09-ACL和QoS命令参考
02-QoS命令
本章节下载: 02-QoS命令  (412.69 KB)
02-QoS命令
1 QoS策略
1.1 定义类的命令
1.1.1 display traffic classifier
1.1.2 if-match
1.1.3 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 nest top-most
1.2.6 packet-rate
1.2.7 primap pre-defined color
1.2.8 redirect
1.2.9 remark dot1p
1.2.10 remark drop-precedence
1.2.11 remark dscp
1.2.12 remark local-precedence
1.2.13 remark service-vlan-id
1.2.14 traffic behavior
1.3 定义策略和应用策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 control-plane management
1.3.4 display qos policy
1.3.5 display qos policy control-plane
1.3.6 display qos policy control-plane management
1.3.7 display qos policy control-plane management pre-defined
1.3.8 display qos policy control-plane pre-defined
1.3.9 display qos policy global
1.3.10 display qos policy interface
1.3.11 display qos vlan-policy
1.3.12 qos apply policy (interface view, control plane view, control plane management view)
1.3.13 qos apply policy global
1.3.14 qos policy
1.3.15 qos vlan-policy
1.3.16 reset qos policy control-plane
1.3.17 reset qos policy control-plane management
1.3.18 reset qos policy global
1.3.19 reset qos vlan-policy
2 优先级映射
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 display qos map-table color
2.1.3 import
2.1.4 qos map-table
2.1.5 qos map-table color
2.2 端口优先级配置命令
2.2.1 qos priority
2.3 端口优先级信任模式配置命令
2.3.1 display qos trust interface
2.3.2 qos trust
3 流量整形
3.1 流量整形配置命令
3.1.1 display qos gts interface
3.1.2 qos gts
4 硬件实现拥塞管理
4.1 加权公平队列配置命令
4.1.1 display qos queue wfq interface
4.1.2 qos bandwidth queue
4.1.3 qos wfq
4.1.4 qos wfq weight
4.2 队列调度策略配置命令
4.2.1 display qos qmprofile configuration
4.2.2 display qos qmprofile interface
4.2.3 qos apply qmprofile
4.2.4 qos qmprofile
4.2.5 queue
4.3 低时延队列调度模式配置命令
4.3.1 queue low-latency enable
5 全局CAR
5.1 全局CAR配置命令
5.1.1 car name
5.1.2 display qos car name
5.1.3 qos car
5.1.4 reset qos car name
6 报文统计配置命令
6.1 报文统计配置命令
6.1.1 display qos traffic-counter
6.1.2 qos traffic-counter
6.1.3 reset qos traffic-counter
7 端口队列统计
7.1 端口队列统计配置命令
7.1.1 display qos queue-statistics interface outbound
7.1.2 qos queue-statistics outbound
1 QoS策略
·     设备支持两种运行模式:独立运行模式和IRF模式,缺省情况为独立运行模式。有关IRF模式的介绍,请参见“虚拟化技术配置指导”中的“IRF”。
·     本文中提到的EB类单板、EC2类单板、FD类单板和FG类单板指的是丝印后缀分别为EB、EC2、FD、FG的单板。
·     本文中提到的ACL基本模式指的是ACL的一种硬件模式,关于ACL基本模式的详细介绍,请参见“ACL和QoS配置指导”中的“ACL”。
1.1  定义类的命令
display traffic classifier命令用来显示类的配置信息。
独立运行模式:
display traffic classifier user-defined  [ classifier-name ] [ slot slot-number ]
IRF模式:
display traffic classifier user-defined [ classifier-name ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定单板的流分类的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主用主控板的类的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的流分类的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示全局主用主控板的类的配置信息。(IRF模式)
# 显示用户定义类的配置信息。
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match not protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
表1-1 display traffic classifier命令显示信息描述表
用户自定义类的信息
Classifier
类的名字及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
1.1.2  if-match
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match match-criteria
undo if-match match-criteria
没有定义匹配数据包的规则。
类视图
not:不匹配该规则。
表1-2 类的匹配规则取值
取值
acl [ ipv6 ] { acl-number | name acl-name }
定义匹配ACL的规则
acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~5999,IPv6 ACL序号的取值范围是2000~3999和10000~42767
acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
如果QoS策略引用了匹配规则是用户自定义ACL的类,仅当该QoS策略应用在入方向时,用户自定义ACL才生效
当EB/EC2/FD类单板工作在ACL基本模式时,该类单板上应用的QoS策略不支持引用匹配规则为IPv6 ACL和用户自定义ACL的类
control-plane protocol protocol-name&<1-8>
定义匹配控制平面或者管理口控制平面协议的规则,protocol-name&<1-8>为系统预定义匹配协议报文类型名称的列表,具体如表1-3所示,&<1-8>表示前面的参数最多可以输入8次
当使用本字段定义匹配控制平面协议的规则时,此流分类中不能再定义其它匹配规则,并且此流分类对应的流行为下只能配置限速动作,即只能配置packet-rate命令
当使用本字段定义匹配管理口控制平面协议的规则时,此流分类中不能再定义其它匹配规则,并且此流分类对应的流行为下只能配置流量监管动作,即只能配置car命令
customer-dot1p dot1p-value&<1-8>
定义匹配带有双层VLAN Tag报文的内层802.1p优先级规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
在全局QoS策略和VLAN策略中,不支持配置本参数
当EB/EC2/FD类单板工作在ACL基本模式时,该类单板上应用的QoS策略不支持引用匹配规则中带有本参数的类
customer-vlan-id vlan-id-list
定义匹配带有双层VLAN Tag报文的内层VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
destination-mac mac-address
定义匹配目的MAC地址的规则
当EB/EC2/FD类单板工作在ACL基本模式时,该类单板入方向应用的QoS策略引用匹配规则中带有本参数的类,对IPv4报文不生效
当EB/EC2/FD类单板工作在ACL基本模式时,该类单板出方向应用的QoS策略引用匹配规则中带有本参数的类,对IPv4报文和IPv6报文不生效
当EB/EC2/FD类单板工作在ACL基本模式时,该类单板应用的QoS策略引用匹配规则中带有本参数的类,对ARP报文不生效
dscp dscp-value&<1-8>
定义匹配DSCP的规则,dscp-value&<1-8>为DSCP取值的列表,DSCP的取值范围为0~63,&<1-8>表示前面的参数最多可以输入8次;也可以输入关键字,具体如表1-5所示
forwarding-layer { bridge | route }
定义匹配转发报文的二、三层属性的规则:
·     bridge:只匹配二层转发报文
·     route:只匹配三层转发报文
inbound-interface interface-type interface-number
定义匹配入接口的规则,interface-type interface-number为接口类型和接口编号
·     该关键字仅能基于控制平面应用QoS策略
·     inbound-interface所指定的接口必须与qos apply policy所应用的控制平面所在的槽位一致,否则功能应用失败
·     当使用本字段时,此流分类对应的流行为下只能配置流量过滤动作或流量监管动作,即只能配置filter或car命令
ip-precedence ip-precedence-value&<1-8>
定义匹配IP优先级的规则,ip-precedence-value&<1-8>为IP优先级的列表,IP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
mpls-exp exp-value&<1-8>
定义匹配第一层MPLS EXP优先级的规则,exp-value&<1-8>为EXP的列表,EXP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
当EB/EC2/FD类单板工作在ACL基本模式时,该类单板出方向应用的QoS策略不支持引用匹配规则中带有本参数的类
mpls-label { label-value&<1-8> | label-value1 to label-value2 }
定义匹配第一层MPLS标签的规则,label-value&<1-8>为MPLS标签值的列表,&<1-8>表示前面的参数最多可以输入8次,label-value1 to label-value2表示一个MPLS标签的范围,label-value1的值必须小于label-value2的值,MPLS标签的取值范围为0~1048575
定义匹配协议的规则,protocol-name取值为arp、ip、ipv6
当EB/EC2/FD类单板工作在ACL基本模式时,该类单板上应用的QoS策略不支持引用匹配规则为ipv6协议的类
second-mpls-exp exp-value&<1-8>
定义匹配第二层MPLS EXP优先级的规则,exp-value&<1-8>为EXP的列表,EXP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
second-mpls-label { label-value&<1-8> | label-value1 to label-value2 }
定义匹配第二层MPLS标签的规则,label-value&<1-8>为MPLS标签值的列表,&<1-8>表示前面的参数最多可以输入8次,label-value1 to label-value2表示一个MPLS标签的范围,label-value1的值必须小于label-value2的值,MPLS标签的取值范围为0~1048575
service-dot1p dot1p-value&<1-8>
定义匹配报文外层VLAN Tag中的802.1p优先级规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
service-vlan-id vlan-id-list
定义匹配报文外层VLAN Tag中的VLAN ID规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
