05-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R Switch Router Series Command References(R52xx)-6W10205-Layer 2—LAN Switching Command Reference
02-Ethernet link aggregation commands
02-Ethernet link aggregation commands 422.97 KB
Ethernet link aggregation commands· 1
display interface· 1
display lacp system-id· 5
display link-aggregation capability· 6
display link-aggregation load-sharing mode· 6
display link-aggregation load-sharing path· 9
display link-aggregation member-port 11
display link-aggregation summary· 13
display link-aggregation troubleshooting· 14
display link-aggregation verbose· 15
interface bridge-aggregation· 18
interface route-aggregation· 19
jumboframe enable· 20
lacp default-selected-port disable· 20
lacp edge-port 21
lacp mode· 22
lacp period short 22
lacp select speed· 23
lacp system-mac· 24
lacp system-number 25
lacp system-priority· 26
lacp transparent enable· 26
link-aggregation auto-aggregation enable· 27
link-aggregation bfd· 28
link-aggregation bfd-compatible enable· 29
link-aggregation capability· 30
link-aggregation global load-sharing algorithm·· 31
link-aggregation global load-sharing mode· 32
link-aggregation global load-sharing offset 33
link-aggregation global load-sharing seed· 34
link-aggregation ignore speed· 35
link-aggregation lacp isolate· 36
link-aggregation lacp traffic-redirect-notification enable· 36
link-aggregation load-sharing mode dynamic· 38
link-aggregation management-port 39
link-aggregation management-subnet 39
link-aggregation management-vlan· 40
link-aggregation mode· 41
link-aggregation port-priority· 42
link-aggregation primary-port 42
link-aggregation reversion delay· 43
link-aggregation secondary-down· 44
link-aggregation selected-port maximum·· 45
link-aggregation selected-port minimum·· 46
link-aggregation selected-port minimum percentage· 47
link-aggregation switchover 48
mac-address· 49
mtu· 49
port lacp system-mac· 50
port lacp system-priority· 51
port link-aggregation group· 52
port s-mlag group· 53
reset lacp statistics· 54
sub-interface rate-statistic· 54
display interface
Use display interface to display aggregate interface information.
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an aggregate interface type, the command displays information about all interfaces.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregate interfaces of the specified type.
# Display detailed information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 1000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Last 300 seconds input:  6900 packets/sec 885160 bytes/sec    0%
Last 300 seconds output:  3150 packets/sec 404430 bytes/sec    0%
Input (total):  5364747 packets, 686688416 bytes
         2682273 unicasts, 1341137 broadcasts, 1341337 multicasts, 0 pauses
Input (normal):  5364747 packets, 686688416 bytes
         - ignored, - parity errors
Output (total): 1042508 packets, 133441832 bytes
         1042306 unicasts, 0 broadcasts, 202 multicasts, - pauses
Output (normal): 1042508 packets, 133441832 bytes
         1042306 unicasts, 0 broadcasts, 202 multicasts, 0 pauses
         - lost carrier, - no carrier
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Description: Route-Aggregation1 Interface
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
Input (total):  0 packets, 0 bytes
Input (normal):  0 packets, 0 bytes
         0 CRC, 0 frame, 0 overruns, 0 aborts
         0 ignored, 0 parity errors
Output (normal): 0 packets, 0 bytes
Output: 0 output errors, 0 underruns, 0 buffer failures
         0 lost carrier, 0 no carrier
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
Speed: (a) – auto
BAGG1                DOWN auto    A      A    1
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1                UP   UP       --
Bridge-Aggregation1
Layer 2 aggregate interface name.
Route-Aggregation1
Layer 3 aggregate interface name.
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
IPv4 packet framing format.
Description of the interface.
Bandwidth
Expected bandwidth of the interface. This field is not displayed when the bandwidth is 0 kbps.
The interface speed and duplex mode are unknown.
Port link-type
Port link type:
·     Access.
·     Trunk.
·     Hybrid.
Tagged VLANs
VLAN whose packets are sent out of this interface with a tag.
Untagged VLANs
VLAN whose packets are sent out of this interface without a tag.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Last 300 seconds input/output rate
Average input or output rate over the last 300 seconds.
Input/Output (total)
Statistics of all packets received or sent on the interface.
Input/Output (normal)
Statistics of all normal packets received or sent on the interface.
Line protocol state
Data link layer state of the interface:
·     UP.
·     DOWN.
MTU of the interface.
IP packet processing capability of the interface when the interface is not assigned an IP address:
·     Disabled—The interface cannot process IP packets.
·     Enabled—The interface can process IP packets.
IP address of the interface and type of the address in parentheses.
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-AllocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
Brief information about Layer 3 interfaces.
Brief information about Layer 2 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Speed
Speed of the interface, in bps.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex. This mode is not supported in the current software version.
·     H(a)—Autonegotiated half duplex.
Link type of the interface:
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN.
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Local system ID, which contains the LACP system priority (0x8000 in this sample output) and the LACP system MAC address (0000-FC00-6504 in this sample output).
Use display link-aggregation capability to display the link aggregation capability for the device.
# Display the link aggregation capability for the device.
<Sysname> display link-aggregation capability
Default link aggregation capability:
  Maximum groups: 1024
  Maximum Selected ports per group: 16
Current link aggregation capability:
Link aggregation capability at the next reboot:
Supported link aggregation capability list:
  1024*16        512*32         256*64         128*128        64*256
Link aggregation capabilities supported by the device. Each item in the list is in the format of maximum number of aggregation groups*maximum number of Selected ports per aggregation group.
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
The bridge-aggregation or route-aggregation keyword is available only when the corresponding aggregate interfaces exist on the device.
# Display the global link-aggregation load sharing mode. This example displays the default setting.
<Sysname> display link-aggregation load-sharing mode
Link-aggregation load-sharing algorithm:
4 (default)
Link-aggregation load-sharing offset:
0 (default)
Link-aggregation load-sharing seed:
0x1 (default)
Link-aggregation load-sharing mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the global link-aggregation load sharing mode. This example displays a user-configured setting.
5
3
0x10
destination-mac address  source-mac address
# Display the link-aggregation load sharing mode of Layer 2 aggregation group 1. This example displays the default setting.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 1
The dynamic load sharing mode takes effect if it exists.
Bridge-Aggregation1 load-sharing mode:
Dynamic:
  N/A
Static:
# Display the link-aggregation load sharing mode of Layer 2 aggregation group 1. This example displays a user-configured setting.
Dynamic:
  Eligible (flowlet gap time: 1000 us)
Static:
Link aggregation load sharing algorithm.
By default, this field displays the default setting. If you have configured the load sharing algorithm, this field displays the configured algorithm.
Hash offset to adjust the load sharing hash results on aggregate links.
By default, this field displays the default setting. If you have configured a hash offset, this field displays the configured offset value.
Link aggregation load sharing hash seed.
By default, this field displays the default setting. If you have configured the load sharing hash seed, this field displays the configured seed.
Global link-aggregation load sharing mode.
By default, this field displays the link-aggregation load sharing modes for Layer 2 and Layer 3 traffic.
If you have configured the global link-aggregation load sharing mode, this field displays the configured mode.
Link-aggregation load sharing mode of Layer 2 aggregation group 1.
