07-Layer 3—IP Routing Configuration Guide
HomeSupportSecurityH3C SecPath L5000Configure & DeployConfiguration GuidesH3C SecPath L5000-AD9X0 Series Configuration Guides(V7)(R9900)-6W10107-Layer 3—IP Routing Configuration Guide
12-Static routing configuration
12-Static routing configuration 309.72 KB
Configuring static routing
About static routes
Static routes are manually configured. If a network's topology is simple, you only need to configure static routes for the network to work correctly.
Static routes cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually.
The device supports configuring static routes for the public network as well as for a VPN instance. The static route configured for a VPN instance is used to guide the forwarding of packets in the VPN instance.
Configuring a static route
2.     Configure a static route.
Public network:
ip route-static dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, no static route is configured.
You can associate Track with a static route to monitor the reachability of the next hops. For more information about Track, see Network Management and Monitoring Configuration Guide.
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
3.     (Optional.) Configure the default preference for static routes.
ip route-static default-preference default-preference
The default setting is 60.
Configuring a static route group
This task allows you to batch create static routes with different prefixes but the same output interface and next hop.
You can create a static route group, and specify the static group in the ip route-static command. All prefixes in the static route group will be assigned the next hop and output interface specified in the ip route-static command.
2.     Create a static route group and enter its view.
ip route-static-group group-name
By default, no static route group is configured.
3.     Add a static route prefix to the static route group.
prefix dest-address { mask-length | mask }
By default, no static route prefix is added to the static route group.
If you have executed the ip route-static group command to bulk create static routes, deleting or adding prefixes in static route group view will delete or add the prefix-associated static routes.
4.     Return to system view.
5.     Configure a static route.
Public network:
ip route-static group group-name { interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name group group-name { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
Configuring the DHCP-designated default router as the next hop of a static route
After an interface obtains an IP address and gateway address through DHCP, the device automatically generates a static route with the interface as the output interface. The destination address of the static route is 0.0.0.0/0 and the next hop of the static route is the default router (the gateway address designated by the DHCP server). This static route cannot form ECMP routes with manually configured static routes. The device uses this static route to guide traffic forwarding only after the manually configured static routes become invalid.
Perform this task to use both the automatically generated static route and the manually configured static routes to guide traffic forwarding. The task is applicable when the device has dual egress WAN links.
This task enables the device to automatically generate a static route destined for the specified network with the DHCP-designated default router of the output interface as the next hop. This static route takes effect only after the output interface obtains an IP address and gateway address through DHCP, and becomes invalid upon the DHCP lease expiration. The next hop of this static route changes as the gateway address of the output interface changes. In addition, this static route can form ECMP routes with manually configured static routes.
As shown in Figure 1, Device A acts as the DHCP client, and Device B acts as the DHCP server. Device A automatically obtains IP address and gateway address 9.9.9.9/24 from Device B. After you configure a static route on Device A whose next hop is the DHCP-designated gateway, Device A will generate a static route with gateway address 9.9.9.9/24 as its next hop address. If the gateway address changes, the next hop address of the static route will change to the new gateway address accordingly.
Figure 1 Configuring the DHCP-designated default router as the next hop of a static route
For more information about DHCP, see DHCP in Layer 3—IP Services Configuration Guide.
When you configure the next hop of a static route as the DHCP-designated default router, make sure the output interface of the static route is a broadcast interface.
2.     Configure a static route and specify the default router designated by the DHCP server for the output interface as the next hop of the static route.
Public network:
ip route-static { dest-address { mask-length | mask } | group group-name } interface-type interface-number dhcp [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number dhcp [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number dhcp [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, no static route is configured with the DHCP-designated default router as the next hop.
Configuring a floating static route
Perform this task to implement route backup and improve network reliability.
When a static or dynamic route to a destination address already exists on the device, you can configure another static route with a lower priority as the backup route to improve the network reliability. This backup static route is called a floating static route, and it is activated only when the primary route fails. After the primary route recovers from failure, the floating static route becomes inactive, and data forwarding switches back to the primary route.
As shown in Figure 2, two links exist between Device A and Device B. On device A, configure a static route with next hop Device C and preference 60, and configure a static route with next hop Device D and preference 100. The static route with next hop Device D automatically becomes a floating static route.
