11-Network Management and Monitoring Command Reference
HomeSupportSwitchesH3C S6300 Switch SeriesReference GuidesCommand ReferencesH3C S6300 Switch Series Command References-Release 243x-6W10011-Network Management and Monitoring Command Reference
03-PTP commands
03-PTP commands 133.52 KB
PTP commands
display ptp clock
Use display ptp clock to display PTP clock information.
display ptp clock
If you specify neither a PTP profile nor PTP mode, no information is displayed.
# Display PTP clock information.
<Sysname> display ptp clock
PTP profile         : IEEE 1588 Version 2
PTP mode            : BC
Slave only          : No
Clock ID            : 000FE2-FFFE-FF0000
Clock type          : Local
Clock domain        : 0
Number of PTP ports : 2
Priority1     : 128
Priority2     : 128
Clock quality :
 Class                 : 248
 Accuracy              : 254
 Offset (log variance) : 65535
Offset from master : 0 (ns)
Mean path delay    : 0 (ns)
Steps removed      : 1
Local clock time   : Sun Jan 15 20:57:29 2011
PTP profile
Standards that PTP complies with:
·     IEEE 1588 version 2.
·     IEEE 802.1AS.
PTP mode
Clock node type:
·     BC.
·     E2ETC.
·     E2ETC-OC.
·     OC.
·     P2PTC.
·     P2PTC-OC.
Slave only
Whether the OC operates in Slave only mode:
·     Yes.
·     No.
Clock ID
Clock ID for the device.
Clock type
Clock type of the device:
·     Local—Local clock.
·     Bits1Bits1 clock.
·     Bits2Bits2 clock.
Clock domain
PTP domain where the device resides.
Priority1
Priority 1 value for the device.
Priority2
Priority 2 value for the device.
Class
Time class of the device.
Accuracy
Time accuracy of the device.
Offset of the grandmaster clock.
Offset from master
Offset from the master clock node, in nanoseconds.
N/A indicates that information for this field is not obtained.
Mean path delay
Mean path delay, in nanoseconds.
Steps removed
Hops from the grandmaster to the local clock node.
display ptp corrections
Use display ptp corrections to display PTP corrections occurred on a subordinate port.
The device records the correction information every time when it performs time or frequency synchronization through a subordinate port. If you specify a PTP profile and PTP mode, and the device has a subordinate port, the correction information is displayed.
If the subordinate port is changed, information recorded will be cleared.
# Display PTP corrections occurred on a subordinate port.
<Sysname> display ptp corrections
Slave port   Correction time          Corrections(s,ns)     Rate ratio
XGE1/0/1       Mar 11 03:14:54 2012     0,74                  0.999999973
XGE1/0/1       Mar 11 03:14:55 2012    -1,17                  0.999999980
Slave port
Name of the subordinate port.
Correction time
Time when the correction occurred.
Corrections(s,ns)
Time corrections in seconds or nanoseconds.
N/A indicates that no correction occurred this time.
Rate ratio
Rate ratio.
display ptp foreign-masters-record
Use display ptp foreign-masters-record to display information about foreign master nodes.
display ptp foreign-masters-record [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about foreign master nodes for all interfaces.
If you specify the PTP profile as IEEE 1588 version 2, and specify a PTP mode, and the device has a subordinate port or a port in uncalibrated state, foreign master node information is displayed.
# Display information about foreign master nodes for all interfaces.
<Sysname> display ptp foreign-masters-record
P1=Priority1, P2=Priority2, C=Class, A=Accuracy,
OSLV=Offset-scaled-log-variance, SR=Steps-removed
GM=Grandmaster
Interface    Clock ID             P1   P2   C    A    OSLV   SR   GM
XGE1/0/1       000FE2-FFFE-FF0000   0    128  248  254  65535  0    Yes
XGE1/0/2       000FE2-FFFE-FF0001   0    128  248  254  65535  1    No
Name of a PTP interface.
Clock ID
Clock ID of the foreign master node.
C
Time class.
A
Time accuracy.