By default, this field displays the global link-aggregation load sharing modes.
If you have configured a link-aggregation load sharing mode for this aggregation group, this field displays the configured mode.
Route-Aggregation1 load-sharing mode
Link-aggregation load sharing mode of Layer 3 aggregation group 1.
Default link-aggregation load sharing mode for Layer 2 traffic. In this sample output, Layer 2 traffic is load shared based on source and destination MAC addresses.
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, Layer 3 traffic is load shared based on source and destination MAC addresses, source and destination IP addresses, and protocol numbers.
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses.
Dynamic
User-configured dynamic load sharing mode:
·     Eligible—Distributes traffic on a per-flowlet basis. The flowlet gap time field displays the flowlet gap in microseconds, which is the idle interval between flowlets.
·     Fixed—Distributes traffic on a per-flow basis.
·     Spray—Distributes traffic across the member links on a per-packet basis.
·     N/A—Dynamic load sharing mode is not configured.
Static
The user-configured static load sharing mode.
Use display link-aggregation load-sharing path to display forwarding information about the specified traffic flow.
display link-aggregation load-sharing path interface { bridge-aggregation | route-aggregation } interface-number ingress-port interface-type interface-number [ route ] { { destination-ip ip-address | destination-ipv6 ipv6-address } | { source-ip ip-address | source-ipv6 ipv6-address } | destination-mac mac-address | destination-port port-id | ip-protocol protocol-id | mpls-label-number number | source-mac mac-address | source-port port-id | vlan vlan-id } *
interface-number: Specifies an existing aggregate interface by its number.
ingress-port interface-type interface-number: Specifies an ingress port by its type and number. The ingress port must be a physical port.
route: Displays forwarding information about Layer 3 traffic. If you do not specify this keyword, the command displays forwarding information about Layer 2 traffic.
destination-ip ip-address: Specifies a destination IPv4 address.
destination-ipv6 ipv6-address: Specifies a destination IPv6 address.
source-ip ip-address: Specifies a source IPv4 address.
source-ipv6 ipv6-address: Specifies a source IPv6 address.
destination-mac mac-address: Specifies a destination MAC address in H-H-H format.
destination-port port-id: Specifies a destination port number in the range of 1 to 65535.
ip-protocol protocol-id: Specifies an IP protocol by its ID in the range of 0 to 255.
mpls-label-number number: Specifies the number of MPLS labels in the flow packets. The value range for the number argument is 1 to 3.
source-mac mac-address: Specifies a source MAC address in H-H-H format.
source-port port-id: Specifies a source port number in the range of 1 to 65535.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
A parameter specified in the command might not be used for selecting the egress port. The Load sharing parameters field displays the parameters that are used in egress port selection. For example, you can specify both the destination-mac mac-address and destination-ip ip-address options. If only the destination MAC address is used for selecting the egress port, the Load sharing parameters field does not display the destination-ip parameter.
If a parameter required for selecting the egress port is not specified, the default value of the parameter is used. If the parameter does not have any default values, the parameter is set to 0.
To avoid inconsistency between the displayed forwarding information and the actual forwarding information, the options you enter for this command must match the options in the display link-aggregation load-sharing mode command.
# Display forwarding information about the specified traffic flow to be sent out of Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display link-aggregation load-sharing path interface  bridge-aggregation 1 ingress-port hundredgige 1/0/1 destination-mac 0000-fc00-0001 source-mac 0000-fc00-0002 source-ip 10.100.0.2 destination-ip 10.100.0.1
Load sharing mode: destination-mac, source-mac, source-ip, destination-ip
Unspecified parameters are set to 0.
Load-sharing parameters:
  Ingress port: HundredGigE1/0/1
  Destination MAC: 0000-fc00-0001
  Source MAC: 0000-fc00-0002
  Destination IP: 10.100.0.1
  Source IP: 10.100.0.2
Egress port: HundredGigE1/0/3
Table 5 Command output
Load sharing mode:
Load sharing mode set for the aggregation group:
·     destination-mac—Traffic is load shared based on destination MAC addresses.
·     source-mac—Traffic is load shared based on source MAC addresses.
·     destination-ip—Traffic is load shared based on destination IP addresses.
·     source-ip—Traffic is load shared based on source IP addresses.
·     destination-port—Traffic is load shared based on destination ports.
·     source-port—Traffic is load shared based on source ports.
·     ip-protocol—Traffic is load shared based on IP protocol types.
·     ingress-port—Traffic is load shared based on ingress ports.
Parameters that are used in egress port selection.
Egress port
Egress port of the specified traffic flow. If no egress port is found, this field displays N/A.
Use display link-aggregation member-port to display detailed link aggregation information about the specified member ports.
display link-aggregation member-port [ interface-list | auto ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
auto: Specifies all link aggregation member ports that are enabled with automatic assignment.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed information about HundredGigE 1/0/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port hundredgige 1/0/1
       G -- Defaulted, H -- Expired
HundredGigE1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed information about HundredGigE 1/0/2, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port hundredgige 1/0/2
HundredGigE1/0/2:
Aggregate Interface: Bridge-Aggregation10
Local:
    Port Number: 2
    Oper-Key: 2
    Flag: {ACDEF}
Remote:
    Port Number: 26
    Oper-Key: 2
    Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Table 6 Command output
Flags
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0.
·     A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive.
·     B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval.
·     C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no.
·     D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no.
·     E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no.
·     F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no.
·     G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no.
·     H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no.
Aggregate Interface
Aggregate interface to which the member port belongs.
Preferred Aggregate Interface
Aggregate interface to which you prefer to assign the member port during automatic assignment.
Local
Information about the local end.
Oper-key
Operational key.
Flag
LACP protocol state flag.
Remote
Information about the peer end.
System ID
Peer system ID, containing the LACP system priority and the LACP system MAC address.
Total number of LACP packets received.
Illegal
Total number of illegal packets.
Sent LACP Packets
Total number of LACP packets sent.
Use display link-aggregation summary to display brief information about all aggregation groups.
The Partner ID field in the command output always displays None for a static link aggregation group. This is because the local aggregation system cannot obtain information from the peer system in a static link aggregation.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG        AGG   Partner ID              Selected  Unselected  Individual  Share
Interface  Mode                          Ports     Ports       Ports       Type
RAGG10     S     None                    1         0           0           NonS
BAGG20     D     0x8000,00e0-fcff-ff01   2         0           0           Shar
Table 7 Command output
Aggregate interface type:
·     BAGG—Layer 2.
·     RAGG—Layer 3.
·     BLAGG—Blade. This type is not available in the current software version.
·     SCH-B—S-channel bundle. This type is not available in the current software version.
Aggregation Mode
Aggregation group type:
·     S—Static.
·     D—Dynamic.
Loadsharing Type
Load sharing type:
·     Shar—Load-sharing.
·     NonS—Non-load-sharing.
Actor System ID
Local system ID, which contains the local LACP system priority and the local LACP system MAC address.
AGG Interface
Type and number of the aggregate interface.
AGG Mode
Aggregation group type.
Partner ID
System ID of the peer system, which contains the peer LACP system priority and the peer LACP system MAC address.
Selected Ports
Total number of Selected ports.
Unselected Ports
Total number of Unselected ports.