Figure 2 Configuring a floating static route
You can configure a floating static route in either of the following ways:
·     Configure different priorities for multiple static routes to the same destination address. The route with lower priority automatically becomes the floating static route.
·     When a route to a destination address already exists on the device, configure a static route with a lower priority to the same destination address.
When you configure a floating static route, the priority value of the route must be larger than the priority value of the primary route. For more information, see "Configuring a static route."
Deleting static routes
To delete a static route, use the undo ip route-static command. To delete all static routes including the default route, use the delete static-routes all command.
2.     Delete all static routes.
Public network:
VPN:
delete vpn-instance vpn-instance-name static-routes all
CAUTION
CAUTION:
This command might interrupt network communication and cause packet forwarding failure. Before executing the command, make sure you fully understand the potential impact on the network.
Configuring BFD for static routes
IMPORTANT
IMPORTANT:
Enabling BFD for a flapping route could worsen the situation.
About BFD
BFD provides a general-purpose, standard, medium-, and protocol-independent fast failure detection mechanism. It can uniformly and quickly detect the failures of the bidirectional forwarding paths between two routers for protocols, such as routing protocols. This feature allows you to associate a BFD session with a static route, and use the BFD session state to monitor the state of the link associated with the IPv4 static route. When the BFD session detects a link failure (BFD session state is Down) on the IPv4 static route, BFD reports the failure to the system, and the system then removes this route from the IP routing table. When the BFD session detects that the previously failed link is re-established successfully (BFD session state is Up), BFD reports this event to the system, and the system then adds this route back to the IP routing table.
For more information about BFD, see Network Management and Monitoring Configuration Guide.
Configuring BFD control packet mode
This mode uses BFD control packets to detect the status of a link bidirectionally at a millisecond level.
BFD control packet mode can be applied to static routes with a direct next hop or with an indirect next hop.
Restrictions and guidelines for BFD control packet mode
If you use BFD control packet mode at the local end, you must use this mode also at the peer end.
Configuring BFD control packet mode for a static route (direct next hop)
2.     Configure BFD control packet mode for a static route.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number { dhcp | next-hop-address } bfd { control-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number { dhcp | next-hop-address } bfd { control-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD control packet mode for a static route is not configured.
Configuring BFD control packet mode for a static route (indirect next hop)
Public network:
ip route-static dest-address { mask-length | mask } { next-hop-address bfd { control-packet bfd-source ip-address | static session-name } | vpn-instance d-vpn-instance-name next-hop-address bfd { control-packet bfd-source ip-address | static session-name } } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { next-hop-address bfd { control-packet bfd-source ip-address | static session-name } | vpn-instance d-vpn-instance-name next-hop-address bfd { control-packet bfd-source ip-address | static session-name } } [ preference preference ] [ tag tag-value ] [ description text ]
Configuring BFD echo packet mode
With BFD echo packet mode enabled for a static route, the output interface sends BFD echo packets to the destination device, which loops the packets back to test the link reachability.
You do not need to configure BFD echo packet mode at the peer end.
Do not use BFD for a static route with the output interface in spoofing state.
2.     (Optional.) Configure the source address of echo packets.
bfd echo-source-ip ip-address
By default, the source address of echo packets is not configured.
As a best practice to avoid network congestion caused by excessive ICMP redirect packets from the peer, use this command. Make sure the source IPv4 address is not on the subnet of any interfaces on the device.
For more information about this command, see High Availability Command Reference.
3.     Configure BFD echo packet mode for a static route.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number { dhcp | next-hop-address } bfd { echo-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number { dhcp | next-hop-address } bfd { echo-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD echo packet mode for a static route is not configured.
Configuring static route FRR
About static route FRR
A link or router failure on a path can cause packet loss. Static route fast reroute (FRR) enables fast rerouting to minimize the impact of link or node failures.
Figure 3 Network diagram
As shown in Figure 3, upon a link failure, packets are directed to the backup next hop to avoid traffic interruption. You can either specify a backup next hop for FRR or enable FRR to automatically select a backup next hop (which must be configured in advance).
Restrictions and guidelines for static route FRR
Do not use static route FRR and BFD (for a static route) at the same time.
Equal-cost routes do not support static route FRR.