source-mac mac-address
定义匹配源MAC地址的规则
表1-3 系统预定义匹配协议报文类型名称的列表
报文类型
default
其他协议
arp
ARP协议
bgp
BGP协议
bgp4+
IPv6 BGP
dhcp
DHCP协议
dhcp-snooping
DHCP Snooping协议
dhcp6
IPv6 DHCP协议
dldp
DLDP协议
mvrp
MVRP协议
http
HTTP协议
https
HTTPS协议
icmp
ICMP协议
icmp6
IPv6 ICMP协议
igmp
IGMP协议
isis
IS-IS协议
lacp
LACP协议
ldp
LDP协议
lldp
LLDP协议
mld
MLD协议
ntp
NTP协议
oam
OAM协议
ospf-multicast
OSPF组播
ospf-unicast
OSPF单播
ospf3-multicast
OSPFv3组播
ospf3-unicast
OSPFv3单播
pim-multicast
PIM组播
pim-unicast
PIM单播
pim6-multicast
IPv6 PIM组播
pim6-unicast
IPv6 PIM单播
portal
PORTAL协议
radius
RADIUS协议
rip
RIP协议
ripng
RIPng协议
snmp
SNMP协议
stp
STP协议
tacacs
TACACS协议
udp-helper
UDP中继转发
vrrp
VRRP协议
ssh
SSH协议
telnet
TELNET协议
ftp
FTP协议
tftp
TFTP协议
在定义各个规则的时候,注意事项如下:
(1)     定义匹配ACL的规则
·     如果类中引用的ACL不存在,则不能在硬件中下发。
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。
·     如果类下的规则之间是逻辑或的关系,则该类允许通过ACL名称和序号的方式分别引用一次同一个ACL;如果类下的规则之间是逻辑与的关系,则该类允许通过ACL名称或序号的方式仅引用一次同一个ACL。
·     ACL规则中的deny表示匹配的报文不执行QoS策略中C-B对中的动作,ACL规则中的permit表示匹配的报文执行QoS策略中C-B对中的动作。
(2)     定义匹配目的MAC地址规则
·     匹配目的MAC地址规则只对以太网接口有意义。
(3)     定义匹配源MAC地址规则
·     匹配源MAC地址规则只对以太网接口有意义。
(4)     定义匹配DSCP的规则
·     一条命令可以配置多个DSCP值,最多可指定8个;如果指定了多个相同的DSCP值,系统默认为一个;多个不同的DSCP值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配DSCP的规则时,指定的所有DSCP值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(5)     定义匹配802.1p优先级的规则
·     一条命令可以配置多个802.1p优先级值,最多可指定8个;如果指定了多个相同的802.1p优先级值,系统默认为一个;多个不同的802.1p优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配802.1p优先级的规则时,指定的所有802.1p优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(6)     定义匹配IP优先级的规则
·     一条命令可以配置多个IP优先级值,最多可指定8个;如果指定了多个相同的IP优先级值,系统默认为一个;多个不同的IP优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配IP优先级的规则时,指定的所有IP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(7)     定义匹配MPLS EXP优先级的规则
·     一条命令可以配置多个MPLS EXP优先级值,最多可指定8个;如果指定了多个相同的MPLS EXP优先级值,系统默认为一个;多个不同的MPLS EXP优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配MPLS EXP优先级的规则时,指定的所有MPLS EXP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     MPLS EXP为MPLS报文特有的参数,该匹配规则仅对MPLS报文生效。
·     对于软转发QoS,MPLS报文不支持匹配IP相关匹配规则。
(8)     定义匹配MPLS Label的规则
·     一条命令可以配置多个MPLS Label值,如果指定了多个相同的MPLS Label值,系统默认为一个;多个不同的MPLS Label值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配MPLS Label的规则时,指定的所有MPLS Label值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(9)     定义匹配内层VLAN Tag和外层VLAN Tag VLAN ID的规则
·     一条命令可以配置多个VLAN ID值,如果指定了多个相同的VLAN ID值,系统默认为一个;多个不同的VLAN ID值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配VLAN ID的规则时,指定的所有VLAN ID值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID规则来匹配。
(10)     定义匹配预定义的上送控制平面或者管理口控制平面报文类型的规则
·     如果类下的规则之间是逻辑或的关系,则一条命令最多可以配置8个protocol值,如果指定了多个相同的protocol,系统默认为一个;多个不同的protocol是或的关系,即只要有一个值匹配,就算匹配这条规则。如果类下的规则之间是逻辑与的关系,则一条命令只能配置1个protocol值。
·     删除某条匹配protocol的规则时,指定的所有protocol必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     多个C-B对若设置同一种协议(同一个protocol值)的不同的限速值(通过packet-rate命令配置)时,生效的将是最小的限速值。
# 定义类class1的匹配规则为:匹配带有双层VLAN Tag报文的内层802.1p优先级为3。
# 定义类class1的匹配规则为:匹配报文外层VLAN Tag中的802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义类class1的匹配规则为:匹配DSCP值为1的报文。
[Sysname-classifier-class1] if-match dscp 1
# 定义类class1的匹配规则为:匹配IP优先级值为6的报文。
[Sysname-classifier-class1] if-match ip-precedence 6
# 定义类class1的匹配规则为:匹配本地优先级值为1的报文。
[Sysname-classifier-class1] if-match local-precedence 1
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配带有双层VLAN Tag报文的内层VLAN ID值为6的报文。
[Sysname-classifier-class1] if-match customer-vlan-id 6
# 定义类class1的匹配规则为:匹配报文外层VLAN Tag中VLAN ID值为7的报文。
[Sysname-classifier-class1] if-match service-vlan-id 7
# 在流分类class1中配置匹配MPLS-Label为1的报文类型。
[Sysname-classifier-class1] if-match mpls-label 1
# 在流分类class1中配置只匹配二层转发报文。
[Sysname-classifier-class1] if-match forwarding-layer bridge
# 在流分类class1中配置匹配上送控制平面或管理口控制平面的ARP协议报文。
[Sysname-classifier-class1] if-match control-plane protocol arp
traffic classifier命令用来定义一个类,并进入类视图。
undo traffic classifier命令用来删除一个类。
没有定义类。
operator:指定各规则之间的逻辑运算符。缺省情况为and。
# 定义一个名为class1的类。
·     display traffic classifier
1.2  定义流行为的命令
1.2.1  accounting
accounting命令用来配置流量统计动作。
undo accounting命令用来取消流量统计动作配置。
accounting { byte | packet }
undo accounting
没有配置流量统计动作。
流行为视图
byte:表示报文基于字节进行统计。
packet:表示报文基于包进行统计。此参数的配置,同时会影响CAR的统计单位。
# 为流行为配置流量统计动作,基于字节进行统计。
[Sysname-behavior-database] accounting byte
1.2.2  car
car命令用来配置流量监管动作。
undo car命令用来取消流量监管动作配置。
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ red action ]
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ red action ]
undo car
没有配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。流量的平均速率,取值范围为:1~100000000,单位为kbps。
cbs committed-burst-size:承诺突发尺寸,取值范围为1553~2147450880,单位为byte。设置的突发尺寸必须大于最大报文长度。缺省取值为500毫秒以CIR速率通过的流量,若该数值小于1553,则缺省值为1553。
ebs excess-burst-size:超出突发尺寸,单位为byte,取值范围为0~2147450880,缺省值为0。
pir peak information rate:峰值速率,取值范围为1~100000000,单位为kbps。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。
action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     接口上应用的策略中使用car时,可以应用到接口报文的接收或者发送方向。
·     如果多次使用该命令在同一个流行为上配置,最后一次配置生效。
·     如果配置了承诺突发尺寸(cbs),建议将该参数的取值设置为大于6.25倍的承诺信息速率(cir),以免影响网络突发流量。(此处不考虑单位,仅以配置值进行比较。)
# 为流行为配置流量监管。报文正常流速为200kbps,承诺突发尺寸为50000bytes,符合承诺速率时对数据包采取丢弃动作。
[Sysname-behavior-database] car cir 200 cbs 50000 red discard
display traffic behavior命令用来显示流行为的配置信息。
独立运行模式:
display traffic behavior user-defined  [ behavior-name ] [ slot slot-number ]
IRF模式:
display traffic behavior user-defined [ behavior-name ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定单板的流行为的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的流行为的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的流行为的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的流行为的配置信息。(IRF模式)
# 显示用户定义行为的配置信息。
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 7000 (Bytes), EBS 512 (Bytes)
        Red action    : discard
      Primap pre-defined color table: dot1p-lp
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Marking:
        Remark mpls-exp 4
      Redirecting:
        Redirect to the CPU
      Mirroring:
        Mirror to the VLAN: VLAN 1000
    Behavior: 3 (ID 102)
      -none-
表1-4 display traffic behavior命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名字及其内容,内容可以有多种类型