Individual Ports
Total number of Individual ports.
Share Type
Load sharing type.
Use display link-aggregation troubleshooting to display the aggregation states of aggregation member ports and the reason why a port was placed in Unselected state.
display link-aggregation troubleshooting [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
If you do not specify an aggregate interface type, the command displays information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregation groups of the specified type.
You can specify the bridge-aggregation or route-aggregation keyword only when aggregate interfaces of the specified type exist on the device.
# Display the aggregation states of aggregation member ports for all aggregation groups and the reason why a port was placed in Unselected state.
<Sysname> display link-aggregation troubleshooting
Aggregate Interface: Bridge-Aggregation2
 Member ports:
  HGE1/0/2
   Status: Selected
  HGE1/0/3
   Status: Unselected
   Reason: The physical or line protocol state of the port is down
   Advice: Check the connection
Table 8 Command output
Reason
Reason why the port was placed in Unselected state.
Advice
Recommended action.
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ all-configuration ]
all-configuration: Specifies all member ports in an aggregation group. If you do not specify this keyword, the command displays the member ports on present cards.
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
This command does not display the interfaces that are enabled with automatic assignment if they have not joined an aggregation group.
# Display detailed information about Layer 2 aggregation group 10, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose  bridge-aggregation 10
Port: A -- Auto port, M -- Management port, R -- Reference port
Role: P -- Primary, S -- Secondary
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  HGE1/0/1            S        32768    61       2                      {ACDEF}
  HGE1/0/2            S        32768    62       2                      {ACDEF}
  HGE1/0/3            S        32768    63       2                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  HGE1/0/1(R)         32768    111      2        0x8000, 000f-e267-57ad {ACDEF}
  HGE1/0/2            32768    112      2        0x8000, 000f-e267-57ad {ACDEF}
  HGE1/0/3            32768    113      2        0x8000, 000f-e267-57ad {ACDEF}
# Display detailed information about Layer 2 aggregation group 20, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 20
Aggregate Interface: Bridge-Aggregation20
Aggregation Mode: Static
  Port             Status  Priority Oper-Key  Role
  HGE1/0/1(R)      S       32768    1         None
  HGE1/0/2         S       32768    1         None
  HGE1/0/3         S       32768    1         None
Table 9 Command output
Loadsharing Type
Load sharing type:
Port Status
Port state:
·     Selected.
·     Unselected.
·     Individual.
Port
Port type:
·     Auto port—The port is enabled with automatic assignment.
·     Management port—The port is a management port. This type is not available in the current software version.
·     Reference port—The port is a reference port.
Flags
Role
Role of the port in the aggregation group operating in 1+1 backup mode:
·     Primary.
·     Secondary.
If the aggregation group is not operating in 1+1 backup mode, None is displayed.
Aggregate Interface
Name of the aggregate interface.
Creation Mode
Creation mode of the dynamic aggregate interface:
·     Auto.
·     Manual.
Aggregation Mode
·     S—Static.
·     D—Dynamic.
Management VLANs
Management VLANs. If no management VLANs are specified, this field displays None.
System ID
Local system ID, containing the local LACP system priority and the local LACP system MAC address.
Local
Information about the local end:
·     Port—Port type and number.
·     Status—Port state, which can be Selected, Unselected, or Individual.
·     Priority—Port priority.
·     Index—Port index.
·     Oper-Key—Operational key.
·     Flag—LACP state flag.
For static aggregation groups, the Index and Flag fields are not displayed.
Remote
Information about the peer end:
·     Actor—Type and number of the local port. This field displays the (R) flag next to the port if its peer port is the reference port.
·     Priority—Priority of the peer port.
·     Index—Index of the peer port.
·     Oper-Key—Operational key of the peer port.
·     System ID—System ID of the peer end.
·     Flag—LACP state flag of the peer end.
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter its view, or enter the view of an existing Layer 2 aggregate interface.
Use undo interface bridge-aggregation to delete a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
No Layer 2 aggregate interfaces exist.
interface-number: Specifies a Layer 2 aggregate interface number. In versions earlier than Release 5212P01, the value range for this argument is 1 to 1024. In Release 5212P01 and later, the value range for this argument is 1 to 4096.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Create a Layer 2 aggregate interface when the device is stable after startup. Do not create a Layer 2 aggregate interface if a card is starting.
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and enter its view.
[Sysname-Bridge-Aggregation1]
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter its view, or enter the view of an existing Layer 3 aggregate interface or subinterface.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface or subinterface.
undo interface route-aggregation { interface-number | interface-number.subnumber }
No Layer 3 aggregate interfaces or subinterfaces exist.
interface-number: Specifies a Layer 3 aggregate interface number. In versions earlier than Release 5212P01, the value range for this argument is 1 to 1024. In Release 5212P01 and later, the value range for this argument is 1 to 4096.
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the subnumber argument is 1 to 4094.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group and all its aggregate subinterfaces. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Deleting a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
Create a Layer 3 aggregate interface when the device is stable after startup. Do not create a Layer 3 aggregate interface if a card is starting.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
[Sysname-Route-Aggregation1]
jumboframe enable
Use jumboframe enable to allow the jumbo frames on an interface to pass through.
Use undo jumboframe enable to deny jumbo frames on an interface.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
An aggregate interface allows jumbo frames that are within 9964 bytes to pass through.
size: Specifies the maximum length of jumbo frames, in bytes. The value range for this argument is 1536 to 9964.
# Allow jumbo frames on Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> System-view
[Sysname-Bridge-Aggregation1] jumboframe enable
Use lacp default-selected-port disable to disable the default port selection action for dynamic aggregation groups.
Use undo lacp default-selected-port disable to enable the default port selection action for dynamic aggregation groups.
The default port selection action is enabled for dynamic aggregation groups.
The default port selection action applies to dynamic aggregation groups.
This action automatically chooses the port with the lowest ID from among all up member ports as a Selected port if none of them has received LACPDUs before the LACP timeout interval expires.
After this action is disabled, a dynamic aggregation group will not have any Selected ports to forward traffic if it has not received LACPDUs before the LACP timeout interval expires.
# Disable the default port selection action.
[Sysname] lacp default-selected-port disable
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an edge aggregate interface.
[Sysname-Bridge-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] lacp mode passive
lacp period short
Use lacp period short to enable short LACP timeout on an interface and configure the short timeout interval.
Use undo lacp period to restore the default.
lacp period short [ timeout timeout ]
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
timeout timeout: Specifies the LACP short timeout interval for an interface, in the range of 3 to 90 seconds. If you do not specify this option, the LACP short timeout interval is 3 seconds on an interface.
The LACP timeout interval refers to the duration a member port waits to receive LACPDUs, and it can be either short or long. By default, the LACP timeout interval is set to long timeout (90 seconds). In this case, if a local member port does not receive LACPDUs from its peer member port within 93 seconds (LACP timeout interval + 3 seconds), the peer member port is considered to have failed.
You can configure the short timeout interval in either of the following methods:
·     Do not specify the timeout keyword—In this method, the short timeout interval is set to a fixed value of 3 seconds. In this case, if a local member port does not receive LACPDUs from its peer member port within 6 seconds (3 seconds of LACP timeout interval + 3 seconds), the peer member port is considered to have failed.