OSLV
SR
GM
Whether the node represents the grandmaster clock:
·     Yes.
·     No.
display ptp interface
Use display ptp interface to display PTP running information for an interface.
display ptp interface [ interface-type interface-number | brief ]
interface-type interface-number: Specifies an interface by its type and number. If you specify an interface, this command displays detailed PTP running information for the specified interface. If you do not specify an interface, this command displays PTP running information for all interfaces.
brief: Displays brief PTP running information for all interfaces. If you do not specify this keyword, this command displays detailed PTP running information for the specified interface or all interfaces.
If PTP is enabled on an interface, detailed running information can be displayed without the brief keyword in this command.
If PTP is operating on the interface, brief running information can be displayed with the brief keyword in this command.
# Display brief PTP running information for all interfaces.
<Sysname> display ptp interface brief
Name         State        Delay mechanism  Clock step  Asymmetry correction
XGE1/0/1       Slave        E2E              Two         0
XGE1/0/2       Passive      E2E              Two         0
# Display detailed PTP running information for Ten-GigabitEthernet 1/0/1.
<Sysname> display ptp interface ten-gigabitethernet 1/0/1
Port number           : 15
PTP version           : 2
PTP enable            : Enabled
Transport of PTP      : User Datagram Protocol (IPv4)
Port state            : Slave
Force state           : No
Clock step            : Two
Asymmetry correction  : 0
Delay mechanism       : End to End
Announce interval (log mean)           : 1
Announce receipt time out              : 3
Sync interval (log mean)               : 2
Delay request interval (log mean)      : 2
Peer delay request interval (log mean) : 0
Name
Name of the PTP interface.
States of the PTP interface:
·     Slave—Receives synchronization time.
·     Uncalibrated—Temporary state before the Slave state.
·     PassiveNeither receives nor sends synchronization time (a state after the interface has received announce messages).
·     MasterSends synchronization time.
·     Premaster—Temporary state before the Master state.
·     ListeningNeither receives nor sends synchronization time (a state after interface initialization).
·     Faulty—PTP runs incorrectly, and the interface does not process PTP messages.
·     Disabled—PTP does not run on the interface, and the interface does not process PTP messages.
·     Initializing—The interface is initializing, and does not process NTP messages.
·     N/A—No state is obtained for this field.
Delay mechanism
Delay measurement mechanism:
·     End to EndRequest-response mechanism.
·     Peer to PeerPeer delay mechanism.
Clock step
Mode for carrying timestamps:
·     OneSingle-step mode.
·     TwoTwo-step mode.
Asymmetric delay correction value (in nanoseconds).
Clock ID
Clock ID of the device where the interface resides.
PTP version
PTP version number. The version number is always 2.
PTP enable
Whether PTP is enabled or disabled:
·     Enabled.
·     Disabled.
Transport of PTP
PTP messages are transported by:
·     User Datagram Protocol (IPv4).
·     IEEE 802.3/Ethernet.
Force state
Whether the force state is configured:
·     Yes.
·     No.
Announce message sending interval (in seconds) = 2value (this field displays the value for the value exponent).
Timeout value for receiving announce messages. If a member node does not receive any announce message from the master node within the specified value, it considers the master node invalid.
Sync message sending interval (in seconds) = 2value (this field displays the value for the value exponent).
Minimum delay request message sending interval (in seconds) = 2value (this field displays the value for the value exponent).
Peer delay request message sending interval (in seconds) = 2value (this field displays the value for the value exponent).
Mean path delay
display ptp parent
Use display ptp parent to display parent node information for the PTP device.
display ptp parent
Parent node information is not displayed, if you:
·     Specify neither a PTP profile nor a PTP mode.
·     Specify the clock node type as e2etc or p2ptc.
·     Configure the ptp active force-state command.