Besides the configured static route for FRR, the device must have another route to reach the destination. When the state of the primary link (with Layer 3 interfaces staying up) changes from bidirectional to unidirectional or down, static route FRR quickly redirects traffic to the backup next hop. When the Layer 3 interfaces of the primary link are down, static route FRR temporarily redirects traffic to the backup next hop. In addition, the device searches for another route to reach the destination and redirects traffic to the new path if a route is found. If no route is found, traffic interruption occurs.
Configuring static route FRR by specifying a backup next hop
After you configure this feature, the backup output interface and backup next hop will be issued to the forwarding table together with the primary output interface and primary next hop of the static route. To view the backup output interface and backup next hop of the static route, use the display route-static routing-table command.
A static route does not take effect when the backup output interface is unavailable.
To change the backup output interface or next hop, you must first remove the current setting. The backup output interface and next hop must be different from the primary output interface and next hop.
1.     ‍Enter system view.
2.     Configure static route FRR.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number [ { dhcp | next-hop-address } [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ { dhcp | next-hop-address } [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, static route FRR is disabled.
Configuring static route FRR to automatically select a backup next hop
If multiple static routes to the same destination address with different priorities exist on the device, you can use perform this task to enable the device to automatically obtain backup routes. Both the primary and backup routes will be issued to the forwarding table. The route with higher priority is the primary route, and the route with lower priority is the backup route.
2.     Configure static route FRR to automatically select a backup next hop.
ip route-static fast-reroute auto
By default, static route FRR is disabled from automatically selecting a backup next hop.
Enabling BFD echo packet mode for static route FRR
By default, static route FRR uses ARP to detect primary link failures. Perform this task to enable static route FRR to use BFD echo packet mode for fast failure detection on the primary link.
2.     (Optional.) Configure the source IP address of BFD echo packets.
By default, the source IP address of BFD echo packets is not configured.
3.     Enable BFD echo packet mode for static route FRR.
ip route-static primary-path-detect bfd echo
By default, BFD echo packet mode for static route FRR is disabled.
Display and maintenance commands for static routing
Display static route information.
display ip routing-table protocol static [ inactive | verbose ]
Display static route next hop information.
display route-static nib [ nib-id ] [ verbose ]
Display static routing table information.
display route-static routing-table [ vpn-instance vpn-instance-name ] [ ip-address { mask-length | mask } ]
For more information about the display ip routing-table protocol static [ inactive | verbose ] command, see basic IP routing in Layer 3—IP Routing Command Reference.
Static route configuration examples
Example: Configuring basic static routes
As shown in Figure 4, configure static routes on the devices for interconnections between any two hosts.
Figure 4 Network diagram
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure static routes:
# Configure a default route on Device A.
[DeviceA] ip route-static 0.0.0.0 0.0.0.0 1.1.4.2
# Configure two static routes on Device B.
[DeviceB] ip route-static 1.1.2.0 255.255.255.0 1.1.4.1
[DeviceB] ip route-static 1.1.3.0 255.255.255.0 1.1.5.6
# Configure a default route on Device C.
<DeviceC> system-view
[DeviceC] ip route-static 0.0.0.0 0.0.0.0 1.1.5.5
3.     Configure the default gateways of Host A, Host B, and Host C as 1.1.2.3, 1.1.6.1, and 1.1.3.1. (Details not shown.)
# Display the static route information on Device A.
[DeviceA] display ip routing-table protocol static
Summary Count : 1
Static Routing table Status : <Active>
Summary Count : 1
0.0.0.0/0           Static 60   0            1.1.4.2         XGE2/3/2
Static Routing table Status : <Inactive>
Summary Count : 0
# Display the static route information on Device B.
[DeviceB] display ip routing-table protocol static
Summary Count : 2
Summary Count : 2
1.1.2.0/24          Static 60   0            1.1.4.1         XGE2/3/1
1.1.3.0/24          Static 60   0            1.1.5.6         XGE2/3/2
Summary Count : 0
# Use the ping command on Host B to test the reachability of Host A (Windows XP runs on the two hosts).
C:\Documents and Settings\Administrator>ping 1.1.2.2
Pinging 1.1.2.2 with 32 bytes of data:
Reply from 1.1.2.2: bytes=32 time=1ms TTL=126
Ping statistics for 1.1.2.2:
# Use the tracert command on Host B to test the reachability of Host A.
C:\Documents and Settings\Administrator>tracert 1.1.2.2
Tracing route to 1.1.2.2 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  1.1.6.1
  2    <1 ms    <1 ms    <1 ms  1.1.4.1
  3     1 ms    <1 ms    <1 ms  1.1.2.2
Trace complete.
