14-SPB命令参考
01-SPBM命令
本章节下载: 01-SPBM命令  (401.64 KB)
01-SPBM命令
1 SPBM
1.1 SPBM配置命令
1.1.1 ap-mode
1.1.2 area-authentication send-only
1.1.3 area-authentication-mode
1.1.4 b-vlan
1.1.5 bandwidth-reference
1.1.6 bridge-priority
1.1.7 circuit-cost
1.1.8 control-address
1.1.9 display l2vpn minm connection
1.1.10 display l2vpn minm forwarding
1.1.11 display l2vpn vsi
1.1.12 display spbm agreement-protocol
1.1.13 display spbm b-vlan
1.1.14 display spbm bridge
1.1.15 display spbm bvlan-info
1.1.16 display spbm bvlan-info statistics
1.1.17 display spbm common statistics
1.1.18 display spbm ect
1.1.19 display spbm ect-migration i-sid
1.1.20 display spbm fast-channel statistics
1.1.21 display spbm graceful-restart status
1.1.22 display spbm interface
1.1.23 display spbm lsdb
1.1.24 display spbm multicast-fdb
1.1.25 display spbm multicast-fdb count
1.1.26 display spbm multicast-fib
1.1.27 display spbm multicast-fib count
1.1.28 display spbm multicast-fib statistics
1.1.29 display spbm multicast-pw
1.1.30 display spbm peer
1.1.31 display spbm summary
1.1.32 display spbm unicast-fdb
1.1.33 display spbm unicast-fdb count
1.1.34 display spbm unicast-fib
1.1.35 display spbm unicast-fib count
1.1.36 display spbm unicast-fib statistics
1.1.37 display spbm unicast-pw
1.1.38 display spbm unicast-tree
1.1.39 ect
1.1.40 flash-flood
1.1.41 graceful-restart
1.1.42 graceful-restart suppress-sa
1.1.43 graceful-restart t2
1.1.44 is-name
1.1.45 log-peer-change
1.1.46 multicast replicate-mode
1.1.47 multicast-bvlan enable
1.1.48 reset spbm bvlan-info statistics
1.1.49 reset spbm database
1.1.50 reset spbm multicast-fib statistics
1.1.51 reset spbm unicast-fib statistics
1.1.52 set-overload
1.1.53 snmp context-name
1.1.54 snmp-agent trap enable spbm
1.1.55 spb i-sid
1.1.56 spbm
1.1.57 spbm authentication send-only
1.1.58 spbm authentication-mode
1.1.59 spbm cost
1.1.60 spbm enable
1.1.61 spbm timer hello
1.1.62 spbm timer holding-multiplier
1.1.63 spbm timer lsp
1.1.64 spsource
1.1.65 timer lsp-generation
1.1.66 timer lsp-max-age
1.1.67 timer lsp-refresh
1.1.68 timer spf
1.1.69 vsi
1.1.70 xconnect vsi
1 SPBM
当设备的系统工作模式为标准模式时,不支持SPBM。关于系统工作模式的介绍,请参见“基础配置指导”中的“设备管理”。
1.1  SPBM配置命令
1.1.1  ap-mode
ap-mode命令用来配置AP(Agreement Protocol,一致协议)协议的运行模式。
undo ap-mode命令用来恢复缺省情况。
ap-mode { both | multicast | off }
undo ap-mode
AP协议运行在both模式。
SPBM视图
both:表示对单播表项、组播表项都进行AP检测。
multicast:表示仅对组播表项进行AP检测。
off:表示关闭AP检测。
·     SPBN整网各节点独立收集拓扑信息,并进行独立计算。网络拓扑震荡时,各节点收敛速度可能不一致,导致各节点计算的速度不一致,导致网络瞬间可能形成环路。可通过AP协议来保证不出现临时环路。
·     配置AP模式后,对应的表项在生效前需进行AP检测,检测通过(即链路状态数据库同步完成)后,才能指导转发,检测不通过则表项不生效。
# 配置AP协议运行在multicast模式。
[Sysname] spbm
[Sysname-spbm] ap-mode multicast
area-authentication send-only命令用来配置不对收到的报文(包括LSP、CSNP、PSNP)进行验证密码检查。
undo area-authentication send-only命令用来恢复缺省情况。
如果配置了区域验证方式和验证密码,则对收到的报文进行验证密码检查。
SPBM视图
配置区域验证方式和验证密码时如果没有配置本命令,则在发送的报文(包括LSP、CSNP、PSNP)中按照area-authentication-mode命令指定的方式携带验证密码,并对收到的报文进行验证密码的检查,只有通过检查后,该报文中的路由信息才会加入到本地LSDB中。当需要更改密码时,由于两台设备的密码更改操作不完全同步,导致瞬时的密码不一致、业务中断。此时,可以通过配置不对收到的报文进行验证密码检查,保证业务不会中断。
# 配置不对收到的报文进行验证密码检查。
[Sysname] spbm
[Sysname-spbm] area-authentication send-only
·     area-authentication-mode
area-authentication-mode命令用来配置区域验证方式和验证密码。
undo area-authentication-mode命令用来恢复缺省情况。
area-authentication-mode { md5 | simple } { cipher cipher-string | plain plain-string }
没有配置区域验证方式和验证密码,不进行区域验证。
SPBM视图
md5:MD5验证模式。
simple:简单验证模式。
cipher:表示以密文的形式输入密码。
cipher-string:表示密文密码,为33~53个字符的字符串,区分大小写。
plain:表示以明文的形式输入密码。
plain-string:表示明文密码,为1~16个字符的字符串,区分大小写。
配置区域验证方式和验证密码后,将在发送的报文(包括LSP、CSNP、PSNP)中按照设定的方式携带验证密码,并对收到的报文进行验证密码的检查。
·     同一区域内的SPBM设备必须配置相同的验证方式和验证密码。
·     以明文或密文方式配置的验证密码,均以密文的方式保存在配置文件中。
# 配置区域采用简单验证模式,验证密码为123456,以明文形式输入密码。
[Sysname] spbm
[Sysname-spbm] area-authentication-mode simple plain 123456
·     area-authentication send-only
1.1.4  b-vlan
b-vlan命令用来为SPB VSI实例指定B-VLAN。
undo b-vlan命令用来恢复缺省情况。
b-vlan vlan-id
undo b-vlan
SPB VSI实例未指定B-VLAN。
VSI SPB子视图
vlan-id:VLAN编号,取值范围为1~4094。
配置SPB VSI实例时必须为其指定B-VLAN,只有I-SID和B-VLAN都相同的SPB VSI实例才能互通。
需要注意的是,SPB VSI实例必须指定B-VLAN才能够生效。一个SPB VSI实例只能指定一个B-VLAN,不同SPB VSI实例可以指定相同的B-VLAN。
# 为SPB VSI实例vpn1(I-SID 256)指定B-VLAN 100。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] spb i-sid 256
[Sysname-vsi-vpn1-256] b-vlan 100
bandwidth-reference命令用来配置SPBM自动计算链路开销值时依据的带宽参考值。
bandwidth-reference value
SPBM自动计算链路度量值时依据的带宽参考值为40Gbps。
SPBM视图
value:带宽参考值,取值范围为1~2147483648,单位为Mbps。
只有当接口链路开销值和全局链路开销值都为缺省值时,SPBM才会自动计算接口链路的开销值。
链路开销值的计算公式为“链路开销值=(带宽参考值÷带宽)×10”,链路开销值的取值范围为1~16777214。
# 配置SPBM进程的带宽参考值为200Mbps。
[Sysname] spbm
[Sysname-spbm] bandwidth-reference 200
·     circuit-cost
·     spbm cost
·     display spbm interface
bridge-priority命令用来配置SPBM的桥优先级。
undo bridge-priority命令用来恢复缺省情况。
bridge-priority priority
SPBM的桥优先级为32768。
SPBM视图
priority:表示SPBM的桥优先级,该数值越小表示优先级越高。取值范围为0~61440,步长为4096,即设备可以配置16个优先级值,如4096、8192等。
设备的桥优先级与设备的系统ID共同组成设备的桥ID。桥ID与ECT掩码进行异或操作,异或后值的大小决定了该设备所在的转发路径是否能够被选举用来承载流量。
# 配置SPBM的桥优先级为4096。
[Sysname] spbm
[Sysname-spbm] bridge-priority 4096
1.1.7  circuit-cost
circuit-cost命令用来全局配置SPBM的链路开销值。
undo circuit-cost命令用来恢复缺省情况。
circuit-cost value
undo circuit-cost
未全局配置SPBM的链路开销值。
SPBM视图
value:链路开销值,取值范围为1~16777215。
·     链路开销值参与SPT(Shortest Path Tree,最短路径树)的计算。
·     全局配置的SPBM的链路开销值将对所有SPBM接口生效。
·     全局和接口同时配置了SPBM的链路开销值时,优先选择接口的配置值。
# 全局配置SPBM的链路开销值为11。
[Sysname] spbm
[Sysname-spbm] circuit-cost 11
·     bandwidth-reference
·     spbm cost
control-address命令用来配置SPBM协议报文的控制MAC。
undo control-address命令用来恢复缺省情况。
control-address { all-cb | all-is | all-l1-is | all-l2-is | all-pb }
SPBM协议报文的控制MAC为all-pb,对应MAC为0180-C200-002E。
SPBM视图
all-cb:SPBM协议报文的控制MAC地址为0180-C200-002F,适用于所有用户桥的中间系统。
all-is:SPBM协议报文的控制MAC地址为0900-2B00-0005,适用于所有的中间系统。
all-l1-is:SPBM协议报文的控制MAC地址为0180-C200-0014,适用于所有Level 1的中间系统。
all-l2-is:SPBM协议报文的控制MAC地址为0180-C200-0015,适用于所有Level 2的中间系统。
all-pb:SPBM协议报文的控制MAC地址为0180-C200-002E,适用于所有供应商桥的中间系统。
不同类别的中间系统分别适用不同的SPBM协议报文的控制MAC地址。
# 配置SPBM协议报文的控制MAC为all-is,对应MAC为0900-2B00-0005。
[Sysname] spbm
[Sysname-spbm] control-address all-is
display l2vpn minm connection命令用来显示MAC-in-MAC连接信息。
display l2vpn minm connection [ vsi vsi-name ]
vsi vsi-name:显示指定VSI的MAC-in-MAC连接信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则显示所有VSI的MAC-in-MAC连接信息。
# 显示所有VSI的MAC-in-MAC连接信息。
<Sysname> display l2vpn minm connection
Total number of MinM connections: 6
Types: MC - multicast, UC - unicast
VSI name: 1
Link ID  I-SID     BMAC            BVLAN  Owner   Type  Interface
64       10001     9999-8888-7777  1234   SPB     UC    GE1/0/1
65       10001     9999-8988-7777  1234   SPB     UC    GE1/0/1
-        10001     0011-2222-3333  1234   SPB     MC    GE1/0/1
VSI name: 2
68       10002     9999-8888-7777  1234   SPB     UC    GE1/0/1
69       10002     9999-8988-7777  1234   SPB     UC    GE1/0/1
-        10002     9999-9088-7777  1234   SPB     MC    GE1/0/1
                                                        GE1/0/2
表1-1 display l2vpn minm connection命令显示信息描述表
VSI name
VSI名称
Link ID
MAC-in-MAC连接的链路标识符
I-SID
骨干网服务实例编号
BMAC
骨干网MAC
BVLAN
骨干网VLAN
Owner
表项生成者,取值包括PBB和SPB
MAC-in-MAC连接的属性标记,取值包括:
·     MC:组播表项
·     UC:单播表项
出接口
display l2vpn minm forwarding命令用来显示MAC-in-MAC转发表项信息。
独立运行模式:
display l2vpn minm forwarding [ vsi vsi-name ] [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
display l2vpn minm forwarding [ vsi vsi-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
vsi vsi-name:显示指定VSI的MAC-in-MAC转发表项信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则显示所有VSI的MAC-in-MAC转发表项信息。
slot slot-number:显示指定单板上的MAC-in-MAC转发表项信息。slot-number表示单板所在的槽位号。如果不指定该参数,则显示主控板上的MAC-in-MAC转发表项信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MAC-in-MAC转发表项信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则显示Master设备上主控板的MAC-in-MAC转发表项信息。(IRF模式)
cpu cpu-number:显示指定CPU的MAC-in-MAC转发表项信息。cpu-number表示CPU的编号。如果不指定该参数,则显示所有CPU的MAC-in-MAC转发表项信息。本参数仅主控板可配置。
# 显示所有的MAC-in-MAC转发表项信息。
<Sysname> display l2vpn minm forwarding