Marking
标记相关信息
Remark dscp
重新标记报文的DSCP优先级值
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为byte
EBS
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位为byte
Red action
对红色报文的动作
Primap color-map-dp
根据报文颜色标记丢弃优先级的映射表
预定义带颜色映射表相关信息。对于带颜色映射表的描述可以参考2.1  优先级映射表配置命令
Accounting enable
流量统计动作
Filter enable
流量过滤动作
Remark mpls-exp
重新标记报文的EXP优先级值
Redirecting
流量重定向相关信息
Mirroring
流量镜像相关信息
none
表示没有配置其他流行为
1.2.4  filter
filter命令用来配置流量过滤动作。
undo filter命令用来取消流量过滤动作配置。
filter { deny | permit }
undo filter
没有配置流量过滤动作。
流行为视图
deny:丢弃数据包。
permit:允许数据包通过。
# 为流行为配置丢弃数据包的过滤动作。
1.2.5  nest top-most
nest top-most命令用来配置添加VLAN Tag的动作。
undo nest top-most命令用来取消添加VLAN Tag的动作。
nest top-most vlan vlan-id
undo nest top-most
没有配置添加VLAN Tag的动作。
流行为视图
vlan vlan-id:添加的VLAN ID,取值范围为1~4094。
·     引用了添加VLAN Tag动作的QoS策略只能应用到接口的入方向上。
·     在同一个流行为上多次配置本命令,新配置将覆盖旧配置。
# 在流行为b1上配置如下动作:添加VLAN ID为123的VLAN Tag。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
1.2.6  packet-rate
packet-rate命令用来为流行为配置限速动作。
undo packet-rate命令用来取消配置的限速动作。
packet-rate value
undo packet-rate
流行为视图
value:协议报文速率,单位为包每秒(pps)。取值范围为1~1048575。
通过限速可以对进入CPU的协议报文速率进行限制,保证CPU的正常运转, 防止遭受协议报文攻击。
# 为流行为copp配置CPU报文限速动作。
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
primap pre-defined color命令用来配置流行为中的动作为使用相应的带颜色优先级映射表为报文获取其他的优先级参数。
undo primap pre-defined color命令用来取消流行为中的使用相应的带颜色优先级映射表为报文映射优先级的动作。
primap pre-defined color { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
undo primap pre-defined color { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
没有配置流优先级映射动作。
流行为视图
pre-defined:预先定义的优先级映射表。
color:使用带颜色优先级映射表做映射。
dot1p-dot1p:802.1p优先级到802.1p优先级映射表。
dot1p-dp:802.1p优先级到丢弃优先级映射表。
dot1p-dscp:802.1p优先级到DSCP映射表。
dot1p-exp:802.1p优先级到EXP映射表。
dot1p-lp:802.1p优先级到本地优先级映射表。
dscp-dot1p:DSCP到802.1p优先级映射表。
dscp-dp:DSCP到丢弃优先级映射表。
dscp-dscp:DSCP到DSCP映射表。
dscp-exp:DSCP到EXP映射表。
dscp-lp:DSCP到本地优先级映射表。
exp-dot1p:EXP到802.1p优先级映射表。
exp-dp:EXP到丢弃优先级映射表。
exp-dscp:EXP到DSCP映射表。
exp-exp:EXP到EXP映射表。
exp-lp:EXP到本地优先级映射表。
本命令需要和CAR结合在一起使用。
# 使用带颜色的DSCP到丢弃优先级映射表为报文获取丢弃优先级参数。
[Sysname-behavior-behavior1] car cir 1600
[Sysname-behavior-behavior1] primap pre-defined color dscp-dp
·     display qos map-table color
1.2.8  redirect
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来取消流量重定向动作配置。
redirect { cpu | interface interface-type interface-number [ track-oap ] [ vlan vlan-id ] }
undo redirect { cpu | interface interface-type interface-number }
没有配置流量重定向动作。
流行为视图
cpu:重定向到CPU。
interface:重定向到指定的接口。
interface-type interface-number:指定接口类型和接口编号,仅支持重定向到二层以太网接口或二层聚合接口。
track-oap:重定向到接口的行为需要关心OAP client的状态。
vlan vlan-id:对重定向到接口的报文封装的VLAN。vlan-id为封装的VLAN ID,取值范围为1~4094。
·     在配置重定向动作时,同一个流行为中重定向类型只能为重定向到CPU、重定向到接口中的一种,以最后一次配置为准。
·     配置track-oap后,设备会先检测是否存在OAP Client,若不存在OAP Client,则不会执行重定向动作至指定的接口;若存在OAP Client,则直接执行重定向动作至指定的接口。
·     在IRF模式下,设备不支持将流量重定向到聚合接口。
·     在IRF模式下,设备不支持跨框(即流量的出接口和入接口位于两台不同的成员设备上)将流量重定向到除OAP单板以外的接口上。
# 为流行为配置流量重定向动作,重定向到接口GigabitEthernet3/0/1。
[Sysname-behavior-database] redirect interface gigabitethernet3/0/1
·     classifier behavior
·     qos policy
·     traffic behavior
1.2.9  remark dot1p
remark dot1p命令用来重新标记报文的802.1p优先级。
undo remark dot1p命令用来取消标记报文的802.1p优先级。
remark dot1p dot1p-value
undo remark dot1p
没有配置重新标记报文的动作。
流行为视图
dot1p-value:802.1p优先级,取值范围为0~7。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence命令用来重新标记报文的丢弃优先级。
undo remark drop-precedence命令用来恢复缺省情况。
remark drop-precedence drop-precedence-value
没有配置重新标记报文的动作。
流行为视图
drop-precedence-value:丢弃优先级,取值范围为0~2。
本命令仅应用在入方向。
# 重新标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.11  remark dscp
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来取消标记报文的DSCP值。
remark dscp dscp-value
undo remark dscp
没有配置重新标记报文的动作。
流行为视图
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
表1-5 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
# 重新标记报文的DSCP值为6。
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来取消标记报文的本地优先级。
remark local-precedence local-precedence-value
没有配置重新标记报文的动作。
流行为视图
local-precedence-value:本地优先级,取值范围为0~7。
# 重新标记报文的本地优先级值为2。
remark service-vlan-id命令用来重标记报文的SVLAN。
undo remark service-vlan-id命令用来取消重标记报文的SVLAN。
没有配置重新标记报文的动作。
流行为视图
vlan-id:表示重标记报文外层VLAN(SVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重标记报文的SVLAN为VLAN 222。
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior命令用来定义一个流行为,并进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
没有定义流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
# 定义一个名为behavior1的流行为。
·     display traffic behavior
1.3  定义策略和应用策略的命令
classifier behavior命令用来为类指定流行为。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [ mode dcbx ]
没有为类指定流行为。
策略视图
mode dcbx:表示该策略为DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议)模式。有关DCBX的介绍,请参见“二层技术-以太网交换配置指导”中的“LLDP”。
·     策略下每个类只能与一个流行为关联。
·     如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
# 在策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
·     qos policy
1.3.2  control-plane
control-plane命令用来进入控制平面视图。
独立运行模式:
IRF模式:
control-plane chassis chassis-number slot slot-number
slot slot-number:指定单板。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 进入3号板控制平面视图。(独立运行模式)
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
# 进入1号成员设备3号板控制平面视图。(IRF模式)
[Sysname] control-plane chassis 1 slot 3
[Sysname-cp-chassis1-slot3]
control-plane management命令用来进入管理口控制平面视图。
# 进入管理口控制平面视图。
[Sysname] control-plane management
[Sysname-cp-management]
display qos policy命令用来显示QoS策略的配置信息。
独立运行模式:
IRF模式:
display qos policy user-defined [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义策略。
policy-name:策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定单板的策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的QoS策略的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板的QoS策略的配置信息。(IRF模式)
# 显示用户定义策略的配置信息。
  User Defined QoS Policy Information:
Policy: qpolicy (ID 100)
   Classifier: tc1 (ID 0)
     Behavior: tb1
      Marking:
        Remark dot1p 5
        CIR 1000 (kbps), CBS 100000 (Bytes), EBS 0 (Bytes)
        Red action: discard
表1-6 display qos policy命令显示信息描述表
User-defined QoS policy information
用户自定义策略的信息
Policy
策略名
其它显示信息解释请参见表1-1和表1-4。