Example: Configuring BFD for static routes (direct next hop)
Configure the following, as shown in Figure 5:
·     Configure a static route to subnet 120.1.1.0/24 on Device A.
·     Configure a static route to subnet 121.1.1.0/24 on Device B.
·     Enable BFD for both routes.
·     Configure a static route to subnet 120.1.1.0/24 and a static route to subnet 121.1.1.0/24 on Device C.
When the link between Device A and Device B through the Layer 2 switch fails, BFD can detect the failure immediately. Device A then communicates with Device B through Device C.
Figure 5 Network diagram
Device
IP address
Device A
XGE2/3/1
12.1.1.1/24
Device A
XGE2/3/2
10.1.1.102/24
Device B
XGE2/3/1
12.1.1.2/24
Device B
XGE2/3/2
13.1.1.1/24
Device C
XGE2/3/1
10.1.1.100/24
Device C
XGE2/3/2
13.1.1.2/24
2.     Configure static routes and BFD:
# Configure static routes on Device A and enable BFD control packet mode for the static route that traverses the Layer 2 switch.
[DeviceA] interface ten-gigabitethernet 2/3/1
[DeviceA-Ten-GigabitEthernet2/3/1] bfd min-transmit-interval 500
[DeviceA-Ten-GigabitEthernet2/3/1] bfd min-receive-interval 500
[DeviceA-Ten-GigabitEthernet2/3/1] bfd detect-multiplier 9
[DeviceA-Ten-GigabitEthernet2/3/1] quit
[DeviceA] ip route-static 120.1.1.0 24 ten-gigabitethernet 2/3/1 12.1.1.2 bfd control-packet
[DeviceA] ip route-static 120.1.1.0 24 ten-gigabitethernet 2/3/2 10.1.1.100 preference 65
[DeviceA] quit
# Configure static routes on Device B and enable BFD control packet mode for the static route that traverses the Layer 2 switch.
[DeviceB] interface ten-gigabitethernet 2/3/1
[DeviceB-Ten-GigabitEthernet2/3/1] bfd min-transmit-interval 500
[DeviceB-Ten-GigabitEthernet2/3/1] bfd min-receive-interval 500
[DeviceB-Ten-GigabitEthernet2/3/1] bfd detect-multiplier 9
[DeviceB-Ten-GigabitEthernet2/3/1] quit
[DeviceB] ip route-static 121.1.1.0 24 ten-gigabitethernet 2/3/1 12.1.1.1 bfd control-packet
[DeviceB] ip route-static 121.1.1.0 24 ten-gigabitethernet 2/3/2 13.1.1.2 preference 65
[DeviceB] quit
# Configure static routes on Device C.
[DeviceC] ip route-static 120.1.1.0 24 13.1.1.1
[DeviceC] ip route-static 121.1.1.0 24 10.1.1.102
# Display BFD sessions on Device A.
<DeviceA> display bfd session
 Total sessions: 1        Up sessions: 1        Init mode: Active
 LD/RD           SourceIP        DestinationIP   State   Holdtime    Interface
 4/7             12.1.1.1        12.1.1.2        Up      2000ms      XGE2/3/1
The output shows that the BFD session has been created.
# Display static routes on Device A.
<DeviceA> display ip routing-table protocol static
Summary Count : 1
Summary Count : 1
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
120.1.1.0/24        Static 60   0            12.1.1.2        XGE2/3/1
Summary Count : 0
The output shows that Device A communicates with Device B through Ten-GigabitEthernet 2/3/1. Then the link over Ten-GigabitEthernet 2/3/1 fails.
Summary Count : 1
Summary Count : 1
120.1.1.0/24        Static 65   0            10.1.1.100      XGE2/3/2
Summary Count : 0
The output shows that Device A communicates with Device B through Ten-GigabitEthernet 2/3/2.
Example: Configuring BFD for static routes (indirect next hop)
Figure 6 shows the network topology as follows:
·     Device A has a route to interface Loopback 1 (2.2.2.9/32) on Device B, with the output interface Ten-GigabitEthernet 2/3/1.
