
No reaction entry for monitoring packet loss is configured.
Voice operation view
accumulate accumulate-occurrences: Specifies the total number of lost packets in the operation. The value is in the range of 1 to 15000 for the UDP jitter operation and 1 to 60000 for the voice operation.
# Create reaction entry 1 for monitoring packet loss in the UDP jitter operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the total number of the lost packets is checked against the threshold. If the number reaches or exceeds 100, the state of the reaction entry is set to over-threshold. Otherwise, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element packet-loss threshold-type accumulate 100 action-type trap-only
reaction checked-element probe-duration
Use reaction checked-element probe-duration to configure a reaction entry for monitoring the probe duration.
reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entry for monitoring the probe duration is configured.
ICMP/UDP echo operation view
accumulate accumulate-occurrences: Checks the total number of threshold violations. The value is in the range of 1 to 15.
average: Checks the average probe duration.
consecutive consecutive-occurrences: Specifies the number of consecutive threshold violations after the NQA operation starts. The value is in the range of 1 to 16.
lower-threshold: Specifies the lower limit in the range of 0 to 3600000. It must not be greater than the upper threshold.
trap-only: Specifies the action of displaying results on the terminal display and meanwhile sending SNMP trap messages to the NMS. This keyword is not available for the DNS operation.
# Create reaction entry 1 for monitoring the average probe duration of ICMP echo operation, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average probe duration is checked. If it exceeds the upper limit, the state is set to over-threshold. If it is below the lower limit, the state of the reaction entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-duration threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the probe duration of ICMP echo operation, and set the upper limit to 50 milliseconds and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the accumulated probe duration is checked against the threshold range. If the total number of threshold violations reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the lower threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-duration threshold-type accumulate 10 threshold-value 50 5 action-type trap-only
# Create reaction entry 3 for monitoring the probe duration time of ICMP echo operation, and set the upper limit to 50 milliseconds and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the consecutive probe duration is checked against the threshold range. If the total number of consecutive threshold violations reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the lower threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 3 checked-element probe-duration threshold-type consecutive 10 threshold-value 50 5 action-type trap-only
reaction checked-element probe-fail (for trap)
Use reaction checked-element probe-fail to configure a reaction entry for monitoring the probe failures of the operation.
reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } [ action-type { none | trap-only } ]
No reaction entry for monitoring probe failures is configured.
accumulate accumulate-occurrences: Checks the total number of probe failures. The value is in the range of 1 to 15.
consecutive consecutive-occurrences: Checks the maximum number of consecutive probe failures. The value is in the range of 1 to 16.
# Create reaction entry 1 for monitoring the probe failures in ICMP echo operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the total number of probe failures reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type accumulate 10 action-type trap-only
# Create reaction entry 2 for monitoring the probe failures in ICMP echo operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the number of consecutive probe failures reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-fail threshold-type consecutive 10 action-type trap-only
reaction checked-element probe-fail (for trigger)
Use reaction checked-element probe-fail to configure a reaction entry for monitoring probe failures.
Use undo reaction to remove the specified reaction entry.
reaction item-number checked-element probe-fail threshold-type consecutive consecutive-occurrences action-type trigger-only
consecutive consecutive-occurrences: Checks the maximum number of consecutive probe failures, in the range of 1 to 16.
trigger-only: Triggers other modules to react to certain conditions.
# Create reaction entry 1. If the number of consecutive probe failures reaches 3, collaboration is triggered.
[Sysname-nqa-admin-test] type tcp
[Sysname-nqa-admin-test-tcp] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
track (High Availability Command Reference)
reaction checked-element rtt
Use reaction checked-element rtt to configure a reaction entry for monitoring packet round-trip time.
reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entry for monitoring packet round-trip time is configured.
UDP jitter operation view
accumulate accumulate-occurrences: Checks the total number of threshold violations. Available value ranges include:
·     1 to 15000 for the UDP jitter operation.
·     1 to 60000 for the voice operation.
average: Checks the packet average round-trip time.
# Create reaction entry 1 for monitoring the average round-trip time of UDP jitter probe packets, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average packet round-trip time is checked. If it exceeds the upper limit, the state is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the reaction entry state changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the round-trip time of UDP jitter probe packets, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the packet round-trip time is checked. If the total number of threshold violations reaches or exceeds 100, the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction trap
Use reaction trap to configure the sending of traps to the NMS under specific conditions.