# Display parent node information for the PTP device.
<Sysname> display ptp parent
Parent clock:
 Parent clock ID                         : 000FE2-FFFE-FF0005
 Parent port number                      : 15
 Observed parent offset (log variance)   : N/A
 Observed parent clock phase change rate : N/A
Grandmaster clock:
 Grandmaster clock ID: 000FE2-FFFE-FF0000
 Grandmaster clock quality:
  Class                 : 248
  Accuracy              : 254
  Priority1             : 128
  Priority2             : 128
Table 5 Command output
Parent port number
Outgoing interface number of the parent clock.
Offset from the parent clock node.
Class
Time class of the grandmaster clock.
Accuracy
Time accuracy of the grandmaster clock.
Priority1
Priority 1 value of the grandmaster clock.
Priority2
Priority 2 value of the grandmaster clock.
display ptp statistics
Use display ptp statistics to display the PTP statistics.
display ptp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the PTP statistics for all interfaces.
The PTP statistics are not displayed if you specify neither a PTP profile nor a PTP mode.
# Display the PTP statistics on Ten-GigabitEthernet 1/0/1.
<Sysname> display ptp statistics interface ten-gigabitethernet1/0/1
                     Received packets
Announce :0          Sync      :0          Signaling          :0
DelayReq :0          DelayResp :0          FollowUp           :0
PdelayReq:0          PdelayResp:0          PdelayRespFollowUp :0
                     Sent packets
Announce :476        Sync      :2543       Signaling          :0
DelayReq :0          DelayResp :0          FollowUp           :2542
PdelayReq:238        PdelayResp:0          PdelayRespFollowUp :0
                     Discarded packets
Table 6 Command output
Received packets
Statistics about received PTP messages.
Sent packets
Statistics about sent PTP messages.
Discarded packets
Statistics about discarded PTP messages.
display ptp time-property
Use display ptp time-property to display PTP clock time properties.
No PTP clock time properties are displayed, if you:
# Display PTP clock time properties.
<Sysname> display ptp time-property
PTP clock time property:
 Current UTC offset valid : True
 Current UTC offset       : 33
 Leap59 : Yes
 Leap61 : No
 Time traceable      : True
 Frequency traceable : True
 PTP timescale       : True
 Time source         : 0xA0 (Internal oscillator)
Table 7 Command output
Whether the UTC offset is valid:
·     True—Yes.
·     False—No.
Current UTC offset
Cumulative offset (in seconds) between the Coordinated Universal Time (UTC) of the grandmaster clock and the International Atomic Time (TAI).
Leap59
Whether cumulative offset minus 1:
·     Yes.
·     No.
Leap61
Whether cumulative offset plus 1:
·     Yes.
·     No.
Time traceable
Whether the PTP time is traceable:
·     True—Yes.
·     False—No.
Frequency traceable
Whether the PTP frequency is traceable:
·     True—Yes.
·     False—No.
PTP timescale
The possible timescales available for use by the grandmaster clock:
·     TruePTP timescale.
·     False—Non-PTP timescale.
Time source
Attributes of the grandmaster clock:
·     Atomic clock.
·     GPS.
·     Handset.
·     Internal oscillator.
·     NTP.
·     Other.
·     PTP.
·     Terrestrial radio.
·     Unknown.
Use ptp active force-state to activate the port role configuration.
Use undo ptp active force-state to restore the default.
The port role configuration is not activated.
This command is available only after you specify a PTP profile and a PTP mode.
# Activate the port role configuration.
[Sysname] ptp profile 1588v2
[Sysname] ptp mode oc
[Sysname] ptp active force-state
·     ptp force-state
·     ptp mode
·     ptp profile
ptp announce-interval
Use ptp announce-interval to configure the interval for sending announce messages.
Use undo ptp announce-interval to restore the default.
ptp announce-interval value
If the PTP profile is IEEE 1588 version 2, the announce message sending interval is 1 (21) second.
If the PTP profile is IEEE 802.1AS, the announce message sending interval is 1 (20) second.
value: Specifies the announce message sending interval (in seconds). The intervals use log base 2 values. If the PTP profile is IEEE 1588 version 2, the value range for the value argument is 0 to 4. If the PTP profile is IEEE 802.1AS, the value range for the value argument is 0 to 6.