·     Device B has a route to interface Loopback 1 (1.1.1.9/32) on Device A, with the output interface Ten-GigabitEthernet 2/3/1.
·     Device D has a route to 1.1.1.9/32, with the output interface Ten-GigabitEthernet 2/3/1, and a route to 2.2.2.9/32, with the output interface Ten-GigabitEthernet 2/3/2.
Configure the following:
·     Configure a static route to subnet 120.1.1.0/24 and a static route to subnet 121.1.1.0/24 on both Device C and Device D.
When the link between Device A and Device B through Device D fails, BFD can detect the failure immediately. Device A then communicates with Device B through Device C.
Figure 6 Network diagram
Device
IP address
Device A
XGE2/3/1
12.1.1.1/24
Device A
XGE2/3/2
10.1.1.102/24
Device A
Loopback 1
1.1.1.9/32
Device B
XGE2/3/1
11.1.1.2/24
Device B
XGE2/3/2
13.1.1.1/24
Device B
Loopback 1
2.2.2.9/32
Device C
XGE2/3/1
10.1.1.100/24
Device C
XGE2/3/2
13.1.1.2/24
Device D
XGE2/3/1
12.1.1.2/24
Device D
XGE2/3/2
11.1.1.2/24
# Configure static routes on Device A and enable BFD control packet mode for the static route that traverses Device D.
[DeviceA] bfd multi-hop min-transmit-interval 500
[DeviceA] bfd multi-hop min-receive-interval 500
[DeviceA] bfd multi-hop detect-multiplier 9
[DeviceA] ip route-static 2.2.2.9 32 12.1.1.2
[DeviceA] ip route-static 120.1.1.0 24 2.2.2.9 bfd control-packet bfd-source 1.1.1.9
[DeviceA] quit
# Configure static routes on Device B and enable BFD control packet mode for the static route that traverses Device D.
[DeviceB] bfd multi-hop min-transmit-interval 500
[DeviceB] bfd multi-hop min-receive-interval 500
[DeviceB] bfd multi-hop detect-multiplier 9
[DeviceB] ip route-static 1.1.1.9 32 11.1.1.1
[DeviceB] ip route-static 121.1.1.0 24 1.1.1.9 bfd control-packet bfd-source 2.2.2.9
[DeviceB] quit
# Configure static routes on Device D.
<DeviceD> system-view
[DeviceD] ip route-static 120.1.1.0 24 11.1.1.2
[DeviceD] ip route-static 121.1.1.0 24 12.1.1.1
# Display the BFD session information on Device A.
 4/7             1.1.1.9         2.2.2.9         Up      2000ms      N/A
Summary Count : 1
Summary Count : 1
Summary Count : 0
Summary Count : 1
Summary Count : 1
Summary Count : 0
Example: Configuring static route FRR
As shown in Figure 7, configure static routes on Device A, Device B, and Device C, and configure static route FRR. When Link A becomes unidirectional, traffic can be switched to Link B immediately.
Figure 7 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device A
XGE2/3/1
12.12.12.1/24
Device A
XGE2/3/2
13.13.13.1/24
Device A
Loopback 0
1.1.1.1/32
Device B
XGE2/3/1
24.24.24.4/24
Device B
XGE2/3/2
13.13.13.2/24
Device B
Loopback 0
4.4.4.4/32
Device C
XGE2/3/1
12.12.12.2/24
Device C
XGE2/3/2
24.24.24.2/24
2.     Configure static route FRR on link A by using one of the following methods:
¡     (Method 1.) Specify a backup next hop for static route FRR:
# Configure a static route on Device A, and specify Ten-GigabitEthernet 2/3/1 as the backup output interface and 12.12.12.2 as the backup next hop.
[DeviceA] ip route-static 4.4.4.4 32 ten-gigabitethernet 2/3/2 13.13.13.2 backup-interface ten-gigabitethernet 2/3/1 backup-nexthop 12.12.12.2
# Configure a static route on Device B, and specify Ten-GigabitEthernet 2/3/1 as the backup output interface and 24.24.24.2 as the backup next hop.