·     Specify the timeout parameter—In this method, you can configure a short timeout interval in the range of 3 to 90 seconds. If a local member port does not receive LACPDUs from its peer member port within the configured LACP short timeout interval, the peer member port is considered to have failed.
# Enable the short LACP timeout interval (3 seconds) on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] lacp period short
# Enable short LACP timeout on HundredGigE 1/0/1 and configure the short timeout interval as 30 seconds.
[Sysname-HundredGigE1/0/1] lacp period short timeout 30
lacp select speed
Use lacp select speed to configure a dynamic aggregation group to use port speed as the prioritized criterion for reference port selection.
Use undo lacp select speed to restore the default.
lacp select speed
Port ID is the prioritized criterion for reference port selection in a dynamic aggregation group.
CAUTION
CAUTION:
Changing reference port selection criteria might cause transient traffic interruption. When you use this command, make sure you understand its impact on your network.
This command enables a dynamic aggregation group to select a high-speed member port as the reference port.
You must execute this command at both ends of the aggregate link so the peer aggregation systems use the same criteria for reference port selection.
As a best practice, shut down the peer aggregate interfaces before you execute this command and bring up the interfaces after this command is executed on both of them.
This command takes effect only on dynamic aggregate interfaces. On a static aggregate interface, you can execute this command, but the setting cannot take effect.
# Specify port speed as the prioritized criterion for reference port selection on Layer 2 dynamic aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] lacp select speed
lacp system-mac
Use lacp system-mac to set the LACP system MAC address.
Use undo lacp system to restore the default.
lacp system-mac mac-address
undo lacp system-mac
The LACP system MAC address is the bridge MAC address of the device.
mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be an all-zero, all-F, or multicast MAC address.
All S-MLAG devices must use the same LACP system MAC address.
LACPDUs carry the LACP system MAC address configured by using this command. To identify the LACP system MAC address used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
You can configure the LACP system MAC address globally and in aggregate interface view. The global LACP system MAC address takes effect on all aggregation groups, and an aggregate-interface-specific LACP system MAC address takes precedence over the global LACP system MAC address.
On an M-LAG system, M-LAG interfaces in the same M-LAG group cannot use the same LACP system MAC address.
# Set the LACP system MAC address to 0001-0001-0001.
[Sysname] lacp system-mac 1-1-1
lacp system-number
Use lacp system-number to set the LACP system number used by the local device.
Use undo lacp system-number to restore the default.
lacp system-number number
The LACP system number is not set.
number: Specifies a number in the range of 1 to 3.
You must assign a unique LACP system number to each S-MLAG device.
The LACP system number configured by using this command takes effect only on aggregate interfaces in S-MLAG groups. Aggregate interfaces not in S-MLAG groups do not use the configured LACP system number in LACPDUs. To view the LACP system number in LACPDUs, examine the Index field in the output from the display link-aggregation verbose command.
# Set the LACP system number to 1.
[Sysname] lacp system-number 1
Use lacp system-priority to set the LACP system priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The LACP system priority is 32768.
priority: Specifies the LACP system priority in the range of 0 to 65535. The smaller the value, the higher the LACP system priority.
LACPDUs carry the LACP system priority configured by using this command. To identify the LACP system priority used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
You can configure the LACP system priority globally and in aggregate interface view. The global LACP system priority takes effect on all aggregation groups, and an aggregate-interface-specific LACP system priority takes precedence over the global LACP system priority.
# Set the LACP system priority to 64.
[Sysname] lacp system-priority 64
Use lacp transparent enable to enable transparent LACPDU transmission on an interface.
Use undo lacp transparent enable to disable transparent LACPDU transmission on an interface.
Transparent LACPDU transmission is disabled on an interface.
To establish a dynamic aggregation between two remote CEs in an L2VPN network, use transparent LACPDU transmission on the PEs to which the CEs are attached.
On the PEs, enable transparent LACPDU transmission on the interfaces that transmit traffic between CEs and PEs and between PEs.
Do not use an interface for dynamic link aggregation if you enable transparent LACPDU transmission on that interface. With transparent LACPDU transmission enabled, an interface cannot be selected for aggregation.
You must enable transparent LACPDU transmission on a Layer 2 Ethernet interface facing the public network. You do not need to enable transparent LACPDU transmission on a Layer 3 Ethernet interface facing the public network.
# Enable transparent LACPDU transmission on HundredGigE 1/0/1.
<Sysname> system
[Sysname-HundredGigE1/0/1] lacp transparent enable
Use link-aggregation auto-aggregation enable to enable automatic link aggregation.
Use undo link-aggregation auto-aggregation enable to disable automatic link aggregation.
Automatic link aggregation is disabled.
After you enable automatic link aggregation and LLDP on two connected devices, they automatically establish a dynamic link aggregation based on the information in incoming LLDP frames. The devices each automatically create a dynamic aggregate interface and assign the redundant ports connected to the peer to the aggregation group of that interface. If you disable LLDP or automatic link aggregation on one device, that device removes the aggregation member ports from the aggregation group, but it will retain the aggregate interface. This event will not trigger member port removal actions on the peer device.
If automatic link aggregation is enabled, subinterface creation might fail on LLDP-enabled Layer 3 Ethernet interfaces. As a best practice, do not create subinterfaces on LLDP-enabled Layer 3 Ethernet interfaces.
To ensure correct operation of an automatically created aggregate interface, do not modify the configuration on the member ports of its aggregation group. Doing so might cause the member ports to be removed from the aggregation group.
For M-LAG to operate correctly, do not use this command on an M-LAG system.
On an interface, the port link-aggregation group setting takes precedence over automatic link aggregation. The interface will not be added to the aggregation group of an automatically created aggregate interface if it has been the member port of a manually created aggregate interface.
# Enable automatic link aggregation.
<Sysname> system
[Sysname] link-aggregation auto-aggregation enable
lldp enable
lldp global enable
Use link-aggregation bfd to enable BFD for an aggregation group.
Use undo link-aggregation bfd to disable BFD for an aggregation group.
link-aggregation bfd { ipv4 | ipv6 } source { ipv4-address | ipv6-address } destination { ipv4-address | ipv6-address }
undo link-aggregation bfd [ ipv4 | ipv6 ]
BFD is disabled for an aggregation group.
ipv4: Specifies IPv4 BFD.
ipv6: Specifies IPv6 BFD.
source: Specifies the unicast source IP address of BFD sessions.
destination: Specifies the unicast destination IP address of BFD sessions.
ipv4-address: Specifies an IPv4 address. The address cannot be 0.0.0.0.
ipv6-address: Specifies an IPv6 address. The address cannot be 0::0.
Make sure the source and destination IP addresses are reversed between the two ends of an aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 at the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 at the peer end. The source and destination IP addresses cannot be the same.
The BFD parameters configured on an aggregate interface take effect on all BFD sessions established by the member ports in its aggregation group. BFD on a link aggregation supports only control packet mode for session establishment and maintenance. The two ends of an established BFD session can only operate in Asynchronous mode. For more information about BFD, see High Availability Configuration Guide.
As a best practice, do not configure BFD for any protocols on a BFD-enabled aggregate interface.