Use undo reaction trap to restore the default.
reaction trap { path-change | probe-failure consecutive-probe-failures | test-complete | test-failure  [ cumulate-probe-failures ] }
undo reaction trap { path-change | probe-failure | test-complete | test-failure }
No traps are sent to the NMS.
DHCP/DLSw/DNS/FTP/HTTP/SNMP/TCP/voice operation view
UDP tracert operation view
path-change: Sends a path change trap when a different path to the destination is detected. This keyword is available only for the UDP tracert operation.
probe-failure consecutive-probe-failures: Sends a probe failure trap if the number of consecutive probe failures in the operation is greater than or equal to consecutive-probe-failures. The value range for the consecutive-probe-failures argument is 1 to 15.
test-complete: Sends an operation complete trap when the operation is completed.
test-failure ccumulate-probe-failures: Sends an operation failure trap if the total number of probe failures in the operation is greater than or equal to ccumulate-probe-failures. The value range for the ccumulate-probe-failures argument is 1 to 15. For the UDP tracert operation, the ccumulate-probe-failures argument is not available and an operation failure trap is sent if the UDP tracert failed to obtain the path to the destination.
The UDP jitter and voice operations support only the test-complete keyword.
# Configure the system to send a probe failure trap if the number of consecutive probe failures reaches or exceeds 5 in the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] reaction trap probe-failure 5
reaction trigger probe-fail
Use reaction trigger probe-fail to set the number of consecutive probe failures to determine an operation failure.
Use undo reaction trigger probe-fail to restore the default.
reaction trigger probe-fail count
The NQA client notifies the feature of the operation failure when the number of consecutive probe failures reaches 3.
Any NQA template view
count: Specifies the number of consecutive probe failures, in the range of 1 to 15.
If the number of consecutive probe failures is reached, the NQA client notifies the feature that uses the NQA template of the operation failure.
# In HTTP template view, configure the NQA client to notify the feature of the operation failure when the number of consecutive probe failures reaches 5.
[Sysname-nqatplt-http-httptplt] reaction trigger probe-fail 5
reaction trigger probe-pass
Use reaction trigger probe-pass to set the number of consecutive successful probes to determine a successful operation event.
reaction trigger probe-pass count
undo reaction trigger probe-pass
The NQA client notifies the feature of the successful operation event if the number of consecutive successful probes reaches 3.
count: Specifies the number of consecutive successful probes, in the range of 1 to 15.
If number of consecutive successful probes is reached, the NQA client notifies the feature that uses the template of the successful operation event.
# In HTTP template view, configure the NQA client to notify the feature of the successful operation event if the number of consecutive successful probes reaches 5.
[Sysname-nqatplt-http-httptplt] reaction trigger probe-pass 5
resolve-target
Use resolve-target to set the domain name for the DNS operation.
Use undo resolve-target to restore the default.
resolve-target domain-name
undo resolve-target
No domain name is configured.
DNS operation view
DNS template view
domain-name: Specifies the domain name to be resolved. It is a dot-separated case-sensitive string of 1 to 255 characters including letters, digits, hyphens (-), and underscores (_) (for example, aabbcc.com). Each part consists of 1 to 63 characters, and consecutive dots (.) are not allowed.
# Specify domain1 as the domain name to be resolved.
[Sysname-nqa-admin-test] type dns
[Sysname-nqa-admin-test-dns] resolve-target domain1
# In DNS template view, specify domain1 as the domain name to be resolved.
[Sysname-nqatplt-dns-dnstplt] resolve-target domain1
resolve-type
Use resolve-type to configure the domain name resolution type.
Use undo resolve-type to restore the default.
resolve-type { A | AAAA }
undo resolve-type
The domain name resolution type is type A.
DNS template view
A: Specifies the type A queries. A type A query resolves a domain name to a mapped IPv4 address.
AAAA: Specifies the type AAAA queries. A type AAAA query resolves a domain name to a mapped IPv6 address.
# In DNS template view, set the domain name resolution type to AAAA.
[Sysname-nqatplt-dns-dnstplt] resolve-type AAAA
route-option bypass-route
Use route-option bypass-route to enable the routing table bypass feature to test the connectivity to the direct destination.
Use undo route-option bypass-route to disable the routing table bypass feature.
The routing table bypass feature is disabled.
When the routing table bypass feature is enabled, the following events occur:
·     The routing table is not searched for probe packets. Packets are sent to the destination in a directly connected network.
·     The TTL value in the probe packet is set to 1. The TTL set in the ttl command does not take effect.