Status Flag: * - inactive
VSI name: 1
VSI name: 2
                                                   GE1/0/2
表1-2 display l2vpn minm forwarding命令显示信息描述表
VSI name
VSI名称
Link ID
MAC-in-MAC连接的链路标识符
I-SID
骨干网服务实例编号
BMAC
骨干网MAC
BVLAN
骨干网VLAN
Owner
表项生成者,取值包括PBB和SPB
属性标记,取值包括:
·     MC:组播表项
·     UC:单播表项
出接口
如果接口后面带有“*”,则表示该表项不生效
display l2vpn vsi命令用来显示VSI的信息。
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name:显示指定VSI的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则显示所有VSI的信息。
verbose:显示VSI的详细信息。如果不指定该参数,则显示VSI的简要信息。
# 显示所有VSI的详细信息。
<Sysname> display l2vpn vsi verbose
VSI Name: test
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : 102400 kbps
  Broadcast Restrain      : 5%
  Multicast Restrain      : -
  Unknown Unicast Restrain: -
  MAC Table Limit         : Unlimited
  Drop Unknown            : -
  SPB I-SID               : 3001
  SPB Connections:
    BMAC            BVLAN            Link ID    Type
    0011-2200-1201  3001             64         Unicast
    0011-2200-1301  3001             65         Unicast
    0011-2200-1401  3001             66         Unicast
    6380-ff00-0bb9  3001             -          Multicast
  ACs:
    AC                               Link ID    State
    XGE1/0/1 srv1                    0          Up
表1-3 display l2vpn vsi命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
VSI Description
VSI的描述信息,如果不配置,则此行不显示
VSI State
VSI的状态,取值包括
·     Up:up状态
·     Down:down状态
·     Administratively down:通过shutdown命令手工关闭VSI
MTU
VSI上配置的最大传输单元
Bandwidth
VSI的带宽限制值,单位为kbps
Broadcast Restrain
VSI的广播抑制百分比。当VSI的广播流量速率超出特定值(带宽限制值×广播抑制百分比)时,该VSI会丢弃广播报文
Multicast Restrain
VSI的组播抑制百分比。当VSI的组播流量速率超出特定值(带宽限制值×组播抑制百分比)时,该VSI会丢弃组播报文
VSI的未知单播抑制百分比。当VSI的未知单播流量速率超出特定值(带宽限制值×未知单播抑制百分比)时,该VSI会丢弃未知单播流量报文
MAC Learning
是否使能了MAC地址学习功能,取值包括:
·     Enabled:使能了MAC地址学习功能
·     Disabled:未使能MAC地址学习功能
MAC Tabel Limit
VSI内MAC地址表项的最大数目
取值为Unlimited,表示不限制VSI内MAC地址表项的最大数目
Drop Unknown
当VSI内学习到的MAC地址数达到最大值后,是否禁止转发源MAC地址不在MAC地址表里的报文,取值包括:
·     Enabled:表示禁止转发
·     Disabled:表示允许转发
SPB I-SID
SPB骨干网服务实例编号
SPB Connections
SPB连接
BMAC
骨干网MAC
BVLAN
骨干网VLAN
属性标记,取值包括:
·     Multicast:组播表项
·     Unicast:单播表项
ACs
VSI的AC列表
AC
接入电路,取值为二层接口名称和以太网服务实例,如GE1/0/1 srv1
Link ID
AC或PW在VSI内的链路ID
AC的状态,取值包括Up和Down
display spbm agreement-protocol命令用来显示指定接口上指定ECT(Equal Cost Tree,等价树)算法的AP信息。
display spbm agreement-protocol status interface interface-type interface-number ect ect-number
interface interface-type interface-number:显示指定接口的AP信息。
ect ect-number:ECT算法编号,取值范围为1~16。
# 显示接口GigabitEthernet1/0/1上ECT算法为1的AP信息。
<Sysname> display spbm agreement-protocol status interface gigabitethernet 1/0/1 ect 1
Port AP information:
TxDigest : 00000000000000000000000000003f1f5e5270ce
RxDigest : 00000000000000000000000000003f1f5e5270ce
NBRAPMode: Both
TxAN     : 1                     TxDAN    : 0
RxAN     : 0                     RxDAN    : 0
TxValid  : No                    RxValid  : No
MisOrder : No                    TopoAgree: Yes
CalcEnd  : Yes                   AgreeSend: Normal
Port SPT AP information:
SystemID : 0011.2200.0001
Role     : ROOT             SelectedRole: ROOT
PSTState : 2                ReRoot      : No
Agree    : Yes              Agreed      : Yes
Sync     : No               Synced      : Yes
Forward  : Yes              Forwarding  : Yes
SystemID : 0011.2200.0101
Role     : DESI             SelectedRole: DESI
表1-4 display spbm agreement-protocol命令显示信息描述表
TxDigest
本地摘要
RxDigest
邻居摘要
NBRAPMode
邻居AP模式:
·     Both:表示对单播表项、组播表项都进行AP检测
·     Multicast:表示仅对组播表项进行AP检测
·     Off:表示AP模式关闭
TxAN
本地Agreement Number
TxDAN
本地Discarded Agreement Number
RxAN
邻居Agreement Number
RxDAN
邻居Discarded Agreement Number
TxValid
本地摘要是否可用
RxValid
邻居摘要是否可用
MisOrder
摘要报文乱序标记
TopoAgree
拓扑Agree标记
CalcEnd
拓扑计算是否结束标记
AgreeSend
发送摘要报文的状态:
·     Normal:普通发送
·     Fast:快速发送
SystemID
端口所在树的树根的System ID
Role
端口在树上当前的角色:
·     ROOT:根端口
·     ALTE:可选端口
·     DESI:指定端口
SelectedRole
端口在树上新计算出的角色:
·     ROOT:根端口
·     ALTE:可选端口
·     DESI:指定端口
PSTState
端口的PST状态
ReRoot
端口是否需要重启t
Agree
端口是否需要发送Agreement标识
Agreed
端口是否收到同步信号应答
Sync
端口是否进行同步
Synced
端口是否已经同步
Forward
端口是否要迁移到Forwarding状态
Forwarding
端口当前是否处于Forwarding状态
display spbm b-vlan命令用来显示SPBM B-VLAN的ECT算法应用情况。
display spbm b-vlan [ vlan-id ]
vlan-id:显示指定B-VLAN的ECT算法应用情况,vlan-id取值范围为1~4094。如果不指定该参数,则显示所有B-VLAN的ECT算法应用情况。
# 显示所有B-VLAN的ECT算法应用情况。
<Sysname> display spbm b-vlan
B-VLAN 1:
  Mode: SPBM
  Local use: Yes      Remote use: No
  ECT-Index:1        Algorithm: 00-80-c2-01  Mask: 0x00
  I-SID list: 300-302, 305, 309
B-VLAN 2:
  Mode: SPBM
  I-SID list: 400-402, 404
表1-5 display spbm b-vlan命令显示信息描述表
Mode
系统使用的模式
Local use
本地B-VLAN是否承载流量:
·     Yes:表示本地B-VLAN承载流量
·     No:表示本地B-VLAN不承载流量
Remote use
远端B-VLAN是否承载流量:
·     Yes:表示远端B-VLAN承载流量
·     No:表示远端B-VLAN不承载流量
ECT-Index
ECT索引
Algorithm
ECT算法
Mask
ECT算法对应的掩码
I-SID list
本地B-VLAN上承载的I-SID,N/A表示无承载I-SID
display spbm bridge命令用来显示SPBM的桥信息。
display spbm bridge
# 显示SPBM的桥信息。
<Sysname> display spbm bridge
System ID            Priority    SPSource ID    Host name
5555.1111.1111       32768       128            SPB-1
表1-6 display spbm bridge命令显示信息描述表
System ID
系统ID
Priority
桥优先级
SPSource ID
最短路径源ID
Host name
主机名,设备未配置主机名则显示对应的系统ID
display spbm bvlan-info用来显示SPBM B-VLAN信息。
独立运行模式:
display spbm bvlan-info [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
display spbm bvlan-info [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定单板的B-VLAN信息。slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有单板的B-VLAN信息。(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的B-VLAN信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有成员设备上所有单板的B-VLAN信息。(IRF模式)。
cpu cpu-number:显示指定CPU的B-VLAN信息。cpu-number表示CPU的编号。如果不指定该参数,则显示所有CPU的B-VLAN信息。本参数仅主控板可配置。
# 显示SPBM B-VLAN信息。
<Sysname> display spbm bvlan-info
Epoch: 0x1
Config B-VLAN list:
  1-7, 20
Driver B-VLAN list:
  1
表1-7 display spbm bvlan-info命令显示信息描述表
Epoch
B-VLAN时间戳
Config B-VLAN list
映射到MSTI 4092的B-VLAN列表(已通过激活MST域的配置使映射关系生效)
Driver B-VLAN list
下发驱动的B-VLAN列表
display spbm bvlan-info statistics命令用来显示SPBM B-VLAN统计信息。
独立运行模式:
display spbm bvlan-info statistics [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
display spbm bvlan-info statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定单板的B-VLAN统计信息。slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有单板的B-VLAN统计信息。(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的B-VLAN统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有成员设备上所有单板的B-VLAN统计信息。(IRF模式)。
cpu cpu-number:显示指定CPU的B-VLAN统计信息。cpu-number表示CPU的编号。如果不指定该参数,则显示所有CPU的B-VLAN统计信息。本参数仅主控板可配置。
# 显示成员设备1上单板0的SPBM B-VLAN统计信息。
<Sysname> display spbm bvlan-info statistics chassis 1 slot 0
SPBM B-VLAN basic statistics:
RefreshMsg     : 1           AgeNumber        : 0
DrvAddNumber   : 1           DrvDeleteNumber  : 0
SPBM B-VLAN error statistics:
BVLANMsgError  : 0           BVLANCreatFail   : 0
DrvEnableFail  : 0           DrvDisableFail   : 0
AllocBVLANFail : 0
表1-8 display spbm bvlan-info statistics命令显示信息描述表
B-VLAN基础统计
RefreshMsg
刷新B-VLAN的消息计数
AgeNumber
B-VLAN老化计数
DrvAddNumber
通知驱动添加B-VLAN消息计数
DrvDeleteNumber
通知驱动删除B-VLAN消息计数
B-VLAN错误统计
BVLANMsgError
收到B-VLAN错误消息计数
BVLANCreatFail
申请B-VLAN内存失败计数
DrvEnableFail
通知驱动B-VLAN生效失败计数
DrvDisableFail
通知驱动B-VLAN失效失败计数
AllocBVLANFail
分配B-VLAN失败计数
display spbm common statistics命令用来显示SPBM全局统计信息。
独立运行模式:
display spbm common statistics [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
display spbm common statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定单板的SPBM公共统计计数信息。slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有单板的SPBM公共统计计数信息。(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的SPBM公共统计计数信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有成员设备上所有单板的SPBM公共统计计数信息。(IRF模式)。
cpu cpu-number:显示指定CPU的SPBM公共统计计数信息。cpu-number表示CPU的编号。如果不指定该参数,则显示所有CPU的SPBM公共统计计数信息。本参数仅主控板可配置。
# 显示SPBM公共统计信息。
<Sysname> display spbm common statistics