# Configure the announce message sending interval on Ten-GigabitEthernet 1/0/1 as 4 (22) seconds.
[Sysname-Ten-GigabitEthernet1/0/1] ptp announce-interval 2
·     ptp mode
·     ptp profile
ptp announce-timeout
Use ptp announce-timeout to configure the timeout value for receiving announce messages.
Use undo ptp announce-timeout to restore the default.
ptp announce-timeout multiple-value
The timeout value for receiving announce messages is 3.
multiple-value: Specifies the number of announcement intervals before the receiving node stops receiving announce messages, in the range of 2 to 10.
·     This command is available only after you specify a PTP profile and a PTP mode.
·     A master node periodically sends announce messages to the member nodes.
¡     When the PTP profile is IEEE 1588 version 2:
If a member node does not receive any announce message from the master node within the specified interval (the announce message sending interval × multiple-value), it considers the master node invalid.
¡     When the PTP profile is IEEE 802.1AS:
·     To ensure a stable PTP network, configure the timeout value range for receiving announce messages as 5 to 7.
# Configure the timeout value for receiving announce messages on Ten-GigabitEthernet 1/0/1 as 5.
[Sysname-Ten-GigabitEthernet1/0/1] ptp announce-timeout 5
·     ptp announce-interval
·     ptp mode
·     ptp profile
ptp asymmetry-correction
Use ptp asymmetry-correction to configure asymmetric delay correction time.
Use undo ptp asymmetry-correction to restore the default.
ptp asymmetry-correction { minus | plus } value
The asymmetric delay correction time is 0 nanoseconds, which means delay correction is not performed.
minus: Subtracts the specified asymmetric delay correction value.
plus: Adds the specified asymmetric delay correction value.
value: Specifies the asymmetric delay correction value in the range of 0 to 2000000 nanoseconds.
# Configure the asymmetric delay correction time on Ten-GigabitEthernet 1/0/1 as 100 nanoseconds.
[Sysname-Ten-GigabitEthernet1/0/1] ptp asymmetry-correction plus 100
·     ptp mode
·     ptp profile
ptp clock-source
Use ptp clock-source to configure parameters of the Bits clock.
Use undo ptp clock-source to restore the default.
ptp clock-source { bits1 | bits2 } { accuracy acc-value | class class-value | time-source ts-value }
undo ptp clock-source { bits1 | bits2 } { accuracy | class | time-source }
For a Bits clock, the time accuracy is 254, the time class is 248, and the attribute value is 160.
bits1: Configures the Bits1 clock parameters.
bits2: Configures the Bits2 clock parameters.
accuracy acc-value: Specifies the time accuracy of the Bits clock, in the range of 0 to 255. A numerically smaller value indicates a higher time accuracy. Table 8 shows the description of time accuracy values.
Table 8 Time accuracy value description
Time accuracy value (in hexadecimal format)
00 through 1F
Reserved.
20
Less than 25 nanoseconds (1 nanosecond = 10-9 second).
21
Less than 100 nanoseconds.
22
Less than 250 nanoseconds.
23
Less than 1 microsecond (10-6 second).
24
Less than 2.5 microseconds.
25
Less than 10 microseconds.
26
Less than 25 microseconds.
27
Less than 100 microseconds.
28
Less than 250 microseconds.
29
Less than 1 millisecond (10-3 second).
2A
Less than 2.5 milliseconds.
2B
Less than 10 milliseconds.
2C
Less than 25 milliseconds.
2D
Less than 100 milliseconds.
2E
Less than 250 milliseconds.
2F
Less than 1 seconds.
30
Less than 10 seconds.
31
More than 10 seconds.
32 through 7F
Reserved.
80 through FD
For use by alternate PTP profiles.
FE
Unknown.
FF
Reserved.
class class-value: Specifies the time class of the Bits clock, in the range of 0 to 255. A numerically smaller value indicates a higher time class. Table 9 shows the description of time classes (those not listed are reserved by the protocol).