# Enable the routing table bypass feature.
[Sysname-nqa-admin-test-icmp-echo] route-option bypass-route
source interface
Use source interface to specify the IP address of the specified interface as the source IP address of ICMP echo request packets.
Use undo source interface to restore the default.
source interface interface-type interface-number
The probe packets take the primary IP address of the output interface as their source IP address.
ICMP template view
If you configure both the source interface and source ip commands for an ICMP echo operation or a UDP tracert operation, the most recent configuration takes effect.
The specified source interface must be up. Otherwise, probe packets can be sent out.
# Specify the IP address of VLAN-interface 2 as the source IP address of ICMP echo request packets.
[Sysname-nqa-admin-test-icmp-echo] source interface vlan-interface 2
# In ICMP template view, specify the IP address of VLAN-interface 2 as the source IP address of ICMP echo request packets.
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt] source interface vlan-interface 2
source ip
source ip
Use source ip to configure the source IP address for probe packets.
Use undo source ip to restore the default.
source ip ip-address
undo source ip
The probe packets take the primary IP address of the outgoing interface as their source IP address.
DHCP/DLSw/FTP/HTTP/SNMP/TCP/voice operation view
Path/UDP jitter operation view
ip-address: Specifies the source IP address for probe packets.
The specified source IP address must be the IP address of a local interface, and the local interface must be up. Otherwise, no probe packets can be sent out.
For an NQA template, if the source and destination addresses have different IP versions, the source address does not take effect.
# Configure the source IP address as 10.1.1.1 for ICMP echo requests.
[Sysname-nqa-admin-test-icmp-echo] source ip 10.1.1.1
# In ICMP template view, configure the source IP address as 10.1.1.1 for ICMP echo requests.
[Sysname-nqatplt-icmp-icmptplt] source ip 10.1.1.1
source interface
source ipv6
Use source ipv6 to configure the source IPv6 address for probe packets.
Use undo source ipv6 to restore the default
source ipv6 ipv6-address
undo source ipv6
The probe packets takes the IPv6 address of their output interface as the source IPv6 address.
ipv6-address: Specifies the source IPv6 address for probe packets. IPv6 link-local addresses are not supported.
If you configure both the source interface and source ipv6 commands for an ICMP echo operation, the most recent configuration takes effect.
The specified source IPv6 address must be the IPv6 address of a local interface. The local interface must be up. Otherwise, no probe packets can be sent out.
# In ICMP template view, set the source IPv6 address to 1::1 for ICMP echo requests.
[Sysname-nqatplt-icmp-icmptplt] source ipv6 1::1
source interface
source port
Use source port to configure the source port for probe packets.
Use undo source port to remove the configured source port number.
source port port-number
undo source port
No source port number is configured for probe packets.
SNMP/voice operation view
DNS template view
port-number: Specifies the source port number in the range of 1 to 65535.
# Configure port 8000 as the source port for probe packets in the UDP echo operation.
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] source port 8000
# In DNS template view, configure port 8000 as the source port for probe packets in the DNS operation.
[Sysname-nqatplt-dns-dnstplt] source port 8000
statistics hold-time
Use statistics hold-time to configure the hold time of statistics groups for an NQA operation.
Use undo statistics hold-time to restore the default.
statistics hold-time hold-time
The hold time of statistics groups is 120 minutes.
ICMP echo/TCP/UDP echo operation view
DHCP/DLSw/DNS/FTP/HTTP/SNMP operation view
Path jitter/UDP jitter/voice operation view
hold-time: Specifies the hold time in minutes, in the range of 1 to 1440.
A statistics group is deleted when its hold time expires.
# Set the hold time of statistics groups to 3 minutes.
[Sysname-nqa-admin-test-icmp-echo] statistics hold-time 3
statistics interval
Use statistics interval to configure the interval for collecting statistics for an NQA operation.
Use undo statistics interval to restore the default.
statistics interval interval
The default statistics collection interval is 60 minutes.
Any operation view
interval: Specifies the statistics collection interval in minutes, in the range of 1 to 35791394.
NQA forms statistics within the same collection interval as a statistics group. To display information about the statistics groups, use the display nqa statistics command.
# Configure the system to collect the ICMP echo operation statistics at 2-minute intervals.
[Sysname-nqa-admin-test-icmp-echo] statistics interval 2
statistics max-group
Use statistics max-group to configure the maximum number of statistics groups that can be saved.