UMACReDRVCount    : 0           MMACReDRVCount      : 0
ActiveFail        : 0           AllocMsgFail        : 0
RTMsgTypeError    : 0           WriteQueFail        : 0
SyncRTMsgFail     : 0           ComMsgTypeError     : 0
ComQueMsgTypeError: 0           TimerQueMsgTypeError: 0
EpochNumber       : 0           GetBMACNumber       : 1
GetBMACFail       : 0           SetIfNumber         : 6
AgeIfNumber       : 0           SetIfErrNumber      : 0
表1-9 display spbm common statistics命令显示信息描述表
UMACReDRVCount
单播表项重新下驱动计数
MMACReDRVCount
组播表项重新下驱动计数
ActiveFail
备板变主板失败
AllocMsgFail
申请内存失败
RTMsgTypeError
错误的路由消息类型
WriteQueFail
外部消息写队列失败
SyncRTMsgFail
路由消息同步失败
ComMsgTypeError
错误的消息类型
ComQueMsgTypeError
错误的队列类型
定时器队列消息类型错误
EpochNumber
全局老化计数,当表项的时间戳小于该值时,则表项需要老化
GetBMACNumber
获取驱动B-MAC计数
GetBMACFail
获取驱动B-MAC失败
SetIfNumber
接口下驱动使能数目
AgeIfNumber
接口老化计数
SetIfErrNumber
接口下驱动失败使能数目
display spbm ect命令用来显示ECT算法信息以及使用对应ECT算法的B-VLAN。
display spbm ect [ ect-index ]
ect-index:ECT算法索引,取值范围为1~16。如果不指定该参数,则显示所有ECT算法信息以及使用对应ECT算法的B-VLAN。
# 显示所有的ECT算法信息。
<Sysname> display spbm ect
ECT-1:
    Active B-VLANs: 1-10
    Inactive B-VLANs: 31-4094
ECT-2:
    Algorithm: 00-80-c2-02     Mask: 0xff
    Active B-VLANs: 11-20
    Inactive B-VLANs: 21-30
ECT-3:
    Algorithm: 00-80-c2-03     Mask: 0x88
    Active B-VLANs: N/A
    Inactive B-VLANs: N/A
ECT-4:
    Algorithm: 00-80-c2-04     Mask: 0x77
    Active B-VLANs: N/A
ECT-5:
    Algorithm: 00-80-c2-05     Mask: 0x44
    Active B-VLANs: N/A
ECT-6:
    Algorithm: 00-80-c2-06     Mask: 0x33
    Active B-VLANs: N/A
ECT-7:
    Algorithm: 00-80-c2-07     Mask: 0xcc
    Active B-VLANs: N/A
ECT-8:
    Algorithm: 00-80-c2-08     Mask: 0xbb
    Active B-VLANs: N/A
ECT-9:
    Algorithm: 00-80-c2-09     Mask: 0x22
    Active B-VLANs: N/A
ECT-10:
    Algorithm: 00-80-c2-0a     Mask: 0x11
    Active B-VLANs: N/A
ECT-11:
    Algorithm: 00-80-c2-0b     Mask: 0x66
    Active B-VLANs: N/A
ECT-12:
    Algorithm: 00-80-c2-0c     Mask: 0x55
    Active B-VLANs: N/A
ECT-13:
    Algorithm: 00-80-c2-0d     Mask: 0xaa
    Active B-VLANs: N/A
ECT-14:
    Algorithm: 00-80-c2-0e     Mask: 0x99
    Active B-VLANs: N/A
ECT-15:
    Algorithm: 00-80-c2-0f     Mask: 0xdd
    Active B-VLANs: N/A
ECT-16:
    Algorithm: 00-80-c2-10     Mask: 0xee
    Active B-VLANs: N/A
表1-10 display spbm ect命令显示信息描述表
Algorithm
ECT算法
Mask
ECT算法对应的掩码
Active B-VLANs
配置在该ECT算法下的生效B-VLAN,N/A表示该ECT算法下不存在生效B-VLAN
Inactive B-VLANs
配置在该ECT算法下无效B-VLAN,N/A表示该ECT算法下不存在无效B-VLAN
display spbm ect-migration i-sid命令用来显示指定I-SID的ECT迁移相关信息。
display spbm ect-migration i-sid i-sid
i-sid:指定的I-SID值,取值范围为255~16777215。
# 显示I-SID 300的相关信息。
<Sysname> display spbm ect-migration i-sid 300
ECT            B-VLAN    T    R
00-80-c2-01    1         0    1
表1-11 display spbm ect-migration i-sid命令显示信息描述表
ECT
ECT算法
B-VLAN
该I-SID映射的B-VLAN
T
T标志是否置位定义了设备在I-SID对应组播组中的传输状态:
·     1:置位,表示该设备是传输者。如果采用核心复制,BEB设备将T标志置位
·     0:未置位,表示该设备不是传输者。如果采用头端复制,BEB设备不将T标志置位
R
R标志是否置位定义了设备在I-SID对应组播组中的接收状态:
·     1:置位,表示该设备是接收者
·     0:未置位,表示该设备不是接收者
display spbm fast-channel statistics命令用来显示LSP快速泛洪通道的相关统计信息。
# 显示LSP快速泛洪通道的相关统计信息。
<Sysname> display spbm fast-channel statistics
                   Fast channel information for SPBM
VSI name              : 1
B-VLAN                : 1
I-SID                 : 255
State                 : Active
Replication mode      : tandem
ECT algorithm         : 00-80-c2-01
LSPs sent count       : 10
LSPs received count   : 20
LSP timer             : 10
LSPs transmitted count: 10
表1-12 display spbm fast-channel statistics命令显示信息描述表
VSI name
VSI名称
B-VLAN
骨干网VLAN
I-SID
骨干网服务实例编号
快速泛洪通道状态,取值为:
·     Active:表示快速泛洪通道可用
·     Inactive:表示快速泛洪通道不可用
Replication mode
组播复制模式,取值为:
·     head-end:表示头端复制模式
·     tandem:表示核心复制模式
ECT algorithm
B-VLAN对应的ECT算法
LSPs sent count
通过快速泛洪通道发送LSP的个数
当发生以下任意一种情况时,本字段清零:
·     执行reset spbm database命令
·     I-SID为255的SPB VSI实例down
·     进行进程分布优化。有关进程分布优化的详细介绍,请参见“可靠性配置指导”中的“进程分布优化”
LSPs received count
通过快速泛洪通道接收的LSP个数
当发生以下任意一种情况时,本字段清零:
·     进行进程分布优化
LSP timer
快速泛洪通道发送LSP的最小时间间隔,单位为毫秒。不可配
快速泛洪通道一次最多可以发送的LSP个数。不可配
display spbm graceful-restart status命令用来显示SPBM GR状态信息。
# 显示SPBM GR状态信息。
<Sysname> display spbm graceful-restart status
                          Restart information for SPBM
Restart status             : Complete
Restart phase              : Finish
Restart interval           : 300
SA bit                     : Supported
Total number of interfaces : 0
Number of waiting LSPs     : 0
表1-13 display spbm graceful-restart status命令显示信息描述表
Restart status
当前设备的Restart状态:
·     Restarting:保证能进行转发
·     Starting:不能保证转发
·     Complete:完成GR
Restart phase
当前设备的Restart阶段:
·     Initialization:GR初始
·     LSDB synchronization:LSDB同步
·     LSP stability:本地LSP稳定阶段
·     LSP generation:LSP生成和泛洪
·     First SPF computation:第一次拓扑计算
·     Finish:完成
Restart Interval
设备预期完成重启的时间间隔,单位为秒,在该时间间隔内邻居不会断掉与重启设备的邻接关系
SA bit
设备是否支持SA:
·     Supported:支持,SA位置位为1,重启设备的邻居不会发布与重启设备的邻接关系
·     Not supported:不支持,SA位清空为0,重启设备的邻居会继续发布与重启设备的邻接关系
当前使能SPBM的接口数
GR Restarter从GR Helper进行LSDB同步时,未完成同步的LSP数目
T2 remaining time
T2定时器剩余的时间,单位为秒,T2定时器用来控制LSDB的同步时间
接口名称
T1 remaining time
接口上T1定时器剩余的时间,单位为秒,T1定时器用来控制带RR(Restart Request,Restart请求)标志位的Hello报文的重传时间
RA received
接口上是否收到邻居发送的带RA标志位的Hello报文
CSNP received
接口上是否收到完整的CSNP报文,即是否完成与GR Helper的LSDB同步
T1 expirations
T1定时器的超时次数,超时达到10次后,不会再进行带RR标志位的Hello报文的重传
display spbm interface命令用来显示使能SPBM功能接口的信息。
display spbm interface [ interface-type interface-number ] [ verbose ]
interface-type interface-number:显示指定接口的信息。如果不指定该参数,则显示所有使能SPBM功能接口的信息。
verbose:显示接口的详细信息。如果不指定该参数,则显示接口的简要信息。
# 显示使能SPBM功能的接口的简要信息。
<Sysname> display spbm interface
                         Interface information for SPBM
 Interface                   Circuit ID    State     MTU      Cost
 GE3/0/2                     1             Up        1497     400
# 显示使能SPBM功能的接口的详细信息。
<Sysname> display spbm interface verbose
 Hello timer           : 10
 Hello multiplier      : 3
 LSP timer             : 33
 LSP transmitted count : 5
表1-14 display spbm interface显示信息描述表
接口名
Circuit ID
电路ID
接口状态
MTU
接口MTU值
Cost
接口的链路开销值
Hello timer
Hello报文发送时间间隔,单位为秒
Hello multiplier
Hello报文失效数目
LSP timer
发送LSP的最小时间间隔,单位为毫秒
发送LSP的数目
display spbm lsdb命令用来显示SPBM链路状态数据库中的LSP信息。
display spbm lsdb [ [ lsp-id lspid | lsp-name lspname ] | local | verbose ] *
lsp-id lspid:LSP标识,形式为SYSID.Pseudonode ID-fragment num,其中,SYSID是产生该LSP的节点的System ID,Pseudonode ID是伪节点ID,fragment num是该LSP的分片号。如果不指定该参数,将显示链路状态数据库中所有LSP标识对应的LSP信息。
lsp-name lspname:LSP名称,形式为Symbolic name-fragment num。其中,Symbolic name是产生该LSP的主机名称(关于主机名称的配置,请参考is-name命令),fragment num是该LSP的分片号。如果不指定该参数,将显示链路状态数据库中所有LSP名称对应的LSP信息。
local:显示本设备产生的所有LSP的信息。如果不指定该参数,将显示链路状态数据库中所有设备产生的LSP信息。
verbose:显示链路状态数据库中的LSP详细信息。如果不指定该参数,将显示链路状态数据库中的LSP摘要信息。
如果未指定任何参数,则显示链路状态数据库中的所有LSP信息。
# 显示SPBM链路状态数据库中的LSP摘要信息。
<Sysname> display spbm lsdb
                         Database information for SPBM
LSP ID: * - Local LSP
LSP ID                Seq Num      Checksum      Holdtime      Length  Overload
4455.6677.0001.00-00  0x00000fd2   0x1cea        1044          236     0
4455.6677.0001.00-01  0x00000fd2   0x1cea        1044          256     0
4455.6677.0003.00-00* 0x00001448   0x3d27        683           323     0
4455.6677.0003.00-01* 0x00001448   0xbd27        683           723     0
4455.6677.0004.00-00  0x00000ff8   0xd1d9        1090          323     0
4455.6677.0004.00-01  0x00000ff8   0xd7d9        1090          329     0
# 显示SPBM链路状态数据库中的LSP详细信息。
<Sysname> display spbm lsdb verbose
0011.2200.0001.00-00  0x0000000e   0x29ef        429           69      0
System ID           : 0011.2200.0001
NLPID               : SPBM
Area address        : 00.0000
MT capability TLV   :
 MT ID       : 00
 MT overload : 0
 SPB instance sub-TLV   :
   CIST root identifier : 0000-0000-0000-0000
   CIST ERPC            : 0
   Bridge priority      : 32768
   SPSourceID           : 100
   Number of trees      : 1