Make sure the number of member ports in the BFD-enabled aggregation group is less than or identical to the number of BFD sessions supported by the device. If the aggregation group contains more member ports than the supported sessions, some Selected ports might change to the Unselected state.
If the number of BFD sessions differs between the two ends of an aggregate link, check their settings for inconsistency in the maximum number of Selected ports. You must make sure the two ends have the same setting for the maximum number of Selected ports.
You can configure both IPv4 and IPv6 BFD. If you configure a BFD type multiple times, the most recent configuration takes effect.
If both IPv4 and IPv6 BFD sessions exist on an aggregate interface, the device places the aggregation member ports in Unselected state when either IPv4 or IPv6 BFD detects a link failure.
# Enable BFD for Layer 2 aggregation group 1, and specify the source and destination IP addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions.
[Sysname-Bridge-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
Use link-aggregation bfd-compatible enable to enable BFD compatible mode on an aggregate interface.
Use undo link-aggregation bfd-compatible enable to disable BFD compatible mode on an aggregate interface.
BFD compatible mode is disabled on aggregate interfaces.
BFD compatible mode enables BFD to operate correctly on an aggregate link whose remote end is a third-party device that implements BFD differently from the device.
With BFD compatible mode enabled, all member ports in an aggregation group establish BFD sessions with their peer ports. The BFD sessions are not deleted or re-established when the aggregation states of the member ports change.
# Enable BFD compatible mode on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-aggregation bfd-compatible enable
# Enable BFD compatible mode on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation bfd-compatible enable
Use link-aggregation capability to configure the link aggregation capability for the device.
Use undo link-aggregation capability to restore the default.
link-aggregation capability max-group max-group-number max-selected-port max-selected-port-number
The device can have a maximum of 1024 aggregation groups and each aggregation group can have a maximum of 16 Selected ports.
max-group max-group-number: Specifies the maximum number of aggregation groups that the device supports. The value for the max-group-number argument can be 64, 128, 256, 512, or 1024.
max-selected-port max-selected-port-number: Specifies the maximum number of Selected ports per aggregation group. The value for the max-selected-port-number argument can be 16, 32, 64, 128, or 256.
After you execute this command, save the configuration and reboot the device for the configuration to take effect. Before rebooting the device, make sure you know the possible impact on the network.
This command fails if the number of existing aggregation groups exceeds the configured maximum number.
If you create aggregation groups after executing the link-aggregation capability command and the number of aggregation groups exceeds the configured number, some aggregation groups are deleted at the next reboot.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
·     Maximum number set by using the link-aggregation selected-port maximum command.
·     Maximum number of Selected ports allowed by the link aggregation capability.
For link aggregation to operate correctly, set the same link aggregation capability for both ends of an aggregate link.
If you execute this command multiple times, the most recent configuration takes effect at the next reboot.
# Configure the device to support a maximum of 1024 aggregation groups and a maximum of 16 Selected ports per aggregation group.
[Sysname] link-aggregation capability max-group 1024 max-selected-port 16
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Please save the configuration, and reboot the device.
Use link-aggregation global load-sharing algorithm to configure a link aggregation load sharing algorithm.
Use undo link-aggregation global load-sharing algorithm to restore the default.
link-aggregation global load-sharing algorithm algorithm-number
Algorithm 4 is used in link aggregation load sharing.
algorithm algorithm-number: Specifies an algorithm by its number. The value range for the algorithm-number argument is 1 to 11.
This command does not take effect on per-flow load sharing.
The load sharing algorithm determines the CRC calculation method. In default load sharing mode, if the device fails to load share traffic flows across all Selected ports, repeat the following procedure until the problem is resolved:
1.     Configure the load sharing algorithm.
2.     Use the display counters command to view traffic statistics on Selected ports.
You can use a load sharing algorithm and a hash seed individually or in combination to obtain the optimal load sharing performance.
# Specify algorithm 1 as the link aggregation load sharing algorithm.
[Sysname] link-aggregation global load-sharing algorithm 1
display counters (Interface Command Reference)
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port |flow-label | ingress-port | ip-protocol | source-ip | source-mac | source-port } * }
Layer 2 frames are load shared based on the source and destination MAC addresses.
Layer 3 packets are load shared based on the source and destination MAC addresses, source and destination IP addresses, and port numbers.
destination-ip: Distributes traffic based on destination IP addresses.
destination-mac: Distributes traffic based on destination MAC addresses.
destination-port: Distributes traffic based on destination ports.
flow-label: Distributes traffic based on flow labels.
ingress-port: Distributes traffic based on ingress ports.
ip-protocol: Distributes traffic based on IP protocol types.
source-ip: Distributes traffic based on source IP addresses.
source-mac: Distributes traffic based on source MAC addresses.
source-port: Distributes traffic based on source ports.
If an unsupported load sharing mode is set, the device displays an error message.
The global link-aggregation load sharing mode can be any combination of the hashing keys.
The ip load-sharing mode command and the link-aggregation load-sharing mode command are mutually exclusive. If you execute both commands, the command executed later takes effect. For more information about the ip load-sharing mode command, see Layer 3—IP Routing Configuration Guide.
When symmetric load sharing is enabled, the device uses the source and destination MAC addresses, IP addresses, or port numbers as hash keys in pairs for link-aggregation load sharing. If you specify one of the hash keys in a pair, the device will use both hash keys in that pair for load sharing. For example, if you specify the source MAC address, the device uses both source and destination MAC addresses for load sharing.
For more information about symmetric load sharing, see IP forwarding basics configuration in Layer 3—IP Routing Configuration Guide.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
Use link-aggregation global load-sharing offset to set a hash offset to adjust the load balancing hash results on link aggregations.
Use undo link-aggregation global load-sharing offset to restore the default.
link-aggregation global load-sharing offset offset-value
The hash offset of load balancing hash results is 0.
offset-value: Specifies a hash offset. The value range for this argument is 0 to 15.
IMPORTANT
IMPORTANT:
Misuse of this command causes unbalanced traffic distribution. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
If undesirable traffic imbalance occurs on link aggregations, you can use this command to adjust the load sharing results on link aggregations.
# Set the hash offset to 2 for the load balancing hash results on link aggregations.
<Sysname> system
[Sysname] link-aggregation global load-sharing offset 2
Use link-aggregation global load-sharing seed to configure a link aggregation load sharing hash seed.
Use undo link-aggregation global load-sharing seed to restore the default.
link-aggregation global load-sharing seed seed-number
The link aggregation load sharing hash seed is 0x1.
seed seed-number: Specifies a seed. The value range for the seed-number argument is 0 to FFFF.
The load sharing hash seed is a parameter used in hashing. In default load sharing mode, if the device fails to load share traffic flows across all Selected ports, repeat the following procedure until the problem is resolved:
1.     Configure the load sharing hash seed.
# Specify 1023 (3FF in hexadecimal format) as the link aggregation load sharing hash seed.
[Sysname] link-aggregation global load-sharing seed 3FF
Use link-aggregation ignore speed to configure the system to ignore port speed when it sets the aggregation states of the member ports in an aggregation group.
Use undo link-aggregation ignore speed to restore the default.
The system does not ignore port speed when it sets the aggregation states of the member ports in an aggregation group.