Use undo statistics max-group to restore the default.
statistics max-group number
A maximum of two statistics groups can be saved.
number: Specifies the maximum number of statistics groups, in the range of 0 to 100. To disable statistics collection, set the value to 0.
When the maximum number of statistics groups is reached, the system deletes the earliest statistics group to save a new group.
# Configure NQA to save a maximum of five statistics groups for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] statistics max-group 5
target-only
Use target-only to perform the path jitter operation only on the destination address.
Use undo target-only to restore the default.
target-only
undo target-only
NQA performs the path jitter operation to the destination hop by hop.
# Perform the path jitter operation only on the destination address.
[Sysname-nqa-admin-test- path-jitter] target-only
tos
Use tos to set the ToS value in the IP header for probe packets.
Use undo tos to restore the default.
tos value
undo tos
The ToS value in the IP header of probe packets is 0.
Any operation view
value: Specifies the ToS value in the range of 0 to 255.
# Set the ToS value to 1 in the IP header for probe packets.
[Sysname-nqa-admin-test-icmp-echo] tos 1
# In ICMP template view, set the ToS value to 1 in the IP header for probe packets.
[Sysname-nqatplt-icmp-icmptplt] tos 1
ttl
Use ttl to set the maximum number of hops that the probe packets can traverse.
Use undo ttl to restore the default.
ttl value
undo ttl
The maximum number of hops is 30 for probe packets of the UDP tracert operation, and is 20 for probe packets of other types of operations.
value: Specifies the maximum number of hops that the probe packets can traverse, in the range of 1 to 255.
The route-option bypass-route command sets the TTL to 1 for probe packets. If you configure both the route-option bypass-route and ttl commands for an operation, the ttl command does not take effect.
For a successful UDP tracert operation, make sure the maximum number of hops is not smaller than the value set in the init-ttl command.
# Set the maximum number of hops to 16 for probe packets in the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] ttl 16
# In ICMP template view, set the maximum number of hops to 16 for probe packets.
[Sysname-nqatplt-icmp-icmptplt] ttl 16
type
Use type to specify the operation type of the NQA operation and enter operation type view.
type { dhcp | dlsw | dns | ftp | http | icmp-echo | path-jitter | snmp | tcp | udp-echo | udp-jitter | udp-tracert | voice }
No operation type is specified.
NQA operation view
dhcp: Specifies the DHCP operation type.
dlsw: Specifies the DLSw operation type.
dns: Specifies the DNS operation type.
ftp: Specifies the FTP operation type.
http: Specifies the HTTP operation type.
icmp-echo: Specifies the ICMP echo operation type.
path-jitter: Specifies the path jitter operation type.
snmp: Specifies the SNMP operation type.
tcp: Specifies the TCP operation type.
udp-echo: Specifies the UDP echo operation type.
udp-jitter: Specifies the UDP jitter operation type.
udp-tracert: Specifies the UDP tracert operation type.
voice: Specifies the voice operation type.
# Specify the type of FTP operation and enter FTP operation view.
url
Use url to specify the URL of the destination HTTP or FTP server.
Use undo url to remove the URL.
url url
undo url
No URL is configured for the destination server.
url: Specifies the URL of the destination server, a case-sensitive string of 1 to 255 characters. The following table describes the URL format and parameters for different operations.
Operation
URL format
Parameter description
HTTP operation
http://host/resource
http://host:port/resource
The host parameter represents the host name of the destination server. The host name is a dot-separated case-sensitive string including letters, digits, hyphens (-), and underscores (_). Host names are composed of series of labels, aabbcc.com for example. Each label consists of 1 to 63 characters. Consecutive dots (.) and question marks are not allowed.
For information about the filename parameter, see Fundamentals Configuration Guide.
FTP operation
ftp://host/filename
ftp://host:port/filename
# Set the destination URL to http://www.company.com/index.htm for the HTTP operation.
[Sysname-nqa-admin-test-http] url http://www.company.com/index.html
# In HTTP template view, set the destination URL to http://www.company.com/index.htm.
[Sysname-nqatplt-http-httptplt] url http://www.company.com/index.html
username
Use username to specify an FTP or HTTP login username.
Use undo username to remove the configuration.
username username
undo username
No FTP or HTTP login username is configured.
username: Specifies the username, a case-sensitive string of 1 to 32 characters.
# Set the FTP login username to administrator.
[Sysname-nqa-admin-test-ftp] username administrator
# Set the FTP login username to administrator in FTP template view.
[Sysname-nqatplt-ftp-ftptplt] username administrator
·     operation
·     password
version
Use version to specify the HTTP version used in the HTTP operation.