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
独立运行模式:
IRF模式:
display qos policy control-plane chassis chassis-number slot slot-number
slot slot-number:显示指定单板的控制平面应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的控制平面应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 显示对进入3号板控制平面的报文应用的QoS策略信息。
<Sysname> display qos policy control-plane slot 3
Control plane slot 3
  Direction: Inbound
  Policy: 1
   Classifier: 2
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 2
        CIR 128 (kbps), CBS 8000 (Bytes), EBS 0 (Bytes)
        Red Action    : discard
        Green :12928(Bytes)
        Yellow:7936(Bytes)
        Red   :43904(Bytes)
表1-7 display qos policy control-plane命令显示信息描述表
Control-plane
控制平面
Direction
对进入控制平面(Inbound)的报文应用QoS策略
Policy
策略名称及其内容
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
流行为的名称及其内容,内容可以有多种类型
流量限速的相关信息
CIR
承诺信息速率,单位是kbps
CBS
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位是byte
EBS
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位是byte
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
display qos policy control-plane management命令用于显示管理口控制平面应用的QoS策略信息。
# 显示对进入管理口控制平面的报文应用的QoS策略信息。
<Sysname> display qos policy control-plane management
Control plane management
  Direction: Inbound
  Policy: test
   Classifier: test
     Operator: AND
     Rule(s) :
      If-match control-plane protocol arp
     Behavior: test
        CIR 8 (kbps), CBS 1553 (Bytes), EBS 0 (Bytes)
        Red packets   : 0 (Packets) 0 (Bytes)
表1-8 display qos policy control-plane management命令显示信息描述表
Control-plane
控制平面
Direction
对进入管理口控制平面(Inbound)的报文应用QoS策略
Policy
策略名称及其内容
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
流量限速的相关信息
CIR
承诺信息速率,单位是kbps
CBS
EBS
Red Action
对红色报文的动作
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
display qos policy control-plane management pre-defined命令用来显示系统预定义的管理口控制平面应用QoS策略的信息。
# 显示系统预定义的管理口控制平面应用QoS策略的信息。
<Sysname> display qos policy control-plane management pre-defined
Pre-defined policy information
  Protocol          Priority   Bandwidth (kbps)   Group
  Default           N/A        100000             N/A
  ARP               N/A        100000             normal
  BGP               N/A        100000             critical
  BGPv6             N/A        100000             critical
  HTTP              N/A        100000             management
  HTTPS             N/A        100000             management
  ICMP              N/A        100000             monitor
  ICMPv6            N/A        100000             monitor
  OSPF Multicast    N/A        100000             critical
  OSPF Unicast      N/A        100000             critical
  OSPFv3 Multicast  N/A        100000             critical
  OSFPv3 Unicast    N/A        100000             critical
  PIM Multicast     N/A        100000             critical
  PIM Unicast       N/A        100000             critical
  PIMv6 Multicast   N/A        100000             critical
  PIMv6 Unicast     N/A        100000             critical
  RADIUS            N/A        100000             management
  RIP               N/A        100000             critical
  RIPng             N/A        100000             critical
  SNMP              N/A        100000             management
  SSH               N/A        100000             management
  TELNET            N/A        100000             management
  FTP               N/A        100000             management
  TFTP              N/A        100000             management
表1-9 display qos policy control-plane management pre-defined命令显示信息描述表
Pre-defined control plane policy management
预定义管理口控制平面策略内容
Protocol
系统预定义协议报文类型
Priority
优先级
Bandwidth
带宽
Group
协议组(产品暂不支持)
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
独立运行模式:
IRF模式:
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的系统预定义的控制平面策略信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number:显示指定成员设备上指定单板的系统预定义的控制平面策略信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
·     如果不指定槽位号,则显示所有在位单板的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
·     如果不指定成员编号和槽位号,则显示所有成员设备上在位单板的系统预定义的控制平面应用QoS策略的信息。(IRF模式)
# 显示3号板系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
<Sysname> display qos policy control-plane pre-defined slot 3
Pre-defined control plane policy slot 3
Protocol          Priority   Bandwidth (pps)    Group
  ARP               2          1000               normal
  BGP               5          400                critical
  DHCP              0          600                normal
  DHCP Snooping     0          600                redirect
  DHCPv6            0          600                normal
  DLDP              7          100                critical
  MVRP              7          100                critical
  ICMP              6          500                monitor
  ICMPv6            6          500                monitor
  IGMP              3          2048               important
  IS-IS             5          1500               critical
  LACP              7          100                critical
  LDP               4          600                critical
  LLDP              7          200                important
  MLD               3          500                important
  NTP               4          200                important
  OAM               7          100                critical
  OSPF Multicast    5          1500               critical
  OSPF Unicast      5          1000               critical
  PIM Multicast     4          2500               critical
  PIM Unicast       4          2000               critical
  PORTAL            1          200                management
  RIP               5          300                critical
  RIPng             5          300                critical
  SNMP              1          200                management
  STP               7          200                critical
  TACACS            4          300                management
  UDP Helper        3          500                redirect
  VRRP              4          2500               important
  TELNET            4          700                management