IMPORTANT
IMPORTANT:
·     When you execute this command or its undo form, the operational key changes and the aggregate interface flaps temporarily.
·     This command might cause traffic loss on Selected ports operating at a speed lower than the other Selected ports in the aggregation group when traffic is distributed among the ports.
This command allows ports at a different speed than the reference port to become Selected by ignoring the port speed during operational key calculation.
You must configure the same port speed ignoring setting at the two ends of a static configuration to ensure that the peer ports are placed in the same aggregation state. This requirement does not apply to a dynamic aggregation, on which the two ends negotiate the aggregation state of the peer ports automatically.
# Configure the system to ignore port speed when it sets the aggregation states of member ports in Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation ignore speed
Use link-aggregation lacp isolate to isolate aggregate interfaces on the device.
Use undo link-aggregation lacp isolate to remove aggregate interface isolation.
link-aggregation lacp isolate [ bagg | ragg ]
undo link-aggregation lacp isolate [ bagg | ragg ]
Aggregate interfaces are not isolated.
bagg: Isolates Layer 2 aggregate interfaces on the device.
ragg: Isolates Layer 3 aggregate interfaces on the device.
Aggregate interface isolation is applicable to the aggregate interfaces that act as M-LAG interfaces when the device acts an M-LAG member device in an M-LAG system. It gracefully changes all M-LAG interfaces on the device to the Unselected state and switch traffic over to their counterpart M-LAG interfaces on the other M-LAG member device.
This feature takes effect only on dynamic aggregate interfaces. It cannot isolate static aggregate interfaces or peer-link interfaces in an M-LAG system.
As a best practice, make sure no M-LAG interfaces are in M-LAG MAD DOWN state before you isolate them. If one of the M-LAG interfaces is in M-LAG MAD DOWN state when you isolate them, that M-LAG interface will persist in that state and cannot forward traffic after the isolation is removed.
If you do not specify any keywords, this command isolates all aggregate interfaces on the device.
# Isolate aggregate interfaces.
[Sysname] link-aggregation lacp isolate
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
This feature redirects traffic on a Selected port to the remaining available Selected ports of an aggregation group if one of the following events occurs:
·     The port is shut down by using the shutdown command.
·     The slot that hosts the port reboots, and the aggregation group spans multiple slots.
The device does not redirect traffic to member ports that become Selected during the traffic redirection process.
This feature ensures zero packet loss for known unicast traffic, but does not protect unknown unicast traffic.
This feature applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
To prevent packet loss that might occur when a slot reboots, do not enable spanning tree together with link-aggregation traffic redirection.
Global link-aggregation traffic redirection settings take effect on all aggregation groups. A link aggregation group preferentially uses the group-specific link-aggregation traffic redirection settings. If group-specific link-aggregation traffic redirection is not configured, the group uses the global link-aggregation traffic redirection settings.
As a best practice, enable link-aggregation traffic redirection on a per-interface basis. If you enable this feature globally, communication with a third-party peer device might be affected if the peer is not compatible with this feature.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode dynamic
Use link-aggregation load-sharing mode dynamic to configure a dynamic load sharing mode on an aggregate interface.
Use undo link-aggregation load-sharing mode dynamic to restore the default.
link-aggregation load-sharing mode dynamic { eligible [ flowlet-gap-time flowlet-gap-time ] | fixed | spray }
An aggregation group uses the static load sharing mode.
eligible: Specifies the eligible mode. This mode distributes the traffic from a flow on a per-flowlet basis. Flowlets are bursts of packets from a flow, which are separated based on the flowlet gap timer. If the forwarding latency between two bursts of packets is larger than the flowlet gap timer, they are two flowlets and can be forwarded on different links. The link selected for a flowlet is the least utilized link at the time of selection.
flowlet-gap-time flowlet-gap-time: Sets the flowlet gap timer, in microseconds. The value range for the timer is 1 to 2000. The default is 1000.
fixed: Specifies the fixed mode. This mode distributes traffic across the aggregation member links on a per-flow basis. The link selected for a flow is the least utilized link at the time of selection.
spray: Specifies the spray mode. This mode distributes traffic across the aggregation member links on a per-packet basis. The link selected for a packet is the least utilized link at the time of selection.
IMPORTANT
IMPORTANT:
In spray mode, packets in a flow might be distributed to different links and arrive at the receiving device out of order. When you use this mode, you must make sure the receiving device supports packet reordering.
The dynamic load sharing mode has priority over the static load sharing mode configured by using the link-aggregation load-sharing mode command.
# Enable the eligible dynamic load sharing mode on interface Bridge-Aggregation 1 and set the flowlet gap timer to 2000 microseconds.
[Syaname] interface bridge-aggregation 1
[Syaname-Bridge-Aggregation1] link-aggregation load-sharing mode dynamic eligible flowlet-gap-time 2000
link-aggregation management-port
Use link-aggregation management-port to configure a management port for an aggregation group.
Use undo link-aggregation management-port to restore the default.
A port does not act as a management port.
You can execute this command on multiple member ports of an aggregation group. The system chooses the member port with the smallest port number as the management port of the aggregation group.
# Configure HundredGigE 1/0/1 as the management port of its aggregation group.
[Sysname-HundredGigE1/0/1] link-aggregation management-port
link-aggregation management-subnet
Use link-aggregation management-subnet to specify a link aggregation management subnet.
Use undo link-aggregation management-subnet to remove a link aggregation management subnet.
link-aggregation management-subnet ip-address { mask | mask-length }
undo link-aggregation management-subnet ip-address { mask | mask-length }
No link aggregation management subnets are specified.
ip-address: Specifies an IP address in dotted decimal notation.
mask: Specifies the subnet mask in dotted decimal notation.
mask-length: Specifies the mask length. The value range is 0 to 32.
Typically, an aggregate interface distributes traffic across its Selected member ports. The uplink and downlink traffic of a host might be distributed to different member ports. To make sure the bidirectional traffic of a subnet traverses the same member port, you can exclude that subnet from load sharing by specifying it as a link aggregation management subnet.
When a link aggregate interface receives an ARP packet from the management subnet, the device looks up the sender IP address in the ARP table for a matching entry.
·     If no matching entry exists, the device creates an ARP entry on the aggregation member port from which the packet came in. This mechanism ensures that the returned downlink traffic will be forwarded out of the member port that received the uplink traffic.
·     If an ARP entry already exists on a different port than the link aggregate interface or its member ports, the device does not update that ARP entry. Instead, the device broadcasts an ARP request out of all ports to relearn the ARP entry.
When a link aggregate interface sends an ARP packet to the management subnet, the device sends the packet out of all Selected member ports of the link aggregate interface.
You can configure a maximum of 20 management subnets.
To ensure correct packet forwarding, delete all ARP entries of a subnet before you specify it as a management subnet or after you remove it from the management subnet list.
If you are using link aggregation management subnets, do not use the following features:
·     M-LAG. For more information about M-LAG, see Layer 2—LAN Switching Configuration Guide.
·     ARP snooping. For more information about ARP snooping, see Layer 3—IP Services Configuration Guide.
# Specify 22.1.1.1/8 as a link aggregation management subnet.
[Sysname] link-aggregation management-subnet 22.1.1.1 255.0.0.0
link-aggregation management-vlan
Use link-aggregation management-vlan to specify link aggregation management VLANs.
