- 11-Network Management and Monitoring Command Reference
- 02-NTP commands
- 03-PTP commands
- 04-Information center commands
- 05-SNMP commands
- 06-RMON commands
- 07-NQA commands
- 08-Mirroring commands
- 09-sFlow commands
- 10-Process monitoring and maintenance commands
- 11-EAA commands
- 12-CWMP commands
- 13-NETCONF commands
- 14-Packet capture commands
| 00-Preface | 84.30 KB |
Preface
This command reference describes network management and monitoring configuration commands. It covers the commands for viewing system information, collecting traffic statistics, assessing the network performance, synchronizing time for all devices with clocks in your network, and checking and debugging the current network connectivity with the ping, tracert, and debug commands.
· Audience
Audience
· Network planners.
· Network administrators working with the S6300 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
service@h3c.com
Documentation feedback
We appreciate your comments.