Use undo version to restore the default.
version { v1.0 | v1.1 }
undo version
HTTP 1.0 is used in the HTTP operation.
HTTP operation view
HTTP template view
v1.0: Uses HTTP version 1.0.
v1.1: Uses HTTP version 1.1.
# Configure the HTTP operation to use HTTP version 1.1.
[Sysname-nqa-admin-test-http] version v1.1
vpn-instance
Use vpn-instance to apply the operation to a VPN instance.
Use undo vpn-instance to restore the default.
undo vpn-instance
The operation applies to the public network.
Any operation view
vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters.
After you specify the VPN instance, the NQA operation tests the connectivity in the specified VPN instance.
# Apply the ICMP echo operation to vpn1.
[Sysname-nqa-admin-test-icmp-echo] vpn-instance vpn1
# In FTP template view, apply the FTP operation to vpn1.
[Sysname-nqatplt-ftp-ftptplt] vpn-instance vpn1
NQA server commands
IMPORTANT
IMPORTANT:
Configure the NQA server only for UDP jitter, TCP, UDP echo, and voice operations.
display nqa server
Use display nqa server status to display NQA server status.
display nqa server
# Display NQA server status.
<Sysname> display nqa server
nqa server is: enabled
tcp-connect:
   IP Address          Port      Vpn-instance
   2.2.2.2             2000      -
udp-echo:
   3.3.3.3             3000      vpn1
Table 8 Command output
tcp-connect
Information about the TCP listening service on the NQA server.
udp-echo
Information about the UDP listening service on the NQA server.
IP Address
IP address specified for the TCP/UDP listening service on the NQA server.
Port
Port number specified for the TCP/UDP listening service on the NQA server.
Vpn-instance
Name of the VPN instance to which the NQA server belongs.
nqa server enable
Use nqa server enable to enable the NQA server.
Use undo nqa server enable to disable the NQA server.
nqa server enable
The NQA server is disabled.
# Enable the NQA server.
[Sysname] nqa server enable
·     display nqa server
·     nqa server tcp-connect
·     nqa server udp-echo
Use nqa server tcp-connect to configure a TCP listening service to enable the NQA server to listen to a port on an IP address.
Use undo nqa server tcp-connect to delete a TCP listening service.
nqa server tcp-connect ip-address port-number [ vpn-instance vpn-instance-name ] [ tos tos ]
undo nqa server tcp-connect ip-address port-number
No TCP listening services exist.
ip-address: Specifies the IP address for the TCP listening service.
port-number: Specifies the port number for the TCP listening service, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the NQA server listens on a public IP address.
tos tos: Specifies the ToS value in the IP header for reply packets. The value range for the tos argument is 0 to 255, and the default value is 0.
Use this command on the NQA server only for the TCP operation.
When you configure the IP address and port number for a TCP listening service on the NQA server, follow these restrictions and guidelines:
·     The IP address and port number must be unique on the NQA server and match the configuration on the NQA client.
·     The IP address must be the address of an interface on the NQA server.
·     To ensure successful NQA operations and avoid affecting existing services, do not configure the TCP listening service on well-known ports from 1 to 1023.
# Configure a TCP listening service to enable the NQA server to listen and respond to IP address 169.254.10.2 and port 9000.
[Sysname] nqa server tcp-connect 169.254.10.2 9000
·     nqa server enable
nqa server udp-echo
Use nqa server udp-echo to configure a UDP listening service to enable the NQA server to listen to a port on an IP address.
Use undo nqa server udp-echo to delete a UDP listening service.
nqa server udp-echo ip-address port-number [ vpn-instance vpn-instance-name ] [ tos tos ]
undo nqa server udp-echo ip-address port-number
No UDP listening services exist.
ip-address: Specifies the IP address for the UDP listening service.
port-number: Specifies the port number for the UDP listening service, in the range of 1 to 65535.
Use this command on the NQA server only for the UDP jitter, UDP echo, and voice operations.
When you configure the IP address and port number for a UDP listening service on the NQA server, follow these restrictions and guidelines:
·     To ensure successful NQA operations and avoid affecting existing services, do not configure the UDP listening service on well-known ports from 1 to 1023.
# Configure a UDP listening service to enable the NQA server to listen and respond on IP address 169.254.10.2 and port 9000.
[Sysname] nqa server udp-echo 169.254.10.2 9000
·     nqa server enable