Use undo link-aggregation management-vlan to remove link aggregation management VLANs.
link-aggregation management-vlan vlan-id-list
undo link-aggregation management-vlan vlan-id-list
No link aggregation management VLANs are specified.
vlan-id-list: Specifies a space-separated list of up to 10 link aggregation management VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
If you execute this command multiple times, the system allows all specified management VLANs whose total number cannot exceed 64.
You cannot specify VLAN 1 as a link aggregation management VLAN.
# Specify VLAN 2 and VLAN 3 as link aggregation management VLANs.
[Sysname] link-aggregation management-vlan 2 3
Use link-aggregation mode to set the aggregation mode of an aggregation group.
Use undo link-aggregation mode to restore the default.
link-aggregation mode { dynamic | static [ backup ] }
An aggregation group operates in static aggregation mode.
dynamic: Specifies dynamic mode and enables LACP.
static: Specifies static mode.
backup: Specifies static 1+1 backup mode. If you do not specify this keyword, 1+1 backup is not enabled. Only Layer 3 aggregate interfaces support this keyword.
When you change the aggregation mode, make sure you understand the impact of the change on services.
Aggregation mode change might cause Selected member ports to become Unselected.
The following restrictions apply to an aggregation group operating in 1+1 backup mode:
·     The aggregation group can contain a maximum of two member ports.
·     The maximum and minimum limits on the number of Selected ports in the aggregation group do not take effect.
# Configure Layer 2 aggregation group 1 to operate in dynamic aggregation mode.
link-aggregation port-priority
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
The port priority of an interface is 32768.
priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 2 Ethernet interface HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] link-aggregation port-priority 64
# Set the port priority to 64 for Layer 3 Ethernet interface HundredGigE 1/0/2.
[Sysname] interface hundredgige 1/0/2
[Sysname-HundredGigE1/0/2] link-aggregation port-priority 64
link-aggregation primary-port
Use link-aggregation primary-port to assign the primary role to a member port in a 1+1 backup aggregation group.
Use undo link-aggregation primary-port to restore the default.
A member port is not assigned the primary role in a 1+1 backup aggregation group.
In a 1+1 backup aggregation group, the primary member port is placed in Selected state to forward all traffic, and the secondary member port is placed in Unselected state as a standby. You can specify a primary member port with this command or let the system to select a primary member port. If you specify a primary member port for a 1+1 backup aggregation group, the aggregation group can revert to the primary member port when that port recovers from failure. As a best practice, use this command to manually specify a primary member port.
If you do not specify a primary member port for an aggregation group, the system acts as follows:
·     Assigns the primary role to the reference port if the member ports join the aggregation group simultaneously.
·     Assigns the primary role to the member port that first becomes Selected if the member ports join the aggregation group successively.
This command is not available on a port that is not an aggregation group member or is in an aggregation group not operating in 1+1 backup mode.
A 1+1 backup aggregation group can have only one primary member port.
# Assign the primary role to HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] port link-aggregation group 1
[Sysname-HundredGigE1/0/1] link-aggregation primary-port
link-aggregation reversion delay
Use link-aggregation reversion delay to set the reversion delay for a 1+1 backup aggregation group.
Use undo link-aggregation reversion delay to restore the default.
link-aggregation reversion delay time-value
A 1+1 backup aggregation group reverts to the primary member port immediately after that port recovers from failure.
time-value: Sets a reversion delay in the range of 1 to 65535 seconds.
The reversion delay is the time a 1+1 backup aggregation group must wait before reverting to the primary member port after that port recovers from failure. This timer prevents link flapping from causing frequent primary/secondary member port switchovers.
For this command to take effect on an aggregation group, first configure the aggregation group to operate in 1+1 backup mode and manually specify its primary member port.
# Set the reversion delay to 5 seconds on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation reversion delay 5
link-aggregation secondary-down
Use link-aggregation secondary-down to configure a 1+1 backup aggregation group to place its secondary member port in down state.
Use undo link-aggregation secondary-down to restore the default.
In a 1+1 backup aggregation group, the secondary member port is in Unselected state.
If the peer for a 1+1 backup aggregation group is unaware of the member port roles, it might send traffic to the secondary member port, and traffic loss occurs consequently. To prevent traffic loss, configure the aggregation group to place its secondary member port in down state. This allows the peer and local ends to use only up ports to transmit traffic.
For this command to take effect on an aggregation group, first configure the aggregation group to operate in 1+1 backup mode.
# Configure Route-Aggregation 1 to place its secondary member port in down state.
[Sysname-Route-Aggregation1] link-aggregation secondary-down
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number [ lacp-sync ]
An aggregation group can contain a maximum of 16 Selected ports.
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 256.
lacp-sync: Synchronizes the maximum number of Selected ports through LACPDUs. If you do not specify this keyword, the aggregate interface does not synchronize the maximum number of Selected ports with the peer.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
On a static aggregate link, you must set the maximum number of Selected ports to the same value at its two ends.
On a dynamic aggregate link, you must set the maximum number of Selected ports to the same value at its two ends if you do not specify the lacp-sync keyword. If you specify this keyword, the two ends of the aggregate link compare their maximum Selected port number settings and use the smaller value.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
You can implement backup between two ports by performing the following tasks:
·     Assigning two ports to an aggregation group.
·     Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
link-aggregation selected-port minimum
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
The minimum number of Selected ports in an aggregation group is not specified.
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 256.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the minimum number of Selected ports must be equal to or lower than the maximum number of Selected ports.
# Set the minimum number of Selected ports to 3 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
link-aggregation selected-port minimum percentage
Use link-aggregation selected-port minimum percentage to set the minimum percentage of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum percentage to restore the default.
link-aggregation selected-port minimum percentage number
The minimum percentage of Selected ports is not set for an aggregation group.
number: Specifies the minimum percentage of Selected ports. The value range for this argument is 1 to 100.
CAUTION
CAUTION:
After you execute this command, aggregate interface flapping might occur when ports join or leave an aggregation group. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
You must set the same minimum percentage of Selected ports at the two ends of an aggregate link.
The minimum number of Selected ports in an aggregation group equals the higher one of the following values:
·     The number of member ports in the aggregation group multiplied by the minimum percentage of Selected ports.
·     The limit set by using the link-aggregation selected-port minimum command.
# Set the minimum percentage of Selected ports to 50% for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum percentage 50
# Set the minimum percentage of Selected ports to 50% for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum percentage 50
link-aggregation switchover
Use link-aggregation switchover to perform a primary/secondary member port switchover in a 1+1 backup aggregation group.
CAUTION
CAUTION:
This command might cause traffic loss. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
Use this command to switch member port roles for a 1+1 backup aggregation group whose primary member port is set by the system when the state of peer ports changes.
If the link-aggregation secondary-down command has been executed for the aggregation group, the link-aggregation switchover command brings up the down secondary member port for it to take over the primary role.
Before you execute the link-aggregation switchover command for a 1+1 backup aggregation group, verify that the following requirements are met:
·     The aggregation group contains one Selected port and one Unselected port.
·     The primary member port is set by the system.
·     The secondary member port can become Selected.