     B-VLAN: 10      U-Bit: 1    ECT: 00-80-c2-01    SPVID: 0
0011.2200.0001.00-01  0x0000000f   0x209e        1190          66      0
Hostname            : 0011.2200.0001.00
MT capability TLV   :
 MT ID       : 00
 MT overload : 0
 SPBM Service Identifier and Unicast Address sub-TLV:
   B-MAC     : 0011-2200-0001
   B-VLAN    : 10
     I-SID   : 300(R)
Extended neighbor reachability TLV:
 Hostname    : 0011.2200.0101.00
 Cost        : 11
 Port number : 1
0011.2200.0101.00-00* 0x00000002   0x3846        1190          69      0
System ID           : 0011.2200.0101
NLPID               : SPBM
MT capability TLV   :
 MT ID       : 00
 MT overload : 0
 SPB instance sub-TLV:
   CIST ERPC            : 0
   SPSourceID           : 10
   Number of Trees      : 1
0011.2200.0101.00-01* 0x00000002   0xfdcd        1190          66      0
MT capability TLV   :
 MT ID       : 00
 MT overload : 0
   B-MAC     : 0011-2200-0101
   B-VLAN    : 10
     I-SID   : 300(R)
     I-SID   : 301(T&R)
 Cost        : 10
 Port number : 1
表1-15 display spbm lsdb命令显示信息描述表
LSP ID
链路状态报文ID,*表示本地LSP
Seq Num
LSP序列号
Checksum
LSP校验和
Holdtime
LSP生存时间(单位为秒),随着时间推移递减
Length
LSP长度
Overload
LSP中Overload的置位情况:
·     1:表示置位
·     0:表示没有置位
System ID
LSP生成设备的System ID
NLPID
LSP生成设备运行的协议
Area address
LSP生成设备的区域地址
MT capability TLV
多拓扑能力TLV
MT ID
多拓扑ID
MT overload
多拓扑能力TLV中overload的置位情况:
·     1:表示置位
·     0:表示没有置位
SPB实例子TLV
CIST根标识
CIST ERPC
CIST外部根路径开销
Bridge priority
桥优先级
SPSourceID
最短路径源ID
Number of trees
ECT算法与Base VID元组数目
B-VLAN
B-VLAN
U-Bit
该B-VLAN是否承载流量:
·     1:表示承载
·     0:表示不承载
ECT
ECT算法
SPVID
SPBV标记
B-MAC
B-MAC
B-VLAN
B-VLAN
I-SID
I-SID值及标记:
·     T:Transmit位置位
·     R:Receive位置位
Hostname
主机名,如果主机未配置则显示设备的System ID
Cost
链路开销
Port number
邻居建立的端口个数
display spbm multicast-fdb命令用来显示SPBM的组播FDB表项信息。
display spbm multicast-fdb [ b-vlan vlan-id | i-sid i-sid | system-id system-id ]
b-vlan vlan-id:显示指定B-VLAN的组播FDB表项信息,vlan-id取值范围为1~4094。如果不指定该参数,则显示所有B-VLAN的组播FDB表项信息。
i-sid i-sid:显示指定I-SID的组播FDB表项信息,i-sid取值范围为255~16777215。如果不指定该参数,则显示所有I-SID的组播FDB表项信息。
system-id system-id:显示指定System ID的组播FDB表项信息,system-id的格式为XXXX.XXXX.XXXX。如果不指定该参数,则显示所有System ID的组播FDB表项信息。
如果三个参数都未指定,则显示所有的SPBM组播FDB表项信息。
# 显示所有的SPBM组播FDB表项信息。
<Sysname> display spbm multicast-fdb
Flags: E-Egress T-Transit
System ID            MAC address      B-VLAN   Flags Port
0011.2200.de01       9334-6900-03e8   7        T     GE1/0/2
0011.2200.de01       9334-6900-0190   4        T     GE1/0/2
0011.2200.de01       9334-6900-01f4   5        T     GE1/0/2
表1-16 display spbm multicast-fdb命令显示信息描述表
System ID
系统ID
MAC address
组播MAC地址
B-VLAN
B-MAC地址对应接口所属的B-VLAN
Flags
报文转发标志:
·     E:表示出隧道
·     T:表示转发
如果字段显示为两个转发标志的组合,如TE,则表示两个报文转发动作都有发生
Port
出端口,N/A表示没有出端口
display spbm multicast-fdb count命令用来显示SPBM的组播FDB表项数目信息。
display spbm multicast-fdb [ b-vlan vlan-id ] count
b-vlan vlan-id:显示指定B-VLAN的组播FDB表项数目信息,vlan-id取值范围为1~4094。如果不指定该参数,则显示所有B-VLAN的组播FDB表项数目信息。
# 显示所有的SPBM组播FDB表项数目信息。
<Sysname> display spbm multicast-fdb count
Total entries: 2
表1-17 display spbm multicast-fdb count命令显示信息描述表
Total entries
组播FDB表项计数
display spbm multicast-fib命令用来显示SPBM组播FIB表项信息。
独立运行模式:
display spbm multicast-fib [ mac-address mac-address [ b-vlan vlan-id ] | b-vlan vlan-id ] [ slot slot-number [ cpu cpu-number ] ] [ verbose ]
IRF模式:
display spbm multicast-fib [ mac-address mac-address [ b-vlan vlan-id ] | b-vlan vlan-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ verbose ]
mac-address mac-address:显示指定MAC地址的组播FIB表项信息,mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定该参数,则显示所有B-MAC地址的组播FIB表项信息。
b-vlan vlan-id:显示指定B-VLAN的组播FIB表项信息,vlan-id取值范围为1~4094。如果不指定该参数,则显示所有B-VLAN的组播FIB表项信息。
mac-address mac-address b-vlan vlan-id:显示指定MAC地址及B-VLAN的组播FIB表项信息。如果不指定该参数,则显示所有组播FIB表项信息。
verbose:显示组播FIB表项的详细信息。如果不指定该参数,则显示组播FIB表项的简要信息。
slot slot-number:显示指定单板的组播FIB表项信息。slot-number表示单板所在的槽位号。(独立运行模式)。如果不指定该参数,则显示所有单板的组播FIB表项信息。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的组播FIB表项信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有成员设备上所有单板的组播FIB表项信息。(IRF模式)。
cpu cpu-number:显示指定CPU的组播FIB表项信息。cpu-number表示CPU的编号。如果不指定该参数,则显示所有CPU的组播FIB表项信息。本参数仅主控板可配置。
# 显示所有的SPBM组播FIB表项信息。
<Sysname> display spbm multicast-fib
0300-0b00-0001 1      TE    GE1/0/2
# 显示所有的SPBM组播FIB表项的详细信息。
<Sysname> display spbm multicast-fib verbose
MAC address    B-VLAN Flags Epoch       Port                     Port flag
0300-0b00-0001 1      TE    0x1         GE1/0/2                  Done
# 显示MAC地址为0300-0b00-0001、B-VLAN为1的SPBM组播FIB表项的详细信息。
<Sysname> display spbm multicast-fib mac-address 0300-0b00-0001 b-vlan 1 verbose
MAC address: 0300-0b00-0001    B-VLAN     : 1
Flags  : TE                 Driver flag: Done         Epoch: 0x1
Context: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
Port                     Context                 Port flag
GE1/0/2                  0xffffaaaa  0xffffaaaa  Done
GE1/0/1                  0xffffaaaa  0xffffbbbb  Done
表1-18 display spbm multicast-fib命令显示信息描述表
MAC address
SPBM组播转发的MAC地址
B-VLAN
SPBM组播转发的VLAN
Flags
报文转发标志:
·     E:表示出隧道
·     T:表示转发
Driver flag
下驱动标记:
·     Nores:下驱动资源不足,此时该表项不可用
·     Done:下驱动成功
Epoch
表项的时间戳
Context
保存SPBM FDB表项下发驱动后返回的驱动信息
Port
出端口,其中N/A表示无出端口
Context
出端口对应的驱动信息
Port flag
端口下驱动标记:
·     Nores:下驱动资源不足
·     Done:下驱动成功
·     N/A:端口未下驱动
display spbm multicast-fib count命令用来显示SPBM组播FIB表项数目信息。
独立运行模式:
display spbm multicast-fib [ b-vlan vlan-id ] [ slot slot-number [ cpu cpu-number ] ] count
IRF模式:
display spbm multicast-fib [ b-vlan vlan-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] count
b-vlan vlan-id:显示指定B-VLAN的组播FIB表项数目信息,vlan-id取值范围为1~4094。如果不指定该参数,则显示所有B-VLAN的组播FIB表项数目信息。
slot slot-number:显示指定单板的组播FIB表项数目信息。slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有单板的组播FIB表项数目信息。(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的组播FIB表项数目信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有成员设备上所有单板的组播FIB表项数目信息。(IRF模式)。
cpu cpu-number:显示指定CPU的组播FIB表项数目信息。cpu-number表示CPU的编号。如果不指定该参数,则显示所有CPU的组播FIB表项数目信息。本参数仅主控板可配置。
# 显示B-VLAN 100的SBPM组播FIB表项数目信息。
<Sysname> display spbm multicast-fib b-vlan 100 count
Total entries: 3
表1-19 display spbm multicast-fib count命令显示信息描述表
Total entries
SPBM组播转发表项计数
display spbm multicast-fib statistics命令用来显示SPBM组播FIB表项统计信息。
独立运行模式:
display spbm multicast-fib statistics [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
display spbm multicast-fib statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定单板的组播FIB表项统计信息。slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有单板的组播FIB表项统计信息。(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的组播FIB表项统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有成员设备上所有单板的组播FIB表项统计信息。(IRF模式)。
cpu cpu-number:显示指定CPU的组播FIB表项统计信息。cpu-number表示CPU的编号。如果不指定该参数,则显示所有CPU的组播FIB表项统计信息。本参数仅主控板可配置。
# 显示成员设备1上单板0的SPBM组播FIB表项统计信息。
<Sysname> display spbm multicast-fib statistics chassis 1 slot 0
SPBM multicast FIB basic statistics:
RefreshMsg      : 0           DeleteMsg        : 0
AddIfMsg        : 1           DeleteIfMsg      : 0
AddMMACNumber   : 1           DeleteMMACNumber : 0
DeleteNotFound  : 0           AgeNumber        : 0
DrvAdd          : 1           DrvDelete        : 0
DrvAddIf        : 0           DrvDeleteIf      : 0
DrvModifyFlag   : 0
SPBM multicast FIB error statistics:
MMACMsgError    : 0           RefreshMsgFail   : 0
DeleteMsgFail   : 0           AddIfMsgFail     : 0
DeleteIfMsgFail : 0           AddMMACFail      : 0
DrvOtherFail    : 0           DrvDeleteFail    : 0
DrvNoResource   : 0           SynMsgFail       : 0
AllocEntryFail  : 0           AllocReDrvMsgFail: 0
AllocDrvMsgFail : 0
表1-20 display spbm multicast-fib statistics命令显示信息描述表
SPBM组播转发表基础统计信息
RefreshMsg
添加组播表项消息计数
DeleteMsg
组播表项删除消息计数
AddIfMsg
添加出接口消息计数
DeleteIfMsg
删除出接口消息计数
AddMMACNumber
创建组播MAC
DeleteMMACNumber
删除组播MAC
DeleteNotFound
删除时,查找不到合适的组播MAC
AgeNumber
当前启动老化状态时老化表项的个数
DrvAdd
添加驱动表项计数
DrvDelete
删除驱动表项计数
DrvAddIf
驱动表项增加出接口计数
DrvDeleteIf