# 显示1号成员设备3号单板系统预定义的控制平面应用QoS策略的信息。(IRF模式)
<Sysname> display qos policy control-plane pre-defined chassis 1 slot 3
Pre-defined control plane policy chassis 1 slot 3
  ARP               2          1000               normal
  BGP               5          400                critical
  DHCP              0          600                normal
  DHCPv6            0          600                normal
  DLDP              7          100                critical
  MVRP              7          100                critical
  ICMP              6          500                monitor
  LACP              7          100                critical
  LDP               4          600                critical
  MLD               3          500                important
  NTP               4          200                important
  OAM               7          100                critical
  RIP               5          300                critical
  STP               7          200                critical
表1-10 display qos policy control-plane pre-defined命令显示信息描述表
预定义控制平面策略内容
Protocol
系统预定义协议报文类型
Priority
优先级
Bandwidth
带宽
Group
协议组(产品暂不支持)
display qos policy global命令用来显示基于全局应用QoS策略的信息。
独立运行模式:
IRF模式:
display qos policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
inbound:显示对全局接收到的报文应用QoS策略的信息。
outbound:显示对全局发送的报文应用QoS策略的信息。
slot slot-number:显示指定单板的基于全局应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于全局应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
·     如果未指定显示方向,则同时显示出入两个方向基于全局应用QoS策略的信息。
·     如果未指定槽位号,则显示主控板上基于全局应用QoS策略的信息,不显示各单板的信息。(独立运行模式)
·     如果未指定成员编号和槽位号,则显示全局主控板上基于全局应用QoS策略的信息,不显示各单板的信息。(IRF模式)
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global inbound
  Direction: Inbound
Policy: qpolicy
   Classifier: tc1
     Operator: AND
     Rule(s) : If-match acl 2000
     Behavior: tb1
      Marking:
        Remark dot1p 5
        Red action: discard
表1-11 display qos policy global命令显示信息描述表
Direction
对接收到(Inbound)/发送(Outbound)的报文应用QoS策略
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的配置信息和运行情况。
inbound:显示对接口接收到的报文应用QoS策略的信息。
outbound:显示对接口发送的报文应用QoS策略的信息。
如果未指定显示方向,则同时显示出入两个方向接口上应用QoS策略的配置信息和运行情况。
# 显示对接口GigabitEthernet3/0/1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface gigabitethernet 3/0/1 inbound
Interface: GigabitEthernet3/0/1
  Direction: Inbound
  Policy: qpolicy
   Classifier: tc1
     Operator: AND
     Behavior: tb1
      Marking:
        Remark dot1p 5
        Red action: discard
表1-12 display qos policy interface命令显示信息描述表
Direction
Policy应用在接口的方向
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的信息。
独立运行模式:
IRF模式:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称,为1~31个字符的字符串,区分大小写。
vlan vlan-id:显示指定VLAN上应用QoS策略的信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
inbound:显示对VLAN接收到的报文应用的QoS策略信息。
outbound:显示对VLAN发送的报文应用的QoS策略信息。
slot slot-number:显示指定单板上基于VLAN应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于VLAN应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
·     如果未指定显示方向,则同时显示出入两个方向基于VLAN应用QoS策略的信息。
·     如果未指定槽位号,则显示设备上所有基于VLAN应用QoS策略的信息。(独立运行模式)
·     如果未指定成员编号和槽位号,则显示设备上所有基于VLAN应用QoS策略的信息。(IRF模式)
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Inbound
  Policy: qpolicy
   Classifier: tc1
     Operator: AND
     Behavior: tb1
      Marking:
        Remark dot1p 5
        Red action: discard
表1-13 display qos vlan-policy命令显示信息描述表
Direction
对VLAN接收到(Inbound)/发送(Outbound)的报文应用QoS策略
qos apply policy命令用来在接口或控制平面或管理口控制平面上应用QoS策略。
undo qos apply policy命令用来取消接口或控制平面或管理口控制平面上应用的QoS策略。
undo qos apply policy policy-name { inbound | outbound }
没有在接口或控制平面或管理口控制平面上应用QoS策略。
接口视图/控制平面/管理口控制平面视图
inbound:对接口或控制平面或管理口控制平面接收到的报文应用QoS策略。
outbound:对接口发送的报文应用QoS策略。在控制平面或管理口控制平面视图下设备不支持此关键字。
·     VLAN接口和聚合接口暂不支持应用QoS策略。
·     在将QoS策略应用在IRF端口所在槽位单板控制平面时,如果在此QoS策略对应的流分类包含的二层ACL中定义了匹配所有的报文的规则(即配置rule permit命令),那么请不要在对应的流行下配置流量监管(即car cir命令)或配置丢弃数据包(即filter deny命令)功能,否则可能导致IRF分裂,影响设备正常使用。
# 将策略USER1应用到接口GigabitEthernet3/0/1的出方向上。
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] qos apply policy USER1 outbound
# 对进入3号槽控制平面的报文应用策略aaa。
[Sysname-cp-slot3] qos apply policy aaa inbound
# 对进入管理口控制平面的报文应用策略bbb。
[Sysname-cp-management] qos apply policy bbb inbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
undo qos apply policy policy-name global { inbound | outbound }
没有在全局应用QoS策略。
inbound:对设备所有端口接收到的流量应用QoS策略。
outbound:对设备所有端口发送的流量应用QoS策略。
·     全局应用的QoS策略对全部流量生效。
·     基于全局应用的QoS策略需要下发到所有接口板,如果遇到某个接口板硬件资源不足等情况,会导致策略在该接口板下发失败。此时主控板及其它接口不回退该策略的配置,需要用户手工将该策略的相关配置清除。类似地,动态修改过程中,如果基于全局应用的QoS策略在某个接口板刷新时遇到硬件资源不足等情况,下发失败,也需要用户手工将该策略的配置清除。
# 将名为user1的策略应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
1.3.14  qos policy
qos policy命令用来定义一个策略,并进入策略视图。
undo qos policy命令用来删除一个策略。
qos policy policy-name
undo qos policy policy-name
没有定义策略。
如果该策略已经被应用,则不允许删除该策略,需要先在应用的位置上取消对该策略的应用,然后再使用undo qos policy命令删除该策略。
# 定义一个名为user1的策略。
·     qos apply policy
·     qos apply policy global
·     qos vlan-policy
qos vlan-policy命令用来在指定VLAN上应用QoS策略。
undo qos vlan-policy命令用来取消指定VLAN上应用的QoS策略。
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
没有在指定VLAN上应用QoS策略。
policy-name:策略名称,为1~31个字符的字符串,区分大小写。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:对VLAN接收到的报文应用QoS策略。
outbound:对VLAN发送的报文应用QoS策略。
基于VLAN的QoS策略需要下发到所有接口板,如果遇到某个接口板硬件资源不足等情况,会导致策略在该接口板下发失败。此时主控板及其它接口不回退该策略的配置,需要用户手工将该策略的相关配置清除。类似地,动态修改过程中,如果基于VLAN的QoS策略在某个接口板刷新时遇到硬件资源不足等情况,下发失败,也需要用户手工将该策略的配置清除。
# 在VLAN 200、300、400、500的入方向上应用VLAN策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
独立运行模式:
IRF模式:
reset qos policy control-plane chassis chassis-number slot slot-number
slot slot-number:清除指定单板的基于控制平面应用QoS策略的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number:清除指定成员设备上指定单板的基于控制平面应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 清除应用到3号板进入控制平面方向的QoS策略统计信息。(独立运行模式)
<Sysname> reset qos policy control-plane slot 3
# 清除应用到1号成员设备3号板控制平面的QoS策略统计信息。(IRF模式)
<Sysname> reset qos policy control-plane chassis 1 slot 3
reset qos policy control-plane management命令用来清除管理口控制平面QoS策略的统计信息。
# 清除管理口控制平面QoS策略的统计信息。
<Sysname> reset qos policy control-plane management
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
inbound:清除全局接收到的报文应用QoS策略的统计信息。
outbound:清除全局发送的报文应用QoS策略的统计信息。