[DeviceB] ip route-static 1.1.1.1 32 ten-gigabitethernet 2/3/2 13.13.13.1 backup-interface ten-gigabitethernet 2/3/1 backup-nexthop 24.24.24.2
¡     (Method 2.) Configure static route FRR to automatically select a backup next hop:
# Configure static routes on Device A, and enable static route FRR.
[DeviceA] ip route-static 4.4.4.4 32 ten-gigabitethernet 2/3/1 12.12.12.2 preference 70
[DeviceA] ip route-static fast-reroute auto
# Configure static routes on Device B, and enable static route FRR.
[DeviceB] ip route-static 1.1.1.1 32 ten-gigabitethernet 2/3/1 24.24.24.2 preference 70
[DeviceB] ip route-static fast-reroute auto
3.     Configure static routes on Device C.
[DeviceC] ip route-static 4.4.4.4 32 ten-gigabitethernet 2/3/2 24.24.24.4
[DeviceC] ip route-static 1.1.1.1 32 ten-gigabitethernet 2/3/1 12.12.12.1
# Display route 4.4.4.4/32 on Device A to view the backup next hop information.
[DeviceA] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.4/32
    Protocol: Static
  Process ID: 0
   SubProtID: 0x0                       Age: 04h20m37s
        Cost: 0                  Preference: 60
       IpPre: N/A                QosLocalID: N/A
         Tag: 0                       State: Active Adv
   OrigTblID: 0x0                   OrigVrf: default-vrf
     TableID: 0x2                    OrigAs: 0
       NibID: 0x26000002             LastAs: 0
      AttrID: 0xffffffff           Neighbor: 0.0.0.0
       Flags: 0x1008c           OrigNextHop: 13.13.13.2
       Label: NULL              RealNextHop: 13.13.13.2
     BkLabel: NULL                BkNextHop: 12.12.12.2
     SRLabel: NULL                Interface: Ten-GigabitEthernet2/3/2
   BkSRLabel: NULL              BkInterface: Ten-GigabitEthernet2/3/1
    SIDIndex: NULL                  InLabel: NULL
   Tunnel ID: Invalid           IPInterface: Ten-GigabitEthernet2/3/2
 BkTunnel ID: Invalid         BkIPInterface: Ten-GigabitEthernet2/3/1
    FtnIndex: 0x0            ColorInterface: N/A
TrafficIndex: N/A          BkColorInterface: N/A
  Connector: N/A                 VpnPeerId: N/A
        Dscp: N/A                       Exp: N/A
  SRTunnelID: Invalid             StatFlags: 0x0
    SID Type: N/A                       SID: N/A
       BkSID: N/A                       NID: Invalid
    FlushNID: Invalid                 BkNID: Invalid
  BkFlushNID: Invalid                PathID: 0x0
CommBlockLen: 0
  OrigLinkID: 0x0                RealLinkID: 0x0
# Display route 1.1.1.1/32 on Device B to view the backup next hop information.
[DeviceB] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
Destination: 1.1.1.1/32
    Protocol: Static
  Process ID: 0
        Cost: 0                  Preference: 10
       Flags: 0x1008c           OrigNextHop: 13.13.13.1
       Label: NULL              RealNextHop: 13.13.13.1
     BkLabel: NULL                BkNextHop: 24.24.24.2
        Dscp: N/A                       Exp: N/A
CommBlockLen: 0
Configuring a default route
A default route is used to forward packets that do not match any specific routing entry in the routing table. Without a default route, packets that do not match any routing entries are discarded and an ICMP destination-unreachable packet is sent to the source.
A default route can be configured in either of the following ways:
·     The network administrator can configure a default route with both destination and mask being 0.0.0.0. For more information, see "Configuring static routing."
·     Some dynamic routing protocols (such as OSPF, IS-IS, and RIP) can generate a default route. For example, an upstream router running OSPF can generate a default route and advertise it to other routers. These routers install the default route with the next hop being the upstream router. For more information, see the respective chapters on these routing protocols in this configuration guide.
As shown in Figure 8, Device B is the next hop for packets from Device A to Device C, Device D, and Device E. You can configure a default route on Device A to replace the three static routes from Device A to Device C, Device D, and Device E. Then, packets that do not match any other routes will be forwarded based on the default route.
Configure the default route as follows:
·     Configure the next hop address as 1.1.1.2.
·     Configure the destination address as 0.0.0.0.
·     Configure the subnet mask as 0.0.0.0.
Figure 8 Configuring a default route