驱动表项删除出接口计数
DrvModifyFlag
驱动表项修改转发标记计数
SPBM组播转发表错误统计信息
MMACMsgError
无效的表项消息计数
RefreshMsgFail
组播MAC添加消息处理失败计数
DeleteMsgFail
组播MAC删除消息处理失败计数
AddIfMsgFail
组播MAC添加出接口消息处理失败计数
DeleteIfMsgFail
组播MAC删除出接口消息处理失败计数
AddUMACFail
创建组播MAC表项失败计数
DrvOtherFail
组播MAC修改转发标记消息处理失败计数
DrvDeleteFail
组播MAC下发驱动删除失败计数
DrvNoResource
组播MAC下发驱动资源不足计数
SynMsgFail
驱动信息同步失败计数
AllocEntryFail
组播MAC表项内存申请失败计数
AllocReDrvMsgFail
重刷组播MAC表项因内存申请失败计数
AllocDrvMsgFail
组播MAC下驱动内存申请失败计数
display spbm multicast-pw命令用来显示SPBM的组播PW信息。
display spbm multicast-pw [ i-sid i-sid ] [ count ]
i-sid i-sid:显示指定I-SID的组播PW信息。i-sid取值范围为255~16777215。如果不指定该参数,则显示所有I-SID的组播PW信息。
count:显示组播PW的数量。如果不指定该参数,则显示组播PW的信息。
# 显示所有SPBM组播PW信息。
<Sysname> display spbm multicast-pw
System ID            I-SID      MAC address    B-VLAN Port
0011.2200.0101       300        0300-0a00-012c 10     GE1/0/1
                                                      GE1/0/2
表1-21 display spbm multicast-pw命令显示信息描述表
System ID
系统ID
I-SID
I-SID
MAC address
组播MAC地址
B-VLAN
Port
出端口列表
# 显示SPBM所有组播PW数目信息。
<Sysname> display spbm multicast-pw count
Total entries: 2
表1-22 display spbm multicast-pw count命令显示信息描述表
Total entries
组播PW表项计数
display spbm peer命令用来显示SPBM的邻居信息。
display spbm peer [ system-id system-id ] [ verbose ]
system-id system-id:显示指定邻居的信息,system-id的格式为XXXX.XXXX.XXXX。如果不指定该参数,则显示所有邻居的信息。
verbose:显示邻居的详细信息。如果不指定该参数,则显示邻居的简要信息。
# 显示所有邻居的简要信息。
<Sysname> display spbm peer
                          Peer information for SPBM
System ID         Port                        Circuit ID    State    Holdtime
5555.1111.1111    GE1/0/2                     1             Up       28s
5555.1111.2222    GE1/0/3                     1             Up*      20s
# 显示所有邻居的详细信息。
<Sysname> display spbm peer verbose
Peer information:
  Host name: spbm-2
  Circuit ID: 1      Cost: 10
  MCID information:
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
    Configuration digest : 0x0253c1480d244e443b21e7c364d6e2a7
  Aux MCID information:
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
  AP information:
    AN: 2    DAN: 0    Valid: 1
    Format identifier       : 0
    Format capabilities     : 0
    Convention identifier   : 0
    Convention capabilities : 0
    Edge count              : 2
    Topology digest         : 0x000000dc12854410daa2c29221f095144f661000
Local information:
  Host name: spbm-1
  MCID information:
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
    Format Selector      : 0
    Region Name          : spb
    Revision Level       : 0
    Configuration Digest : 0x0253c1480d244e443b21e7c364d6e2a7
  AP information:
    Edge count              : 2
5555.1111.2222    GE1/0/3                     1             Up       20s
Peer information:
  Host name: spbm-3
  MCID information:
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
  AP information:
    Edge count              : 2
Local information:
  Host name: spbm-1
  MCID information:
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
  AP information:
    Edge count              : 2
# 显示System ID为5555.1111.1111的邻居的详细信息。
<Sysname> display spbm peer system-id 5555.1111.1111 verbose
5555.1111.1111    GE1/0/1                     1             Up       28s
Peer information:
  Host name: spbm-2
  MCID information:
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
  AP information:
    Edge count              : 2
Local information:
  Host name: spbm-1
  MCID information:
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
    Format selector      : 0
    Region name          : spb
    Revision level       : 0
  AP information:
    Edge count              : 2
表1-23 display spbm peer命令显示信息描述表
System ID
邻居的System ID
Port
与对端相连的本地SPBM接口
Circuit ID
邻居电路ID
邻居状态:
·     Init:表示请求与邻居建立连接
·     Up:表示邻居已建立,与邻居间的连接处于Up状态
·     Up*:表示邻居已建立,与邻居间的连接处于Up状态,但该邻居不承载流量
·     Down:表示邻居已建立,与邻居间的连接处于Down状态
Holdtime
抑制时间,随着时间推移递减,如果在抑制时间内还没有收到邻居发送的Hello报文,则认为邻居已经失效,如果收到了Hello报文,则抑制时间将重置为初始值
Peer information
邻居信息
Host name
邻居主机名,未配置主机名时显示邻居System ID
Circuit ID
邻居电路ID
Cost
邻居链路开销值
MCID information
邻居携带的主MCID信息
邻居携带的辅助MCID信息
Format selector
邻居生成树协议规定的选择因子,缺省值为0,不可配置
Region name
邻居MST域的域名
Revision level
邻居MST域的修订级别,可使用命令revision-level来配置,缺省为0级
邻居配置摘要
AP information
邻居携带的AP信息,N/A表示未携带AP相关信息
AN
邻居携带的Agreement Number
DAN
邻居携带的Discarded Agreement Number
Valid
邻居携带的AP摘要是否有效:
·     0:表示摘要无效
·     1:表示摘要有效
Format identifier
邻居摘要类型标识
Format capabilities
邻居摘要格式类型
邻居约定标识,发布环路避免的转发规则:
·     1:表示无需匹配邻居的摘要信息
·     2:表示发送者将继续进行无环路的组播和单播发送,即邻居之间严格Agreement之后才能转发流量
·     3:表示发送者继续进行无环路的组播转发
邻居支持的摘要协商能力
Edge count
邻居AP协议计算摘要需要的参数
Topology digest
邻居拓朴摘要信息
Local information
本地信息
Hostname
本地主机名,未配置主机名时显示System ID
Circuit ID
本地电路ID
Cost
本地链路开销值
MCID information
本地携带的MCID
本地携带的辅助MCID
Format selector
本地生成树协议规定的选择因子,缺省值为0,不可配置
Region name
本地MST域的域名
Revision level
本地MST域的修订级别,可使用命令revision-level来配置,缺省为0级
本地配置摘要
AP information
本地携带的AP信息,N/A表项未携带AP相关信息
AN
本地携带的Agreement Number
DAN
本地携带的Discarded Agreement Number
Valid
本地发送的AP摘要是否有效:
·     0:表示摘要无效
·     1:表示摘要有效
Format identifier
本地摘要类型标识
Format capabilities
本地摘要格式类型
本地约定标识,发布环路避免的转发规则:
·     1:表示无需匹配邻居的摘要信息
本地支持的摘要协商能力
Edge count
本地AP摘要边数
Topology digest
本地拓朴摘要信息
display spbm summary命令用来显示SPBM摘要信息。
# 显示SPBM摘要信息。
<Sysname> display spbm summary
                   Summary information for SPBM
System control address : 0180-c200-002e
System name            : spb-1
SPSource ID            : 200
SPSource mode          : Static
Agreement mode         : Both
MCID information:
  Format selector      : 0
  Region name          : spb
  Revision level       : 0
B-VLANs                : 1-10, 100-200
表1-24 display spbm summary命令显示信息描述表
Area address
区域地址
System ID
系统ID
协议控制地址
System name
系统名
Bridge priority
桥优先级
SPSource ID
最短路径源ID
SPSource mode
最短路径源模式:
·     Static:表明为静态配置
·     Dynamic:表明为动态生成
Agreement mode
AP模式:
·     Off:表示AP模式关闭
B-VLANs
本地配置的B-VLAN
MCID information
本地MCID信息
Format selector
Region name
MST域的域名
Revision level
MST域的修订级别,可使用命令revision-level来配置,缺省值为0
配置摘要
display spbm unicast-fdb命令用来显示SPBM的单播FDB表项信息。
display spbm unicast-fdb [ b-mac mac-address | b-vlan vlan-id | system-id system-id ]
b-mac mac-address:显示指定B-MAC地址的单播FDB表项信息,mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定该参数,则显示所有B-MAC地址的单播FDB表项信息。
b-vlan vlan-id:显示指定B-VLAN的单播FDB表项信息。vlan-id为指定VLAN的编号,取值范围为1~4094。如果不指定该参数,则显示所有B-VLAN的单播FDB表项信息。
system-id system-id:显示指定System ID的SPBM单播FDB表项信息,system-id的格式为XXXX.XXXX.XXXX。如果不指定该参数,则显示所有System ID的单播FDB表项信息。
如果三个参数都未指定,则显示所有的SPBM单播FDB表项信息。
# 显示所有SPBM单播FDB表项信息。
<Sysname> display spbm unicast-fdb
System ID            B-MAC            B-VLAN   Flags Port
0011.2200.0001       0011-2200-0001   9        T     GE1/0/2
0011.2200.0001       0011-2200-0001   4        T     GE1/0/2
0011.2200.0001       0011-2200-0001   5        T     GE1/0/2
表1-25 display spbm unicast-fdb命令显示信息描述表
System ID
系统ID
B-MAC
B-MAC地址
B-VLAN
Flags
报文转发标志:
·     E:表示出隧道
·     T:表示转发
Port
出端口
display spbm unicast-fdb count命令用来显示SPBM的单播FDB表项数目信息。
display spbm unicast-fdb [ b-mac mac-address | b-vlan vlan-id | system-id system-id ] count
b-mac mac-address:显示指定B-MAC地址的单播FDB表项数目信息,mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定该参数,则显示所有B-MAC地址的单播FDB表项数目信息。
b-vlan vlan-id:显示指定B-VLAN的单播FDB表项数目信息。vlan-id为指定VLAN的编号,取值范围为1~4094。如果不指定该参数,则显示所有B-VLAN的单播FDB表项数目信息。
system-id system-id:显示指定System ID的单播FDB表项数目信息,system-id的格式为XXXX.XXXX.XXXX。如果不指定该参数,则显示所有System ID的单播FDB表项数目信息。
如果三个参数都未指定,则显示所有的SPBM单播FDB表项数目信息。
# 显示所有的SPBM单播FDB表项数目信息。
<Sysname> display spbm unicast-fdb count
Total entries: 2
表1-26 display spbm unicast-fdb count命令显示信息描述表
Total entries
SPBM单播FDB表项计数
display spbm unicast-fib命令用来显示SPBM单播FIB表项信息。
独立运行模式:
display spbm unicast-fib [ b-mac mac-address [ b-vlan vlan-id ] | b-vlan vlan-id ] [ slot slot-number [ cpu cpu-number ] ] [ verbose ]
IRF模式:
display spbm unicast-fib [ b-mac mac-address [ b-vlan vlan-id ] | b-vlan vlan-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ verbose ]