Table 9 Time class description
Time class (in decimal format)
6
The clock node synchronizes its time to the master reference time source. PTP assigns a time table to the clock node. A clock node with time class 6 cannot become a member clock of any other clocks in the domain.
7
The former time class is 6. The clock node cannot synchronize its time to a time source. It enters the reappointment mode and meets the reappointment conditions. PTP assigns a time table to the clock node. A clock node with time class 7 cannot become a member clock of any other clocks in the domain.
13
The clock node synchronizes its time to a time source. ARB assigns a time table to the clock node. A clock node with time class 13 cannot become a member clock of any other clocks in the domain.
14
The former time class is 13. The clock node cannot synchronize its time to a time source. It enters the reappointment mode and meets the reappointment conditions. ARB assigns a time table to the clock node. A clock node with time class 14 cannot become a member clock of any other clocks in the domain.
52
The clock node with time class 7 becomes optional clock A because it does not meet the reappointment conditions. A clock node with time class 52 cannot become a member clock of any other clocks in the domain.
58
The clock node with time class 14 becomes optional clock A because it does not meet the reappointment conditions. A clock node with time class 58 cannot become a member clock of any other clocks in the domain.
187
The clock node with time class 7 becomes optional clock B because it does not meet the reappointment conditions. A clock node with time class 187 can become a member clock of another clock in the domain.
193
The clock node with time class 14 becomes optional clock B because it does not meet the reappointment conditions. A clock node with time class 193 can become a member clock of another clock in the domain.
248
Default time class value.
255
Clock node operating in slave-only mode.
time-source ts-value: Specifies the clock attribute value, in the range of 0 to 255. Table 10 shows the description of the GM attribute values (those not listed are reserved for the protocol).
Table 10 GM attribute value description
GM attribute values (in hexadecimal format)
10
Atomic clock.
20
GPS.
30
Terrestrial radio.
40
PTP.
50
NTP.
60
Handset.
90
Other.
A0
F0 to FE
FF
Reserved.
# Configure the time accuracy for the Bits1 clock as 44.
[Sysname] ptp clock-source bits1 accuracy 44
·     ptp mode
·     ptp profile
ptp clock-step
Use ptp clock-step to configure the mode for carrying timestamps.
Use undo ptp clock-step to restore the default.
ptp clock-step { one-step | two-step }
undo ptp clock-step
Two-step mode is used.
one-step: Specifies the single-step mode.
two-step: Specifies the two-step mode.
If you specify the PTP profile as IEEE 802.1AS, only the two-step mode is supported.
If you specify the clock node type as E2ETC, P2PTC, E2ETC+OC, or P2PTC+OC, only the two-step mode is supported.
# Configure the mode for carrying timestamps on Ten-GigabitEthernet 1/0/1 as two-step.
[Sysname-Ten-GigabitEthernet1/0/1] ptp clock-step two-step
·     ptp mode
·     ptp profile
ptp delay-mechanism
Use ptp delay-mechanism to specify a delay measurement mechanism for a BC or OC.
Use undo ptp delay-mechanism to restore the default.
ptp delay-mechanism { e2e | p2p }
·     If the PTP profile is IEEE 1588 version 2, the delay measurement mechanism is request-response mechanism.
·     If the PTP profile is IEEE 802.1AS, the delay measurement mechanism is peer delay mechanism.
e2e: Specifies the request-response mechanism used by E2ETC.
p2p: Specifies the peer delay mechanism used by P2PTC.
This command is applicable only to BCs and OCs.
This command is available only if you specify the PTP profile as IEEE 1588 version 2.
# Configure the clock node type as OC, and specify the delay measurement mechanism on Ten-GigabitEthernet 1/0/1 as e2e.
[Sysname-Ten-GigabitEthernet1/0/1] ptp delay-mechanism e2e
·     ptp profile
·     ptp mode
ptp destination-mac
Use ptp destination-mac to configure the destination MAC address for non-peer delay messages.