如果不指定方向,则同时清除出入两个方向全局应用的QoS策略的统计信息。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
vlan vlan-id:指定VLAN。vlan-id为指定VLAN的ID号,取值范围为1~4094。
inbound:清除VLAN接收到的报文应用QoS策略的统计信息。
outbound:清除对VLAN发送的报文应用QoS策略的统计信息。
如果不指定方向,则同时清除出入两个方向VLAN应用的QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射
2.1  优先级映射表配置命令
display qos map-table命令用来显示指定优先级映射表配置情况。
display qos map-table [ inbound [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-lp ] ]
inbound:接收报文方向。
表2-1 优先级映射表
优先级映射
dot1p-dot1p
dot1p-dp
802.1p优先级到丢弃优先级映射表
dot1p-dscp
802.1p优先级到DSCP映射表
dot1p-exp
802.1p优先级到EXP映射表
dot1p-lp
802.1p优先级到本地优先级映射表
dscp-dot1p
DSCP到802.1p优先级映射表
dscp-dp
DSCP到丢弃优先级映射表
dscp-dscp
DSCP到DSCP映射表
dscp-exp
DSCP到EXP映射表
dscp-lp
DSCP到本地优先级映射表
exp-dot1p
EXP到802.1p优先级映射表
exp-dp
EXP到丢弃优先级映射表
exp-dscp
EXP到DSCP映射表
exp-lp
EXP到本地优先级映射表
·     如果未指定表的类型,将显示所有映射表的配置情况。
·     如果未指定任何参数,即display qos map-table命令将显示所有映射表(以及带颜色映射表)的配置情况。
# 显示接收报文方向802.1p优先级到本地优先级映射表的配置信息。
<Sysname> display qos map-table inbound dot1p-lp
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define   DIRECTION: inbound
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名字
TYPE
映射表的类型
DIRECTION
映射表的方向
IMPORT
映射表的输入值
EXPORT
映射表的输出值
display qos map-table color命令用来显示指定带颜色优先级映射表配置情况。
display qos map-table color [ green | yellow | red ] { inbound [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp ] | outbound [ dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp ] }
green:绿色报文。
yellow:黄色报文。
red:红色报文。
inbound:接收报文方向。
outbound:发送报文方向。
表2-3 优先级映射表
优先级映射
dot1p-dot1p
dot1p-dp
802.1p优先级到丢弃优先级映射表
dot1p-dscp
802.1p优先级到DSCP映射表
dot1p-exp
802.1p优先级到EXP映射表
dot1p-lp
802.1p优先级到本地优先级映射表
dscp-dot1p
DSCP到802.1p优先级映射表
dscp-dp
DSCP到丢弃优先级映射表
dscp-dscp
DSCP到DSCP映射表
dscp-exp
DSCP到EXP映射表
dscp-lp
DSCP到本地优先级映射表
exp-dot1p
EXP到802.1p优先级映射表
exp-dp
EXP到丢弃优先级映射表
exp-dscp
EXP到DSCP映射表
exp-exp
EXP到EXP映射表
exp-lp
EXP到本地优先级映射表
经过流量监管处理的报文被分成了三种颜色(绿色、黄色、红色),为了对不同颜色报文进行优先级映射,设备提供了多张带颜色优先级映射表,分别对应相应颜色的优先级映射关系。流量监管对报文处理的相关内容请参见流量监管章节内容。
·     如果未指定表的类型,将显示所有带颜色映射表的配置情况。
·     如果未指定颜色,将显示所有颜色的带颜色映射表的配置情况。
# 显示绿色报文的接收报文方向的EXP到本地优先级映射表的配置信息。
<Sysname> display qos map-table color green inbound exp-lp
MAP-TABLE NAME: exp-lp   TYPE: pre-define   COLOR: green   DIRECTION: inbound
IMPORT  :  EXPORT
   0    :    0
   1    :    1
   2    :    2
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-4 display qos map-table color命令显示信息描述表
MAP-TABLE NAME
映射表的名字
TYPE
映射表的类型
COLOR
映射表的颜色
DIRECTION
映射表的方向
IMPORT
映射表的输入值
EXPORT
映射表的输出值
2.1.3  import
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 B。
优先级映射表视图
import-value-list:输入值列表。
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
# 在接收报文方向上,配置802.1p优先级到丢弃优先级映射表的映射关系,与802.1p优先级4、5相对应的丢弃优先级为1。
[Sysname] qos map-table inbound dot1p-dp
[Sysname-maptbl-in-dot1p-dp] import 4 5 export 1
2.1.4  qos map-table
qos map-table { inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-lp } }
inbound:接收报文方向。
其它参数请参见表2-1。
# 进入接收报文方向的802.1p优先级到丢弃优先级映射表视图。
·     import
qos map-table color命令用来进入指定的带颜色优先级映射表视图。
qos map-table color { green | yellow | red } { inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp } | outbound { dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp } }
green:绿色报文。
yellow:黄色报文。
red:红色报文。
inbound:接收报文方向。
outbound:发送报文方向。
其它参数请参见表2-3。
# 进入红色报文的接收报文方向的DSCP到本地优先级映射表视图。
[Sysname] qos map-table color red inbound dscp-lp
[Sysname-maptbl-red-in-dscp-lp]
·     import
2.2  端口优先级配置命令
2.2.1  qos priority
qos priority命令用来配置当前端口的端口优先级。
undo qos priority命令用来恢复端口优先级为缺省值。
qos priority { dot1p | dp | dscp | exp | lp } priority-value
undo qos priority { dot1p | dp | dscp | exp | lp }
lp类型优先级的缺省值为2,dp类型优先级的缺省值为0,其余类型优先级没有缺省值。
priority-value:端口优先级值。各优先级的取值范围如表2-5所示。
表2-5 各种端口优先级取值范围
端口优先级类型
priority-value取值范围
dot1p(802.1p优先级)
0~7
dscp(DSCP优先级)
0~63
exp(EXP优先级)
0~7
dp(丢弃优先级)
0~2
丢弃优先级值越大的报文越被优先丢弃
lp(本地优先级)
0~7
本地优先级值越大的报文,进入的队列优先级越高,从而能够获得优先的调度
不同类型的端口优先级可以同时在同一个接口上配置,同一种类型的端口优先级配置采用覆盖方式。
# 配置接口GigabitEthernet3/0/1的DSCP优先级为20。
[Sysname-GigabitEthernet3/0/1] qos priority dscp 20
·     display qos trust interface
2.3  端口优先级信任模式配置命令
display qos trust interface命令用来显示当前配置的端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示当前配置的端口优先级信任模式信息。
<Sysname> display qos trust interface GigabitEthernet 3/0/1
Port priority information
  Port dot1p priority: -
  Port dp priority: 0
  Port dscp priority: -
  Port exp priority: -
  Port lp priority: 2
  Port priority trust type: none,  Override: disable
表2-6 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
Port priority trust information
端口优先级信任信息
Port dot1p priority
端口802.1p优先级
Port dscp priority
端口DSCP优先级
Port dp priority
端口丢弃优先级
Port exp priority
端口EXP优先级
Port lp priority
端口本地优先级
端口优先级信任类型,取值为:
·     auto:根据报文的类型,自动提取报文中的优先级字段
·     dot11e:dot11e优先级
·     dot1p:802.1p优先级
·     dscp:DSCP优先级
·     exp:EXP优先级
·     none:不信任任何优先级
Override
是否以报文自带的信任优先级值进行优先级映射
2.3.2  qos trust
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { auto | dot1p | dscp | exp } [ override ]
undo qos trust
缺省情况下,信任接收端口的端口优先级。
auto:表示根据报文的类型,自动提取报文中的优先级字段进行优先级映射。对于非IP报文,采用802.1p优先级;对于IP报文,采用DSCP优先级;对于MPLS报文,采用EXP。
exp:信任MPLS报文自带的EXP,以此优先级进行优先级映射。
override:表示先映射信任的优先级,然后根据该优先级映射后的值进行其它优先级的映射,缺省为以报文自带的信任优先级值进行优先级映射。本参数不支持exp。
# 在接口GigabitEthernet3/0/1上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname-GigabitEthernet3/0/1] qos trust dot1p
3 流量整形
3.1  流量整形配置命令
display qos gts interface命令用来显示接口的流量整形配置情况和统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量整形配置情况和统计信息。
# 显示所有接口的流量整形配置情况和统计信息。
Interface : GigabitEthernet3/0/1
 Rule: If-match any
表3-1 display qos gts命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成
Rule
匹配规则
CIR
承诺信息速率,单位为kbps
CBS
3.1.2  qos gts
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
qos gts { any | queue queue-id } cir committed-information-rate [ cbs committed-burst-size ]
undo qos gts { any | queue queue-id }
接口上没有配置流量整形。
any:对所有的数据包进行流量整形。
queue queue-id:对队列queue上的数据包进行流量整形,queue-id为匹配的队列号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位是kbps。对于GE接口,取值范围1000~1000000;对于10GE接口,取值范围2500~10000000;对于40GE接口,取值范围1000~40000000;对于100GE接口,取值范围1000~100000000。
cbs committed-burst-size:承诺突发尺寸,取值范围16384~16777215,单位是byte。cbs缺省取值为500毫秒以CIR速率通过的流量。