b-mac mac-address:显示指定B-MAC地址的单播FIB表项信息,mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定该参数,则显示所有B-MAC地址的单播FIB表项信息。
b-vlan vlan-id:显示指定B-VLAN的单播FIB表项信息,vlan-id取值范围为1~4094。如果不指定该参数,则显示所有B-VLAN的单播FIB表项信息。
b-mac mac-address b-vlan vlan-id:显示指定B-MAC及B-VLAN的单播FIB表项信息。如果不指定本参数,则显示所有的单播FIB表项信息。
verbose:显示单播FIB表项的详细信息。如果不指定本参数,则显示单播FIB表项的简要信息。
slot slot-number:显示指定单板的单播FIB表项信息。slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有单板的单播FIB表项信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的单播FIB表项信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有成员设备上所有单板的单播FIB表项信息。(IRF模式)
cpu cpu-number:显示指定CPU的单播FIB表项信息。cpu-number表示CPU的编号。如果不指定该参数,则显示所有CPU的单播FIB表项信息。本参数仅主控板可配置。
# 显示SPBM单播FIB表的所有表项的简要信息。
<Sysname> display spbm unicast-fib
0011-2200-0101 1      T     GE1/0/1
0011-2200-0101 2      T     GE1/0/2
# 显示SPBM单播FIB表的所有表项的详细信息。
<Sysname> display spbm unicast-fib verbose
B-MAC          B-VLAN Flags Driver flag Epoch       Port
0011-2200-0101 1      T     Done        0x1         GE1/0/2
0011-2200-0101 2      T     Done        0x1         GE1/0/2
# 显示B-MAC为0011-2200-0101、B-VLAN为1的SPBM单播FIB表项的详细信息。
<Sysname> display spbm unicast-fib b-mac 0011-2200-0101 b-vlan 1 verbose
B-MAC  : 0011-2200-0101   B-VLAN     : 1
Port   : GE1/0/2
Flags  : T                Driver flag: Done
Epoch  : 0x1
表1-27 display spbm unicast-fib命令显示信息描述表
B-MAC
SPBM单播转发表项的MAC地址
B-VLAN
SPBM单播转发表项的VLAN
Port
出端口
Flags
报文转发标志:
·     E:表示出隧道
·     T:表示转发
Driver flag
下驱动标记:
·     Nores:表示下驱动资源不足
·     Done:表示下驱动成功
Epoch
老化时间戳,用于表示表项是否需要老化
Context
保存SPBM FDB下刷驱动后返回的驱动信息
display spbm unicast-fib count命令用来显示SPBM单播FIB表项数目信息。
独立运行模式:
display spbm unicast-fib [ b-vlan vlan-id ] [ slot slot-number [ cpu cpu-number ] ] count
IRF模式:
display spbm unicast-fib [ b-vlan vlan-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] count
b-vlan vlan-id:显示指定B-VLAN的单播FIB表项数目信息,vlan-id取值范围为1~4094。如果不指定该参数,则显示所有B-VLAN的单播FIB表项数目信息。
slot slot-number:显示指定单板的单播FIB表项数目信息。slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有单板的单播FIB表项数目信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的单播FIB表项数目信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有成员设备上所有单板的单播FIB表项数目信息。(IRF模式)
cpu cpu-number:显示指定CPU的单播FIB表项数目信息。cpu-number表示CPU的编号。如果不指定该参数,则显示所有CPU的单播FIB表项数目信息。本参数仅主控板可配置。
# 显示B-VLAN 100的SPBM单播FIB表的表项数量。
<Sysname> display spbm unicast-fib b-vlan 100 count
Total entries: 2
表1-28 display spbm unicast-fib count命令显示信息描述表
Total entries
SPBM单播转发表项计数
display spbm unicast-fib statistics命令用来显示SPBM单播FIB表项统计信息。
独立运行模式:
display spbm unicast-fib statistics [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
display spbm unicast-fib statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定单板的单播FIB表项统计信息。slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有单板的单播FIB表项统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的单播FIB表项统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则显示所有成员设备上所有单板的单播FIB表项统计信息。(IRF模式)
cpu cpu-number:显示指定CPU的单播FIB表项统计信息。cpu-number表示CPU的编号。如果不指定该参数,则显示所有CPU的单播FIB表项统计信息。本参数仅主控板可配置。
# 显示SPBM单播FIB表项统计信息。
<Sysname> display spbm unicast-fib statistics
SPBM unicast FIB basic statistics:
RefreshMsg     : 1           DeleteMsg        : 0
AddUMACNumber  : 1           DeleteUMACNumber : 0
DrvDelRefresh  : 0
SPBM unicast FIB error statistics:
UMACMsgError   : 0           RefreshMsgFail   : 0
DeleteMsgFail  : 0           AddUMACFail      : 0
表1-29 display spbm unicast-fib statistics命令显示信息描述表
SPBM单播转发表基础统计信息
RefreshMsg
单播MAC刷新消息
DeleteMsg
单播MAC删除消息
AddUMACNumber
创建单播MAC
DeleteUMACNumber
删除单播MAC
DeleteNotFound
删除时查找不到合适的单播MAC
AgeNumber
当前启动老化状态时老化表项的个数
DrvAdd
驱动表项添加
DrvDelete
驱动表项删除
DrvDelRefresh
驱动表项Modify时删除
UMACMsgError
无效的单播MAC消息
SPBM单播转发表错误统计信息
RefreshMsgFail
单播MAC刷新消息处理失败
DeleteMsgFail
单播MAC删除消息处理失败
AddUMACFail
创建单播MAC表项失败
DrvOtherFail
单播MAC下发驱动添加或更新
DrvDeleteFail
单播MAC下发驱动删除
DrvNoResource
单播MAC下发驱动资源不足
SynMsgFail
信息同步失败
AllocEntryFail
单播MAC表项内存申请失败
AllocReDrvMsgFail
单播MAC重刷节点内存申请失败
display spbm unicast-pw命令用来显示SPBM的单播PW信息。
display spbm unicast-pw [ i-sid i-sid ] [ count ]
i-sid i-sid:显示指定I-SID的单播PW信息。i-sid取值范围为255~16777215。如果不指定该参数,则显示所有I-SID的单播PW信息。
count:显示单播PW的数量。如果不指定该参数,则显示单播PW信息。
# 显示SPBM所有单播PW信息。
<Sysname> display spbm unicast-pw
System ID            I-SID      B-MAC          B-VLAN Port
000f.e201.0101       300        000f-e201-0101 100    GE1/0/1
000f.e201.0102       300        000f-e201-0102 100    GE1/0/2
表1-30 display spbm unicast-pw命令显示信息描述表
System ID
系统ID
I-SID
I-SID
B-MAC
B-MAC地址
B-VLAN
Port
B-MAC地址对应的接口
# 显示SPBM所有单播PW数目信息。
<Sysname> display spbm unicast-pw count
Total entries: 2
表1-31 display spbm unicast-pw count命令显示信息描述表
Total entries
单播PW表项计数
display spbm unicast-tree用来显示单播树信息
# 显示B-VLAN 100的SPBM单播树。
<Sysname> display spbm unicast-tree
                         SPF tree information for SPBM
    Flags: S-Node is on SPF tree       D-Node or Link is to be deleted
           O-Node is overload          I-Node is invalid
           T-Node is on tent list      P-Neighbor is parent node
           C-Neighbor is child node    L-Link is on changelist
           V-Link is involved          N-Link is a new path
SPF node: 0011.2200.0001
  LinkCount: 0x1    NodeFlags: T S
SPF link: -->0011.2200.0101
  Cost: 0xb      NewCost: 0xb      LinkFlags: P
SPF node: 0011.2200.0101
  LinkCount: 0x1    NodeFlags: S
SPF link: -->0011.2200.0001
  Cost: 0xa      NewCost: 0xb      LinkFlags: C
表1-32 display spbm unicast-tree命令显示信息描述表
Flags
节点或链路标志:
·     S:表示节点在SPF树上
·     D:表示节点或链路待删除
·     O:表示节点置位OVERLOAD标记
·     I:表示节点无效
·     T:表示节点是候选节点
·     P:表示节点是SPF树上指定链路的父节点
·     C:表示节点是SPF树上指定链路的子节点
·     L:表示链路在链路变化链上
·     V:表示链路置位INVOLVED标记
·     N:表示链路是新增的
SPF node
SPF节点信息
LinkCount
以每个SPF节点为源的链路数
NodeFlags
SPF节点标志
SPF link
SPF链路信息
Cost
该链路源节点发布的度量值
NewCost
该链路源节点和目的节点协商后的度量值
LinkFlags
链路标志
1.1.39  ect
ect命令用来配置B-VLAN与ECT算法之间的映射关系。
undo ect命令用来取消B-VLAN与ECT算法之间的映射关系。
ect ect-index b-vlan vlan-id-list
undo ect ect-index b-vlan [ vlan-id-list ]
所有B-VLAN映射到ECT 1。
SPBM视图
ect-index:ECT算法索引值,取值范围为1~16。
vlan-id-list:B-VLAN列表,表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>。其中vlan-id1和vlan-id2为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。vlan-id2的值要大于或等于vlan-id1的值。
·     在SPBN内通过不同ECT算法决策出不同的SPT,每个SPT对应一个转发路径,不同的SPT间形成流量的负载分担。ECT算法与B-VLAN之间有映射关系,一组B-VLAN可以映射到同一ECT算法,后续该组B-VLAN的流量都在该ECT算法决策的SPT内进行转发。通过调整B-VLAN与ECT算法的映射关系可以达到调整网络负载分担的目的。
·     邻居间B-VLAN和ECT算法的映射关系不一致时,邻居间的链路不能承载流量。
# 配置B-VLAN 100~150映射到ECT 2上。
[Sysname] spbm
[Sysname-spbm] ect 2 b-vlan 100 to 150
# 取消ECT 2与所有B-VLAN的映射关系。
[Sysname] spbm
[Sysname-spbm] undo ect 2 b-vlan
1.1.40  flash-flood
flash-flood命令用来使能LSP快速扩散功能。
undo flash-flood命令用来恢复缺省情况。
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval ] *
undo flash-flood
未使能LSP快速扩散功能。
SPBM视图
flood-count flooding-count:在SPF重新计算前快速扩散的LSP个数,取值范围为1~15,缺省值为5。
max-timer-interval flooding-interval:在LSP快速扩散之前的等待时间,取值范围为10~50000,单位为毫秒,缺省值为10毫秒。
使能LSP快速扩散功能后,当LSP发生变化而导致SPF重新计算时,在SPF重新计算前,将把导致SPF重新计算的LSP快速扩散出去,扩散后,整网重新计算SPF。从而大大缩短设备之间由于进行LSP同步而导致LSDB不一致的时间,提高全网的快速收敛性能。
# 使能LSP快速扩散功能,配置在SPF重新计算前快速扩散的LSP个数为10,在LSP快速扩散之前的等待时间为100毫秒。
[Sysname] spbm
[Sysname-spbm] flash-flood flood-count 10 max-timer-interval 100
graceful-restart命令用来使能SPBM的GR(Graceful Restart,平滑重启)功能。
undo graceful-restart命令用来恢复缺省情况。
graceful-restart
SPBM的GR功能处于关闭状态。
SPBM视图
# 使能SPBM功能的GR功能。
[Sysname] spbm
[Sysname-spbm] graceful-restart
graceful-restart suppress-sa命令用来配置重启时抑制SA(Suppress-Advertisement)位置位。
undo graceful-restart suppress-sa命令用来取消重启时抑制SA位置位。
SA位处于置位状态。
SPBM视图
SA表示抑制邻接标志位,其主要目的是为了避免出现路由黑洞,例如在启动或者重启时没有保留本地转发表,此时如果GR Helper将报文送到设备来进行转发将会造成严重的丢包现象,在这种情况下GR Restarter发送的Hello报文中必须将SA位置1,而GR Helper接收到这种SA位被置1的Hello报文后就不会将发送该Hello报文的GR Restarter放入LSP扩散出去。
重启时抑制SA位,即在重启设备的Hello PDU中抑制发布SA位置位,重启设备的邻居将继续发布该邻接关系。
# 配置重启时抑制SA位置位。
[Sysname] spbm
[Sysname-spbm] graceful-restart suppress-sa
graceful-restart t2命令用来配置SPBM的GR T2定时器超时时间。
undo graceful-restart t2命令用来恢复缺省情况。