# Perform a primary/secondary member port switchover in the aggregation group of Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation switchover
This operation will change the current link status. Continue? [Y/N]:
mac-address
Use mac-address to assign a MAC address to an aggregate interface or subinterface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
No MAC address is assigned to an aggregate interface.
The default MAC address of Layer 3 aggregate interfaces varies by device. You can use the display interface command to view the MAC address of a Layer 3 aggregate interface.
When you assign a MAC address to a Layer 3 interface after a base MAC address has been configured, make sure the following requirements are met:
·     The MAC address must have the same higher 36 bits as the base MAC address.
·     The MAC address must be equal to or higher than the base MAC address plus 160 (decimal).
For more information about the base MAC address, see MAC address table configuration in Layer 2—LAN Switching Configuration Guide.
# Assign MAC address 0001-0001-0002 to interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] mac-address 1-1-2
mtu
Use mtu to set the MTU of a Layer 3 aggregate interface or subinterface.
mtu size
undo mtu
The MTU of Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
size: Specifies an MTU in bytes. The value range for this argument is 46 to 9216..
# Set the MTU of interface Route-Aggregation 1 to 1430 bytes.
[Sysname-Route-Aggregation1] mtu 1430
display interface
port lacp system-mac
Use port lacp system-mac to set the LACP system MAC address on an aggregate interface.
Use undo port lacp system to restore the default.
port lacp system-mac mac-address
undo port lacp system-mac
Member devices in an S-MLAG system must use the same LACP system MAC address.
On an M-LAG system, M-LAG interfaces in the same M-LAG group must use the same LACP system MAC address.
# Set the LACP system MAC address to 0002-0002-0002 on an aggregate interface.
[Sysname-Bridge-Aggregation1] port lacp system-mac 2-2-2
lacp system-mac
port lacp system-priority
Use port lacp system-priority to set the LACP system priority on an aggregate interface.
Use undo port lacp system-priority to restore the default.
port lacp system-priority priority
Member devices in an S-MLAG system must use the same LACP system priority.
# Set the LACP system priority to 32 on an aggregate interface.
[Sysname-Bridge-Aggregation1] port lacp system-priority 32
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
port link-aggregation group { group-id [ force ] | auto [ group-id ] }
An interface does not belong to any aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. In versions earlier than Release 5212P01, the value range for this argument is 1 to 1024. In Release 5212P01 and later, the value range for this argument is 1 to 4096.
force: Enables the current interface to synchronize attribute configurations from the aggregate interface. If you do not specify this keyword, the current interface does not synchronize attribute configurations from the aggregate interface when it joins the aggregation group. This keyword is supported only on Layer 2 Ethernet interfaces.
auto: Enables automatic assignment.
A Layer 2 Ethernet interface can be assigned only to a Layer 2 aggregation group. A Layer 3 Ethernet interface or subinterface can be assigned only to a Layer 3 aggregation group.
An interface can belong to only one aggregation group.
An interface cannot join an aggregation group if it has different attribute configurations from the aggregate interface. After joining an aggregation group, an interface inherits the attribute configurations on the aggregate interface. You can modify the attribute configurations only on the aggregate interface.
MACsec is mutually exclusive with link aggregation on LSXM1CGQ72KCR1 modules and LSXM1CDMS36KCR1 modules. You cannot assign interfaces with MACsec enabled to an aggregation group, and you cannot enable MACsec on interfaces assigned to an aggregation group. For more information, see MACsec configuration in Security Configuration Guide.
The force keyword takes effect only when you assign the interface to an aggregation group. It cannot be saved in the running configuration or a configuration file.
You cannot assign both Ethernet interfaces and Ethernet subinterfaces to an aggregation group. You cannot create subinterfaces on an Ethernet interface that is in an aggregation group. You cannot assign an Ethernet interface that has subinterfaces to an aggregation group.
You cannot create aggregate subinterfaces on an aggregate interface if its aggregation group contains Ethernet subinterfaces. You cannot assign Ethernet subinterfaces to an aggregation group if its aggregate interface has aggregate subinterfaces.
Automatic assignment is available only on Layer 2 and Layer 3 Ethernet interfaces.
When you enable automatic assignment, you can specify a preferred aggregation group, which must be in dynamic mode.
The device assigns the interface to the preferred aggregation group as long as the LACPDUs received on the interface match the peer information of the reference port in the group.
If you do not specify a preferred group or if the preferred group match fails, the device attempts to select a matching group from the existing dynamic aggregation groups. If no match is found, the device creates a dynamic aggregation group based on the LACPDUs and assigns the interface to that aggregation group.
As a best practice, do not modify the configuration on an automatically created aggregate interface or its member ports.
You cannot assign the following interfaces to an aggregation group:
·     Member interfaces of redundant Ethernet interfaces.
·     Member interfaces of redundancy group nodes.
For more information about redundant Ethernet interfaces and redundancy group nodes, see High Availability Configuration Guide.
# Assign Layer 2 Ethernet interface HundredGigE 1/0/1 to Layer 2 aggregation group 1.
# Assign Layer 3 Ethernet interface HundredGigE 1/0/2 to Layer 3 aggregation group 2.
[Sysname-HundredGigE1/0/2] port link-aggregation group 2
port s-mlag group
Use port s-mlag group to assign an aggregate interface to an S-MLAG group.
Use undo port s-mlag group to restore the default.
port s-mlag group group-id
An aggregate interface is not in any S-MLAG group.
group-id: Specifies an S-MLAG group number in the range of 1 to 1024.
You can assign only Layer 2 aggregate interfaces in dynamic mode to an S-MLAG group.
Each S-MLAG group can contain only one aggregate interface on each device.
The aggregate interfaces in an S-MLAG group cannot be used as M-LAG interfaces or M-LAG peer-link interfaces. For more information about M-LAG interfaces and peer-link interfaces, see M-LAG configuration in Layer 2—LAN Switching Configuration Guide.
# Assign Bridge-Aggregation 1 to S-MLAG group 1.
[Sysname-Bridge-Aggregation1] port s-mlag group 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics for the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number1 argument must be equal to or greater than the value for the interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics for all member ports.
# Clear LACP statistics for all link aggregation member ports.
<Sysname> reset lacp statistics
display link-aggregation member-port
sub-interface rate-statistic
Use sub-interface rate-statistic to enable rate statistics collection for the subinterfaces of a Layer 3 aggregate interface.
Use undo sub-interface rate-statistic to disable rate statistics collection for the subinterfaces of a Layer 3 aggregate interface.
Rate statistics collection is disabled for Layer 3 aggregate subinterfaces.
Rate statistics collection for Layer 3 aggregate subinterfaces is resource intensive. When you use this feature on a live network, make sure you fully understand its impact.
This command enables the device to periodically refresh rate statistics for the subinterfaces of a Layer 3 aggregate interface. The rate statistics are available in two statistics polling intervals after you execute this command. To set the statistics polling interval, use the flow-interval command.
# Enable rate statistics collection for the subinterfaces of Route-Aggregation 1.
[Sysname-Route-Aggregation1] sub-interface rate-statistic
This configuration may make a negative effect on the performance. Are you sure to continue? [Y/N]:y
The configuration will take effect after 2 flow intervals.
flow-interval (Interface Command Reference)