# 在接口GigabitEthernet3/0/1上对所有数据包进行流量整形。正常流速为1200kbps,突发流量为50000bytes。
[Sysname-GigabitEthernet3/0/1] qos gts any cir 1200 cbs 50000
4 硬件实现拥塞管理
4.1  加权公平队列配置命令
display qos queue wfq interface命令用来显示指定接口或所有接口上的加权公平队列配置情况和统计信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的加权公平队列配置情况和统计信息。
# 显示接口GigabitEthernet2/0/1的加权公平队列配置情况和统计信息。
<Sysname> display qos queue wfq interface gigabitethernet 2/0/1
Interface: GigabitEthernet2/0/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Weight          Min-Bandwidth
 be              2               40
 af1             1               40
 af2             1               40
 af3             1               40
 af4             1               40
 ef              1               40
 cs6             1               40
 cs7             1               40
表4-1 display qos queue wfq interface命令显示信息描述表
Output queue
当前出队列类型
Queue ID
队列号
Weight
调度时各个队列的权重
Min-Bandwidth
队列的最小保证带宽值,单位是kbps
qos bandwidth queue命令用来配置端口队列的最小带宽保证。
undo qos bandwidth queue命令用来恢复缺省情况。
undo qos bandwidth queue queue-id
WFQ队列的最小带宽保证值为40kbps。
queue-id:队列序号。可以使用数字或关键字表示,两者对应关系请参见表4-2。
表4-2 队列参数描述表
关键字
队列号(十进制)
af1
1
af2
2
af3
3
af4
4
be
0
cs6
6
cs7
7
ef
5
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。
·     对于GE接口,取值范围为40~1000000;
·     对于10GE接口,取值范围为40~10000000;
·     对于40GE接口,取值范围为40~40000000;
·     对于100GE接口,取值范围为40~100000000。
·     必须先使用qos wfq命令在接口上使能WFQ队列,然后才能进行本配置。
·     在同一接口用qos bandwidth queue queue-number min bandwidth-value命令为多个队列配置最小保证带宽值时,这些队列min参数的取值之和不能大于所配置接口所有的数据包的承诺信息速率(即min的取值之和不能大于qos gts any cir committed-information-rate命令中cir参数的值)和接口带宽值。
# 在GigabitEthernet2/0/1上配置队列1的最小保证带宽值为100kbps。
[Sysname] interface GigabitEthernet 2/0/1
[Sysname-GigabitEthernet2/0/1] qos wfq weight
[Sysname-GigabitEthernet2/0/1] qos bandwidth queue 1 min 100
·     qos wfq
4.1.3  qos wfq
qos wfq命令用来在接口上使能WFQ队列,并指明当前WFQ队列调度权重的计算方式。
undo qos wfq命令用来在接口上取消WFQ队列,恢复缺省的队列算法。
qos wfq weight
undo qos wfq weight
接口采用严格优先队列调度。
weight:表示按照权重进行计算。
·     必须先使用qos wfq命令在接口上使能WFQ队列,然后才能进行WFQ配置。
·     接口刚使能WFQ队列后,该接口各队列的调度权重值默认为1,最小保证带宽值默认为40kbps。
# 在接口GigabitEthernet3/0/1上使能WFQ队列,并按照权重进行计算。
[Sysname-GigabitEthernet3/0/1] qos wfq weight
·     display qos queue wfq interface
qos wfq weight 命令用来修改WFQ队列的调度权重值。
undo qos wfq命令用来恢复缺省情况。
qos wfq queue-id weight  schedule-value
undo qos wfq queue-id
WFQ队列的调度权重值为1。
weight:表示按照权重进行计算。
schedule-value:配置队列的调度权重,取值范围为1~63,缺省的调度权重值为1。
# 在GigabitEthernet2/0/1上配置队列3和队列4的调度权重值分别为20、30。
[Sysname-GigabitEthernet2/0/1] qos wfq 3 weight 20
[Sysname-GigabitEthernet2/0/1] qos wfq 4 weight 30
·     qos bandwidth queue
·     qos wfq
4.2  队列调度策略配置命令
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
独立运行模式:
IRF模式:
display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number ]
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。
·     如果不指定队列调度策略的名称,将显示所有队列调度策略的配置情况。
·     如果不指定槽位号,则显示设备上所有队列调度策略的配置情况。(独立运行模式)
·     如果不指定成员编号和槽位号,则显示所有成员设备上所有队列调度策略的配置情况。(IRF模式)
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
 Queue ID    Type    Group    Schedule-unit    Schedule-value    Bandwidth
 be          SP      N/A      N/A              N/A                N/A
 af1         WRR     1        byte-count       1                  N/A
 af2         SP      N/A      N/A              N/A                N/A
 af3         SP      N/A      N/A              N/A                N/A
 af4         SP      N/A      N/A              N/A                N/A
 ef          SP      N/A      N/A              N/A                N/A
 cs6         SP      N/A      N/A              N/A                N/A
 cs7         SP      N/A      N/A              N/A                N/A
表4-3 display qos qmprofile configuration命令显示信息描述表
队列调度策略名称
Queue ID
队列号
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)
Group
优先组,N/A表示无效
Schedule-unit
队列调度单位byte-count,N/A表示无效
Schedule-vlaue
权重值,N/A表示无效
Bandwidth
最小保证带宽值,N/A表示无效
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface gigabitethernet 3/0/1
表4-4 display qos qmprofile interface命令显示信息描述表
接口名称
队列调度策略名称
qos apply qmprofile命令用来在接口上应用队列调度策略。
undo qos apply qmprofile命令用来恢复缺省情况。
没有在接口应用队列调度策略。
每个接口只能应用一个队列调度策略。
# 在接口上应用队列调度策略myprofile。
[Sysname-GigabitEthernet3/0/1] qos apply qmprofile myprofile
·     display qos qmprofile interface
4.2.4  qos qmprofile
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入队列调度策略视图。
undo qos qmprofile命令用来删除用户自定义的队列调度策略。
qos qmprofile profile-name
undo qos qmprofile profile-name
不存在用户自定义的队列调度策略。
不能删除已经应用到接口的队列调度策略,必须先在应用的接口上取消对该队列调度策略的应用,然后再删除该队列调度策略。
# 创建自定义的队列调度策略myprofile,并进入队列调度策略视图。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile]
·     queue
4.2.5  queue
queue命令用来配置队列调度参数。
undo queue命令用来恢复缺省情况。
queue queue-id { sp | wrr group group-id byte-count schedule-value }
undo queue queue-id
各队列使用严格优先级调度。
队列调度策略视图
queue-id:队列序号。可以使用数字或关键字表示,两者对应关系请参见表4-5。
表4-5 队列参数描述表
关键字
队列号(十进制)
af1
1
af2
2
af3
3
af4
4
be
0
cs6
6
cs7
7
ef
5
sp:配置队列为严格优先级调度。
wrr:配置队列为加权轮询调度。
group-id:WRR优先组号,取值范围为1~2。
byte-count:表示按照每次轮询可发送的字节数进行计算。
schedule-value:调度权重,取值范围为1~250。
# 创建自定义的队列调度策略myprofile,并配置队列0为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 0 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,权重为100,分组为1。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 byte-count 100
·     qos qmprofile
4.3  低时延队列调度模式配置命令
queue low-latency enable命令用来开启低时延队列调度模式。
undo queue low-latency enable命令用来关闭低时延队列调度模式。
低时延队列调度模式处于关闭状态。
在对转发时延性能要求较高的场景下,可开启低时延队列调度模式,使得系统获得更高的转发时延性能。
本命令仅缺省MDC支持。有关MDC的详细介绍,请参见“虚拟化技术配置指导”中的“MDC”。
# 开启低时延队列调度模式。
[Sysname] queue low-latency enable
5 全局CAR
5.1  全局CAR配置命令
5.1.1  car name
car name命令用来引用全局CAR。
undo car用来取消对全局CAR的引用。
car name car-name
undo car
没有引用全局CAR。
流行为视图
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
被引用的聚合CAR必须已经存在。
# 在流行为be1中引用名称为aggcar-1的聚合CAR。
·     display qos car name
·     display traffic behavior user-defined
display qos car name命令用来显示全局CAR的配置。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。显示指定全局CAR的配置信息。如果未指定本参数,将显示所有全局CAR的配置信息。
# 显示所有全局CAR的配置信息。
<Sysname> display qos car name
  Mode: aggregative
   CIR 1000 (kbps), CBS 10000 (Bytes), PIR 10000 (kbps), EBS 625000 (Bytes)
表5-1 display qos car name命令显示信息描述表