graceful-restart t2 t2-value
SPBM的GR T2定时器超时时间为300秒。
SPBM视图
t2-value:指定SPBM协议的GR T2定时器的超时时间,取值范围为30~1800,单位为秒。
T2定时器用来控制设备的GR时间间隔。T2定时器的超时值在SPBM的Hello PDU中为保持时间,这样在该设备GR的时间内邻居不会断掉与其的邻接关系。如果T2定时器超时后,GR还没有完成,则GR失败。
# 配置SPBM的GR T2定时器超时时间为120秒。
[Sysname] spbm
[Sysname-spbm] graceful-restart t2 120
1.1.44  is-name
is-name命令用来使能动态主机名映射功能并为当前设备配置主机名称。
undo is-name命令用来恢复缺省情况。
is-name is-name
undo is-name
动态主机名映射功能处于关闭状态且没有为当前设备配置主机名称。
SPBM视图
is-name:为当前设备配置的主机名称,为1~64个字符的字符串。
SPB IS-IS用System ID来在区域内唯一标识设备,System ID长度固定为6字节。当网络管理员检查SPBM邻居关系的状态、SPBM路由表以及LSDB中的内容时,十六进制表示的System ID以及LSP标识符不够直观,查看也不方便。
动态主机名映射功能提供了一种将System ID映射到主机名的服务,运行SPBM的设备维护一个主机名到System ID的映射关系表,在维护和管理以及网络故障诊断时,使用主机名比使用System ID会更直观,也更容易记忆。
使能动态主机名映射功能后,SPBN中的每台设备只需要在本机上配置自己的主机名称即可,配置的主机名称将通过动态主机名TLV发布出去,最后SPBN中使能动态主机名映射功能的设备都将收集到其他设备System ID与主机名称的映射关系并生成映射表。
# 使能动态主机名映射功能,并为本地SPBM配置主机名称为spbm。
[Sysname] spbm
[Sysname-spbm] is-name spbm
log-peer-change命令用来打开SPBM邻接状态的输出开关。
undo log-peer-change命令用来关闭SPBM邻接状态的输出开关。
log-peer-change
邻接状态的输出开关处于开启状态。
SPBM视图
当打开邻接状态输出开关后,SPBM邻接状态的变化会输出到配置终端上,方便用户查看变化过程,直至邻接状态输出开关被关闭。
# 关闭SPBM邻接状态变化的输出开关。
[Sysname] spbm
[Sysname-spbm] undo log-peer-change
multicast replicate-mode命令用来配置组播复制模式。
undo multicast replicate-mode命令用来恢复缺省情况。
multicast replicate-mode { head-end | tandem }
SPBM组播转发模式采用头端复制模式。
VSI SPB子视图
head-end:头端复制模式。
tandem:核心复制模式。
SPBM组播支持两种模式:头端复制和核心复制:
·     SPBM以头端复制模式进行组播发送时,会向SPBM同一实例中所有隧道进行发送。BEB会把原始报文复制多份,生成对应的MAC-in-MAC报文,MAC-in-MAC报文中除B-DA外其他字段一致。B-DA分别为各隧道目的地址。
·     SPBM以核心复制模式进行组播发送时,BEB以自己为组播源,向同一组播组进行发送。MAC-in-MAC报文中B-DA为BEB的组播地址。
# 配置组播复制模式为核心复制。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-256] multicast replicate-mode tandem
multicast-bvlan enable命令用来使能SPBM双B-VLAN功能。
undo multicast-bvlan enable命令用来恢复缺省情况。
SPBM双B-VLAN处于关闭状态。
SPBM视图
支持组播核心复制模式功能的设备,缺省会使用同一B-VLAN来承载单播流量和组播流量。可能会出现报文出隧道时无法终结的问题。通过使能组播双B-VLAN功能可以解决该问题。
组播双B-VLAN方案使用奇数B-VLAN(即编号为奇数的B-VLAN)来承载单播流量,使用偶数B-VLAN(编号为偶数的B-VLAN)来承载组播流量。SPBM协议报文中仅使用奇数B-VLAN,链路计算时会使用奇数B-VLAN来生成对应的单播转发表,同时使用编号为该奇数B-VLAN+1的偶数B-VLAN来生成对应的组播B-VLAN。后续用户侧报文入SPBN时,会在该奇数B-VLAN内进行单播发送,在对应的偶数B-VLAN内进行组播发送。
·     只要有一台设备需使能双B-VLAN功能,则同一SPBN内所有其他设备也必须使能双B-VLAN功能。
·     组播双B-VLAN功能中奇数B-VLAN和偶数B-VLAN必须成对配置,仅配置奇数B-VLAN或偶数B-VLAN时,SPBM协议报文无法使用该B-VLAN。
# 使能SPBM双B-VLAN功能。
[Sysname] spbm
[Sysname-spbm] multicast-bvlan enable
reset spbm bvlan-info statistics用来清除SPBM的B-VLAN统计信息。
独立运行模式:
reset spbm bvlan-info statistics slot slot-number [ cpu cpu-number ]
IRF模式:
reset spbm bvlan-info statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
slot slot-number:清除指定单板的B-VLAN统计信息。slot-number表示单板所在的槽位号。(独立运行模式)。
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的B-VLAN统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)。
cpu cpu-number:清除指定CPU的B-VLAN统计信息。cpu-number表示CPU的编号。本参数仅主控板可配置。
# 清除单板1上SPBM的B-VLAN统计信息。(独立运行模式)
<Sysname> reset spbm bvlan-info statistics slot 1
reset spbm database用来清除SPBM的数据库信息。
reset spbm database [ graceful-restart ]
graceful-restart:清除SPBM的数据库信息之后,通过GR方式来恢复。如果未指定本参数,则在清除SPBM的数据库信息后,以非GR方式来恢复数据。
# 清除SPBM的数据库信息。
<Sysname> reset spbm database
reset spbm multicast-fib statistics用来清除SPBM的组播FIB表统计信息。
独立运行模式:
reset spbm multicast-fib statistics slot slot-number [ cpu cpu-number ]
IRF模式:
reset spbm multicast-fib statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
slot slot-number:清除指定单板的组播FIB表统计信息。slot-number表示单板所在的槽位号。(独立运行模式)。
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的组播FIB表统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)。
cpu cpu-number:清除指定CPU的组播FIB表统计信息。cpu-number表示CPU的编号。本参数仅主控板可配置。
# 清除单板1上SPBM的组播FIB表统计信息。(独立运行模式)
<Sysname> reset spbm multicast-fib statistics slot 1
reset spbm unicast-fib statistics用来清除SPBM的单播FIB表统计信息。
独立运行模式:
reset spbm unicast-fib statistics slot slot-number [ cpu cpu-number ]
IRF模式:
reset spbm unicast-fib statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
slot slot-number:清除指定单板的单播FIB表统计信息。slot-number表示单板所在的槽位号。(独立运行模式)。
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的单播FIB表统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)。
cpu cpu-number:清除指定CPU的单播FIB表统计信息。cpu-number表示CPU的编号。本参数仅主控板可配置。
# 清除单板1上SPBM的单播FIB表统计信息。(独立运行模式)
<Sysname> reset spbm unicast-fib statistics slot 1
1.1.52  set-overload
set-overload命令用来配置LSDB过载标志位。
undo set-overload命令用来恢复缺省情况。
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 ]
undo set-overload
未配置LSDB过载标志位。
SPBM视图
on-startup:系统启动时将过载标志位置位。
start-from-nbr system-id [ timeout1 [ nbr-timeout ] ]:从系统启动时开始计算,如果在nbr-timeout参数指定的时长内仍未与指定邻居建立邻接关系完毕,过载标志位将结束置位状态;如果在nbr-timeout参数指定的时长内与指定邻居建立邻接关系完毕,过载标志位将继续保持置位状态,且从与指定邻居建立邻接关系时重新计时,在timeout1参数配置的时长内保持置位状态。
system-id:指定邻居的System ID,system-id的格式为XXXX.XXXX.XXXX。
timeout1:取值范围为5~86400,单位为秒,缺省值为600秒(10分钟)。
nbr-timeout:取值范围为5~86400,单位为秒,缺省值为1200秒(20分钟)。
timeout2:从系统启动时开始计算,过载标志位保持置位状态的时间长度,取值范围为5~86400,单位为秒,缺省值为600秒(10分钟)。
当运行SPBM的设备因为内存不足或其他原因无法记录完整的LSDB时,将会导致区域路由的计算错误。在故障排除过程中,通过给怀疑有问题的设备配置LSDB过载标志位,SPBM将在该设备发送的LSP报文中把Overload位置位,以通知其他设备该设备发生了问题,无法正确的执行路由选择和报文转发,从而可以将其从SPBN中暂时隔离,便于进行故障定位。
·     如果没有指定on-startup参数,SPBM将立即把过载标志位置位且一直保持置位状态,直到用户通过undo set-overload命令清除过载标志位。
·     如果只指定on-startup参数,过载标志位将在系统启动时开始置位,并且在timeout2参数指定的时长内保持置位状态。
# 配置LSDB过载标志位。
[Sysname] spbm
[Sysname-spbm] set-overload
snmp context-name命令用来配置管理SPBM的SNMP实体所使用的上下文名称。
没有配置管理SPBM的SNMP实体所使用的上下文名称。
SPBM视图
context-name:管理SPBM的SNMP实体所使用的上下文名称,为1~32个字符的字符串,区分大小写。
·     SPBM使用IS-IS的MIB(Management Information Base,管理信息库)对NMS(Network Management System,网络管理系统)提供SPBM对象的管理,但标准IS-IS MIB中定义的MIB为单实例的管理对象,无法同时对IS-IS和SPBM进行管理。因此,参考RFC 4750中对OSPF多实例的管理方法,为管理SPBM定义一个上下文名称,以区分从NMS来的SNMP请求是要对IS-IS还是SPBM进行管理。
·     由于上下文名称只是SNMPv3独有的概念,因此对于SNMPv1/v2c,会将团体名映射为上下文名称以对不同协议进行区分。
·     所有使用IS-IS MIB的特性,如TRILL、EVI、SPBM、IS-IS等,都需要支持配置上下文名称以区分SNMP请求的管理对象。各个特性实际配置的上下文名称是互斥的,即不允许不同的特性配置相同的上下文名称。
# 配置管理SPBM的SNMP实体所使用的上下文名称为sbpm。
[Sysname] spbm
[Sysname-spbm] snmp context-name spbm
snmp-agent trap enable spbm命令用来开启SPBM的告警功能。
undo snmp-agent trap enable spbm命令用来关闭SPBM的告警功能。
snmp-agent trap enable spbm [ adjacency-state-change | area-mismatch | authentication | authentication-type | b-mac-conflict | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | spsource-conflict | version-skew ] *
undo snmp-agent trap enable spbm [ adjacency-state-change | area-mismatch | authentication | authentication-type | b-mac-conflict | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | spsource-conflict | version-skew ] *
SPBM的告警功能处于开启状态。
adjacency-state-change:表示SPBM邻居状态变化的告警信息。
area-mismatch:表示Hello报文区域地址不匹配的告警信息。
authentication:表示认证信息错误的告警信息。
authentication-type:表示认证信息类型错误的告警信息。
b-mac-conflict:表示远端B-MAC与本地B-MAC发生冲突的告警信息。
buffsize-mismatch:表示LSP报文长度和产生缓冲区大小不匹配的告警信息。
id-length-mismatch:表示SPBM报文中System ID长度不匹配的告警信息。
lsdboverload-state-change:表示LSDB过载状态变化的告警信息。
lsp-parse-error:表示LSP报文解析错误的告警信息。
lsp-size-exceeded:表示超大的LSP报文导致泛洪失败的告警信息。
max-seq-exceeded:表示LSP序列号超过最大序列号的告警信息。
maxarea-mismatch:表示Hello报文最大区域地址不匹配的告警信息。
own-lsp-purge:表示尝试清除本地LSP的告警信息。
protocol-support:表示报文协议支持类型不匹配的告警信息。
rejected-adjacency:表示Hello报文邻接不匹配丢弃的告警信息。
skip-sequence-number:表示跳过已经产生过的LSP序列号的告警信息。
spsource-conflict:表示远端SPSource ID与本地配置SPSource ID发生冲突的告警信息。
version-skew:表示Hello报文版本号不匹配的告警信息。
如果未指定参数任何参数,表示开启或关闭SPBM的全部告警功能。
开启SPBM的告警功能后,SPBM会生成告警信息,用于报告本模块的重要事件。生成的告警信息将发送至SNMP模块,通过配置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭SPBM的全部告警功能。
[Sysname] undo snmp-agent trap enable spbm
1.1.55  spb i-sid
spb i-sid命令用来创建SPB VSI实例,并进入VSI SPB子视图。
undo spb i-sid命令用来恢复缺省情况。
spb i-sid i-sid
undo spb i-sid
未创建SPB VSI实例。
VSI视图
i-sid:指定SPB的骨干网服务实例编号,取值范围为255~16777215。
创建SPB VSI实例就是创建一个SPB类型的VSI(Virtual Switch Instance,虚拟交换实例),并同时指定其I-SID。I-SID是SPB VSI实例的唯一编号,用来标识同一类型的服务,在同一个SPBN中必须指定相同的I-SID。
I-SID为255的SPB VSI实例专门提供给LSP快速泛洪通道,用于快速泛洪LSP。该SPB VSI实例在创建后即可开启LSP快速泛洪通道,无需与接口或以太网服务实例关联。
# 为VSI实例vpn1指定SPB的I-SID为256,并进入VSI SPB子视图。
[Sysname] vsi vpn1
1.1.56  spbm
spbm命令用来全局使能SPBM功能,并进入SPBM视图。
undo spbm命令用来恢复缺省情况。
spbm
undo spbm
全局的SPBM功能处于关闭状态。