Use undo ptp destination-mac to restore the default.
ptp destination-mac mac-address
The destination MAC address for non-peer delay messages is 011B-1900-0000.
mac-address: Specifies the destination MAC address for non-peer delay messages, which can be 0180-C200-000E or 011B-1900-0000.
Peer delay messages include Pdelay_Req, Pdelay_Resp, and Pdelay_Resp_Follow_Up messages. By default, the destination MAC address for peer delay messages is 0180-C200-000E, which cannot be modified.
This command is available only if PTP messages are transported over Ethernet.
# Configure the destination MAC address for non-peer delay messages as 0180-C200-000E on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ptp destination-mac 0180-c200-000e
·     ptp mode
·     ptp profile
ptp domain
Use ptp domain to configure the domain number to use for the device.
Use undo ptp domain to restore the default.
ptp domain domain-number
undo ptp domain
The PTP domain number is 0.
domain-number: Specifies the PTP domain by its domain number, in the range of 0 to 255.
# Configure the domain number to use for the device as 2.
[Sysname] ptp domain 2
·     ptp mode
·     ptp profile
ptp enable
Use ptp enable to enable PTP on a port.
Use undo ptp enable to disable PTP.
ptp enable
undo ptp enable
PTP is disabled on a port.
An OC can have only one PTP port.
As a best practice, enable PTP on a port after you configure PTP parameters for the port.
# Configure the clock node type as OC and enable PTP on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ptp enable
# Configure the clock node type as E2ETC, and enable PTP on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[Sysname] ptp mode e2etc
[Sysname-Ten-GigabitEthernet1/0/1] interface ten-gigabitethernet 1/0/2
[Sysname-Ten-GigabitEthernet1/0/2] ptp enable
·     ptp mode
·     ptp profile
ptp force-state
Use ptp force-state to configure the force state of a PTP port.
Use undo ptp force-state to restore the default.
ptp force-state { master | passive | slave }
The force state of a PTP port is automatically specified through BMC.
master: Specifies the PTP port as a master port.
passive: Specifies the PTP port as a passive port.
slave: Specifies the PTP port as a subordinate port.
You can configure only one subordinate port for a device.
# Configure the clock node type as OC and specify the PTP port Ten-GigabitEthernet 1/0/1 as a subordinate port.
[Sysname-Ten-GigabitEthernet1/0/1] ptp force-state slave
·     ptp mode
·     ptp profile
·     ptp slave-only
ptp min-delayreq-interval
Use ptp min-delayreq-interval to configure the minimum interval for sending delay request messages.
Use undo ptp min-delayreq-interval to restore the default.
ptp min-delayreq-interval value
If the PTP profile is IEEE 1588 version 2, the minimum interval for sending delay request messages is 1 (20) second.
value: Specifies the minimum interval for sending delay request messages (in seconds). The intervals use log base 2 values. The value range for the value argument is –4 to 6.
If the PTP profile is IEEE 802.1AS, you cannot execute this command.
# Configure the minimum interval for sending delay request messages as 4 (22) seconds on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ptp min-delayreq-interval 2
·     ptp mode
·     ptp profile
ptp mode
Use ptp mode to specify a clock node type for the device.
Use undo ptp mode to restore the default.
ptp mode { bc | e2etc | e2etc-oc | oc | p2ptc | p2ptc-oc }
undo ptp mode
No clock node type is specified.
bc: Specifies the clock node type as boundary clock (BC).
e2etc: Specifies the clock node type as end-to-end transparent clock (E2ETC).
e2etc-oc: Specifies the clock node type as E2ETC+OC.
oc: Specifies the clock node type as ordinary clock (OC).
p2ptc: Specifies the clock node type as peer-to-peer transparent clock (P2PTC).
p2ptc-oc: Specifies the clock node type as P2PTC+OC.
This command is available only after you specify a PTP profile.
If the PTP profile is IEEE 802.1AS, you cannot specify the clock node type as E2ETC or E2ETC+OC.
If you change the clock node type for the device, all the configurations except for the PTP profile will be removed.