Name
全局CAR的名称
Mode
全局CAR的类型(aggregative:聚合CAR)
CIR  CBS  PIR  EBS
流量监管流量的参数配置
Red action
对红色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
5.1.3  qos car
qos car命令用来配置聚合CAR。
undo qos car命令用来取消聚合CAR配置。
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ red action ]
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peek-information-rate [ ebs excess-burst-size ] [ red action ]
undo qos car car-name
没有配置聚合CAR。
aggregative:该全局CAR为聚合模式,目前只支持聚合CAR。
cir committed-information-rate:承诺信息速率,取值范围为1~100000000,单位为kbps。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,取值范围为1553~2147450880,单位为byte。缺省取值为500毫秒以CIR速率通过的流量,若该数值小于1553,则缺省值为1553。设置的突发尺寸同时必须大于最大报文长度。
ebs excess-burst-size:过度突发尺寸,取值范围为0~2147450880,单位为byte。
pir peak-information-rate:峰值速率,取值范围为1~100000000,单位为kbps。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     聚合CAR配置需要在策略中引用后才能生效。
# 配置聚合CAR采取的CAR参数取值,cir取值为200,cbs取值为2000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2000 red discard
reset qos car name命令用来清除全局CAR的统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。清除指定全局CAR的统计信息。如果未指定本参数,将清除所有全局CAR的统计信息。
# 清除全局CAR aggcar-1的配置信息。
<Sysname> reset qos car name aggcar-1
6 报文统计配置命令
6.1  报文统计配置命令
display qos traffic-counter命令用来显示报文统计信息和计数器的配置信息。
独立运行模式:
display qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number
IRF模式:
display qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number
inbound:入方向报文统计。
outbound:出方向报文统计。
counter0:计数器0。
counter1:计数器1。
slot slot-number:显示指定单板的报文统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的报文统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 显示4号板的出方向报文统计信息和计数器0的配置信息。
<Sysname> display qos traffic-counter outbound counter0 slot 4
Slot 4 outbound counter0 mode:
 Interface: all
 VLAN: all
 Local precedence: all
 Drop priority: all
 Traffic-counter summary:
  Unicast: 1 packets
  Multicast: 1 packets
  Broadcast: 1 packets
  Control packets: 1 packets
  Bridge egress filtered packets: 1 packets
  Tail drop packets: 1 packets
  Tail drop multicast packets: 1 packets
  Forwarding restrictions packets: 1 packets
表6-1 display qos traffic-counter命令显示信息描述表
单板上某计数器统计出方向流量的监控对象
本计数器所统计的接口
VLAN
本计数器所统计的VLAN
Local precedence
本计数器所统计的本地优先级
Drop priority
本计数器所统计的丢弃优先级
本计数器统计信息汇总
Unicast
单播报文数
Multicast
组播报文数
Broadcast
广播报文数
Control packets
控制报文数
下行桥过滤报文数
Tail drop packets
尾丢弃报文数
尾丢弃组播报文数
禁止转发报文数(目前,该项暂不支持)
# 显示1号板的入方向报文统计信息和计数器0的配置信息。
<Sysname> display qos traffic-counter inbound counter0 slot 1
Slot 1 inbound counter0 mode:
 Interface: all
 VLAN: all
  Summary inbound: 0 packets
  Dropped of local filtering: 0 packets
  Dropped of VLAN filtering: 0 packets
  Dropped of security filtering: 0 packets
表6-2 display qos traffic-counter inbound命令显示信息描述表
1槽位单板上计数器0统计入方向流量的监控对象
本计数器所统计的接口
VLAN
本计数器所统计的VLAN
本计数器统计信息汇总
Summary inbound
桥(二层)接收到的报文个数
桥(二层)丢弃报文个数(除了桥安全过滤和VLAN入方向过滤外的其他原因丢弃的报文数)
VLAN入方向过滤报文数
桥(二层)安全过滤报文数
qos traffic-counter命令用来使能报文统计功能,并指定统计的流量类型。
undo qos traffic-counter命令用来关闭报文统计功能。
独立运行模式:
qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number [ drop-priority drop-priority | interface interface-type interface-number | vlan vlan-id ] *
undo qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number
IRF模式:
qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number [ drop-priority drop-priority | interface interface-type interface-number | vlan vlan-id ] *
undo qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number
报文统计功能处于关闭状态。
inbound:入方向报文统计。
outbound:出方向报文统计。
counter0:计数器0。
counter1:计数器1。
slot slot-number:slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
drop-priority drop-priority:丢弃优先级,取值范围为0~2。
interface interface-type interface-number:指定绑定的端口类型和端口编号。
vlan vlan-id:VLAN ID,取值范围为1~4094。
一块单板提供两组计数器用于统计单板流量,监控的对象可以是端口、VLAN和丢弃优先级。
·     当不指定端口时,则监控单板上所有端口的流量。
·     当不指定VLAN时,则监控所有VLAN的流量。
·     当不指定丢弃优先级时,则监控所有丢弃优先级的流量。
·     使用qos traffic-counter命令重新设置某单板的监控对象后,计数器的值会自动清空。
·     drop-priority只支持outbound方向上的应用。
·     FD/FG类单板仅支持监控单板上指定端口的流量,不支持监控VLAN、丢弃优先级和所有端口的流量。配置时需要同时指定槽位号及端口编号。
# 配置4号板的计数器0统计GigabitEthernet3/0/1端口的出方向流量。(独立运行模式)
[Sysname] qos traffic-counter outbound counter0 slot 4 interface gigabitethernet 3/0/1
# 配置1号成员设备4号板的计数器0统计GigabitEthernet1/3/0/1端口的出方向流量。(IRF模式)
[Sysname] qos traffic-counter outbound counter0 chassis 1 slot 4 interface gigabitethernet 1/3/0/1
reset qos traffic-counter命令用来清除报文统计计数器的统计信息。
独立运行模式:
reset qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number
IRF模式:
reset qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number
inbound:入方向报文统计。
outbound:出方向报文统计。
counter0:计数器0。
counter1:计数器1。
slot slot-number:清除指定单板的报文统计计数器的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的报文统计计数器的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 清除4号板的出方向报文统计计数器的统计信息。(独立运行模式)
<Sysname> reset qos traffic-counter outbound counter0 slot 4
# 清除1号成员设备4号板的出方向报文统计计数器的统计信息。(IRF模式)
<Sysname> reset qos traffic-counter outbound counter0 chassis 1 slot 4
7 端口队列统计
7.1  端口队列统计配置命令
display qos queue-statistics interface outbound命令用来显示出方向端口队列的统计信息。
interface-type interface-number:指定端口类型和端口编号。如果未指定本参数,将显示属于本MDC的所有端口的队列出方向统计信息。
本命令只能用于显示FD类单板、FG类单板、单板丝印为LST1FW3C1或LST1NSM2C1的OAA单板上的报文统计信息。
“FD类单板”指的是丝印后缀为FD的单板,如LST1XP48LFD1;FG类单板含义类似。
# 显示端口Ten-GigabitEthernet3/0/1的队列出方向统计信息。
<Sysname> display qos queue-statistics interface Ten-GigabitEthernet3/0/1 outbound
Interface: Ten-GigabitEthernet3/0/1
 Direction: outbound
 Forwarded: 0 packets, 0 bytes
 Dropped: 0 packets, 0 bytes
Queue 0
Queue 1
Queue 2
Queue 3
Queue 4
Queue 5
Queue 6
Queue 7
表7-1 display qos queue-statistics interface outbound命令显示信息描述表
端口队列统计的端口
Direction
端口队列统计的方向
Forwarded
转发的数据包数目和字节数
Dropped
丢弃的数据包数目和字节数
Queue 0、Queue 1、Queue 2、Queue 3、Queue 4、Queue 5、Queue 6、Queue 7
某端口队列统计信息
·     reset qos queue-statistics interface
qos queue-statistics outbound命令用来使能出方向端口队列统计功能。
undo qos queue-statistics outbound命令用来关闭出方向端口队列统计功能。
出方向端口队列统计功能处于使能状态。
·     本命令仅缺省MDC支持,在缺省MDC配置本命令后,非缺省MDC也生效。有关MDC的详细介绍,请参见“虚拟技术配置指导”中的“MDC”。
·     端口队列统计功能仅能统计出从FD类或FG类单板接收的已知单播报文,对于未知单播报文、广播报文、组播报文和协议报文无法统计成功。
# 使能出方向端口队列统计功能。
[Sysname] qos queue-statistics outbound
·     display qos queue-statistics interface outbound