·     全局使能SPBM功能后才可进行其他SPBM相关配置。
·     全局关闭SPBM功能时会删除所有SPBM相关配置。
# 全局使能SPBM功能。
[Sysname] spbm
[Sysname-spbm]
spbm authentication send-only命令用来配置不对收到的Hello报文进行验证密码检查。
undo spbm authentication send-only命令用来恢复缺省情况。
如果配置了接口验证方式和验证密码,则对收到的Hello报文进行验证密码检查。
二层以太网接口视图/二层聚合接口视图
配置邻居关系验证方式和验证密码时如果没有配置本命令,则在发送的Hello报文中按照spbm authentication-mode命令指定的方式携带验证密码,并对收到的Hello报文进行验证密码的检查,只有通过检查后,才会形成邻居关系。当需要更改密码时,由于两台设备的密码更改操作不完全同步,导致瞬时的密码不一致、邻居关系中断。此时,可以通过配置不对收到的报文进行验证密码检查,保证邻居关系不中断。
# 配置不对接口GigabitEthernet1/0/1收到的Hello报文进行验证密码检查。
[Sysname-GigabitEthernet1/0/1] spbm authentication send-only
·     spbm authentication-mode
spbm authentication-mode命令用来配置邻居关系验证方式和验证密码。
undo spbm authentication-mode命令用来恢复缺省情况。
spbm authentication-mode { md5 | simple } { cipher cipher-string | plain plain-string }
没有配置邻居关系验证方式和验证密码,不进行邻居关系验证。
二层以太网接口视图/二层聚合接口视图
md5:MD5验证模式。
simple:简单验证模式。
plain:表示以明文的形式输入密码。
配置邻居关系验证方式和验证密码后,将在发送的Hello报文中按照设定的方式携带验证密码,并对收到的报文进行验证密码的检查。
·     两台SPBM设备要形成邻居关系必须在相应接口上配置相同的验证方式和验证密码。
# 在接口GigabitEthernet1/0/1上配置邻居关系采用简单验证模式,验证密码为123456,以明文形式输入密码。
[Sysname-GigabitEthernet1/0/1] spbm authentication-mode simple plain 123456
·     spbm authentication send-only
1.1.59  spbm cost
spbm cost命令用来配置SPBM的接口链路开销值。
undo spbm cost命令用来恢复缺省情况。
spbm cost value
undo spbm cost
自动计算链路开销值。
二层以太网接口视图/二层聚合接口视图
·     当接口链路开销值为16777215时,其邻居Up,但该邻居不承载流量。
·     当全局和接口同时配置链路开销值时,优先选择接口配置的链路开销值。
# 配置接口GigabitEthernet1/0/1的链路开销值为5。
[Sysname-GigabitEthernet1/0/1] spbm cost 5
1.1.60  spbm enable
spbm enable命令用来在当前接口上使能SPBM功能。
undo spbm enable命令用来恢复缺省情况。
spbm enable
undo spbm enable
SPBM功能在接口上处于关闭状态。
二层以太网接口视图/二层聚合接口视图
·     只需在BEB的上行口及BCB的接口上使能SPBM功能。
·     打开接口上SPBM功能后才可进行接口上其他SPBM相关配置。
·     关闭接口上SPBM功能时会删除该接口下所有SPBM相关配置。
# 在接口GigabitEthernet1/0/1上使能SPBM功能。
[Sysname-GigabitEthernet1/0/1] spbm enable
spbm timer hello命令用来配置Hello报文的发送时间间隔。
undo spbm timer hello命令用来恢复缺省情况。
spbm timer hello seconds
Hello报文的发送时间间隔为10秒。
二层以太网接口视图/二层聚合接口视图。
seconds:配置Hello报文的发送时间间隔,取值范围为3~255,单位为秒。
·     如果设备在邻居关系保持时间内(邻居关系保持时间=Hello报文失效数目×Hello报文的发送时间间隔)没有收到来自邻居设备的Hello报文时将宣告邻居关系失效。通过配置Hello报文失效数目和Hello报文的发送时间间隔,可以调整邻居关系保持时间,即设备要花多长时间能够监测到邻居关系已经失效并重新进行路由计算。
·     发送时间间隔越短,网络收敛越快,但同时会占用更多的带宽资源和设备资源,请根据实际情况进行配置。
·     邻居关系保持时间最大为65535秒。如果配置本命令后,计算出的邻居关系保持时间超过65535秒,则配置失败,配置前的Hello报文的发送时间间隔不做改变。
# 配置Hello报文在接口GigabitEthernet1/0/1上的发送时间间隔为20秒。
[Sysname-GigabitEthernet1/0/1] spbm timer hello 20
·     spbm timer holding-multiplier
spbm timer holding-multiplier命令用来配置Hello报文失效数目。
undo spbm timer holding-multiplier命令用来恢复缺省情况。
spbm timer holding-multiplier value
Hello报文失效数目为3。
二层以太网接口视图/二层聚合接口视图。
value:SPBM邻居的Hello报文失效数目,取值范围为3~1000。
·     Hello报文失效数目,即宣告邻居失效前没有收到的邻居Hello报文的数目。
·     如果设备在邻居关系保持时间内(邻居关系保持时间=Hello报文失效数目×Hello报文的发送时间间隔)没有收到来自邻居设备的Hello报文时将宣告邻居关系失效。通过配置Hello报文失效数目和Hello报文的发送时间间隔,可以调整邻居关系保持时间,即设备要花多长时间能够监测到链路已经失效并重新进行路由计算。
·     邻居关系保持时间最大为65535秒。如果配置本命令后,计算出的邻居关系保持时间超过65535秒,则配置失败,配置前的Hello报文失效数目不做改变。
# 指定接口GigabitEthernet1/0/1上Hello报文失效数目为6。
[Sysname-GigabitEthernet1/0/1] spbm timer holding-multiplier 6
·     spbm timer hello
spbm timer lsp命令用来配置发送LSP的最小时间间隔以及一次最多可以发送的LSP数目。
undo spbm timer lsp命令用来恢复缺省情况。
spbm timer lsp time [ count count ]
undo spbm timer lsp
发送LSP的最小时间间隔为33毫秒,一次最多发送5个LSP报文。
二层以太网接口视图/二层聚合接口视图
time:发送LSP的最小时间间隔,取值范围为1~1000,单位为毫秒。
count:一次最多可以发送的LSP数目,取值范围为1~1000。
当LSDB的内容发生变化时,SPBM将把发生变化的LSP扩散出去,用户可以对LSP的最小发送时间间隔以及一次可以最多发送的LSP数目进行调节。
当存在大量SPBM接口或大量路由时,会发送大量的LSP报文,导致LSP风暴的出现。在这种情况下,建议将LSP的发送时间间隔配置得稍大一些。
# 配置接口GigabitEthernet1/0/1发送LSP的最小发送时间间隔为500毫秒。
[Sysname-GigabitEthernet1/0/1] spbm timer lsp 500
1.1.64  spsource
spsource命令用来配置最短路径源标识。
undo spsource命令用来恢复缺省情况。
spsource spsource-id
undo spsource
最短路径源标识由SPBM自动分配。
SPBM视图
spsource-id:源标识,取值范围为1~1048575。
在SPBN中每台设备在每个实例中都会分配一个组播地址,该地址是由SPSource ID(Shortest Path Source Identifier,最短路径源标记)和I-SID拼装而成,其中,I-SID用来标记实例,SPSource ID用来区分同一实例中不同的设备。
在SPBN中SPSource ID可唯一标识一台设备,用户手工配置时需保证全网配置不冲突,即SPSource ID全网唯一。
# 配置最短路径源标识为100。
[Sysname] spbm
[Sysname-spbm] spsource 100
timer lsp-generation命令用来配置LSP重新生成的时间间隔。
undo timer lsp-generation命令用来恢复缺省情况
timer lsp-generation maximum-interval [ minimum-interval [ incremental-interval ] ]
LSP重新生成的最大时间间隔为2秒,最小时间间隔为10毫秒,时间间隔惩罚增量为10毫秒。
SPBM视图
maximum-interval:网络拓扑变化导致LSP重新生成时,LSP生成的最大时间间隔,取值范围为1~120,单位为秒。
minimum-interval:网络拓扑变化导致LSP重新生成时,LSP生成的最小时间间隔,取值范围为10~60000,单位为毫秒。
incremental-interval:网络拓扑变化导致LSP重新生成时,LSP生成的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒。
·     当网络拓扑发生变化,如邻居设备up或down,接口Metric值、System ID或区域地址发生变化等,将触发设备重新生成LSP。为了防止网络拓扑频繁变化而导致LSP频繁重新生成,用户可通过调节LSP重新生成的时间间隔,以抑制网络频繁变化可能导致的占用过多带宽资源和设备资源。
·     本命令在网络变化不频繁的情况下将LSP重新生成时间间隔缩小到minimum-interval,而在网络变化频繁的情况下可以进行相应惩罚,增加incremental-interval×2n-2(n为连续触发路由计算的次数),将等待时间按照配置的惩罚增量延长,最大不超过maximum-interval。
·     本命令中minimum-interval和incremental-interval的配置值不允许大于maximum-interval的配置值。
# 配置SPBM LSP重新生成的最大时间间隔为10秒,最小时间间隔为100毫秒,时间间隔惩罚增量为200毫秒。
[Sysname] spbm
[Sysname-spbm] timer lsp-generation 10 100 200
timer lsp-max-age命令用来配置当前设备生成的LSP在LSDB里的最大生存时间。
undo timer lsp-max-age命令用来恢复缺省情况。
timer lsp-max-age seconds
当前设备生成的LSP在LSDB里的最大生存时间为1200秒。
SPBM视图
seconds:LSP在LSDB里的最大生存时间,取值范围是1~65535,单位为秒。
每一个LSP都有一个最大生存时间,当生成一个LSP时,会将该LSP的最大生存时间作为LSP中的剩余生存时间告知其他LSDB,随着时间的推移,剩余生存时间将逐渐减小,当LSDB中一个LSP的剩余生存时间为0时,说明该LSP已失效,将从LSDB中删除该LSP的内容,只保留其摘要(保留60秒),并将该LSP的剩余生存时间置0后泛洪给其他LSDB以清除此LSP。用户可根据网络规模对LSP的最大生存时间进行调整。
# 配置当前设备生成的LSP在LSDB里的最大生存时间为25分钟,即1500秒。
[Sysname] spbm
[Sysname-spbm] timer lsp-max-age 1500
·     timer lsp-refresh
1.1.67  timer lsp-refresh
timer lsp-refresh命令用来配置LSP刷新周期。
undo timer lsp-refresh命令用来恢复缺省情况。
timer lsp-refresh seconds
LSP刷新周期为900秒。
SPBM视图
seconds:LSP在LSDB里的最大生存时间,取值范围是1~65534,单位为秒。
·     每一个LSP都有一个最大生存时间,每个LSP都会随着时间的推移而被逐渐老化,因此每台设备必须定时刷新自己生成的LSP,防止LSP的剩余生存时间减小为0。另外,通过定时刷新LSP,可以使整个区域中的LSP保持同步。用户可对LSP的刷新周期进行配置,通过提高LSP的刷新频率可以加快网络收敛速度,但同时会占用更多的带宽资源和设备资源,请根据实际情况进行配置。
·     timer lsp-refresh命令配置的时间必须小于timer lsp-max-age命令配置的时间,以保证在LSP失效前进行刷新。
# 配置当前系统的LSP刷新周期为1200秒。
[Sysname] spbm
[Sysname-spbm] timer lsp-refresh 1200
·     timer lsp-max-age
1.1.68  timer spf
timer spf命令用来配置SPBM路由计算的时间间隔。
undo timer spf命令用来恢复缺省情况。
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ]
undo timer spf
SPBM路由计算的最大时间间隔为5秒,最小时间间隔为10毫秒,时间间隔惩罚增量为10毫秒。
SPBM视图
maximum-interval:SPBM路由计算的最大时间间隔,取值范围为1~120,单位为秒。
minimum-interval:SPBM路由计算的最小时间间隔,取值范围为10~60000,单位为毫秒。
incremental-interval:SPBM路由计算的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒。
·     SPBM设备根据本地维护的LSDB,通过SPF算法计算出以自己为根的SPT,并根据这一SPT决定到目的网络的下一跳。通过调节SPF的计算间隔,可以抑制网络频繁变化可能导致的占用过多带宽资源和设备资源。
·     本命令在网络变化不频繁的情况下将连续路由计算的时间间隔缩小到minimum-interval,而在网络变化频繁的情况下可以进行相应惩罚,将等待时间按照配置的惩罚增量延长,最大不超过maximum-interval。
# 配置SPBM SPT树计算的最大时间间隔为10秒,最小时间间隔为100毫秒,惩罚增量为300毫秒。
[Sysname] spbm
[Sysname-spbm] timer spf 10 100 300
1.1.69  vsi
vsi命令用来创建一个VSI,并进入VSI视图。如果指定的VSI已经存在,则直接进入VSI视图。
undo vsi命令用来删除指定的VSI。
vsi vsi-name
undo vsi vsi-name
设备上不存在任何VSI。
vsi-name:VSI的名称,为1~31个字符的字符串,区分大小写。
# 创建名为test的VSI,并进入VSI视图。
[Sysname]vsi test
[Sysname-vsi-test]
·     display l2vpn vsi
1.1.70  xconnect vsi
xconnect vsi命令用来将以太网服务实例与VSI关联。
undo xconnect vsi命令用来取消以太网服务实例与VSI的关联。
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ]
undo xconnect vsi
以太网服务实例没有与VSI关联。
以太网服务实例视图
access-mode:指定接入模式。当关联VSI的AC为以太网服务实例时,接入模式缺省为VLAN。
ethernet:指定接入模式为Ethernet。
vlan:指定接入模式为VLAN。
在某个接口的以太网服务实例视图下执行本命令后,从该接口接收到的、符合以太网服务实例报文匹配规则的报文,将通过查找关联VSI的MAC地址表进行转发。
接入模式是BEB设备对从用户网络收到的以太网帧携带的外层VLAN Tag的理解方式,以及BEB设备向用户网络发送以太网帧的方式。接入模式分为两种:
·     VLAN接入模式:用户网络发送给BEB设备的以太网帧头需要带有一个VLAN Tag,该Tag被理解为P-Tag,即服务提供商网络为了区分用户而压入的“服务定界符”。BEB设备发送以太网帧给用户网络时,也需要携带P-Tag。
·     Ethernet接入模式:用户网络发送给BEB设备的以太网帧头中如果带有VLAN Tag,则该Tag被理解为用户网络的内部VLAN Tag,对于BEB设备没有意义。BEB设备发送以太网帧给用户网络时,不需要携带P-Tag。
·     在以太网服务实例下配置该命令前,必须先配置encapsulation命令。
# 接口GigabitEthernet1/0/1下采用以太网服务实例1来匹配外层VLAN Tag为100的报文,将该以太网服务实例与名为vpn1的VSI关联。
[Sysname-GigabitEthernet1/0/1] service-instance 1
[Sysname-GigabitEthernet1/0/1-srv1] encapsulation s-vid 100
[Sysname-GigabitEthernet1/0/1-srv1] xconnect vsi vpn1
·     vsi