# Specify the clock node type as OC for the device.
ptp profile
ptp pdelay-req-interval
Use ptp pdelay-req-interval to configure the interval for sending peer delay request messages.
Use undo ptp pdelay-req-interval to restore the default.
ptp pdelay-req-interval value
The interval for sending peer delay request messages is 1 (20) second.
value: Specifies the interval (in seconds) for sending peer delay request messages. The intervals use log base 2 values. The value range for this argument is –4 to 6. If the PTP profile is IEEE 1588 version 2, the value range for this argument is 0 to 5.
# Configure the interval for sending peer delay request messages on Ten-GigabitEthernet 1/0/1 as 4 (22) seconds.
[Sysname-Ten-GigabitEthernet1/0/1] ptp pdelay-req-interval 2
·     ptp mode
·     ptp profile
ptp port-mode
Use ptp port-mode to configure the port type as OC for a TC+OC (including E2ETC+OC and P2PTC+OC) clock.
Use undo ptp port-mode to restore the default.
ptp port-mode oc
undo ptp port-mode
The type of all ports on an E2ETC+OC or a P2PTC+OC clock is TC.
oc: Specifies the port type for a TC+OC clock as OC.
This command is applicable to an E2ETC+OC clock or a P2PTC+OC clock.
# Specify the clock node type as P2PTC+OC for the device. Configure the port type of Ten-GigabitEthernet 1/0/1 as OC.
[Sysname] ptp mode p2ptc-oc
[Sysname-Ten-GigabitEthernet1/0/1] ptp port-mode oc
·     ptp mode
·     ptp profile
ptp priority
Use ptp priority clock-source to configure the priority for the specified clock for GM election through BMC.
Use undo ptp priority clock-source to restore the default.
ptp priority clock-source { bits1 | bits2 | local } { priority1 pri1-value | priority2 pri2-value }
undo ptp priority clock-source { bits1 | bits2 | local } { priority1 | priority2 }
If the PTP profile is IEEE 1588 version 2, the default value for priority 1 and priority 2 are both 128.
If the PTP profile is IEEE 802.1AS, the default value  is 246 for priority 1 and 248 for priority 2.
bits1: Specifies the priority for a Bits1 clock.
bits2: Specifies the priority for a Bits2 clock.
local: Specifies the priority for the local clock.
priority1 pri1-value: Specifies priority 1 for the clock, in the range of 0 to 255. A numerically smaller value has higher priority.
priority2 pri2-value: Specifies priority 2 for the clock, in the range of 0 to 255. A numerically smaller value has higher priority.
# Configure priority 1 as 10 for the local clock.
[Sysname] ptp priority clock-source local priority1 10
·     ptp mode
·     ptp profile
ptp profile
Use ptp profile to configure a PTP profile for the device.
Use undo ptp profile to restore the default.
ptp profile { 1588v2 | 8021as }
undo ptp profile
PTP operates only after you configure a PTP profile.
1588v2: Specifies the PTP profile as IEEE 1588 version 2.
8021as: Specifies the PTP profile as IEEE 802.1AS.
Configure a PTP profile for the device before any other PTP configurations.
If you change or remove the PTP profile, PTP functions do not operate and all the configurations for that PTP profile will be removed.
# Configure the PTP profile as IEEE 1588 version 2.
ptp slave-only
Use ptp slave-only to configure the OC to operate only as a member clock.
Use undo ptp slave-only to restore the default.
ptp slave-only
undo ptp slave-only
An OC can operate either as a master clock or a member clock.
This command is applicable only to OCs.
You can execute the ptp force-state command to specify a subordinate port as a master port or passive port even if the OC operates as a member clock.
# Specify the clock node type as OC for the device. Configure the OC to operate only as a member clock.
[Sysname] ptp slave-only
·     ptp force-state
·     ptp mode
·     ptp profile
ptp source
Use ptp source to configure the source IP address for a PTP message that uses UDP for transport.
