- 07-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-BGP configuration
- 03-IPv6 policy-based routing configuration
- 04-IPv6 static routing configuration
- 05-IS-IS configuration
- 06-OSPF configuration
- 07-OSPFv3 configuration
- 08-Policy-based routing configuration
- 09-RIP configuration
- 10-RIPng configuration
- 11-Routing policy configuration
- 12-Static routing configuration
| 00-Preface | 109.76 KB |
Preface
This configuration guide describes the fundamentals and configuration procedures for routing protocols.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