Use undo ptp source to restore the default.
ptp source ip-address [ vpn-instance vpn-instance-name ]
undo ptp source ip-address [ vpn-instance vpn-instance-name ]
No source IP address is configured for a PTP message.
ip-address: Specifies the source IP address for a PTP message.
vpn-instance vpn-instance-name: Specifies the name of a VPN instance used for communication between the local device and the peer device, a case-sensitive string of 1 to 31 characters. If you do not specify the VPN, the peer device belongs to the public network.
To enable the PTP functions to operate on the port, you must execute this command, if PTP messages are transported by UDP and IPv4.
# Configure the source IP address as 3.5.1.5 for the PTP message.
[Sysname] ptp source 3.5.1.5
·     ptp mode
·     ptp profile
·     ptp transport-protocol
ptp syn-interval
Use ptp syn-interval to configure the interval for sending Sync messages.
Use undo ptp syn-interval to restore the default.
ptp syn-interval value
If the PTP profile is IEEE 1588 version 2, the interval for sending Sync messages is 1 (20) second.
If the PTP profile is IEEE 802.1AS, the interval for sending Sync messages is 1/8 (2-3) second.
value: Specifies the Sync message sending interval (in seconds). The intervals use log base 2 values. If the PTP profile is IEEE 802.1AS, the value range for the value argument is -4 to 6. If the PTP profile is IEEE 1588 version 2, the value range for the value argument is -1 to 1.
# Configure the Sync message sending interval on Ten-GigabitEthernet 1/0/1 as 2 (21) seconds.
[Sysname-Ten-GigabitEthernet1/0/1] ptp syn-interval 1
·     ptp mode
·     ptp profile
Use ptp transport-protocol to configure UDP and IPv4 as the transport protocols for PTP messages.
Use undo ptp transport-protocol to restore the default.
ptp transport-protocol udp
PTP messages are transported through IEEE 802.3 and Ethernet.
udp: Specifies the UDP and IPv4 protocols for PTP messages.
# Configure UDP and IPv4 as the transport protocols for PTP messages on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ptp transport-protocol udp
·     ptp mode
·     ptp profile
ptp utc
Use ptp utc to configure the correction date of the UTC.
Use undo ptp utc to restore the default.
ptp utc { leap59-date | leap61-date } date
undo ptp utc { leap59-date | leap61-date }
No correction date is configured for the UTC.
leap59-date: Adjusts the UTC at the last minute (23:59) of the specified date so that the UTC is one second slower than the TAI.
leap61-date: Adjusts the UTC at the last minute (23:59) of the specified date so that the UTC is one second faster than the TAI.
date: Specifies the date to adjust the UTC, in the format of YYYY/MM/DD. The value range for YYYY and MM is 2000 to 2035 and 1 to 12, respectively. The value range for DD depends on the specified month. Do not specify a date earlier than the current date. Otherwise, the configuration does not take effect.
Specify either the leap59-date or leap61-date keyword in this command. The most recent configuration overwrites the earlier configuration.
# Assume the current date is August 8, 2010. Specify the clock node type as BC for the device, and adjust the UTC at the last minute of December 31, 2010 so that the UTC is one second slower than the TAI.
[Sysname] ptp mode bc
[Sysname] ptp utc leap59-date 2010/12/31
·     ptp mode
·     ptp profile
ptp utc offset
Use ptp utc offset to configure the cumulative offset between the UTC and TAI.
Use undo ptp utc offset to restore the default.
ptp utc offset utc-offset
undo ptp utc offset
The cumulative offset between the UTC and TAI is 0 seconds.
utc-offset: Specifies the cumulative offset between the UTC and TAI, in the range of 0 to 999 seconds.
# Configure the cumulative offset between the UTC and TAI as 33 seconds.
[Sysname] ptp utc offset 33
·     ptp mode
·     ptp profile
reset ptp statistics
Use reset ptp statistics to clear PTP statistics.
reset ptp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Clears PTP statistics on the specified port. If no port is specified, this command clears PTP statistics on all ports.
# Clear PTP statistics on Ten-GigabitEthernet 1/0/1.
<Sysname> reset ptp statistics interface ten-gigabitethernet 1/0/1
